Date/Time: Mon, 21 Apr 2025 04:41:24 +0000
multiple symbols on 1 chart
View Count: 157
[2025-03-05 17:03:56]
User333366 - Posts: 11
I am plotting indices (eg UDVR) and there are so many of them (one for each stock index). What i did till now is
- use 1 chartbook
- create a new chart for each symbol
- they all get plotted with my custom study to see the logarithm. I struggled with the log axis, and this works
- then I use a particular chart with many price/study overlay to include them all in 1 view.
I just wanted to check this is the right approach as I now have so many tabs/charts inside this chartbook that it got messy. I dont know if it affects the performance?
So the thoughts I had to improve:
- Can I directly bring multiple symbols to 1 chart? This would avoid so many tabs.
- Can I hide these tabs cause I dont really want to see them cause I have 1 main page with a chart that has 5 of them visible.
- Can I move the "source" charts to another chartbook and leave them there? I imagine this chartbook needs to be open as well but at least they are out of the way then.
Just checking for best practise as I have a few more of those to do (eg Tick and others) so I need to repeat this process. and before I get it all set up it is worth checking with the experts.
Hope my description of my question is clear.
[2025-03-05 19:28:32]
John - SC Support - Posts: 39362
Use the "Add Additional Symbol" study. Refer to the following:
[2025-03-08 16:08:07]
User490955 - Posts: 1
I’m currently using another platform because I can’t find solution how I can make market profile with volume or imbalance to work on sierra using add additional symbol I can choose to show bolinger bands on both es and nasdaq but when I want to make two imbalance or market profile it’s showing just on main also with Fvg it’s not working on one chart I’m sure I do something wrong but I’m appreciate to give me solution I didn’t find someone who had similar problem adding studies of Fvg on both product
imageimage.jpg / V - Attached On 2025-03-08 16:04:24 UTC - Size: 1.65 MB - 50 views
[2025-03-10 15:09:31]
There is no support for multiple TPO profiles for different symbols on a single chart.
The imbalance should work, what study are you using for this?
