Date/Time: Mon, 21 Apr 2025 23:36:11 +0000
TW size buttons no longer linked to control bar?
View Count: 125
[2025-02-14 16:26:59] |
User993067 - Posts: 174 |
I have been making adjustments to my setup and Im not certain where I made the error hopefully you can help me get corrected: 1. the TW radio buttons no longer are dominant to the size buttons I have set on my control bar. ie...if I adjust size in the TW, the control bars do not adjust. 2. the control bar is inactive unless i click in the DOM prior to the CB, if I last clicked in the chart, and dont realize which window is last active the CB is useless, only clue that CB is inactive is the clear functions on the CB are slightly grayed out. 3. If Im testing something and want to switch between sim accts, the TW no longer controls which sim acct is listed on the DOM,defaults to sim 16, not sure how to adjust. help is appreciated. |
[2025-02-14 18:50:37] |
We are not understanding what you are asking. We assume "TW" refers to the "Trade Window", and if so, then we do not understand how you are making a comparison between the Trade Window and Control Bar Buttons. And we are not understanding what you are trying to state with regards to the Control Bar being inactive. It would help if you would include some images of what you are referencing. Refer to the following for how to get us images: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-14 20:50:11] |
so i attached the trade window to the dom window and issue resolves...even after i float it again, somehow it reset
[2025-02-14 22:43:03] |
Then that particular trade window was not the one for that chart.
[2025-02-15 17:24:15] |
my setup always had a single TW, been that way for years. My point was something caused settings to change, i believe it could have been windows update, the day prior???...updated to latest version the day before that...idk order fills, were only showing on DOM for years, started showing on charts, order confirmations started popping up, many settings suddenly were off... Anyway, resolved now....ty |
