Date/Time: Mon, 21 Apr 2025 13:11:39 +0000
DOM recent bid/asl volume not showing
View Count: 133
[2025-02-24 18:03:33] |
Twist3d - Posts: 5 |
Previously the recent bid/ask volume numbers were showing. However, today they no longer appeared. I checked the DOM customize columns and it was there. I also check the color setting in case was the same color as background and it wasnt. How to get them to show again? i just uploaded 3 screenshots |
[2025-02-24 18:29:59] |
John - SC Support - Posts: 39362 |
There is nothing we can think of that would cause this to occur. Please get us that chart by following these instructions so we can take a look: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-25 00:23:20] |
here is the chart
[2025-02-25 15:44:06] |
We are not seeing any issue with the Trading DOM. Everything looks fine to us. Are you only having a problem with this DOM, or are you having a problem with data in general? There are two things we are curious about: - You are running a slightly older version (v 2700). We would like for you to update to the latest release to see if you continue to have an issue. Follow these instructions to update: Software Download: Fast Update - Our servers show that you use Sierra Chart on two different computers, but you are only setup to get the data to one system at a time. If you have Sierra Chart running on another system, then you will not be able to get the data to the current system. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-26 13:58:59] |
I figured it out. In order to show Recent Bid/Ask Volume, Bid Size/BuyColumn and Ask Size/Sell Column have to be as well instead of Buy/Sell Order Column
