Date/Time: Mon, 21 Apr 2025 13:08:38 +0000
Problem re-opening Chartbook
View Count: 83
[2025-02-27 20:17:57]
User311932 - Posts: 5
Good morning, I saved a file on chartbook but just today, after closing it, I tried to open it but it doesn't open, what can I do?
Original
Buongiorno io ho salvato un file su chartbook ma proprio oggi ,dopo averlo chiuso,ho cercato di aprirlo ma non me lo apre come posso fare?
[2025-02-27 20:20:41]
Sierra_Chart Engineering - Posts: 19285
Use a backup Chartbook. Instructions:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
If you still have a problem, check for error messages displayed in the Message Log when opening the Chartbook:
Message Log
[2025-02-28 16:32:43]
Buongiotrno ieri per aprire il file ho fatto come avete detto voi e ci sono riuscito.
Oggi tuttavia ho provato con la stessa procedura ma non l ho aperto.
PS i messaggi di errore non so leggerli.Non so come fare mi potreste aiutare per favore?
[2025-02-28 16:44:30]
John - SC Support - Posts: 39362
Please do the following:
- Select "File >> Close All Chartbooks".
- Select "Window >> Message Log" to open the Message Log, if it is not already open.
- On the "Message Log" window, select "Edit >> Clear Log".
- Select "File >> Open Chartbook".
- Select the Chartbook you are having an issue with.
- On the Message Log select "Send for Analysis" (this looks like a menu at the top, but it is a button).
- Post in this log and let us know that you sent the log to us.
