Date/Time: Fri, 18 Apr 2025 06:28:17 +0000
Issues routing orders from trade DOM
View Count: 162
[2025-03-26 00:32:09] |
Kurt2951 - Posts: 4 |
I am having significant issues routing orders from my Sierra Charts DOM. I have checked to see if I am running multiple instances of charts or DOMS and as far as I can tell I am not. Specifically what is happening: 1) On multiple occasions my Dom is working just fine and then suddenly I can only enter sell side orders. Buy side orders do not work at all. Nothing happens when I hit the order button. 2) on other occasions the DOM is just not responsive at all - on either side. 3) Several times my breakeven stop has failed Attached are my Dom settings - they were set the same when these issues happened. |
[2025-03-26 07:59:54] |
Sierra_Chart Engineering - Posts: 19259 |
This does not matter and is not a problem: . I have checked to see if I am running multiple instances of charts or DOMS and as far as I can tell I am not.
1. Reset the scale: The Chart DOM Scale Check for order rejections in the Trade Service Log: Trading Information Windows: Trade Service Log 2. Same answer as above. But we are not fully understanding this. 3. Check the Trade Activity Log for any indication of why this would be the case: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-26 08:00:19
[2025-03-26 15:46:04] |
Thanks for your response I noticed this morning that only the sell side of the DOM is showing activity. No orders showing on the buy side (picture attached). My DOM scaling settings are: interactive scale move and Scale range: constant range. I do not see any rejected orders in the activity logs but I have attached files. My trade activity is all fine up until last night. All orders showing and no sign of any rejected orders. There is just nothing there after the DOM stopped working properly. Thanks again for your help. |
[2025-03-26 18:33:39] |
John - SC Support - Posts: 39353 |
We need to see an image of your DOM since you state that "only the sell side of the DOM is showing activity." Please get us an image by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
