Date/Time: Mon, 28 Sep 2026 04:26:20 +0000
Global Settings - Customize Chart Header - Standard doesn't seem to work
View Count: 750
[2025-02-19 08:20:55]
xORDERBOOKx - Posts: 191
I'm trying to have time shown on the chart without the need for an indicator.
[Global Settings - Customize Chart Header - Trade DOM] works perfectly fine when I put "time" under the "Selected Header Fields".
[Global Settings - Customize Chart Header - Standard] does nothing.
I see the product name, chart timeframe (ie. 5min), symbol, exchange, etc. in the chart title bar, but even this doesn't change when I change the [Customize Chart Header] settings.
All I want is to display the time on the chart in the upper left corner just like the trade DOM. Any ideas?
Thanks.
Date Time Of Last Edit: 2025-02-19 08:21:53
[2025-02-19 09:20:58]
Sierra_Chart Engineering - Posts: 24993
This really is impossible. It is not possible for those settings to do nothing. Make sure, you are changing the fields on the rightmost list of Global Settings >> Customize Chart Header - Standard.
[2025-02-19 10:11:57]
Is there a toggle for a chart header? I'm getting nothing on my screen at all.
Date Time Of Last Edit: 2025-02-19 11:43:26
imageNothing showing on chart header.png / V - Attached On 2025-02-19 10:11:36 UTC - Size: 321.57 KB - 264 views
[2025-02-19 16:59:33]
John - SC Support - Posts: 48028
There is not a toggle for the Chart Header. The only way to not have anything is to remove all the items associated with the Chart Header.
Keep in mind, there are two Chart Header options, one for a standard chart (Customize Chart Header - Standard) and one for the Trading DOM (Customize Chart Header - Trade DOM). Make sure you are making changes to the "Customize Chart Header - Standard" to change the items for the header on the charts.
[2025-02-19 17:14:23]
Still having the same problem despite following your advice (screenshot above shows I'm not lying), however after re-creating the chart from scratch (Find Symbol - Open Intraday Chart) the problem was fixed and I now have chart headers on the chart. I was having a problem earlier about data not being displayed when "Continuous Volume Based Rollover - Back Adjusted" was selected as well, but only on duplicated charts from my base model.
I don't know what caused it (corrupted file/data?) but it's gone now (both problems: the chart header not displaying and the chart not showing all data from the past).
Thank you.
Date Time Of Last Edit: 2025-02-19 18:20:45
[2025-02-23 08:39:10]
There is a setting to hide the chart header:
Chart Settings: Region Data Lines (List) (Chart >> Chart Settings >> Regions >> Region Data Line menu)
[2025-02-23 09:50:28]
That was the problem. Thank you.
