Date/Time: Wed, 27 Nov 2024 18:43:44 +0000
[Locked] - RGB colors
View Count: 1364
[2014-09-27 23:09:12] |
marcovth - Posts: 61 |
Hello ... Is there a function that would allow me to obtain the three R,G,B values in a given RGB color? Thanks |
[2014-09-28 05:21:48] |
Yes, and you should be able to find this just by performing an Internet search.
[2014-09-28 22:48:37] |
This the way to make a given color a bit darker ... int rc = GetRValue(bar.PrimaryColor); if(rc>=100) rc=rc-75; int gc = GetGValue(bar.PrimaryColor); if(gc>=100) gc=gc-75; int bc = GetBValue(bar.PrimaryColor); if(bc>=100) bc=bc-75; bar.DataColor=RGB(rc,gc,bc); |
