Date/Time: Mon, 21 Apr 2025 04:47:14 +0000
Horizontal line increment
View Count: 66
[2025-03-12 15:39:59]
Pedro7 - Posts: 30
I'm looking to have eg ES every 4 points a horizontal grid line. So in scale settings horizontal line increment is 4. Issue is have if the candles become to large suddenly the line increment is 8 or if 'compress' the chart by sliding with my pointer over the right hand scale then the increment also becomes bigger. Tried about everything in settings without success. What are the correct setting to achieve this ?
[2025-03-12 16:00:43]
John - SC Support - Posts: 39362
There is going to be a point at which the grid lines are too close together at the specified increment, at which point they will jump out to the next multiple of the entered increment.
For example, you have it set to a value of 4, and then if the lines are too close together to be able to continue to display them properly at an increment of 4, the grid lines will change to an increment of 8 (2 x 4).
If you are seeing something different from what we describe above, then we would need more information on exactly what is occurring.
