Date/Time: Tue, 15 Apr 2025 13:54:18 +0000
Last Trade Price Box text color
View Count: 51
[2025-04-08 13:18:40]
User781731 - Posts: 49
Is it possible to change the color of the text in Last Trade Price Box? It is white even though the text color on the price scale is black
I thought perhaps it was the "Last Trade Price Box Foreground" option but "Enable" is greyed out and I can't click it.
[2025-04-08 15:02:51]
John - SC Support - Posts: 39274
It is the "Last Trade Price Box Foreground". Change the color for this item to change the color of the text in the last trade price box in the Price Ladder.
When a Graphics Setting item has the "Enable" option grayed out and non-selectable, this means that the item is always enabled and does not need to be specifically enabled.
[2025-04-08 15:09:02]
Thank you.
When I change the color of Last Trade Price Box Foreground, it does not change the color of the text in the box. The text color in box is white no matter what I change the color to in that setting.
I am doing this via Graphics Settings - Global. The Graphics Settings - Chart is set to Use Global
I tried Disconnect and Connect to the data feed after making the change. For about 1-2 seconds after it connects, it shows the correct color (I chose pink as an example) but then it quickly changes to white again.
There must be some other setting which impacts this setting?
[2025-04-08 15:40:21]
Check to see if you have the settings for "Chart DOM Last Price Text Bid Trade" and/or "Chart DOM Last Price Text Ask Trade" enabled. These will change the color of the text based on whether the last trade was at the Bid or Ask. Turn off the "Enable" options for these to not use them.
