Date/Time: Sat, 19 Apr 2025 09:48:46 +0000
Sierra Chart Paper Demo trading account
View Count: 180
[2025-03-17 18:33:14]
pavel.lysenka - Posts: 7
Hello, is there a way to get a paper demo trading account with paper account balance and etc. just like in a real Account? because the current demo offers only seeing P&L in points and not balance.l
[2025-03-17 20:21:36]
John - SC Support - Posts: 39362
Refer to the following for what we have available:
Simulated Futures Trading Service
[2025-03-18 19:59:38]
Hey, Thank you, I managed to open a Account. But now a new problem arises, when I changed the Account on my main Instance, the other instances also automatically get the account i think, but then the Data just stops working for the other Instances and only my main Instance works, any fixes?
[2025-03-18 22:22:27]
Make sure you have the proper symbols in the sub-instances. If they are not correct for the selected service, then select "Edit >> Translate Symbols to Current Service". Refer to the following:
Edit Menu: Edit >> Translate Symbols To Current Service
[2025-03-19 19:06:51]
I tried to Translate the symbols, but it still stays at the same Price and doesnt move while my main Instance is active. Is there any way I can have all Instances working with using a different Account? Im using the CQG account normally, but when I switch to the Demo account, only the Main instance works.
[2025-03-19 20:04:55]
We are not certain of which way you are asking this question, so we'll answer all the options that we can think of.
The first is that sub-instances, which are started by selecting "File >> New Instance", all share the same trading service. So you can not use different trading services with Sub-Instances - these are going to use the service that is set in the Main Instance. This also means that whatever accounts are available in the Main Instance will also be available in the Sub-Instances.
The one caveat (if you want to call it this) is that sub-instances can also be in "Simulation Mode" when the main instance is not. If you are wanting your trades to go through your main instance, then you need to ensure that the sub-instance does NOT have "Trade >> Trade Simulation On" enabled.
There should not be any difference between using Sub-Instances with CQG versus using them with the Trading Simulator. Again, make sure the sub-instances do not have "Trade >> Trade Simulation Mode On" enabled.
If you are still having an issue with a sub-instance, then we would need to know exactly what is occurring (are you not getting data, or are you not able to place a trade, or something else).
If the problem is data in the sub-instance, then we would need to see the sub-instance Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2025-03-20 17:41:41]
I tried to tujrn off Trade simulation but sadly still, only main Instance is updating price while all the others are stuck at the same Level. Below are Logs when I startup sierra from one of my Sub-instance, and my main instance: (I have 3 Sub-instances and 1 Main instance)
Sub instance:
2025-03-20 18:38:09.442 | Trade activity files set size: 49
2025-03-20 18:38:09.512 | Created the DTC Protocol server.
2025-03-20 18:38:09.515 | DTC Protocol Server listening on port 11112.
2025-03-20 18:38:09.515 | Reading Internal Order ID file.
2025-03-20 18:38:09.518 | Reading Trade Orders file.
2025-03-20 18:38:09.518 | Reading Trade Positions file.
2025-03-20 18:38:09.519 | Reading Trade Account Data files.
2025-03-20 18:38:09.523 | Software version: 2735 64-bit
2025-03-20 18:38:09.523 | Primary Thread ID: 24952
2025-03-20 18:38:09.523 | Usage end date: 2025-04-11
2025-03-20 18:38:09.523 | Enabled for: Advanced Features 2.
2025-03-20 18:38:09.523 | Enabled for: Sierra Chart Historical Data Service.
2025-03-20 18:38:09.523 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-03-20 18:38:09.523 | Enabled for: Delayed Denali Exchange Data Feed.
2025-03-20 18:38:09.523 | Enabled for exchange2: CME
2025-03-20 18:38:09.523 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-03-20 18:38:09.523 | Current selected Data/Trading service: DTC - Sub Instance
2025-03-20 18:38:09.523 | Custom symbol settings values: enabled
2025-03-20 18:38:09.523 | Chart Update Interval: 50
2025-03-20 18:38:09.523 | Intraday Data Storage Time Unit: 0
2025-03-20 18:38:09.523 | Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00)
2025-03-20 18:38:09.523 | 2025-03-20 17:38:09 Local computer time in UTC
2025-03-20 18:38:09.523 | 2025-03-20 18:38:09 Local computer time in SC Time Zone
2025-03-20 18:38:09.523 | 2025-03-20 17:38:09 Server time in UTC
2025-03-20 18:38:09.523 | Local computer UTC time and Server UTC time difference: 0 seconds.
2025-03-20 18:38:09.524 | Program path: C:\SierraChart\SierraChartInstance_3\
2025-03-20 18:38:09.524 | Data Files path: C:\SierraChart\SierraChartInstance_3\Data\
2025-03-20 18:38:09.524 | OS Version Number: 10.0
2025-03-20 18:38:09.524 | Locale Setting: C
2025-03-20 18:38:09.524 | DLLs: gcUserStudies_64.dll, UserContributedStudies_64.dll
2025-03-20 18:38:09.524 | Allowed protected custom studies:
2025-03-20 18:38:09.524 | Crash reporter started: true
2025-03-20 18:38:09.524 | Created the DTC Protocol historical data server.
2025-03-20 18:38:09.528 | Listening socket (1916). Port 0 | Failed to bind socket to 0.0.0.0:11111. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. *
2025-03-20 18:38:09.528 | Listening socket (0). Port 0 | Closed listening socket.
2025-03-20 18:38:09.529 | HD Server Manager | Error starting listening socket on port 11111.
2025-03-20 18:38:09.554 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-03-20 18:38:09.703 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-03-20 18:38:09.703 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-03-20 18:38:10.022 | Received 5 login tokens.
2025-03-20 18:38:12.034 | Requested user files to download.
2025-03-20 18:38:14.035 |
2025-03-20 18:38:14.038 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2025-03-20 18:38:14.038 | DTC Client socket (1) | Creating socket.
2025-03-20 18:38:14.038 | DTC Client socket (1) | New receive buffer size: 0
2025-03-20 18:38:14.038 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2025-03-20 18:38:14.040 | DTC - Sub Instance | Network connection to server complete.
2025-03-20 18:38:14.040 | DTC - Sub Instance | Starting socket receive thread.
2025-03-20 18:38:14.040 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2025-03-20 18:38:14.040 | DTC - Sub Instance | Setting DTC encoding to Binary VLS
2025-03-20 18:38:14.040 | DTC - Sub Instance | Sending logon request message.
2025-03-20 18:38:14.041 | DTC - Sub Instance | Received logon response.
2025-03-20 18:38:14.041 | DTC - Sub Instance | Server Name: SC DTC Server. Build=52277.
2025-03-20 18:38:14.041 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8
2025-03-20 18:38:14.041 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=tradingevaluator.dtctrading|SymbolSettings=tradesimulation.dtctrading.
2025-03-20 18:38:14.041 | DTC - Sub Instance | Trading is supported.
2025-03-20 18:38:14.041 | DTC - Sub Instance | Order cancel and replace is supported.
2025-03-20 18:38:14.041 | DTC - Sub Instance | OCO Orders supported.
2025-03-20 18:38:14.041 | DTC - Sub Instance | Bracket Orders supported.
2025-03-20 18:38:14.041 | DTC - Sub Instance | MarketDepthIsSupported: 1
2025-03-20 18:38:14.041 | DTC - Sub Instance | Connected to server complete.
2025-03-20 18:38:14.042 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-03-20 18:38:17.248 | Files to Open on Startup | Opening file: Footprint TPO ES.Cht
2025-03-20 18:38:17.298 | F.US.EPH25 Renko 8t #1 | Reloading chart.
2025-03-20 18:38:17.315 | F.US.EPH25 #3 | Reloading chart.
2025-03-20 18:38:17.348 | F.US.EPH25 5 Min #4 | Reloading chart.
2025-03-20 18:38:17.367 | F.US.EPH25 10 Min #5 | Reloading chart.
2025-03-20 18:38:17.412 | Using symbol data fast lookup vector
2025-03-20 18:38:17.413 | DTC - Sub Instance | Starting real-time market data updates for: F.US.EPH25. ID: 1
2025-03-20 18:38:17.413 | DTC - Sub Instance | Requesting security definition data for: F.US.EPH25. ID: 1
2025-03-20 18:38:17.413 | No historical data client is currently set to download historical Intraday data for F.US.EPH25.
2025-03-20 18:38:17.413 | Real-time Intraday chart data file updates started for F.US.EPH25
2025-03-20 18:38:17.413 | Intraday chart data file opened for F.US.EPH25
2025-03-20 18:38:17.418 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EPH25 to 3
2025-03-20 18:38:17.418 | DTC - Sub Instance | Received security definition for symbol F.US.EPH25
2025-03-20 18:38:19.859 | F.US.EPH25 5 Min #4 | Chart data loading complete.
2025-03-20 18:38:21.227 | F.US.EPH25 10 Min #5 | Chart data loading complete.
2025-03-20 18:38:22.139 | F.US.EPH25 Renko 8t #1 | StartDateTimeForLoadingOrderFills: 2024-03-11 00:00:00
2025-03-20 18:38:22.154 | Chart #1 has tagged chart #5 for full recalculation. Chartbook: Footprint TPO ES.Cht
2025-03-20 18:38:22.159 | F.US.EPH25 Renko 8t #1 | Chart data loading complete.
2025-03-20 18:38:32.045 | F.US.EPH25 #3 | Chart data loading complete.
2025-03-20 18:38:32.045 | F.US.EPH25 10 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Footprint TPO ES.Cht
Main Instance:
2025-03-20 18:37:50.161 | Trade activity files set size: 55
2025-03-20 18:37:50.216 | Created the DTC Protocol server.
2025-03-20 18:37:50.218 | DTC Protocol Server listening on port 11099.
2025-03-20 18:37:50.218 | Reading Internal Order ID file.
2025-03-20 18:37:50.246 | Reading Trade Orders file.
2025-03-20 18:37:50.246 | Reading Trade Positions file.
2025-03-20 18:37:50.246 | Reading Trade Account Data files.
2025-03-20 18:37:50.249 | Software version: 2735 64-bit
2025-03-20 18:37:50.249 | Primary Thread ID: 15624
2025-03-20 18:37:50.249 | Usage end date: 2025-04-11
2025-03-20 18:37:50.249 | Enabled for: Advanced Features 2.
2025-03-20 18:37:50.249 | Enabled for: Sierra Chart Historical Data Service.
2025-03-20 18:37:50.249 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-03-20 18:37:50.249 | Enabled for: Delayed Denali Exchange Data Feed.
2025-03-20 18:37:50.249 | Enabled for exchange2: CME
2025-03-20 18:37:50.249 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-03-20 18:37:50.249 | Current selected Data/Trading service: Trading Evaluator
2025-03-20 18:37:50.249 | Custom symbol settings values: enabled
2025-03-20 18:37:50.249 | Chart Update Interval: 50
2025-03-20 18:37:50.249 | Intraday Data Storage Time Unit: 0
2025-03-20 18:37:50.249 | Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00)
2025-03-20 18:37:50.249 | 2025-03-20 17:37:50 Local computer time in UTC
2025-03-20 18:37:50.249 | 2025-03-20 18:37:50 Local computer time in SC Time Zone
2025-03-20 18:37:50.249 | 2025-03-20 17:37:50 Server time in UTC
2025-03-20 18:37:50.249 | Local computer UTC time and Server UTC time difference: 1 seconds.
2025-03-20 18:37:50.249 | Program path: C:\SierraChart\
2025-03-20 18:37:50.249 | Data Files path: C:\SierraChart\Data\
2025-03-20 18:37:50.249 | OS Version Number: 10.0
2025-03-20 18:37:50.249 | Locale Setting: C
2025-03-20 18:37:50.250 | DLLs: gcUserStudies_64.dll, UserContributedStudies_64.dll
2025-03-20 18:37:50.250 | Allowed protected custom studies:
2025-03-20 18:37:50.250 | Crash reporter started: true
2025-03-20 18:37:50.266 | Created the DTC Protocol historical data server.
2025-03-20 18:37:50.269 | HD Server Manager | Listening on port 11098.
2025-03-20 18:37:50.269 | Checking for new symbol settings. Requested symbol settings MD5 for service code tradesimulation.dtctrading. Request ID: 1.
2025-03-20 18:37:50.286 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-03-20 18:37:50.439 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-03-20 18:37:50.439 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-03-20 18:37:50.746 | Received 5 login tokens.
2025-03-20 18:37:51.173 | Symbol settings MD5 received. Request ID: 1.
2025-03-20 18:37:51.173 | Symbol settings are up-to-date for tradesimulation.dtctrading.
2025-03-20 18:37:52.770 | Requested user files to download.
2025-03-20 18:37:54.765 |
2025-03-20 18:37:54.767 | Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096
2025-03-20 18:37:54.767 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-03-20 18:37:54.767 | DTC Client socket (1) | New receive buffer size: 0
2025-03-20 18:37:54.767 | DTC Client socket (1) | Connecting to IP: 64.152.155.17.
2025-03-20 18:37:54.913 | Trading Evaluator | Network connection to server complete.
2025-03-20 18:37:54.913 | Trading Evaluator | Starting socket receive thread.
2025-03-20 18:37:54.914 | Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none
2025-03-20 18:37:55.364 | Trading Evaluator | Setting DTC encoding to Binary VLS
2025-03-20 18:37:55.364 | Trading Evaluator | Sending logon request message.
2025-03-20 18:37:55.541 | Trading Evaluator | Received logon response.
2025-03-20 18:37:55.541 | Trading Evaluator | Server Name: SC DTC Server. Build=52391.
2025-03-20 18:37:55.541 | Trading Evaluator | Server protocol version: 8. Client protocol version: 8
2025-03-20 18:37:55.541 | Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradingevaluatorserver.dtctrading.
2025-03-20 18:37:55.541 | Trading Evaluator | Trading is supported.
2025-03-20 18:37:55.541 | Trading Evaluator | Order cancel and replace is supported.
2025-03-20 18:37:55.541 | Trading Evaluator | OCO Orders supported.
2025-03-20 18:37:55.541 | Trading Evaluator | Bracket Orders supported.
2025-03-20 18:37:55.541 | Trading Evaluator | MarketDepthIsSupported: 1
2025-03-20 18:37:55.541 | Trading Evaluator | Connected to server complete.
2025-03-20 18:37:55.541 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-03-20 18:37:55.541 | Trading Evaluator | Performing query for most recent Order Activity Date-Time.
2025-03-20 18:37:55.550 | Trading Evaluator | Requesting historical order activity from server. Start date-time UTC: 2025-03-18 18:49:34.344029
2025-03-20 18:37:55.701 | Trading Evaluator | Received final trade activity snapshot. Count=1. No data. TradeAccount=1113
2025-03-20 18:37:57.988 | Files to Open on Startup | Opening file: Scalping_DOM.Cht
2025-03-20 18:37:58.004 | ESM25 1 Min #2 | Reloading chart.
2025-03-20 18:37:58.031 | ESM25 30 Min #1 | Reloading chart.
2025-03-20 18:37:58.270 | ESM25 #3 | Reloading chart.
2025-03-20 18:37:58.293 | ESM25 100 Trades #4 | Reloading chart.
2025-03-20 18:37:58.344 | Mapping ESM25 to ESM25. Service code: cme
2025-03-20 18:37:58.344 | Using symbol data fast lookup vector
2025-03-20 18:37:58.344 | Denali Data Feed | Starting real-time market data updates for: ESM25 (ESM25). ID: 1 Service code: cme
2025-03-20 18:37:58.347 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048
2025-03-20 18:37:58.347 | Denali Data Feed | Requesting security definition data for: ESM25 (ESM25). ID: 1
2025-03-20 18:37:58.347 | Starting DelayedDownloadMonitoringTimer
2025-03-20 18:37:58.347 | Starting HDTimeoutTimer
2025-03-20 18:37:58.347 | Added historical Intraday data request for ESM25 to the queue.
2025-03-20 18:37:58.347 | Intraday data recording state for symbol ESM25 is set to download 'Pending'.
2025-03-20 18:37:58.347 | DTC Client socket (2) | Creating socket.
2025-03-20 18:37:58.347 | DTC Client socket (2) | New receive buffer size: 0
2025-03-20 18:37:58.347 | DTC Client socket (2) | Connecting to IP: 67.214.125.5.
2025-03-20 18:37:58.350 | Triggering next historical data download in queue.
2025-03-20 18:37:58.351 | Delaying start of download for ESM25.
2025-03-20 18:37:58.359 | ESM25[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:37:58.359 | ESM25[M] 30 Min #1 | Chart data loading complete.
2025-03-20 18:37:58.366 | Requesting market depth updates for: ESM25 if supported. NumLevels=100
2025-03-20 18:37:58.473 | Denali Data Feed | Network connection to server complete.
2025-03-20 18:37:58.473 | Denali Data Feed | Starting socket receive thread.
2025-03-20 18:37:58.473 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-03-20 18:37:58.488 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM25
2025-03-20 18:37:58.488 | Trading Evaluator | Setting external service identifier for symbol ESM25 to 4916
2025-03-20 18:37:58.488 | Trading Evaluator | Received security definition for symbol ESM25
2025-03-20 18:37:58.537 | ESM25[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:37:58.542 | ESM25[M] 1 Min #2 | Chart data loading complete.
2025-03-20 18:37:58.613 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-03-20 18:37:58.613 | Denali Data Feed | Sending logon request message.
2025-03-20 18:37:58.945 | ESM25[M] #3 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:37:58.951 | ESM25[M] #3 | Chart data loading complete.
2025-03-20 18:37:59.134 | Loading market depth data.
2025-03-20 18:37:59.208 | Denali Data Feed | Received logon response.
2025-03-20 18:37:59.208 | Denali Data Feed | Server Name: SC Realtime Server.
2025-03-20 18:37:59.208 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-03-20 18:37:59.208 | Denali Data Feed | Successfully connected.
2025-03-20 18:37:59.208 | Denali Data Feed | Trading is not supported.
2025-03-20 18:37:59.208 | Denali Data Feed | MarketDepthIsSupported: 1
2025-03-20 18:37:59.208 | Denali Data Feed | Restarting real-time data updates for symbol: ESM25 -> ESM25. Market Depth data restarted.
2025-03-20 18:37:59.208 | Starting DelayedDownloadMonitoringTimer
2025-03-20 18:37:59.208 | Starting HDTimeoutTimer
2025-03-20 18:37:59.208 | Added historical Market Depth data request for ESM25 to the queue.
2025-03-20 18:37:59.208 | Market depth data recording state for symbol ESM25 is set to download 'Pending'.
2025-03-20 18:37:59.210 | Triggering next historical data download in queue.
2025-03-20 18:37:59.210 | HD Request # 1 | Downloading Market Depth data for ESM25. Service: cme.marketdepth.
2025-03-20 18:37:59.211 | HD Request # 1 | Download start date-time: 2025-03-20 18:36:55.017110.
2025-03-20 18:37:59.211 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149
2025-03-20 18:37:59.211 | Socket (3) | Creating socket.
2025-03-20 18:37:59.211 | Socket (3) | New receive buffer size: 0
2025-03-20 18:37:59.211 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-03-20 18:37:59.295 | Loaded depth data records for ESM25 2025-03-13 from 2025-03-13 19:40:28.052000 to 2025-03-14 00:59:59.999000.
2025-03-20 18:37:59.426 | Denali Data Feed | Clearing market depth for ESM25
2025-03-20 18:37:59.426 | Denali Data Feed | Setting external service identifier for symbol ESM25 to 4916
2025-03-20 18:37:59.426 | Denali Data Feed | Received security definition for symbol ESM25
2025-03-20 18:37:59.459 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-03-20 18:37:59.459 | HD Request # 1 | Sending historical data logon request message.
2025-03-20 18:37:59.625 | HD Request # 1 | Requesting market depth data. Start date-time: 2025-03-20 18:36:55. Symbol: ESM25
2025-03-20 18:37:59.747 | HD Request # 1 | Decompressing data.
2025-03-20 18:37:59.880 | HD Request # 1 | Receiving market depth data for ESM25 starting at 2025-03-20 18:36:55.026000
2025-03-20 18:38:00.123 | Socket (3) | CloseSocket call.
2025-03-20 18:38:00.123 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-03-20 18:38:00.124 | Historical data download thread signaled to stop.
2025-03-20 18:38:00.124 | HD Request # 1 | Timestamp of first market depth data file record written: 2025-03-20 18:36:55.026000.
2025-03-20 18:38:00.124 | HD Request # 1 | Received 25146 Market Depth data records from 2025-03-20 18:36:55.026000 to 2025-03-20 18:37:58.370000 (63.3 seconds. Delay: 1.8 seconds) and wrote 25146 records for ESM25
2025-03-20 18:38:00.124 | HD Request # 1 | Completion time: 1s.
2025-03-20 18:38:00.124 | HD Request # 1 | Market Depth data download complete for ESM25. Unique request ID: 2
2025-03-20 18:38:00.124 | Removing historical data download ID 2.
2025-03-20 18:38:00.124 | Real-time market depth file updates started for ESM25
2025-03-20 18:38:00.131 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM25.2025-03-20.depth
2025-03-20 18:38:00.131 | ESM25[M] 1 Min #2 | Flagging to reload Intraday data on market depth download completion.
2025-03-20 18:38:00.131 | ESM25[M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion.
2025-03-20 18:38:00.131 | ESM25[M] #3 | Flagging to reload Intraday data on market depth download completion.
2025-03-20 18:38:00.131 | ESM25[M] 100 Trades #4 | Flagging to reload Intraday data on market depth download completion.
2025-03-20 18:38:00.131 | No download requests in the queue to start downloads for.
2025-03-20 18:38:00.136 | ESM25[M] #3 | Reloading chart.
2025-03-20 18:38:00.152 | ESM25[M] 30 Min #1 | Reloading chart.
2025-03-20 18:38:00.167 | ESM25[M] 100 Trades #4 | Reloading chart.
2025-03-20 18:38:00.183 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM25.2025-03-20.depth
2025-03-20 18:38:00.184 | ESM25[M] 1 Min #2 | Reloading chart.
2025-03-20 18:38:00.232 | Loaded depth data records for ESM25 2025-03-14 from 2025-03-14 01:00:00.001000 to 2025-03-14 22:00:00.064000.
2025-03-20 18:38:00.232 | Loaded depth data records for ESM25 2025-03-15 from 2025-03-15 03:00:21.209064 to 2025-03-15 12:06:09.724587.
2025-03-20 18:38:00.247 | Socket (3) | Socket gracefully closed by remote side.
2025-03-20 18:38:00.247 | Socket (3) | Closed.
2025-03-20 18:38:00.270 | Loaded depth data records for ESM25 2025-03-16 from 2025-03-16 13:00:09.632000 to 2025-03-17 00:59:59.867000.
2025-03-20 18:38:01.480 | Loaded depth data records for ESM25 2025-03-17 from 2025-03-17 01:00:00.042000 to 2025-03-18 00:59:58.506000.
2025-03-20 18:38:01.611 | Created process C:\SierraChart\SierraChartInstance_2\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_2
2025-03-20 18:38:02.964 | Created process C:\SierraChart\SierraChartInstance_3\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_3
2025-03-20 18:38:03.025 | Loaded depth data records for ESM25 2025-03-18 from 2025-03-18 01:00:00.000000 to 2025-03-19 00:59:59.897000.
2025-03-20 18:38:04.303 | Created process C:\SierraChart\SierraChartInstance_4\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_4
2025-03-20 18:38:04.303 | HD Request # 2 | Downloading Intraday chart data for ESM25 to the file ESM25.scid. Service: cme
2025-03-20 18:38:04.304 | HD Request # 2 | Download start date-time: 2025-03-20 18:36:55.000000. File last date-time: 2025-03-20 18:36:55.360002
2025-03-20 18:38:04.304 | HD Request # 2 | Using server: ds28.sierracharts.com port 10149
2025-03-20 18:38:04.304 | Socket (3) | Creating socket.
2025-03-20 18:38:04.304 | Socket (3) | New receive buffer size: 0
2025-03-20 18:38:04.304 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-03-20 18:38:04.310 | ESM25[M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:38:04.310 | ESM25[M] 30 Min #1 | Chart data loading complete.
2025-03-20 18:38:04.313 | ESM25[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:38:04.319 | ESM25[M] 1 Min #2 | Chart data loading complete.
2025-03-20 18:38:04.321 | ESM25[M] #3 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:38:04.328 | ESM25[M] #3 | Chart data loading complete.
2025-03-20 18:38:04.427 | Loaded depth data records for ESM25 2025-03-19 from 2025-03-19 01:00:00.030000 to 2025-03-20 00:59:59.045000.
2025-03-20 18:38:04.566 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-03-20 18:38:04.566 | HD Request # 2 | Sending historical data logon request message.
2025-03-20 18:38:04.689 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-03-20 18:36:55. Record interval: 0. Symbol: ESM25
2025-03-20 18:38:04.812 | HD Request # 2 | Decompressing data.
2025-03-20 18:38:04.943 | HD Request # 2 | Receiving Intraday data for ESM25 starting at 2025-03-20 18:36:55.301000
2025-03-20 18:38:04.944 | Socket (3) | CloseSocket call.
2025-03-20 18:38:04.944 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-03-20 18:38:04.945 | Historical data download thread signaled to stop.
2025-03-20 18:38:04.945 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-03-20 18:36:55.856000.
2025-03-20 18:38:04.945 | HD Request # 2 | Received 1926 Intraday data records from 2025-03-20 18:36:55.301000 to 2025-03-20 18:38:02.241000 (66.9 seconds. Delay: 2.7 seconds) and wrote 1902 records for ESM25
2025-03-20 18:38:04.954 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-03-20 17:38:02.241000
2025-03-20 18:38:04.954 | Added 67 Time and Sales records to Intraday data file for ESM25 after download.
2025-03-20 18:38:04.955 | HD Request # 2 | Completion time: 0s.
2025-03-20 18:38:04.955 | HD Request # 2 | Intraday data download complete for ESM25. Unique request ID: 1
2025-03-20 18:38:04.955 | Removing historical data download ID 1.
2025-03-20 18:38:04.955 | Real-time Intraday chart data file updates started for ESM25
2025-03-20 18:38:04.955 | Intraday chart data file opened for ESM25
2025-03-20 18:38:04.955 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-03-20 18:38:04.955 | No download requests in the queue to start downloads for.
2025-03-20 18:38:05.073 | Socket (3) | Socket gracefully closed by remote side.
2025-03-20 18:38:05.073 | Socket (3) | Closed.
2025-03-20 18:38:05.255 | Opened cached Intraday file: C:\SierraChart\Data\ESM25.scid. Thread ID: 39088
2025-03-20 18:38:05.555 | Loaded depth data records for ESM25 2025-03-20 from 2025-03-20 01:00:00.051000 to 2025-03-20 18:36:55.360000.
2025-03-20 18:38:05.555 | + Loading additional symbol data.
2025-03-20 18:38:05.567 | ESM25[M] 100 Trades #4 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:38:05.569 | Mapping ESH22 to ESH22. Service code: cme
2025-03-20 18:38:05.569 | Denali Data Feed | Starting real-time market data updates for: ESH22 (ESH22). ID: 2 Service code: cme
2025-03-20 18:38:05.569 | Denali Data Feed | Requesting security definition data for: ESH22 (ESH22). ID: 2
2025-03-20 18:38:05.569 | Added historical Intraday data request for ESH22 to the queue.
2025-03-20 18:38:05.569 | Intraday data recording state for symbol ESH22 is set to download 'Pending'.
2025-03-20 18:38:05.569 | Triggering next historical data download in queue.
2025-03-20 18:38:05.569 | ESM25[M] 100 Trades #4 | Started historical data download for additional symbol ESH22. Download ID: 3
2025-03-20 18:38:05.600 | ESM25[M] 100 Trades #4 | Chart data loading complete.
2025-03-20 18:38:05.630 | Delaying start of download for ESH22.
2025-03-20 18:38:06.969 | ESM25[M] 100 Trades #4 | Reloading chart.
2025-03-20 18:38:06.973 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22
2025-03-20 18:38:06.973 | Trading Evaluator | Setting external service identifier for symbol ESH22 to 291
2025-03-20 18:38:06.973 | Trading Evaluator | Received security definition for symbol ESH22
2025-03-20 18:38:06.974 | Denali Data Feed | Real-time data for symbol ESH22 is currently unavailable.
2025-03-20 18:38:06.974 | Denali Data Feed | Received security definition for symbol ESH22
2025-03-20 18:38:07.941 | Loading market depth data.
2025-03-20 18:38:08.148 | Loaded depth data records for ESM25 2025-03-13 from 2025-03-13 19:40:28.052000 to 2025-03-14 00:59:59.999000.
2025-03-20 18:38:09.171 | Loaded depth data records for ESM25 2025-03-14 from 2025-03-14 01:00:00.001000 to 2025-03-14 22:00:00.064000.
2025-03-20 18:38:09.172 | Loaded depth data records for ESM25 2025-03-15 from 2025-03-15 03:00:21.209064 to 2025-03-15 12:06:09.724587.
2025-03-20 18:38:09.212 | Loaded depth data records for ESM25 2025-03-16 from 2025-03-16 13:00:09.632000 to 2025-03-17 00:59:59.867000.
2025-03-20 18:38:10.442 | Loaded depth data records for ESM25 2025-03-17 from 2025-03-17 01:00:00.042000 to 2025-03-18 00:59:58.506000.
2025-03-20 18:38:11.345 | HD Request # 3 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme
2025-03-20 18:38:11.345 | HD Request # 3 | Download start date-time: 2022-03-18 14:29:59.000000. File last date-time: 2022-03-18 14:29:59.181000
2025-03-20 18:38:11.345 | HD Request # 3 | Using server: ds32.sierracharts.com port 10150
2025-03-20 18:38:11.346 | Socket (3) | Creating socket.
2025-03-20 18:38:11.346 | Socket (3) | New receive buffer size: 0
2025-03-20 18:38:11.346 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-03-20 18:38:11.610 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-03-20 18:38:11.610 | HD Request # 3 | Sending historical data logon request message.
2025-03-20 18:38:11.778 | HD Request # 3 | Requesting Intraday data. Start date-time: 2022-03-18 14:29:59. Record interval: 0. Symbol: ESH22
2025-03-20 18:38:11.896 | Loaded depth data records for ESM25 2025-03-18 from 2025-03-18 01:00:00.000000 to 2025-03-19 00:59:59.897000.
2025-03-20 18:38:11.907 | HD Request # 3 | Decompressing data.
2025-03-20 18:38:12.031 | HD Request # 3 | Receiving Intraday data for ESH22 starting at 2022-03-18 14:29:59.181000
2025-03-20 18:38:12.031 | Socket (3) | CloseSocket call.
2025-03-20 18:38:12.031 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-03-20 18:38:12.031 | Historical data download thread signaled to stop.
2025-03-20 18:38:12.031 | HD Request # 3 | Received 1 Intraday data record from 2022-03-18 14:29:59.181000 to 2022-03-18 14:29:59.181000 (0.0 seconds. Delay: 3.0 years) and wrote 0 records for ESH22
2025-03-20 18:38:12.032 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-03-18 13:29:59.181000
2025-03-20 18:38:12.032 | HD Request # 3 | Completion time: 1s.
2025-03-20 18:38:12.032 | HD Request # 3 | Intraday data download complete for ESH22. Unique request ID: 3
2025-03-20 18:38:12.032 | Removing historical data download ID 3.
2025-03-20 18:38:12.032 | Real-time Intraday chart data file updates started for ESH22
2025-03-20 18:38:12.032 | Intraday chart data file opened for ESH22
2025-03-20 18:38:12.032 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-03-20 18:38:12.032 | ESM25[M] 100 Trades #4 | Historical data download for additional symbol ESH22 with ID 3 has completed.
2025-03-20 18:38:12.032 | No download requests in the queue to start downloads for.
2025-03-20 18:38:12.151 | Socket (3) | Socket gracefully closed by remote side.
2025-03-20 18:38:12.151 | Socket (3) | Closed.
2025-03-20 18:38:12.642 | DTC Protocol server | Incoming connection from 127.0.0.1.
2025-03-20 18:38:12.642 | DTC client #1. 127.0.0.1 (3) | Creating socket.
2025-03-20 18:38:12.643 | DTC client #1. 127.0.0.1 (3) | New receive buffer size: 262144
2025-03-20 18:38:12.643 | DTC client #1. 127.0.0.1 (3) | Allocated send buffers: 32 of 131072 bytes.
2025-03-20 18:38:12.643 | DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS
2025-03-20 18:38:12.643 | DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20
2025-03-20 18:38:12.643 | DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request.
2025-03-20 18:38:12.643 | DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: pavel.lysenka. Result text: Connected to SC DTC Protocol server. Service=tradingevaluator.dtctrading|SymbolSettings=tradesimulation.dtctrading
2025-03-20 18:38:13.163 | Loaded depth data records for ESM25 2025-03-19 from 2025-03-19 01:00:00.030000 to 2025-03-20 00:59:59.045000.
2025-03-20 18:38:14.039 | DTC Protocol server | Incoming connection from 127.0.0.1.
2025-03-20 18:38:14.040 | DTC client #2. 127.0.0.1 (4) | Creating socket.
2025-03-20 18:38:14.040 | DTC client #2. 127.0.0.1 (4) | New receive buffer size: 262144
2025-03-20 18:38:14.040 | DTC client #2. 127.0.0.1 (4) | Allocated send buffers: 32 of 131072 bytes.
2025-03-20 18:38:14.040 | DTC client #2. 127.0.0.1 | Set DTC encoding to Binary VLS
2025-03-20 18:38:14.041 | DTC client #2. 127.0.0.1 | Requested heartbeat interval: 20
2025-03-20 18:38:14.041 | DTC client #2. Sierra Chart. 127.0.0.1 | Received logon request.
2025-03-20 18:38:14.041 | DTC client #2. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: pavel.lysenka. Result text: Connected to SC DTC Protocol server. Service=tradingevaluator.dtctrading|SymbolSettings=tradesimulation.dtctrading
2025-03-20 18:38:14.300 | Loaded depth data records for ESM25 2025-03-20 from 2025-03-20 01:00:00.051000 to 2025-03-20 18:38:05.885000.
2025-03-20 18:38:14.300 | + Loading additional symbol data.
2025-03-20 18:38:14.310 | ESM25[M] 100 Trades #4 | StartDateTimeForLoadingOrderFills: 2024-03-13 00:00:00
2025-03-20 18:38:14.343 | ESM25[M] 100 Trades #4 | Chart data loading complete.
2025-03-20 18:38:15.311 | DTC Protocol server | Incoming connection from 127.0.0.1.
2025-03-20 18:38:15.311 | DTC client #3. 127.0.0.1 (5) | Creating socket.
2025-03-20 18:38:15.311 | DTC client #3. 127.0.0.1 (5) | New receive buffer size: 262144
2025-03-20 18:38:15.311 | DTC client #3. 127.0.0.1 (5) | Allocated send buffers: 32 of 131072 bytes.
2025-03-20 18:38:15.312 | DTC client #3. 127.0.0.1 | Set DTC encoding to Binary VLS
2025-03-20 18:38:15.313 | DTC client #3. 127.0.0.1 | Requested heartbeat interval: 20
2025-03-20 18:38:15.313 | DTC client #3. Sierra Chart. 127.0.0.1 | Received logon request.
2025-03-20 18:38:15.313 | DTC client #3. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: pavel.lysenka. Result text: Connected to SC DTC Protocol server. Service=tradingevaluator.dtctrading|SymbolSettings=tradesimulation.dtctrading
2025-03-20 18:38:15.936 | Trading Evaluator | Service client does not support market data subscriptions
2025-03-20 18:38:15.936 | Symbol Error | F.US.EPH25 is unknown, unavailable, or improperly formatted. Service client does not support market data subscriptions
2025-03-20 18:38:18.865 | Trading Evaluator | Service client does not support market data subscriptions
2025-03-20 18:38:18.865 | Symbol Error | ESH25-CME is unknown, unavailable, or improperly formatted. Service client does not support market data subscriptions
2025-03-20 18:38:18.866 | Trading Evaluator | Service client does not support market data subscriptions
2025-03-20 18:38:18.866 | Symbol Error | NQH25-CME is unknown, unavailable, or improperly formatted. Service client does not support market data subscriptions
2025-03-20 18:38:18.867 | Trading Evaluator | Service client does not support market data subscriptions
2025-03-20 18:38:18.867 | Symbol Error | SIH25-COMEX is unknown, unavailable, or improperly formatted. Service client does not support market data subscriptions
[2025-03-20 18:31:35]
The symbols in the sub-instance are incorrect for the "Trading Evaluator" service. If the symbols are not updating correctly when selecting "Edit >> Translate Symbols to Current Service" in the sub-instance, then you will need to update them manually.
For instance, the Sub-Instance is showing a symbol of "F.US.EPH25" - this is a CQG symbol. The symbol for the Trading Evaluator would be ESH25.
You must also have another instance with incorrect symbols, as we see references to "ESH25-CME", "NQH25-CME", and "SIH25-COMEX". These are the symbols for the "SC Data" service. These are not correct for the Trading Evaluator.
[2025-03-21 18:51:47]
Thank you, this fixed it :)
