Date/Time: Fri, 14 Mar 2025 12:33:29 +0000
Intermittent historical and bar data drops out
View Count: 109
[2025-02-06 15:58:30] |
UserTLE - Posts: 8 |
Hello! It only happens on a couple of my charts, for instance MGC, YM, MYM... doesn't seem to ever effect my CME tickers. But I will be trading as normal, watching charts as normal, and then bars will stop loading, and will get the message that historical data is being downloaded. Probably happens once every 5-10 minutes or so. This can be infuriating when I have risk on and need to see the developing candles to make decisions. Do we know of any way to correct this issue? It really stresses me out. Reload and Recalculate does not make a difference. Thanks again! |
[2025-02-06 16:18:57] |
John - SC Support - Posts: 38653 |
What you are stating means that you are losing connectivity for some reason. Please get us your Message Log by following these instructions so we can see if there is anything in particular in the log: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-06 16:33:03] |
2025-02-05 08:46:52.804 | Trade activity files set size: 1893 2025-02-05 08:46:52.832 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2025-02-05 08:46:52.832 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2025-02-05 08:46:52.832 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130. 2025-02-05 08:46:52.863 | Created the DTC Protocol server. 2025-02-05 08:46:52.865 | DTC Protocol Server listening on port 11099. 2025-02-05 08:46:52.865 | Reading Internal Order ID file. 2025-02-05 08:46:52.897 | Reading Trade Orders file. 2025-02-05 08:46:52.898 | Reading Trade Positions file. 2025-02-05 08:46:52.898 | Reading Trade Account Data files. 2025-02-05 08:46:52.901 | Software version: 2646 64-bit 2025-02-05 08:46:52.901 | Primary Thread ID: 15136 2025-02-05 08:46:52.901 | Usage end date: 2025-04-19 2025-02-05 08:46:52.901 | Enabled for: Advanced Features 2. 2025-02-05 08:46:52.901 | Enabled for: Sierra Chart Historical Data Service. 2025-02-05 08:46:52.901 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-02-05 08:46:52.901 | Enabled for: Delayed Denali Exchange Data Feed. 2025-02-05 08:46:52.901 | Enabled for exchange2: CME 2025-02-05 08:46:52.901 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-02-05 08:46:52.901 | Current selected Data/Trading service: Rithmic Direct - DTC 2025-02-05 08:46:52.901 | Custom symbol settings values: enabled 2025-02-05 08:46:52.901 | Chart Update Interval: 500 2025-02-05 08:46:52.901 | Intraday Data Storage Time Unit: 0 2025-02-05 08:46:52.901 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2025-02-05 08:46:52.901 | 2025-02-05 13:46:52 Local computer time in UTC 2025-02-05 08:46:52.901 | 2025-02-05 08:46:52 Local computer time in SC Time Zone 2025-02-05 08:46:52.901 | 2025-02-05 13:46:51 Server time in UTC 2025-02-05 08:46:52.901 | Local computer UTC time and Server UTC time difference: 0 seconds. 2025-02-05 08:46:52.901 | Program path: D:\SierraChart\ 2025-02-05 08:46:52.901 | Data Files path: D:\SierraChart\Data\ 2025-02-05 08:46:52.901 | OS Version Number: 10.0 2025-02-05 08:46:52.901 | Locale Setting: C 2025-02-05 08:46:52.902 | DLLs: UserContributedStudies_64.dll 2025-02-05 08:46:52.902 | Allowed protected custom studies: 2025-02-05 08:46:52.902 | Crash reporter started: true 2025-02-05 08:46:52.902 | 2025-02-05 08:46:52.922 | Created the DTC Protocol historical data server. 2025-02-05 08:46:52.923 | HD Server Manager | Listening on port 11098. 2025-02-05 08:46:52.924 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2025-02-05 08:46:52.971 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:46:53.006 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2025-02-05 08:46:53.006 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2025-02-05 08:46:53.053 | Received 5 login tokens. 2025-02-05 08:46:53.321 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2025-02-05 08:46:53.321 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. 2025-02-05 08:46:53.341 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. 2025-02-05 08:46:53.341 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2025-02-05 08:46:53.387 | Symbol settings MD5 received. Request ID: 1. 2025-02-05 08:46:53.387 | Symbol settings are up-to-date for rithmic_v2.trading. 2025-02-05 08:46:55.433 | Requested user files to download. 2025-02-05 08:46:57.426 | 2025-02-05 08:46:57.426 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 08:46:57.429 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2025-02-05 08:46:57.447 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-02-05 08:46:57.447 | DTC Client socket (1) | New receive buffer size: 0 2025-02-05 08:46:57.447 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2025-02-05 08:47:00.644 | Files to Open on Startup | Opening file: MoneyMaker.Cht 2025-02-05 08:47:00.678 | ESH5.CME [CV] Daily #3 | Reloading chart. 2025-02-05 08:47:01.455 | ESH5.CME [CBV] 10 Min #1 | Reloading chart. 2025-02-05 08:47:01.457 | Starting DelayedDownloadMonitoringTimer 2025-02-05 08:47:01.457 | Starting HDTimeoutTimer 2025-02-05 08:47:01.457 | Added historical Intraday data request for ESH5.CME to the queue. 2025-02-05 08:47:01.459 | Triggering next historical data download in queue. 2025-02-05 08:47:01.479 | ESH5.CME [CBV] 10 Min #1 | Waiting for historical downloads to complete with the IDs: 1, 2025-02-05 08:47:01.687 | MYMH5.CBOT 2 Min #11 | Reloading chart. 2025-02-05 08:47:01.939 | MESH5.CME 1 Min #14 | Reloading chart. 2025-02-05 08:47:02.253 | MGCJ5.COMEX 15 Sec #6 | Reloading chart. 2025-02-05 08:47:02.526 | MCLH5.NYMEX 5 Min #2 | Reloading chart. 2025-02-05 08:47:02.544 | Mapping ESH5.CME to ESH25. Service code: cme 2025-02-05 08:47:02.544 | Using symbol data fast lookup vector 2025-02-05 08:47:02.544 | HD Request # 1 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme 2025-02-05 08:47:02.544 | HD Request # 1 | Download start date-time: 2025-02-05 08:17:53.000000. File last date-time: 2025-02-05 08:17:53.649000 2025-02-05 08:47:02.544 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2025-02-05 08:47:02.545 | Socket (2) | Creating socket. 2025-02-05 08:47:02.545 | Socket (2) | New receive buffer size: 0 2025-02-05 08:47:02.545 | Socket (2) | Connecting to IP: 67.214.125.5. 2025-02-05 08:47:02.582 | ESH5.CME [CV] Daily #3 | Chart data loading complete. 2025-02-05 08:47:02.595 | MYMH5.CBOT 2 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:47:02.599 | MYMH5.CBOT 2 Min #11 | Chart data loading complete. 2025-02-05 08:47:02.608 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 08:47:02.633 | HD Request # 1 | Setting DTC encoding to Binary VLS 2025-02-05 08:47:02.633 | HD Request # 1 | Sending historical data logon request message. 2025-02-05 08:47:02.664 | MGCJ5.COMEX 15 Sec #6 | Chart data loading complete. 2025-02-05 08:47:02.715 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-02-05 08:17:53. Record interval: 0. Symbol: ESH25 2025-02-05 08:47:02.751 | HD Request # 1 | Decompressing data. 2025-02-05 08:47:02.777 | MCLH5.NYMEX 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:47:02.779 | MCLH5.NYMEX 5 Min #2 | Chart data loading complete. 2025-02-05 08:47:02.808 | HD Request # 1 | Receiving Intraday data for ESH5.CME starting at 2025-02-05 08:17:53.649000 2025-02-05 08:47:02.885 | Socket (2) | CloseSocket call. 2025-02-05 08:47:02.885 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-05 08:47:02.911 | Historical data download thread signaled to stop. 2025-02-05 08:47:02.912 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-02-05 08:17:53.885000. 2025-02-05 08:47:02.912 | HD Request # 1 | Received 15593 Intraday data records from 2025-02-05 08:17:53.649000 to 2025-02-05 08:47:02.380003 (29.1 minutes. Delay: 0.5 seconds) and wrote 15592 records for ESH5.CME 2025-02-05 08:47:02.912 | HD Request # 1 | Completion time: 0s. 2025-02-05 08:47:02.912 | HD Request # 1 | Intraday data download complete for ESH5.CME. Unique request ID: 1 2025-02-05 08:47:02.912 | Removing historical data download ID 1. 2025-02-05 08:47:02.912 | Real-time Intraday chart data file updates started for ESH5.CME 2025-02-05 08:47:02.912 | Intraday chart data file opened for ESH5.CME 2025-02-05 08:47:02.912 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2025-02-05 08:47:02.912 | 2025-02-05 08:47:02.912 | No download requests in the queue to start downloads for. 2025-02-05 08:47:02.912 | Historical data for ESH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-02-05 08:47:02.913 | ESH5.CME [CBV] 10 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-02-05 08:47:02.921 | Socket (2) | Socket gracefully closed by remote side. 2025-02-05 08:47:02.921 | Socket (2) | Closed. 2025-02-05 08:47:02.923 | ESH5.CME [CBV] 10 Min #1 | Reloading chart. | Number times message added: 1 2025-02-05 08:47:02.980 | Mapping MESH5.CME to MESH25. Service code: cme 2025-02-05 08:47:02.980 | Added historical Intraday data request for MESH5.CME to the queue. 2025-02-05 08:47:02.980 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'. 2025-02-05 08:47:02.980 | Triggering next historical data download in queue. 2025-02-05 08:47:02.980 | HD Request # 2 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme 2025-02-05 08:47:02.981 | HD Request # 2 | Download start date-time: 2025-02-05 08:18:56.000000. File last date-time: 2025-02-05 08:18:56.855000 2025-02-05 08:47:02.981 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149 2025-02-05 08:47:02.981 | Socket (2) | Creating socket. 2025-02-05 08:47:02.981 | Socket (2) | New receive buffer size: 0 2025-02-05 08:47:02.981 | Socket (2) | Connecting to IP: 67.214.125.3. 2025-02-05 08:47:03.063 | HD Request # 2 | Setting DTC encoding to Binary VLS 2025-02-05 08:47:03.063 | HD Request # 2 | Sending historical data logon request message. 2025-02-05 08:47:03.138 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-02-05 08:18:56. Record interval: 0. Symbol: MESH25 2025-02-05 08:47:03.180 | HD Request # 2 | Decompressing data. 2025-02-05 08:47:03.206 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 08:47:03.206 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 08:47:03.206 | Triggering next historical data download in queue. 2025-02-05 08:47:03.239 | HD Request # 2 | Receiving Intraday data for MESH5.CME starting at 2025-02-05 08:18:56.855000 2025-02-05 08:47:03.257 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 08:47:03.257 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 08:47:03.257 | Triggering next historical data download in queue. 2025-02-05 08:47:03.311 | Socket (2) | CloseSocket call. 2025-02-05 08:47:03.311 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-05 08:47:03.311 | Historical data download thread signaled to stop. 2025-02-05 08:47:03.311 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-02-05 08:18:57.852000. 2025-02-05 08:47:03.311 | HD Request # 2 | Received 9989 Intraday data records from 2025-02-05 08:18:56.855000 to 2025-02-05 08:47:00.746005 (28.1 minutes. Delay: 2.6 seconds) and wrote 9988 records for MESH5.CME 2025-02-05 08:47:03.311 | HD Request # 2 | Completion time: 1s. 2025-02-05 08:47:03.311 | HD Request # 2 | Intraday data download complete for MESH5.CME. Unique request ID: 2 2025-02-05 08:47:03.311 | Removing historical data download ID 2. 2025-02-05 08:47:03.311 | Real-time Intraday chart data file updates started for MESH5.CME 2025-02-05 08:47:03.311 | Intraday chart data file opened for MESH5.CME 2025-02-05 08:47:03.311 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2025-02-05 08:47:03.311 | 2025-02-05 08:47:03.311 | Triggering next historical data download in queue. 2025-02-05 08:47:03.311 | Historical data for MESH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-02-05 08:47:03.311 | HD Request # 3 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 08:47:03.312 | HD Request # 3 | Download start date-time: 2025-02-05 01:23:10.000000. File last date-time: 2025-02-05 01:23:10.000000 2025-02-05 08:47:03.312 | HD Request # 3 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 08:47:03.312 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 08:47:03.312 | Socket (4) | New receive buffer size: 0 2025-02-05 08:47:03.312 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 08:47:03.347 | Socket (2) | Socket gracefully closed by remote side. 2025-02-05 08:47:03.347 | Socket (2) | Closed. 2025-02-05 08:47:03.519 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 08:47:03.519 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 08:47:03.519 | Triggering next historical data download in queue. 2025-02-05 08:47:03.573 | ESH5.CME [CBV][M] 10 Min #1 | StartDateTimeForLoadingOrderFills: 2025-01-22 08:47:02 2025-02-05 08:47:03.574 | ESH5.CME [CBV][M] 10 Min #1 | Chart data loading complete. 2025-02-05 08:47:04.786 | MESH5.CME[M] 1 Min #14 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:47:04.791 | MESH5.CME[M] 1 Min #14 | Chart data loading complete. 2025-02-05 08:47:17.459 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. 2025-02-05 08:47:17.459 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0 2025-02-05 08:47:17.459 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 216.66.0.130. 2025-02-05 08:47:17.865 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call. 2025-02-05 08:47:17.865 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. 2025-02-05 08:47:17.884 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. 2025-02-05 08:47:17.884 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed. 2025-02-05 08:47:18.475 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2025-02-05 08:47:18.475 | DTC Client socket (1) | CloseSocket call. 2025-02-05 08:47:18.475 | DTC Client socket (1) | Closed. 2025-02-05 08:47:18.475 | Rithmic Direct - DTC | Failed connections: 1 2025-02-05 08:47:18.475 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-02-05 08:47:18.475 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-02-05 08:47:18.489 | DTC Client socket (0) | CloseSocket call. 2025-02-05 08:47:18.489 | Rithmic Direct - DTC | Disconnected. 2025-02-05 08:47:18.489 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-02-05 08:47:22.488 | 2025-02-05 08:47:22.489 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 08:47:22.489 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2025-02-05 08:47:22.489 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-02-05 08:47:22.489 | DTC Client socket (1) | New receive buffer size: 0 2025-02-05 08:47:22.489 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2025-02-05 08:47:24.345 | Socket (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2025-02-05 08:47:24.346 | Socket (4) | CloseSocket call. 2025-02-05 08:47:24.346 | Socket (0) | CloseSocket call. 2025-02-05 08:47:24.346 | Socket (4) | Closed. 2025-02-05 08:47:24.346 | HD Request # 3 | Error downloading historical Intraday data for MYMH5.CBOT. The network socket has been closed. Retrying download. 2025-02-05 08:47:24.346 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 08:47:24.346 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 08:47:24.346 | Triggering next historical data download in queue. 2025-02-05 08:47:24.346 | Historical data download thread signaled to stop. 2025-02-05 08:47:24.346 | HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MYMH5.CBOT 2025-02-05 08:47:24.346 | HD Request # 3 | Completion time: 21s. 2025-02-05 08:47:24.346 | 2025-02-05 08:47:24.346 | HD Request # 4 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 08:47:24.347 | HD Request # 4 | Download start date-time: 2025-02-05 01:23:10.000000. File last date-time: 2025-02-05 01:23:10.000000 2025-02-05 08:47:24.347 | HD Request # 4 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 08:47:24.347 | Socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 08:47:24.347 | Socket (2) | New receive buffer size: 0 2025-02-05 08:47:24.347 | Socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 08:47:42.489 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. 2025-02-05 08:47:42.489 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0 2025-02-05 08:47:42.489 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 216.66.0.130. 2025-02-05 08:47:42.888 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | CloseSocket call. 2025-02-05 08:47:42.889 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close. 2025-02-05 08:47:42.908 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. 2025-02-05 08:47:42.908 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Closed. 2025-02-05 08:47:43.524 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2025-02-05 08:47:43.524 | DTC Client socket (1) | CloseSocket call. 2025-02-05 08:47:43.524 | DTC Client socket (1) | Closed. 2025-02-05 08:47:43.524 | Rithmic Direct - DTC | Failed connections: 2 2025-02-05 08:47:43.524 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-02-05 08:47:43.524 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-02-05 08:47:43.540 | DTC Client socket (0) | CloseSocket call. 2025-02-05 08:47:43.540 | Rithmic Direct - DTC | Disconnected. 2025-02-05 08:47:43.540 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-02-05 08:47:45.386 | Socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2025-02-05 08:47:45.387 | Socket (2) | CloseSocket call. 2025-02-05 08:47:45.387 | Socket (0) | CloseSocket call. 2025-02-05 08:47:45.387 | Socket (2) | Closed. 2025-02-05 08:47:45.387 | HD Request # 4 | Error downloading historical Intraday data for MYMH5.CBOT. The network socket has been closed. Retrying download. 2025-02-05 08:47:45.387 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 08:47:45.387 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 08:47:45.387 | Triggering next historical data download in queue. 2025-02-05 08:47:45.387 | Historical data download thread signaled to stop. 2025-02-05 08:47:45.387 | HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MYMH5.CBOT 2025-02-05 08:47:45.387 | HD Request # 4 | Completion time: 21s. 2025-02-05 08:47:45.387 | 2025-02-05 08:47:45.387 | HD Request # 5 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 08:47:45.387 | HD Request # 5 | Download start date-time: 2025-02-05 01:23:10.000000. File last date-time: 2025-02-05 01:23:10.000000 2025-02-05 08:47:45.387 | HD Request # 5 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 08:47:45.387 | Socket (1) | Creating socket. Using TLS 1.2. 2025-02-05 08:47:45.388 | Socket (1) | New receive buffer size: 0 2025-02-05 08:47:45.388 | Socket (1) | Connecting to IP: 216.57.156.163. 2025-02-05 08:47:47.541 | 2025-02-05 08:47:47.541 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 08:47:47.541 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2025-02-05 08:47:47.542 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 08:47:47.542 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 08:47:47.542 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 08:47:56.769 | DTC Client socket (2) | CloseSocket call. 2025-02-05 08:47:56.769 | Rithmic Direct - DTC | Disconnected. 2025-02-05 08:47:56.769 | Canceling queued historical data download request for MGCJ5.COMEX Intraday data. 2025-02-05 08:47:56.769 | Removing historical data download ID 4. 2025-02-05 08:47:56.769 | Canceling queued historical data download request for MCLH5.NYMEX Intraday data. 2025-02-05 08:47:56.769 | DTC Client socket (2) | Closed. 2025-02-05 08:47:56.769 | Removing historical data download ID 5. 2025-02-05 08:47:56.769 | HD Request # 5 | Active download canceled. 2025-02-05 08:47:56.769 | Historical data download thread signaled to stop. 2025-02-05 08:47:56.769 | Socket (1) | CloseSocket call. 2025-02-05 08:47:56.769 | Socket (1) | Closed. 2025-02-05 08:47:56.769 | HD Request # 5 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MYMH5.CBOT 2025-02-05 08:47:56.769 | HD Request # 5 | Completion time: 11s. 2025-02-05 08:47:56.769 | HD Request # 5 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 3 2025-02-05 08:47:56.769 | Removing historical data download ID 3. 2025-02-05 08:47:56.769 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2025-02-05 08:47:56.769 | 2025-02-05 08:47:56.769 | No download requests in the queue to start downloads for. 2025-02-05 08:47:56.800 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 2. 2025-02-05 08:47:56.800 | Current selected Data/Trading service: Teton CME Order Routing 2025-02-05 08:47:57.546 | Symbol settings MD5 received. Request ID: 2. 2025-02-05 08:47:57.547 | Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 3. 2025-02-05 08:47:58.153 | Symbol settings received. Request ID: 3. 2025-02-05 08:47:58.730 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-02-05 08:47:58.887 | ESH25_FUT_CME [CBV][M] 10 Min #1 | Reloading chart. 2025-02-05 08:47:58.889 | Added historical Intraday data request for ESH25_FUT_CME to the queue. 2025-02-05 08:47:58.889 | Triggering next historical data download in queue. 2025-02-05 08:47:58.891 | ESH25_FUT_CME [CBV][M] 10 Min #1 | Performing continuous chart historical Daily data download for symbol ESH25_FUT_CME starting at last date in file. 2025-02-05 08:47:58.891 | Starting DelayedDownloadMonitoringTimer 2025-02-05 08:47:58.892 | Starting HDTimeoutTimer 2025-02-05 08:47:58.892 | Added historical Daily data request for ESH25_FUT_CME to the queue. 2025-02-05 08:47:58.894 | Triggering next historical data download in queue. 2025-02-05 08:47:58.915 | ESH25_FUT_CME [CBV][M] 10 Min #1 | Waiting for historical downloads to complete with the IDs: 6, 7, 2025-02-05 08:47:58.915 | Mapping ESH25_FUT_CME to ESH25. Service code: cme 2025-02-05 08:47:58.916 | HD Request # 6 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme 2025-02-05 08:47:58.916 | HD Request # 6 | Download start date-time: 2025-02-05 01:34:07.000000. File last date-time: 2025-02-05 01:34:07.249001 2025-02-05 08:47:58.916 | HD Request # 6 | Using server: ds26.sierracharts.com port 10149 2025-02-05 08:47:58.919 | HD Request # 7 | Downloading Historical Daily chart data for ESH25_FUT_CME. Starting date: 2025-01-31. Service: sc_futures_direct.dtc.trading 2025-02-05 08:47:58.937 | Socket (1) | Creating socket. 2025-02-05 08:47:58.937 | Socket (1) | New receive buffer size: 0 2025-02-05 08:47:58.937 | Socket (1) | Connecting to IP: 64.152.155.17. 2025-02-05 08:47:58.948 | MGCJ25_FUT_CME 15 Sec #6 | Reloading chart. 2025-02-05 08:47:58.957 | MGCJ25_FUT_CME 15 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\MGCJ25_FUT_CME.scid 2025-02-05 08:47:58.960 | MGCJ25_FUT_CME 15 Sec #6 | Chart data loading complete. 2025-02-05 08:47:58.961 | MESH25_FUT_CME[M] 1 Min #14 | Reloading chart. 2025-02-05 08:47:58.967 | MESH25_FUT_CME[M] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\MESH25_FUT_CME.scid 2025-02-05 08:47:58.967 | MESH25_FUT_CME[M] 1 Min #14 | Chart data loading complete. 2025-02-05 08:47:59.014 | HD Request # 6 | Setting DTC encoding to Binary VLS 2025-02-05 08:47:59.014 | HD Request # 6 | Sending historical data logon request message. 2025-02-05 08:47:59.018 | MCLH25_FUT_CME 5 Min #2 | Reloading chart. 2025-02-05 08:47:59.023 | MCLH25_FUT_CME 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\MCLH25_FUT_CME.scid 2025-02-05 08:47:59.023 | MCLH25_FUT_CME 5 Min #2 | Chart data loading complete. 2025-02-05 08:47:59.090 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-02-05 01:34:07. Record interval: 0. Symbol: ESH25 2025-02-05 08:47:59.142 | HD Request # 6 | Decompressing data. 2025-02-05 08:47:59.179 | HD Request # 6 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-02-05 01:34:07.249000 2025-02-05 08:47:59.190 | HD Request # 7 | Requesting historical Daily data for ESH25 starting at 2025-01-30. SC External HD service. 2025-02-05 08:47:59.193 | ESH25_FUT_CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 08:47:59.284 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-02-05 01:34:12.783000. 2025-02-05 08:47:59.362 | Socket (1) | CloseSocket call. 2025-02-05 08:47:59.362 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:47:59.390 | Socket (1) | Socket gracefully closed by remote side. 2025-02-05 08:47:59.390 | Socket (1) | Closed. 2025-02-05 08:47:59.711 | ESH25_FUT_CME [CV][M] Daily #3 | Waiting for historical downloads to complete with the IDs: 7, 2025-02-05 08:47:59.713 | Historical data download thread signaled to stop. 2025-02-05 08:47:59.713 | HD Request # 6 | Received 87021 Intraday data records from 2025-02-05 01:34:07.249000 to 2025-02-05 08:47:54.936000 (7.2 hours. Delay: 4.8 seconds) and wrote 87019 records for ESH25_FUT_CME 2025-02-05 08:47:59.714 | HD Request # 6 | Completion time: 1s. 2025-02-05 08:47:59.714 | HD Request # 6 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 6 2025-02-05 08:47:59.714 | Removing historical data download ID 6. 2025-02-05 08:47:59.714 | Real-time Intraday chart data file updates started for ESH25_FUT_CME 2025-02-05 08:47:59.714 | Intraday chart data file opened for ESH25_FUT_CME 2025-02-05 08:47:59.714 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2025-02-05 08:47:59.714 | 2025-02-05 08:47:59.714 | No download requests in the queue to start downloads for. 2025-02-05 08:47:59.714 | Historical data for ESH25_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-02-05 08:47:59.716 | MYMH25_FUT_CME 2 Min #11 | Reloading chart. 2025-02-05 08:47:59.720 | Mapping MGCJ25_FUT_CME to MGCJ25. Service code: comex 2025-02-05 08:47:59.720 | Added historical Intraday data request for MGCJ25_FUT_CME to the queue. 2025-02-05 08:47:59.720 | Intraday data recording state for symbol MGCJ25_FUT_CME is set to download 'Pending'. 2025-02-05 08:47:59.720 | Triggering next historical data download in queue. 2025-02-05 08:47:59.721 | HD Request # 8 | Downloading Intraday chart data for MGCJ25_FUT_CME to the file MGCJ25_FUT_CME.scid. Service: comex 2025-02-05 08:47:59.721 | HD Request # 8 | Download start date-time: 2024-08-03 09:47:59.000000. File last date-time: 00:00:00.000000 2025-02-05 08:47:59.721 | HD Request # 8 | Using server: ds28.sierracharts.com port 10150 2025-02-05 08:47:59.721 | Socket (1) | Creating socket. 2025-02-05 08:47:59.721 | Socket (1) | New receive buffer size: 0 2025-02-05 08:47:59.721 | Socket (1) | Connecting to IP: 67.214.125.5. 2025-02-05 08:47:59.724 | Mapping MESH25_FUT_CME to MESH25. Service code: cme 2025-02-05 08:47:59.724 | Added historical Intraday data request for MESH25_FUT_CME to the queue. 2025-02-05 08:47:59.724 | Intraday data recording state for symbol MESH25_FUT_CME is set to download 'Pending'. 2025-02-05 08:47:59.724 | Triggering next historical data download in queue. 2025-02-05 08:47:59.725 | Mapping MCLH25_FUT_CME to MCLH25. Service code: nymex 2025-02-05 08:47:59.725 | Added historical Intraday data request for MCLH25_FUT_CME to the queue. 2025-02-05 08:47:59.725 | Intraday data recording state for symbol MCLH25_FUT_CME is set to download 'Pending'. 2025-02-05 08:47:59.725 | Triggering next historical data download in queue. 2025-02-05 08:47:59.792 | HD Request # 8 | Setting DTC encoding to Binary VLS 2025-02-05 08:47:59.792 | HD Request # 8 | Sending historical data logon request message. 2025-02-05 08:47:59.860 | HD Request # 7 | Receiving historical Daily data for ESH25_FUT_CME starting at 2025-01-31. 2025-02-05 08:47:59.861 | HD Request # 7 | Writing historical Daily data to the file ESH25_FUT_CME.dly. 2025-02-05 08:47:59.866 | HD Request # 7 | Bytes received: 239 2025-02-05 08:47:59.866 | HD Request # 7 | Received 4 Daily data records from 2025-01-31 00:00:00 to 2025-02-04 00:00:00 (5.0 days) and wrote 3 records for ESH25_FUT_CME 2025-02-05 08:47:59.866 | HD Request # 7 | Completion time: 1s. 2025-02-05 08:47:59.866 | HD Request # 7 | Daily data download complete for ESH25_FUT_CME. Unique request ID: 7 2025-02-05 08:47:59.866 | Removing historical data download ID 7. 2025-02-05 08:47:59.866 | 2025-02-05 08:47:59.866 | No download requests in the queue to start downloads for. 2025-02-05 08:47:59.867 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-08-03 09:47:59. Record interval: 0. Symbol: MGCJ25 2025-02-05 08:47:59.868 | ESH25_FUT_CME [CBV][M] 10 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-02-05 08:47:59.869 | ESH25_FUT_CME [CBV][M] 10 Min #1 | Reloading chart. | Number times message added: 1 2025-02-05 08:47:59.899 | HD Request # 8 | Decompressing data. 2025-02-05 08:47:59.985 | HD Request # 8 | Receiving Intraday data for MGCJ25_FUT_CME starting at 2024-08-04 20:08:00.270000 2025-02-05 08:48:00.019 | MYMH25_FUT_CME 2 Min #11 | StartDateTimeForLoadingOrderFills: 2024-12-08 17:59:00 2025-02-05 08:48:00.022 | MYMH25_FUT_CME 2 Min #11 | Chart data loading complete. 2025-02-05 08:48:00.109 | HD Request # 8 | Timestamp of first Intraday data file record written: 2024-08-04 20:08:00.270000. 2025-02-05 08:48:00.194 | ESH25_FUT_CME [CV][M] Daily #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-02-05 08:48:00.196 | ESH25_FUT_CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 08:48:00.342 | Mapping MYMH25_FUT_CME to MYMH25. Service code: cbot 2025-02-05 08:48:00.342 | Added historical Intraday data request for MYMH25_FUT_CME to the queue. 2025-02-05 08:48:00.342 | Intraday data recording state for symbol MYMH25_FUT_CME is set to download 'Pending'. 2025-02-05 08:48:00.342 | Triggering next historical data download in queue. 2025-02-05 08:48:00.408 | ESH25_FUT_CME [CBV][M] 10 Min #1 | StartDateTimeForLoadingOrderFills: 2025-01-22 08:47:54 2025-02-05 08:48:00.410 | ESH25_FUT_CME [CBV][M] 10 Min #1 | Chart data loading complete. 2025-02-05 08:48:00.461 | ESH25_FUT_CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-05 08:48:00.554 | MGCJ25_FUT_CME[M] 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2024-08-04 20:08:00 2025-02-05 08:48:00.694 | ESH25_FUT_CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 08:48:01.109 | Socket (1) | CloseSocket call. 2025-02-05 08:48:01.109 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:48:01.140 | Socket (1) | Socket gracefully closed by remote side. 2025-02-05 08:48:01.140 | Socket (1) | Closed. 2025-02-05 08:48:01.343 | Historical data download thread signaled to stop. 2025-02-05 08:48:01.344 | HD Request # 8 | Received 598655 Intraday data records from 2024-08-04 20:08:00.270000 to 2025-02-05 08:37:59.582000 (184.6 days. Delay: 10.0 minutes) and wrote 598655 records for MGCJ25_FUT_CME 2025-02-05 08:48:01.344 | HD Request # 8 | Completion time: 2s. 2025-02-05 08:48:01.344 | HD Request # 8 | Intraday data download complete for MGCJ25_FUT_CME. Unique request ID: 8 2025-02-05 08:48:01.344 | Removing historical data download ID 8. 2025-02-05 08:48:01.344 | Real-time Intraday chart data file updates started for MGCJ25_FUT_CME 2025-02-05 08:48:01.344 | Intraday chart data file opened for MGCJ25_FUT_CME 2025-02-05 08:48:01.344 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2025-02-05 08:48:01.344 | 2025-02-05 08:48:01.344 | Triggering next historical data download in queue. 2025-02-05 08:48:01.344 | Historical data for MGCJ25_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-02-05 08:48:01.344 | HD Request # 9 | Downloading Intraday chart data for MESH25_FUT_CME to the file MESH25_FUT_CME.scid. Service: cme 2025-02-05 08:48:01.344 | HD Request # 9 | Download start date-time: 2024-08-03 09:48:01.000000. File last date-time: 00:00:00.000000 2025-02-05 08:48:01.344 | HD Request # 9 | Using server: ds32.sierracharts.com port 10149 2025-02-05 08:48:01.344 | Socket (1) | Creating socket. 2025-02-05 08:48:01.344 | Socket (1) | New receive buffer size: 0 2025-02-05 08:48:01.344 | Socket (1) | Connecting to IP: 67.214.125.3. 2025-02-05 08:48:01.382 | 2025-02-05 08:48:01.382 | Teton CME Order Routing | Firm: IronBeam 2025-02-05 08:48:01.387 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 2025-02-05 08:48:01.431 | HD Request # 9 | Setting DTC encoding to Binary VLS 2025-02-05 08:48:01.431 | HD Request # 9 | Sending historical data logon request message. 2025-02-05 08:48:01.435 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 08:48:01.436 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 08:48:01.436 | DTC Client socket (2) | Connecting to IP: 208.185.224.130. 2025-02-05 08:48:01.500 | HD Request # 9 | Requesting Intraday data. Start date-time: 2024-08-03 09:48:01. Record interval: 0. Symbol: MESH25 2025-02-05 08:48:01.534 | HD Request # 9 | Decompressing data. 2025-02-05 08:48:01.569 | ESH25_FUT_CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-05 08:48:01.569 | Teton CME Order Routing | Network connection to server complete. 2025-02-05 08:48:01.569 | Teton CME Order Routing | Starting socket receive thread. 2025-02-05 08:48:01.569 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-02-05 08:48:01.620 | HD Request # 9 | Receiving Intraday data for MESH25_FUT_CME starting at 2024-08-04 18:01:20.754000 2025-02-05 08:48:01.665 | Teton CME Order Routing | Setting DTC encoding to Binary VLS 2025-02-05 08:48:01.665 | Teton CME Order Routing | Sending logon request message. 2025-02-05 08:48:01.696 | HD Request # 9 | Timestamp of first Intraday data file record written: 2024-08-04 18:01:20.754000. 2025-02-05 08:48:01.764 | Teton CME Order Routing | Received logon response. 2025-02-05 08:48:01.764 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528. 2025-02-05 08:48:01.764 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 2025-02-05 08:48:01.764 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-02-05 08:48:01.764 | Teton CME Order Routing | Trading is supported. 2025-02-05 08:48:01.764 | Teton CME Order Routing | Order cancel and replace is supported. 2025-02-05 08:48:01.764 | Teton CME Order Routing | OCO Orders supported. 2025-02-05 08:48:01.764 | Teton CME Order Routing | Bracket Orders supported. 2025-02-05 08:48:01.764 | Teton CME Order Routing | MarketDepthIsSupported: 1 2025-02-05 08:48:01.764 | Teton CME Order Routing | Connected to server complete. 2025-02-05 08:48:01.764 | No download requests in the queue to start downloads for. 2025-02-05 08:48:01.764 | Triggering next historical data download in queue. 2025-02-05 08:48:01.764 | No download requests in the queue to start downloads for. | Number times message added: 1 2025-02-05 08:48:01.767 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. 2025-02-05 08:48:01.768 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2025-02-05 05:00:00.539215 2025-02-05 08:48:01.770 | Mapping ESH25_FUT_CME to ESH25. Service code: cme 2025-02-05 08:48:01.770 | Using symbol data fast lookup vector 2025-02-05 08:48:01.770 | Denali Data Feed | Starting real-time market data updates for: ESH25_FUT_CME (ESH25). ID: 1 Service code: cme 2025-02-05 08:48:01.772 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2025-02-05 08:48:01.776 | Denali Data Feed | Requesting security definition data for: ESH25_FUT_CME (ESH25). ID: 1 2025-02-05 08:48:01.776 | Added historical Intraday data request for ESH25_FUT_CME to the queue. 2025-02-05 08:48:01.776 | Intraday data recording state for symbol ESH25_FUT_CME is set to download 'Pending'. 2025-02-05 08:48:01.776 | Triggering next historical data download in queue. 2025-02-05 08:48:01.797 | Updated verified funded futures trading account ending date to: 2025-03-07 13:48:01 2025-02-05 08:48:01.804 | DTC Client socket (3) | Creating socket. 2025-02-05 08:48:01.804 | DTC Client socket (3) | New receive buffer size: 0 2025-02-05 08:48:01.804 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2025-02-05 08:48:01.806 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH25_FUT_CME 2025-02-05 08:48:01.806 | Teton CME Order Routing | Received security definition for symbol ESH25_FUT_CME 2025-02-05 08:48:01.815 | Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=36001046 2025-02-05 08:48:01.838 | Denali Data Feed | Network connection to server complete. 2025-02-05 08:48:01.838 | Denali Data Feed | Starting socket receive thread. 2025-02-05 08:48:01.838 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-05 08:48:01.885 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-02-05 08:48:01.885 | Denali Data Feed | Sending logon request message. 2025-02-05 08:48:01.940 | Mapping MGCJ25_FUT_CME to MGCJ25. Service code: comex 2025-02-05 08:48:01.940 | Delayed Data Feed | Starting real-time market data updates for: MGCJ25_FUT_CME (MGCJ25). ID: 2 Service code: comex 2025-02-05 08:48:01.942 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2025-02-05 08:48:01.942 | DTC Client socket (4) | Creating socket. 2025-02-05 08:48:01.942 | DTC Client socket (4) | New receive buffer size: 0 2025-02-05 08:48:01.942 | DTC Client socket (4) | Connecting to IP: 67.214.125.6. 2025-02-05 08:48:01.944 | Delayed Data Feed | Requesting security definition data for: MGCJ25_FUT_CME (MGCJ25). ID: 2 2025-02-05 08:48:01.944 | Added historical Intraday data request for MGCJ25_FUT_CME to the queue. 2025-02-05 08:48:01.944 | Intraday data recording state for symbol MGCJ25_FUT_CME is set to download 'Pending'. 2025-02-05 08:48:01.944 | Triggering next historical data download in queue. 2025-02-05 08:48:01.978 | Mapping MESH25_FUT_CME to MESH25. Service code: cme 2025-02-05 08:48:01.978 | Denali Data Feed | Starting real-time market data updates for: MESH25_FUT_CME (MESH25). ID: 3 Service code: cme 2025-02-05 08:48:01.978 | Denali Data Feed | Requesting security definition data for: MESH25_FUT_CME (MESH25). ID: 3 2025-02-05 08:48:02.046 | MESH25_FUT_CME[M] 1 Min #14 | StartDateTimeForLoadingOrderFills: 2024-08-04 18:01:00 2025-02-05 08:48:02.051 | Delayed Data Feed | Network connection to server complete. 2025-02-05 08:48:02.051 | Delayed Data Feed | Starting socket receive thread. 2025-02-05 08:48:02.051 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-05 08:48:02.057 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH25_FUT_CME 2025-02-05 08:48:02.057 | Teton CME Order Routing | Received security definition for symbol MESH25_FUT_CME 2025-02-05 08:48:02.058 | Mapping MCLH25_FUT_CME to MCLH25. Service code: nymex 2025-02-05 08:48:02.058 | Delayed Data Feed | Starting real-time market data updates for: MCLH25_FUT_CME (MCLH25). ID: 4 Service code: nymex 2025-02-05 08:48:02.058 | Delayed Data Feed | Requesting security definition data for: MCLH25_FUT_CME (MCLH25). ID: 4 2025-02-05 08:48:02.107 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2025-02-05 08:48:02.107 | Delayed Data Feed | Sending logon request message. 2025-02-05 08:48:02.222 | Mapping MYMH25_FUT_CME to MYMH25. Service code: cbot 2025-02-05 08:48:02.222 | Delayed Data Feed | Starting real-time market data updates for: MYMH25_FUT_CME (MYMH25). ID: 5 Service code: cbot 2025-02-05 08:48:02.222 | Delayed Data Feed | Requesting security definition data for: MYMH25_FUT_CME (MYMH25). ID: 5 2025-02-05 08:48:02.354 | Denali Data Feed | Received logon response. 2025-02-05 08:48:02.354 | Denali Data Feed | Server Name: SC Realtime Server. 2025-02-05 08:48:02.354 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-02-05 08:48:02.354 | Denali Data Feed | Successfully connected. 2025-02-05 08:48:02.354 | Denali Data Feed | Trading is not supported. 2025-02-05 08:48:02.354 | Denali Data Feed | MarketDepthIsSupported: 1 2025-02-05 08:48:02.354 | Denali Data Feed | Restarting real-time data updates for symbol: ESH25_FUT_CME -> ESH25 2025-02-05 08:48:02.354 | Denali Data Feed | Restarting real-time data updates for symbol: MESH25_FUT_CME -> MESH25 2025-02-05 08:48:02.561 | Denali Data Feed | Received security definition for symbol ESH25_FUT_CME 2025-02-05 08:48:02.561 | Denali Data Feed | Received security definition for symbol MESH25_FUT_CME 2025-02-05 08:48:02.574 | Delayed Data Feed | Received logon response. 2025-02-05 08:48:02.574 | Delayed Data Feed | Server Name: SC Realtime Server. 2025-02-05 08:48:02.574 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2025-02-05 08:48:02.574 | Delayed Data Feed | Successfully connected. 2025-02-05 08:48:02.574 | Delayed Data Feed | Trading is not supported. 2025-02-05 08:48:02.574 | Delayed Data Feed | MarketDepthIsSupported: 1 2025-02-05 08:48:02.574 | Delayed Data Feed | Restarting real-time data updates for symbol: MCLH25_FUT_CME -> MCLH25 2025-02-05 08:48:02.574 | Delayed Data Feed | Restarting real-time data updates for symbol: MGCJ25_FUT_CME -> MGCJ25 2025-02-05 08:48:02.574 | Delayed Data Feed | Restarting real-time data updates for symbol: MYMH25_FUT_CME -> MYMH25 2025-02-05 08:48:02.724 | Delayed Data Feed | Received security definition for symbol MCLH25_FUT_CME 2025-02-05 08:48:02.724 | Delayed Data Feed | Received security definition for symbol MGCJ25_FUT_CME 2025-02-05 08:48:02.724 | Delayed Data Feed | Received security definition for symbol MYMH25_FUT_CME 2025-02-05 08:48:06.752 | Requesting market depth updates for: ESH25_FUT_CME if supported. NumLevels=100 2025-02-05 08:48:06.752 | Requesting market depth updates for: MCLH25_FUT_CME if supported. NumLevels=100 2025-02-05 08:48:06.752 | Requesting market depth updates for: MESH25_FUT_CME if supported. NumLevels=100 2025-02-05 08:48:06.752 | Requesting market depth updates for: MGCJ25_FUT_CME if supported. NumLevels=100 2025-02-05 08:48:06.752 | Requesting market depth updates for: MYMH25_FUT_CME if supported. NumLevels=100 2025-02-05 08:48:06.808 | Delayed Data Feed | Clearing market depth for MCLH25_FUT_CME 2025-02-05 08:48:06.808 | Delayed Data Feed | Clearing market depth for MGCJ25_FUT_CME 2025-02-05 08:48:06.808 | Delayed Data Feed | Clearing market depth for MYMH25_FUT_CME 2025-02-05 08:48:06.812 | Denali Data Feed | Clearing market depth for ESH25_FUT_CME 2025-02-05 08:48:06.812 | Denali Data Feed | Clearing market depth for MESH25_FUT_CME 2025-02-05 08:48:21.785 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2025-02-05 08:48:22.053 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-03-07"}. Success=true 2025-02-05 08:48:29.670 | Socket (1) | CloseSocket call. 2025-02-05 08:48:29.670 | Historical data download thread signaled to stop. 2025-02-05 08:48:29.670 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:48:29.671 | HD Request # 9 | Received 19584159 Intraday data records from 2024-08-04 18:01:20.754000 to 2025-02-05 08:48:29.529000 (184.7 days. Delay: 0.1 seconds) and wrote 19584159 records for MESH25_FUT_CME 2025-02-05 08:48:29.681 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:48:29.529000 2025-02-05 08:48:29.681 | HD Request # 9 | Completion time: 28s. 2025-02-05 08:48:29.681 | HD Request # 9 | Intraday data download complete for MESH25_FUT_CME. Unique request ID: 9 2025-02-05 08:48:29.681 | Removing historical data download ID 9. 2025-02-05 08:48:29.681 | Real-time Intraday chart data file updates started for MESH25_FUT_CME 2025-02-05 08:48:29.681 | Intraday chart data file opened for MESH25_FUT_CME 2025-02-05 08:48:29.681 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2025-02-05 08:48:29.681 | 2025-02-05 08:48:29.681 | Triggering next historical data download in queue. 2025-02-05 08:48:29.681 | Initiating new historical data download for MESH25_FUT_CME to get the latest data since the download was started while not connected to primary service. 2025-02-05 08:48:29.681 | Added historical Intraday data request for MESH25_FUT_CME to the queue. 2025-02-05 08:48:29.681 | Intraday data recording state for symbol MESH25_FUT_CME is set to download 'Pending'. 2025-02-05 08:48:29.681 | HD Request # 10 | Downloading Intraday chart data for MESH25_FUT_CME to the file MESH25_FUT_CME.scid. Service: cme 2025-02-05 08:48:29.682 | HD Request # 10 | Download start date-time: 2025-02-05 08:48:29.000000. File last date-time: 2025-02-05 08:48:29.529000 2025-02-05 08:48:29.682 | HD Request # 10 | Using server: ds26.sierracharts.com port 10150 2025-02-05 08:48:29.682 | Socket (5) | Creating socket. 2025-02-05 08:48:29.682 | Socket (5) | New receive buffer size: 0 2025-02-05 08:48:29.682 | Socket (5) | Connecting to IP: 64.152.155.17. 2025-02-05 08:48:29.702 | Socket (1) | Socket gracefully closed by remote side. 2025-02-05 08:48:29.702 | Socket (1) | Closed. 2025-02-05 08:48:29.756 | HD Request # 10 | Setting DTC encoding to Binary VLS 2025-02-05 08:48:29.756 | HD Request # 10 | Sending historical data logon request message. 2025-02-05 08:48:29.826 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-02-05 08:48:29. Record interval: 0. Symbol: MESH25 2025-02-05 08:48:29.855 | HD Request # 10 | Decompressing data. 2025-02-05 08:48:29.897 | HD Request # 10 | Receiving Intraday data for MESH25_FUT_CME starting at 2025-02-05 07:48:28.832000 2025-02-05 08:48:29.958 | Socket (5) | CloseSocket call. 2025-02-05 08:48:29.959 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 08:48:29.975 | Historical data download thread signaled to stop. 2025-02-05 08:48:29.976 | HD Request # 10 | Received 17653 Intraday data records from 2025-02-05 07:48:28.832000 to 2025-02-05 08:48:27.945000 (60.0 minutes. Delay: 2.0 seconds) and wrote 0 records for MESH25_FUT_CME 2025-02-05 08:48:29.976 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:48:29.529000 2025-02-05 08:48:29.976 | Added 1 Time and Sales records to Intraday data file for MESH25_FUT_CME after download. 2025-02-05 08:48:29.976 | HD Request # 10 | Timestamp of first Intraday data file record written: 2025-02-05 08:48:30.119000. 2025-02-05 08:48:29.976 | HD Request # 10 | Completion time: 0s. 2025-02-05 08:48:29.976 | HD Request # 10 | Intraday data download complete for MESH25_FUT_CME. Unique request ID: 14 2025-02-05 08:48:29.976 | Removing historical data download ID 14. 2025-02-05 08:48:29.976 | Real-time Intraday chart data file updates started for MESH25_FUT_CME 2025-02-05 08:48:29.976 | Intraday chart data file opened for MESH25_FUT_CME 2025-02-05 08:48:29.976 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2025-02-05 08:48:29.976 | 2025-02-05 08:48:29.976 | Triggering next historical data download in queue. 2025-02-05 08:48:29.977 | HD Request # 11 | Downloading Intraday chart data for MCLH25_FUT_CME to the file MCLH25_FUT_CME.scid. Service: nymex 2025-02-05 08:48:29.977 | HD Request # 11 | Download start date-time: 2024-08-03 09:48:29.000000. File last date-time: 00:00:00.000000 2025-02-05 08:48:29.977 | HD Request # 11 | Using server: ds28.sierracharts.com port 10149 2025-02-05 08:48:29.977 | Socket (1) | Creating socket. 2025-02-05 08:48:29.977 | Socket (1) | New receive buffer size: 0 2025-02-05 08:48:29.977 | Socket (1) | Connecting to IP: 67.214.125.5. 2025-02-05 08:48:29.987 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 08:48:29.987 | Socket (5) | Closed. 2025-02-05 08:48:30.049 | HD Request # 11 | Setting DTC encoding to Binary VLS 2025-02-05 08:48:30.049 | HD Request # 11 | Sending historical data logon request message. 2025-02-05 08:48:30.128 | HD Request # 11 | Requesting Intraday data. Start date-time: 2024-08-03 09:48:29. Record interval: 0. Symbol: MCLH25 2025-02-05 08:48:30.158 | HD Request # 11 | Decompressing data. 2025-02-05 08:48:30.239 | HD Request # 11 | Receiving Intraday data for MCLH25_FUT_CME starting at 2024-08-04 22:14:34.811000 2025-02-05 08:48:30.344 | HD Request # 11 | Timestamp of first Intraday data file record written: 2024-08-04 22:14:34.811000. 2025-02-05 08:48:30.566 | MCLH25_FUT_CME[M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2024-08-04 22:10:00 2025-02-05 08:48:31.626 | Socket (1) | CloseSocket call. 2025-02-05 08:48:31.626 | Historical data download thread signaled to stop. 2025-02-05 08:48:31.626 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:48:31.626 | HD Request # 11 | Received 884366 Intraday data records from 2024-08-04 22:14:34.811000 to 2025-02-05 08:38:30.848000 (184.5 days. Delay: 10.0 minutes) and wrote 884366 records for MCLH25_FUT_CME 2025-02-05 08:48:31.636 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:38:30.848000 2025-02-05 08:48:31.636 | HD Request # 11 | Completion time: 2s. 2025-02-05 08:48:31.636 | HD Request # 11 | Intraday data download complete for MCLH25_FUT_CME. Unique request ID: 10 2025-02-05 08:48:31.636 | Removing historical data download ID 10. 2025-02-05 08:48:31.636 | Real-time Intraday chart data file updates started for MCLH25_FUT_CME 2025-02-05 08:48:31.636 | Intraday chart data file opened for MCLH25_FUT_CME 2025-02-05 08:48:31.636 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2025-02-05 08:48:31.636 | 2025-02-05 08:48:31.636 | Triggering next historical data download in queue. 2025-02-05 08:48:31.636 | HD Request # 12 | Downloading Intraday chart data for MYMH25_FUT_CME to the file MYMH25_FUT_CME.scid. Service: cbot 2025-02-05 08:48:31.636 | HD Request # 12 | Download start date-time: 2025-01-07 15:47:22.000000. File last date-time: 2025-01-07 15:47:22.267000 2025-02-05 08:48:31.636 | HD Request # 12 | Using server: ds32.sierracharts.com port 10150 2025-02-05 08:48:31.637 | Socket (5) | Creating socket. 2025-02-05 08:48:31.637 | Socket (5) | New receive buffer size: 0 2025-02-05 08:48:31.637 | Socket (5) | Connecting to IP: 67.214.125.3. 2025-02-05 08:48:31.659 | Socket (1) | Socket gracefully closed by remote side. 2025-02-05 08:48:31.659 | Socket (1) | Closed. 2025-02-05 08:48:31.706 | HD Request # 12 | Setting DTC encoding to Binary VLS 2025-02-05 08:48:31.706 | HD Request # 12 | Sending historical data logon request message. 2025-02-05 08:48:31.781 | HD Request # 12 | Requesting Intraday data. Start date-time: 2025-01-07 15:47:22. Record interval: 0. Symbol: MYMH25 2025-02-05 08:48:31.812 | HD Request # 12 | Decompressing data. 2025-02-05 08:48:31.891 | HD Request # 12 | Receiving Intraday data for MYMH25_FUT_CME starting at 2025-01-07 15:47:22.267000 2025-02-05 08:48:31.978 | HD Request # 12 | Timestamp of first Intraday data file record written: 2025-01-07 15:47:24.769000. 2025-02-05 08:48:32.500 | Opened cached Intraday file: D:\SierraChart\Data\MCLH25_FUT_CME.scid. Thread ID: 23708 2025-02-05 08:48:33.832 | Opened cached Intraday file: D:\SierraChart\Data\MESH25_FUT_CME.scid. Thread ID: 22756 2025-02-05 08:48:35.396 | Socket (5) | CloseSocket call. 2025-02-05 08:48:35.396 | Historical data download thread signaled to stop. 2025-02-05 08:48:35.396 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 08:48:35.396 | HD Request # 12 | Received 2050641 Intraday data records from 2025-01-07 15:47:22.267000 to 2025-02-05 08:38:29.566004 (28.7 days. Delay: 10.1 minutes) and wrote 2050640 records for MYMH25_FUT_CME 2025-02-05 08:48:35.405 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:38:29.566004 2025-02-05 08:48:35.405 | HD Request # 12 | Completion time: 4s. 2025-02-05 08:48:35.405 | HD Request # 12 | Intraday data download complete for MYMH25_FUT_CME. Unique request ID: 11 2025-02-05 08:48:35.405 | Removing historical data download ID 11. 2025-02-05 08:48:35.405 | Real-time Intraday chart data file updates started for MYMH25_FUT_CME 2025-02-05 08:48:35.405 | Intraday chart data file opened for MYMH25_FUT_CME 2025-02-05 08:48:35.405 | HD Request # 12 | Enabling Intraday chart updating for symbol. 2025-02-05 08:48:35.405 | 2025-02-05 08:48:35.405 | Triggering next historical data download in queue. 2025-02-05 08:48:35.405 | HD Request # 13 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme 2025-02-05 08:48:35.405 | HD Request # 13 | Download start date-time: 2025-02-05 08:47:54.000000. File last date-time: 2025-02-05 08:47:54.936000 2025-02-05 08:48:35.405 | HD Request # 13 | Using server: ds26.sierracharts.com port 10149 2025-02-05 08:48:35.405 | Socket (1) | Creating socket. 2025-02-05 08:48:35.405 | Socket (1) | New receive buffer size: 0 2025-02-05 08:48:35.405 | Socket (1) | Connecting to IP: 64.152.155.17. 2025-02-05 08:48:35.428 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 08:48:35.428 | Socket (5) | Closed. 2025-02-05 08:48:35.473 | HD Request # 13 | Setting DTC encoding to Binary VLS 2025-02-05 08:48:35.473 | HD Request # 13 | Sending historical data logon request message. 2025-02-05 08:48:35.547 | HD Request # 13 | Requesting Intraday data. Start date-time: 2025-02-05 08:47:54. Record interval: 0. Symbol: ESH25 2025-02-05 08:48:35.574 | HD Request # 13 | Decompressing data. 2025-02-05 08:48:35.604 | HD Request # 13 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-02-05 08:47:54.177000 2025-02-05 08:48:35.605 | Socket (1) | CloseSocket call. 2025-02-05 08:48:35.605 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:48:35.606 | Historical data download thread signaled to stop. 2025-02-05 08:48:35.606 | HD Request # 13 | Timestamp of first Intraday data file record written: 2025-02-05 08:47:56.140000. 2025-02-05 08:48:35.606 | HD Request # 13 | Received 271 Intraday data records from 2025-02-05 08:47:54.177000 to 2025-02-05 08:48:31.336000 (37.2 seconds. Delay: 4.3 seconds) and wrote 241 records for ESH25_FUT_CME 2025-02-05 08:48:35.614 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:48:31.336000 2025-02-05 08:48:35.614 | Added 27 Time and Sales records to Intraday data file for ESH25_FUT_CME after download. 2025-02-05 08:48:35.614 | HD Request # 13 | Completion time: 0s. 2025-02-05 08:48:35.614 | HD Request # 13 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 12 2025-02-05 08:48:35.614 | Removing historical data download ID 12. 2025-02-05 08:48:35.614 | Real-time Intraday chart data file updates started for ESH25_FUT_CME 2025-02-05 08:48:35.614 | Intraday chart data file opened for ESH25_FUT_CME 2025-02-05 08:48:35.614 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2025-02-05 08:48:35.614 | 2025-02-05 08:48:35.614 | Triggering next historical data download in queue. 2025-02-05 08:48:35.614 | HD Request # 14 | Downloading Intraday chart data for MGCJ25_FUT_CME to the file MGCJ25_FUT_CME.scid. Service: comex 2025-02-05 08:48:35.615 | HD Request # 14 | Download start date-time: 2025-02-05 08:37:59.000000. File last date-time: 2025-02-05 08:37:59.582000 2025-02-05 08:48:35.615 | HD Request # 14 | Using server: ds28.sierracharts.com port 10150 2025-02-05 08:48:35.615 | Socket (5) | Creating socket. 2025-02-05 08:48:35.615 | Socket (5) | New receive buffer size: 0 2025-02-05 08:48:35.615 | Socket (5) | Connecting to IP: 67.214.125.5. 2025-02-05 08:48:35.633 | Socket (1) | Socket gracefully closed by remote side. 2025-02-05 08:48:35.633 | Socket (1) | Closed. 2025-02-05 08:48:35.687 | HD Request # 14 | Setting DTC encoding to Binary VLS 2025-02-05 08:48:35.687 | HD Request # 14 | Sending historical data logon request message. 2025-02-05 08:48:35.762 | HD Request # 14 | Requesting Intraday data. Start date-time: 2025-02-05 08:37:59. Record interval: 0. Symbol: MGCJ25 2025-02-05 08:48:35.793 | HD Request # 14 | Decompressing data. 2025-02-05 08:48:35.824 | HD Request # 14 | Receiving Intraday data for MGCJ25_FUT_CME starting at 2025-02-05 08:37:59.582000 2025-02-05 08:48:35.824 | Socket (5) | CloseSocket call. 2025-02-05 08:48:35.824 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 08:48:35.824 | Historical data download thread signaled to stop. 2025-02-05 08:48:35.824 | HD Request # 14 | Timestamp of first Intraday data file record written: 2025-02-05 08:38:02.414000. 2025-02-05 08:48:35.824 | HD Request # 14 | Received 53 Intraday data records from 2025-02-05 08:37:59.582000 to 2025-02-05 08:38:34.341000 (34.8 seconds. Delay: 10.0 minutes) and wrote 52 records for MGCJ25_FUT_CME 2025-02-05 08:48:35.832 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:38:34.341000 2025-02-05 08:48:35.832 | HD Request # 14 | Completion time: 0s. 2025-02-05 08:48:35.832 | HD Request # 14 | Intraday data download complete for MGCJ25_FUT_CME. Unique request ID: 13 2025-02-05 08:48:35.832 | Removing historical data download ID 13. 2025-02-05 08:48:35.832 | Real-time Intraday chart data file updates started for MGCJ25_FUT_CME 2025-02-05 08:48:35.832 | Intraday chart data file opened for MGCJ25_FUT_CME 2025-02-05 08:48:35.832 | HD Request # 14 | Enabling Intraday chart updating for symbol. 2025-02-05 08:48:35.832 | 2025-02-05 08:48:35.832 | No download requests in the queue to start downloads for. 2025-02-05 08:48:35.856 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 08:48:35.856 | Socket (5) | Closed. 2025-02-05 08:48:36.126 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ25_FUT_CME.scid. Thread ID: 23708 2025-02-05 08:48:38.878 | Opened cached Intraday file: D:\SierraChart\Data\ESH25_FUT_CME.scid. Thread ID: 22756 2025-02-05 08:48:39.480 | Opened cached Intraday file: D:\SierraChart\Data\MYMH25_FUT_CME.scid. Thread ID: 23708 2025-02-05 08:54:51.053 | Teton CME Order Routing | Waiting for socket receive thread to end 2025-02-05 08:54:51.053 | DTC Client socket (2) | CloseSocket call. 2025-02-05 08:54:51.053 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 08:54:51.053 | DTC Client socket (2) | Max send buffer size during socket life: 236 2025-02-05 08:54:51.053 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-02-05 08:54:51.053 | Denali Data Feed | Waiting for socket receive thread to end 2025-02-05 08:54:51.054 | DTC Client socket (3) | CloseSocket call. 2025-02-05 08:54:51.054 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2025-02-05 08:54:51.054 | Denali Data Feed | Disconnected from the server. 2025-02-05 08:54:51.054 | Delayed Data Feed | Waiting for socket receive thread to end 2025-02-05 08:54:51.054 | DTC Client socket (4) | CloseSocket call. 2025-02-05 08:54:51.054 | Delayed Data Feed | Disconnected from the server. 2025-02-05 08:54:51.054 | Teton CME Order Routing | Disconnected. 2025-02-05 08:54:51.054 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 08:54:51.082 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 4. 2025-02-05 08:54:51.082 | Current selected Data/Trading service: Rithmic Direct - DTC 2025-02-05 08:54:51.084 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 08:54:51.084 | DTC Client socket (2) | Closed. 2025-02-05 08:54:51.086 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-02-05 08:54:51.086 | DTC Client socket (3) | Closed. 2025-02-05 08:54:51.104 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. 2025-02-05 08:54:51.104 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | New receive buffer size: 0 2025-02-05 08:54:51.104 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Connecting to IP: 216.66.0.130. 2025-02-05 08:54:51.175 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-02-05 08:54:51.175 | DTC Client socket (4) | Closed. 2025-02-05 08:54:51.673 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | CloseSocket call. 2025-02-05 08:54:51.673 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:54:51.699 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2025-02-05 08:54:51.699 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (1) | Closed. 2025-02-05 08:54:51.745 | Symbol settings MD5 received. Request ID: 4. 2025-02-05 08:54:51.745 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 5. 2025-02-05 08:54:52.310 | Symbol settings received. Request ID: 5. 2025-02-05 08:54:52.375 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-02-05 08:54:52.507 | ESH5.CME [CBV][M] 10 Min #1 | Reloading chart. 2025-02-05 08:54:52.529 | MGCJ5.COMEX[M] 15 Sec #6 | Reloading chart. 2025-02-05 08:54:52.538 | MESH5.CME[M] 1 Min #14 | Reloading chart. 2025-02-05 08:54:52.542 | Mapping ESH5.CME to ESH25. Service code: cme 2025-02-05 08:54:52.543 | Added historical Intraday data request for ESH5.CME to the queue. 2025-02-05 08:54:52.543 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'. 2025-02-05 08:54:52.543 | Triggering next historical data download in queue. 2025-02-05 08:54:52.543 | HD Request # 15 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme 2025-02-05 08:54:52.543 | HD Request # 15 | Download start date-time: 2025-02-05 08:47:02.000000. File last date-time: 2025-02-05 08:47:02.380003 2025-02-05 08:54:52.543 | HD Request # 15 | Using server: ds32.sierracharts.com port 10149 2025-02-05 08:54:52.543 | Socket (2) | Creating socket. 2025-02-05 08:54:52.543 | Socket (2) | New receive buffer size: 0 2025-02-05 08:54:52.543 | Socket (2) | Connecting to IP: 67.214.125.3. 2025-02-05 08:54:52.548 | MCLH5.NYMEX[M] 5 Min #2 | Reloading chart. 2025-02-05 08:54:52.630 | HD Request # 15 | Setting DTC encoding to Binary VLS 2025-02-05 08:54:52.630 | HD Request # 15 | Sending historical data logon request message. 2025-02-05 08:54:52.697 | ESH5.CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 08:54:52.724 | HD Request # 15 | Requesting Intraday data. Start date-time: 2025-02-05 08:47:02. Record interval: 0. Symbol: ESH25 2025-02-05 08:54:52.770 | HD Request # 15 | Decompressing data. 2025-02-05 08:54:52.821 | HD Request # 15 | Receiving Intraday data for ESH5.CME starting at 2025-02-05 08:47:02.379000 2025-02-05 08:54:52.823 | Socket (2) | CloseSocket call. 2025-02-05 08:54:52.823 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-05 08:54:52.862 | Socket (2) | Socket gracefully closed by remote side. 2025-02-05 08:54:52.862 | Socket (2) | Closed. 2025-02-05 08:54:53.502 | MGCJ5.COMEX[M] 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 08:54:53.550 | MGCJ5.COMEX[M] 15 Sec #6 | Chart data loading complete. 2025-02-05 08:54:53.550 | Historical data download thread signaled to stop. 2025-02-05 08:54:53.551 | HD Request # 15 | Timestamp of first Intraday data file record written: 2025-02-05 08:47:03.757000. 2025-02-05 08:54:53.551 | HD Request # 15 | Received 2418 Intraday data records from 2025-02-05 08:47:02.379000 to 2025-02-05 08:54:50.852010 (7.8 minutes. Delay: 2.7 seconds) and wrote 2401 records for ESH5.CME 2025-02-05 08:54:53.551 | HD Request # 15 | Completion time: 1s. 2025-02-05 08:54:53.551 | HD Request # 15 | Intraday data download complete for ESH5.CME. Unique request ID: 15 2025-02-05 08:54:53.551 | Removing historical data download ID 15. 2025-02-05 08:54:53.551 | Real-time Intraday chart data file updates started for ESH5.CME 2025-02-05 08:54:53.551 | Intraday chart data file opened for ESH5.CME 2025-02-05 08:54:53.551 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2025-02-05 08:54:53.551 | 2025-02-05 08:54:53.551 | No download requests in the queue to start downloads for. 2025-02-05 08:54:53.551 | Historical data for ESH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-02-05 08:54:53.552 | MCLH5.NYMEX[M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:54:53.554 | MCLH5.NYMEX[M] 5 Min #2 | Chart data loading complete. 2025-02-05 08:54:53.563 | ESH5.CME [CBV][M] 10 Min #1 | StartDateTimeForLoadingOrderFills: 2025-01-22 08:54:50 2025-02-05 08:54:53.565 | ESH5.CME [CBV][M] 10 Min #1 | Chart data loading complete. 2025-02-05 08:54:53.641 | ESH5.CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-05 08:54:53.644 | MYMH5.CBOT[M] 2 Min #11 | Reloading chart. 2025-02-05 08:54:53.691 | Mapping MESH5.CME to MESH25. Service code: cme 2025-02-05 08:54:53.691 | Added historical Intraday data request for MESH5.CME to the queue. 2025-02-05 08:54:53.691 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'. 2025-02-05 08:54:53.691 | Triggering next historical data download in queue. 2025-02-05 08:54:53.691 | HD Request # 16 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme 2025-02-05 08:54:53.692 | HD Request # 16 | Download start date-time: 2025-02-05 08:47:00.000000. File last date-time: 2025-02-05 08:47:00.746005 2025-02-05 08:54:53.692 | HD Request # 16 | Using server: ds26.sierracharts.com port 10150 2025-02-05 08:54:53.692 | Socket (1) | Creating socket. 2025-02-05 08:54:53.692 | Socket (1) | New receive buffer size: 0 2025-02-05 08:54:53.692 | Socket (1) | Connecting to IP: 64.152.155.17. 2025-02-05 08:54:53.764 | HD Request # 16 | Setting DTC encoding to Binary VLS 2025-02-05 08:54:53.764 | HD Request # 16 | Sending historical data logon request message. 2025-02-05 08:54:53.826 | HD Request # 16 | Requesting Intraday data. Start date-time: 2025-02-05 08:47:00. Record interval: 0. Symbol: MESH25 2025-02-05 08:54:53.856 | HD Request # 16 | Decompressing data. 2025-02-05 08:54:53.884 | HD Request # 16 | Receiving Intraday data for MESH5.CME starting at 2025-02-05 08:47:00.746000 2025-02-05 08:54:53.885 | Socket (1) | CloseSocket call. 2025-02-05 08:54:53.885 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-02-05 08:54:53.885 | Historical data download thread signaled to stop. 2025-02-05 08:54:53.886 | HD Request # 16 | Timestamp of first Intraday data file record written: 2025-02-05 08:47:02.379000. 2025-02-05 08:54:53.886 | HD Request # 16 | Received 1410 Intraday data records from 2025-02-05 08:47:00.746000 to 2025-02-05 08:54:49.523000 (7.8 minutes. Delay: 4.4 seconds) and wrote 1404 records for MESH5.CME 2025-02-05 08:54:53.887 | HD Request # 16 | Completion time: 0s. 2025-02-05 08:54:53.887 | HD Request # 16 | Intraday data download complete for MESH5.CME. Unique request ID: 16 2025-02-05 08:54:53.887 | Removing historical data download ID 16. 2025-02-05 08:54:53.887 | Real-time Intraday chart data file updates started for MESH5.CME 2025-02-05 08:54:53.887 | Intraday chart data file opened for MESH5.CME 2025-02-05 08:54:53.887 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2025-02-05 08:54:53.887 | 2025-02-05 08:54:53.887 | No download requests in the queue to start downloads for. 2025-02-05 08:54:53.887 | Historical data for MESH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-02-05 08:54:53.913 | Socket (1) | Socket gracefully closed by remote side. 2025-02-05 08:54:53.913 | Socket (1) | Closed. 2025-02-05 08:54:54.139 | MYMH5.CBOT[M] 2 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:54:54.141 | MYMH5.CBOT[M] 2 Min #11 | Chart data loading complete. 2025-02-05 08:54:55.268 | MESH5.CME[M] 1 Min #14 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:54:55.274 | MESH5.CME[M] 1 Min #14 | Chart data loading complete. 2025-02-05 08:54:56.361 | 2025-02-05 08:54:56.361 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 08:54:56.364 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2025-02-05 08:54:56.443 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-02-05 08:54:56.443 | DTC Client socket (1) | New receive buffer size: 0 2025-02-05 08:54:56.443 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2025-02-05 08:54:56.492 | Rithmic Direct - DTC | Network connection to server complete. 2025-02-05 08:54:56.492 | Rithmic Direct - DTC | Starting socket receive thread. 2025-02-05 08:54:56.492 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2025-02-05 08:54:56.492 | Rithmic Direct - DTC | Sending logon request message. 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Received logon response. 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Server Name: . 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Successfully connected. 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Trading is supported. 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Order cancel and replace is supported. 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | OCO Orders supported. 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2025-02-05 08:54:56.639 | Rithmic Direct - DTC | Connected to server complete. 2025-02-05 08:54:56.639 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-02-05 08:54:56.650 | Using symbol data fast lookup vector 2025-02-05 08:54:56.650 | Rithmic Direct - DTC | Starting real-time market data updates for: MYMH5.CBOT. ID: 1 Service code: rithmic.trading 2025-02-05 08:54:56.651 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 08:54:56.652 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 08:54:56.652 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 08:54:56.652 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 08:54:56.653 | Rithmic Direct - DTC | Requesting security definition data for: MYMH5.CBOT. ID: 1 2025-02-05 08:54:56.653 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 08:54:56.653 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 08:54:56.653 | Triggering next historical data download in queue. 2025-02-05 08:54:56.654 | Delaying start of download for MYMH5.CBOT. 2025-02-05 08:54:56.662 | Mapping ESH5.CME to ESH25. Service code: cme 2025-02-05 08:54:56.662 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 2 Service code: cme 2025-02-05 08:54:56.662 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048 2025-02-05 08:54:56.662 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 2 2025-02-05 08:54:56.662 | Added historical Intraday data request for ESH5.CME to the queue. 2025-02-05 08:54:56.662 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'. 2025-02-05 08:54:56.662 | Triggering next historical data download in queue. 2025-02-05 08:54:56.719 | ESH5.CME [CBV][M] 10 Min #1 | StartDateTimeForLoadingOrderFills: 2025-01-22 08:54:50 2025-02-05 08:54:57.026 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 08:54:57.027 | Rithmic Direct - DTC | Starting real-time market data updates for: MGCJ5.COMEX. ID: 3 Service code: rithmic.trading 2025-02-05 08:54:57.027 | Rithmic Direct - DTC | Requesting security definition data for: MGCJ5.COMEX. ID: 3 2025-02-05 08:54:57.027 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 08:54:57.027 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 08:54:57.027 | Triggering next historical data download in queue. 2025-02-05 08:54:57.048 | DTC Client socket (3) | Creating socket. 2025-02-05 08:54:57.048 | DTC Client socket (3) | New receive buffer size: 0 2025-02-05 08:54:57.048 | DTC Client socket (3) | Connecting to IP: 208.185.224.131. 2025-02-05 08:54:57.066 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 08:54:57.066 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 08:54:57.066 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 08:54:57.066 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 08:54:57.072 | MCLH5.NYMEX 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:54:57.073 | Rithmic Direct - DTC | Starting real-time market data updates for: MCLH5.NYMEX. ID: 4 Service code: rithmic.trading 2025-02-05 08:54:57.073 | Rithmic Direct - DTC | Requesting security definition data for: MCLH5.NYMEX. ID: 4 2025-02-05 08:54:57.073 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 08:54:57.073 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 08:54:57.073 | Triggering next historical data download in queue. 2025-02-05 08:54:57.130 | Denali Data Feed | Network connection to server complete. 2025-02-05 08:54:57.130 | Denali Data Feed | Starting socket receive thread. 2025-02-05 08:54:57.130 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-05 08:54:57.134 | MESH5.CME[M] 1 Min #14 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:54:57.135 | Mapping MESH5.CME to MESH25. Service code: cme 2025-02-05 08:54:57.135 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 5 Service code: cme 2025-02-05 08:54:57.135 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 5 2025-02-05 08:54:57.135 | Added historical Intraday data request for MESH5.CME to the queue. 2025-02-05 08:54:57.135 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'. 2025-02-05 08:54:57.135 | Triggering next historical data download in queue. 2025-02-05 08:54:57.155 | MYMH5.CBOT 2 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:15:00 2025-02-05 08:54:57.192 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-02-05 08:54:57.193 | Denali Data Feed | Sending logon request message. 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX 2025-02-05 08:54:57.222 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-05 08:54:57.238 | Denali Data Feed | Received logon response. 2025-02-05 08:54:57.238 | Denali Data Feed | Server Name: RealTimeServer. 2025-02-05 08:54:57.238 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-02-05 08:54:57.238 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2025-02-05 08:54:57.238 | Denali Data Feed | Failed connections: 1 2025-02-05 08:54:57.238 | Denali Data Feed | Waiting for socket receive thread to end 2025-02-05 08:54:57.238 | DTC Client socket (3) | CloseSocket call. 2025-02-05 08:54:57.238 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2025-02-05 08:54:57.238 | Denali Data Feed | Disconnected from the server. 2025-02-05 08:54:57.238 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2025-02-05 08:54:57.265 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 08:54:57.265 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 08:54:57.265 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 08:54:57.269 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-02-05 08:54:57.269 | DTC Client socket (3) | Closed. 2025-02-05 08:55:00.243 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 2025-02-05 08:55:00.244 | DTC Client socket (3) | Creating socket. 2025-02-05 08:55:00.244 | DTC Client socket (3) | New receive buffer size: 0 2025-02-05 08:55:00.244 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2025-02-05 08:55:00.284 | Denali Data Feed | Network connection to server complete. 2025-02-05 08:55:00.284 | Denali Data Feed | Starting socket receive thread. 2025-02-05 08:55:00.284 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-05 08:55:00.349 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-02-05 08:55:00.349 | Denali Data Feed | Sending logon request message. 2025-02-05 08:55:00.849 | Denali Data Feed | Received logon response. 2025-02-05 08:55:00.849 | Denali Data Feed | Server Name: SC Realtime Server. 2025-02-05 08:55:00.849 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-02-05 08:55:00.849 | Denali Data Feed | Successfully connected. 2025-02-05 08:55:00.849 | Denali Data Feed | Trading is not supported. 2025-02-05 08:55:00.849 | Denali Data Feed | MarketDepthIsSupported: 1 2025-02-05 08:55:00.849 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25 2025-02-05 08:55:00.849 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25 2025-02-05 08:55:00.974 | Denali Data Feed | Received security definition for symbol ESH5.CME 2025-02-05 08:55:00.974 | Denali Data Feed | Received security definition for symbol MESH5.CME 2025-02-05 08:55:01.639 | Requesting market depth updates for: ESH5.CME if supported. NumLevels=100 2025-02-05 08:55:01.639 | Requesting market depth updates for: MCLH5.NYMEX if supported. NumLevels=100 2025-02-05 08:55:01.640 | Requesting market depth updates for: MESH5.CME if supported. NumLevels=100 2025-02-05 08:55:01.640 | Requesting market depth updates for: MGCJ5.COMEX if supported. NumLevels=100 2025-02-05 08:55:01.640 | Requesting market depth updates for: MYMH5.CBOT if supported. NumLevels=100 2025-02-05 08:55:01.686 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 08:55:01.686 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 08:55:01.686 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 08:55:01.690 | Added historical Daily data request for ESH5.CME to the queue. 2025-02-05 08:55:01.690 | Triggering next historical data download in queue. 2025-02-05 08:55:01.715 | HD Request # 17 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-01-31. Service: rithmic.trading 2025-02-05 08:55:01.756 | Denali Data Feed | Clearing market depth for ESH5.CME 2025-02-05 08:55:01.756 | Denali Data Feed | Clearing market depth for MESH5.CME 2025-02-05 08:55:01.937 | HD Request # 17 | Requesting historical Daily data for ESH25 starting at 2025-01-30. SC External HD service. 2025-02-05 08:55:02.086 | HD Request # 17 | Receiving historical Daily data for ESH5.CME starting at 2025-01-31. 2025-02-05 08:55:02.086 | HD Request # 17 | Writing historical Daily data to the file ESH5.CME.dly. 2025-02-05 08:55:02.093 | HD Request # 17 | Bytes received: 239 2025-02-05 08:55:02.093 | HD Request # 17 | Received 4 Daily data records from 2025-01-31 00:00:00 to 2025-02-04 00:00:00 (5.0 days) and wrote 3 records for ESH5.CME 2025-02-05 08:55:02.093 | HD Request # 17 | Completion time: 1s. 2025-02-05 08:55:02.093 | HD Request # 17 | Daily data download complete for ESH5.CME. Unique request ID: 22 2025-02-05 08:55:02.093 | Removing historical data download ID 22. 2025-02-05 08:55:02.093 | 2025-02-05 08:55:02.093 | No download requests in the queue to start downloads for. 2025-02-05 08:55:02.194 | ESH5.CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 08:55:03.041 | HD Request # 18 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 08:55:03.041 | HD Request # 18 | Download start date-time: 2025-02-05 01:23:10.000000. File last date-time: 2025-02-05 01:23:10.000000 2025-02-05 08:55:03.041 | HD Request # 18 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 08:55:03.041 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 08:55:03.041 | Socket (4) | New receive buffer size: 0 2025-02-05 08:55:03.041 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 08:55:03.092 | HD Request # 18 | Sending historical data logon request message. 2025-02-05 08:55:03.107 | ESH5.CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 08:55:03.222 | HD Request # 18 | Requesting Intraday data. Start date-time: 2025-02-05 01:23:10. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 08:55:03.281 | HD Request # 18 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 01:23:10.140000 2025-02-05 08:55:03.584 | Socket (4) | CloseSocket call. 2025-02-05 08:55:03.584 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 08:55:03.633 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 08:55:03.634 | Socket (4) | Closed. 2025-02-05 08:55:03.754 | Restarting the loading process. 2025-02-05 08:55:03.756 | Historical data download thread signaled to stop. 2025-02-05 08:55:03.756 | HD Request # 18 | Timestamp of first Intraday data file record written: 2025-02-05 01:23:10.140000. 2025-02-05 08:55:03.756 | HD Request # 18 | Received 10894 Intraday data records from 2025-02-05 01:23:10.140000 to 2025-02-05 08:55:01.736000 (7.5 hours. Delay: 2.0 seconds) and wrote 10891 records for MYMH5.CBOT 2025-02-05 08:55:03.782 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:55:01.736000 2025-02-05 08:55:03.782 | HD Request # 18 | Completion time: 0s. 2025-02-05 08:55:03.782 | HD Request # 18 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 17 2025-02-05 08:55:03.782 | Removing historical data download ID 17. 2025-02-05 08:55:03.782 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 08:55:03.782 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 08:55:03.782 | HD Request # 18 | Enabling Intraday chart updating for symbol. 2025-02-05 08:55:03.782 | 2025-02-05 08:55:03.782 | Triggering next historical data download in queue. 2025-02-05 08:55:03.782 | Delaying start of download for ESH5.CME. 2025-02-05 08:55:03.889 | ESH5.CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-05 08:55:05.486 | HD Request # 19 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme 2025-02-05 08:55:05.486 | HD Request # 19 | Download start date-time: 2025-02-05 08:54:50.000000. File last date-time: 2025-02-05 08:54:50.852010 2025-02-05 08:55:05.486 | HD Request # 19 | Using server: ds28.sierracharts.com port 10150 2025-02-05 08:55:05.486 | Socket (4) | Creating socket. 2025-02-05 08:55:05.487 | Socket (4) | New receive buffer size: 0 2025-02-05 08:55:05.487 | Socket (4) | Connecting to IP: 67.214.125.5. 2025-02-05 08:55:05.558 | HD Request # 19 | Setting DTC encoding to Binary VLS 2025-02-05 08:55:05.558 | HD Request # 19 | Sending historical data logon request message. 2025-02-05 08:55:05.633 | HD Request # 19 | Requesting Intraday data. Start date-time: 2025-02-05 08:54:50. Record interval: 0. Symbol: ESH25 2025-02-05 08:55:05.674 | HD Request # 19 | Decompressing data. 2025-02-05 08:55:05.705 | HD Request # 19 | Receiving Intraday data for ESH5.CME starting at 2025-02-05 08:54:50.852000 2025-02-05 08:55:05.705 | Socket (4) | CloseSocket call. 2025-02-05 08:55:05.705 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 08:55:05.705 | Historical data download thread signaled to stop. 2025-02-05 08:55:05.705 | HD Request # 19 | Timestamp of first Intraday data file record written: 2025-02-05 08:54:52.942000. 2025-02-05 08:55:05.705 | HD Request # 19 | Received 135 Intraday data records from 2025-02-05 08:54:50.852000 to 2025-02-05 08:55:01.767000 (10.9 seconds. Delay: 3.9 seconds) and wrote 124 records for ESH5.CME 2025-02-05 08:55:05.735 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 08:55:05.735 | Socket (4) | Closed. 2025-02-05 08:55:05.737 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:55:01.767000 2025-02-05 08:55:05.737 | Added 36 Time and Sales records to Intraday data file for ESH5.CME after download. 2025-02-05 08:55:05.737 | HD Request # 19 | Completion time: 0s. 2025-02-05 08:55:05.737 | HD Request # 19 | Intraday data download complete for ESH5.CME. Unique request ID: 18 2025-02-05 08:55:05.737 | Removing historical data download ID 18. 2025-02-05 08:55:05.737 | Real-time Intraday chart data file updates started for ESH5.CME 2025-02-05 08:55:05.737 | Intraday chart data file opened for ESH5.CME 2025-02-05 08:55:05.737 | HD Request # 19 | Enabling Intraday chart updating for symbol. 2025-02-05 08:55:05.737 | 2025-02-05 08:55:05.737 | Triggering next historical data download in queue. 2025-02-05 08:55:05.737 | HD Request # 20 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 08:55:05.738 | HD Request # 20 | Download start date-time: 2025-02-05 01:23:23.000000. File last date-time: 2025-02-05 01:23:23.000000 2025-02-05 08:55:05.738 | HD Request # 20 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 08:55:05.738 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 08:55:05.738 | Socket (4) | New receive buffer size: 0 2025-02-05 08:55:05.738 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 08:55:05.780 | HD Request # 20 | Sending historical data logon request message. 2025-02-05 08:55:05.905 | HD Request # 20 | Requesting Intraday data. Start date-time: 2025-02-05 01:23:23. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 08:55:05.950 | HD Request # 20 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 01:23:23.204000 2025-02-05 08:55:06.490 | HD Request # 20 | Timestamp of first Intraday data file record written: 2025-02-05 01:23:23.204000. 2025-02-05 08:55:06.492 | Socket (4) | CloseSocket call. 2025-02-05 08:55:06.492 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 08:55:06.492 | Historical data download thread signaled to stop. 2025-02-05 08:55:06.492 | HD Request # 20 | Received 33409 Intraday data records from 2025-02-05 01:23:23.204000 to 2025-02-05 08:55:01.790000 (7.5 hours. Delay: 4.7 seconds) and wrote 33406 records for MGCJ5.COMEX 2025-02-05 08:55:06.531 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:55:01.790000 2025-02-05 08:55:06.531 | HD Request # 20 | Completion time: 1s. 2025-02-05 08:55:06.531 | HD Request # 20 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 19 2025-02-05 08:55:06.531 | Removing historical data download ID 19. 2025-02-05 08:55:06.531 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 08:55:06.531 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 08:55:06.531 | HD Request # 20 | Enabling Intraday chart updating for symbol. 2025-02-05 08:55:06.531 | 2025-02-05 08:55:06.531 | Triggering next historical data download in queue. 2025-02-05 08:55:06.531 | HD Request # 21 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 08:55:06.532 | HD Request # 21 | Download start date-time: 2025-02-05 01:23:25.000000. File last date-time: 2025-02-05 01:23:25.000002 2025-02-05 08:55:06.532 | HD Request # 21 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 08:55:06.532 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 08:55:06.532 | Socket (5) | New receive buffer size: 0 2025-02-05 08:55:06.532 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 08:55:06.548 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 08:55:06.548 | Socket (4) | Closed. 2025-02-05 08:55:06.578 | HD Request # 21 | Sending historical data logon request message. 2025-02-05 08:55:06.712 | HD Request # 21 | Requesting Intraday data. Start date-time: 2025-02-05 01:23:25. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 08:55:06.759 | HD Request # 21 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 01:23:25.269000 2025-02-05 08:55:07.109 | Socket (5) | CloseSocket call. 2025-02-05 08:55:07.109 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 08:55:07.145 | Historical data download thread signaled to stop. 2025-02-05 08:55:07.146 | HD Request # 21 | Timestamp of first Intraday data file record written: 2025-02-05 01:23:25.269000. 2025-02-05 08:55:07.146 | HD Request # 21 | Received 15067 Intraday data records from 2025-02-05 01:23:25.269000 to 2025-02-05 08:55:07.036002 (7.5 hours. Delay: 0.1 seconds) and wrote 15064 records for MCLH5.NYMEX 2025-02-05 08:55:07.150 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 08:55:07.150 | Socket (5) | Closed. 2025-02-05 08:55:07.164 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:55:07.036002 2025-02-05 08:55:07.164 | HD Request # 21 | Completion time: 1s. 2025-02-05 08:55:07.164 | HD Request # 21 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 20 2025-02-05 08:55:07.164 | Removing historical data download ID 20. 2025-02-05 08:55:07.164 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 08:55:07.164 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 08:55:07.164 | HD Request # 21 | Enabling Intraday chart updating for symbol. 2025-02-05 08:55:07.164 | 2025-02-05 08:55:07.164 | Triggering next historical data download in queue. 2025-02-05 08:55:07.164 | HD Request # 22 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme 2025-02-05 08:55:07.164 | HD Request # 22 | Download start date-time: 2025-02-05 08:54:49.000000. File last date-time: 2025-02-05 08:54:49.523000 2025-02-05 08:55:07.164 | HD Request # 22 | Using server: ds32.sierracharts.com port 10149 2025-02-05 08:55:07.164 | Socket (4) | Creating socket. 2025-02-05 08:55:07.164 | Socket (4) | New receive buffer size: 0 2025-02-05 08:55:07.164 | Socket (4) | Connecting to IP: 67.214.125.3. 2025-02-05 08:55:07.249 | HD Request # 22 | Setting DTC encoding to Binary VLS 2025-02-05 08:55:07.249 | HD Request # 22 | Sending historical data logon request message. 2025-02-05 08:55:07.281 | HD Request # 22 | Requesting Intraday data. Start date-time: 2025-02-05 08:54:49. Record interval: 0. Symbol: MESH25 2025-02-05 08:55:07.312 | HD Request # 22 | Decompressing data. 2025-02-05 08:55:07.344 | HD Request # 22 | Receiving Intraday data for MESH5.CME starting at 2025-02-05 08:54:49.523000 2025-02-05 08:55:07.344 | Socket (4) | CloseSocket call. 2025-02-05 08:55:07.344 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 08:55:07.346 | Historical data download thread signaled to stop. 2025-02-05 08:55:07.346 | HD Request # 22 | Timestamp of first Intraday data file record written: 2025-02-05 08:54:50.852000. 2025-02-05 08:55:07.346 | HD Request # 22 | Received 74 Intraday data records from 2025-02-05 08:54:49.523000 to 2025-02-05 08:55:02.688000 (13.2 seconds. Delay: 4.7 seconds) and wrote 73 records for MESH5.CME 2025-02-05 08:55:07.373 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2025-02-05 13:55:02.688000 2025-02-05 08:55:07.373 | Added 14 Time and Sales records to Intraday data file for MESH5.CME after download. 2025-02-05 08:55:07.373 | HD Request # 22 | Completion time: 0s. 2025-02-05 08:55:07.373 | HD Request # 22 | Intraday data download complete for MESH5.CME. Unique request ID: 21 2025-02-05 08:55:07.373 | Removing historical data download ID 21. 2025-02-05 08:55:07.373 | Real-time Intraday chart data file updates started for MESH5.CME 2025-02-05 08:55:07.373 | Intraday chart data file opened for MESH5.CME 2025-02-05 08:55:07.373 | HD Request # 22 | Enabling Intraday chart updating for symbol. 2025-02-05 08:55:07.373 | 2025-02-05 08:55:07.373 | No download requests in the queue to start downloads for. 2025-02-05 08:55:07.376 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 08:55:07.376 | Socket (4) | Closed. 2025-02-05 08:55:07.501 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 08:55:07.501 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 08:55:12.544 | Opened cached Intraday file: D:\SierraChart\Data\ESH5.CME.scid. Thread ID: 22756 2025-02-05 08:55:12.545 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 08:55:12.545 | Opened cached Intraday file: D:\SierraChart\Data\MESH5.CME.scid. Thread ID: 22756 2025-02-05 08:55:16.391 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Creating socket. Using TLS 1.2. 2025-02-05 08:55:16.391 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | New receive buffer size: 0 2025-02-05 08:55:16.391 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Connecting to IP: 216.66.0.130. 2025-02-05 08:55:17.065 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | CloseSocket call. 2025-02-05 08:55:17.066 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Shutdown started. Waiting for graceful close. 2025-02-05 08:55:17.085 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Socket gracefully closed by remote side. 2025-02-05 08:55:17.085 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Closed. 2025-02-05 09:01:00.521 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 09:04:08.521 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 09:04:22.025 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 09:21:18.538 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 09:27:58.034 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 09:27:58.034 | DTC Client socket (2) | CloseSocket call. 2025-02-05 09:27:58.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 09:27:58.034 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 09:27:58.034 | DTC Client socket (2) | Closed. 2025-02-05 09:27:58.034 | DTC Client socket (0) | CloseSocket call. 2025-02-05 09:27:58.034 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 09:27:58.034 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 09:28:00.041 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 09:28:00.041 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 09:28:00.080 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 09:28:00.080 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 09:28:00.080 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 09:28:00.125 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 09:28:00.125 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 09:28:00.125 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 09:28:00.125 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 09:28:00.260 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 09:28:00.260 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 09:28:00.260 | Triggering next historical data download in queue. 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 09:28:00.260 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 09:28:00.260 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 09:28:00.260 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 09:28:00.260 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 09:28:00.260 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 09:28:00.260 | HD Request # 23 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 09:28:00.268 | HD Request # 23 | Download start date-time: 2025-02-05 09:27:56.000000. File last date-time: 2025-02-05 09:27:56.000000 2025-02-05 09:28:00.269 | HD Request # 23 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:28:00.269 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:28:00.269 | Socket (4) | New receive buffer size: 0 2025-02-05 09:28:00.269 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:28:00.303 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 09:28:00.304 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 09:28:00.304 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 09:28:00.312 | HD Request # 23 | Sending historical data logon request message. 2025-02-05 09:28:00.443 | HD Request # 23 | Requesting Intraday data. Start date-time: 2025-02-05 09:27:56. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 09:28:00.488 | HD Request # 23 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 09:27:56.208000 2025-02-05 09:28:00.491 | Socket (4) | CloseSocket call. 2025-02-05 09:28:00.491 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:28:00.493 | Historical data download thread signaled to stop. 2025-02-05 09:28:00.493 | HD Request # 23 | Timestamp of first Intraday data file record written: 2025-02-05 09:27:56.208000. 2025-02-05 09:28:00.493 | HD Request # 23 | Received 4 Intraday data records from 2025-02-05 09:27:56.208000 to 2025-02-05 09:28:00.036001 (3.8 seconds. Delay: 0.5 seconds) and wrote 4 records for MCLH5.NYMEX 2025-02-05 09:28:00.502 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:28:00.036001 2025-02-05 09:28:00.502 | HD Request # 23 | Completion time: 0s. 2025-02-05 09:28:00.502 | HD Request # 23 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 23 2025-02-05 09:28:00.502 | Removing historical data download ID 23. 2025-02-05 09:28:00.502 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 09:28:00.502 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 09:28:00.502 | HD Request # 23 | Enabling Intraday chart updating for symbol. 2025-02-05 09:28:00.502 | 2025-02-05 09:28:00.502 | Triggering next historical data download in queue. 2025-02-05 09:28:00.502 | HD Request # 24 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 09:28:00.503 | HD Request # 24 | Download start date-time: 2025-02-05 09:27:56.000000. File last date-time: 2025-02-05 09:27:56.000001 2025-02-05 09:28:00.503 | HD Request # 24 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:28:00.503 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 09:28:00.503 | Socket (5) | New receive buffer size: 0 2025-02-05 09:28:00.503 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 09:28:00.531 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:28:00.531 | Socket (4) | Closed. 2025-02-05 09:28:00.548 | HD Request # 24 | Sending historical data logon request message. 2025-02-05 09:28:00.677 | HD Request # 24 | Requesting Intraday data. Start date-time: 2025-02-05 09:27:56. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 09:28:00.721 | HD Request # 24 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 09:27:56.277000 2025-02-05 09:28:00.761 | Socket (5) | CloseSocket call. 2025-02-05 09:28:00.761 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 09:28:00.761 | Historical data download thread signaled to stop. 2025-02-05 09:28:00.761 | HD Request # 24 | Timestamp of first Intraday data file record written: 2025-02-05 09:27:56.277000. 2025-02-05 09:28:00.761 | HD Request # 24 | Received 25 Intraday data records from 2025-02-05 09:27:56.277000 to 2025-02-05 09:28:00.143004 (3.9 seconds. Delay: 0.6 seconds) and wrote 25 records for MGCJ5.COMEX 2025-02-05 09:28:00.769 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:28:00.143004 2025-02-05 09:28:00.769 | HD Request # 24 | Completion time: 0s. 2025-02-05 09:28:00.769 | HD Request # 24 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 24 2025-02-05 09:28:00.769 | Removing historical data download ID 24. 2025-02-05 09:28:00.769 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 09:28:00.769 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 09:28:00.769 | HD Request # 24 | Enabling Intraday chart updating for symbol. 2025-02-05 09:28:00.769 | 2025-02-05 09:28:00.769 | Triggering next historical data download in queue. 2025-02-05 09:28:00.769 | HD Request # 25 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 09:28:00.769 | HD Request # 25 | Download start date-time: 2025-02-05 09:27:55.000000. File last date-time: 2025-02-05 09:27:55.000000 2025-02-05 09:28:00.769 | HD Request # 25 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:28:00.769 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:28:00.770 | Socket (4) | New receive buffer size: 0 2025-02-05 09:28:00.770 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:28:00.801 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 09:28:00.801 | Socket (5) | Closed. 2025-02-05 09:28:00.813 | HD Request # 25 | Sending historical data logon request message. 2025-02-05 09:28:00.940 | HD Request # 25 | Requesting Intraday data. Start date-time: 2025-02-05 09:27:55. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 09:28:00.985 | HD Request # 25 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 09:27:55.770000 2025-02-05 09:28:01.025 | Socket (4) | CloseSocket call. 2025-02-05 09:28:01.025 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:28:01.026 | Historical data download thread signaled to stop. 2025-02-05 09:28:01.026 | HD Request # 25 | Timestamp of first Intraday data file record written: 2025-02-05 09:27:55.770000. 2025-02-05 09:28:01.026 | HD Request # 25 | Received 104 Intraday data records from 2025-02-05 09:27:55.770000 to 2025-02-05 09:28:01.253000 (5.5 seconds. Delay: -0.2 seconds) and wrote 104 records for MYMH5.CBOT 2025-02-05 09:28:01.035 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:28:01.253000 2025-02-05 09:28:01.035 | HD Request # 25 | Completion time: 1s. 2025-02-05 09:28:01.035 | HD Request # 25 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 25 2025-02-05 09:28:01.035 | Removing historical data download ID 25. 2025-02-05 09:28:01.035 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 09:28:01.035 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 09:28:01.035 | HD Request # 25 | Enabling Intraday chart updating for symbol. 2025-02-05 09:28:01.035 | 2025-02-05 09:28:01.035 | No download requests in the queue to start downloads for. 2025-02-05 09:28:01.065 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:28:01.065 | Socket (4) | Closed. 2025-02-05 09:28:01.339 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 09:28:01.339 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 09:28:01.339 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 09:28:05.255 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 09:28:05.256 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 09:28:20.362 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 09:28:24.043 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 09:29:21.740 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 09:29:21.740 | DTC Client socket (2) | CloseSocket call. 2025-02-05 09:29:21.740 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 09:29:21.740 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 09:29:21.740 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 09:29:21.740 | DTC Client socket (2) | Closed. 2025-02-05 09:29:21.740 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 09:29:21.741 | DTC Client socket (0) | CloseSocket call. 2025-02-05 09:29:21.741 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 09:29:21.741 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 09:29:23.737 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 09:29:23.737 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 09:29:23.738 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 09:29:23.738 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 09:29:23.738 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 09:29:23.788 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 09:29:23.788 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 09:29:23.788 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 09:29:23.788 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 09:29:23.914 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 09:29:23.914 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 09:29:23.914 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 09:29:23.914 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 09:29:23.914 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 09:29:23.914 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 09:29:23.914 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 09:29:23.915 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 09:29:23.915 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 09:29:23.915 | Triggering next historical data download in queue. 2025-02-05 09:29:23.915 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 09:29:23.915 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 09:29:23.915 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 09:29:23.915 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 09:29:23.915 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 09:29:23.915 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 09:29:23.915 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 09:29:23.915 | HD Request # 26 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 09:29:23.915 | HD Request # 26 | Download start date-time: 2025-02-05 09:29:17.000000. File last date-time: 2025-02-05 09:29:17.000001 2025-02-05 09:29:23.915 | HD Request # 26 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:29:23.915 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:29:23.915 | Socket (4) | New receive buffer size: 0 2025-02-05 09:29:23.916 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:29:23.955 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 09:29:23.955 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 09:29:23.955 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 09:29:23.958 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 09:29:23.958 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 09:29:23.958 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 09:29:23.961 | HD Request # 26 | Sending historical data logon request message. 2025-02-05 09:29:24.101 | HD Request # 26 | Requesting Intraday data. Start date-time: 2025-02-05 09:29:17. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 09:29:24.147 | HD Request # 26 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 09:29:17.985000 2025-02-05 09:29:24.147 | Socket (4) | CloseSocket call. 2025-02-05 09:29:24.148 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:29:24.148 | Historical data download thread signaled to stop. 2025-02-05 09:29:24.148 | HD Request # 26 | Timestamp of first Intraday data file record written: 2025-02-05 09:29:17.985000. 2025-02-05 09:29:24.148 | HD Request # 26 | Received 5 Intraday data records from 2025-02-05 09:29:17.985000 to 2025-02-05 09:29:23.613000 (5.6 seconds. Delay: 0.5 seconds) and wrote 5 records for MCLH5.NYMEX 2025-02-05 09:29:24.155 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:29:23.613000 2025-02-05 09:29:24.155 | HD Request # 26 | Completion time: 1s. 2025-02-05 09:29:24.155 | HD Request # 26 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 26 2025-02-05 09:29:24.155 | Removing historical data download ID 26. 2025-02-05 09:29:24.155 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 09:29:24.155 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 09:29:24.155 | HD Request # 26 | Enabling Intraday chart updating for symbol. 2025-02-05 09:29:24.155 | 2025-02-05 09:29:24.155 | Triggering next historical data download in queue. 2025-02-05 09:29:24.155 | HD Request # 27 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 09:29:24.155 | HD Request # 27 | Download start date-time: 2025-02-05 09:29:19.000000. File last date-time: 2025-02-05 09:29:19.000007 2025-02-05 09:29:24.155 | HD Request # 27 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:29:24.155 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 09:29:24.156 | Socket (5) | New receive buffer size: 0 2025-02-05 09:29:24.156 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 09:29:24.188 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:29:24.188 | Socket (4) | Closed. 2025-02-05 09:29:24.199 | HD Request # 27 | Sending historical data logon request message. 2025-02-05 09:29:24.323 | HD Request # 27 | Requesting Intraday data. Start date-time: 2025-02-05 09:29:19. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 09:29:24.366 | HD Request # 27 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 09:29:19.626000 2025-02-05 09:29:24.406 | Socket (5) | CloseSocket call. 2025-02-05 09:29:24.406 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 09:29:24.406 | Historical data download thread signaled to stop. 2025-02-05 09:29:24.406 | HD Request # 27 | Timestamp of first Intraday data file record written: 2025-02-05 09:29:19.626000. 2025-02-05 09:29:24.406 | HD Request # 27 | Received 23 Intraday data records from 2025-02-05 09:29:19.626000 to 2025-02-05 09:29:23.043000 (3.4 seconds. Delay: 1.4 seconds) and wrote 23 records for MGCJ5.COMEX 2025-02-05 09:29:24.415 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:29:23.043000 2025-02-05 09:29:24.415 | HD Request # 27 | Completion time: 0s. 2025-02-05 09:29:24.415 | HD Request # 27 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 27 2025-02-05 09:29:24.415 | Removing historical data download ID 27. 2025-02-05 09:29:24.415 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 09:29:24.415 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 09:29:24.415 | HD Request # 27 | Enabling Intraday chart updating for symbol. 2025-02-05 09:29:24.415 | 2025-02-05 09:29:24.415 | Triggering next historical data download in queue. 2025-02-05 09:29:24.415 | HD Request # 28 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 09:29:24.416 | HD Request # 28 | Download start date-time: 2025-02-05 09:29:19.000000. File last date-time: 2025-02-05 09:29:19.000001 2025-02-05 09:29:24.416 | HD Request # 28 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:29:24.416 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:29:24.416 | Socket (4) | New receive buffer size: 0 2025-02-05 09:29:24.416 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:29:24.446 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 09:29:24.446 | Socket (5) | Closed. 2025-02-05 09:29:24.460 | HD Request # 28 | Sending historical data logon request message. 2025-02-05 09:29:24.594 | HD Request # 28 | Requesting Intraday data. Start date-time: 2025-02-05 09:29:19. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 09:29:24.640 | HD Request # 28 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 09:29:19.800000 2025-02-05 09:29:24.679 | Socket (4) | CloseSocket call. 2025-02-05 09:29:24.679 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:29:24.679 | Historical data download thread signaled to stop. 2025-02-05 09:29:24.679 | HD Request # 28 | Timestamp of first Intraday data file record written: 2025-02-05 09:29:19.800000. 2025-02-05 09:29:24.680 | HD Request # 28 | Received 19 Intraday data records from 2025-02-05 09:29:19.800000 to 2025-02-05 09:29:23.590000 (3.8 seconds. Delay: 1.1 seconds) and wrote 19 records for MYMH5.CBOT 2025-02-05 09:29:24.688 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:29:23.590000 2025-02-05 09:29:24.688 | HD Request # 28 | Completion time: 0s. 2025-02-05 09:29:24.688 | HD Request # 28 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 28 2025-02-05 09:29:24.688 | Removing historical data download ID 28. 2025-02-05 09:29:24.688 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 09:29:24.688 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 09:29:24.688 | HD Request # 28 | Enabling Intraday chart updating for symbol. 2025-02-05 09:29:24.688 | 2025-02-05 09:29:24.688 | No download requests in the queue to start downloads for. 2025-02-05 09:29:24.720 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:29:24.720 | Socket (4) | Closed. 2025-02-05 09:29:30.986 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 09:29:30.987 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 09:29:30.987 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 09:31:44.005 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 09:31:44.005 | DTC Client socket (2) | CloseSocket call. 2025-02-05 09:31:44.005 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 09:31:44.005 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 09:31:44.005 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 09:31:44.005 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 09:31:44.005 | DTC Client socket (2) | Closed. 2025-02-05 09:31:44.005 | DTC Client socket (0) | CloseSocket call. 2025-02-05 09:31:44.005 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 09:31:44.005 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 09:31:46.009 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 09:31:46.009 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 09:31:46.009 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 09:31:46.010 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 09:31:46.010 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 09:31:46.053 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 09:31:46.053 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 09:31:46.053 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 09:31:46.053 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 09:31:46.178 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 09:31:46.178 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 09:31:46.178 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 09:31:46.178 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 09:31:46.178 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 09:31:46.178 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 09:31:46.178 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 09:31:46.178 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 09:31:46.179 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 09:31:46.179 | Triggering next historical data download in queue. 2025-02-05 09:31:46.179 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 09:31:46.179 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 09:31:46.179 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 09:31:46.179 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 09:31:46.179 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 09:31:46.179 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 09:31:46.179 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 09:31:46.179 | HD Request # 29 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 09:31:46.179 | HD Request # 29 | Download start date-time: 2025-02-05 09:31:39.000000. File last date-time: 2025-02-05 09:31:39.000002 2025-02-05 09:31:46.179 | HD Request # 29 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:31:46.179 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:31:46.180 | Socket (4) | New receive buffer size: 0 2025-02-05 09:31:46.180 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:31:46.220 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 09:31:46.220 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 09:31:46.220 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 09:31:46.221 | HD Request # 29 | Sending historical data logon request message. 2025-02-05 09:31:46.235 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 09:31:46.235 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 09:31:46.236 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 09:31:46.347 | HD Request # 29 | Requesting Intraday data. Start date-time: 2025-02-05 09:31:39. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 09:31:46.392 | HD Request # 29 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 09:31:39.456000 2025-02-05 09:31:46.394 | Socket (4) | CloseSocket call. 2025-02-05 09:31:46.394 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:31:46.394 | Historical data download thread signaled to stop. 2025-02-05 09:31:46.394 | HD Request # 29 | Timestamp of first Intraday data file record written: 2025-02-05 09:31:39.456000. 2025-02-05 09:31:46.394 | HD Request # 29 | Received 9 Intraday data records from 2025-02-05 09:31:39.456000 to 2025-02-05 09:31:46.690001 (7.2 seconds. Delay: -0.3 seconds) and wrote 9 records for MCLH5.NYMEX 2025-02-05 09:31:46.401 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:31:46.690001 2025-02-05 09:31:46.402 | HD Request # 29 | Completion time: 0s. 2025-02-05 09:31:46.402 | HD Request # 29 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 29 2025-02-05 09:31:46.402 | Removing historical data download ID 29. 2025-02-05 09:31:46.402 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 09:31:46.402 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 09:31:46.402 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2025-02-05 09:31:46.402 | 2025-02-05 09:31:46.402 | Triggering next historical data download in queue. 2025-02-05 09:31:46.402 | HD Request # 30 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 09:31:46.402 | HD Request # 30 | Download start date-time: 2025-02-05 09:31:41.000000. File last date-time: 2025-02-05 09:31:41.000002 2025-02-05 09:31:46.402 | HD Request # 30 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:31:46.402 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 09:31:46.402 | Socket (5) | New receive buffer size: 0 2025-02-05 09:31:46.402 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 09:31:46.447 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:31:46.447 | Socket (4) | Closed. 2025-02-05 09:31:46.449 | HD Request # 30 | Sending historical data logon request message. 2025-02-05 09:31:46.581 | HD Request # 30 | Requesting Intraday data. Start date-time: 2025-02-05 09:31:41. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 09:31:46.626 | HD Request # 30 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 09:31:41.015000 2025-02-05 09:31:46.666 | Socket (5) | CloseSocket call. 2025-02-05 09:31:46.666 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 09:31:46.666 | Historical data download thread signaled to stop. 2025-02-05 09:31:46.666 | HD Request # 30 | Timestamp of first Intraday data file record written: 2025-02-05 09:31:41.015000. 2025-02-05 09:31:46.666 | HD Request # 30 | Received 39 Intraday data records from 2025-02-05 09:31:41.015000 to 2025-02-05 09:31:46.498000 (5.5 seconds. Delay: 0.2 seconds) and wrote 39 records for MGCJ5.COMEX 2025-02-05 09:31:46.676 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:31:46.498000 2025-02-05 09:31:46.676 | HD Request # 30 | Completion time: 0s. 2025-02-05 09:31:46.676 | HD Request # 30 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 30 2025-02-05 09:31:46.676 | Removing historical data download ID 30. 2025-02-05 09:31:46.676 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 09:31:46.676 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 09:31:46.676 | HD Request # 30 | Enabling Intraday chart updating for symbol. 2025-02-05 09:31:46.676 | 2025-02-05 09:31:46.676 | Triggering next historical data download in queue. 2025-02-05 09:31:46.676 | HD Request # 31 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 09:31:46.676 | HD Request # 31 | Download start date-time: 2025-02-05 09:31:42.000000. File last date-time: 2025-02-05 09:31:42.000003 2025-02-05 09:31:46.676 | HD Request # 31 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:31:46.676 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:31:46.677 | Socket (4) | New receive buffer size: 0 2025-02-05 09:31:46.677 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:31:46.708 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 09:31:46.708 | Socket (5) | Closed. 2025-02-05 09:31:46.719 | HD Request # 31 | Sending historical data logon request message. 2025-02-05 09:31:46.858 | HD Request # 31 | Requesting Intraday data. Start date-time: 2025-02-05 09:31:42. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 09:31:46.903 | HD Request # 31 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 09:31:42.023000 2025-02-05 09:31:46.949 | Socket (4) | CloseSocket call. 2025-02-05 09:31:46.949 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:31:46.955 | Historical data download thread signaled to stop. 2025-02-05 09:31:46.955 | HD Request # 31 | Timestamp of first Intraday data file record written: 2025-02-05 09:31:42.023000. 2025-02-05 09:31:46.956 | HD Request # 31 | Received 40 Intraday data records from 2025-02-05 09:31:42.023000 to 2025-02-05 09:31:47.177000 (5.2 seconds. Delay: -0.2 seconds) and wrote 40 records for MYMH5.CBOT 2025-02-05 09:31:46.964 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:31:47.177000 2025-02-05 09:31:46.964 | HD Request # 31 | Completion time: 0s. 2025-02-05 09:31:46.964 | HD Request # 31 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 31 2025-02-05 09:31:46.964 | Removing historical data download ID 31. 2025-02-05 09:31:46.964 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 09:31:46.964 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 09:31:46.964 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2025-02-05 09:31:46.964 | 2025-02-05 09:31:46.964 | No download requests in the queue to start downloads for. 2025-02-05 09:31:46.998 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:31:46.998 | Socket (4) | Closed. 2025-02-05 09:31:47.080 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 09:31:52.112 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 09:31:52.112 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 09:32:02.042 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 09:32:18.540 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 | Number times message added: 1 2025-02-05 09:32:34.535 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 09:32:34.535 | DTC Client socket (2) | CloseSocket call. 2025-02-05 09:32:34.535 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 09:32:34.535 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 09:32:34.535 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 09:32:34.535 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 09:32:34.535 | DTC Client socket (2) | Closed. 2025-02-05 09:32:34.535 | DTC Client socket (0) | CloseSocket call. 2025-02-05 09:32:34.535 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 09:32:34.535 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 09:32:36.538 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 09:32:36.538 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 09:32:36.538 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 09:32:36.538 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 09:32:36.538 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 09:32:36.582 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 09:32:36.582 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 09:32:36.582 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 09:32:36.582 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 09:32:36.714 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 09:32:36.714 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 09:32:36.714 | Triggering next historical data download in queue. 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 09:32:36.714 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 09:32:36.714 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 09:32:36.714 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 09:32:36.714 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 09:32:36.714 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 09:32:36.714 | HD Request # 32 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 09:32:36.714 | HD Request # 32 | Download start date-time: 2025-02-05 09:32:29.000000. File last date-time: 2025-02-05 09:32:29.000000 2025-02-05 09:32:36.715 | HD Request # 32 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:32:36.715 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:32:36.715 | Socket (4) | New receive buffer size: 0 2025-02-05 09:32:36.715 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:32:36.758 | HD Request # 32 | Sending historical data logon request message. 2025-02-05 09:32:36.768 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 09:32:36.768 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 09:32:36.768 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 09:32:36.768 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 09:32:36.773 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 09:32:36.773 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 09:32:36.892 | HD Request # 32 | Requesting Intraday data. Start date-time: 2025-02-05 09:32:29. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 09:32:36.935 | HD Request # 32 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 09:32:29.398000 2025-02-05 09:32:36.936 | Socket (4) | CloseSocket call. 2025-02-05 09:32:36.936 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:32:36.936 | Historical data download thread signaled to stop. 2025-02-05 09:32:36.936 | HD Request # 32 | Timestamp of first Intraday data file record written: 2025-02-05 09:32:29.398000. 2025-02-05 09:32:36.936 | HD Request # 32 | Received 2 Intraday data records from 2025-02-05 09:32:29.398000 to 2025-02-05 09:32:33.123000 (3.7 seconds. Delay: 3.8 seconds) and wrote 2 records for MCLH5.NYMEX 2025-02-05 09:32:36.945 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:32:33.123000 2025-02-05 09:32:36.945 | HD Request # 32 | Completion time: 0s. 2025-02-05 09:32:36.945 | HD Request # 32 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 32 2025-02-05 09:32:36.945 | Removing historical data download ID 32. 2025-02-05 09:32:36.945 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 09:32:36.945 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 09:32:36.945 | HD Request # 32 | Enabling Intraday chart updating for symbol. 2025-02-05 09:32:36.945 | 2025-02-05 09:32:36.945 | Triggering next historical data download in queue. 2025-02-05 09:32:36.945 | HD Request # 33 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 09:32:36.946 | HD Request # 33 | Download start date-time: 2025-02-05 09:32:31.000000. File last date-time: 2025-02-05 09:32:31.000001 2025-02-05 09:32:36.946 | HD Request # 33 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:32:36.946 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 09:32:36.946 | Socket (5) | New receive buffer size: 0 2025-02-05 09:32:36.946 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 09:32:36.975 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:32:36.975 | Socket (4) | Closed. 2025-02-05 09:32:36.989 | HD Request # 33 | Sending historical data logon request message. 2025-02-05 09:32:37.122 | HD Request # 33 | Requesting Intraday data. Start date-time: 2025-02-05 09:32:31. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 09:32:37.167 | HD Request # 33 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 09:32:31.070000 2025-02-05 09:32:37.213 | Socket (5) | CloseSocket call. 2025-02-05 09:32:37.213 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 09:32:37.213 | Historical data download thread signaled to stop. 2025-02-05 09:32:37.213 | HD Request # 33 | Timestamp of first Intraday data file record written: 2025-02-05 09:32:31.070000. 2025-02-05 09:32:37.213 | HD Request # 33 | Received 11 Intraday data records from 2025-02-05 09:32:31.070000 to 2025-02-05 09:32:36.447000 (5.4 seconds. Delay: 0.8 seconds) and wrote 11 records for MGCJ5.COMEX 2025-02-05 09:32:37.222 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:32:36.447000 2025-02-05 09:32:37.222 | HD Request # 33 | Completion time: 1s. 2025-02-05 09:32:37.222 | HD Request # 33 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 33 2025-02-05 09:32:37.222 | Removing historical data download ID 33. 2025-02-05 09:32:37.222 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 09:32:37.222 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 09:32:37.222 | HD Request # 33 | Enabling Intraday chart updating for symbol. 2025-02-05 09:32:37.222 | 2025-02-05 09:32:37.222 | Triggering next historical data download in queue. 2025-02-05 09:32:37.222 | HD Request # 34 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 09:32:37.222 | HD Request # 34 | Download start date-time: 2025-02-05 09:32:32.000000. File last date-time: 2025-02-05 09:32:32.000002 2025-02-05 09:32:37.222 | HD Request # 34 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:32:37.222 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:32:37.222 | Socket (4) | New receive buffer size: 0 2025-02-05 09:32:37.222 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:32:37.254 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 09:32:37.254 | Socket (5) | Closed. 2025-02-05 09:32:37.265 | HD Request # 34 | Sending historical data logon request message. 2025-02-05 09:32:37.389 | HD Request # 34 | Requesting Intraday data. Start date-time: 2025-02-05 09:32:32. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 09:32:37.445 | HD Request # 34 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 09:32:32.001000 2025-02-05 09:32:37.485 | Socket (4) | CloseSocket call. 2025-02-05 09:32:37.485 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 09:32:37.485 | Historical data download thread signaled to stop. 2025-02-05 09:32:37.485 | HD Request # 34 | Timestamp of first Intraday data file record written: 2025-02-05 09:32:32.001000. 2025-02-05 09:32:37.485 | HD Request # 34 | Received 79 Intraday data records from 2025-02-05 09:32:32.001000 to 2025-02-05 09:32:37.666001 (5.7 seconds. Delay: -0.2 seconds) and wrote 79 records for MYMH5.CBOT 2025-02-05 09:32:37.493 | HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:32:37.666001 2025-02-05 09:32:37.493 | HD Request # 34 | Completion time: 0s. 2025-02-05 09:32:37.493 | HD Request # 34 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 34 2025-02-05 09:32:37.493 | Removing historical data download ID 34. 2025-02-05 09:32:37.493 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 09:32:37.493 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 09:32:37.493 | HD Request # 34 | Enabling Intraday chart updating for symbol. 2025-02-05 09:32:37.493 | 2025-02-05 09:32:37.493 | No download requests in the queue to start downloads for. 2025-02-05 09:32:37.525 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 09:32:37.525 | Socket (4) | Closed. 2025-02-05 09:32:42.478 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 09:32:42.478 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 09:32:42.478 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 09:35:04.059 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 09:52:00.999 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 09:52:00.999 | DTC Client socket (2) | CloseSocket call. 2025-02-05 09:52:00.999 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 09:52:00.999 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 09:52:00.999 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 09:52:00.999 | DTC Client socket (2) | Closed. 2025-02-05 09:52:00.999 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 09:52:00.999 | DTC Client socket (0) | CloseSocket call. 2025-02-05 09:52:00.999 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 09:52:01.000 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 09:52:03.001 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 09:52:03.002 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 09:52:03.042 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 09:52:03.042 | DTC Client socket (4) | New receive buffer size: 0 2025-02-05 09:52:03.042 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 09:52:03.087 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 09:52:03.087 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 09:52:03.087 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 09:52:03.087 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 09:52:03.216 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 09:52:03.216 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 09:52:03.216 | Triggering next historical data download in queue. 2025-02-05 09:52:03.216 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 09:52:03.217 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 09:52:03.217 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 09:52:03.217 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 09:52:03.217 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 09:52:03.217 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 09:52:03.217 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 09:52:03.217 | HD Request # 35 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 09:52:03.217 | HD Request # 35 | Download start date-time: 2025-02-05 09:51:56.000000. File last date-time: 2025-02-05 09:51:56.000002 2025-02-05 09:52:03.217 | HD Request # 35 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:52:03.217 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 09:52:03.217 | Socket (5) | New receive buffer size: 0 2025-02-05 09:52:03.217 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 09:52:03.258 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 09:52:03.258 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 09:52:03.258 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 09:52:03.260 | HD Request # 35 | Sending historical data logon request message. 2025-02-05 09:52:03.397 | HD Request # 35 | Requesting Intraday data. Start date-time: 2025-02-05 09:51:56. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 09:52:03.445 | HD Request # 35 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 09:51:56.237000 2025-02-05 09:52:03.459 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 09:52:03.459 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 09:52:03.460 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 09:52:03.484 | Socket (5) | CloseSocket call. 2025-02-05 09:52:03.484 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 09:52:03.485 | Historical data download thread signaled to stop. 2025-02-05 09:52:03.485 | HD Request # 35 | Timestamp of first Intraday data file record written: 2025-02-05 09:51:56.237000. 2025-02-05 09:52:03.485 | HD Request # 35 | Received 13 Intraday data records from 2025-02-05 09:51:56.237000 to 2025-02-05 09:52:02.917003 (6.7 seconds. Delay: 0.6 seconds) and wrote 13 records for MCLH5.NYMEX 2025-02-05 09:52:03.493 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:52:02.917003 2025-02-05 09:52:03.493 | HD Request # 35 | Completion time: 0s. 2025-02-05 09:52:03.493 | HD Request # 35 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 35 2025-02-05 09:52:03.493 | Removing historical data download ID 35. 2025-02-05 09:52:03.493 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 09:52:03.493 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 09:52:03.493 | HD Request # 35 | Enabling Intraday chart updating for symbol. 2025-02-05 09:52:03.493 | 2025-02-05 09:52:03.493 | Triggering next historical data download in queue. 2025-02-05 09:52:03.493 | HD Request # 36 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 09:52:03.494 | HD Request # 36 | Download start date-time: 2025-02-05 09:51:57.000000. File last date-time: 2025-02-05 09:51:57.000000 2025-02-05 09:52:03.494 | HD Request # 36 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:52:03.494 | Socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 09:52:03.494 | Socket (2) | New receive buffer size: 0 2025-02-05 09:52:03.494 | Socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 09:52:03.525 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 09:52:03.525 | Socket (5) | Closed. 2025-02-05 09:52:03.537 | HD Request # 36 | Sending historical data logon request message. 2025-02-05 09:52:03.665 | HD Request # 36 | Requesting Intraday data. Start date-time: 2025-02-05 09:51:57. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 09:52:03.710 | HD Request # 36 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 09:51:57.806000 2025-02-05 09:52:03.750 | Socket (2) | CloseSocket call. 2025-02-05 09:52:03.750 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-05 09:52:03.750 | Historical data download thread signaled to stop. 2025-02-05 09:52:03.750 | HD Request # 36 | Timestamp of first Intraday data file record written: 2025-02-05 09:51:57.806000. 2025-02-05 09:52:03.750 | HD Request # 36 | Received 28 Intraday data records from 2025-02-05 09:51:57.806000 to 2025-02-05 09:52:03.517001 (5.7 seconds. Delay: 0.2 seconds) and wrote 28 records for MGCJ5.COMEX 2025-02-05 09:52:03.758 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:52:03.517001 2025-02-05 09:52:03.758 | Added 2 Time and Sales records to Intraday data file for MGCJ5.COMEX after download. 2025-02-05 09:52:03.758 | HD Request # 36 | Completion time: 0s. 2025-02-05 09:52:03.758 | HD Request # 36 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 36 2025-02-05 09:52:03.758 | Removing historical data download ID 36. 2025-02-05 09:52:03.758 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 09:52:03.758 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 09:52:03.758 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2025-02-05 09:52:03.758 | 2025-02-05 09:52:03.758 | Triggering next historical data download in queue. 2025-02-05 09:52:03.759 | HD Request # 37 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 09:52:03.759 | HD Request # 37 | Download start date-time: 2025-02-05 09:51:59.000000. File last date-time: 2025-02-05 09:51:59.000000 2025-02-05 09:52:03.759 | HD Request # 37 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 09:52:03.759 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 09:52:03.759 | Socket (5) | New receive buffer size: 0 2025-02-05 09:52:03.759 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 09:52:03.791 | Socket (2) | Socket gracefully closed by remote side. 2025-02-05 09:52:03.791 | Socket (2) | Closed. 2025-02-05 09:52:03.804 | HD Request # 37 | Sending historical data logon request message. 2025-02-05 09:52:04.183 | HD Request # 37 | Requesting Intraday data. Start date-time: 2025-02-05 09:51:59. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 09:52:06.111 | HD Request # 37 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 09:51:59.066000 2025-02-05 09:52:06.151 | Socket (5) | CloseSocket call. 2025-02-05 09:52:06.151 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 09:52:06.151 | Historical data download thread signaled to stop. 2025-02-05 09:52:06.151 | HD Request # 37 | Timestamp of first Intraday data file record written: 2025-02-05 09:51:59.066000. 2025-02-05 09:52:06.151 | HD Request # 37 | Received 85 Intraday data records from 2025-02-05 09:51:59.066000 to 2025-02-05 09:52:06.312000 (7.2 seconds. Delay: -0.2 seconds) and wrote 85 records for MYMH5.CBOT 2025-02-05 09:52:06.159 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2025-02-05 14:52:06.312000 2025-02-05 09:52:06.159 | HD Request # 37 | Completion time: 3s. 2025-02-05 09:52:06.159 | HD Request # 37 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 37 2025-02-05 09:52:06.159 | Removing historical data download ID 37. 2025-02-05 09:52:06.160 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 09:52:06.160 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 09:52:06.160 | HD Request # 37 | Enabling Intraday chart updating for symbol. 2025-02-05 09:52:06.160 | 2025-02-05 09:52:06.160 | No download requests in the queue to start downloads for. 2025-02-05 09:52:06.192 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 09:52:06.192 | Socket (5) | Closed. 2025-02-05 09:52:06.566 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 09:52:06.566 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 09:52:11.621 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 11:31:22.635 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-02-05 11:31:22.635 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-02-05 11:31:22.636 | DTC Client socket (3) | CloseSocket call. 2025-02-05 11:31:22.636 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 11:31:22.636 | Denali Data Feed | Waiting for socket receive thread to end 2025-02-05 11:31:22.636 | DTC Client socket (3) | Closed. 2025-02-05 11:31:22.636 | DTC Client socket (0) | CloseSocket call. 2025-02-05 11:31:22.636 | Denali Data Feed | Disconnected from the server. 2025-02-05 11:31:22.636 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2025-02-05 11:31:25.636 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2025-02-05 11:31:25.653 | DTC Client socket (2) | Creating socket. 2025-02-05 11:31:25.653 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 11:31:25.653 | DTC Client socket (2) | Connecting to IP: 67.214.125.5. 2025-02-05 11:31:25.691 | Denali Data Feed | Network connection to server complete. 2025-02-05 11:31:25.691 | Denali Data Feed | Starting socket receive thread. 2025-02-05 11:31:25.691 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-05 11:31:25.737 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-02-05 11:31:25.737 | Denali Data Feed | Sending logon request message. 2025-02-05 11:31:26.235 | Denali Data Feed | Received logon response. 2025-02-05 11:31:26.235 | Denali Data Feed | Server Name: SC Realtime Server. 2025-02-05 11:31:26.235 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-02-05 11:31:26.235 | Denali Data Feed | Successfully connected. 2025-02-05 11:31:26.235 | Denali Data Feed | Trading is not supported. 2025-02-05 11:31:26.235 | Denali Data Feed | MarketDepthIsSupported: 1 2025-02-05 11:31:26.236 | Added historical Intraday data request for ESH5.CME to the queue. 2025-02-05 11:31:26.236 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'. 2025-02-05 11:31:26.236 | Triggering next historical data download in queue. 2025-02-05 11:31:26.236 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25. Market Depth data restarted. 2025-02-05 11:31:26.236 | Added historical Intraday data request for MESH5.CME to the queue. 2025-02-05 11:31:26.236 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'. 2025-02-05 11:31:26.236 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25. Market Depth data restarted. 2025-02-05 11:31:26.236 | HD Request # 38 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme 2025-02-05 11:31:26.237 | HD Request # 38 | Download start date-time: 2025-02-05 11:31:03.000000. File last date-time: 2025-02-05 11:31:03.367000 2025-02-05 11:31:26.237 | HD Request # 38 | Using server: ds26.sierracharts.com port 10149 2025-02-05 11:31:26.294 | Socket (3) | Creating socket. 2025-02-05 11:31:26.294 | Socket (3) | New receive buffer size: 0 2025-02-05 11:31:26.294 | Socket (3) | Connecting to IP: 64.152.155.17. 2025-02-05 11:31:26.359 | Denali Data Feed | Clearing market depth for ESH5.CME 2025-02-05 11:31:26.359 | Denali Data Feed | Clearing market depth for MESH5.CME 2025-02-05 11:31:26.360 | Denali Data Feed | Received security definition for symbol ESH5.CME 2025-02-05 11:31:26.360 | Denali Data Feed | Received security definition for symbol MESH5.CME 2025-02-05 11:31:26.367 | HD Request # 38 | Setting DTC encoding to Binary VLS 2025-02-05 11:31:26.367 | HD Request # 38 | Sending historical data logon request message. 2025-02-05 11:31:26.447 | HD Request # 38 | Requesting Intraday data. Start date-time: 2025-02-05 11:31:03. Record interval: 0. Symbol: ESH25 2025-02-05 11:31:26.475 | HD Request # 38 | Decompressing data. 2025-02-05 11:31:26.504 | HD Request # 38 | Receiving Intraday data for ESH5.CME starting at 2025-02-05 11:31:03.146000 2025-02-05 11:31:26.505 | Socket (3) | CloseSocket call. 2025-02-05 11:31:26.505 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-02-05 11:31:26.507 | Historical data download thread signaled to stop. 2025-02-05 11:31:26.507 | HD Request # 38 | Timestamp of first Intraday data file record written: 2025-02-05 11:31:04.207000. 2025-02-05 11:31:26.507 | HD Request # 38 | Received 801 Intraday data records from 2025-02-05 11:31:03.146000 to 2025-02-05 11:31:23.295000 (20.1 seconds. Delay: 3.2 seconds) and wrote 753 records for ESH5.CME 2025-02-05 11:31:26.516 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2025-02-05 16:31:23.295000 2025-02-05 11:31:26.516 | Added 25 Time and Sales records to Intraday data file for ESH5.CME after download. 2025-02-05 11:31:26.516 | HD Request # 38 | Completion time: 0s. 2025-02-05 11:31:26.516 | HD Request # 38 | Intraday data download complete for ESH5.CME. Unique request ID: 38 2025-02-05 11:31:26.516 | Removing historical data download ID 38. 2025-02-05 11:31:26.516 | Real-time Intraday chart data file updates started for ESH5.CME 2025-02-05 11:31:26.516 | Intraday chart data file opened for ESH5.CME 2025-02-05 11:31:26.516 | HD Request # 38 | Enabling Intraday chart updating for symbol. 2025-02-05 11:31:26.516 | 2025-02-05 11:31:26.516 | Triggering next historical data download in queue. 2025-02-05 11:31:26.516 | HD Request # 39 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme 2025-02-05 11:31:26.517 | HD Request # 39 | Download start date-time: 2025-02-05 11:31:03.000000. File last date-time: 2025-02-05 11:31:03.307001 2025-02-05 11:31:26.517 | HD Request # 39 | Using server: ds28.sierracharts.com port 10150 2025-02-05 11:31:26.517 | Socket (5) | Creating socket. 2025-02-05 11:31:26.517 | Socket (5) | New receive buffer size: 0 2025-02-05 11:31:26.517 | Socket (5) | Connecting to IP: 67.214.125.5. 2025-02-05 11:31:26.534 | Socket (3) | Socket gracefully closed by remote side. 2025-02-05 11:31:26.534 | Socket (3) | Closed. 2025-02-05 11:31:26.598 | HD Request # 39 | Setting DTC encoding to Binary VLS 2025-02-05 11:31:26.598 | HD Request # 39 | Sending historical data logon request message. 2025-02-05 11:31:26.681 | HD Request # 39 | Requesting Intraday data. Start date-time: 2025-02-05 11:31:03. Record interval: 0. Symbol: MESH25 2025-02-05 11:31:26.718 | HD Request # 39 | Decompressing data. 2025-02-05 11:31:26.755 | HD Request # 39 | Receiving Intraday data for MESH5.CME starting at 2025-02-05 11:31:03.147000 2025-02-05 11:31:26.756 | Socket (5) | CloseSocket call. 2025-02-05 11:31:26.756 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 11:31:26.756 | Historical data download thread signaled to stop. 2025-02-05 11:31:26.757 | HD Request # 39 | Timestamp of first Intraday data file record written: 2025-02-05 11:31:03.632000. 2025-02-05 11:31:26.757 | HD Request # 39 | Received 654 Intraday data records from 2025-02-05 11:31:03.147000 to 2025-02-05 11:31:26.013002 (22.9 seconds. Delay: 0.7 seconds) and wrote 633 records for MESH5.CME 2025-02-05 11:31:26.765 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2025-02-05 16:31:26.013002 2025-02-05 11:31:26.765 | Added 21 Time and Sales records to Intraday data file for MESH5.CME after download. 2025-02-05 11:31:26.765 | HD Request # 39 | Completion time: 0s. 2025-02-05 11:31:26.765 | HD Request # 39 | Intraday data download complete for MESH5.CME. Unique request ID: 39 2025-02-05 11:31:26.765 | Removing historical data download ID 39. 2025-02-05 11:31:26.765 | Real-time Intraday chart data file updates started for MESH5.CME 2025-02-05 11:31:26.765 | Intraday chart data file opened for MESH5.CME 2025-02-05 11:31:26.765 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2025-02-05 11:31:26.765 | 2025-02-05 11:31:26.765 | No download requests in the queue to start downloads for. 2025-02-05 11:31:26.793 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 11:31:26.793 | Socket (5) | Closed. 2025-02-05 11:31:28.610 | Opened cached Intraday file: D:\SierraChart\Data\ESH5.CME.scid. Thread ID: 22756 2025-02-05 11:31:28.610 | Opened cached Intraday file: D:\SierraChart\Data\MESH5.CME.scid. Thread ID: 22756 2025-02-05 11:49:45.771 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-02-05 11:49:45.771 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-02-05 11:49:45.771 | DTC Client socket (1) | CloseSocket call. 2025-02-05 11:49:45.771 | DTC Client socket (1) | Max send buffers used during socket life: 3 2025-02-05 11:49:45.771 | DTC Client socket (1) | Max send buffer size during socket life: 954 2025-02-05 11:49:45.772 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 11:49:45.772 | DTC Client socket (1) | Closed. 2025-02-05 11:49:45.772 | Connection to the external service has been lost. 2025-02-05 11:49:45.786 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 11:49:45.786 | DTC Client socket (4) | CloseSocket call. 2025-02-05 11:49:45.786 | DTC Client socket (4) | Max send buffers used during socket life: 3 2025-02-05 11:49:45.786 | DTC Client socket (4) | Max send buffer size during socket life: 927 2025-02-05 11:49:45.786 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 11:49:45.786 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 11:49:45.787 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2025-02-05 11:49:45.788 | DTC Client socket (0) | CloseSocket call. 2025-02-05 11:49:45.788 | Rithmic Direct - DTC | Disconnected. 2025-02-05 11:49:45.788 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-02-05 11:49:45.826 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-02-05 11:49:45.826 | DTC Client socket (4) | Closed. 2025-02-05 11:49:49.784 | 2025-02-05 11:49:49.784 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 11:49:49.784 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508 2025-02-05 11:49:49.825 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-02-05 11:49:49.825 | DTC Client socket (1) | New receive buffer size: 0 2025-02-05 11:49:49.825 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2025-02-05 11:49:49.869 | Rithmic Direct - DTC | Network connection to server complete. 2025-02-05 11:49:49.869 | Rithmic Direct - DTC | Starting socket receive thread. 2025-02-05 11:49:49.869 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2025-02-05 11:49:49.869 | Rithmic Direct - DTC | Sending logon request message. 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Received logon response. 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Server Name: . 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Successfully connected. 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Trading is supported. 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Order cancel and replace is supported. 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | OCO Orders supported. 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2025-02-05 11:49:49.999 | Rithmic Direct - DTC | Connected to server complete. 2025-02-05 11:49:49.999 | Denali Data Feed | Waiting for socket receive thread to end 2025-02-05 11:49:50.000 | DTC Client socket (2) | CloseSocket call. 2025-02-05 11:49:50.000 | Denali Data Feed | Disconnected from the server. 2025-02-05 11:49:50.000 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-02-05 11:49:50.001 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-02-05 11:49:50.009 | Mapping ESH5.CME to ESH25. Service code: cme 2025-02-05 11:49:50.009 | Using symbol data fast lookup vector 2025-02-05 11:49:50.009 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 1 Service code: cme 2025-02-05 11:49:50.009 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443 2025-02-05 11:49:50.009 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 1 2025-02-05 11:49:50.009 | Added historical Intraday data request for ESH5.CME to the queue. 2025-02-05 11:49:50.009 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'. 2025-02-05 11:49:50.009 | Triggering next historical data download in queue. 2025-02-05 11:49:50.010 | Delaying start of download for ESH5.CME. 2025-02-05 11:49:50.108 | DTC Client socket (3) | Creating socket. 2025-02-05 11:49:50.108 | DTC Client socket (3) | New receive buffer size: 0 2025-02-05 11:49:50.108 | DTC Client socket (3) | Connecting to IP: 64.152.155.21. 2025-02-05 11:49:50.111 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 11:49:50.111 | DTC Client socket (2) | Closed. 2025-02-05 11:49:50.131 | Rithmic Direct - DTC | Starting real-time market data updates for: MCLH5.NYMEX. ID: 2 Service code: rithmic.trading 2025-02-05 11:49:50.133 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 11:49:50.133 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 11:49:50.133 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 11:49:50.133 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 11:49:50.134 | Rithmic Direct - DTC | Requesting security definition data for: MCLH5.NYMEX. ID: 2 2025-02-05 11:49:50.134 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 11:49:50.134 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 11:49:50.134 | Triggering next historical data download in queue. 2025-02-05 11:49:50.136 | Mapping MESH5.CME to MESH25. Service code: cme 2025-02-05 11:49:50.136 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 3 Service code: cme 2025-02-05 11:49:50.136 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 3 2025-02-05 11:49:50.136 | Added historical Intraday data request for MESH5.CME to the queue. 2025-02-05 11:49:50.136 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'. 2025-02-05 11:49:50.136 | Triggering next historical data download in queue. 2025-02-05 11:49:50.137 | Rithmic Direct - DTC | Starting real-time market data updates for: MGCJ5.COMEX. ID: 4 Service code: rithmic.trading 2025-02-05 11:49:50.137 | Rithmic Direct - DTC | Requesting security definition data for: MGCJ5.COMEX. ID: 4 2025-02-05 11:49:50.137 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 11:49:50.137 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 11:49:50.137 | Triggering next historical data download in queue. 2025-02-05 11:49:50.147 | Denali Data Feed | Network connection to server complete. 2025-02-05 11:49:50.147 | Denali Data Feed | Starting socket receive thread. 2025-02-05 11:49:50.147 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-05 11:49:50.176 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 11:49:50.176 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 11:49:50.176 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 11:49:50.176 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 11:49:50.190 | Rithmic Direct - DTC | Starting real-time market data updates for: MYMH5.CBOT. ID: 5 Service code: rithmic.trading 2025-02-05 11:49:50.190 | Rithmic Direct - DTC | Requesting security definition data for: MYMH5.CBOT. ID: 5 2025-02-05 11:49:50.190 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 11:49:50.190 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 11:49:50.190 | Triggering next historical data download in queue. 2025-02-05 11:49:50.195 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-02-05 11:49:50.195 | Denali Data Feed | Sending logon request message. 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX 2025-02-05 11:49:50.302 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-05 11:49:50.345 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 11:49:50.345 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 11:49:50.346 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 11:49:50.695 | Denali Data Feed | Received logon response. 2025-02-05 11:49:50.695 | Denali Data Feed | Server Name: SC Realtime Server. 2025-02-05 11:49:50.695 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-02-05 11:49:50.695 | Denali Data Feed | Successfully connected. 2025-02-05 11:49:50.695 | Denali Data Feed | Trading is not supported. 2025-02-05 11:49:50.695 | Denali Data Feed | MarketDepthIsSupported: 1 2025-02-05 11:49:50.695 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25 2025-02-05 11:49:50.695 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25 2025-02-05 11:49:50.820 | Denali Data Feed | Received security definition for symbol ESH5.CME 2025-02-05 11:49:50.820 | Denali Data Feed | Received security definition for symbol MESH5.CME 2025-02-05 11:49:54.994 | Requesting market depth updates for: ESH5.CME if supported. NumLevels=100 2025-02-05 11:49:54.994 | Requesting market depth updates for: MCLH5.NYMEX if supported. NumLevels=100 2025-02-05 11:49:54.994 | Requesting market depth updates for: MESH5.CME if supported. NumLevels=100 2025-02-05 11:49:54.994 | Requesting market depth updates for: MGCJ5.COMEX if supported. NumLevels=100 2025-02-05 11:49:54.994 | Requesting market depth updates for: MYMH5.CBOT if supported. NumLevels=100 2025-02-05 11:49:55.031 | Denali Data Feed | Clearing market depth for ESH5.CME 2025-02-05 11:49:55.031 | Denali Data Feed | Clearing market depth for MESH5.CME 2025-02-05 11:49:55.035 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 11:49:55.035 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 11:49:55.035 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 11:49:55.463 | HD Request # 40 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme 2025-02-05 11:49:55.464 | HD Request # 40 | Download start date-time: 2025-02-05 11:49:45.000000. File last date-time: 2025-02-05 11:49:45.207000 2025-02-05 11:49:55.464 | HD Request # 40 | Using server: ds32.sierracharts.com port 10149 2025-02-05 11:49:55.487 | Socket (4) | Creating socket. 2025-02-05 11:49:55.487 | Socket (4) | New receive buffer size: 0 2025-02-05 11:49:55.487 | Socket (4) | Connecting to IP: 67.214.125.3. 2025-02-05 11:49:55.561 | HD Request # 40 | Setting DTC encoding to Binary VLS 2025-02-05 11:49:55.561 | HD Request # 40 | Sending historical data logon request message. 2025-02-05 11:49:55.642 | HD Request # 40 | Requesting Intraday data. Start date-time: 2025-02-05 11:49:45. Record interval: 0. Symbol: ESH25 2025-02-05 11:49:55.674 | HD Request # 40 | Decompressing data. 2025-02-05 11:49:55.710 | HD Request # 40 | Receiving Intraday data for ESH5.CME starting at 2025-02-05 11:49:45.009000 2025-02-05 11:49:55.710 | Socket (4) | CloseSocket call. 2025-02-05 11:49:55.710 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 11:49:55.710 | Historical data download thread signaled to stop. 2025-02-05 11:49:55.711 | HD Request # 40 | Timestamp of first Intraday data file record written: 2025-02-05 11:49:46.290000. 2025-02-05 11:49:55.711 | HD Request # 40 | Received 434 Intraday data records from 2025-02-05 11:49:45.009000 to 2025-02-05 11:49:55.017001 (10.0 seconds. Delay: 0.7 seconds) and wrote 432 records for ESH5.CME 2025-02-05 11:49:55.718 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2025-02-05 16:49:55.017001 2025-02-05 11:49:55.718 | Added 2 Time and Sales records to Intraday data file for ESH5.CME after download. 2025-02-05 11:49:55.718 | HD Request # 40 | Completion time: 0s. 2025-02-05 11:49:55.718 | HD Request # 40 | Intraday data download complete for ESH5.CME. Unique request ID: 40 2025-02-05 11:49:55.718 | Removing historical data download ID 40. 2025-02-05 11:49:55.718 | Real-time Intraday chart data file updates started for ESH5.CME 2025-02-05 11:49:55.718 | Intraday chart data file opened for ESH5.CME 2025-02-05 11:49:55.718 | HD Request # 40 | Enabling Intraday chart updating for symbol. 2025-02-05 11:49:55.718 | 2025-02-05 11:49:55.718 | Triggering next historical data download in queue. 2025-02-05 11:49:55.719 | HD Request # 41 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 11:49:55.719 | HD Request # 41 | Download start date-time: 2025-02-05 11:49:45.000000. File last date-time: 2025-02-05 11:49:45.000001 2025-02-05 11:49:55.719 | HD Request # 41 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 11:49:55.719 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 11:49:55.719 | Socket (5) | New receive buffer size: 0 2025-02-05 11:49:55.719 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 11:49:55.742 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 11:49:55.742 | Socket (4) | Closed. 2025-02-05 11:49:55.762 | HD Request # 41 | Sending historical data logon request message. 2025-02-05 11:49:55.887 | HD Request # 41 | Requesting Intraday data. Start date-time: 2025-02-05 11:49:45. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 11:49:55.931 | HD Request # 41 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 11:49:45.786000 2025-02-05 11:49:55.932 | Socket (5) | CloseSocket call. 2025-02-05 11:49:55.932 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 11:49:55.932 | Historical data download thread signaled to stop. 2025-02-05 11:49:55.932 | HD Request # 41 | Timestamp of first Intraday data file record written: 2025-02-05 11:49:45.786000. 2025-02-05 11:49:55.932 | HD Request # 41 | Received 5 Intraday data records from 2025-02-05 11:49:45.786000 to 2025-02-05 11:49:50.601000 (4.8 seconds. Delay: 5.3 seconds) and wrote 5 records for MCLH5.NYMEX 2025-02-05 11:49:55.940 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2025-02-05 16:49:50.601000 2025-02-05 11:49:55.940 | HD Request # 41 | Completion time: 0s. 2025-02-05 11:49:55.940 | HD Request # 41 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 41 2025-02-05 11:49:55.940 | Removing historical data download ID 41. 2025-02-05 11:49:55.940 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 11:49:55.940 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 11:49:55.940 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2025-02-05 11:49:55.940 | 2025-02-05 11:49:55.940 | Triggering next historical data download in queue. 2025-02-05 11:49:55.940 | HD Request # 42 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme 2025-02-05 11:49:55.941 | HD Request # 42 | Download start date-time: 2025-02-05 11:49:45.000000. File last date-time: 2025-02-05 11:49:45.964000 2025-02-05 11:49:55.941 | HD Request # 42 | Using server: ds26.sierracharts.com port 10149 2025-02-05 11:49:55.971 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 11:49:55.971 | Socket (5) | Closed. 2025-02-05 11:49:55.984 | Socket (4) | Creating socket. 2025-02-05 11:49:55.984 | Socket (4) | New receive buffer size: 0 2025-02-05 11:49:55.984 | Socket (4) | Connecting to IP: 64.152.155.17. 2025-02-05 11:49:56.051 | HD Request # 42 | Setting DTC encoding to Binary VLS 2025-02-05 11:49:56.051 | HD Request # 42 | Sending historical data logon request message. 2025-02-05 11:49:56.119 | HD Request # 42 | Requesting Intraday data. Start date-time: 2025-02-05 11:49:45. Record interval: 0. Symbol: MESH25 2025-02-05 11:49:56.147 | HD Request # 42 | Decompressing data. 2025-02-05 11:49:56.175 | HD Request # 42 | Receiving Intraday data for MESH5.CME starting at 2025-02-05 11:49:45.082000 2025-02-05 11:49:56.175 | Socket (4) | CloseSocket call. 2025-02-05 11:49:56.175 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 11:49:56.175 | Historical data download thread signaled to stop. 2025-02-05 11:49:56.175 | HD Request # 42 | Timestamp of first Intraday data file record written: 2025-02-05 11:49:46.155000. 2025-02-05 11:49:56.175 | HD Request # 42 | Received 185 Intraday data records from 2025-02-05 11:49:45.082000 to 2025-02-05 11:49:55.368000 (10.3 seconds. Delay: 0.8 seconds) and wrote 178 records for MESH5.CME 2025-02-05 11:49:56.183 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2025-02-05 16:49:55.368000 2025-02-05 11:49:56.183 | Added 4 Time and Sales records to Intraday data file for MESH5.CME after download. 2025-02-05 11:49:56.183 | HD Request # 42 | Completion time: 1s. 2025-02-05 11:49:56.183 | HD Request # 42 | Intraday data download complete for MESH5.CME. Unique request ID: 42 2025-02-05 11:49:56.183 | Removing historical data download ID 42. 2025-02-05 11:49:56.183 | Real-time Intraday chart data file updates started for MESH5.CME 2025-02-05 11:49:56.183 | Intraday chart data file opened for MESH5.CME 2025-02-05 11:49:56.183 | HD Request # 42 | Enabling Intraday chart updating for symbol. 2025-02-05 11:49:56.183 | 2025-02-05 11:49:56.183 | Triggering next historical data download in queue. 2025-02-05 11:49:56.183 | HD Request # 43 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 11:49:56.184 | HD Request # 43 | Download start date-time: 2025-02-05 11:49:44.000000. File last date-time: 2025-02-05 11:49:44.000002 2025-02-05 11:49:56.184 | HD Request # 43 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 11:49:56.184 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 11:49:56.184 | Socket (5) | New receive buffer size: 0 2025-02-05 11:49:56.184 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 11:49:56.204 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 11:49:56.204 | Socket (4) | Closed. 2025-02-05 11:49:56.228 | HD Request # 43 | Sending historical data logon request message. 2025-02-05 11:49:56.351 | HD Request # 43 | Requesting Intraday data. Start date-time: 2025-02-05 11:49:44. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 11:49:56.395 | HD Request # 43 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 11:49:44.552000 2025-02-05 11:49:56.399 | Socket (5) | CloseSocket call. 2025-02-05 11:49:56.399 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 11:49:56.400 | Historical data download thread signaled to stop. 2025-02-05 11:49:56.400 | HD Request # 43 | Timestamp of first Intraday data file record written: 2025-02-05 11:49:44.552000. 2025-02-05 11:49:56.400 | HD Request # 43 | Received 6 Intraday data records from 2025-02-05 11:49:44.552000 to 2025-02-05 11:49:53.040000 (8.5 seconds. Delay: 3.4 seconds) and wrote 6 records for MGCJ5.COMEX 2025-02-05 11:49:56.410 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2025-02-05 16:49:53.040000 2025-02-05 11:49:56.410 | HD Request # 43 | Completion time: 0s. 2025-02-05 11:49:56.410 | HD Request # 43 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 43 2025-02-05 11:49:56.410 | Removing historical data download ID 43. 2025-02-05 11:49:56.410 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 11:49:56.410 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 11:49:56.410 | HD Request # 43 | Enabling Intraday chart updating for symbol. 2025-02-05 11:49:56.410 | 2025-02-05 11:49:56.410 | Triggering next historical data download in queue. 2025-02-05 11:49:56.410 | HD Request # 44 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 11:49:56.411 | HD Request # 44 | Download start date-time: 2025-02-05 11:49:44.000000. File last date-time: 2025-02-05 11:49:44.000000 2025-02-05 11:49:56.411 | HD Request # 44 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 11:49:56.411 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 11:49:56.411 | Socket (4) | New receive buffer size: 0 2025-02-05 11:49:56.411 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 11:49:56.444 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 11:49:56.444 | Socket (5) | Closed. 2025-02-05 11:49:56.455 | HD Request # 44 | Sending historical data logon request message. 2025-02-05 11:49:56.578 | HD Request # 44 | Requesting Intraday data. Start date-time: 2025-02-05 11:49:44. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 11:49:56.623 | HD Request # 44 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 11:49:44.062000 2025-02-05 11:49:56.662 | Socket (4) | CloseSocket call. 2025-02-05 11:49:56.662 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 11:49:56.662 | Historical data download thread signaled to stop. 2025-02-05 11:49:56.662 | HD Request # 44 | Timestamp of first Intraday data file record written: 2025-02-05 11:49:44.062000. 2025-02-05 11:49:56.662 | HD Request # 44 | Received 35 Intraday data records from 2025-02-05 11:49:44.062000 to 2025-02-05 11:49:56.185000 (12.1 seconds. Delay: 0.5 seconds) and wrote 35 records for MYMH5.CBOT 2025-02-05 11:49:56.671 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2025-02-05 16:49:56.185000 2025-02-05 11:49:56.671 | HD Request # 44 | Completion time: 0s. 2025-02-05 11:49:56.671 | HD Request # 44 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 44 2025-02-05 11:49:56.671 | Removing historical data download ID 44. 2025-02-05 11:49:56.671 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 11:49:56.671 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 11:49:56.671 | HD Request # 44 | Enabling Intraday chart updating for symbol. 2025-02-05 11:49:56.671 | 2025-02-05 11:49:56.671 | No download requests in the queue to start downloads for. 2025-02-05 11:49:56.703 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 11:49:56.703 | Socket (4) | Closed. 2025-02-05 11:49:58.709 | Opened cached Intraday file: D:\SierraChart\Data\ESH5.CME.scid. Thread ID: 22756 2025-02-05 11:49:58.709 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 11:49:58.709 | Opened cached Intraday file: D:\SierraChart\Data\MESH5.CME.scid. Thread ID: 22756 2025-02-05 11:49:58.710 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 11:50:03.772 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 11:50:09.819 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Creating socket. Using TLS 1.2. 2025-02-05 11:50:09.819 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | New receive buffer size: 0 2025-02-05 11:50:09.819 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Connecting to IP: 216.66.0.130. 2025-02-05 11:50:10.217 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | CloseSocket call. 2025-02-05 11:50:10.217 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Shutdown started. Waiting for graceful close. 2025-02-05 11:50:10.237 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Socket gracefully closed by remote side. 2025-02-05 11:50:10.238 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Closed. 2025-02-05 17:45:00.457 | Added historical Daily data request for ESH5.CME to the queue. 2025-02-05 17:45:00.457 | Triggering next historical data download in queue. 2025-02-05 17:45:00.460 | HD Request # 45 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-01-31. Service: rithmic.trading 2025-02-05 17:45:00.719 | HD Request # 45 | Requesting historical Daily data for ESH25 starting at 2025-01-30. SC External HD service. 2025-02-05 17:45:00.869 | HD Request # 45 | Receiving historical Daily data for ESH5.CME starting at 2025-01-31. 2025-02-05 17:45:00.869 | HD Request # 45 | Writing historical Daily data to the file ESH5.CME.dly. 2025-02-05 17:45:00.874 | HD Request # 45 | Bytes received: 294 2025-02-05 17:45:00.874 | HD Request # 45 | Received 5 Daily data records from 2025-01-31 00:00:00 to 2025-02-05 00:00:00 (6.0 days) and wrote 4 records for ESH5.CME 2025-02-05 17:45:00.874 | HD Request # 45 | Completion time: 0s. 2025-02-05 17:45:00.874 | HD Request # 45 | Daily data download complete for ESH5.CME. Unique request ID: 45 2025-02-05 17:45:00.874 | Removing historical data download ID 45. 2025-02-05 17:45:00.874 | 2025-02-05 17:45:00.874 | No download requests in the queue to start downloads for. 2025-02-05 17:45:00.929 | ESH5.CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 17:45:01.642 | ESH5.CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-05 18:00:30.938 | Added historical Daily data request for ESH5.CME to the queue. 2025-02-05 18:00:30.938 | Triggering next historical data download in queue. 2025-02-05 18:00:30.940 | HD Request # 46 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-02-03. Service: rithmic.trading 2025-02-05 18:00:31.158 | HD Request # 46 | Requesting historical Daily data for ESH25 starting at 2025-02-02. SC External HD service. 2025-02-05 18:00:31.346 | HD Request # 46 | Receiving historical Daily data for ESH5.CME starting at 2025-02-03. 2025-02-05 18:00:31.347 | HD Request # 46 | Writing historical Daily data to the file ESH5.CME.dly. 2025-02-05 18:00:31.352 | HD Request # 46 | Bytes received: 169 2025-02-05 18:00:31.352 | HD Request # 46 | Received 3 Daily data records from 2025-02-03 00:00:00 to 2025-02-05 00:00:00 (3.0 days) and wrote 3 records for ESH5.CME 2025-02-05 18:00:31.352 | HD Request # 46 | Completion time: 1s. 2025-02-05 18:00:31.352 | HD Request # 46 | Daily data download complete for ESH5.CME. Unique request ID: 46 2025-02-05 18:00:31.352 | Removing historical data download ID 46. 2025-02-05 18:00:31.352 | 2025-02-05 18:00:31.352 | No download requests in the queue to start downloads for. 2025-02-05 18:00:31.480 | ESH5.CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 18:00:32.198 | ESH5.CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-05 18:00:32.474 | ESH5.CME [CV][M] Daily #3 | Reloading Historical Daily chart due to current quote data for new date received. 2025-02-05 18:00:32.980 | ESH5.CME [CV][M] Daily #3 | Reloading chart. 2025-02-05 18:00:33.697 | ESH5.CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-05 18:04:33.430 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 18:22:08.428 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 19:17:47.605 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 19:17:47.605 | DTC Client socket (2) | CloseSocket call. 2025-02-05 19:17:47.605 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 19:17:47.605 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 19:17:47.605 | DTC Client socket (2) | Closed. 2025-02-05 19:17:47.605 | DTC Client socket (0) | CloseSocket call. 2025-02-05 19:17:47.605 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 19:17:47.605 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 19:17:49.599 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 19:17:49.599 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 19:17:49.647 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 19:17:49.647 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 19:17:49.647 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 19:17:49.691 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 19:17:49.691 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 19:17:49.691 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 19:17:49.691 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 19:17:49.817 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 19:17:49.817 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 19:17:49.817 | Triggering next historical data download in queue. 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 19:17:49.817 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 19:17:49.817 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 19:17:49.817 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 19:17:49.817 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 19:17:49.817 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 19:17:49.817 | HD Request # 47 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 19:17:49.818 | HD Request # 47 | Download start date-time: 2025-02-05 19:17:40.000000. File last date-time: 2025-02-05 19:17:40.000000 2025-02-05 19:17:49.818 | HD Request # 47 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 19:17:49.818 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 19:17:49.818 | Socket (4) | New receive buffer size: 0 2025-02-05 19:17:49.818 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 19:17:49.858 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 19:17:49.858 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 19:17:49.858 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 19:17:49.861 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 19:17:49.861 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 19:17:49.861 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 19:17:49.862 | HD Request # 47 | Sending historical data logon request message. 2025-02-05 19:17:49.986 | HD Request # 47 | Requesting Intraday data. Start date-time: 2025-02-05 19:17:40. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 19:17:50.031 | HD Request # 47 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 19:17:40.761000 2025-02-05 19:17:50.071 | Socket (4) | CloseSocket call. 2025-02-05 19:17:50.071 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 19:17:50.071 | Historical data download thread signaled to stop. 2025-02-05 19:17:50.071 | HD Request # 47 | Timestamp of first Intraday data file record written: 2025-02-05 19:17:40.761000. 2025-02-05 19:17:50.072 | HD Request # 47 | Received 14 Intraday data records from 2025-02-05 19:17:40.761000 to 2025-02-05 19:17:49.071000 (8.3 seconds. Delay: 1.0 seconds) and wrote 14 records for MCLH5.NYMEX 2025-02-05 19:17:50.079 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2025-02-06 00:17:49.071000 2025-02-05 19:17:50.079 | HD Request # 47 | Completion time: 1s. 2025-02-05 19:17:50.079 | HD Request # 47 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 47 2025-02-05 19:17:50.079 | Removing historical data download ID 47. 2025-02-05 19:17:50.079 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 19:17:50.079 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 19:17:50.079 | HD Request # 47 | Enabling Intraday chart updating for symbol. 2025-02-05 19:17:50.079 | 2025-02-05 19:17:50.080 | Triggering next historical data download in queue. 2025-02-05 19:17:50.080 | HD Request # 48 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 19:17:50.080 | HD Request # 48 | Download start date-time: 2025-02-05 19:17:44.000000. File last date-time: 2025-02-05 19:17:44.000000 2025-02-05 19:17:50.080 | HD Request # 48 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 19:17:50.080 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 19:17:50.081 | Socket (5) | New receive buffer size: 0 2025-02-05 19:17:50.081 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 19:17:50.112 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 19:17:50.112 | Socket (4) | Closed. 2025-02-05 19:17:50.124 | HD Request # 48 | Sending historical data logon request message. 2025-02-05 19:17:50.251 | HD Request # 48 | Requesting Intraday data. Start date-time: 2025-02-05 19:17:44. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 19:17:50.295 | HD Request # 48 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 19:17:44.281000 2025-02-05 19:17:50.296 | Socket (5) | CloseSocket call. 2025-02-05 19:17:50.296 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 19:17:50.296 | Historical data download thread signaled to stop. 2025-02-05 19:17:50.296 | HD Request # 48 | Timestamp of first Intraday data file record written: 2025-02-05 19:17:44.281000. 2025-02-05 19:17:50.296 | HD Request # 48 | Received 2 Intraday data records from 2025-02-05 19:17:44.281000 to 2025-02-05 19:17:49.915000 (5.6 seconds. Delay: 0.4 seconds) and wrote 2 records for MGCJ5.COMEX 2025-02-05 19:17:50.304 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2025-02-06 00:17:49.915000 2025-02-05 19:17:50.304 | HD Request # 48 | Completion time: 0s. 2025-02-05 19:17:50.304 | HD Request # 48 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 48 2025-02-05 19:17:50.304 | Removing historical data download ID 48. 2025-02-05 19:17:50.304 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 19:17:50.304 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 19:17:50.304 | HD Request # 48 | Enabling Intraday chart updating for symbol. 2025-02-05 19:17:50.304 | 2025-02-05 19:17:50.305 | Triggering next historical data download in queue. 2025-02-05 19:17:50.305 | HD Request # 49 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 19:17:50.305 | HD Request # 49 | Download start date-time: 2025-02-05 19:17:24.000000. File last date-time: 2025-02-05 19:17:24.000004 2025-02-05 19:17:50.306 | HD Request # 49 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 19:17:50.306 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 19:17:50.306 | Socket (4) | New receive buffer size: 0 2025-02-05 19:17:50.306 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 19:17:50.336 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 19:17:50.336 | Socket (5) | Closed. 2025-02-05 19:17:50.349 | HD Request # 49 | Sending historical data logon request message. 2025-02-05 19:17:50.494 | HD Request # 49 | Requesting Intraday data. Start date-time: 2025-02-05 19:17:24. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 19:17:50.541 | HD Request # 49 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 19:17:24.462000 2025-02-05 19:17:50.541 | Socket (4) | CloseSocket call. 2025-02-05 19:17:50.541 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 19:17:50.542 | Historical data download thread signaled to stop. 2025-02-05 19:17:50.542 | HD Request # 49 | Timestamp of first Intraday data file record written: 2025-02-05 19:17:24.462000. 2025-02-05 19:17:50.542 | HD Request # 49 | Received 6 Intraday data records from 2025-02-05 19:17:24.462000 to 2025-02-05 19:17:46.786000 (22.3 seconds. Delay: 3.8 seconds) and wrote 6 records for MYMH5.CBOT 2025-02-05 19:17:50.550 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2025-02-06 00:17:46.786000 2025-02-05 19:17:50.550 | HD Request # 49 | Completion time: 0s. 2025-02-05 19:17:50.550 | HD Request # 49 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 49 2025-02-05 19:17:50.550 | Removing historical data download ID 49. 2025-02-05 19:17:50.550 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 19:17:50.550 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 19:17:50.550 | HD Request # 49 | Enabling Intraday chart updating for symbol. 2025-02-05 19:17:50.550 | 2025-02-05 19:17:50.550 | No download requests in the queue to start downloads for. 2025-02-05 19:17:50.582 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 19:17:50.582 | Socket (4) | Closed. 2025-02-05 19:17:53.448 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 19:17:58.500 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 19:17:58.500 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 19:50:10.001 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Creating socket. Using TLS 1.2. 2025-02-05 19:50:10.001 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | New receive buffer size: 0 2025-02-05 19:50:10.001 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Connecting to IP: 216.66.0.130. 2025-02-05 19:50:10.377 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | CloseSocket call. 2025-02-05 19:50:10.377 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Shutdown started. Waiting for graceful close. 2025-02-05 19:50:10.396 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Socket gracefully closed by remote side. 2025-02-05 19:50:10.396 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Closed. 2025-02-05 20:52:49.691 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 21:10:05.120 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 21:10:05.120 | DTC Client socket (2) | CloseSocket call. 2025-02-05 21:10:05.120 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 21:10:05.120 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 21:10:05.120 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 21:10:05.120 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 21:10:05.120 | DTC Client socket (2) | Closed. 2025-02-05 21:10:05.120 | DTC Client socket (0) | CloseSocket call. 2025-02-05 21:10:05.120 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 21:10:05.120 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 21:10:07.113 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 21:10:07.113 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 21:10:07.156 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 21:10:07.156 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 21:10:07.156 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 21:10:07.200 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 21:10:07.200 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 21:10:07.200 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 21:10:07.200 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 21:10:07.356 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 21:10:07.356 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 21:10:07.356 | Triggering next historical data download in queue. 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 21:10:07.356 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 21:10:07.356 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 21:10:07.356 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 21:10:07.356 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 21:10:07.356 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 21:10:07.356 | HD Request # 50 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 21:10:07.357 | HD Request # 50 | Download start date-time: 2025-02-05 21:09:56.000000. File last date-time: 2025-02-05 21:09:56.000001 2025-02-05 21:10:07.357 | HD Request # 50 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 21:10:07.357 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 21:10:07.357 | Socket (4) | New receive buffer size: 0 2025-02-05 21:10:07.357 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 21:10:07.399 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 21:10:07.399 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 21:10:07.399 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 21:10:07.399 | HD Request # 50 | Sending historical data logon request message. 2025-02-05 21:10:07.400 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 21:10:07.400 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 21:10:07.400 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 21:10:07.523 | HD Request # 50 | Requesting Intraday data. Start date-time: 2025-02-05 21:09:56. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 21:10:07.568 | HD Request # 50 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 21:09:56.497000 2025-02-05 21:10:07.568 | Socket (4) | CloseSocket call. 2025-02-05 21:10:07.568 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 21:10:07.568 | Historical data download thread signaled to stop. 2025-02-05 21:10:07.568 | HD Request # 50 | Timestamp of first Intraday data file record written: 2025-02-05 21:09:56.497000. 2025-02-05 21:10:07.568 | HD Request # 50 | Received 2 Intraday data records from 2025-02-05 21:09:56.497000 to 2025-02-05 21:09:56.867000 (0.4 seconds. Delay: 10.7 seconds) and wrote 2 records for MCLH5.NYMEX 2025-02-05 21:10:07.575 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2025-02-06 02:09:56.867000 2025-02-05 21:10:07.575 | HD Request # 50 | Completion time: 0s. 2025-02-05 21:10:07.575 | HD Request # 50 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 50 2025-02-05 21:10:07.575 | Removing historical data download ID 50. 2025-02-05 21:10:07.576 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 21:10:07.576 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 21:10:07.576 | HD Request # 50 | Enabling Intraday chart updating for symbol. 2025-02-05 21:10:07.576 | 2025-02-05 21:10:07.576 | Triggering next historical data download in queue. 2025-02-05 21:10:07.576 | HD Request # 51 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 21:10:07.576 | HD Request # 51 | Download start date-time: 2025-02-05 21:10:01.000000. File last date-time: 2025-02-05 21:10:01.000000 2025-02-05 21:10:07.576 | HD Request # 51 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 21:10:07.576 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 21:10:07.576 | Socket (5) | New receive buffer size: 0 2025-02-05 21:10:07.576 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 21:10:07.608 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 21:10:07.608 | Socket (4) | Closed. 2025-02-05 21:10:07.619 | HD Request # 51 | Sending historical data logon request message. 2025-02-05 21:10:07.745 | HD Request # 51 | Requesting Intraday data. Start date-time: 2025-02-05 21:10:01. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 21:10:07.790 | HD Request # 51 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 21:10:01.623000 2025-02-05 21:10:07.791 | Socket (5) | CloseSocket call. 2025-02-05 21:10:07.791 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 21:10:07.791 | Historical data download thread signaled to stop. 2025-02-05 21:10:07.791 | HD Request # 51 | Timestamp of first Intraday data file record written: 2025-02-05 21:10:01.623000. 2025-02-05 21:10:07.791 | HD Request # 51 | Received 1 Intraday data record from 2025-02-05 21:10:01.623000 to 2025-02-05 21:10:01.623000 (0.0 seconds. Delay: 6.2 seconds) and wrote 1 record for MGCJ5.COMEX 2025-02-05 21:10:07.798 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2025-02-06 02:10:01.623000 2025-02-05 21:10:07.798 | HD Request # 51 | Completion time: 0s. 2025-02-05 21:10:07.798 | HD Request # 51 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 51 2025-02-05 21:10:07.798 | Removing historical data download ID 51. 2025-02-05 21:10:07.798 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 21:10:07.798 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 21:10:07.798 | HD Request # 51 | Enabling Intraday chart updating for symbol. 2025-02-05 21:10:07.798 | 2025-02-05 21:10:07.798 | Triggering next historical data download in queue. 2025-02-05 21:10:07.798 | HD Request # 52 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 21:10:07.799 | HD Request # 52 | Download start date-time: 2025-02-05 21:09:59.000000. File last date-time: 2025-02-05 21:09:59.000001 2025-02-05 21:10:07.799 | HD Request # 52 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 21:10:07.799 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 21:10:07.799 | Socket (4) | New receive buffer size: 0 2025-02-05 21:10:07.799 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 21:10:07.834 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 21:10:07.834 | Socket (5) | Closed. 2025-02-05 21:10:07.841 | HD Request # 52 | Sending historical data logon request message. 2025-02-05 21:10:07.965 | HD Request # 52 | Requesting Intraday data. Start date-time: 2025-02-05 21:09:59. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 21:10:08.019 | HD Request # 52 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 21:09:59.946000 2025-02-05 21:10:08.019 | Socket (4) | CloseSocket call. 2025-02-05 21:10:08.019 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 21:10:08.019 | Historical data download thread signaled to stop. 2025-02-05 21:10:08.019 | HD Request # 52 | Timestamp of first Intraday data file record written: 2025-02-05 21:09:59.946000. 2025-02-05 21:10:08.019 | HD Request # 52 | Received 2 Intraday data records from 2025-02-05 21:09:59.946000 to 2025-02-05 21:09:59.946001 (0.0 seconds. Delay: 8.1 seconds) and wrote 2 records for MYMH5.CBOT 2025-02-05 21:10:08.028 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2025-02-06 02:09:59.946001 2025-02-05 21:10:08.028 | HD Request # 52 | Completion time: 1s. 2025-02-05 21:10:08.028 | HD Request # 52 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 52 2025-02-05 21:10:08.028 | Removing historical data download ID 52. 2025-02-05 21:10:08.028 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 21:10:08.028 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 21:10:08.028 | HD Request # 52 | Enabling Intraday chart updating for symbol. 2025-02-05 21:10:08.028 | 2025-02-05 21:10:08.028 | No download requests in the queue to start downloads for. 2025-02-05 21:10:08.060 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 21:10:08.060 | Socket (4) | Closed. 2025-02-05 21:10:13.759 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 21:10:18.817 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 21:10:49.152 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 22:01:51.015 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 22:01:51.015 | DTC Client socket (2) | CloseSocket call. 2025-02-05 22:01:51.015 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 22:01:51.015 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 22:01:51.015 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 22:01:51.015 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 22:01:51.015 | DTC Client socket (2) | Closed. 2025-02-05 22:01:51.015 | DTC Client socket (0) | CloseSocket call. 2025-02-05 22:01:51.015 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 22:01:51.015 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 22:01:53.001 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 22:01:53.001 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 22:01:53.474 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 22:01:53.474 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 22:01:53.474 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 22:01:53.519 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 22:01:53.519 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 22:01:53.519 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 22:01:53.519 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 22:01:53.661 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 22:01:53.661 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 22:01:53.661 | Triggering next historical data download in queue. 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 22:01:53.661 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 22:01:53.661 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 22:01:53.661 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 22:01:53.661 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 22:01:53.661 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 22:01:53.661 | HD Request # 53 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 22:01:53.661 | HD Request # 53 | Download start date-time: 2025-02-05 22:01:46.000000. File last date-time: 2025-02-05 22:01:46.000000 2025-02-05 22:01:53.661 | HD Request # 53 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:01:53.661 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:01:53.662 | Socket (4) | New receive buffer size: 0 2025-02-05 22:01:53.662 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:01:53.705 | HD Request # 53 | Sending historical data logon request message. 2025-02-05 22:01:53.705 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 22:01:53.705 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 22:01:53.705 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 22:01:53.705 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 22:01:53.705 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 22:01:53.705 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 22:01:53.829 | HD Request # 53 | Requesting Intraday data. Start date-time: 2025-02-05 22:01:46. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 22:01:53.873 | HD Request # 53 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 22:01:46.946000 2025-02-05 22:01:53.874 | Socket (4) | CloseSocket call. 2025-02-05 22:01:53.874 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:01:53.874 | Historical data download thread signaled to stop. 2025-02-05 22:01:53.874 | HD Request # 53 | Timestamp of first Intraday data file record written: 2025-02-05 22:01:46.946000. 2025-02-05 22:01:53.874 | HD Request # 53 | Received 1 Intraday data record from 2025-02-05 22:01:46.946000 to 2025-02-05 22:01:46.946000 (0.0 seconds. Delay: 6.9 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-05 22:01:53.882 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:01:46.946000 2025-02-05 22:01:53.882 | HD Request # 53 | Completion time: 0s. 2025-02-05 22:01:53.882 | HD Request # 53 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 53 2025-02-05 22:01:53.882 | Removing historical data download ID 53. 2025-02-05 22:01:53.882 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 22:01:53.882 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 22:01:53.882 | HD Request # 53 | Enabling Intraday chart updating for symbol. 2025-02-05 22:01:53.882 | 2025-02-05 22:01:53.882 | Triggering next historical data download in queue. 2025-02-05 22:01:53.882 | HD Request # 54 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 22:01:53.883 | HD Request # 54 | Download start date-time: 2025-02-05 22:01:42.000000. File last date-time: 2025-02-05 22:01:42.000001 2025-02-05 22:01:53.883 | HD Request # 54 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:01:53.883 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 22:01:53.883 | Socket (5) | New receive buffer size: 0 2025-02-05 22:01:53.883 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 22:01:53.914 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:01:53.914 | Socket (4) | Closed. 2025-02-05 22:01:53.926 | HD Request # 54 | Sending historical data logon request message. 2025-02-05 22:01:54.071 | HD Request # 54 | Requesting Intraday data. Start date-time: 2025-02-05 22:01:42. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 22:01:54.116 | HD Request # 54 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 22:01:42.072000 2025-02-05 22:01:54.117 | Socket (5) | CloseSocket call. 2025-02-05 22:01:54.117 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 22:01:54.117 | Historical data download thread signaled to stop. 2025-02-05 22:01:54.117 | HD Request # 54 | Timestamp of first Intraday data file record written: 2025-02-05 22:01:42.072000. 2025-02-05 22:01:54.117 | HD Request # 54 | Received 2 Intraday data records from 2025-02-05 22:01:42.072000 to 2025-02-05 22:01:42.072001 (0.0 seconds. Delay: 12.0 seconds) and wrote 2 records for MGCJ5.COMEX 2025-02-05 22:01:54.124 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:01:42.072001 2025-02-05 22:01:54.125 | HD Request # 54 | Completion time: 1s. 2025-02-05 22:01:54.125 | HD Request # 54 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 54 2025-02-05 22:01:54.125 | Removing historical data download ID 54. 2025-02-05 22:01:54.125 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 22:01:54.125 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 22:01:54.125 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2025-02-05 22:01:54.125 | 2025-02-05 22:01:54.125 | Triggering next historical data download in queue. 2025-02-05 22:01:54.125 | HD Request # 55 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 22:01:54.125 | HD Request # 55 | Download start date-time: 2025-02-05 22:01:48.000000. File last date-time: 2025-02-05 22:01:48.000000 2025-02-05 22:01:54.125 | HD Request # 55 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:01:54.125 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:01:54.125 | Socket (4) | New receive buffer size: 0 2025-02-05 22:01:54.125 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:01:54.163 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 22:01:54.163 | Socket (5) | Closed. 2025-02-05 22:01:54.172 | HD Request # 55 | Sending historical data logon request message. 2025-02-05 22:01:54.303 | HD Request # 55 | Requesting Intraday data. Start date-time: 2025-02-05 22:01:48. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 22:01:54.349 | HD Request # 55 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 22:01:48.803000 2025-02-05 22:01:54.349 | Socket (4) | CloseSocket call. 2025-02-05 22:01:54.349 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:01:54.349 | Historical data download thread signaled to stop. 2025-02-05 22:01:54.349 | HD Request # 55 | Timestamp of first Intraday data file record written: 2025-02-05 22:01:48.803000. 2025-02-05 22:01:54.349 | HD Request # 55 | Received 2 Intraday data records from 2025-02-05 22:01:48.803000 to 2025-02-05 22:01:52.044000 (3.2 seconds. Delay: 2.3 seconds) and wrote 2 records for MYMH5.CBOT 2025-02-05 22:01:54.360 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:01:52.044000 2025-02-05 22:01:54.360 | HD Request # 55 | Completion time: 0s. 2025-02-05 22:01:54.360 | HD Request # 55 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 55 2025-02-05 22:01:54.360 | Removing historical data download ID 55. 2025-02-05 22:01:54.360 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 22:01:54.360 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 22:01:54.360 | HD Request # 55 | Enabling Intraday chart updating for symbol. 2025-02-05 22:01:54.360 | 2025-02-05 22:01:54.360 | No download requests in the queue to start downloads for. 2025-02-05 22:01:54.389 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:01:54.389 | Socket (4) | Closed. 2025-02-05 22:01:58.588 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 22:01:58.588 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 22:02:08.702 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 22:13:46.255 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 22:13:46.255 | DTC Client socket (2) | CloseSocket call. 2025-02-05 22:13:46.255 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 22:13:46.255 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 22:13:46.255 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 22:13:46.255 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 22:13:46.255 | DTC Client socket (2) | Closed. 2025-02-05 22:13:46.255 | DTC Client socket (0) | CloseSocket call. 2025-02-05 22:13:46.255 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 22:13:46.255 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 22:13:48.260 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 22:13:48.260 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 22:13:48.326 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 22:13:48.326 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 22:13:48.326 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 22:13:48.370 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 22:13:48.370 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 22:13:48.370 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 22:13:48.370 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 22:13:48.497 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 22:13:48.497 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 22:13:48.497 | Triggering next historical data download in queue. 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 22:13:48.497 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 22:13:48.497 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 22:13:48.497 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 22:13:48.497 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 22:13:48.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 22:13:48.497 | HD Request # 56 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 22:13:48.498 | HD Request # 56 | Download start date-time: 2025-02-05 22:13:39.000000. File last date-time: 2025-02-05 22:13:39.000000 2025-02-05 22:13:48.498 | HD Request # 56 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:13:48.498 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:13:48.498 | Socket (4) | New receive buffer size: 0 2025-02-05 22:13:48.498 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:13:48.541 | HD Request # 56 | Sending historical data logon request message. 2025-02-05 22:13:48.542 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 22:13:48.542 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 22:13:48.542 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 22:13:48.542 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 22:13:48.542 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 22:13:48.542 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 22:13:48.666 | HD Request # 56 | Requesting Intraday data. Start date-time: 2025-02-05 22:13:39. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 22:13:48.711 | HD Request # 56 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 22:13:39.569000 2025-02-05 22:13:48.711 | Socket (4) | CloseSocket call. 2025-02-05 22:13:48.711 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:13:48.739 | Historical data download thread signaled to stop. 2025-02-05 22:13:48.740 | HD Request # 56 | Timestamp of first Intraday data file record written: 2025-02-05 22:13:39.569000. 2025-02-05 22:13:48.740 | HD Request # 56 | Received 1 Intraday data record from 2025-02-05 22:13:39.569000 to 2025-02-05 22:13:39.569000 (0.0 seconds. Delay: 9.2 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-05 22:13:48.749 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:13:39.569000 2025-02-05 22:13:48.749 | HD Request # 56 | Completion time: 0s. 2025-02-05 22:13:48.749 | HD Request # 56 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 56 2025-02-05 22:13:48.749 | Removing historical data download ID 56. 2025-02-05 22:13:48.749 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 22:13:48.749 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 22:13:48.749 | HD Request # 56 | Enabling Intraday chart updating for symbol. 2025-02-05 22:13:48.749 | 2025-02-05 22:13:48.749 | Triggering next historical data download in queue. 2025-02-05 22:13:48.749 | HD Request # 57 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 22:13:48.750 | HD Request # 57 | Download start date-time: 2025-02-05 22:13:44.000000. File last date-time: 2025-02-05 22:13:44.000000 2025-02-05 22:13:48.750 | HD Request # 57 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:13:48.750 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 22:13:48.750 | Socket (5) | New receive buffer size: 0 2025-02-05 22:13:48.750 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 22:13:48.762 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:13:48.762 | Socket (4) | Closed. 2025-02-05 22:13:48.794 | HD Request # 57 | Sending historical data logon request message. 2025-02-05 22:13:48.921 | HD Request # 57 | Requesting Intraday data. Start date-time: 2025-02-05 22:13:44. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 22:13:48.965 | HD Request # 57 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 22:13:44.204000 2025-02-05 22:13:48.966 | Socket (5) | CloseSocket call. 2025-02-05 22:13:48.966 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 22:13:48.966 | Historical data download thread signaled to stop. 2025-02-05 22:13:48.966 | HD Request # 57 | Timestamp of first Intraday data file record written: 2025-02-05 22:13:44.204000. 2025-02-05 22:13:48.966 | HD Request # 57 | Received 2 Intraday data records from 2025-02-05 22:13:44.204000 to 2025-02-05 22:13:48.888000 (4.7 seconds. Delay: 0.1 seconds) and wrote 2 records for MGCJ5.COMEX 2025-02-05 22:13:48.974 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:13:48.888000 2025-02-05 22:13:48.974 | HD Request # 57 | Completion time: 0s. 2025-02-05 22:13:48.974 | HD Request # 57 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 57 2025-02-05 22:13:48.974 | Removing historical data download ID 57. 2025-02-05 22:13:48.974 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 22:13:48.974 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 22:13:48.974 | HD Request # 57 | Enabling Intraday chart updating for symbol. 2025-02-05 22:13:48.974 | 2025-02-05 22:13:48.974 | Triggering next historical data download in queue. 2025-02-05 22:13:48.974 | HD Request # 58 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 22:13:48.974 | HD Request # 58 | Download start date-time: 2025-02-05 22:13:27.000000. File last date-time: 2025-02-05 22:13:27.000001 2025-02-05 22:13:48.975 | HD Request # 58 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:13:48.975 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:13:48.975 | Socket (4) | New receive buffer size: 0 2025-02-05 22:13:48.975 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:13:49.007 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 22:13:49.007 | Socket (5) | Closed. 2025-02-05 22:13:49.017 | HD Request # 58 | Sending historical data logon request message. 2025-02-05 22:13:49.149 | HD Request # 58 | Requesting Intraday data. Start date-time: 2025-02-05 22:13:27. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 22:13:49.193 | HD Request # 58 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 22:13:27.303000 2025-02-05 22:13:49.194 | Socket (4) | CloseSocket call. 2025-02-05 22:13:49.194 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:13:49.194 | Historical data download thread signaled to stop. 2025-02-05 22:13:49.194 | HD Request # 58 | Timestamp of first Intraday data file record written: 2025-02-05 22:13:27.303000. 2025-02-05 22:13:49.194 | HD Request # 58 | Received 3 Intraday data records from 2025-02-05 22:13:27.303000 to 2025-02-05 22:13:47.712000 (20.4 seconds. Delay: 1.5 seconds) and wrote 3 records for MYMH5.CBOT 2025-02-05 22:13:49.202 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:13:47.712000 2025-02-05 22:13:49.202 | HD Request # 58 | Completion time: 1s. 2025-02-05 22:13:49.202 | HD Request # 58 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 58 2025-02-05 22:13:49.202 | Removing historical data download ID 58. 2025-02-05 22:13:49.202 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 22:13:49.202 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 22:13:49.202 | HD Request # 58 | Enabling Intraday chart updating for symbol. 2025-02-05 22:13:49.202 | 2025-02-05 22:13:49.202 | No download requests in the queue to start downloads for. 2025-02-05 22:13:49.236 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:13:49.236 | Socket (4) | Closed. 2025-02-05 22:13:55.711 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 22:14:00.772 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 22:14:25.996 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 22:19:41.987 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 22:19:41.987 | DTC Client socket (2) | CloseSocket call. 2025-02-05 22:19:41.987 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 22:19:41.987 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 22:19:41.987 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 22:19:41.987 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 22:19:41.987 | DTC Client socket (2) | Closed. 2025-02-05 22:19:41.988 | DTC Client socket (0) | CloseSocket call. 2025-02-05 22:19:41.988 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 22:19:41.988 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 22:19:43.990 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 22:19:43.990 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 22:19:44.110 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 22:19:44.110 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 22:19:44.110 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 22:19:44.153 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 22:19:44.153 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 22:19:44.153 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 22:19:44.153 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 22:19:44.279 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 22:19:44.279 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 22:19:44.279 | Triggering next historical data download in queue. 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 22:19:44.279 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 22:19:44.279 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 22:19:44.279 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 22:19:44.279 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 22:19:44.279 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 22:19:44.279 | HD Request # 59 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 22:19:44.279 | HD Request # 59 | Download start date-time: 2025-02-05 22:19:31.000000. File last date-time: 2025-02-05 22:19:31.000000 2025-02-05 22:19:44.280 | HD Request # 59 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:19:44.280 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:19:44.280 | Socket (4) | New receive buffer size: 0 2025-02-05 22:19:44.280 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:19:44.321 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 22:19:44.321 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 22:19:44.321 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 22:19:44.324 | HD Request # 59 | Sending historical data logon request message. 2025-02-05 22:19:44.416 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 22:19:44.416 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 22:19:44.416 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 22:19:44.449 | HD Request # 59 | Requesting Intraday data. Start date-time: 2025-02-05 22:19:31. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 22:19:44.495 | HD Request # 59 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 22:19:31.527000 2025-02-05 22:19:44.495 | Socket (4) | CloseSocket call. 2025-02-05 22:19:44.495 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:19:44.495 | Historical data download thread signaled to stop. 2025-02-05 22:19:44.495 | HD Request # 59 | Timestamp of first Intraday data file record written: 2025-02-05 22:19:31.527000. 2025-02-05 22:19:44.495 | HD Request # 59 | Received 1 Intraday data record from 2025-02-05 22:19:31.527000 to 2025-02-05 22:19:31.527000 (0.0 seconds. Delay: 13.0 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-05 22:19:44.504 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:19:31.527000 2025-02-05 22:19:44.504 | HD Request # 59 | Completion time: 0s. 2025-02-05 22:19:44.504 | HD Request # 59 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 59 2025-02-05 22:19:44.504 | Removing historical data download ID 59. 2025-02-05 22:19:44.504 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 22:19:44.504 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 22:19:44.504 | HD Request # 59 | Enabling Intraday chart updating for symbol. 2025-02-05 22:19:44.504 | 2025-02-05 22:19:44.504 | Triggering next historical data download in queue. 2025-02-05 22:19:44.504 | HD Request # 60 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 22:19:44.505 | HD Request # 60 | Download start date-time: 2025-02-05 22:19:40.000000. File last date-time: 2025-02-05 22:19:40.000000 2025-02-05 22:19:44.505 | HD Request # 60 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:19:44.505 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 22:19:44.505 | Socket (5) | New receive buffer size: 0 2025-02-05 22:19:44.505 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 22:19:44.537 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:19:44.537 | Socket (4) | Closed. 2025-02-05 22:19:44.548 | HD Request # 60 | Sending historical data logon request message. 2025-02-05 22:19:44.683 | HD Request # 60 | Requesting Intraday data. Start date-time: 2025-02-05 22:19:40. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 22:19:44.728 | HD Request # 60 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 22:19:40.589000 2025-02-05 22:19:44.768 | Socket (5) | CloseSocket call. 2025-02-05 22:19:44.768 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 22:19:44.768 | Historical data download thread signaled to stop. 2025-02-05 22:19:44.768 | HD Request # 60 | Timestamp of first Intraday data file record written: 2025-02-05 22:19:40.589000. 2025-02-05 22:19:44.768 | HD Request # 60 | Received 18 Intraday data records from 2025-02-05 22:19:40.589000 to 2025-02-05 22:19:45.338001 (4.7 seconds. Delay: -0.6 seconds) and wrote 18 records for MGCJ5.COMEX 2025-02-05 22:19:44.775 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:19:45.338001 2025-02-05 22:19:44.775 | HD Request # 60 | Completion time: 0s. 2025-02-05 22:19:44.775 | HD Request # 60 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 60 2025-02-05 22:19:44.775 | Removing historical data download ID 60. 2025-02-05 22:19:44.775 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 22:19:44.775 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 22:19:44.775 | HD Request # 60 | Enabling Intraday chart updating for symbol. 2025-02-05 22:19:44.775 | 2025-02-05 22:19:44.775 | Triggering next historical data download in queue. 2025-02-05 22:19:44.775 | HD Request # 61 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 22:19:44.776 | HD Request # 61 | Download start date-time: 2025-02-05 22:18:35.000000. File last date-time: 2025-02-05 22:18:35.000001 2025-02-05 22:19:44.776 | HD Request # 61 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:19:44.776 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:19:44.776 | Socket (4) | New receive buffer size: 0 2025-02-05 22:19:44.776 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:19:44.808 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 22:19:44.808 | Socket (5) | Closed. 2025-02-05 22:19:44.819 | HD Request # 61 | Sending historical data logon request message. 2025-02-05 22:19:44.948 | HD Request # 61 | Requesting Intraday data. Start date-time: 2025-02-05 22:18:35. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 22:19:44.993 | HD Request # 61 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 22:18:35.946000 2025-02-05 22:19:44.993 | Socket (4) | CloseSocket call. 2025-02-05 22:19:44.993 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:19:44.993 | Historical data download thread signaled to stop. 2025-02-05 22:19:44.993 | HD Request # 61 | Timestamp of first Intraday data file record written: 2025-02-05 22:18:35.946000. 2025-02-05 22:19:44.993 | HD Request # 61 | Received 2 Intraday data records from 2025-02-05 22:18:35.946000 to 2025-02-05 22:18:35.946001 (0.0 seconds. Delay: 69.0 seconds) and wrote 2 records for MYMH5.CBOT 2025-02-05 22:19:45.002 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:18:35.946001 2025-02-05 22:19:45.002 | HD Request # 61 | Completion time: 1s. 2025-02-05 22:19:45.002 | HD Request # 61 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 61 2025-02-05 22:19:45.002 | Removing historical data download ID 61. 2025-02-05 22:19:45.002 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 22:19:45.002 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 22:19:45.002 | HD Request # 61 | Enabling Intraday chart updating for symbol. 2025-02-05 22:19:45.002 | 2025-02-05 22:19:45.002 | No download requests in the queue to start downloads for. 2025-02-05 22:19:45.034 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:19:45.034 | Socket (4) | Closed. 2025-02-05 22:20:04.118 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 22:20:14.200 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 22:20:29.326 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 22:21:15.968 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 22:21:15.968 | DTC Client socket (2) | CloseSocket call. 2025-02-05 22:21:15.968 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 22:21:15.968 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 22:21:15.968 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 22:21:15.968 | DTC Client socket (2) | Closed. 2025-02-05 22:21:15.968 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 22:21:15.968 | DTC Client socket (0) | CloseSocket call. 2025-02-05 22:21:15.968 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 22:21:15.968 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 22:21:17.958 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 22:21:17.958 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 22:21:17.959 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:17.959 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 22:21:17.959 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:18.027 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 22:21:18.027 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 22:21:18.027 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 22:21:18.027 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 22:21:18.173 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 22:21:18.173 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 22:21:18.173 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 22:21:18.173 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 22:21:18.173 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 22:21:18.173 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 22:21:18.173 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 22:21:18.174 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 22:21:18.174 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 22:21:18.174 | Triggering next historical data download in queue. 2025-02-05 22:21:18.174 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 22:21:18.174 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 22:21:18.174 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 22:21:18.174 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 22:21:18.174 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 22:21:18.174 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 22:21:18.174 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 22:21:18.174 | HD Request # 62 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 22:21:18.175 | HD Request # 62 | Download start date-time: 2025-02-05 22:21:07.000000. File last date-time: 2025-02-05 22:21:07.000000 2025-02-05 22:21:18.175 | HD Request # 62 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:21:18.175 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:18.175 | Socket (4) | New receive buffer size: 0 2025-02-05 22:21:18.175 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:18.214 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 22:21:18.214 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 22:21:18.215 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 22:21:18.219 | HD Request # 62 | Sending historical data logon request message. 2025-02-05 22:21:18.220 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 22:21:18.220 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 22:21:18.220 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 22:21:18.344 | HD Request # 62 | Requesting Intraday data. Start date-time: 2025-02-05 22:21:07. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 22:21:18.392 | HD Request # 62 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 22:21:07.335000 2025-02-05 22:21:18.392 | Socket (4) | CloseSocket call. 2025-02-05 22:21:18.392 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:21:18.392 | Historical data download thread signaled to stop. 2025-02-05 22:21:18.392 | HD Request # 62 | Timestamp of first Intraday data file record written: 2025-02-05 22:21:07.335000. 2025-02-05 22:21:18.393 | HD Request # 62 | Received 1 Intraday data record from 2025-02-05 22:21:07.335000 to 2025-02-05 22:21:07.335000 (0.0 seconds. Delay: 11.1 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-05 22:21:18.407 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:21:07.335000 2025-02-05 22:21:18.407 | HD Request # 62 | Completion time: 0s. 2025-02-05 22:21:18.407 | HD Request # 62 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 62 2025-02-05 22:21:18.407 | Removing historical data download ID 62. 2025-02-05 22:21:18.407 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 22:21:18.407 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 22:21:18.407 | HD Request # 62 | Enabling Intraday chart updating for symbol. 2025-02-05 22:21:18.407 | 2025-02-05 22:21:18.407 | Triggering next historical data download in queue. 2025-02-05 22:21:18.407 | HD Request # 63 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 22:21:18.407 | HD Request # 63 | Download start date-time: 2025-02-05 22:21:11.000000. File last date-time: 2025-02-05 22:21:11.000004 2025-02-05 22:21:18.408 | HD Request # 63 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:21:18.408 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:18.408 | Socket (5) | New receive buffer size: 0 2025-02-05 22:21:18.408 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:18.435 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:21:18.435 | Socket (4) | Closed. 2025-02-05 22:21:18.450 | HD Request # 63 | Sending historical data logon request message. 2025-02-05 22:21:18.587 | HD Request # 63 | Requesting Intraday data. Start date-time: 2025-02-05 22:21:11. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 22:21:18.631 | HD Request # 63 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 22:21:11.171000 2025-02-05 22:21:18.631 | Socket (5) | CloseSocket call. 2025-02-05 22:21:18.631 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 22:21:18.631 | Historical data download thread signaled to stop. 2025-02-05 22:21:18.631 | HD Request # 63 | Timestamp of first Intraday data file record written: 2025-02-05 22:21:11.171000. 2025-02-05 22:21:18.631 | HD Request # 63 | Received 7 Intraday data records from 2025-02-05 22:21:11.171000 to 2025-02-05 22:21:19.082001 (7.9 seconds. Delay: -0.5 seconds) and wrote 7 records for MGCJ5.COMEX 2025-02-05 22:21:18.641 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:21:19.082001 2025-02-05 22:21:18.641 | HD Request # 63 | Completion time: 0s. 2025-02-05 22:21:18.641 | HD Request # 63 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 63 2025-02-05 22:21:18.641 | Removing historical data download ID 63. 2025-02-05 22:21:18.641 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 22:21:18.641 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 22:21:18.641 | HD Request # 63 | Enabling Intraday chart updating for symbol. 2025-02-05 22:21:18.641 | 2025-02-05 22:21:18.641 | Triggering next historical data download in queue. 2025-02-05 22:21:18.641 | HD Request # 64 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 22:21:18.641 | HD Request # 64 | Download start date-time: 2025-02-05 22:20:45.000000. File last date-time: 2025-02-05 22:20:45.000000 2025-02-05 22:21:18.641 | HD Request # 64 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:21:18.641 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:18.641 | Socket (4) | New receive buffer size: 0 2025-02-05 22:21:18.641 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:18.673 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 22:21:18.673 | Socket (5) | Closed. 2025-02-05 22:21:18.690 | HD Request # 64 | Sending historical data logon request message. 2025-02-05 22:21:18.824 | HD Request # 64 | Requesting Intraday data. Start date-time: 2025-02-05 22:20:45. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 22:21:18.869 | HD Request # 64 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 22:20:45.222000 2025-02-05 22:21:18.869 | Socket (4) | CloseSocket call. 2025-02-05 22:21:18.870 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:21:18.870 | Historical data download thread signaled to stop. 2025-02-05 22:21:18.870 | HD Request # 64 | Timestamp of first Intraday data file record written: 2025-02-05 22:20:45.222000. 2025-02-05 22:21:18.870 | HD Request # 64 | Received 1 Intraday data record from 2025-02-05 22:20:45.222000 to 2025-02-05 22:20:45.222000 (0.0 seconds. Delay: 33.6 seconds) and wrote 1 record for MYMH5.CBOT 2025-02-05 22:21:18.882 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:20:45.222000 2025-02-05 22:21:18.882 | HD Request # 64 | Completion time: 0s. 2025-02-05 22:21:18.882 | HD Request # 64 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 64 2025-02-05 22:21:18.882 | Removing historical data download ID 64. 2025-02-05 22:21:18.882 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 22:21:18.882 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 22:21:18.882 | HD Request # 64 | Enabling Intraday chart updating for symbol. 2025-02-05 22:21:18.882 | 2025-02-05 22:21:18.882 | No download requests in the queue to start downloads for. 2025-02-05 22:21:18.911 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:21:18.911 | Socket (4) | Closed. 2025-02-05 22:21:21.351 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 22:21:21.352 | DTC Client socket (2) | CloseSocket call. 2025-02-05 22:21:21.352 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 22:21:21.352 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 22:21:21.352 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 22:21:21.352 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 22:21:21.352 | DTC Client socket (2) | Closed. 2025-02-05 22:21:21.352 | DTC Client socket (0) | CloseSocket call. 2025-02-05 22:21:21.352 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 22:21:21.352 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 22:21:23.354 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 22:21:23.354 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 22:21:23.354 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:23.354 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 22:21:23.354 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:23.397 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 22:21:23.397 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 22:21:23.397 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 22:21:23.397 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 22:21:23.523 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 22:21:23.523 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 22:21:23.523 | Triggering next historical data download in queue. 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 22:21:23.523 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 22:21:23.523 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 22:21:23.523 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 22:21:23.523 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 22:21:23.523 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 22:21:23.523 | HD Request # 65 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 22:21:23.524 | HD Request # 65 | Download start date-time: 2025-02-05 22:21:07.000000. File last date-time: 2025-02-05 22:21:07.335000 2025-02-05 22:21:23.524 | HD Request # 65 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:21:23.524 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:23.524 | Socket (4) | New receive buffer size: 0 2025-02-05 22:21:23.524 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:23.564 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 22:21:23.564 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 22:21:23.566 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 22:21:23.566 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 22:21:23.566 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 22:21:23.567 | HD Request # 65 | Sending historical data logon request message. 2025-02-05 22:21:23.606 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 22:21:23.691 | HD Request # 65 | Requesting Intraday data. Start date-time: 2025-02-05 22:21:07. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 22:21:23.736 | HD Request # 65 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 22:21:07.335000 2025-02-05 22:21:23.736 | Socket (4) | CloseSocket call. 2025-02-05 22:21:23.736 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:21:23.736 | Historical data download thread signaled to stop. 2025-02-05 22:21:23.736 | HD Request # 65 | Received 1 Intraday data record from 2025-02-05 22:21:07.335000 to 2025-02-05 22:21:07.335000 (0.0 seconds. Delay: 16.4 seconds) and wrote 0 records for MCLH5.NYMEX 2025-02-05 22:21:23.737 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:21:07.335000 2025-02-05 22:21:23.737 | HD Request # 65 | Completion time: 0s. 2025-02-05 22:21:23.737 | HD Request # 65 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 65 2025-02-05 22:21:23.737 | Removing historical data download ID 65. 2025-02-05 22:21:23.737 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 22:21:23.737 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 22:21:23.737 | HD Request # 65 | Enabling Intraday chart updating for symbol. 2025-02-05 22:21:23.737 | 2025-02-05 22:21:23.737 | Triggering next historical data download in queue. 2025-02-05 22:21:23.737 | HD Request # 66 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 22:21:23.737 | HD Request # 66 | Download start date-time: 2025-02-05 22:21:19.000000. File last date-time: 2025-02-05 22:21:19.082001 2025-02-05 22:21:23.737 | HD Request # 66 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:21:23.738 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:23.738 | Socket (5) | New receive buffer size: 0 2025-02-05 22:21:23.738 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:23.782 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:21:23.782 | Socket (4) | Closed. 2025-02-05 22:21:23.785 | HD Request # 66 | Sending historical data logon request message. 2025-02-05 22:21:23.911 | HD Request # 66 | Requesting Intraday data. Start date-time: 2025-02-05 22:21:19. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 22:21:23.961 | HD Request # 66 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 22:21:19.082000 2025-02-05 22:21:23.963 | Socket (5) | CloseSocket call. 2025-02-05 22:21:23.963 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 22:21:23.963 | Historical data download thread signaled to stop. 2025-02-05 22:21:23.963 | HD Request # 66 | Timestamp of first Intraday data file record written: 2025-02-05 22:21:21.451000. 2025-02-05 22:21:23.964 | HD Request # 66 | Received 6 Intraday data records from 2025-02-05 22:21:19.082000 to 2025-02-05 22:21:22.443000 (3.4 seconds. Delay: 1.5 seconds) and wrote 4 records for MGCJ5.COMEX 2025-02-05 22:21:23.971 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:21:22.443000 2025-02-05 22:21:23.971 | HD Request # 66 | Completion time: 0s. 2025-02-05 22:21:23.971 | HD Request # 66 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 66 2025-02-05 22:21:23.971 | Removing historical data download ID 66. 2025-02-05 22:21:23.971 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 22:21:23.971 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 22:21:23.971 | HD Request # 66 | Enabling Intraday chart updating for symbol. 2025-02-05 22:21:23.971 | 2025-02-05 22:21:23.971 | Triggering next historical data download in queue. 2025-02-05 22:21:23.971 | HD Request # 67 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 22:21:23.972 | HD Request # 67 | Download start date-time: 2025-02-05 22:20:45.000000. File last date-time: 2025-02-05 22:20:45.222000 2025-02-05 22:21:23.972 | HD Request # 67 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:21:23.972 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:21:23.972 | Socket (4) | New receive buffer size: 0 2025-02-05 22:21:23.972 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:21:24.005 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 22:21:24.005 | Socket (5) | Closed. 2025-02-05 22:21:24.019 | HD Request # 67 | Sending historical data logon request message. 2025-02-05 22:21:24.148 | HD Request # 67 | Requesting Intraday data. Start date-time: 2025-02-05 22:20:45. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 22:21:24.196 | HD Request # 67 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 22:20:45.222000 2025-02-05 22:21:24.196 | Socket (4) | CloseSocket call. 2025-02-05 22:21:24.196 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:21:24.197 | Historical data download thread signaled to stop. 2025-02-05 22:21:24.197 | HD Request # 67 | Received 1 Intraday data record from 2025-02-05 22:20:45.222000 to 2025-02-05 22:20:45.222000 (0.0 seconds. Delay: 39.0 seconds) and wrote 0 records for MYMH5.CBOT 2025-02-05 22:21:24.197 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:20:45.222000 2025-02-05 22:21:24.197 | HD Request # 67 | Completion time: 1s. 2025-02-05 22:21:24.197 | HD Request # 67 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 67 2025-02-05 22:21:24.197 | Removing historical data download ID 67. 2025-02-05 22:21:24.197 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 22:21:24.197 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 22:21:24.197 | HD Request # 67 | Enabling Intraday chart updating for symbol. 2025-02-05 22:21:24.197 | 2025-02-05 22:21:24.197 | No download requests in the queue to start downloads for. 2025-02-05 22:21:24.237 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:21:24.237 | Socket (4) | Closed. 2025-02-05 22:21:24.782 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 22:21:34.878 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 22:21:34.878 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 22:49:38.364 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 22:55:33.520 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 22:55:33.520 | DTC Client socket (2) | CloseSocket call. 2025-02-05 22:55:33.520 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 22:55:33.520 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 22:55:33.520 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 22:55:33.520 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 22:55:33.520 | DTC Client socket (2) | Closed. 2025-02-05 22:55:33.520 | DTC Client socket (0) | CloseSocket call. 2025-02-05 22:55:33.520 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 22:55:33.521 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 22:55:35.529 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 22:55:35.529 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 22:55:35.595 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 22:55:35.595 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 22:55:35.595 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 22:55:35.649 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 22:55:35.649 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 22:55:35.649 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 22:55:35.649 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 22:55:35.777 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 22:55:35.777 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 22:55:35.777 | Triggering next historical data download in queue. 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 22:55:35.777 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 22:55:35.777 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 22:55:35.777 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 22:55:35.777 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 22:55:35.777 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 22:55:35.777 | HD Request # 68 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 22:55:35.777 | HD Request # 68 | Download start date-time: 2025-02-05 22:55:14.000000. File last date-time: 2025-02-05 22:55:14.000000 2025-02-05 22:55:35.777 | HD Request # 68 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:55:35.778 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:55:35.778 | Socket (4) | New receive buffer size: 0 2025-02-05 22:55:35.778 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:55:35.818 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 22:55:35.818 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 22:55:35.818 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 22:55:35.820 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 22:55:35.820 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 22:55:35.820 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 22:55:35.821 | HD Request # 68 | Sending historical data logon request message. 2025-02-05 22:55:35.947 | HD Request # 68 | Requesting Intraday data. Start date-time: 2025-02-05 22:55:14. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 22:55:35.993 | HD Request # 68 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 22:55:14.720000 2025-02-05 22:55:35.993 | Socket (4) | CloseSocket call. 2025-02-05 22:55:35.993 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:55:35.993 | Historical data download thread signaled to stop. 2025-02-05 22:55:35.993 | HD Request # 68 | Timestamp of first Intraday data file record written: 2025-02-05 22:55:14.720000. 2025-02-05 22:55:35.993 | HD Request # 68 | Received 1 Intraday data record from 2025-02-05 22:55:14.720000 to 2025-02-05 22:55:14.720000 (0.0 seconds. Delay: 21.3 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-05 22:55:36.002 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:55:14.720000 2025-02-05 22:55:36.002 | HD Request # 68 | Completion time: 1s. 2025-02-05 22:55:36.002 | HD Request # 68 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 68 2025-02-05 22:55:36.002 | Removing historical data download ID 68. 2025-02-05 22:55:36.002 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 22:55:36.002 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 22:55:36.002 | HD Request # 68 | Enabling Intraday chart updating for symbol. 2025-02-05 22:55:36.002 | 2025-02-05 22:55:36.002 | Triggering next historical data download in queue. 2025-02-05 22:55:36.002 | HD Request # 69 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 22:55:36.002 | HD Request # 69 | Download start date-time: 2025-02-05 22:55:01.000000. File last date-time: 2025-02-05 22:55:01.000004 2025-02-05 22:55:36.002 | HD Request # 69 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:55:36.003 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 22:55:36.003 | Socket (5) | New receive buffer size: 0 2025-02-05 22:55:36.003 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 22:55:36.033 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:55:36.033 | Socket (4) | Closed. 2025-02-05 22:55:36.045 | HD Request # 69 | Sending historical data logon request message. 2025-02-05 22:55:36.172 | HD Request # 69 | Requesting Intraday data. Start date-time: 2025-02-05 22:55:01. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 22:55:36.217 | HD Request # 69 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 22:55:01.055000 2025-02-05 22:55:36.217 | Socket (5) | CloseSocket call. 2025-02-05 22:55:36.217 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 22:55:36.218 | Historical data download thread signaled to stop. 2025-02-05 22:55:36.219 | HD Request # 69 | Timestamp of first Intraday data file record written: 2025-02-05 22:55:01.055000. 2025-02-05 22:55:36.219 | HD Request # 69 | Received 5 Intraday data records from 2025-02-05 22:55:01.055000 to 2025-02-05 22:55:01.055004 (0.0 seconds. Delay: 35.2 seconds) and wrote 5 records for MGCJ5.COMEX 2025-02-05 22:55:36.226 | HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:55:01.055004 2025-02-05 22:55:36.226 | HD Request # 69 | Completion time: 0s. 2025-02-05 22:55:36.226 | HD Request # 69 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 69 2025-02-05 22:55:36.226 | Removing historical data download ID 69. 2025-02-05 22:55:36.226 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 22:55:36.226 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 22:55:36.226 | HD Request # 69 | Enabling Intraday chart updating for symbol. 2025-02-05 22:55:36.226 | 2025-02-05 22:55:36.226 | Triggering next historical data download in queue. 2025-02-05 22:55:36.226 | HD Request # 70 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 22:55:36.226 | HD Request # 70 | Download start date-time: 2025-02-05 22:55:27.000000. File last date-time: 2025-02-05 22:55:27.000000 2025-02-05 22:55:36.227 | HD Request # 70 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 22:55:36.227 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 22:55:36.227 | Socket (4) | New receive buffer size: 0 2025-02-05 22:55:36.227 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 22:55:36.257 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 22:55:36.257 | Socket (5) | Closed. 2025-02-05 22:55:36.269 | HD Request # 70 | Sending historical data logon request message. 2025-02-05 22:55:36.404 | HD Request # 70 | Requesting Intraday data. Start date-time: 2025-02-05 22:55:27. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 22:55:36.449 | HD Request # 70 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 22:55:27.617000 2025-02-05 22:55:36.449 | Socket (4) | CloseSocket call. 2025-02-05 22:55:36.449 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 22:55:36.449 | Historical data download thread signaled to stop. 2025-02-05 22:55:36.449 | HD Request # 70 | Timestamp of first Intraday data file record written: 2025-02-05 22:55:27.617000. 2025-02-05 22:55:36.449 | HD Request # 70 | Received 1 Intraday data record from 2025-02-05 22:55:27.617000 to 2025-02-05 22:55:27.617000 (0.0 seconds. Delay: 8.8 seconds) and wrote 1 record for MYMH5.CBOT 2025-02-05 22:55:36.457 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2025-02-06 03:55:27.617000 2025-02-05 22:55:36.457 | HD Request # 70 | Completion time: 0s. 2025-02-05 22:55:36.457 | HD Request # 70 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 70 2025-02-05 22:55:36.457 | Removing historical data download ID 70. 2025-02-05 22:55:36.457 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 22:55:36.457 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 22:55:36.457 | HD Request # 70 | Enabling Intraday chart updating for symbol. 2025-02-05 22:55:36.457 | 2025-02-05 22:55:36.457 | No download requests in the queue to start downloads for. 2025-02-05 22:55:36.489 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 22:55:36.489 | Socket (4) | Closed. 2025-02-05 22:55:38.952 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 22:55:49.050 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 22:56:14.283 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 23:03:00.265 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:03:00.265 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:03:00.265 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 23:03:00.265 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 23:03:00.265 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:03:00.265 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:03:00.265 | DTC Client socket (2) | Closed. 2025-02-05 23:03:00.265 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:03:00.265 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:03:00.265 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:03:02.255 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:03:02.255 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:03:02.301 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:03:02.301 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:03:02.301 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:03:02.347 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:03:02.347 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:03:02.347 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:03:02.347 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:03:02.473 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:03:02.473 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:03:02.473 | Triggering next historical data download in queue. 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:03:02.473 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:03:02.473 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:03:02.473 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:03:02.473 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:03:02.473 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:03:02.473 | HD Request # 71 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:03:02.474 | HD Request # 71 | Download start date-time: 2025-02-05 23:02:00.000000. File last date-time: 2025-02-05 23:02:00.000000 2025-02-05 23:03:02.474 | HD Request # 71 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:03:02.474 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:03:02.474 | Socket (4) | New receive buffer size: 0 2025-02-05 23:03:02.474 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:03:02.514 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:03:02.514 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:03:02.514 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:03:02.516 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:03:02.518 | HD Request # 71 | Sending historical data logon request message. 2025-02-05 23:03:02.519 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:03:02.519 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:03:02.665 | HD Request # 71 | Requesting Intraday data. Start date-time: 2025-02-05 23:02:00. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:03:02.711 | HD Request # 71 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:02:00.837000 2025-02-05 23:03:02.711 | Socket (4) | CloseSocket call. 2025-02-05 23:03:02.711 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:03:02.711 | Historical data download thread signaled to stop. 2025-02-05 23:03:02.711 | HD Request # 71 | Timestamp of first Intraday data file record written: 2025-02-05 23:02:00.837000. 2025-02-05 23:03:02.711 | HD Request # 71 | Received 1 Intraday data record from 2025-02-05 23:02:00.837000 to 2025-02-05 23:02:00.837000 (0.0 seconds. Delay: 61.9 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-05 23:03:02.720 | HD Request # 71 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:02:00.837000 2025-02-05 23:03:02.721 | HD Request # 71 | Completion time: 0s. 2025-02-05 23:03:02.721 | HD Request # 71 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 71 2025-02-05 23:03:02.721 | Removing historical data download ID 71. 2025-02-05 23:03:02.721 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:03:02.721 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:03:02.721 | HD Request # 71 | Enabling Intraday chart updating for symbol. 2025-02-05 23:03:02.721 | 2025-02-05 23:03:02.721 | Triggering next historical data download in queue. 2025-02-05 23:03:02.721 | HD Request # 72 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:03:02.721 | HD Request # 72 | Download start date-time: 2025-02-05 23:02:55.000000. File last date-time: 2025-02-05 23:02:55.000003 2025-02-05 23:03:02.721 | HD Request # 72 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:03:02.721 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:03:02.722 | Socket (5) | New receive buffer size: 0 2025-02-05 23:03:02.722 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:03:02.757 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:03:02.757 | Socket (4) | Closed. 2025-02-05 23:03:02.764 | HD Request # 72 | Sending historical data logon request message. 2025-02-05 23:03:02.892 | HD Request # 72 | Requesting Intraday data. Start date-time: 2025-02-05 23:02:55. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:03:02.937 | HD Request # 72 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:02:55.735000 2025-02-05 23:03:02.937 | Socket (5) | CloseSocket call. 2025-02-05 23:03:02.938 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:03:02.938 | Historical data download thread signaled to stop. 2025-02-05 23:03:02.938 | HD Request # 72 | Timestamp of first Intraday data file record written: 2025-02-05 23:02:55.735000. 2025-02-05 23:03:02.938 | HD Request # 72 | Received 7 Intraday data records from 2025-02-05 23:02:55.735000 to 2025-02-05 23:03:03.551000 (7.8 seconds. Delay: -0.6 seconds) and wrote 7 records for MGCJ5.COMEX 2025-02-05 23:03:02.946 | HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:03:03.551000 2025-02-05 23:03:02.946 | HD Request # 72 | Completion time: 0s. 2025-02-05 23:03:02.946 | HD Request # 72 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 72 2025-02-05 23:03:02.946 | Removing historical data download ID 72. 2025-02-05 23:03:02.947 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:03:02.947 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:03:02.947 | HD Request # 72 | Enabling Intraday chart updating for symbol. 2025-02-05 23:03:02.947 | 2025-02-05 23:03:02.947 | Triggering next historical data download in queue. 2025-02-05 23:03:02.947 | HD Request # 73 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:03:02.947 | HD Request # 73 | Download start date-time: 2025-02-05 23:02:50.000000. File last date-time: 2025-02-05 23:02:50.000000 2025-02-05 23:03:02.947 | HD Request # 73 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:03:02.947 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:03:02.947 | Socket (4) | New receive buffer size: 0 2025-02-05 23:03:02.947 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:03:02.977 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:03:02.977 | Socket (5) | Closed. 2025-02-05 23:03:02.990 | HD Request # 73 | Sending historical data logon request message. 2025-02-05 23:03:03.116 | HD Request # 73 | Requesting Intraday data. Start date-time: 2025-02-05 23:02:50. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:03:03.167 | HD Request # 73 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:02:50.090000 2025-02-05 23:03:03.167 | Socket (4) | CloseSocket call. 2025-02-05 23:03:03.167 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:03:03.167 | Historical data download thread signaled to stop. 2025-02-05 23:03:03.167 | HD Request # 73 | Timestamp of first Intraday data file record written: 2025-02-05 23:02:50.090000. 2025-02-05 23:03:03.167 | HD Request # 73 | Received 1 Intraday data record from 2025-02-05 23:02:50.090000 to 2025-02-05 23:02:50.090000 (0.0 seconds. Delay: 13.1 seconds) and wrote 1 record for MYMH5.CBOT 2025-02-05 23:03:03.176 | HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:02:50.090000 2025-02-05 23:03:03.176 | HD Request # 73 | Completion time: 1s. 2025-02-05 23:03:03.176 | HD Request # 73 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 73 2025-02-05 23:03:03.176 | Removing historical data download ID 73. 2025-02-05 23:03:03.176 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:03:03.176 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:03:03.176 | HD Request # 73 | Enabling Intraday chart updating for symbol. 2025-02-05 23:03:03.176 | 2025-02-05 23:03:03.176 | No download requests in the queue to start downloads for. 2025-02-05 23:03:03.207 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:03:03.207 | Socket (4) | Closed. 2025-02-05 23:03:13.181 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 23:03:28.330 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 23:03:53.545 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 23:06:57.595 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:06:57.595 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:06:57.595 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 23:06:57.595 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 23:06:57.595 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:06:57.595 | DTC Client socket (2) | Closed. 2025-02-05 23:06:57.595 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:06:57.596 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:06:57.596 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:06:57.596 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:06:59.599 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:06:59.599 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:06:59.600 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:06:59.600 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:06:59.600 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:06:59.644 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:06:59.644 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:06:59.644 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:06:59.644 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:06:59.774 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:06:59.774 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:06:59.774 | Triggering next historical data download in queue. 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:06:59.774 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:06:59.774 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:06:59.774 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:06:59.774 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:06:59.774 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:06:59.774 | HD Request # 74 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:06:59.775 | HD Request # 74 | Download start date-time: 2025-02-05 23:06:39.000000. File last date-time: 2025-02-05 23:06:39.000001 2025-02-05 23:06:59.775 | HD Request # 74 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:06:59.775 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:06:59.775 | Socket (4) | New receive buffer size: 0 2025-02-05 23:06:59.775 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:06:59.815 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:06:59.816 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:06:59.816 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:06:59.819 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:06:59.819 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:06:59.819 | HD Request # 74 | Sending historical data logon request message. 2025-02-05 23:06:59.819 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:06:59.944 | HD Request # 74 | Requesting Intraday data. Start date-time: 2025-02-05 23:06:39. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:06:59.989 | HD Request # 74 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:06:39.050000 2025-02-05 23:06:59.990 | Socket (4) | CloseSocket call. 2025-02-05 23:06:59.990 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:06:59.990 | Historical data download thread signaled to stop. 2025-02-05 23:06:59.990 | HD Request # 74 | Timestamp of first Intraday data file record written: 2025-02-05 23:06:39.050000. 2025-02-05 23:06:59.990 | HD Request # 74 | Received 7 Intraday data records from 2025-02-05 23:06:39.050000 to 2025-02-05 23:07:00.803001 (21.8 seconds. Delay: -0.8 seconds) and wrote 7 records for MCLH5.NYMEX 2025-02-05 23:06:59.999 | HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:07:00.803001 2025-02-05 23:06:59.999 | HD Request # 74 | Completion time: 0s. 2025-02-05 23:06:59.999 | HD Request # 74 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 74 2025-02-05 23:06:59.999 | Removing historical data download ID 74. 2025-02-05 23:06:59.999 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:06:59.999 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:06:59.999 | HD Request # 74 | Enabling Intraday chart updating for symbol. 2025-02-05 23:06:59.999 | 2025-02-05 23:06:59.999 | Triggering next historical data download in queue. 2025-02-05 23:06:59.999 | HD Request # 75 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:06:59.999 | HD Request # 75 | Download start date-time: 2025-02-05 23:06:54.000000. File last date-time: 2025-02-05 23:06:54.000001 2025-02-05 23:06:59.999 | HD Request # 75 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:06:59.999 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:06:59.999 | Socket (5) | New receive buffer size: 0 2025-02-05 23:06:59.999 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:07:00.030 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:07:00.030 | Socket (4) | Closed. 2025-02-05 23:07:00.041 | HD Request # 75 | Sending historical data logon request message. 2025-02-05 23:07:00.165 | HD Request # 75 | Requesting Intraday data. Start date-time: 2025-02-05 23:06:54. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:07:00.210 | HD Request # 75 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:06:54.601000 2025-02-05 23:07:00.211 | Socket (5) | CloseSocket call. 2025-02-05 23:07:00.211 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:07:00.211 | Historical data download thread signaled to stop. 2025-02-05 23:07:00.211 | HD Request # 75 | Timestamp of first Intraday data file record written: 2025-02-05 23:06:54.601000. 2025-02-05 23:07:00.211 | HD Request # 75 | Received 2 Intraday data records from 2025-02-05 23:06:54.601000 to 2025-02-05 23:06:54.601001 (0.0 seconds. Delay: 5.6 seconds) and wrote 2 records for MGCJ5.COMEX 2025-02-05 23:07:00.219 | HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:06:54.601001 2025-02-05 23:07:00.219 | HD Request # 75 | Completion time: 1s. 2025-02-05 23:07:00.219 | HD Request # 75 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 75 2025-02-05 23:07:00.219 | Removing historical data download ID 75. 2025-02-05 23:07:00.219 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:07:00.219 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:07:00.219 | HD Request # 75 | Enabling Intraday chart updating for symbol. 2025-02-05 23:07:00.219 | 2025-02-05 23:07:00.219 | Triggering next historical data download in queue. 2025-02-05 23:07:00.219 | HD Request # 76 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:07:00.219 | HD Request # 76 | Download start date-time: 2025-02-05 23:06:52.000000. File last date-time: 2025-02-05 23:06:52.000000 2025-02-05 23:07:00.219 | HD Request # 76 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:07:00.219 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:07:00.220 | Socket (4) | New receive buffer size: 0 2025-02-05 23:07:00.220 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:07:00.251 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:07:00.251 | Socket (5) | Closed. 2025-02-05 23:07:00.263 | HD Request # 76 | Sending historical data logon request message. 2025-02-05 23:07:00.388 | HD Request # 76 | Requesting Intraday data. Start date-time: 2025-02-05 23:06:52. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:07:00.433 | HD Request # 76 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:06:52.880000 2025-02-05 23:07:00.433 | Socket (4) | CloseSocket call. 2025-02-05 23:07:00.433 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:07:00.433 | Historical data download thread signaled to stop. 2025-02-05 23:07:00.433 | HD Request # 76 | Timestamp of first Intraday data file record written: 2025-02-05 23:06:52.880000. 2025-02-05 23:07:00.434 | HD Request # 76 | Received 5 Intraday data records from 2025-02-05 23:06:52.880000 to 2025-02-05 23:06:56.988000 (4.1 seconds. Delay: 3.4 seconds) and wrote 5 records for MYMH5.CBOT 2025-02-05 23:07:00.442 | HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:06:56.988000 2025-02-05 23:07:00.442 | HD Request # 76 | Completion time: 0s. 2025-02-05 23:07:00.442 | HD Request # 76 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 76 2025-02-05 23:07:00.442 | Removing historical data download ID 76. 2025-02-05 23:07:00.442 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:07:00.442 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:07:00.442 | HD Request # 76 | Enabling Intraday chart updating for symbol. 2025-02-05 23:07:00.442 | 2025-02-05 23:07:00.442 | No download requests in the queue to start downloads for. 2025-02-05 23:07:00.473 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:07:00.473 | Socket (4) | Closed. 2025-02-05 23:07:05.416 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 23:07:10.448 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 23:07:35.694 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 23:08:59.024 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:08:59.024 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:08:59.024 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 23:08:59.024 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 23:08:59.024 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:08:59.024 | DTC Client socket (2) | Closed. 2025-02-05 23:08:59.024 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:08:59.024 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:08:59.024 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:08:59.024 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:09:01.017 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:09:01.017 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:09:01.056 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:09:01.056 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:09:01.056 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:09:01.103 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:09:01.103 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:09:01.103 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:09:01.103 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:09:01.231 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:09:01.231 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:09:01.231 | Triggering next historical data download in queue. 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:09:01.231 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:09:01.231 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:09:01.231 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:09:01.231 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:09:01.231 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:09:01.231 | HD Request # 77 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:09:01.232 | HD Request # 77 | Download start date-time: 2025-02-05 23:08:34.000000. File last date-time: 2025-02-05 23:08:34.000000 2025-02-05 23:09:01.232 | HD Request # 77 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:09:01.232 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:09:01.232 | Socket (4) | New receive buffer size: 0 2025-02-05 23:09:01.232 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:09:01.272 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:09:01.272 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:09:01.272 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:09:01.275 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:09:01.276 | HD Request # 77 | Sending historical data logon request message. 2025-02-05 23:09:01.276 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:09:01.276 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:09:01.402 | HD Request # 77 | Requesting Intraday data. Start date-time: 2025-02-05 23:08:34. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:09:01.446 | HD Request # 77 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:08:34.336000 2025-02-05 23:09:01.447 | Socket (4) | CloseSocket call. 2025-02-05 23:09:01.447 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:09:01.447 | Historical data download thread signaled to stop. 2025-02-05 23:09:01.447 | HD Request # 77 | Timestamp of first Intraday data file record written: 2025-02-05 23:08:34.336000. 2025-02-05 23:09:01.447 | HD Request # 77 | Received 2 Intraday data records from 2025-02-05 23:08:34.336000 to 2025-02-05 23:09:01.679000 (27.3 seconds. Delay: -0.2 seconds) and wrote 2 records for MCLH5.NYMEX 2025-02-05 23:09:01.455 | HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:09:01.679000 2025-02-05 23:09:01.455 | HD Request # 77 | Completion time: 0s. 2025-02-05 23:09:01.455 | HD Request # 77 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 77 2025-02-05 23:09:01.455 | Removing historical data download ID 77. 2025-02-05 23:09:01.455 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:09:01.455 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:09:01.455 | HD Request # 77 | Enabling Intraday chart updating for symbol. 2025-02-05 23:09:01.455 | 2025-02-05 23:09:01.455 | Triggering next historical data download in queue. 2025-02-05 23:09:01.456 | HD Request # 78 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:09:01.456 | HD Request # 78 | Download start date-time: 2025-02-05 23:08:51.000000. File last date-time: 2025-02-05 23:08:51.000004 2025-02-05 23:09:01.456 | HD Request # 78 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:09:01.456 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:09:01.456 | Socket (5) | New receive buffer size: 0 2025-02-05 23:09:01.456 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:09:01.495 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:09:01.495 | Socket (4) | Closed. 2025-02-05 23:09:01.502 | HD Request # 78 | Sending historical data logon request message. 2025-02-05 23:09:01.631 | HD Request # 78 | Requesting Intraday data. Start date-time: 2025-02-05 23:08:51. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:09:01.676 | HD Request # 78 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:08:51.386000 2025-02-05 23:09:01.676 | Socket (5) | CloseSocket call. 2025-02-05 23:09:01.676 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:09:01.676 | Historical data download thread signaled to stop. 2025-02-05 23:09:01.676 | HD Request # 78 | Timestamp of first Intraday data file record written: 2025-02-05 23:08:51.386000. 2025-02-05 23:09:01.676 | HD Request # 78 | Received 5 Intraday data records from 2025-02-05 23:08:51.386000 to 2025-02-05 23:08:51.886000 (0.5 seconds. Delay: 9.8 seconds) and wrote 5 records for MGCJ5.COMEX 2025-02-05 23:09:01.685 | HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:08:51.886000 2025-02-05 23:09:01.685 | HD Request # 78 | Completion time: 0s. 2025-02-05 23:09:01.685 | HD Request # 78 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 78 2025-02-05 23:09:01.685 | Removing historical data download ID 78. 2025-02-05 23:09:01.685 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:09:01.685 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:09:01.685 | HD Request # 78 | Enabling Intraday chart updating for symbol. 2025-02-05 23:09:01.685 | 2025-02-05 23:09:01.685 | Triggering next historical data download in queue. 2025-02-05 23:09:01.685 | HD Request # 79 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:09:01.685 | HD Request # 79 | Download start date-time: 2025-02-05 23:08:22.000000. File last date-time: 2025-02-05 23:08:22.000000 2025-02-05 23:09:01.686 | HD Request # 79 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:09:01.686 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:09:01.686 | Socket (4) | New receive buffer size: 0 2025-02-05 23:09:01.686 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:09:01.717 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:09:01.717 | Socket (5) | Closed. 2025-02-05 23:09:01.728 | HD Request # 79 | Sending historical data logon request message. 2025-02-05 23:09:01.855 | HD Request # 79 | Requesting Intraday data. Start date-time: 2025-02-05 23:08:22. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:09:01.899 | HD Request # 79 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:08:22.626000 2025-02-05 23:09:01.899 | Socket (4) | CloseSocket call. 2025-02-05 23:09:01.899 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:09:01.900 | Historical data download thread signaled to stop. 2025-02-05 23:09:01.900 | HD Request # 79 | Timestamp of first Intraday data file record written: 2025-02-05 23:08:22.626000. 2025-02-05 23:09:01.900 | HD Request # 79 | Received 1 Intraday data record from 2025-02-05 23:08:22.626000 to 2025-02-05 23:08:22.626000 (0.0 seconds. Delay: 39.3 seconds) and wrote 1 record for MYMH5.CBOT 2025-02-05 23:09:01.908 | HD Request # 79 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:08:22.626000 2025-02-05 23:09:01.908 | HD Request # 79 | Completion time: 0s. 2025-02-05 23:09:01.908 | HD Request # 79 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 79 2025-02-05 23:09:01.908 | Removing historical data download ID 79. 2025-02-05 23:09:01.908 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:09:01.908 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:09:01.908 | HD Request # 79 | Enabling Intraday chart updating for symbol. 2025-02-05 23:09:01.908 | 2025-02-05 23:09:01.908 | No download requests in the queue to start downloads for. 2025-02-05 23:09:01.939 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:09:01.939 | Socket (4) | Closed. 2025-02-05 23:09:06.510 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 23:09:06.511 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 23:09:36.795 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 23:14:29.753 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:14:29.755 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:14:29.755 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 23:14:29.755 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 23:14:29.755 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:14:29.755 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:14:29.755 | DTC Client socket (2) | Closed. 2025-02-05 23:14:29.755 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:14:29.755 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:14:29.755 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:14:31.753 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:14:31.753 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:14:31.797 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:14:31.797 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:14:31.797 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:14:31.842 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:14:31.842 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:14:31.842 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:14:31.842 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:14:31.969 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:14:31.969 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:14:31.969 | Triggering next historical data download in queue. 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:14:31.969 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:14:31.969 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:14:31.969 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:14:31.970 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:14:31.970 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:14:31.970 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:14:31.970 | HD Request # 80 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:14:31.970 | HD Request # 80 | Download start date-time: 2025-02-05 23:14:27.000000. File last date-time: 2025-02-05 23:14:27.000001 2025-02-05 23:14:31.970 | HD Request # 80 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:14:31.970 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:14:31.970 | Socket (4) | New receive buffer size: 0 2025-02-05 23:14:31.970 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:14:32.012 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:14:32.012 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:14:32.012 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:14:32.014 | HD Request # 80 | Sending historical data logon request message. 2025-02-05 23:14:32.015 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:14:32.016 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:14:32.016 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:14:32.140 | HD Request # 80 | Requesting Intraday data. Start date-time: 2025-02-05 23:14:27. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:14:32.185 | HD Request # 80 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:14:27.023000 2025-02-05 23:14:32.185 | Socket (4) | CloseSocket call. 2025-02-05 23:14:32.186 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:14:32.186 | Historical data download thread signaled to stop. 2025-02-05 23:14:32.186 | HD Request # 80 | Timestamp of first Intraday data file record written: 2025-02-05 23:14:27.023000. 2025-02-05 23:14:32.186 | HD Request # 80 | Received 2 Intraday data records from 2025-02-05 23:14:27.023000 to 2025-02-05 23:14:27.207000 (0.2 seconds. Delay: 5.0 seconds) and wrote 2 records for MCLH5.NYMEX 2025-02-05 23:14:32.194 | HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:14:27.207000 2025-02-05 23:14:32.194 | HD Request # 80 | Completion time: 1s. 2025-02-05 23:14:32.194 | HD Request # 80 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 80 2025-02-05 23:14:32.194 | Removing historical data download ID 80. 2025-02-05 23:14:32.194 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:14:32.194 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:14:32.194 | HD Request # 80 | Enabling Intraday chart updating for symbol. 2025-02-05 23:14:32.194 | 2025-02-05 23:14:32.194 | Triggering next historical data download in queue. 2025-02-05 23:14:32.195 | HD Request # 81 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:14:32.195 | HD Request # 81 | Download start date-time: 2025-02-05 23:14:28.000000. File last date-time: 2025-02-05 23:14:28.000000 2025-02-05 23:14:32.195 | HD Request # 81 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:14:32.195 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:14:32.195 | Socket (5) | New receive buffer size: 0 2025-02-05 23:14:32.195 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:14:32.228 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:14:32.228 | Socket (4) | Closed. 2025-02-05 23:14:32.239 | HD Request # 81 | Sending historical data logon request message. 2025-02-05 23:14:32.364 | HD Request # 81 | Requesting Intraday data. Start date-time: 2025-02-05 23:14:28. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:14:32.410 | HD Request # 81 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:14:28.274000 2025-02-05 23:14:32.410 | Socket (5) | CloseSocket call. 2025-02-05 23:14:32.410 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:14:32.411 | Historical data download thread signaled to stop. 2025-02-05 23:14:32.411 | HD Request # 81 | Timestamp of first Intraday data file record written: 2025-02-05 23:14:28.274000. 2025-02-05 23:14:32.411 | HD Request # 81 | Received 1 Intraday data record from 2025-02-05 23:14:28.274000 to 2025-02-05 23:14:28.274000 (0.0 seconds. Delay: 4.1 seconds) and wrote 1 record for MGCJ5.COMEX 2025-02-05 23:14:32.419 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:14:28.274000 2025-02-05 23:14:32.419 | HD Request # 81 | Completion time: 0s. 2025-02-05 23:14:32.419 | HD Request # 81 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 81 2025-02-05 23:14:32.419 | Removing historical data download ID 81. 2025-02-05 23:14:32.419 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:14:32.419 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:14:32.419 | HD Request # 81 | Enabling Intraday chart updating for symbol. 2025-02-05 23:14:32.419 | 2025-02-05 23:14:32.419 | Triggering next historical data download in queue. 2025-02-05 23:14:32.419 | HD Request # 82 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:14:32.419 | HD Request # 82 | Download start date-time: 2025-02-05 23:14:28.000000. File last date-time: 2025-02-05 23:14:28.000003 2025-02-05 23:14:32.419 | HD Request # 82 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:14:32.420 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:14:32.420 | Socket (4) | New receive buffer size: 0 2025-02-05 23:14:32.420 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:14:32.450 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:14:32.450 | Socket (5) | Closed. 2025-02-05 23:14:32.464 | HD Request # 82 | Sending historical data logon request message. 2025-02-05 23:14:32.591 | HD Request # 82 | Requesting Intraday data. Start date-time: 2025-02-05 23:14:28. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:14:32.636 | HD Request # 82 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:14:28.029000 2025-02-05 23:14:32.637 | Socket (4) | CloseSocket call. 2025-02-05 23:14:32.637 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:14:32.637 | Historical data download thread signaled to stop. 2025-02-05 23:14:32.637 | HD Request # 82 | Timestamp of first Intraday data file record written: 2025-02-05 23:14:28.029000. 2025-02-05 23:14:32.637 | HD Request # 82 | Received 5 Intraday data records from 2025-02-05 23:14:28.029000 to 2025-02-05 23:14:30.824000 (2.8 seconds. Delay: 1.8 seconds) and wrote 5 records for MYMH5.CBOT 2025-02-05 23:14:32.645 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:14:30.824000 2025-02-05 23:14:32.645 | HD Request # 82 | Completion time: 0s. 2025-02-05 23:14:32.645 | HD Request # 82 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 82 2025-02-05 23:14:32.645 | Removing historical data download ID 82. 2025-02-05 23:14:32.645 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:14:32.645 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:14:32.645 | HD Request # 82 | Enabling Intraday chart updating for symbol. 2025-02-05 23:14:32.645 | 2025-02-05 23:14:32.645 | No download requests in the queue to start downloads for. 2025-02-05 23:14:32.677 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:14:32.677 | Socket (4) | Closed. 2025-02-05 23:14:39.650 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 23:14:59.839 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 23:15:04.878 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 23:16:08.246 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:16:08.247 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:16:08.247 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 23:16:08.247 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 23:16:08.247 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:16:08.247 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:16:08.247 | DTC Client socket (2) | Closed. 2025-02-05 23:16:08.247 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:16:08.247 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:16:08.247 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:16:10.237 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:16:10.237 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:16:10.237 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:10.237 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:16:10.237 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:10.283 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:16:10.283 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:16:10.283 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:16:10.283 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:16:10.411 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:16:10.411 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:16:10.411 | Triggering next historical data download in queue. 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:16:10.411 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:16:10.411 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:16:10.411 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:16:10.411 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:16:10.411 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:16:10.411 | HD Request # 83 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:16:10.412 | HD Request # 83 | Download start date-time: 2025-02-05 23:15:44.000000. File last date-time: 2025-02-05 23:15:44.000000 2025-02-05 23:16:10.412 | HD Request # 83 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:10.412 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:10.412 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:10.412 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:10.454 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:16:10.454 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:16:10.454 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:16:10.455 | HD Request # 83 | Sending historical data logon request message. 2025-02-05 23:16:10.458 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:16:10.458 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:16:10.458 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:16:10.581 | HD Request # 83 | Requesting Intraday data. Start date-time: 2025-02-05 23:15:44. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:16:10.625 | HD Request # 83 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:15:44.447000 2025-02-05 23:16:10.625 | Socket (4) | CloseSocket call. 2025-02-05 23:16:10.625 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:10.625 | Historical data download thread signaled to stop. 2025-02-05 23:16:10.625 | HD Request # 83 | Timestamp of first Intraday data file record written: 2025-02-05 23:15:44.447000. 2025-02-05 23:16:10.625 | HD Request # 83 | Received 1 Intraday data record from 2025-02-05 23:15:44.447000 to 2025-02-05 23:15:44.447000 (0.0 seconds. Delay: 26.2 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-05 23:16:10.634 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:15:44.447000 2025-02-05 23:16:10.634 | HD Request # 83 | Completion time: 0s. 2025-02-05 23:16:10.634 | HD Request # 83 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 83 2025-02-05 23:16:10.634 | Removing historical data download ID 83. 2025-02-05 23:16:10.634 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:16:10.634 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:16:10.634 | HD Request # 83 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:10.634 | 2025-02-05 23:16:10.634 | Triggering next historical data download in queue. 2025-02-05 23:16:10.634 | HD Request # 84 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:16:10.634 | HD Request # 84 | Download start date-time: 2025-02-05 23:16:06.000000. File last date-time: 2025-02-05 23:16:06.000001 2025-02-05 23:16:10.634 | HD Request # 84 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:10.634 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:10.634 | Socket (5) | New receive buffer size: 0 2025-02-05 23:16:10.634 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:10.666 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:10.666 | Socket (4) | Closed. 2025-02-05 23:16:10.677 | HD Request # 84 | Sending historical data logon request message. 2025-02-05 23:16:10.801 | HD Request # 84 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:06. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:16:10.846 | HD Request # 84 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:16:06.089000 2025-02-05 23:16:10.846 | Socket (5) | CloseSocket call. 2025-02-05 23:16:10.846 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:10.846 | Historical data download thread signaled to stop. 2025-02-05 23:16:10.846 | HD Request # 84 | Timestamp of first Intraday data file record written: 2025-02-05 23:16:06.089000. 2025-02-05 23:16:10.846 | HD Request # 84 | Received 2 Intraday data records from 2025-02-05 23:16:06.089000 to 2025-02-05 23:16:06.089001 (0.0 seconds. Delay: 4.8 seconds) and wrote 2 records for MGCJ5.COMEX 2025-02-05 23:16:10.855 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:06.089001 2025-02-05 23:16:10.855 | HD Request # 84 | Completion time: 0s. 2025-02-05 23:16:10.855 | HD Request # 84 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 84 2025-02-05 23:16:10.855 | Removing historical data download ID 84. 2025-02-05 23:16:10.855 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:16:10.855 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:16:10.855 | HD Request # 84 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:10.855 | 2025-02-05 23:16:10.855 | Triggering next historical data download in queue. 2025-02-05 23:16:10.855 | HD Request # 85 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:16:10.855 | HD Request # 85 | Download start date-time: 2025-02-05 23:16:04.000000. File last date-time: 2025-02-05 23:16:04.000000 2025-02-05 23:16:10.855 | HD Request # 85 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:10.855 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:10.855 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:10.855 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:10.886 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:16:10.886 | Socket (5) | Closed. 2025-02-05 23:16:10.898 | HD Request # 85 | Sending historical data logon request message. 2025-02-05 23:16:11.024 | HD Request # 85 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:04. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:16:11.068 | HD Request # 85 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:16:04.106000 2025-02-05 23:16:11.069 | Socket (4) | CloseSocket call. 2025-02-05 23:16:11.069 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:11.069 | Historical data download thread signaled to stop. 2025-02-05 23:16:11.069 | HD Request # 85 | Timestamp of first Intraday data file record written: 2025-02-05 23:16:04.106000. 2025-02-05 23:16:11.069 | HD Request # 85 | Received 2 Intraday data records from 2025-02-05 23:16:04.106000 to 2025-02-05 23:16:11.700000 (7.6 seconds. Delay: -0.6 seconds) and wrote 2 records for MYMH5.CBOT 2025-02-05 23:16:11.078 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:11.700000 2025-02-05 23:16:11.078 | HD Request # 85 | Completion time: 1s. 2025-02-05 23:16:11.078 | HD Request # 85 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 85 2025-02-05 23:16:11.078 | Removing historical data download ID 85. 2025-02-05 23:16:11.078 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:16:11.078 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:16:11.078 | HD Request # 85 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:11.078 | 2025-02-05 23:16:11.078 | No download requests in the queue to start downloads for. 2025-02-05 23:16:11.110 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:11.110 | Socket (4) | Closed. 2025-02-05 23:16:15.006 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:16:15.007 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:16:15.007 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 23:16:15.007 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 23:16:15.007 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:16:15.007 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:16:15.007 | DTC Client socket (2) | Closed. 2025-02-05 23:16:15.007 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:16:15.007 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:16:15.007 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:16:17.011 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:16:17.011 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:16:17.011 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:17.011 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:16:17.012 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:17.054 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:16:17.054 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:16:17.054 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:16:17.054 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:16:17.180 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:16:17.180 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:16:17.180 | Triggering next historical data download in queue. 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:16:17.180 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:16:17.180 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:16:17.180 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:16:17.180 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:16:17.180 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:16:17.180 | HD Request # 86 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:16:17.180 | HD Request # 86 | Download start date-time: 2025-02-05 23:15:44.000000. File last date-time: 2025-02-05 23:15:44.447000 2025-02-05 23:16:17.180 | HD Request # 86 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:17.180 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:17.180 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:17.180 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:17.222 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:16:17.222 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:16:17.222 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:16:17.223 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:16:17.224 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:16:17.224 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:16:17.225 | HD Request # 86 | Sending historical data logon request message. 2025-02-05 23:16:17.358 | HD Request # 86 | Requesting Intraday data. Start date-time: 2025-02-05 23:15:44. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:16:17.404 | HD Request # 86 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:15:44.447000 2025-02-05 23:16:17.404 | Socket (4) | CloseSocket call. 2025-02-05 23:16:17.404 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:17.404 | Historical data download thread signaled to stop. 2025-02-05 23:16:17.404 | HD Request # 86 | Received 1 Intraday data record from 2025-02-05 23:15:44.447000 to 2025-02-05 23:15:44.447000 (0.0 seconds. Delay: 33.0 seconds) and wrote 0 records for MCLH5.NYMEX 2025-02-05 23:16:17.404 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:15:44.447000 2025-02-05 23:16:17.405 | HD Request # 86 | Completion time: 0s. 2025-02-05 23:16:17.405 | HD Request # 86 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 86 2025-02-05 23:16:17.405 | Removing historical data download ID 86. 2025-02-05 23:16:17.405 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:16:17.405 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:16:17.405 | HD Request # 86 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:17.405 | 2025-02-05 23:16:17.405 | Triggering next historical data download in queue. 2025-02-05 23:16:17.405 | HD Request # 87 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:16:17.405 | HD Request # 87 | Download start date-time: 2025-02-05 23:16:06.000000. File last date-time: 2025-02-05 23:16:06.089001 2025-02-05 23:16:17.405 | HD Request # 87 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:17.405 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:17.406 | Socket (5) | New receive buffer size: 0 2025-02-05 23:16:17.406 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:17.444 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:17.444 | Socket (4) | Closed. 2025-02-05 23:16:17.450 | HD Request # 87 | Sending historical data logon request message. 2025-02-05 23:16:17.577 | HD Request # 87 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:06. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:16:17.623 | HD Request # 87 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:16:06.089000 2025-02-05 23:16:17.623 | Socket (5) | CloseSocket call. 2025-02-05 23:16:17.623 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:17.623 | Historical data download thread signaled to stop. 2025-02-05 23:16:17.623 | HD Request # 87 | Timestamp of first Intraday data file record written: 2025-02-05 23:16:14.044000. 2025-02-05 23:16:17.624 | HD Request # 87 | Received 6 Intraday data records from 2025-02-05 23:16:06.089000 to 2025-02-05 23:16:14.064002 (8.0 seconds. Delay: 3.6 seconds) and wrote 4 records for MGCJ5.COMEX 2025-02-05 23:16:17.632 | HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:14.064002 2025-02-05 23:16:17.632 | HD Request # 87 | Completion time: 0s. 2025-02-05 23:16:17.632 | HD Request # 87 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 87 2025-02-05 23:16:17.632 | Removing historical data download ID 87. 2025-02-05 23:16:17.632 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:16:17.632 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:16:17.632 | HD Request # 87 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:17.632 | 2025-02-05 23:16:17.632 | Triggering next historical data download in queue. 2025-02-05 23:16:17.632 | HD Request # 88 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:16:17.633 | HD Request # 88 | Download start date-time: 2025-02-05 23:16:11.000000. File last date-time: 2025-02-05 23:16:11.700000 2025-02-05 23:16:17.633 | HD Request # 88 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:17.633 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:17.633 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:17.633 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:17.663 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:16:17.663 | Socket (5) | Closed. 2025-02-05 23:16:17.677 | HD Request # 88 | Sending historical data logon request message. 2025-02-05 23:16:17.805 | HD Request # 88 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:11. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:16:17.851 | HD Request # 88 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:16:11.700000 2025-02-05 23:16:17.852 | Socket (4) | CloseSocket call. 2025-02-05 23:16:17.852 | Historical data download thread signaled to stop. 2025-02-05 23:16:17.852 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:17.852 | HD Request # 88 | Timestamp of first Intraday data file record written: 2025-02-05 23:16:15.566000. 2025-02-05 23:16:17.852 | HD Request # 88 | Received 2 Intraday data records from 2025-02-05 23:16:11.700000 to 2025-02-05 23:16:15.566000 (3.9 seconds. Delay: 2.3 seconds) and wrote 1 record for MYMH5.CBOT 2025-02-05 23:16:17.860 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:15.566000 2025-02-05 23:16:17.860 | HD Request # 88 | Completion time: 0s. 2025-02-05 23:16:17.860 | HD Request # 88 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 88 2025-02-05 23:16:17.860 | Removing historical data download ID 88. 2025-02-05 23:16:17.860 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:16:17.860 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:16:17.860 | HD Request # 88 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:17.860 | 2025-02-05 23:16:17.860 | No download requests in the queue to start downloads for. 2025-02-05 23:16:17.892 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:17.892 | Socket (4) | Closed. 2025-02-05 23:16:22.846 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:16:22.846 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:16:22.847 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:16:22.847 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:16:22.847 | DTC Client socket (2) | Closed. 2025-02-05 23:16:22.847 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:16:22.847 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:16:22.847 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:16:24.857 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:16:24.857 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:16:24.857 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:24.857 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:16:24.857 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:24.899 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:16:24.899 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:16:24.899 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:16:24.899 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:16:25.024 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:16:25.024 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:16:25.024 | Triggering next historical data download in queue. 2025-02-05 23:16:25.024 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:16:25.025 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 15136 2025-02-05 23:16:25.025 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:16:25.025 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:16:25.025 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:16:25.025 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:16:25.025 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:16:25.025 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:16:25.025 | HD Request # 89 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:16:25.025 | HD Request # 89 | Download start date-time: 2025-02-05 23:15:44.000000. File last date-time: 2025-02-05 23:15:44.447000 2025-02-05 23:16:25.025 | HD Request # 89 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:25.025 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:25.025 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:25.026 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:25.064 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:16:25.064 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:16:25.065 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:16:25.067 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:16:25.068 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:16:25.068 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:16:25.068 | HD Request # 89 | Sending historical data logon request message. 2025-02-05 23:16:25.195 | HD Request # 89 | Requesting Intraday data. Start date-time: 2025-02-05 23:15:44. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:16:25.238 | HD Request # 89 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:15:44.447000 2025-02-05 23:16:25.239 | Socket (4) | CloseSocket call. 2025-02-05 23:16:25.239 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:25.239 | Historical data download thread signaled to stop. 2025-02-05 23:16:25.239 | HD Request # 89 | Timestamp of first Intraday data file record written: 2025-02-05 23:16:25.378000. 2025-02-05 23:16:25.239 | HD Request # 89 | Received 5 Intraday data records from 2025-02-05 23:15:44.447000 to 2025-02-05 23:16:25.378003 (40.9 seconds. Delay: -0.1 seconds) and wrote 4 records for MCLH5.NYMEX 2025-02-05 23:16:25.248 | HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:25.378003 2025-02-05 23:16:25.248 | HD Request # 89 | Completion time: 0s. 2025-02-05 23:16:25.248 | HD Request # 89 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 89 2025-02-05 23:16:25.248 | Removing historical data download ID 89. 2025-02-05 23:16:25.248 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:16:25.248 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:16:25.248 | HD Request # 89 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:25.248 | 2025-02-05 23:16:25.248 | Triggering next historical data download in queue. 2025-02-05 23:16:25.248 | HD Request # 90 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:16:25.248 | HD Request # 90 | Download start date-time: 2025-02-05 23:16:21.000000. File last date-time: 2025-02-05 23:16:21.000001 2025-02-05 23:16:25.248 | HD Request # 90 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:25.248 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:25.248 | Socket (5) | New receive buffer size: 0 2025-02-05 23:16:25.248 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:25.279 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:25.279 | Socket (4) | Closed. 2025-02-05 23:16:25.290 | HD Request # 90 | Sending historical data logon request message. 2025-02-05 23:16:25.414 | HD Request # 90 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:21. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:16:25.460 | HD Request # 90 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:16:21.664000 2025-02-05 23:16:25.460 | Socket (5) | CloseSocket call. 2025-02-05 23:16:25.460 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:25.460 | Historical data download thread signaled to stop. 2025-02-05 23:16:25.460 | HD Request # 90 | Timestamp of first Intraday data file record written: 2025-02-05 23:16:21.664000. 2025-02-05 23:16:25.461 | HD Request # 90 | Received 7 Intraday data records from 2025-02-05 23:16:21.664000 to 2025-02-05 23:16:25.337000 (3.7 seconds. Delay: 0.1 seconds) and wrote 7 records for MGCJ5.COMEX 2025-02-05 23:16:25.470 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:25.337000 2025-02-05 23:16:25.470 | HD Request # 90 | Completion time: 0s. 2025-02-05 23:16:25.470 | HD Request # 90 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 90 2025-02-05 23:16:25.470 | Removing historical data download ID 90. 2025-02-05 23:16:25.470 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:16:25.470 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:16:25.470 | HD Request # 90 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:25.470 | 2025-02-05 23:16:25.470 | Triggering next historical data download in queue. 2025-02-05 23:16:25.470 | HD Request # 91 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:16:25.470 | HD Request # 91 | Download start date-time: 2025-02-05 23:16:15.000000. File last date-time: 2025-02-05 23:16:15.566000 2025-02-05 23:16:25.470 | HD Request # 91 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:25.470 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:25.470 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:25.471 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:25.501 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:16:25.501 | Socket (5) | Closed. 2025-02-05 23:16:25.512 | HD Request # 91 | Sending historical data logon request message. 2025-02-05 23:16:25.650 | HD Request # 91 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:15. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:16:25.696 | HD Request # 91 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:16:15.566000 2025-02-05 23:16:25.696 | Socket (4) | CloseSocket call. 2025-02-05 23:16:25.696 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:25.696 | Historical data download thread signaled to stop. 2025-02-05 23:16:25.696 | HD Request # 91 | Received 1 Intraday data record from 2025-02-05 23:16:15.566000 to 2025-02-05 23:16:15.566000 (0.0 seconds. Delay: 10.1 seconds) and wrote 0 records for MYMH5.CBOT 2025-02-05 23:16:25.697 | HD Request # 91 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:15.566000 2025-02-05 23:16:25.697 | HD Request # 91 | Completion time: 0s. 2025-02-05 23:16:25.697 | HD Request # 91 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 91 2025-02-05 23:16:25.697 | Removing historical data download ID 91. 2025-02-05 23:16:25.697 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:16:25.697 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:16:25.697 | HD Request # 91 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:25.697 | 2025-02-05 23:16:25.697 | No download requests in the queue to start downloads for. 2025-02-05 23:16:25.736 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:25.737 | Socket (4) | Closed. 2025-02-05 23:16:28.260 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-05 23:16:28.260 | DTC Client socket (2) | CloseSocket call. 2025-02-05 23:16:28.260 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-05 23:16:28.260 | DTC Client socket (2) | Max send buffer size during socket life: 927 2025-02-05 23:16:28.260 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-05 23:16:28.260 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-05 23:16:28.260 | DTC Client socket (2) | Closed. 2025-02-05 23:16:28.261 | DTC Client socket (0) | CloseSocket call. 2025-02-05 23:16:28.261 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-05 23:16:28.261 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-05 23:16:30.254 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-05 23:16:30.254 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-05 23:16:30.254 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:30.254 | DTC Client socket (2) | New receive buffer size: 0 2025-02-05 23:16:30.254 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:30.296 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-05 23:16:30.296 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-05 23:16:30.296 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-05 23:16:30.296 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-05 23:16:30.422 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-05 23:16:30.422 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-05 23:16:30.422 | Triggering next historical data download in queue. 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-05 23:16:30.422 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-05 23:16:30.422 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-05 23:16:30.422 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-05 23:16:30.422 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-05 23:16:30.422 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT. Market Depth data restarted. 2025-02-05 23:16:30.422 | HD Request # 92 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-05 23:16:30.423 | HD Request # 92 | Download start date-time: 2025-02-05 23:16:25.000000. File last date-time: 2025-02-05 23:16:25.378003 2025-02-05 23:16:30.423 | HD Request # 92 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:30.423 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:30.423 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:30.423 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:30.463 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-05 23:16:30.463 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-05 23:16:30.463 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-05 23:16:30.466 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-05 23:16:30.466 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-05 23:16:30.466 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-05 23:16:30.469 | HD Request # 92 | Sending historical data logon request message. 2025-02-05 23:16:30.594 | HD Request # 92 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:25. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-05 23:16:30.640 | HD Request # 92 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-05 23:16:25.378000 2025-02-05 23:16:30.640 | Socket (4) | CloseSocket call. 2025-02-05 23:16:30.640 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:30.640 | Historical data download thread signaled to stop. 2025-02-05 23:16:30.640 | HD Request # 92 | Received 4 Intraday data records from 2025-02-05 23:16:25.378000 to 2025-02-05 23:16:25.378000 (0.0 seconds. Delay: 5.3 seconds) and wrote 0 records for MCLH5.NYMEX 2025-02-05 23:16:30.640 | HD Request # 92 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:25.378003 2025-02-05 23:16:30.640 | HD Request # 92 | Completion time: 0s. 2025-02-05 23:16:30.640 | HD Request # 92 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 92 2025-02-05 23:16:30.640 | Removing historical data download ID 92. 2025-02-05 23:16:30.640 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-05 23:16:30.640 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-05 23:16:30.640 | HD Request # 92 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:30.640 | 2025-02-05 23:16:30.640 | Triggering next historical data download in queue. 2025-02-05 23:16:30.640 | HD Request # 93 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-05 23:16:30.641 | HD Request # 93 | Download start date-time: 2025-02-05 23:16:25.000000. File last date-time: 2025-02-05 23:16:25.337000 2025-02-05 23:16:30.641 | HD Request # 93 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:30.641 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:30.641 | Socket (5) | New receive buffer size: 0 2025-02-05 23:16:30.641 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:30.680 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:30.680 | Socket (4) | Closed. 2025-02-05 23:16:30.697 | HD Request # 93 | Sending historical data logon request message. 2025-02-05 23:16:30.822 | HD Request # 93 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:25. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-05 23:16:30.867 | HD Request # 93 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-05 23:16:25.335000 2025-02-05 23:16:30.868 | Socket (5) | CloseSocket call. 2025-02-05 23:16:30.868 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:30.874 | Historical data download thread signaled to stop. 2025-02-05 23:16:30.874 | HD Request # 93 | Timestamp of first Intraday data file record written: 2025-02-05 23:16:28.584000. 2025-02-05 23:16:30.874 | HD Request # 93 | Received 7 Intraday data records from 2025-02-05 23:16:25.335000 to 2025-02-05 23:16:30.923000 (5.6 seconds. Delay: -0.0 seconds) and wrote 4 records for MGCJ5.COMEX 2025-02-05 23:16:30.882 | HD Request # 93 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:30.923000 2025-02-05 23:16:30.882 | HD Request # 93 | Completion time: 0s. 2025-02-05 23:16:30.882 | HD Request # 93 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 93 2025-02-05 23:16:30.882 | Removing historical data download ID 93. 2025-02-05 23:16:30.882 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-05 23:16:30.882 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-05 23:16:30.882 | HD Request # 93 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:30.882 | 2025-02-05 23:16:30.882 | Triggering next historical data download in queue. 2025-02-05 23:16:30.882 | HD Request # 94 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-05 23:16:30.882 | HD Request # 94 | Download start date-time: 2025-02-05 23:16:15.000000. File last date-time: 2025-02-05 23:16:15.566000 2025-02-05 23:16:30.882 | HD Request # 94 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-05 23:16:30.882 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-05 23:16:30.882 | Socket (4) | New receive buffer size: 0 2025-02-05 23:16:30.882 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-05 23:16:30.909 | Socket (5) | Socket gracefully closed by remote side. 2025-02-05 23:16:30.909 | Socket (5) | Closed. 2025-02-05 23:16:30.925 | HD Request # 94 | Sending historical data logon request message. 2025-02-05 23:16:31.050 | HD Request # 94 | Requesting Intraday data. Start date-time: 2025-02-05 23:16:15. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-05 23:16:31.094 | HD Request # 94 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-05 23:16:15.566000 2025-02-05 23:16:31.094 | Socket (4) | CloseSocket call. 2025-02-05 23:16:31.094 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-05 23:16:31.094 | Historical data download thread signaled to stop. 2025-02-05 23:16:31.094 | HD Request # 94 | Received 1 Intraday data record from 2025-02-05 23:16:15.566000 to 2025-02-05 23:16:15.566000 (0.0 seconds. Delay: 15.5 seconds) and wrote 0 records for MYMH5.CBOT 2025-02-05 23:16:31.095 | HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2025-02-06 04:16:15.566000 2025-02-05 23:16:31.095 | HD Request # 94 | Completion time: 1s. 2025-02-05 23:16:31.095 | HD Request # 94 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 94 2025-02-05 23:16:31.095 | Removing historical data download ID 94. 2025-02-05 23:16:31.095 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-05 23:16:31.095 | Intraday chart data file opened for MYMH5.CBOT 2025-02-05 23:16:31.095 | HD Request # 94 | Enabling Intraday chart updating for symbol. 2025-02-05 23:16:31.095 | 2025-02-05 23:16:31.095 | No download requests in the queue to start downloads for. 2025-02-05 23:16:31.135 | Socket (4) | Socket gracefully closed by remote side. 2025-02-05 23:16:31.135 | Socket (4) | Closed. 2025-02-05 23:16:35.748 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-05 23:16:35.748 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-05 23:16:50.902 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-05 23:20:17.373 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-05 23:41:08.877 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 00:00:00.376 | Added historical Daily data request for ESH5.CME to the queue. 2025-02-06 00:00:00.376 | Triggering next historical data download in queue. 2025-02-06 00:00:00.389 | HD Request # 95 | Downloading Historical Daily chart data for ESH5.CME. Starting date: 2025-02-03. Service: rithmic.trading 2025-02-06 00:00:00.599 | HD Request # 95 | Requesting historical Daily data for ESH25 starting at 2025-02-02. SC External HD service. 2025-02-06 00:00:00.694 | HD Request # 95 | Receiving historical Daily data for ESH5.CME starting at 2025-02-03. 2025-02-06 00:00:00.694 | HD Request # 95 | Writing historical Daily data to the file ESH5.CME.dly. 2025-02-06 00:00:00.699 | HD Request # 95 | Bytes received: 175 2025-02-06 00:00:00.699 | HD Request # 95 | Received 3 Daily data records from 2025-02-03 00:00:00 to 2025-02-05 00:00:00 (3.0 days) and wrote 3 records for ESH5.CME 2025-02-06 00:00:00.700 | HD Request # 95 | Completion time: 0s. 2025-02-06 00:00:00.700 | HD Request # 95 | Daily data download complete for ESH5.CME. Unique request ID: 95 2025-02-06 00:00:00.700 | Removing historical data download ID 95. 2025-02-06 00:00:00.700 | 2025-02-06 00:00:00.700 | No download requests in the queue to start downloads for. 2025-02-06 00:00:00.906 | ESH5.CME [CV][M] Daily #3 | Reloading chart. 2025-02-06 00:00:01.903 | ESH5.CME [CV][M] Daily #3 | Chart data loading complete. 2025-02-06 03:50:10.628 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Creating socket. Using TLS 1.2. 2025-02-06 03:50:10.628 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | New receive buffer size: 0 2025-02-06 03:50:10.628 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Connecting to IP: 216.66.0.130. 2025-02-06 03:50:11.017 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | CloseSocket call. 2025-02-06 03:50:11.018 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Shutdown started. Waiting for graceful close. 2025-02-06 03:50:11.042 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Socket gracefully closed by remote side. 2025-02-06 03:50:11.042 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (4) | Closed. 2025-02-06 04:41:42.883 | RTYH5.CME 2 Min #11 | Reloading chart. 2025-02-06 04:41:43.003 | RTYH5.CME 2 Min #11 | StartDateTimeForLoadingOrderFills: 2024-11-12 16:43:00 2025-02-06 04:41:43.019 | RTYH5.CME 2 Min #11 | Chart data loading complete. 2025-02-06 04:41:43.386 | Mapping RTYH5.CME to RTYH25. Service code: cme 2025-02-06 04:41:43.386 | Denali Data Feed | Starting real-time market data updates for: RTYH5.CME (RTYH25). ID: 6 Service code: cme 2025-02-06 04:41:43.386 | Denali Data Feed | Requesting security definition data for: RTYH5.CME (RTYH25). ID: 6 2025-02-06 04:41:43.386 | Added historical Intraday data request for RTYH5.CME to the queue. 2025-02-06 04:41:43.386 | Intraday data recording state for symbol RTYH5.CME is set to download 'Pending'. 2025-02-06 04:41:43.386 | Triggering next historical data download in queue. 2025-02-06 04:41:43.392 | Delaying start of download for RTYH5.CME. 2025-02-06 04:41:43.518 | Denali Data Feed | Received security definition for symbol RTYH5.CME 2025-02-06 04:41:45.194 | Unsubscribed from market depth data for MYMH5.CBOT 2025-02-06 04:41:45.194 | Requesting market depth updates for: RTYH5.CME if supported. NumLevels=100 2025-02-06 04:41:45.235 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MYMH5.CBOT. permission denied 2025-02-06 04:41:45.243 | Denali Data Feed | Clearing market depth for RTYH5.CME 2025-02-06 04:41:48.505 | HD Request # 96 | Downloading Intraday chart data for RTYH5.CME to the file RTYH5.CME.scid. Service: cme 2025-02-06 04:41:48.506 | HD Request # 96 | Download start date-time: 2024-12-12 00:34:37.000000. File last date-time: 2024-12-12 00:34:37.377000 2025-02-06 04:41:48.506 | HD Request # 96 | Using server: ds28.sierracharts.com port 10150 2025-02-06 04:41:48.902 | Socket (4) | Creating socket. 2025-02-06 04:41:48.902 | Socket (4) | New receive buffer size: 0 2025-02-06 04:41:48.902 | Socket (4) | Connecting to IP: 67.214.125.5. 2025-02-06 04:41:48.996 | HD Request # 96 | Setting DTC encoding to Binary VLS 2025-02-06 04:41:48.996 | HD Request # 96 | Sending historical data logon request message. 2025-02-06 04:41:49.088 | HD Request # 96 | Requesting Intraday data. Start date-time: 2024-12-12 00:34:37. Record interval: 0. Symbol: RTYH25 2025-02-06 04:41:49.124 | HD Request # 96 | Decompressing data. 2025-02-06 04:41:49.211 | HD Request # 96 | Receiving Intraday data for RTYH5.CME starting at 2024-12-12 00:34:37.377000 2025-02-06 04:41:49.308 | HD Request # 96 | Timestamp of first Intraday data file record written: 2024-12-12 00:50:26.621000. 2025-02-06 04:41:56.723 | Socket (4) | CloseSocket call. 2025-02-06 04:41:56.723 | Historical data download thread signaled to stop. 2025-02-06 04:41:56.723 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 04:41:56.723 | HD Request # 96 | Received 4654848 Intraday data records from 2024-12-12 00:34:37.377000 to 2025-02-06 04:41:45.683000 (56.2 days. Delay: 11.0 seconds) and wrote 4654847 records for RTYH5.CME 2025-02-06 04:41:56.732 | HD Request # 96 | Add time&sales data | Remembered last file record date-time: 2025-02-06 09:41:45.683000 2025-02-06 04:41:56.732 | HD Request # 96 | Completion time: 8s. 2025-02-06 04:41:56.732 | HD Request # 96 | Intraday data download complete for RTYH5.CME. Unique request ID: 96 2025-02-06 04:41:56.732 | Removing historical data download ID 96. 2025-02-06 04:41:56.732 | Real-time Intraday chart data file updates started for RTYH5.CME 2025-02-06 04:41:56.732 | Intraday chart data file opened for RTYH5.CME 2025-02-06 04:41:56.732 | HD Request # 96 | Enabling Intraday chart updating for symbol. 2025-02-06 04:41:56.732 | 2025-02-06 04:41:56.732 | No download requests in the queue to start downloads for. 2025-02-06 04:41:56.759 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 04:41:56.759 | Socket (4) | Closed. 2025-02-06 04:42:04.990 | M2KH5.CME[M] 2 Min #11 | Reloading chart. 2025-02-06 04:42:05.191 | Unsubscribed from market depth data for RTYH5.CME 2025-02-06 04:42:05.191 | Mapping M2KH5.CME to M2KH25. Service code: cme 2025-02-06 04:42:05.191 | Denali Data Feed | Starting real-time market data updates for: M2KH5.CME (M2KH25). ID: 7 Service code: cme 2025-02-06 04:42:05.191 | Denali Data Feed | Requesting security definition data for: M2KH5.CME (M2KH25). ID: 7 2025-02-06 04:42:05.191 | Requesting market depth updates for: M2KH5.CME if supported. NumLevels=100 2025-02-06 04:42:05.323 | Denali Data Feed | Clearing market depth for M2KH5.CME 2025-02-06 04:42:05.323 | Denali Data Feed | Received security definition for symbol M2KH5.CME 2025-02-06 04:42:05.388 | M2KH5.CME[M] 2 Min #11 | StartDateTimeForLoadingOrderFills: 2024-12-30 16:15:00 2025-02-06 04:42:05.398 | M2KH5.CME[M] 2 Min #11 | Chart data loading complete. 2025-02-06 04:42:05.490 | Added historical Intraday data request for M2KH5.CME to the queue. 2025-02-06 04:42:05.490 | Intraday data recording state for symbol M2KH5.CME is set to download 'Pending'. 2025-02-06 04:42:05.490 | Triggering next historical data download in queue. 2025-02-06 04:42:05.499 | Delaying start of download for M2KH5.CME. 2025-02-06 04:42:10.506 | HD Request # 97 | Downloading Intraday chart data for M2KH5.CME to the file M2KH5.CME.scid. Service: cme 2025-02-06 04:42:10.507 | HD Request # 97 | Download start date-time: 2025-01-29 21:49:18.000000. File last date-time: 2025-01-29 21:49:18.184000 2025-02-06 04:42:10.507 | HD Request # 97 | Using server: ds32.sierracharts.com port 10149 2025-02-06 04:42:10.606 | Socket (4) | Creating socket. 2025-02-06 04:42:10.606 | Socket (4) | New receive buffer size: 0 2025-02-06 04:42:10.606 | Socket (4) | Connecting to IP: 67.214.125.3. 2025-02-06 04:42:10.687 | HD Request # 97 | Setting DTC encoding to Binary VLS 2025-02-06 04:42:10.687 | HD Request # 97 | Sending historical data logon request message. 2025-02-06 04:42:10.764 | HD Request # 97 | Requesting Intraday data. Start date-time: 2025-01-29 21:49:18. Record interval: 0. Symbol: M2KH25 2025-02-06 04:42:10.796 | HD Request # 97 | Decompressing data. 2025-02-06 04:42:10.884 | HD Request # 97 | Receiving Intraday data for M2KH5.CME starting at 2025-01-29 21:49:18.184000 2025-02-06 04:42:10.961 | HD Request # 97 | Timestamp of first Intraday data file record written: 2025-01-29 21:49:46.189000. 2025-02-06 04:42:11.139 | Opened cached Intraday file: D:\SierraChart\Data\RTYH5.CME.scid. Thread ID: 22756 2025-02-06 04:42:12.141 | Socket (4) | CloseSocket call. 2025-02-06 04:42:12.141 | Historical data download thread signaled to stop. 2025-02-06 04:42:12.141 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 04:42:12.142 | HD Request # 97 | Received 379222 Intraday data records from 2025-01-29 21:49:18.184000 to 2025-02-06 04:42:08.462000 (7.3 days. Delay: 3.7 seconds) and wrote 379221 records for M2KH5.CME 2025-02-06 04:42:12.153 | HD Request # 97 | Add time&sales data | Remembered last file record date-time: 2025-02-06 09:42:08.462000 2025-02-06 04:42:12.153 | Added 2 Time and Sales records to Intraday data file for M2KH5.CME after download. 2025-02-06 04:42:12.153 | HD Request # 97 | Completion time: 2s. 2025-02-06 04:42:12.153 | HD Request # 97 | Intraday data download complete for M2KH5.CME. Unique request ID: 97 2025-02-06 04:42:12.153 | Removing historical data download ID 97. 2025-02-06 04:42:12.153 | Real-time Intraday chart data file updates started for M2KH5.CME 2025-02-06 04:42:12.153 | Intraday chart data file opened for M2KH5.CME 2025-02-06 04:42:12.153 | HD Request # 97 | Enabling Intraday chart updating for symbol. 2025-02-06 04:42:12.153 | 2025-02-06 04:42:12.153 | No download requests in the queue to start downloads for. 2025-02-06 04:42:12.172 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 04:42:12.172 | Socket (4) | Closed. 2025-02-06 04:42:21.228 | Opened cached Intraday file: D:\SierraChart\Data\M2KH5.CME.scid. Thread ID: 22756 2025-02-06 04:43:06.671 | M2KH5.CME[M] 5 Min #11 | Reloading chart. 2025-02-06 04:43:07.004 | M2KH5.CME[M] 5 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 04:43:07.012 | M2KH5.CME[M] 5 Min #11 | Chart data loading complete. 2025-02-06 04:46:52.664 | M2KH5.CME[M] 5 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 04:47:38.536 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 07:00:34.950 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:00:34.950 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:00:34.950 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:00:34.950 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:00:34.950 | DTC Client socket (2) | Closed. 2025-02-06 07:00:34.951 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:00:34.951 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:00:34.951 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:00:36.942 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:00:36.942 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:00:37.020 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:37.020 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:00:37.020 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:37.066 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:00:37.066 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:00:37.066 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:00:37.066 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:00:37.192 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:00:37.192 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:00:37.192 | Triggering next historical data download in queue. 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:00:37.192 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:00:37.192 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:00:37.192 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:00:37.192 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:00:37.192 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:00:37.193 | HD Request # 98 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:00:37.193 | HD Request # 98 | Download start date-time: 2025-02-06 07:00:32.000000. File last date-time: 2025-02-06 07:00:32.000000 2025-02-06 07:00:37.193 | HD Request # 98 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:00:37.193 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:37.193 | Socket (4) | New receive buffer size: 0 2025-02-06 07:00:37.193 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:37.232 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:00:37.233 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:00:37.236 | HD Request # 98 | Sending historical data logon request message. 2025-02-06 07:00:37.256 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:00:37.256 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:00:37.256 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:00:37.366 | HD Request # 98 | Requesting Intraday data. Start date-time: 2025-02-06 07:00:32. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:00:37.409 | HD Request # 98 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:00:32.314000 2025-02-06 07:00:37.451 | Socket (4) | CloseSocket call. 2025-02-06 07:00:37.451 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:00:37.451 | Historical data download thread signaled to stop. 2025-02-06 07:00:37.451 | HD Request # 98 | Timestamp of first Intraday data file record written: 2025-02-06 07:00:32.314000. 2025-02-06 07:00:37.451 | HD Request # 98 | Received 12 Intraday data records from 2025-02-06 07:00:32.314000 to 2025-02-06 07:00:38.273001 (6.0 seconds. Delay: -0.8 seconds) and wrote 12 records for MCLH5.NYMEX 2025-02-06 07:00:37.464 | HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:00:38.273001 2025-02-06 07:00:37.464 | HD Request # 98 | Completion time: 0s. 2025-02-06 07:00:37.464 | HD Request # 98 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 98 2025-02-06 07:00:37.464 | Removing historical data download ID 98. 2025-02-06 07:00:37.464 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:00:37.464 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:00:37.464 | HD Request # 98 | Enabling Intraday chart updating for symbol. 2025-02-06 07:00:37.464 | 2025-02-06 07:00:37.464 | Triggering next historical data download in queue. 2025-02-06 07:00:37.464 | HD Request # 99 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:00:37.465 | HD Request # 99 | Download start date-time: 2025-02-06 07:00:32.000000. File last date-time: 2025-02-06 07:00:32.000001 2025-02-06 07:00:37.465 | HD Request # 99 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:00:37.465 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:37.465 | Socket (5) | New receive buffer size: 0 2025-02-06 07:00:37.465 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:37.494 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:00:37.494 | Socket (4) | Closed. 2025-02-06 07:00:37.508 | HD Request # 99 | Sending historical data logon request message. 2025-02-06 07:00:37.631 | HD Request # 99 | Requesting Intraday data. Start date-time: 2025-02-06 07:00:32. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:00:37.675 | HD Request # 99 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:00:32.570000 2025-02-06 07:00:37.675 | Socket (5) | CloseSocket call. 2025-02-06 07:00:37.675 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:00:37.675 | Historical data download thread signaled to stop. 2025-02-06 07:00:37.675 | HD Request # 99 | Timestamp of first Intraday data file record written: 2025-02-06 07:00:32.570000. 2025-02-06 07:00:37.676 | HD Request # 99 | Received 4 Intraday data records from 2025-02-06 07:00:32.570000 to 2025-02-06 07:00:37.884000 (5.3 seconds. Delay: -0.2 seconds) and wrote 4 records for MGCJ5.COMEX 2025-02-06 07:00:37.683 | HD Request # 99 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:00:37.884000 2025-02-06 07:00:37.684 | HD Request # 99 | Completion time: 0s. 2025-02-06 07:00:37.684 | HD Request # 99 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 99 2025-02-06 07:00:37.684 | Removing historical data download ID 99. 2025-02-06 07:00:37.684 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:00:37.684 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:00:37.684 | HD Request # 99 | Enabling Intraday chart updating for symbol. 2025-02-06 07:00:37.684 | 2025-02-06 07:00:37.684 | Triggering next historical data download in queue. 2025-02-06 07:00:37.684 | HD Request # 100 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:00:37.684 | HD Request # 100 | Download start date-time: 2025-02-06 07:00:34.000000. File last date-time: 2025-02-06 07:00:34.000006 2025-02-06 07:00:37.684 | HD Request # 100 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:00:37.684 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:37.684 | Socket (4) | New receive buffer size: 0 2025-02-06 07:00:37.684 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:37.716 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:00:37.716 | Socket (5) | Closed. 2025-02-06 07:00:37.729 | HD Request # 100 | Sending historical data logon request message. 2025-02-06 07:00:37.857 | HD Request # 100 | Requesting Intraday data. Start date-time: 2025-02-06 07:00:34. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:00:37.900 | HD Request # 100 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:00:34.002000 2025-02-06 07:00:37.940 | Socket (4) | CloseSocket call. 2025-02-06 07:00:37.940 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:00:37.940 | Historical data download thread signaled to stop. 2025-02-06 07:00:37.940 | HD Request # 100 | Timestamp of first Intraday data file record written: 2025-02-06 07:00:34.002000. 2025-02-06 07:00:37.940 | HD Request # 100 | Received 22 Intraday data records from 2025-02-06 07:00:34.002000 to 2025-02-06 07:00:38.385004 (4.4 seconds. Delay: -0.4 seconds) and wrote 22 records for MYMH5.CBOT 2025-02-06 07:00:37.951 | HD Request # 100 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:00:38.385004 2025-02-06 07:00:37.951 | HD Request # 100 | Completion time: 0s. 2025-02-06 07:00:37.951 | HD Request # 100 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 100 2025-02-06 07:00:37.951 | Removing historical data download ID 100. 2025-02-06 07:00:37.951 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:00:37.951 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:00:37.951 | HD Request # 100 | Enabling Intraday chart updating for symbol. 2025-02-06 07:00:37.951 | 2025-02-06 07:00:37.951 | No download requests in the queue to start downloads for. 2025-02-06 07:00:37.979 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:00:37.979 | Socket (4) | Closed. 2025-02-06 07:00:40.820 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:00:40.820 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:00:41.214 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:00:41.214 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:00:41.214 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:00:41.214 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:00:41.214 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:00:41.214 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:00:41.214 | DTC Client socket (2) | Closed. 2025-02-06 07:00:41.214 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:00:41.214 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:00:41.214 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:00:43.209 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:00:43.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:00:43.209 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:43.209 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:00:43.209 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:43.252 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:00:43.252 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:00:43.252 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:00:43.252 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:00:43.377 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:00:43.377 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:00:43.377 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:00:43.377 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:00:43.377 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:00:43.377 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:00:43.377 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:00:43.378 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:00:43.378 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:00:43.378 | Triggering next historical data download in queue. 2025-02-06 07:00:43.378 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:00:43.378 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:00:43.378 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:00:43.378 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:00:43.378 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:00:43.378 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:00:43.378 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:00:43.378 | HD Request # 101 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:00:43.378 | HD Request # 101 | Download start date-time: 2025-02-06 07:00:40.000000. File last date-time: 2025-02-06 07:00:40.000000 2025-02-06 07:00:43.378 | HD Request # 101 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:00:43.378 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:43.379 | Socket (4) | New receive buffer size: 0 2025-02-06 07:00:43.379 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:43.419 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:00:43.419 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:00:43.422 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:00:43.422 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:00:43.422 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:00:43.422 | HD Request # 101 | Sending historical data logon request message. 2025-02-06 07:00:43.548 | HD Request # 101 | Requesting Intraday data. Start date-time: 2025-02-06 07:00:40. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:00:43.592 | HD Request # 101 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:00:40.348000 2025-02-06 07:00:43.592 | Socket (4) | CloseSocket call. 2025-02-06 07:00:43.592 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:00:43.592 | Historical data download thread signaled to stop. 2025-02-06 07:00:43.592 | HD Request # 101 | Timestamp of first Intraday data file record written: 2025-02-06 07:00:40.348000. 2025-02-06 07:00:43.593 | HD Request # 101 | Received 2 Intraday data records from 2025-02-06 07:00:40.348000 to 2025-02-06 07:00:42.364000 (2.0 seconds. Delay: 1.2 seconds) and wrote 2 records for MCLH5.NYMEX 2025-02-06 07:00:43.601 | HD Request # 101 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:00:42.364000 2025-02-06 07:00:43.601 | HD Request # 101 | Completion time: 0s. 2025-02-06 07:00:43.601 | HD Request # 101 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 101 2025-02-06 07:00:43.601 | Removing historical data download ID 101. 2025-02-06 07:00:43.601 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:00:43.601 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:00:43.601 | HD Request # 101 | Enabling Intraday chart updating for symbol. 2025-02-06 07:00:43.601 | 2025-02-06 07:00:43.601 | Triggering next historical data download in queue. 2025-02-06 07:00:43.602 | HD Request # 102 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:00:43.602 | HD Request # 102 | Download start date-time: 2025-02-06 07:00:37.000000. File last date-time: 2025-02-06 07:00:37.884000 2025-02-06 07:00:43.602 | HD Request # 102 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:00:43.602 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:43.603 | Socket (5) | New receive buffer size: 0 2025-02-06 07:00:43.603 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:43.634 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:00:43.634 | Socket (4) | Closed. 2025-02-06 07:00:43.645 | HD Request # 102 | Sending historical data logon request message. 2025-02-06 07:00:43.775 | HD Request # 102 | Requesting Intraday data. Start date-time: 2025-02-06 07:00:37. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:00:43.819 | HD Request # 102 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:00:37.872000 2025-02-06 07:00:43.820 | Socket (5) | CloseSocket call. 2025-02-06 07:00:43.820 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:00:43.820 | Historical data download thread signaled to stop. 2025-02-06 07:00:43.820 | HD Request # 102 | Timestamp of first Intraday data file record written: 2025-02-06 07:00:43.214000. 2025-02-06 07:00:43.820 | HD Request # 102 | Received 8 Intraday data records from 2025-02-06 07:00:37.872000 to 2025-02-06 07:00:43.594000 (5.7 seconds. Delay: 0.2 seconds) and wrote 6 records for MGCJ5.COMEX 2025-02-06 07:00:43.830 | HD Request # 102 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:00:43.594000 2025-02-06 07:00:43.830 | HD Request # 102 | Completion time: 0s. 2025-02-06 07:00:43.830 | HD Request # 102 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 102 2025-02-06 07:00:43.830 | Removing historical data download ID 102. 2025-02-06 07:00:43.830 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:00:43.830 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:00:43.830 | HD Request # 102 | Enabling Intraday chart updating for symbol. 2025-02-06 07:00:43.830 | 2025-02-06 07:00:43.830 | Triggering next historical data download in queue. 2025-02-06 07:00:43.831 | HD Request # 103 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:00:43.831 | HD Request # 103 | Download start date-time: 2025-02-06 07:00:39.000000. File last date-time: 2025-02-06 07:00:39.000000 2025-02-06 07:00:43.831 | HD Request # 103 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:00:43.831 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:00:43.832 | Socket (4) | New receive buffer size: 0 2025-02-06 07:00:43.832 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:00:43.860 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:00:43.860 | Socket (5) | Closed. 2025-02-06 07:00:43.874 | HD Request # 103 | Sending historical data logon request message. 2025-02-06 07:00:44.000 | HD Request # 103 | Requesting Intraday data. Start date-time: 2025-02-06 07:00:39. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:00:44.043 | HD Request # 103 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:00:39.251000 2025-02-06 07:00:44.082 | Socket (4) | CloseSocket call. 2025-02-06 07:00:44.082 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:00:44.083 | Historical data download thread signaled to stop. 2025-02-06 07:00:44.083 | HD Request # 103 | Timestamp of first Intraday data file record written: 2025-02-06 07:00:39.251000. 2025-02-06 07:00:44.083 | HD Request # 103 | Received 20 Intraday data records from 2025-02-06 07:00:39.251000 to 2025-02-06 07:00:44.599000 (5.3 seconds. Delay: -0.5 seconds) and wrote 20 records for MYMH5.CBOT 2025-02-06 07:00:44.092 | HD Request # 103 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:00:44.599000 2025-02-06 07:00:44.092 | HD Request # 103 | Completion time: 1s. 2025-02-06 07:00:44.092 | HD Request # 103 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 103 2025-02-06 07:00:44.092 | Removing historical data download ID 103. 2025-02-06 07:00:44.092 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:00:44.092 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:00:44.092 | HD Request # 103 | Enabling Intraday chart updating for symbol. 2025-02-06 07:00:44.092 | 2025-02-06 07:00:44.092 | No download requests in the queue to start downloads for. 2025-02-06 07:00:44.122 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:00:44.122 | Socket (4) | Closed. 2025-02-06 07:00:45.846 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:00:50.881 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:00:50.882 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:05:25.964 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:05:25.964 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:05:25.964 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:05:25.964 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:05:25.964 | DTC Client socket (2) | Closed. 2025-02-06 07:05:25.965 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:05:25.965 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:05:25.965 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:05:27.961 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:05:27.961 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:05:27.961 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:27.961 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:05:27.961 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:28.006 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:05:28.006 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:05:28.006 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:05:28.006 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:05:28.136 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:05:28.136 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:05:28.136 | Triggering next historical data download in queue. 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:05:28.136 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:05:28.136 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:05:28.136 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:05:28.137 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:05:28.137 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:05:28.137 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:05:28.137 | HD Request # 104 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:05:28.137 | HD Request # 104 | Download start date-time: 2025-02-06 07:05:14.000000. File last date-time: 2025-02-06 07:05:14.000001 2025-02-06 07:05:28.137 | HD Request # 104 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:28.137 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:28.137 | Socket (4) | New receive buffer size: 0 2025-02-06 07:05:28.137 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:28.176 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:05:28.179 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:05:28.179 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:05:28.179 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:05:28.180 | HD Request # 104 | Sending historical data logon request message. 2025-02-06 07:05:28.180 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:05:28.309 | HD Request # 104 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:14. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:05:28.353 | HD Request # 104 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:05:14.046000 2025-02-06 07:05:28.354 | Socket (4) | CloseSocket call. 2025-02-06 07:05:28.354 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:28.354 | Historical data download thread signaled to stop. 2025-02-06 07:05:28.354 | HD Request # 104 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:14.046000. 2025-02-06 07:05:28.354 | HD Request # 104 | Received 4 Intraday data records from 2025-02-06 07:05:14.046000 to 2025-02-06 07:05:26.040000 (12.0 seconds. Delay: 2.3 seconds) and wrote 4 records for MCLH5.NYMEX 2025-02-06 07:05:28.363 | HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:26.040000 2025-02-06 07:05:28.363 | HD Request # 104 | Completion time: 0s. 2025-02-06 07:05:28.363 | HD Request # 104 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 104 2025-02-06 07:05:28.363 | Removing historical data download ID 104. 2025-02-06 07:05:28.363 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:05:28.363 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:05:28.363 | HD Request # 104 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:28.363 | 2025-02-06 07:05:28.363 | Triggering next historical data download in queue. 2025-02-06 07:05:28.363 | HD Request # 105 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:05:28.364 | HD Request # 105 | Download start date-time: 2025-02-06 07:05:25.000000. File last date-time: 2025-02-06 07:05:25.000000 2025-02-06 07:05:28.364 | HD Request # 105 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:28.364 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:28.364 | Socket (5) | New receive buffer size: 0 2025-02-06 07:05:28.364 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:28.394 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:05:28.394 | Socket (4) | Closed. 2025-02-06 07:05:28.407 | HD Request # 105 | Sending historical data logon request message. 2025-02-06 07:05:28.534 | HD Request # 105 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:25. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:05:28.579 | HD Request # 105 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:05:25.072000 2025-02-06 07:05:28.579 | Socket (5) | CloseSocket call. 2025-02-06 07:05:28.579 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:28.579 | Historical data download thread signaled to stop. 2025-02-06 07:05:28.579 | HD Request # 105 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:25.072000. 2025-02-06 07:05:28.579 | HD Request # 105 | Received 4 Intraday data records from 2025-02-06 07:05:25.072000 to 2025-02-06 07:05:29.359000 (4.3 seconds. Delay: -0.8 seconds) and wrote 4 records for MGCJ5.COMEX 2025-02-06 07:05:28.591 | HD Request # 105 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:29.359000 2025-02-06 07:05:28.591 | HD Request # 105 | Completion time: 0s. 2025-02-06 07:05:28.591 | HD Request # 105 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 105 2025-02-06 07:05:28.591 | Removing historical data download ID 105. 2025-02-06 07:05:28.591 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:05:28.591 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:05:28.591 | HD Request # 105 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:28.591 | 2025-02-06 07:05:28.591 | Triggering next historical data download in queue. 2025-02-06 07:05:28.592 | HD Request # 106 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:05:28.592 | HD Request # 106 | Download start date-time: 2025-02-06 07:05:23.000000. File last date-time: 2025-02-06 07:05:23.000000 2025-02-06 07:05:28.592 | HD Request # 106 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:28.592 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:28.593 | Socket (4) | New receive buffer size: 0 2025-02-06 07:05:28.593 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:28.619 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:05:28.619 | Socket (5) | Closed. 2025-02-06 07:05:28.641 | HD Request # 106 | Sending historical data logon request message. 2025-02-06 07:05:28.765 | HD Request # 106 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:23. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:05:28.808 | HD Request # 106 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:05:23.640000 2025-02-06 07:05:28.808 | Socket (4) | CloseSocket call. 2025-02-06 07:05:28.808 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:28.808 | Historical data download thread signaled to stop. 2025-02-06 07:05:28.808 | HD Request # 106 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:23.640000. 2025-02-06 07:05:28.808 | HD Request # 106 | Received 1 Intraday data record from 2025-02-06 07:05:23.640000 to 2025-02-06 07:05:23.640000 (0.0 seconds. Delay: 5.2 seconds) and wrote 1 record for MYMH5.CBOT 2025-02-06 07:05:28.817 | HD Request # 106 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:23.640000 2025-02-06 07:05:28.817 | HD Request # 106 | Completion time: 0s. 2025-02-06 07:05:28.817 | HD Request # 106 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 106 2025-02-06 07:05:28.817 | Removing historical data download ID 106. 2025-02-06 07:05:28.817 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:05:28.817 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:05:28.817 | HD Request # 106 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:28.817 | 2025-02-06 07:05:28.817 | No download requests in the queue to start downloads for. 2025-02-06 07:05:28.848 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:05:28.848 | Socket (4) | Closed. 2025-02-06 07:05:33.129 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:05:33.129 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:05:38.161 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:05:43.324 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:05:43.324 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:05:43.324 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:05:43.324 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:05:43.324 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:05:43.324 | DTC Client socket (2) | Closed. 2025-02-06 07:05:43.324 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:05:43.325 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:05:43.325 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:05:43.325 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:05:45.314 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:05:45.314 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:05:45.358 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:45.358 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:05:45.358 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:45.403 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:05:45.403 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:05:45.403 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:05:45.403 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:05:45.532 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:05:45.532 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:05:45.532 | Triggering next historical data download in queue. 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:05:45.532 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:05:45.532 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:05:45.532 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:05:45.532 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:05:45.532 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:05:45.532 | HD Request # 107 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:05:45.533 | HD Request # 107 | Download start date-time: 2025-02-06 07:05:41.000000. File last date-time: 2025-02-06 07:05:41.000000 2025-02-06 07:05:45.533 | HD Request # 107 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:45.533 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:45.533 | Socket (4) | New receive buffer size: 0 2025-02-06 07:05:45.533 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:45.573 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:05:45.573 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:05:45.575 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:05:45.575 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:05:45.576 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:05:45.577 | HD Request # 107 | Sending historical data logon request message. 2025-02-06 07:05:45.709 | HD Request # 107 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:41. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:05:45.753 | HD Request # 107 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:05:41.248000 2025-02-06 07:05:45.753 | Socket (4) | CloseSocket call. 2025-02-06 07:05:45.753 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:45.753 | Historical data download thread signaled to stop. 2025-02-06 07:05:45.753 | HD Request # 107 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:41.248000. 2025-02-06 07:05:45.753 | HD Request # 107 | Received 3 Intraday data records from 2025-02-06 07:05:41.248000 to 2025-02-06 07:05:43.417000 (2.2 seconds. Delay: 2.3 seconds) and wrote 3 records for MCLH5.NYMEX 2025-02-06 07:05:45.763 | HD Request # 107 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:43.417000 2025-02-06 07:05:45.763 | HD Request # 107 | Completion time: 0s. 2025-02-06 07:05:45.763 | HD Request # 107 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 107 2025-02-06 07:05:45.763 | Removing historical data download ID 107. 2025-02-06 07:05:45.763 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:05:45.763 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:05:45.763 | HD Request # 107 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:45.763 | 2025-02-06 07:05:45.763 | Triggering next historical data download in queue. 2025-02-06 07:05:45.763 | HD Request # 108 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:05:45.764 | HD Request # 108 | Download start date-time: 2025-02-06 07:05:42.000000. File last date-time: 2025-02-06 07:05:42.000001 2025-02-06 07:05:45.764 | HD Request # 108 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:45.764 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:45.764 | Socket (5) | New receive buffer size: 0 2025-02-06 07:05:45.764 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:45.802 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:05:45.802 | Socket (4) | Closed. 2025-02-06 07:05:45.807 | HD Request # 108 | Sending historical data logon request message. 2025-02-06 07:05:45.931 | HD Request # 108 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:42. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:05:45.976 | HD Request # 108 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:05:42.135000 2025-02-06 07:05:46.015 | Socket (5) | CloseSocket call. 2025-02-06 07:05:46.015 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:46.015 | Historical data download thread signaled to stop. 2025-02-06 07:05:46.015 | HD Request # 108 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:42.135000. 2025-02-06 07:05:46.015 | HD Request # 108 | Received 18 Intraday data records from 2025-02-06 07:05:42.135000 to 2025-02-06 07:05:46.578000 (4.4 seconds. Delay: -0.6 seconds) and wrote 18 records for MGCJ5.COMEX 2025-02-06 07:05:46.024 | HD Request # 108 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:46.578000 2025-02-06 07:05:46.024 | HD Request # 108 | Completion time: 1s. 2025-02-06 07:05:46.024 | HD Request # 108 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 108 2025-02-06 07:05:46.024 | Removing historical data download ID 108. 2025-02-06 07:05:46.024 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:05:46.024 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:05:46.024 | HD Request # 108 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:46.024 | 2025-02-06 07:05:46.024 | Triggering next historical data download in queue. 2025-02-06 07:05:46.024 | HD Request # 109 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:05:46.024 | HD Request # 109 | Download start date-time: 2025-02-06 07:05:37.000000. File last date-time: 2025-02-06 07:05:37.000004 2025-02-06 07:05:46.024 | HD Request # 109 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:46.024 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:46.025 | Socket (4) | New receive buffer size: 0 2025-02-06 07:05:46.025 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:46.055 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:05:46.056 | Socket (5) | Closed. 2025-02-06 07:05:46.068 | HD Request # 109 | Sending historical data logon request message. 2025-02-06 07:05:46.194 | HD Request # 109 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:37. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:05:46.238 | HD Request # 109 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:05:37.178000 2025-02-06 07:05:46.238 | Socket (4) | CloseSocket call. 2025-02-06 07:05:46.239 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:46.239 | Historical data download thread signaled to stop. 2025-02-06 07:05:46.239 | HD Request # 109 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:37.178000. 2025-02-06 07:05:46.239 | HD Request # 109 | Received 5 Intraday data records from 2025-02-06 07:05:37.178000 to 2025-02-06 07:05:37.178004 (0.0 seconds. Delay: 9.1 seconds) and wrote 5 records for MYMH5.CBOT 2025-02-06 07:05:46.248 | HD Request # 109 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:37.178004 2025-02-06 07:05:46.248 | HD Request # 109 | Completion time: 0s. 2025-02-06 07:05:46.248 | HD Request # 109 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 109 2025-02-06 07:05:46.248 | Removing historical data download ID 109. 2025-02-06 07:05:46.248 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:05:46.248 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:05:46.248 | HD Request # 109 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:46.248 | 2025-02-06 07:05:46.248 | No download requests in the queue to start downloads for. 2025-02-06 07:05:46.282 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:05:46.283 | Socket (4) | Closed. 2025-02-06 07:05:48.216 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:05:52.200 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:05:52.201 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:05:52.201 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:05:52.201 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:05:52.201 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:05:52.201 | DTC Client socket (2) | Closed. 2025-02-06 07:05:52.202 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:05:52.202 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:05:52.202 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:05:52.202 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:05:53.255 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:05:53.256 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:05:54.201 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:05:54.201 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:05:54.202 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:54.202 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:05:54.202 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:54.358 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:05:54.358 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:05:54.359 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:05:54.359 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:05:54.485 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:05:54.485 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:05:54.485 | Triggering next historical data download in queue. 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:05:54.485 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:05:54.485 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:05:54.485 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:05:54.486 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:05:54.486 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:05:54.486 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:05:54.486 | HD Request # 110 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:05:54.486 | HD Request # 110 | Download start date-time: 2025-02-06 07:05:51.000000. File last date-time: 2025-02-06 07:05:51.000000 2025-02-06 07:05:54.486 | HD Request # 110 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:54.486 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:54.486 | Socket (4) | New receive buffer size: 0 2025-02-06 07:05:54.486 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:54.526 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:05:54.527 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:05:54.530 | HD Request # 110 | Sending historical data logon request message. 2025-02-06 07:05:54.531 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:05:54.531 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:05:54.531 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:05:54.656 | HD Request # 110 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:51. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:05:54.700 | HD Request # 110 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:05:51.098000 2025-02-06 07:05:54.700 | Socket (4) | CloseSocket call. 2025-02-06 07:05:54.700 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:54.701 | Historical data download thread signaled to stop. 2025-02-06 07:05:54.701 | HD Request # 110 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:51.098000. 2025-02-06 07:05:54.701 | HD Request # 110 | Received 1 Intraday data record from 2025-02-06 07:05:51.098000 to 2025-02-06 07:05:51.098000 (0.0 seconds. Delay: 3.6 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-06 07:05:54.710 | HD Request # 110 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:51.098000 2025-02-06 07:05:54.710 | HD Request # 110 | Completion time: 0s. 2025-02-06 07:05:54.710 | HD Request # 110 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 110 2025-02-06 07:05:54.710 | Removing historical data download ID 110. 2025-02-06 07:05:54.710 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:05:54.710 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:05:54.710 | HD Request # 110 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:54.710 | 2025-02-06 07:05:54.710 | Triggering next historical data download in queue. 2025-02-06 07:05:54.710 | HD Request # 111 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:05:54.711 | HD Request # 111 | Download start date-time: 2025-02-06 07:05:51.000000. File last date-time: 2025-02-06 07:05:51.000000 2025-02-06 07:05:54.711 | HD Request # 111 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:54.711 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:54.711 | Socket (5) | New receive buffer size: 0 2025-02-06 07:05:54.711 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:54.746 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:05:54.746 | Socket (4) | Closed. 2025-02-06 07:05:54.754 | HD Request # 111 | Sending historical data logon request message. 2025-02-06 07:05:54.885 | HD Request # 111 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:51. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:05:54.930 | HD Request # 111 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:05:51.046000 2025-02-06 07:05:54.931 | Socket (5) | CloseSocket call. 2025-02-06 07:05:54.931 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:54.931 | Historical data download thread signaled to stop. 2025-02-06 07:05:54.931 | HD Request # 111 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:51.046000. 2025-02-06 07:05:54.931 | HD Request # 111 | Received 4 Intraday data records from 2025-02-06 07:05:51.046000 to 2025-02-06 07:05:53.578001 (2.5 seconds. Delay: 1.4 seconds) and wrote 4 records for MGCJ5.COMEX 2025-02-06 07:05:54.941 | HD Request # 111 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:53.578001 2025-02-06 07:05:54.941 | HD Request # 111 | Completion time: 0s. 2025-02-06 07:05:54.941 | HD Request # 111 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 111 2025-02-06 07:05:54.941 | Removing historical data download ID 111. 2025-02-06 07:05:54.941 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:05:54.941 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:05:54.941 | HD Request # 111 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:54.941 | 2025-02-06 07:05:54.942 | Triggering next historical data download in queue. 2025-02-06 07:05:54.942 | HD Request # 112 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:05:54.942 | HD Request # 112 | Download start date-time: 2025-02-06 07:05:48.000000. File last date-time: 2025-02-06 07:05:48.000000 2025-02-06 07:05:54.942 | HD Request # 112 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:05:54.942 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:05:54.942 | Socket (4) | New receive buffer size: 0 2025-02-06 07:05:54.942 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:05:54.974 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:05:54.974 | Socket (5) | Closed. 2025-02-06 07:05:54.985 | HD Request # 112 | Sending historical data logon request message. 2025-02-06 07:05:55.111 | HD Request # 112 | Requesting Intraday data. Start date-time: 2025-02-06 07:05:48. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:05:55.155 | HD Request # 112 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:05:48.835000 2025-02-06 07:05:55.156 | Socket (4) | CloseSocket call. 2025-02-06 07:05:55.156 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:05:55.156 | Historical data download thread signaled to stop. 2025-02-06 07:05:55.156 | HD Request # 112 | Timestamp of first Intraday data file record written: 2025-02-06 07:05:48.835000. 2025-02-06 07:05:55.156 | HD Request # 112 | Received 4 Intraday data records from 2025-02-06 07:05:48.835000 to 2025-02-06 07:05:52.497000 (3.7 seconds. Delay: 2.7 seconds) and wrote 4 records for MYMH5.CBOT 2025-02-06 07:05:55.169 | HD Request # 112 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:05:52.497000 2025-02-06 07:05:55.169 | HD Request # 112 | Completion time: 1s. 2025-02-06 07:05:55.169 | HD Request # 112 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 112 2025-02-06 07:05:55.169 | Removing historical data download ID 112. 2025-02-06 07:05:55.169 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:05:55.169 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:05:55.169 | HD Request # 112 | Enabling Intraday chart updating for symbol. 2025-02-06 07:05:55.169 | 2025-02-06 07:05:55.169 | No download requests in the queue to start downloads for. 2025-02-06 07:05:55.197 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:05:55.197 | Socket (4) | Closed. 2025-02-06 07:05:58.290 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:05:58.290 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:06:13.418 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:07:51.588 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:07:51.588 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:07:51.588 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:07:51.588 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:07:51.588 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:07:51.588 | DTC Client socket (2) | Closed. 2025-02-06 07:07:51.588 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:07:51.588 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:07:51.588 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:07:51.588 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:07:53.584 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:07:53.584 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:07:53.585 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:07:53.585 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:07:53.585 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:07:53.629 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:07:53.629 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:07:53.629 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:07:53.629 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:07:53.762 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:07:53.762 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:07:53.762 | Triggering next historical data download in queue. 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:07:53.762 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:07:53.762 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:07:53.762 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:07:53.763 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:07:53.763 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:07:53.763 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:07:53.763 | HD Request # 113 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:07:53.763 | HD Request # 113 | Download start date-time: 2025-02-06 07:07:37.000000. File last date-time: 2025-02-06 07:07:37.000000 2025-02-06 07:07:53.763 | HD Request # 113 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:07:53.763 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:07:53.763 | Socket (4) | New receive buffer size: 0 2025-02-06 07:07:53.763 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:07:53.804 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:07:53.804 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:07:53.806 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:07:53.806 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:07:53.806 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:07:54.816 | HD Request # 113 | Sending historical data logon request message. 2025-02-06 07:07:54.942 | HD Request # 113 | Requesting Intraday data. Start date-time: 2025-02-06 07:07:37. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:07:54.989 | HD Request # 113 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:07:37.421000 2025-02-06 07:07:54.989 | Socket (4) | CloseSocket call. 2025-02-06 07:07:54.989 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:07:54.989 | Historical data download thread signaled to stop. 2025-02-06 07:07:54.989 | HD Request # 113 | Timestamp of first Intraday data file record written: 2025-02-06 07:07:37.421000. 2025-02-06 07:07:54.989 | HD Request # 113 | Received 3 Intraday data records from 2025-02-06 07:07:37.421000 to 2025-02-06 07:07:52.342001 (14.9 seconds. Delay: 2.6 seconds) and wrote 3 records for MCLH5.NYMEX 2025-02-06 07:07:54.997 | HD Request # 113 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:07:52.342001 2025-02-06 07:07:54.997 | HD Request # 113 | Completion time: 1s. 2025-02-06 07:07:54.997 | HD Request # 113 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 113 2025-02-06 07:07:54.997 | Removing historical data download ID 113. 2025-02-06 07:07:54.997 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:07:54.997 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:07:54.997 | HD Request # 113 | Enabling Intraday chart updating for symbol. 2025-02-06 07:07:54.997 | 2025-02-06 07:07:54.997 | Triggering next historical data download in queue. 2025-02-06 07:07:54.997 | HD Request # 114 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:07:54.998 | HD Request # 114 | Download start date-time: 2025-02-06 07:07:50.000000. File last date-time: 2025-02-06 07:07:50.000000 2025-02-06 07:07:54.998 | HD Request # 114 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:07:54.998 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:07:54.998 | Socket (5) | New receive buffer size: 0 2025-02-06 07:07:54.998 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:07:55.033 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:07:55.033 | Socket (4) | Closed. 2025-02-06 07:07:55.044 | HD Request # 114 | Sending historical data logon request message. 2025-02-06 07:07:55.181 | HD Request # 114 | Requesting Intraday data. Start date-time: 2025-02-06 07:07:50. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:07:55.226 | HD Request # 114 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:07:50.715000 2025-02-06 07:07:55.226 | Socket (5) | CloseSocket call. 2025-02-06 07:07:55.226 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:07:55.226 | Historical data download thread signaled to stop. 2025-02-06 07:07:55.226 | HD Request # 114 | Timestamp of first Intraday data file record written: 2025-02-06 07:07:50.715000. 2025-02-06 07:07:55.227 | HD Request # 114 | Received 6 Intraday data records from 2025-02-06 07:07:50.715000 to 2025-02-06 07:07:56.287000 (5.6 seconds. Delay: -1.1 seconds) and wrote 6 records for MGCJ5.COMEX 2025-02-06 07:07:55.235 | HD Request # 114 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:07:56.287000 2025-02-06 07:07:55.235 | HD Request # 114 | Completion time: 1s. 2025-02-06 07:07:55.235 | HD Request # 114 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 114 2025-02-06 07:07:55.235 | Removing historical data download ID 114. 2025-02-06 07:07:55.235 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:07:55.235 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:07:55.235 | HD Request # 114 | Enabling Intraday chart updating for symbol. 2025-02-06 07:07:55.235 | 2025-02-06 07:07:55.235 | Triggering next historical data download in queue. 2025-02-06 07:07:55.235 | HD Request # 115 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:07:55.235 | HD Request # 115 | Download start date-time: 2025-02-06 07:07:50.000000. File last date-time: 2025-02-06 07:07:50.000000 2025-02-06 07:07:55.235 | HD Request # 115 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:07:55.236 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:07:55.236 | Socket (4) | New receive buffer size: 0 2025-02-06 07:07:55.236 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:07:55.267 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:07:55.267 | Socket (5) | Closed. 2025-02-06 07:07:55.279 | HD Request # 115 | Sending historical data logon request message. 2025-02-06 07:07:55.412 | HD Request # 115 | Requesting Intraday data. Start date-time: 2025-02-06 07:07:50. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:07:55.458 | HD Request # 115 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:07:50.295000 2025-02-06 07:07:55.459 | Socket (4) | CloseSocket call. 2025-02-06 07:07:55.459 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:07:55.459 | Historical data download thread signaled to stop. 2025-02-06 07:07:55.459 | HD Request # 115 | Timestamp of first Intraday data file record written: 2025-02-06 07:07:50.295000. 2025-02-06 07:07:55.459 | HD Request # 115 | Received 4 Intraday data records from 2025-02-06 07:07:50.295000 to 2025-02-06 07:07:52.891000 (2.6 seconds. Delay: 2.6 seconds) and wrote 4 records for MYMH5.CBOT 2025-02-06 07:07:55.470 | HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:07:52.891000 2025-02-06 07:07:55.470 | HD Request # 115 | Completion time: 0s. 2025-02-06 07:07:55.470 | HD Request # 115 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 115 2025-02-06 07:07:55.470 | Removing historical data download ID 115. 2025-02-06 07:07:55.470 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:07:55.470 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:07:55.470 | HD Request # 115 | Enabling Intraday chart updating for symbol. 2025-02-06 07:07:55.470 | 2025-02-06 07:07:55.470 | No download requests in the queue to start downloads for. 2025-02-06 07:07:55.502 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:07:55.502 | Socket (4) | Closed. 2025-02-06 07:07:59.252 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:08:04.295 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:08:04.295 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:11:00.086 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:11:00.086 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:11:00.086 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:11:00.086 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:11:00.086 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:11:00.086 | DTC Client socket (2) | Closed. 2025-02-06 07:11:00.086 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:11:00.087 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:11:00.087 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:11:00.087 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:11:02.089 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:11:02.089 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:11:02.201 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:02.201 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:11:02.201 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:02.250 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:11:02.250 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:11:02.250 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:11:02.250 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:11:02.380 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:11:02.380 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:11:02.380 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:11:02.380 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:11:02.380 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:11:02.380 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:11:02.380 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:11:02.380 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:11:02.380 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:11:02.381 | Triggering next historical data download in queue. 2025-02-06 07:11:02.381 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:11:02.381 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:11:02.381 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:11:02.381 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:11:02.381 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:11:02.381 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:11:02.381 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:11:02.381 | HD Request # 116 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:11:02.381 | HD Request # 116 | Download start date-time: 2025-02-06 07:10:48.000000. File last date-time: 2025-02-06 07:10:48.000000 2025-02-06 07:11:02.381 | HD Request # 116 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:11:02.381 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:02.382 | Socket (4) | New receive buffer size: 0 2025-02-06 07:11:02.382 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:02.421 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:11:02.421 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:11:02.424 | HD Request # 116 | Sending historical data logon request message. 2025-02-06 07:11:02.449 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:11:02.449 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:11:02.449 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:11:02.550 | HD Request # 116 | Requesting Intraday data. Start date-time: 2025-02-06 07:10:48. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:11:02.594 | HD Request # 116 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:10:48.666000 2025-02-06 07:11:02.595 | Socket (4) | CloseSocket call. 2025-02-06 07:11:02.595 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:11:02.595 | Historical data download thread signaled to stop. 2025-02-06 07:11:02.595 | HD Request # 116 | Timestamp of first Intraday data file record written: 2025-02-06 07:10:48.666000. 2025-02-06 07:11:02.595 | HD Request # 116 | Received 2 Intraday data records from 2025-02-06 07:10:48.666000 to 2025-02-06 07:11:00.013000 (11.3 seconds. Delay: 2.6 seconds) and wrote 2 records for MCLH5.NYMEX 2025-02-06 07:11:02.604 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:11:00.013000 2025-02-06 07:11:02.604 | HD Request # 116 | Completion time: 0s. 2025-02-06 07:11:02.604 | HD Request # 116 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 116 2025-02-06 07:11:02.604 | Removing historical data download ID 116. 2025-02-06 07:11:02.604 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:11:02.604 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:11:02.604 | HD Request # 116 | Enabling Intraday chart updating for symbol. 2025-02-06 07:11:02.604 | 2025-02-06 07:11:02.604 | Triggering next historical data download in queue. 2025-02-06 07:11:02.604 | HD Request # 117 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:11:02.604 | HD Request # 117 | Download start date-time: 2025-02-06 07:10:57.000000. File last date-time: 2025-02-06 07:10:57.000002 2025-02-06 07:11:02.605 | HD Request # 117 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:11:02.605 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:02.605 | Socket (5) | New receive buffer size: 0 2025-02-06 07:11:02.605 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:02.635 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:11:02.635 | Socket (4) | Closed. 2025-02-06 07:11:02.647 | HD Request # 117 | Sending historical data logon request message. 2025-02-06 07:11:02.772 | HD Request # 117 | Requesting Intraday data. Start date-time: 2025-02-06 07:10:57. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:11:02.816 | HD Request # 117 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:10:57.180000 2025-02-06 07:11:02.817 | Socket (5) | CloseSocket call. 2025-02-06 07:11:02.817 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:11:02.817 | Historical data download thread signaled to stop. 2025-02-06 07:11:02.817 | HD Request # 117 | Timestamp of first Intraday data file record written: 2025-02-06 07:10:57.180000. 2025-02-06 07:11:02.817 | HD Request # 117 | Received 5 Intraday data records from 2025-02-06 07:10:57.180000 to 2025-02-06 07:11:00.819000 (3.6 seconds. Delay: 2.0 seconds) and wrote 5 records for MGCJ5.COMEX 2025-02-06 07:11:02.825 | HD Request # 117 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:11:00.819000 2025-02-06 07:11:02.825 | HD Request # 117 | Completion time: 0s. 2025-02-06 07:11:02.825 | HD Request # 117 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 117 2025-02-06 07:11:02.825 | Removing historical data download ID 117. 2025-02-06 07:11:02.825 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:11:02.825 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:11:02.825 | HD Request # 117 | Enabling Intraday chart updating for symbol. 2025-02-06 07:11:02.825 | 2025-02-06 07:11:02.825 | Triggering next historical data download in queue. 2025-02-06 07:11:02.825 | HD Request # 118 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:11:02.826 | HD Request # 118 | Download start date-time: 2025-02-06 07:10:33.000000. File last date-time: 2025-02-06 07:10:33.000000 2025-02-06 07:11:02.826 | HD Request # 118 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:11:02.826 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:02.826 | Socket (4) | New receive buffer size: 0 2025-02-06 07:11:02.826 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:02.858 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:11:02.858 | Socket (5) | Closed. 2025-02-06 07:11:02.868 | HD Request # 118 | Sending historical data logon request message. 2025-02-06 07:11:02.998 | HD Request # 118 | Requesting Intraday data. Start date-time: 2025-02-06 07:10:33. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:11:03.042 | HD Request # 118 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:10:33.476000 2025-02-06 07:11:03.043 | Socket (4) | CloseSocket call. 2025-02-06 07:11:03.043 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:11:03.043 | Historical data download thread signaled to stop. 2025-02-06 07:11:03.043 | HD Request # 118 | Timestamp of first Intraday data file record written: 2025-02-06 07:10:33.476000. 2025-02-06 07:11:03.043 | HD Request # 118 | Received 2 Intraday data records from 2025-02-06 07:10:33.476000 to 2025-02-06 07:11:02.310000 (28.8 seconds. Delay: 0.7 seconds) and wrote 2 records for MYMH5.CBOT 2025-02-06 07:11:03.052 | HD Request # 118 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:11:02.310000 2025-02-06 07:11:03.052 | HD Request # 118 | Completion time: 1s. 2025-02-06 07:11:03.052 | HD Request # 118 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 118 2025-02-06 07:11:03.052 | Removing historical data download ID 118. 2025-02-06 07:11:03.052 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:11:03.052 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:11:03.052 | HD Request # 118 | Enabling Intraday chart updating for symbol. 2025-02-06 07:11:03.052 | 2025-02-06 07:11:03.052 | No download requests in the queue to start downloads for. 2025-02-06 07:11:03.084 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:11:03.084 | Socket (4) | Closed. 2025-02-06 07:11:05.715 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:11:10.736 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:11:20.823 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:11:55.039 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:11:55.039 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:11:55.039 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:11:55.039 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:11:55.039 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:11:55.039 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:11:55.039 | DTC Client socket (2) | Closed. 2025-02-06 07:11:55.040 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:11:55.040 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:11:55.040 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:11:57.034 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:11:57.034 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:11:57.034 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:57.034 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:11:57.034 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:57.078 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:11:57.078 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:11:57.079 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:11:57.079 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:11:57.205 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:11:57.205 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:11:57.205 | Triggering next historical data download in queue. 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:11:57.205 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:11:57.205 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:11:57.205 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:11:57.205 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:11:57.205 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:11:57.205 | HD Request # 119 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:11:57.206 | HD Request # 119 | Download start date-time: 2025-02-06 07:11:49.000000. File last date-time: 2025-02-06 07:11:49.000002 2025-02-06 07:11:57.206 | HD Request # 119 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:11:57.206 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:57.206 | Socket (4) | New receive buffer size: 0 2025-02-06 07:11:57.206 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:57.246 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:11:57.246 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:11:57.249 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:11:57.249 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:11:57.249 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:11:57.249 | HD Request # 119 | Sending historical data logon request message. 2025-02-06 07:11:57.374 | HD Request # 119 | Requesting Intraday data. Start date-time: 2025-02-06 07:11:49. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:11:57.418 | HD Request # 119 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:11:49.462000 2025-02-06 07:11:57.419 | Socket (4) | CloseSocket call. 2025-02-06 07:11:57.419 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:11:57.419 | Historical data download thread signaled to stop. 2025-02-06 07:11:57.419 | HD Request # 119 | Timestamp of first Intraday data file record written: 2025-02-06 07:11:49.462000. 2025-02-06 07:11:57.419 | HD Request # 119 | Received 3 Intraday data records from 2025-02-06 07:11:49.462000 to 2025-02-06 07:11:49.496000 (0.0 seconds. Delay: 7.9 seconds) and wrote 3 records for MCLH5.NYMEX 2025-02-06 07:11:57.427 | HD Request # 119 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:11:49.496000 2025-02-06 07:11:57.427 | HD Request # 119 | Completion time: 0s. 2025-02-06 07:11:57.427 | HD Request # 119 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 119 2025-02-06 07:11:57.427 | Removing historical data download ID 119. 2025-02-06 07:11:57.427 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:11:57.427 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:11:57.427 | HD Request # 119 | Enabling Intraday chart updating for symbol. 2025-02-06 07:11:57.427 | 2025-02-06 07:11:57.427 | Triggering next historical data download in queue. 2025-02-06 07:11:57.428 | HD Request # 120 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:11:57.429 | HD Request # 120 | Download start date-time: 2025-02-06 07:11:49.000000. File last date-time: 2025-02-06 07:11:49.000004 2025-02-06 07:11:57.429 | HD Request # 120 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:11:57.429 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:57.429 | Socket (5) | New receive buffer size: 0 2025-02-06 07:11:57.429 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:57.459 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:11:57.459 | Socket (4) | Closed. 2025-02-06 07:11:57.472 | HD Request # 120 | Sending historical data logon request message. 2025-02-06 07:11:57.596 | HD Request # 120 | Requesting Intraday data. Start date-time: 2025-02-06 07:11:49. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:11:57.646 | HD Request # 120 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:11:49.196000 2025-02-06 07:11:57.685 | Socket (5) | CloseSocket call. 2025-02-06 07:11:57.685 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:11:57.685 | Historical data download thread signaled to stop. 2025-02-06 07:11:57.686 | HD Request # 120 | Timestamp of first Intraday data file record written: 2025-02-06 07:11:49.196000. 2025-02-06 07:11:57.686 | HD Request # 120 | Received 11 Intraday data records from 2025-02-06 07:11:49.196000 to 2025-02-06 07:11:56.236000 (7.0 seconds. Delay: 1.5 seconds) and wrote 11 records for MGCJ5.COMEX 2025-02-06 07:11:57.693 | HD Request # 120 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:11:56.236000 2025-02-06 07:11:57.693 | HD Request # 120 | Completion time: 0s. 2025-02-06 07:11:57.693 | HD Request # 120 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 120 2025-02-06 07:11:57.693 | Removing historical data download ID 120. 2025-02-06 07:11:57.693 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:11:57.693 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:11:57.693 | HD Request # 120 | Enabling Intraday chart updating for symbol. 2025-02-06 07:11:57.693 | 2025-02-06 07:11:57.693 | Triggering next historical data download in queue. 2025-02-06 07:11:57.694 | HD Request # 121 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:11:57.694 | HD Request # 121 | Download start date-time: 2025-02-06 07:11:38.000000. File last date-time: 2025-02-06 07:11:38.000001 2025-02-06 07:11:57.694 | HD Request # 121 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:11:57.694 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:11:57.694 | Socket (4) | New receive buffer size: 0 2025-02-06 07:11:57.694 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:11:57.726 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:11:57.726 | Socket (5) | Closed. 2025-02-06 07:11:57.737 | HD Request # 121 | Sending historical data logon request message. 2025-02-06 07:11:57.862 | HD Request # 121 | Requesting Intraday data. Start date-time: 2025-02-06 07:11:38. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:11:57.907 | HD Request # 121 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:11:38.205000 2025-02-06 07:11:57.907 | Socket (4) | CloseSocket call. 2025-02-06 07:11:57.907 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:11:57.907 | Historical data download thread signaled to stop. 2025-02-06 07:11:57.907 | HD Request # 121 | Timestamp of first Intraday data file record written: 2025-02-06 07:11:38.205000. 2025-02-06 07:11:57.908 | HD Request # 121 | Received 5 Intraday data records from 2025-02-06 07:11:38.205000 to 2025-02-06 07:11:56.261000 (18.1 seconds. Delay: 1.6 seconds) and wrote 5 records for MYMH5.CBOT 2025-02-06 07:11:57.915 | HD Request # 121 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:11:56.261000 2025-02-06 07:11:57.915 | HD Request # 121 | Completion time: 0s. 2025-02-06 07:11:57.915 | HD Request # 121 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 121 2025-02-06 07:11:57.915 | Removing historical data download ID 121. 2025-02-06 07:11:57.915 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:11:57.915 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:11:57.915 | HD Request # 121 | Enabling Intraday chart updating for symbol. 2025-02-06 07:11:57.915 | 2025-02-06 07:11:57.915 | No download requests in the queue to start downloads for. 2025-02-06 07:11:57.947 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:11:57.948 | Socket (4) | Closed. 2025-02-06 07:12:01.224 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:12:01.225 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:12:46.614 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:16:18.367 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:16:18.367 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:16:18.367 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:16:18.367 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:16:18.367 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:16:18.367 | DTC Client socket (2) | Closed. 2025-02-06 07:16:18.367 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:16:18.368 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:16:18.368 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:16:18.368 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:16:20.361 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:16:20.361 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:16:20.429 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:16:20.429 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:16:20.429 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:16:20.474 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:16:20.474 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:16:20.474 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:16:20.474 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:16:20.603 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:16:20.603 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:16:20.603 | Triggering next historical data download in queue. 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:16:20.603 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:16:20.603 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:16:20.603 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:16:20.603 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:16:20.603 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:16:20.603 | HD Request # 122 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:16:20.604 | HD Request # 122 | Download start date-time: 2025-02-06 07:16:16.000000. File last date-time: 2025-02-06 07:16:16.000010 2025-02-06 07:16:20.604 | HD Request # 122 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:16:20.604 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:16:20.604 | Socket (4) | New receive buffer size: 0 2025-02-06 07:16:20.604 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:16:20.646 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:16:20.646 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:16:20.649 | HD Request # 122 | Sending historical data logon request message. 2025-02-06 07:16:20.649 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:16:20.649 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:16:20.649 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:16:20.773 | HD Request # 122 | Requesting Intraday data. Start date-time: 2025-02-06 07:16:16. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:16:20.818 | HD Request # 122 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:16:16.895000 2025-02-06 07:16:20.857 | Socket (4) | CloseSocket call. 2025-02-06 07:16:20.857 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:16:20.857 | Historical data download thread signaled to stop. 2025-02-06 07:16:20.857 | HD Request # 122 | Timestamp of first Intraday data file record written: 2025-02-06 07:16:16.895000. 2025-02-06 07:16:20.858 | HD Request # 122 | Received 18 Intraday data records from 2025-02-06 07:16:16.895000 to 2025-02-06 07:16:20.535001 (3.6 seconds. Delay: 0.3 seconds) and wrote 18 records for MCLH5.NYMEX 2025-02-06 07:16:20.867 | HD Request # 122 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:16:20.535001 2025-02-06 07:16:20.867 | HD Request # 122 | Completion time: 0s. 2025-02-06 07:16:20.867 | HD Request # 122 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 122 2025-02-06 07:16:20.867 | Removing historical data download ID 122. 2025-02-06 07:16:20.867 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:16:20.867 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:16:20.867 | HD Request # 122 | Enabling Intraday chart updating for symbol. 2025-02-06 07:16:20.867 | 2025-02-06 07:16:20.867 | Triggering next historical data download in queue. 2025-02-06 07:16:20.867 | HD Request # 123 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:16:20.867 | HD Request # 123 | Download start date-time: 2025-02-06 07:16:17.000000. File last date-time: 2025-02-06 07:16:17.000000 2025-02-06 07:16:20.867 | HD Request # 123 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:16:20.868 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:16:20.868 | Socket (5) | New receive buffer size: 0 2025-02-06 07:16:20.868 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:16:20.897 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:16:20.897 | Socket (4) | Closed. 2025-02-06 07:16:20.909 | HD Request # 123 | Sending historical data logon request message. 2025-02-06 07:16:21.037 | HD Request # 123 | Requesting Intraday data. Start date-time: 2025-02-06 07:16:17. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:16:21.081 | HD Request # 123 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:16:17.520000 2025-02-06 07:16:21.081 | Socket (5) | CloseSocket call. 2025-02-06 07:16:21.081 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:16:21.083 | Historical data download thread signaled to stop. 2025-02-06 07:16:21.083 | HD Request # 123 | Timestamp of first Intraday data file record written: 2025-02-06 07:16:17.520000. 2025-02-06 07:16:21.083 | HD Request # 123 | Received 8 Intraday data records from 2025-02-06 07:16:17.520000 to 2025-02-06 07:16:21.573001 (4.1 seconds. Delay: -0.5 seconds) and wrote 8 records for MGCJ5.COMEX 2025-02-06 07:16:21.091 | HD Request # 123 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:16:21.573001 2025-02-06 07:16:21.091 | HD Request # 123 | Completion time: 1s. 2025-02-06 07:16:21.091 | HD Request # 123 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 123 2025-02-06 07:16:21.091 | Removing historical data download ID 123. 2025-02-06 07:16:21.091 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:16:21.091 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:16:21.091 | HD Request # 123 | Enabling Intraday chart updating for symbol. 2025-02-06 07:16:21.091 | 2025-02-06 07:16:21.091 | Triggering next historical data download in queue. 2025-02-06 07:16:21.091 | HD Request # 124 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:16:21.092 | HD Request # 124 | Download start date-time: 2025-02-06 07:15:57.000000. File last date-time: 2025-02-06 07:15:57.000000 2025-02-06 07:16:21.092 | HD Request # 124 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:16:21.092 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:16:21.092 | Socket (4) | New receive buffer size: 0 2025-02-06 07:16:21.092 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:16:21.122 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:16:21.122 | Socket (5) | Closed. 2025-02-06 07:16:21.148 | HD Request # 124 | Sending historical data logon request message. 2025-02-06 07:16:21.279 | HD Request # 124 | Requesting Intraday data. Start date-time: 2025-02-06 07:15:57. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:16:21.323 | HD Request # 124 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:15:57.857000 2025-02-06 07:16:21.325 | Socket (4) | CloseSocket call. 2025-02-06 07:16:21.325 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:16:21.325 | Historical data download thread signaled to stop. 2025-02-06 07:16:21.325 | HD Request # 124 | Timestamp of first Intraday data file record written: 2025-02-06 07:15:57.857000. 2025-02-06 07:16:21.325 | HD Request # 124 | Received 3 Intraday data records from 2025-02-06 07:15:57.857000 to 2025-02-06 07:16:21.472000 (23.6 seconds. Delay: -0.1 seconds) and wrote 3 records for MYMH5.CBOT 2025-02-06 07:16:21.332 | HD Request # 124 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:16:21.472000 2025-02-06 07:16:21.332 | HD Request # 124 | Completion time: 0s. 2025-02-06 07:16:21.332 | HD Request # 124 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 124 2025-02-06 07:16:21.332 | Removing historical data download ID 124. 2025-02-06 07:16:21.332 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:16:21.332 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:16:21.332 | HD Request # 124 | Enabling Intraday chart updating for symbol. 2025-02-06 07:16:21.332 | 2025-02-06 07:16:21.332 | No download requests in the queue to start downloads for. 2025-02-06 07:16:21.366 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:16:21.366 | Socket (4) | Closed. 2025-02-06 07:16:23.472 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:16:23.473 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:16:23.473 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:27:53.185 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:27:53.185 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:27:53.185 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:27:53.185 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:27:53.185 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:27:53.185 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:27:53.185 | DTC Client socket (2) | Closed. 2025-02-06 07:27:53.186 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:27:53.186 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:27:53.186 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:27:55.173 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:27:55.173 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:27:55.216 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:27:55.216 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:27:55.216 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:27:55.261 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:27:55.261 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:27:55.261 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:27:55.261 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:27:55.391 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:27:55.391 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:27:55.391 | Triggering next historical data download in queue. 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:27:55.391 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:27:55.391 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:27:55.391 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:27:55.391 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:27:55.391 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:27:55.391 | HD Request # 125 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:27:55.391 | HD Request # 125 | Download start date-time: 2025-02-06 07:27:45.000000. File last date-time: 2025-02-06 07:27:45.000000 2025-02-06 07:27:55.392 | HD Request # 125 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:27:55.392 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:27:55.392 | Socket (4) | New receive buffer size: 0 2025-02-06 07:27:55.392 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:27:55.431 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:27:55.432 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:27:55.435 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:27:55.435 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:27:55.435 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:27:55.436 | HD Request # 125 | Sending historical data logon request message. 2025-02-06 07:27:55.564 | HD Request # 125 | Requesting Intraday data. Start date-time: 2025-02-06 07:27:45. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:27:55.609 | HD Request # 125 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:27:45.415000 2025-02-06 07:27:55.609 | Socket (4) | CloseSocket call. 2025-02-06 07:27:55.609 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:27:55.609 | Historical data download thread signaled to stop. 2025-02-06 07:27:55.609 | HD Request # 125 | Timestamp of first Intraday data file record written: 2025-02-06 07:27:45.415000. 2025-02-06 07:27:55.609 | HD Request # 125 | Received 1 Intraday data record from 2025-02-06 07:27:45.415000 to 2025-02-06 07:27:45.415000 (0.0 seconds. Delay: 10.2 seconds) and wrote 1 record for MCLH5.NYMEX 2025-02-06 07:27:55.617 | HD Request # 125 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:27:45.415000 2025-02-06 07:27:55.617 | HD Request # 125 | Completion time: 0s. 2025-02-06 07:27:55.617 | HD Request # 125 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 125 2025-02-06 07:27:55.617 | Removing historical data download ID 125. 2025-02-06 07:27:55.617 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:27:55.617 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:27:55.617 | HD Request # 125 | Enabling Intraday chart updating for symbol. 2025-02-06 07:27:55.617 | 2025-02-06 07:27:55.617 | Triggering next historical data download in queue. 2025-02-06 07:27:55.617 | HD Request # 126 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:27:55.618 | HD Request # 126 | Download start date-time: 2025-02-06 07:27:48.000000. File last date-time: 2025-02-06 07:27:48.000003 2025-02-06 07:27:55.618 | HD Request # 126 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:27:55.618 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:27:55.618 | Socket (5) | New receive buffer size: 0 2025-02-06 07:27:55.618 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:27:55.649 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:27:55.649 | Socket (4) | Closed. 2025-02-06 07:27:55.661 | HD Request # 126 | Sending historical data logon request message. 2025-02-06 07:27:55.786 | HD Request # 126 | Requesting Intraday data. Start date-time: 2025-02-06 07:27:48. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:27:55.835 | HD Request # 126 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:27:48.619000 2025-02-06 07:27:55.835 | Socket (5) | CloseSocket call. 2025-02-06 07:27:55.835 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:27:55.835 | Historical data download thread signaled to stop. 2025-02-06 07:27:55.835 | HD Request # 126 | Timestamp of first Intraday data file record written: 2025-02-06 07:27:48.619000. 2025-02-06 07:27:55.835 | HD Request # 126 | Received 7 Intraday data records from 2025-02-06 07:27:48.619000 to 2025-02-06 07:27:56.431001 (7.8 seconds. Delay: -0.6 seconds) and wrote 7 records for MGCJ5.COMEX 2025-02-06 07:27:55.843 | HD Request # 126 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:27:56.431001 2025-02-06 07:27:55.843 | HD Request # 126 | Completion time: 0s. 2025-02-06 07:27:55.843 | HD Request # 126 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 126 2025-02-06 07:27:55.843 | Removing historical data download ID 126. 2025-02-06 07:27:55.843 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:27:55.843 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:27:55.843 | HD Request # 126 | Enabling Intraday chart updating for symbol. 2025-02-06 07:27:55.843 | 2025-02-06 07:27:55.843 | Triggering next historical data download in queue. 2025-02-06 07:27:55.843 | HD Request # 127 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:27:55.843 | HD Request # 127 | Download start date-time: 2025-02-06 07:27:43.000000. File last date-time: 2025-02-06 07:27:43.000000 2025-02-06 07:27:55.844 | HD Request # 127 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:27:55.844 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:27:55.844 | Socket (4) | New receive buffer size: 0 2025-02-06 07:27:55.844 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:27:55.875 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:27:55.875 | Socket (5) | Closed. 2025-02-06 07:27:55.887 | HD Request # 127 | Sending historical data logon request message. 2025-02-06 07:27:56.013 | HD Request # 127 | Requesting Intraday data. Start date-time: 2025-02-06 07:27:43. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:27:56.058 | HD Request # 127 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:27:43.441000 2025-02-06 07:27:56.058 | Socket (4) | CloseSocket call. 2025-02-06 07:27:56.058 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:27:56.058 | Historical data download thread signaled to stop. 2025-02-06 07:27:56.058 | HD Request # 127 | Timestamp of first Intraday data file record written: 2025-02-06 07:27:43.441000. 2025-02-06 07:27:56.058 | HD Request # 127 | Received 2 Intraday data records from 2025-02-06 07:27:43.441000 to 2025-02-06 07:27:53.981000 (10.5 seconds. Delay: 2.1 seconds) and wrote 2 records for MYMH5.CBOT 2025-02-06 07:27:56.069 | HD Request # 127 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:27:53.981000 2025-02-06 07:27:56.069 | HD Request # 127 | Completion time: 1s. 2025-02-06 07:27:56.069 | HD Request # 127 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 127 2025-02-06 07:27:56.069 | Removing historical data download ID 127. 2025-02-06 07:27:56.069 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:27:56.069 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:27:56.069 | HD Request # 127 | Enabling Intraday chart updating for symbol. 2025-02-06 07:27:56.069 | 2025-02-06 07:27:56.069 | No download requests in the queue to start downloads for. 2025-02-06 07:27:56.098 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:27:56.098 | Socket (4) | Closed. 2025-02-06 07:27:59.456 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 07:27:59.456 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:27:59.586 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 07:27:59.586 | DTC Client socket (2) | CloseSocket call. 2025-02-06 07:27:59.586 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 07:27:59.586 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 07:27:59.586 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 07:27:59.586 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 07:27:59.586 | DTC Client socket (2) | Closed. 2025-02-06 07:27:59.587 | DTC Client socket (0) | CloseSocket call. 2025-02-06 07:27:59.587 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 07:27:59.587 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 07:28:01.583 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 07:28:01.583 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 07:28:01.583 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 07:28:01.584 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 07:28:01.584 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 07:28:01.627 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 07:28:01.627 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 07:28:01.627 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 07:28:01.627 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 07:28:01.772 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 07:28:01.772 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 07:28:01.772 | Triggering next historical data download in queue. 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 07:28:01.772 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 07:28:01.772 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 07:28:01.772 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 07:28:01.772 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 07:28:01.772 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 07:28:01.772 | HD Request # 128 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 07:28:01.773 | HD Request # 128 | Download start date-time: 2025-02-06 07:27:57.000000. File last date-time: 2025-02-06 07:27:57.000001 2025-02-06 07:28:01.773 | HD Request # 128 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:28:01.773 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:28:01.773 | Socket (4) | New receive buffer size: 0 2025-02-06 07:28:01.773 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:28:01.812 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 07:28:01.812 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 07:28:01.815 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 07:28:01.815 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 07:28:01.816 | HD Request # 128 | Sending historical data logon request message. 2025-02-06 07:28:01.817 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 07:28:01.940 | HD Request # 128 | Requesting Intraday data. Start date-time: 2025-02-06 07:27:57. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 07:28:01.985 | HD Request # 128 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 07:27:57.024000 2025-02-06 07:28:01.986 | Socket (4) | CloseSocket call. 2025-02-06 07:28:01.986 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:28:01.986 | Historical data download thread signaled to stop. 2025-02-06 07:28:01.986 | HD Request # 128 | Timestamp of first Intraday data file record written: 2025-02-06 07:27:57.024000. 2025-02-06 07:28:01.986 | HD Request # 128 | Received 3 Intraday data records from 2025-02-06 07:27:57.024000 to 2025-02-06 07:28:02.274000 (5.3 seconds. Delay: -0.3 seconds) and wrote 3 records for MCLH5.NYMEX 2025-02-06 07:28:01.995 | HD Request # 128 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:28:02.274000 2025-02-06 07:28:01.996 | HD Request # 128 | Completion time: 0s. 2025-02-06 07:28:01.996 | HD Request # 128 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 128 2025-02-06 07:28:01.996 | Removing historical data download ID 128. 2025-02-06 07:28:01.996 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 07:28:01.996 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 07:28:01.996 | HD Request # 128 | Enabling Intraday chart updating for symbol. 2025-02-06 07:28:01.996 | 2025-02-06 07:28:01.996 | Triggering next historical data download in queue. 2025-02-06 07:28:01.996 | HD Request # 129 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 07:28:01.996 | HD Request # 129 | Download start date-time: 2025-02-06 07:27:57.000000. File last date-time: 2025-02-06 07:27:57.000003 2025-02-06 07:28:01.996 | HD Request # 129 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:28:01.996 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 07:28:01.997 | Socket (5) | New receive buffer size: 0 2025-02-06 07:28:01.997 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 07:28:02.026 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:28:02.026 | Socket (4) | Closed. 2025-02-06 07:28:02.038 | HD Request # 129 | Sending historical data logon request message. 2025-02-06 07:28:02.163 | HD Request # 129 | Requesting Intraday data. Start date-time: 2025-02-06 07:27:57. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 07:28:02.207 | HD Request # 129 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 07:27:57.413000 2025-02-06 07:28:02.208 | Socket (5) | CloseSocket call. 2025-02-06 07:28:02.208 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 07:28:02.208 | Historical data download thread signaled to stop. 2025-02-06 07:28:02.208 | HD Request # 129 | Timestamp of first Intraday data file record written: 2025-02-06 07:27:57.413000. 2025-02-06 07:28:02.208 | HD Request # 129 | Received 9 Intraday data records from 2025-02-06 07:27:57.413000 to 2025-02-06 07:28:02.579000 (5.2 seconds. Delay: -0.4 seconds) and wrote 9 records for MGCJ5.COMEX 2025-02-06 07:28:02.215 | HD Request # 129 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:28:02.579000 2025-02-06 07:28:02.215 | HD Request # 129 | Completion time: 1s. 2025-02-06 07:28:02.215 | HD Request # 129 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 129 2025-02-06 07:28:02.215 | Removing historical data download ID 129. 2025-02-06 07:28:02.215 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 07:28:02.215 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 07:28:02.215 | HD Request # 129 | Enabling Intraday chart updating for symbol. 2025-02-06 07:28:02.215 | 2025-02-06 07:28:02.215 | Triggering next historical data download in queue. 2025-02-06 07:28:02.215 | HD Request # 130 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 07:28:02.216 | HD Request # 130 | Download start date-time: 2025-02-06 07:27:53.000000. File last date-time: 2025-02-06 07:27:53.981000 2025-02-06 07:28:02.216 | HD Request # 130 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 07:28:02.216 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 07:28:02.216 | Socket (4) | New receive buffer size: 0 2025-02-06 07:28:02.216 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 07:28:02.248 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 07:28:02.248 | Socket (5) | Closed. 2025-02-06 07:28:02.259 | HD Request # 130 | Sending historical data logon request message. 2025-02-06 07:28:02.385 | HD Request # 130 | Requesting Intraday data. Start date-time: 2025-02-06 07:27:53. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 07:28:02.440 | HD Request # 130 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 07:27:53.981000 2025-02-06 07:28:02.440 | Socket (4) | CloseSocket call. 2025-02-06 07:28:02.440 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 07:28:02.440 | Historical data download thread signaled to stop. 2025-02-06 07:28:02.440 | HD Request # 130 | Received 1 Intraday data record from 2025-02-06 07:27:53.981000 to 2025-02-06 07:27:53.981000 (0.0 seconds. Delay: 8.5 seconds) and wrote 0 records for MYMH5.CBOT 2025-02-06 07:28:02.440 | HD Request # 130 | Add time&sales data | Remembered last file record date-time: 2025-02-06 12:27:53.981000 2025-02-06 07:28:02.440 | HD Request # 130 | Completion time: 0s. 2025-02-06 07:28:02.440 | HD Request # 130 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 130 2025-02-06 07:28:02.440 | Removing historical data download ID 130. 2025-02-06 07:28:02.440 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 07:28:02.440 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 07:28:02.440 | HD Request # 130 | Enabling Intraday chart updating for symbol. 2025-02-06 07:28:02.440 | 2025-02-06 07:28:02.440 | No download requests in the queue to start downloads for. 2025-02-06 07:28:02.480 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 07:28:02.480 | Socket (4) | Closed. 2025-02-06 07:28:04.495 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 07:28:19.610 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 07:28:29.698 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 08:09:01.320 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 08:09:01.320 | DTC Client socket (2) | CloseSocket call. 2025-02-06 08:09:01.320 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 08:09:01.320 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 08:09:01.320 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 08:09:01.320 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 08:09:01.320 | DTC Client socket (2) | Closed. 2025-02-06 08:09:01.321 | DTC Client socket (0) | CloseSocket call. 2025-02-06 08:09:01.321 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 08:09:01.321 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 08:09:03.321 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 08:09:03.321 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 08:09:03.366 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 08:09:03.367 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 08:09:03.367 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 08:09:03.410 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 08:09:03.410 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 08:09:03.411 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 08:09:03.411 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 08:09:03.544 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 08:09:03.544 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 08:09:03.544 | Triggering next historical data download in queue. 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 08:09:03.544 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 08:09:03.544 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 08:09:03.544 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 08:09:03.544 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 08:09:03.544 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 08:09:03.544 | HD Request # 131 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 08:09:03.545 | HD Request # 131 | Download start date-time: 2025-02-06 08:08:59.000000. File last date-time: 2025-02-06 08:08:59.000000 2025-02-06 08:09:03.545 | HD Request # 131 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 08:09:03.545 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 08:09:03.545 | Socket (4) | New receive buffer size: 0 2025-02-06 08:09:03.545 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 08:09:03.585 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 08:09:03.585 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 08:09:03.586 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 08:09:03.587 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 08:09:03.587 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 08:09:03.588 | HD Request # 131 | Sending historical data logon request message. 2025-02-06 08:09:03.720 | HD Request # 131 | Requesting Intraday data. Start date-time: 2025-02-06 08:08:59. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 08:09:03.765 | HD Request # 131 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 08:08:59.237000 2025-02-06 08:09:03.765 | Socket (4) | CloseSocket call. 2025-02-06 08:09:03.765 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 08:09:03.767 | Historical data download thread signaled to stop. 2025-02-06 08:09:03.767 | HD Request # 131 | Timestamp of first Intraday data file record written: 2025-02-06 08:08:59.237000. 2025-02-06 08:09:03.767 | HD Request # 131 | Received 4 Intraday data records from 2025-02-06 08:08:59.237000 to 2025-02-06 08:09:02.837000 (3.6 seconds. Delay: 0.9 seconds) and wrote 4 records for MCLH5.NYMEX 2025-02-06 08:09:03.775 | HD Request # 131 | Add time&sales data | Remembered last file record date-time: 2025-02-06 13:09:02.837000 2025-02-06 08:09:03.775 | HD Request # 131 | Completion time: 0s. 2025-02-06 08:09:03.775 | HD Request # 131 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 131 2025-02-06 08:09:03.775 | Removing historical data download ID 131. 2025-02-06 08:09:03.775 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 08:09:03.775 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 08:09:03.775 | HD Request # 131 | Enabling Intraday chart updating for symbol. 2025-02-06 08:09:03.775 | 2025-02-06 08:09:03.775 | Triggering next historical data download in queue. 2025-02-06 08:09:03.776 | HD Request # 132 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 08:09:03.776 | HD Request # 132 | Download start date-time: 2025-02-06 08:08:55.000000. File last date-time: 2025-02-06 08:08:55.000001 2025-02-06 08:09:03.776 | HD Request # 132 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 08:09:03.776 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 08:09:03.776 | Socket (5) | New receive buffer size: 0 2025-02-06 08:09:03.776 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 08:09:03.805 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 08:09:03.805 | Socket (4) | Closed. 2025-02-06 08:09:03.818 | HD Request # 132 | Sending historical data logon request message. 2025-02-06 08:09:03.944 | HD Request # 132 | Requesting Intraday data. Start date-time: 2025-02-06 08:08:55. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 08:09:03.989 | HD Request # 132 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 08:08:55.107000 2025-02-06 08:09:03.989 | Socket (5) | CloseSocket call. 2025-02-06 08:09:03.989 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 08:09:03.989 | Historical data download thread signaled to stop. 2025-02-06 08:09:03.989 | HD Request # 132 | Timestamp of first Intraday data file record written: 2025-02-06 08:08:55.107000. 2025-02-06 08:09:03.990 | HD Request # 132 | Received 7 Intraday data records from 2025-02-06 08:08:55.107000 to 2025-02-06 08:09:03.185000 (8.1 seconds. Delay: 0.8 seconds) and wrote 7 records for MGCJ5.COMEX 2025-02-06 08:09:03.998 | HD Request # 132 | Add time&sales data | Remembered last file record date-time: 2025-02-06 13:09:03.185000 2025-02-06 08:09:03.998 | HD Request # 132 | Completion time: 0s. 2025-02-06 08:09:03.998 | HD Request # 132 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 132 2025-02-06 08:09:03.998 | Removing historical data download ID 132. 2025-02-06 08:09:03.998 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 08:09:03.998 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 08:09:03.998 | HD Request # 132 | Enabling Intraday chart updating for symbol. 2025-02-06 08:09:03.998 | 2025-02-06 08:09:03.998 | Triggering next historical data download in queue. 2025-02-06 08:09:03.998 | HD Request # 133 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 08:09:03.999 | HD Request # 133 | Download start date-time: 2025-02-06 08:08:58.000000. File last date-time: 2025-02-06 08:08:58.000001 2025-02-06 08:09:03.999 | HD Request # 133 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 08:09:03.999 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 08:09:03.999 | Socket (4) | New receive buffer size: 0 2025-02-06 08:09:03.999 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 08:09:04.030 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 08:09:04.030 | Socket (5) | Closed. 2025-02-06 08:09:04.042 | HD Request # 133 | Sending historical data logon request message. 2025-02-06 08:09:04.167 | HD Request # 133 | Requesting Intraday data. Start date-time: 2025-02-06 08:08:58. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 08:09:04.214 | HD Request # 133 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 08:08:58.119000 2025-02-06 08:09:04.214 | Socket (4) | CloseSocket call. 2025-02-06 08:09:04.214 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 08:09:04.215 | Historical data download thread signaled to stop. 2025-02-06 08:09:04.216 | HD Request # 133 | Timestamp of first Intraday data file record written: 2025-02-06 08:08:58.119000. 2025-02-06 08:09:04.216 | HD Request # 133 | Received 2 Intraday data records from 2025-02-06 08:08:58.119000 to 2025-02-06 08:08:58.119001 (0.0 seconds. Delay: 6.1 seconds) and wrote 2 records for MYMH5.CBOT 2025-02-06 08:09:04.225 | HD Request # 133 | Add time&sales data | Remembered last file record date-time: 2025-02-06 13:08:58.119001 2025-02-06 08:09:04.225 | HD Request # 133 | Completion time: 1s. 2025-02-06 08:09:04.225 | HD Request # 133 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 133 2025-02-06 08:09:04.225 | Removing historical data download ID 133. 2025-02-06 08:09:04.225 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 08:09:04.225 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 08:09:04.225 | HD Request # 133 | Enabling Intraday chart updating for symbol. 2025-02-06 08:09:04.225 | 2025-02-06 08:09:04.225 | No download requests in the queue to start downloads for. 2025-02-06 08:09:04.254 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 08:09:04.254 | Socket (4) | Closed. 2025-02-06 08:09:04.773 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 08:09:09.792 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 08:09:14.832 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 08:19:00.277 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 08:19:12.755 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 08:20:11.262 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 08:22:30.777 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 08:38:25.757 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 09:39:34.140 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 09:39:34.140 | DTC Client socket (2) | CloseSocket call. 2025-02-06 09:39:34.140 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 09:39:34.140 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 09:39:34.140 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 09:39:34.140 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 09:39:34.140 | DTC Client socket (2) | Closed. 2025-02-06 09:39:34.141 | DTC Client socket (0) | CloseSocket call. 2025-02-06 09:39:34.141 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 09:39:34.141 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 09:39:36.137 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 09:39:36.137 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 09:39:36.207 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 09:39:36.207 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 09:39:36.207 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 09:39:36.251 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 09:39:36.251 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 09:39:36.252 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 09:39:36.252 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 09:39:36.379 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 09:39:36.379 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 09:39:36.379 | Triggering next historical data download in queue. 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 09:39:36.379 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 09:39:36.379 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 09:39:36.379 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 09:39:36.379 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 09:39:36.379 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 09:39:36.379 | HD Request # 134 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 09:39:36.380 | HD Request # 134 | Download start date-time: 2025-02-06 09:39:33.000000. File last date-time: 2025-02-06 09:39:33.000000 2025-02-06 09:39:36.380 | HD Request # 134 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:39:36.380 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 09:39:36.380 | Socket (4) | New receive buffer size: 0 2025-02-06 09:39:36.380 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 09:39:36.419 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 09:39:36.419 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 09:39:36.422 | HD Request # 134 | Sending historical data logon request message. 2025-02-06 09:39:36.428 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 09:39:36.428 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 09:39:36.428 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 09:39:36.547 | HD Request # 134 | Requesting Intraday data. Start date-time: 2025-02-06 09:39:33. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 09:39:36.594 | HD Request # 134 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 09:39:33.101000 2025-02-06 09:39:36.594 | Socket (4) | CloseSocket call. 2025-02-06 09:39:36.594 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 09:39:36.595 | Historical data download thread signaled to stop. 2025-02-06 09:39:36.595 | HD Request # 134 | Timestamp of first Intraday data file record written: 2025-02-06 09:39:33.101000. 2025-02-06 09:39:36.595 | HD Request # 134 | Received 6 Intraday data records from 2025-02-06 09:39:33.101000 to 2025-02-06 09:39:37.798000 (4.7 seconds. Delay: -1.2 seconds) and wrote 6 records for MCLH5.NYMEX 2025-02-06 09:39:36.603 | HD Request # 134 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:39:37.798000 2025-02-06 09:39:36.603 | HD Request # 134 | Completion time: 0s. 2025-02-06 09:39:36.603 | HD Request # 134 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 134 2025-02-06 09:39:36.603 | Removing historical data download ID 134. 2025-02-06 09:39:36.603 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 09:39:36.603 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 09:39:36.603 | HD Request # 134 | Enabling Intraday chart updating for symbol. 2025-02-06 09:39:36.603 | 2025-02-06 09:39:36.603 | Triggering next historical data download in queue. 2025-02-06 09:39:36.603 | HD Request # 135 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 09:39:36.604 | HD Request # 135 | Download start date-time: 2025-02-06 09:39:25.000000. File last date-time: 2025-02-06 09:39:25.000000 2025-02-06 09:39:36.604 | HD Request # 135 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:39:36.604 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 09:39:36.604 | Socket (5) | New receive buffer size: 0 2025-02-06 09:39:36.604 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 09:39:36.635 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 09:39:36.635 | Socket (4) | Closed. 2025-02-06 09:39:36.646 | HD Request # 135 | Sending historical data logon request message. 2025-02-06 09:39:36.772 | HD Request # 135 | Requesting Intraday data. Start date-time: 2025-02-06 09:39:25. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 09:39:36.817 | HD Request # 135 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 09:39:25.500000 2025-02-06 09:39:36.817 | Socket (5) | CloseSocket call. 2025-02-06 09:39:36.817 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 09:39:36.817 | Historical data download thread signaled to stop. 2025-02-06 09:39:36.817 | HD Request # 135 | Timestamp of first Intraday data file record written: 2025-02-06 09:39:25.500000. 2025-02-06 09:39:36.817 | HD Request # 135 | Received 5 Intraday data records from 2025-02-06 09:39:25.500000 to 2025-02-06 09:39:37.427000 (11.9 seconds. Delay: -0.6 seconds) and wrote 5 records for MGCJ5.COMEX 2025-02-06 09:39:36.825 | HD Request # 135 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:39:37.427000 2025-02-06 09:39:36.825 | HD Request # 135 | Completion time: 0s. 2025-02-06 09:39:36.825 | HD Request # 135 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 135 2025-02-06 09:39:36.825 | Removing historical data download ID 135. 2025-02-06 09:39:36.825 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 09:39:36.825 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 09:39:36.825 | HD Request # 135 | Enabling Intraday chart updating for symbol. 2025-02-06 09:39:36.825 | 2025-02-06 09:39:36.825 | Triggering next historical data download in queue. 2025-02-06 09:39:36.826 | HD Request # 136 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 09:39:36.826 | HD Request # 136 | Download start date-time: 2025-02-06 09:39:32.000000. File last date-time: 2025-02-06 09:39:32.000011 2025-02-06 09:39:36.826 | HD Request # 136 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:39:36.826 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 09:39:36.826 | Socket (4) | New receive buffer size: 0 2025-02-06 09:39:36.826 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 09:39:36.858 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 09:39:36.858 | Socket (5) | Closed. 2025-02-06 09:39:36.869 | HD Request # 136 | Sending historical data logon request message. 2025-02-06 09:39:37.001 | HD Request # 136 | Requesting Intraday data. Start date-time: 2025-02-06 09:39:32. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 09:39:37.046 | HD Request # 136 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 09:39:32.158000 2025-02-06 09:39:37.086 | Socket (4) | CloseSocket call. 2025-02-06 09:39:37.086 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 09:39:37.086 | Historical data download thread signaled to stop. 2025-02-06 09:39:37.086 | HD Request # 136 | Timestamp of first Intraday data file record written: 2025-02-06 09:39:32.158000. 2025-02-06 09:39:37.086 | HD Request # 136 | Received 29 Intraday data records from 2025-02-06 09:39:32.158000 to 2025-02-06 09:39:38.201001 (6.0 seconds. Delay: -1.1 seconds) and wrote 29 records for MYMH5.CBOT 2025-02-06 09:39:37.094 | HD Request # 136 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:39:38.201001 2025-02-06 09:39:37.094 | HD Request # 136 | Completion time: 1s. 2025-02-06 09:39:37.094 | HD Request # 136 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 136 2025-02-06 09:39:37.094 | Removing historical data download ID 136. 2025-02-06 09:39:37.094 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 09:39:37.094 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 09:39:37.094 | HD Request # 136 | Enabling Intraday chart updating for symbol. 2025-02-06 09:39:37.094 | 2025-02-06 09:39:37.094 | No download requests in the queue to start downloads for. 2025-02-06 09:39:37.128 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 09:39:37.128 | Socket (4) | Closed. 2025-02-06 09:39:41.169 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 09:39:41.169 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 09:39:41.169 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 09:47:57.343 | M2KH5.CME[M] 1 Min #11 | Reloading chart. 2025-02-06 09:47:57.667 | M2KH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 09:47:57.681 | M2KH5.CME[M] 1 Min #11 | Chart data loading complete. 2025-02-06 09:49:39.835 | M2KH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 09:52:11.062 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 09:52:11.062 | DTC Client socket (2) | CloseSocket call. 2025-02-06 09:52:11.062 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 09:52:11.062 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 09:52:11.062 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 09:52:11.062 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 09:52:11.062 | DTC Client socket (2) | Closed. 2025-02-06 09:52:11.062 | DTC Client socket (0) | CloseSocket call. 2025-02-06 09:52:11.062 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 09:52:11.062 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 09:52:13.049 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 09:52:13.049 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 09:52:13.096 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 09:52:13.096 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 09:52:13.096 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 09:52:13.140 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 09:52:13.140 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 09:52:13.140 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 09:52:13.140 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 09:52:13.271 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 09:52:13.271 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 09:52:13.271 | Triggering next historical data download in queue. 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 09:52:13.271 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 09:52:13.271 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 09:52:13.271 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 09:52:13.271 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 09:52:13.271 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 09:52:13.271 | HD Request # 137 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 09:52:13.272 | HD Request # 137 | Download start date-time: 2025-02-06 09:52:05.000000. File last date-time: 2025-02-06 09:52:05.000000 2025-02-06 09:52:13.272 | HD Request # 137 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:52:13.272 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 09:52:13.272 | Socket (4) | New receive buffer size: 0 2025-02-06 09:52:13.272 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 09:52:13.312 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 09:52:13.312 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 09:52:13.315 | HD Request # 137 | Sending historical data logon request message. 2025-02-06 09:52:13.321 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 09:52:13.321 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 09:52:13.321 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 09:52:13.441 | HD Request # 137 | Requesting Intraday data. Start date-time: 2025-02-06 09:52:05. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 09:53:10.549 | HD Request # 137 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 09:52:05.673000 2025-02-06 09:53:10.549 | Socket (4) | CloseSocket call. 2025-02-06 09:53:10.549 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 09:53:10.549 | Historical data download thread signaled to stop. 2025-02-06 09:53:10.550 | HD Request # 137 | Timestamp of first Intraday data file record written: 2025-02-06 09:52:05.673000. 2025-02-06 09:53:10.550 | HD Request # 137 | Received 7 Intraday data records from 2025-02-06 09:52:05.673000 to 2025-02-06 09:52:13.014000 (7.3 seconds. Delay: 57.5 seconds) and wrote 7 records for MCLH5.NYMEX 2025-02-06 09:53:10.561 | HD Request # 137 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:52:13.014000 2025-02-06 09:53:10.561 | Added 172 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 09:53:10.561 | HD Request # 137 | Completion time: 57s. 2025-02-06 09:53:10.561 | HD Request # 137 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 137 2025-02-06 09:53:10.561 | Removing historical data download ID 137. 2025-02-06 09:53:10.561 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 09:53:10.561 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 09:53:10.561 | HD Request # 137 | Enabling Intraday chart updating for symbol. 2025-02-06 09:53:10.561 | 2025-02-06 09:53:10.562 | Triggering next historical data download in queue. 2025-02-06 09:53:10.562 | HD Request # 138 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 09:53:10.562 | HD Request # 138 | Download start date-time: 2025-02-06 09:52:10.000000. File last date-time: 2025-02-06 09:52:10.000000 2025-02-06 09:53:10.562 | HD Request # 138 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:53:10.562 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 09:53:10.563 | Socket (5) | New receive buffer size: 0 2025-02-06 09:53:10.563 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 09:53:10.589 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 09:53:10.589 | Socket (4) | Closed. 2025-02-06 09:53:10.607 | HD Request # 138 | Sending historical data logon request message. 2025-02-06 09:53:10.742 | HD Request # 138 | Requesting Intraday data. Start date-time: 2025-02-06 09:52:10. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 09:53:12.744 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 09:53:12.744 | DTC Client socket (2) | CloseSocket call. 2025-02-06 09:53:12.744 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 09:53:12.744 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 09:53:12.744 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 09:53:12.744 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 09:53:12.744 | DTC Client socket (2) | Closed. 2025-02-06 09:53:12.744 | DTC Client socket (0) | CloseSocket call. 2025-02-06 09:53:12.744 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 09:53:12.744 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 09:53:12.749 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 09:53:12.750 | Socket (5) | CloseSocket call. 2025-02-06 09:53:12.750 | Socket (0) | CloseSocket call. 2025-02-06 09:53:12.750 | Socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 09:53:12.750 | Socket (5) | Closed. 2025-02-06 09:53:12.750 | HD Request # 138 | Error downloading historical Intraday data for MGCJ5.COMEX. The network socket has been closed. Retrying download. 2025-02-06 09:53:12.750 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 09:53:12.750 | Triggering next historical data download in queue. 2025-02-06 09:53:12.750 | Historical data download thread signaled to stop. 2025-02-06 09:53:12.750 | HD Request # 138 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MGCJ5.COMEX 2025-02-06 09:53:12.750 | HD Request # 138 | Completion time: 2s. 2025-02-06 09:53:12.750 | 2025-02-06 09:53:12.750 | HD Request # 139 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 09:53:12.751 | HD Request # 139 | Download start date-time: 2025-02-06 09:52:10.000000. File last date-time: 2025-02-06 09:52:10.000000 2025-02-06 09:53:12.751 | HD Request # 139 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:53:12.751 | Socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 09:53:12.751 | Socket (2) | New receive buffer size: 0 2025-02-06 09:53:12.751 | Socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 09:53:12.793 | HD Request # 139 | Sending historical data logon request message. 2025-02-06 09:53:12.919 | HD Request # 139 | Requesting Intraday data. Start date-time: 2025-02-06 09:52:10. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 09:53:12.924 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 09:53:12.964 | HD Request # 139 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 09:52:10.038000 2025-02-06 09:53:14.741 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 09:53:14.741 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 09:53:14.741 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 09:53:14.742 | DTC Client socket (4) | New receive buffer size: 0 2025-02-06 09:53:14.742 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 09:53:14.784 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 09:53:14.784 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 09:53:14.784 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 09:53:14.784 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 09:53:14.913 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 09:53:14.913 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 09:53:14.913 | Triggering next historical data download in queue. 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 09:53:14.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 09:53:14.953 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 09:53:14.953 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 09:53:14.987 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 09:53:14.987 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 09:53:14.987 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 09:54:21.849 | M2KH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 09:55:10.868 | Socket (2) | CloseSocket call. 2025-02-06 09:55:10.868 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-06 09:55:10.869 | Historical data download thread signaled to stop. 2025-02-06 09:55:10.869 | HD Request # 139 | Timestamp of first Intraday data file record written: 2025-02-06 09:52:10.038000. 2025-02-06 09:55:10.869 | HD Request # 139 | Received 291 Intraday data records from 2025-02-06 09:52:10.038000 to 2025-02-06 09:53:12.532001 (62.5 seconds. Delay: 118.3 seconds) and wrote 291 records for MGCJ5.COMEX 2025-02-06 09:55:10.876 | HD Request # 139 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:53:12.532001 2025-02-06 09:55:10.876 | Added 217 Time and Sales records to Intraday data file for MGCJ5.COMEX after download. 2025-02-06 09:55:10.877 | HD Request # 139 | Completion time: 1m 58s. 2025-02-06 09:55:10.877 | HD Request # 139 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 138 2025-02-06 09:55:10.877 | Removing historical data download ID 138. 2025-02-06 09:55:10.877 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 09:55:10.877 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 09:55:10.877 | HD Request # 139 | Enabling Intraday chart updating for symbol. 2025-02-06 09:55:10.877 | 2025-02-06 09:55:10.877 | Triggering next historical data download in queue. 2025-02-06 09:55:10.877 | HD Request # 140 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 09:55:10.877 | HD Request # 140 | Download start date-time: 2025-02-06 09:52:10.000000. File last date-time: 2025-02-06 09:52:10.000000 2025-02-06 09:55:10.877 | HD Request # 140 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:55:10.877 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 09:55:10.877 | Socket (5) | New receive buffer size: 0 2025-02-06 09:55:10.877 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 09:55:10.910 | Socket (2) | Socket gracefully closed by remote side. 2025-02-06 09:55:10.910 | Socket (2) | Closed. 2025-02-06 09:55:10.922 | HD Request # 140 | Sending historical data logon request message. 2025-02-06 09:55:11.071 | HD Request # 140 | Requesting Intraday data. Start date-time: 2025-02-06 09:52:10. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 09:55:11.137 | HD Request # 140 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 09:52:10.296000 2025-02-06 09:55:13.981 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 09:55:31.849 | M2KH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 09:55:41.358 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-02-06 09:55:41.358 | DTC Client socket (4) | CloseSocket call. 2025-02-06 09:55:41.358 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 09:55:41.358 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 09:55:41.358 | DTC Client socket (4) | Closed. 2025-02-06 09:55:41.358 | DTC Client socket (0) | CloseSocket call. 2025-02-06 09:55:41.358 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 09:55:41.358 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 09:55:41.361 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 09:55:41.361 | Socket (5) | CloseSocket call. 2025-02-06 09:55:41.361 | Socket (0) | CloseSocket call. 2025-02-06 09:55:41.361 | Socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 09:55:41.361 | Socket (5) | Closed. 2025-02-06 09:55:41.361 | HD Request # 140 | Error downloading historical Intraday data for MYMH5.CBOT. The network socket has been closed. Retrying download. 2025-02-06 09:55:41.361 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 09:55:41.361 | Triggering next historical data download in queue. 2025-02-06 09:55:41.361 | Historical data download thread signaled to stop. 2025-02-06 09:55:41.362 | HD Request # 140 | Timestamp of first Intraday data file record written: 2025-02-06 09:52:10.296000. 2025-02-06 09:55:41.362 | HD Request # 140 | Received 608 Intraday data records from 2025-02-06 09:52:10.296000 to 2025-02-06 09:55:12.330000 (3.0 minutes. Delay: 29.0 seconds) and wrote 608 records for MYMH5.CBOT 2025-02-06 09:55:41.362 | HD Request # 140 | Completion time: 31s. 2025-02-06 09:55:41.362 | 2025-02-06 09:55:41.362 | HD Request # 141 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 09:55:41.371 | HD Request # 141 | Download start date-time: 2025-02-06 09:55:12.000000. File last date-time: 2025-02-06 09:55:12.330000 2025-02-06 09:55:41.371 | HD Request # 141 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:55:41.371 | Socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 09:55:41.371 | Socket (2) | New receive buffer size: 0 2025-02-06 09:55:41.371 | Socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 09:55:41.415 | HD Request # 141 | Sending historical data logon request message. 2025-02-06 09:55:41.563 | HD Request # 141 | Requesting Intraday data. Start date-time: 2025-02-06 09:55:12. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 09:55:41.609 | HD Request # 141 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 09:55:12.273000 2025-02-06 09:55:43.353 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 09:55:43.353 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 09:55:43.354 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 09:55:43.354 | DTC Client socket (4) | New receive buffer size: 0 2025-02-06 09:55:43.354 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 09:55:43.397 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 09:55:43.397 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 09:55:43.397 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 09:55:43.397 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 09:55:43.522 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 09:55:43.522 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 09:55:43.522 | Triggering next historical data download in queue. 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 09:55:43.522 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 09:55:43.563 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 09:55:43.563 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 09:55:43.565 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 09:55:43.565 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 09:55:43.565 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 09:56:48.361 | M2KH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 09:57:08.126 | Socket (2) | CloseSocket call. 2025-02-06 09:57:08.126 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-06 09:57:08.126 | Historical data download thread signaled to stop. 2025-02-06 09:57:08.126 | HD Request # 141 | Timestamp of first Intraday data file record written: 2025-02-06 09:55:12.387000. 2025-02-06 09:57:08.126 | HD Request # 141 | Received 227 Intraday data records from 2025-02-06 09:55:12.273000 to 2025-02-06 09:55:42.621000 (30.3 seconds. Delay: 85.5 seconds) and wrote 163 records for MYMH5.CBOT 2025-02-06 09:57:08.135 | HD Request # 141 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:55:42.621000 2025-02-06 09:57:08.135 | Added 95 Time and Sales records to Intraday data file for MYMH5.CBOT after download. 2025-02-06 09:57:08.135 | HD Request # 141 | Completion time: 1m 27s. 2025-02-06 09:57:08.135 | HD Request # 141 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 139 2025-02-06 09:57:08.135 | Removing historical data download ID 139. 2025-02-06 09:57:08.135 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 09:57:08.135 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 09:57:08.135 | HD Request # 141 | Enabling Intraday chart updating for symbol. 2025-02-06 09:57:08.135 | 2025-02-06 09:57:08.135 | Triggering next historical data download in queue. 2025-02-06 09:57:08.136 | HD Request # 142 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 09:57:08.136 | HD Request # 142 | Download start date-time: 2025-02-06 09:53:11.000000. File last date-time: 2025-02-06 09:53:11.000055 2025-02-06 09:57:08.136 | HD Request # 142 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:57:08.136 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 09:57:08.137 | Socket (5) | New receive buffer size: 0 2025-02-06 09:57:08.137 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 09:57:08.166 | Socket (2) | Socket gracefully closed by remote side. 2025-02-06 09:57:08.166 | Socket (2) | Closed. 2025-02-06 09:57:08.181 | HD Request # 142 | Sending historical data logon request message. 2025-02-06 09:57:08.310 | HD Request # 142 | Requesting Intraday data. Start date-time: 2025-02-06 09:53:11. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 09:57:08.365 | HD Request # 142 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 09:53:11.121000 2025-02-06 09:57:08.528 | Socket (5) | CloseSocket call. 2025-02-06 09:57:08.528 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 09:57:08.528 | Historical data download thread signaled to stop. 2025-02-06 09:57:08.528 | HD Request # 142 | Timestamp of first Intraday data file record written: 2025-02-06 09:53:11.121000. 2025-02-06 09:57:08.528 | HD Request # 142 | Received 2505 Intraday data records from 2025-02-06 09:53:11.121000 to 2025-02-06 09:57:09.546002 (4.0 minutes. Delay: -1.0 seconds) and wrote 2504 records for MCLH5.NYMEX 2025-02-06 09:57:08.539 | HD Request # 142 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:57:09.546002 2025-02-06 09:57:08.539 | HD Request # 142 | Completion time: 0s. 2025-02-06 09:57:08.539 | HD Request # 142 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 140 2025-02-06 09:57:08.539 | Removing historical data download ID 140. 2025-02-06 09:57:08.539 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 09:57:08.539 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 09:57:08.539 | HD Request # 142 | Enabling Intraday chart updating for symbol. 2025-02-06 09:57:08.539 | 2025-02-06 09:57:08.539 | Triggering next historical data download in queue. 2025-02-06 09:57:08.539 | HD Request # 143 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 09:57:08.539 | HD Request # 143 | Download start date-time: 2025-02-06 09:55:39.000000. File last date-time: 2025-02-06 09:55:39.000000 2025-02-06 09:57:08.539 | HD Request # 143 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 09:57:08.539 | Socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 09:57:08.540 | Socket (2) | New receive buffer size: 0 2025-02-06 09:57:08.540 | Socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 09:57:08.570 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 09:57:08.570 | Socket (5) | Closed. 2025-02-06 09:57:08.581 | HD Request # 143 | Sending historical data logon request message. 2025-02-06 09:57:08.708 | HD Request # 143 | Requesting Intraday data. Start date-time: 2025-02-06 09:55:39. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 09:57:08.752 | HD Request # 143 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 09:55:39.811000 2025-02-06 09:57:08.834 | Socket (2) | CloseSocket call. 2025-02-06 09:57:08.834 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-06 09:57:08.834 | Historical data download thread signaled to stop. 2025-02-06 09:57:08.834 | HD Request # 143 | Timestamp of first Intraday data file record written: 2025-02-06 09:55:39.811000. 2025-02-06 09:57:08.834 | HD Request # 143 | Received 818 Intraday data records from 2025-02-06 09:55:39.811000 to 2025-02-06 09:57:09.934000 (90.1 seconds. Delay: -1.1 seconds) and wrote 818 records for MGCJ5.COMEX 2025-02-06 09:57:08.842 | HD Request # 143 | Add time&sales data | Remembered last file record date-time: 2025-02-06 14:57:09.934000 2025-02-06 09:57:08.842 | HD Request # 143 | Completion time: 0s. 2025-02-06 09:57:08.842 | HD Request # 143 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 141 2025-02-06 09:57:08.842 | Removing historical data download ID 141. 2025-02-06 09:57:08.842 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 09:57:08.842 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 09:57:08.842 | HD Request # 143 | Enabling Intraday chart updating for symbol. 2025-02-06 09:57:08.842 | 2025-02-06 09:57:08.842 | No download requests in the queue to start downloads for. 2025-02-06 09:57:08.876 | Socket (2) | Socket gracefully closed by remote side. 2025-02-06 09:57:08.876 | Socket (2) | Closed. 2025-02-06 09:57:09.899 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 09:57:09.899 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 09:57:14.939 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 10:04:00.263 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 2025-02-06 10:08:08.070 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:08:08.070 | DTC Client socket (4) | CloseSocket call. 2025-02-06 10:08:08.070 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:08:08.070 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:08:08.070 | DTC Client socket (4) | Closed. 2025-02-06 10:08:08.071 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:08:08.071 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:08:08.071 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:08:10.070 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:08:10.070 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:08:10.111 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:08:10.111 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:08:10.111 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:08:10.156 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:08:10.156 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:08:10.156 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:08:10.156 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:08:10.468 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:08:10.468 | DTC Client socket (2) | CloseSocket call. 2025-02-06 10:08:10.468 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:08:10.468 | DTC Client socket (2) | Closed. 2025-02-06 10:08:10.468 | Rithmic Direct - DTC (Data) | Failed connections: 1 2025-02-06 10:08:10.468 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:08:10.468 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:08:10.468 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:08:10.468 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:08:12.457 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:08:12.457 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:08:12.457 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:08:12.458 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:08:12.458 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:08:12.500 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:08:12.500 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:08:12.500 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:08:12.500 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:08:13.009 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:08:13.009 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:08:13.009 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:08:13.009 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:08:13.009 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:08:13.009 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:08:13.009 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:08:13.010 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:08:13.010 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:08:13.010 | Triggering next historical data download in queue. 2025-02-06 10:08:13.010 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 10:08:13.010 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:08:13.010 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:08:13.010 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:08:13.010 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:08:13.010 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 10:08:13.010 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:08:13.010 | HD Request # 144 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:08:13.010 | HD Request # 144 | Download start date-time: 2025-02-06 10:08:05.000000. File last date-time: 2025-02-06 10:08:05.000006 2025-02-06 10:08:13.010 | HD Request # 144 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:08:13.010 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:08:13.011 | Socket (4) | New receive buffer size: 0 2025-02-06 10:08:13.011 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:08:13.051 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 10:08:13.051 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:08:13.054 | HD Request # 144 | Sending historical data logon request message. 2025-02-06 10:08:13.058 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:08:13.058 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:08:13.100 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:08:13.186 | HD Request # 144 | Requesting Intraday data. Start date-time: 2025-02-06 10:08:05. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:09:30.361 | M2KH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 10:09:42.098 | HD Request # 144 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:08:05.432000 2025-02-06 10:09:42.138 | Socket (4) | CloseSocket call. 2025-02-06 10:09:42.139 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:09:42.139 | Historical data download thread signaled to stop. 2025-02-06 10:09:42.139 | HD Request # 144 | Timestamp of first Intraday data file record written: 2025-02-06 10:08:05.432000. 2025-02-06 10:09:42.139 | HD Request # 144 | Received 14 Intraday data records from 2025-02-06 10:08:05.432000 to 2025-02-06 10:08:11.448000 (6.0 seconds. Delay: 90.7 seconds) and wrote 14 records for MCLH5.NYMEX 2025-02-06 10:09:42.152 | HD Request # 144 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:08:11.448000 2025-02-06 10:09:42.152 | Added 187 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 10:09:42.152 | HD Request # 144 | Completion time: 1m 29s. 2025-02-06 10:09:42.152 | HD Request # 144 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 142 2025-02-06 10:09:42.152 | Removing historical data download ID 142. 2025-02-06 10:09:42.152 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:09:42.152 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:09:42.152 | HD Request # 144 | Enabling Intraday chart updating for symbol. 2025-02-06 10:09:42.152 | 2025-02-06 10:09:42.152 | Triggering next historical data download in queue. 2025-02-06 10:09:42.152 | HD Request # 145 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:09:42.152 | HD Request # 145 | Download start date-time: 2025-02-06 10:08:07.000000. File last date-time: 2025-02-06 10:08:07.000005 2025-02-06 10:09:42.152 | HD Request # 145 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:09:42.152 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:09:42.153 | Socket (5) | New receive buffer size: 0 2025-02-06 10:09:42.153 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:09:42.184 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:09:42.184 | Socket (4) | Closed. 2025-02-06 10:09:42.202 | HD Request # 145 | Sending historical data logon request message. 2025-02-06 10:09:42.337 | HD Request # 145 | Requesting Intraday data. Start date-time: 2025-02-06 10:08:07. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:09:42.382 | HD Request # 145 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:08:07.078000 2025-02-06 10:09:42.468 | Socket (5) | CloseSocket call. 2025-02-06 10:09:42.468 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:09:42.468 | Historical data download thread signaled to stop. 2025-02-06 10:09:42.468 | HD Request # 145 | Timestamp of first Intraday data file record written: 2025-02-06 10:08:07.078000. 2025-02-06 10:09:42.468 | HD Request # 145 | Received 940 Intraday data records from 2025-02-06 10:08:07.078000 to 2025-02-06 10:09:43.513001 (96.4 seconds. Delay: -1.0 seconds) and wrote 940 records for MGCJ5.COMEX 2025-02-06 10:09:42.477 | HD Request # 145 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:09:43.513001 2025-02-06 10:09:42.477 | HD Request # 145 | Completion time: 0s. 2025-02-06 10:09:42.477 | HD Request # 145 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 143 2025-02-06 10:09:42.477 | Removing historical data download ID 143. 2025-02-06 10:09:42.477 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:09:42.477 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:09:42.477 | HD Request # 145 | Enabling Intraday chart updating for symbol. 2025-02-06 10:09:42.477 | 2025-02-06 10:09:42.477 | Triggering next historical data download in queue. 2025-02-06 10:09:42.477 | HD Request # 146 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:09:42.477 | HD Request # 146 | Download start date-time: 2025-02-06 10:08:05.000000. File last date-time: 2025-02-06 10:08:05.000000 2025-02-06 10:09:42.477 | HD Request # 146 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:09:42.477 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:09:42.477 | Socket (4) | New receive buffer size: 0 2025-02-06 10:09:42.477 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:09:42.508 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:09:42.508 | Socket (5) | Closed. 2025-02-06 10:09:42.521 | HD Request # 146 | Sending historical data logon request message. 2025-02-06 10:09:42.664 | HD Request # 146 | Requesting Intraday data. Start date-time: 2025-02-06 10:08:05. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:09:42.710 | HD Request # 146 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:08:05.535000 2025-02-06 10:09:46.103 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:09:46.103 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:09:55.204 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:09:55.204 | DTC Client socket (2) | CloseSocket call. 2025-02-06 10:09:55.204 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 10:09:55.204 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 10:09:55.204 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:09:55.204 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:09:55.204 | DTC Client socket (2) | Closed. 2025-02-06 10:09:55.205 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:09:55.205 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:09:55.205 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:09:55.209 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:09:55.209 | Socket (4) | CloseSocket call. 2025-02-06 10:09:55.209 | Socket (0) | CloseSocket call. 2025-02-06 10:09:55.209 | Socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:09:55.209 | Socket (4) | Closed. 2025-02-06 10:09:55.210 | HD Request # 146 | Error downloading historical Intraday data for MYMH5.CBOT. The network socket has been closed. Retrying download. 2025-02-06 10:09:55.210 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:09:55.210 | Triggering next historical data download in queue. 2025-02-06 10:09:55.210 | Historical data download thread signaled to stop. 2025-02-06 10:09:55.210 | HD Request # 146 | Timestamp of first Intraday data file record written: 2025-02-06 10:08:05.535000. 2025-02-06 10:09:55.210 | HD Request # 146 | Received 304 Intraday data records from 2025-02-06 10:08:05.535000 to 2025-02-06 10:09:40.604000 (95.1 seconds. Delay: 14.6 seconds) and wrote 304 records for MYMH5.CBOT 2025-02-06 10:09:55.211 | HD Request # 146 | Completion time: 13s. 2025-02-06 10:09:55.211 | 2025-02-06 10:09:55.211 | HD Request # 147 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:09:55.219 | HD Request # 147 | Download start date-time: 2025-02-06 10:09:40.000000. File last date-time: 2025-02-06 10:09:40.604000 2025-02-06 10:09:55.219 | HD Request # 147 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:09:55.219 | Socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:09:55.220 | Socket (2) | New receive buffer size: 0 2025-02-06 10:09:55.220 | Socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:09:55.264 | HD Request # 147 | Sending historical data logon request message. 2025-02-06 10:09:55.394 | HD Request # 147 | Requesting Intraday data. Start date-time: 2025-02-06 10:09:40. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:09:55.440 | HD Request # 147 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:09:40.194000 2025-02-06 10:09:57.209 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:09:57.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:09:57.209 | DTC Client socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:09:57.210 | DTC Client socket (4) | New receive buffer size: 0 2025-02-06 10:09:57.210 | DTC Client socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:09:57.253 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:09:57.253 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:09:57.253 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:09:57.253 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:09:57.388 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:09:57.388 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:09:57.388 | Triggering next historical data download in queue. 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 10:09:57.388 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:09:57.388 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:09:57.388 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:09:57.428 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 10:09:57.428 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:09:57.460 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:09:57.460 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:09:57.470 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:10:41.884 | Socket (2) | CloseSocket call. 2025-02-06 10:10:41.884 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-06 10:10:41.884 | Historical data download thread signaled to stop. 2025-02-06 10:10:41.884 | HD Request # 147 | Timestamp of first Intraday data file record written: 2025-02-06 10:09:40.670000. 2025-02-06 10:10:41.884 | HD Request # 147 | Received 135 Intraday data records from 2025-02-06 10:09:40.194000 to 2025-02-06 10:09:55.585000 (15.4 seconds. Delay: 46.3 seconds) and wrote 97 records for MYMH5.CBOT 2025-02-06 10:10:41.893 | HD Request # 147 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:09:55.585000 2025-02-06 10:10:41.893 | Added 124 Time and Sales records to Intraday data file for MYMH5.CBOT after download. 2025-02-06 10:10:41.893 | HD Request # 147 | Completion time: 46s. 2025-02-06 10:10:41.893 | HD Request # 147 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 144 2025-02-06 10:10:41.893 | Removing historical data download ID 144. 2025-02-06 10:10:41.893 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 10:10:41.893 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 10:10:41.893 | HD Request # 147 | Enabling Intraday chart updating for symbol. 2025-02-06 10:10:41.893 | 2025-02-06 10:10:41.893 | Triggering next historical data download in queue. 2025-02-06 10:10:41.893 | HD Request # 148 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:10:41.894 | HD Request # 148 | Download start date-time: 2025-02-06 10:09:51.000000. File last date-time: 2025-02-06 10:09:51.000000 2025-02-06 10:10:41.894 | HD Request # 148 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:10:41.894 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:10:41.894 | Socket (5) | New receive buffer size: 0 2025-02-06 10:10:41.894 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:10:41.924 | Socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:10:41.924 | Socket (2) | Closed. 2025-02-06 10:10:41.939 | HD Request # 148 | Sending historical data logon request message. 2025-02-06 10:10:42.064 | HD Request # 148 | Requesting Intraday data. Start date-time: 2025-02-06 10:09:51. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:10:42.108 | HD Request # 148 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:09:51.665000 2025-02-06 10:10:42.149 | Socket (5) | CloseSocket call. 2025-02-06 10:10:42.149 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:10:42.149 | Historical data download thread signaled to stop. 2025-02-06 10:10:42.149 | HD Request # 148 | Timestamp of first Intraday data file record written: 2025-02-06 10:09:51.665000. 2025-02-06 10:10:42.149 | HD Request # 148 | Received 126 Intraday data records from 2025-02-06 10:09:51.665000 to 2025-02-06 10:10:41.869000 (50.2 seconds. Delay: 0.3 seconds) and wrote 126 records for MCLH5.NYMEX 2025-02-06 10:10:42.158 | HD Request # 148 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:10:41.869000 2025-02-06 10:10:42.158 | Added 3 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 10:10:42.158 | HD Request # 148 | Completion time: 1s. 2025-02-06 10:10:42.158 | HD Request # 148 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 145 2025-02-06 10:10:42.158 | Removing historical data download ID 145. 2025-02-06 10:10:42.158 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:10:42.158 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:10:42.158 | HD Request # 148 | Enabling Intraday chart updating for symbol. 2025-02-06 10:10:42.158 | 2025-02-06 10:10:42.158 | Triggering next historical data download in queue. 2025-02-06 10:10:42.158 | HD Request # 149 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:10:42.159 | HD Request # 149 | Download start date-time: 2025-02-06 10:09:54.000000. File last date-time: 2025-02-06 10:09:54.000001 2025-02-06 10:10:42.159 | HD Request # 149 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:10:42.159 | Socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:10:42.159 | Socket (2) | New receive buffer size: 0 2025-02-06 10:10:42.159 | Socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:10:42.190 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:10:42.190 | Socket (5) | Closed. 2025-02-06 10:10:42.202 | HD Request # 149 | Sending historical data logon request message. 2025-02-06 10:10:42.350 | HD Request # 149 | Requesting Intraday data. Start date-time: 2025-02-06 10:09:54. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:10:42.396 | HD Request # 149 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:09:54.035000 2025-02-06 10:10:42.476 | Socket (2) | CloseSocket call. 2025-02-06 10:10:42.476 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-02-06 10:10:42.476 | Historical data download thread signaled to stop. 2025-02-06 10:10:42.476 | HD Request # 149 | Timestamp of first Intraday data file record written: 2025-02-06 10:09:54.035000. 2025-02-06 10:10:42.476 | HD Request # 149 | Received 495 Intraday data records from 2025-02-06 10:09:54.035000 to 2025-02-06 10:10:43.558008 (49.5 seconds. Delay: -1.1 seconds) and wrote 495 records for MGCJ5.COMEX 2025-02-06 10:10:42.484 | HD Request # 149 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:10:43.558008 2025-02-06 10:10:42.484 | HD Request # 149 | Completion time: 0s. 2025-02-06 10:10:42.484 | HD Request # 149 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 146 2025-02-06 10:10:42.484 | Removing historical data download ID 146. 2025-02-06 10:10:42.484 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:10:42.484 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:10:42.484 | HD Request # 149 | Enabling Intraday chart updating for symbol. 2025-02-06 10:10:42.484 | 2025-02-06 10:10:42.484 | No download requests in the queue to start downloads for. 2025-02-06 10:10:42.516 | Socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:10:42.516 | Socket (2) | Closed. 2025-02-06 10:10:46.608 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:10:46.608 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:10:46.609 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 10:12:28.781 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-06 16:16:15 | Number times message added: 1 2025-02-06 10:13:40.864 | M2KH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 10:15:32.846 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:15:32.846 | DTC Client socket (4) | CloseSocket call. 2025-02-06 10:15:32.846 | DTC Client socket (4) | Max send buffers used during socket life: 3 2025-02-06 10:15:32.846 | DTC Client socket (4) | Max send buffer size during socket life: 831 2025-02-06 10:15:32.846 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:15:32.846 | DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:15:32.846 | DTC Client socket (4) | Closed. 2025-02-06 10:15:32.847 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:15:32.847 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:15:32.847 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:15:34.847 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:15:34.847 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:15:34.939 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:15:34.940 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:15:34.940 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:15:34.984 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:15:34.984 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:15:34.984 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:15:34.984 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:15:35.111 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:15:35.111 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:15:35.111 | Triggering next historical data download in queue. 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 10:15:35.111 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:15:35.111 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:15:35.111 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:15:35.111 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 10:15:35.111 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:15:35.111 | HD Request # 150 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:15:35.112 | HD Request # 150 | Download start date-time: 2025-02-06 10:15:27.000000. File last date-time: 2025-02-06 10:15:27.000000 2025-02-06 10:15:35.112 | HD Request # 150 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:15:35.112 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:15:35.112 | Socket (4) | New receive buffer size: 0 2025-02-06 10:15:35.112 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:15:35.152 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 10:15:35.153 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:15:35.154 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:15:35.154 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:15:35.155 | HD Request # 150 | Sending historical data logon request message. 2025-02-06 10:15:35.200 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:15:35.279 | HD Request # 150 | Requesting Intraday data. Start date-time: 2025-02-06 10:15:27. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:15:39.992 | HD Request # 150 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:15:27.390000 2025-02-06 10:15:39.992 | Socket (4) | CloseSocket call. 2025-02-06 10:15:39.992 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:15:39.992 | Historical data download thread signaled to stop. 2025-02-06 10:15:39.992 | HD Request # 150 | Timestamp of first Intraday data file record written: 2025-02-06 10:15:27.390000. 2025-02-06 10:15:39.993 | HD Request # 150 | Received 2 Intraday data records from 2025-02-06 10:15:27.390000 to 2025-02-06 10:15:34.934000 (7.5 seconds. Delay: 5.1 seconds) and wrote 2 records for MCLH5.NYMEX 2025-02-06 10:15:40.001 | HD Request # 150 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:15:34.934000 2025-02-06 10:15:40.001 | Added 6 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 10:15:40.001 | HD Request # 150 | Completion time: 5s. 2025-02-06 10:15:40.001 | HD Request # 150 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 147 2025-02-06 10:15:40.001 | Removing historical data download ID 147. 2025-02-06 10:15:40.001 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:15:40.001 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:15:40.001 | HD Request # 150 | Enabling Intraday chart updating for symbol. 2025-02-06 10:15:40.001 | 2025-02-06 10:15:40.001 | Triggering next historical data download in queue. 2025-02-06 10:15:40.001 | HD Request # 151 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:15:40.001 | HD Request # 151 | Download start date-time: 2025-02-06 10:15:32.000000. File last date-time: 2025-02-06 10:15:32.000000 2025-02-06 10:15:40.001 | HD Request # 151 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:15:40.001 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:15:40.002 | Socket (5) | New receive buffer size: 0 2025-02-06 10:15:40.002 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:15:40.032 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:15:40.032 | Socket (4) | Closed. 2025-02-06 10:15:40.045 | HD Request # 151 | Sending historical data logon request message. 2025-02-06 10:15:40.171 | HD Request # 151 | Requesting Intraday data. Start date-time: 2025-02-06 10:15:32. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:15:40.219 | HD Request # 151 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:15:32.076000 2025-02-06 10:15:49.150 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:16:08.497 | Socket (5) | CloseSocket call. 2025-02-06 10:16:08.497 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:16:08.497 | Historical data download thread signaled to stop. 2025-02-06 10:16:08.497 | HD Request # 151 | Timestamp of first Intraday data file record written: 2025-02-06 10:15:32.076000. 2025-02-06 10:16:08.498 | HD Request # 151 | Received 108 Intraday data records from 2025-02-06 10:15:32.076000 to 2025-02-06 10:15:41.277000 (9.2 seconds. Delay: 27.2 seconds) and wrote 108 records for MGCJ5.COMEX 2025-02-06 10:16:08.506 | HD Request # 151 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:15:41.277000 2025-02-06 10:16:08.506 | Added 124 Time and Sales records to Intraday data file for MGCJ5.COMEX after download. 2025-02-06 10:16:08.506 | HD Request # 151 | Completion time: 28s. 2025-02-06 10:16:08.506 | HD Request # 151 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 148 2025-02-06 10:16:08.506 | Removing historical data download ID 148. 2025-02-06 10:16:08.506 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:16:08.506 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:16:08.506 | HD Request # 151 | Enabling Intraday chart updating for symbol. 2025-02-06 10:16:08.506 | 2025-02-06 10:16:08.506 | Triggering next historical data download in queue. 2025-02-06 10:16:08.506 | HD Request # 152 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:16:08.507 | HD Request # 152 | Download start date-time: 2025-02-06 10:15:31.000000. File last date-time: 2025-02-06 10:15:31.000001 2025-02-06 10:16:08.507 | HD Request # 152 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:16:08.507 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:16:08.507 | Socket (4) | New receive buffer size: 0 2025-02-06 10:16:08.507 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:16:08.538 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:16:08.538 | Socket (5) | Closed. 2025-02-06 10:16:08.552 | HD Request # 152 | Sending historical data logon request message. 2025-02-06 10:16:08.678 | HD Request # 152 | Requesting Intraday data. Start date-time: 2025-02-06 10:15:31. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:16:08.723 | HD Request # 152 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:15:31.712000 2025-02-06 10:16:08.762 | Socket (4) | CloseSocket call. 2025-02-06 10:16:08.762 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:16:08.762 | Historical data download thread signaled to stop. 2025-02-06 10:16:08.762 | HD Request # 152 | Timestamp of first Intraday data file record written: 2025-02-06 10:15:31.712000. 2025-02-06 10:16:08.763 | HD Request # 152 | Received 103 Intraday data records from 2025-02-06 10:15:31.712000 to 2025-02-06 10:16:08.447000 (36.7 seconds. Delay: 0.3 seconds) and wrote 103 records for MYMH5.CBOT 2025-02-06 10:16:08.771 | HD Request # 152 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:16:08.447000 2025-02-06 10:16:08.771 | HD Request # 152 | Completion time: 0s. 2025-02-06 10:16:08.771 | HD Request # 152 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 149 2025-02-06 10:16:08.771 | Removing historical data download ID 149. 2025-02-06 10:16:08.771 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 10:16:08.771 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 10:16:08.771 | HD Request # 152 | Enabling Intraday chart updating for symbol. 2025-02-06 10:16:08.771 | 2025-02-06 10:16:08.771 | No download requests in the queue to start downloads for. 2025-02-06 10:16:08.802 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:16:08.802 | Socket (4) | Closed. 2025-02-06 10:16:09.329 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:16:09.329 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 10:16:42.954 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:16:42.954 | DTC Client socket (2) | CloseSocket call. 2025-02-06 10:16:42.954 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 10:16:42.954 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 10:16:42.954 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:16:42.954 | DTC Client socket (2) | Closed. 2025-02-06 10:16:42.955 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:16:42.955 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:16:42.955 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:16:42.955 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:16:44.964 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:16:44.964 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:16:44.965 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:16:44.965 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:16:44.965 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:16:45.010 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:16:45.010 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:16:45.010 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:16:45.010 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:16:45.136 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:16:45.136 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:16:45.136 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:16:45.136 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:16:45.136 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:16:45.136 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:16:45.136 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:16:45.137 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:16:45.137 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:16:45.137 | Triggering next historical data download in queue. 2025-02-06 10:16:45.137 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX. Market Depth data restarted. 2025-02-06 10:16:45.137 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:16:45.137 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:16:45.137 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:16:45.137 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:16:45.137 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 10:16:45.137 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:16:45.137 | HD Request # 153 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:16:45.137 | HD Request # 153 | Download start date-time: 2025-02-06 10:16:36.000000. File last date-time: 2025-02-06 10:16:36.000000 2025-02-06 10:16:45.137 | HD Request # 153 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:16:45.138 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:16:45.138 | Socket (4) | New receive buffer size: 0 2025-02-06 10:16:45.138 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:16:45.176 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 10:16:45.177 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:16:45.180 | HD Request # 153 | Sending historical data logon request message. 2025-02-06 10:16:45.207 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:16:45.207 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:16:45.208 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:16:45.310 | HD Request # 153 | Requesting Intraday data. Start date-time: 2025-02-06 10:16:36. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:17:54.642 | HD Request # 153 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:16:36.796000 2025-02-06 10:17:54.642 | Socket (4) | CloseSocket call. 2025-02-06 10:17:54.642 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:17:54.643 | Historical data download thread signaled to stop. 2025-02-06 10:17:54.643 | HD Request # 153 | Timestamp of first Intraday data file record written: 2025-02-06 10:16:36.796000. 2025-02-06 10:17:54.643 | HD Request # 153 | Received 8 Intraday data records from 2025-02-06 10:16:36.796000 to 2025-02-06 10:16:45.063000 (8.3 seconds. Delay: 69.6 seconds) and wrote 8 records for MCLH5.NYMEX 2025-02-06 10:17:54.677 | HD Request # 153 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:16:45.063000 2025-02-06 10:17:54.677 | Added 45 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 10:17:54.677 | HD Request # 153 | Completion time: 1m 9s. 2025-02-06 10:17:54.677 | HD Request # 153 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 150 2025-02-06 10:17:54.677 | Removing historical data download ID 150. 2025-02-06 10:17:54.677 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:17:54.677 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:17:54.677 | HD Request # 153 | Enabling Intraday chart updating for symbol. 2025-02-06 10:17:54.677 | 2025-02-06 10:17:54.677 | Triggering next historical data download in queue. 2025-02-06 10:17:54.677 | HD Request # 154 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:17:54.677 | HD Request # 154 | Download start date-time: 2025-02-06 10:16:41.000000. File last date-time: 2025-02-06 10:16:41.000004 2025-02-06 10:17:54.677 | HD Request # 154 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:17:54.677 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:17:54.678 | Socket (5) | New receive buffer size: 0 2025-02-06 10:17:54.678 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:17:54.683 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:17:54.683 | Socket (4) | Closed. 2025-02-06 10:17:54.721 | HD Request # 154 | Sending historical data logon request message. 2025-02-06 10:17:54.854 | HD Request # 154 | Requesting Intraday data. Start date-time: 2025-02-06 10:16:41. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:17:54.898 | HD Request # 154 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:16:41.148000 2025-02-06 10:17:54.979 | Socket (5) | CloseSocket call. 2025-02-06 10:17:54.979 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:17:54.979 | Historical data download thread signaled to stop. 2025-02-06 10:17:54.979 | HD Request # 154 | Timestamp of first Intraday data file record written: 2025-02-06 10:16:41.148000. 2025-02-06 10:17:54.979 | HD Request # 154 | Received 548 Intraday data records from 2025-02-06 10:16:41.148000 to 2025-02-06 10:17:55.032001 (73.9 seconds. Delay: -0.1 seconds) and wrote 548 records for MGCJ5.COMEX 2025-02-06 10:17:54.994 | HD Request # 154 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:17:55.032001 2025-02-06 10:17:54.994 | HD Request # 154 | Completion time: 0s. 2025-02-06 10:17:54.994 | HD Request # 154 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 151 2025-02-06 10:17:54.994 | Removing historical data download ID 151. 2025-02-06 10:17:54.994 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:17:54.994 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:17:54.994 | HD Request # 154 | Enabling Intraday chart updating for symbol. 2025-02-06 10:17:54.994 | 2025-02-06 10:17:54.994 | Triggering next historical data download in queue. 2025-02-06 10:17:54.994 | HD Request # 155 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:17:54.994 | HD Request # 155 | Download start date-time: 2025-02-06 10:16:42.000000. File last date-time: 2025-02-06 10:16:42.000000 2025-02-06 10:17:54.994 | HD Request # 155 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:17:54.994 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:17:54.994 | Socket (4) | New receive buffer size: 0 2025-02-06 10:17:54.994 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:17:55.019 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:17:55.019 | Socket (5) | Closed. 2025-02-06 10:17:55.038 | HD Request # 155 | Sending historical data logon request message. 2025-02-06 10:17:55.168 | HD Request # 155 | Requesting Intraday data. Start date-time: 2025-02-06 10:16:42. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:17:55.179 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:17:55.214 | HD Request # 155 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:16:42.071000 2025-02-06 10:17:55.254 | Socket (4) | CloseSocket call. 2025-02-06 10:17:55.254 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:17:55.254 | Historical data download thread signaled to stop. 2025-02-06 10:17:55.254 | HD Request # 155 | Timestamp of first Intraday data file record written: 2025-02-06 10:16:42.071000. 2025-02-06 10:17:55.254 | HD Request # 155 | Received 128 Intraday data records from 2025-02-06 10:16:42.071000 to 2025-02-06 10:17:56.177000 (74.1 seconds. Delay: -0.9 seconds) and wrote 128 records for MYMH5.CBOT 2025-02-06 10:17:55.270 | HD Request # 155 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:17:56.177000 2025-02-06 10:17:55.270 | HD Request # 155 | Completion time: 1s. 2025-02-06 10:17:55.270 | HD Request # 155 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 152 2025-02-06 10:17:55.270 | Removing historical data download ID 152. 2025-02-06 10:17:55.270 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 10:17:55.270 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 10:17:55.270 | HD Request # 155 | Enabling Intraday chart updating for symbol. 2025-02-06 10:17:55.270 | 2025-02-06 10:17:55.270 | No download requests in the queue to start downloads for. 2025-02-06 10:17:55.293 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:17:55.293 | Socket (4) | Closed. 2025-02-06 10:18:00.247 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:18:00.248 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 10:18:50.277 | MNQH5.CME[M] 1 Min #14 | Reloading chart. 2025-02-06 10:18:50.316 | Unsubscribed from market depth data for MESH5.CME 2025-02-06 10:18:50.316 | Mapping MNQH5.CME to MNQH25. Service code: cme 2025-02-06 10:18:50.317 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 8 Service code: cme 2025-02-06 10:18:50.317 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 8 2025-02-06 10:18:50.317 | Requesting market depth updates for: MNQH5.CME if supported. NumLevels=100 2025-02-06 10:18:50.424 | Denali Data Feed | Clearing market depth for MNQH5.CME 2025-02-06 10:18:50.424 | Denali Data Feed | Received security definition for symbol MNQH5.CME 2025-02-06 10:18:50.768 | Added historical Intraday data request for MNQH5.CME to the queue. 2025-02-06 10:18:50.768 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'. 2025-02-06 10:18:50.768 | Triggering next historical data download in queue. 2025-02-06 10:18:50.768 | Delaying start of download for MNQH5.CME. 2025-02-06 10:18:51.272 | MNQH5.CME[M] 1 Min #14 | StartDateTimeForLoadingOrderFills: 2025-01-16 11:57:52 2025-02-06 10:18:51.274 | MNQH5.CME[M] 1 Min #14 | Chart data loading complete. 2025-02-06 10:18:55.507 | HD Request # 156 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme 2025-02-06 10:18:55.507 | HD Request # 156 | Download start date-time: 2025-01-30 11:57:52.000000. File last date-time: 2025-01-30 11:57:52.248000 2025-02-06 10:18:55.508 | HD Request # 156 | Using server: ds26.sierracharts.com port 10150 2025-02-06 10:18:55.656 | Socket (4) | Creating socket. 2025-02-06 10:18:55.656 | Socket (4) | New receive buffer size: 0 2025-02-06 10:18:55.656 | Socket (4) | Connecting to IP: 64.152.155.17. 2025-02-06 10:18:55.724 | HD Request # 156 | Setting DTC encoding to Binary VLS 2025-02-06 10:18:55.724 | HD Request # 156 | Sending historical data logon request message. 2025-02-06 10:18:55.816 | HD Request # 156 | Requesting Intraday data. Start date-time: 2025-01-30 11:57:52. Record interval: 0. Symbol: MNQH25 2025-02-06 10:18:55.845 | HD Request # 156 | Decompressing data. 2025-02-06 10:18:55.884 | HD Request # 156 | Receiving Intraday data for MNQH5.CME starting at 2025-01-30 11:57:52.076000 2025-02-06 10:18:56.040 | HD Request # 156 | Timestamp of first Intraday data file record written: 2025-01-30 11:57:52.453000. 2025-02-06 10:19:06.856 | Socket (4) | CloseSocket call. 2025-02-06 10:19:06.856 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:19:06.892 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:19:06.892 | Socket (4) | Closed. 2025-02-06 10:19:06.941 | Historical data download thread signaled to stop. 2025-02-06 10:19:06.941 | HD Request # 156 | Received 7272041 Intraday data records from 2025-01-30 11:57:52.076000 to 2025-02-06 10:19:05.378000 (6.9 days. Delay: 1.6 seconds) and wrote 7272037 records for MNQH5.CME 2025-02-06 10:19:06.949 | HD Request # 156 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:19:05.378000 2025-02-06 10:19:06.949 | Added 243 Time and Sales records to Intraday data file for MNQH5.CME after download. 2025-02-06 10:19:06.950 | HD Request # 156 | Completion time: 11s. 2025-02-06 10:19:06.950 | HD Request # 156 | Intraday data download complete for MNQH5.CME. Unique request ID: 153 2025-02-06 10:19:06.950 | Removing historical data download ID 153. 2025-02-06 10:19:06.950 | Real-time Intraday chart data file updates started for MNQH5.CME 2025-02-06 10:19:06.950 | Intraday chart data file opened for MNQH5.CME 2025-02-06 10:19:06.950 | HD Request # 156 | Enabling Intraday chart updating for symbol. 2025-02-06 10:19:06.950 | 2025-02-06 10:19:06.950 | No download requests in the queue to start downloads for. 2025-02-06 10:19:09.638 | MNQH5.CME[M] 1 Min #11 | Reloading chart. 2025-02-06 10:19:10.196 | Unsubscribed from market depth data for M2KH5.CME 2025-02-06 10:19:10.833 | Opened cached Intraday file: D:\SierraChart\Data\MNQH5.CME.scid. Thread ID: 22756 2025-02-06 10:19:12.051 | MNQH5.CME[M] 1 Min #11 | StartDateTimeForLoadingOrderFills: 2025-01-23 10:19:13 2025-02-06 10:19:12.061 | MNQH5.CME[M] 1 Min #11 | Chart data loading complete. 2025-02-06 10:19:17.046 | MNQH5.CME[M] 15 Sec #11 | Reloading chart. 2025-02-06 10:19:19.310 | MNQH5.CME[M] 15 Sec #11 | StartDateTimeForLoadingOrderFills: 2025-01-23 10:19:20 2025-02-06 10:19:19.325 | MNQH5.CME[M] 15 Sec #11 | Chart data loading complete. 2025-02-06 10:33:43.438 | RTYH5.CME 5 Min #2 | Reloading chart. 2025-02-06 10:33:44.037 | RTYH5.CME[M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 10:33:44.040 | RTYH5.CME[M] 5 Min #2 | Chart data loading complete. 2025-02-06 10:33:45.192 | Unsubscribed from market depth data for MCLH5.NYMEX 2025-02-06 10:33:45.192 | Requesting market depth updates for: RTYH5.CME if supported. NumLevels=100 2025-02-06 10:33:45.232 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MCLH5.NYMEX. permission denied 2025-02-06 10:33:45.273 | Denali Data Feed | Clearing market depth for RTYH5.CME 2025-02-06 10:33:54.923 | RTYH5.CME[M] 15 Sec #2 | Reloading chart. 2025-02-06 10:33:55.554 | RTYH5.CME[M] 15 Sec #2 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:15:00 2025-02-06 10:33:55.571 | RTYH5.CME[M] 15 Sec #2 | Chart data loading complete. 2025-02-06 10:34:45.737 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:34:45.737 | DTC Client socket (2) | CloseSocket call. 2025-02-06 10:34:45.737 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 10:34:45.737 | DTC Client socket (2) | Max send buffer size during socket life: 831 2025-02-06 10:34:45.737 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:34:45.737 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:34:45.737 | DTC Client socket (2) | Closed. 2025-02-06 10:34:45.738 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:34:45.738 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:34:45.738 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:34:47.737 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:34:47.737 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:34:47.811 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:34:47.811 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:34:47.811 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:34:47.857 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:34:47.857 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:34:47.857 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:34:47.857 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:34:47.984 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:34:47.984 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:34:47.984 | Triggering next historical data download in queue. 2025-02-06 10:34:47.984 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX 2025-02-06 10:34:47.985 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:34:47.985 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:34:47.985 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:34:47.985 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:34:47.985 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 10:34:47.985 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:34:47.985 | HD Request # 157 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:34:47.993 | HD Request # 157 | Download start date-time: 2025-02-06 10:34:43.000000. File last date-time: 2025-02-06 10:34:43.000000 2025-02-06 10:34:47.993 | HD Request # 157 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:34:47.993 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:34:47.993 | Socket (4) | New receive buffer size: 0 2025-02-06 10:34:47.993 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:34:48.027 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:34:48.036 | HD Request # 157 | Sending historical data logon request message. 2025-02-06 10:34:48.049 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:34:48.049 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:34:48.169 | HD Request # 157 | Requesting Intraday data. Start date-time: 2025-02-06 10:34:43. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:34:48.214 | HD Request # 157 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:34:43.413000 2025-02-06 10:34:48.254 | Socket (4) | CloseSocket call. 2025-02-06 10:34:48.254 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:34:48.254 | Historical data download thread signaled to stop. 2025-02-06 10:34:48.254 | HD Request # 157 | Timestamp of first Intraday data file record written: 2025-02-06 10:34:43.413000. 2025-02-06 10:34:48.254 | HD Request # 157 | Received 10 Intraday data records from 2025-02-06 10:34:43.413000 to 2025-02-06 10:34:49.416000 (6.0 seconds. Delay: -1.2 seconds) and wrote 10 records for MCLH5.NYMEX 2025-02-06 10:34:48.263 | HD Request # 157 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:34:49.416000 2025-02-06 10:34:48.263 | HD Request # 157 | Completion time: 1s. 2025-02-06 10:34:48.263 | HD Request # 157 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 154 2025-02-06 10:34:48.263 | Removing historical data download ID 154. 2025-02-06 10:34:48.263 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:34:48.263 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:34:48.263 | HD Request # 157 | Enabling Intraday chart updating for symbol. 2025-02-06 10:34:48.263 | 2025-02-06 10:34:48.263 | Triggering next historical data download in queue. 2025-02-06 10:34:48.263 | HD Request # 158 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:34:48.263 | HD Request # 158 | Download start date-time: 2025-02-06 10:34:44.000000. File last date-time: 2025-02-06 10:34:44.000000 2025-02-06 10:34:48.263 | HD Request # 158 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:34:48.264 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:34:48.264 | Socket (5) | New receive buffer size: 0 2025-02-06 10:34:48.264 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:34:48.289 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:34:48.293 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:34:48.293 | Socket (4) | Closed. 2025-02-06 10:34:48.306 | HD Request # 158 | Sending historical data logon request message. 2025-02-06 10:34:48.430 | HD Request # 158 | Requesting Intraday data. Start date-time: 2025-02-06 10:34:44. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:34:48.473 | HD Request # 158 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:34:44.463000 2025-02-06 10:34:48.512 | Socket (5) | CloseSocket call. 2025-02-06 10:34:48.512 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:34:48.512 | Historical data download thread signaled to stop. 2025-02-06 10:34:48.512 | HD Request # 158 | Timestamp of first Intraday data file record written: 2025-02-06 10:34:44.463000. 2025-02-06 10:34:48.512 | HD Request # 158 | Received 21 Intraday data records from 2025-02-06 10:34:44.463000 to 2025-02-06 10:34:49.584004 (5.1 seconds. Delay: -1.1 seconds) and wrote 21 records for MGCJ5.COMEX 2025-02-06 10:34:48.520 | HD Request # 158 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:34:49.584004 2025-02-06 10:34:48.521 | HD Request # 158 | Completion time: 0s. 2025-02-06 10:34:48.521 | HD Request # 158 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 155 2025-02-06 10:34:48.521 | Removing historical data download ID 155. 2025-02-06 10:34:48.521 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:34:48.521 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:34:48.521 | HD Request # 158 | Enabling Intraday chart updating for symbol. 2025-02-06 10:34:48.521 | 2025-02-06 10:34:48.521 | Triggering next historical data download in queue. 2025-02-06 10:34:48.521 | HD Request # 159 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:34:48.521 | HD Request # 159 | Download start date-time: 2025-02-06 10:34:44.000000. File last date-time: 2025-02-06 10:34:44.000004 2025-02-06 10:34:48.522 | HD Request # 159 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:34:48.522 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:34:48.522 | Socket (4) | New receive buffer size: 0 2025-02-06 10:34:48.522 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:34:48.552 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:34:48.552 | Socket (5) | Closed. 2025-02-06 10:34:48.565 | HD Request # 159 | Sending historical data logon request message. 2025-02-06 10:34:48.692 | HD Request # 159 | Requesting Intraday data. Start date-time: 2025-02-06 10:34:44. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:34:48.743 | HD Request # 159 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:34:44.015000 2025-02-06 10:34:48.783 | Socket (4) | CloseSocket call. 2025-02-06 10:34:48.783 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:34:48.784 | Historical data download thread signaled to stop. 2025-02-06 10:34:48.784 | HD Request # 159 | Timestamp of first Intraday data file record written: 2025-02-06 10:34:44.015000. 2025-02-06 10:34:48.784 | HD Request # 159 | Received 106 Intraday data records from 2025-02-06 10:34:44.015000 to 2025-02-06 10:34:49.472000 (5.5 seconds. Delay: -0.7 seconds) and wrote 106 records for MYMH5.CBOT 2025-02-06 10:34:48.792 | HD Request # 159 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:34:49.472000 2025-02-06 10:34:48.792 | HD Request # 159 | Completion time: 0s. 2025-02-06 10:34:48.792 | HD Request # 159 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 156 2025-02-06 10:34:48.792 | Removing historical data download ID 156. 2025-02-06 10:34:48.792 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 10:34:48.792 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 10:34:48.792 | HD Request # 159 | Enabling Intraday chart updating for symbol. 2025-02-06 10:34:48.792 | 2025-02-06 10:34:48.792 | No download requests in the queue to start downloads for. 2025-02-06 10:34:48.825 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:34:48.825 | Socket (4) | Closed. 2025-02-06 10:34:49.396 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:34:49.397 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:34:49.397 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 10:42:15.408 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:42:15.408 | DTC Client socket (2) | CloseSocket call. 2025-02-06 10:42:15.408 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 10:42:15.408 | DTC Client socket (2) | Max send buffer size during socket life: 735 2025-02-06 10:42:15.408 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:42:15.408 | DTC Client socket (2) | Closed. 2025-02-06 10:42:15.409 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:42:15.409 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:42:15.409 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:42:15.409 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:42:17.414 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:42:17.414 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:42:17.456 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:42:17.456 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:42:17.456 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:42:17.502 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:42:17.502 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:42:17.502 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:42:17.502 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:42:17.629 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:42:17.629 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:42:17.629 | Triggering next historical data download in queue. 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX 2025-02-06 10:42:17.629 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:42:17.629 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:42:17.629 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:42:17.629 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 10:42:17.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:42:17.629 | HD Request # 160 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:42:17.639 | HD Request # 160 | Download start date-time: 2025-02-06 10:42:14.000000. File last date-time: 2025-02-06 10:42:14.000001 2025-02-06 10:42:17.639 | HD Request # 160 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:42:17.639 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:42:17.639 | Socket (4) | New receive buffer size: 0 2025-02-06 10:42:17.639 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:42:17.669 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:42:17.672 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:42:17.673 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:42:17.673 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:42:17.681 | HD Request # 160 | Sending historical data logon request message. 2025-02-06 10:42:17.809 | HD Request # 160 | Requesting Intraday data. Start date-time: 2025-02-06 10:42:14. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:43:12.829 | HD Request # 160 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:42:14.480000 2025-02-06 10:43:12.869 | Socket (4) | CloseSocket call. 2025-02-06 10:43:12.869 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:43:12.870 | Historical data download thread signaled to stop. 2025-02-06 10:43:12.870 | HD Request # 160 | Timestamp of first Intraday data file record written: 2025-02-06 10:42:14.480000. 2025-02-06 10:43:12.870 | HD Request # 160 | Received 16 Intraday data records from 2025-02-06 10:42:14.480000 to 2025-02-06 10:42:18.000000 (3.5 seconds. Delay: 54.9 seconds) and wrote 16 records for MCLH5.NYMEX 2025-02-06 10:43:12.908 | HD Request # 160 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:42:18.000000 2025-02-06 10:43:12.908 | Added 106 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 10:43:12.908 | HD Request # 160 | Completion time: 55s. 2025-02-06 10:43:12.908 | HD Request # 160 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 157 2025-02-06 10:43:12.908 | Removing historical data download ID 157. 2025-02-06 10:43:12.908 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:43:12.908 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:43:12.908 | HD Request # 160 | Enabling Intraday chart updating for symbol. 2025-02-06 10:43:12.908 | 2025-02-06 10:43:12.908 | Triggering next historical data download in queue. 2025-02-06 10:43:12.908 | HD Request # 161 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:43:12.909 | HD Request # 161 | Download start date-time: 2025-02-06 10:42:14.000000. File last date-time: 2025-02-06 10:42:14.000004 2025-02-06 10:43:12.909 | HD Request # 161 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:43:12.909 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:43:12.909 | Socket (5) | New receive buffer size: 0 2025-02-06 10:43:12.909 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:43:12.914 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:43:12.914 | Socket (4) | Closed. 2025-02-06 10:43:12.952 | HD Request # 161 | Sending historical data logon request message. 2025-02-06 10:43:13.081 | HD Request # 161 | Requesting Intraday data. Start date-time: 2025-02-06 10:42:14. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:43:13.126 | HD Request # 161 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:42:14.021000 2025-02-06 10:43:13.167 | Socket (5) | CloseSocket call. 2025-02-06 10:43:13.167 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:43:13.167 | Historical data download thread signaled to stop. 2025-02-06 10:43:13.167 | HD Request # 161 | Timestamp of first Intraday data file record written: 2025-02-06 10:42:14.021000. 2025-02-06 10:43:13.168 | HD Request # 161 | Received 324 Intraday data records from 2025-02-06 10:42:14.021000 to 2025-02-06 10:43:14.249000 (60.2 seconds. Delay: -1.1 seconds) and wrote 324 records for MGCJ5.COMEX 2025-02-06 10:43:13.182 | HD Request # 161 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:43:14.249000 2025-02-06 10:43:13.182 | HD Request # 161 | Completion time: 1s. 2025-02-06 10:43:13.182 | HD Request # 161 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 158 2025-02-06 10:43:13.182 | Removing historical data download ID 158. 2025-02-06 10:43:13.182 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:43:13.182 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:43:13.182 | HD Request # 161 | Enabling Intraday chart updating for symbol. 2025-02-06 10:43:13.182 | 2025-02-06 10:43:13.182 | Triggering next historical data download in queue. 2025-02-06 10:43:13.183 | HD Request # 162 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:43:13.183 | HD Request # 162 | Download start date-time: 2025-02-06 10:42:14.000000. File last date-time: 2025-02-06 10:42:14.000003 2025-02-06 10:43:13.183 | HD Request # 162 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:43:13.183 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:43:13.183 | Socket (4) | New receive buffer size: 0 2025-02-06 10:43:13.183 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:43:13.208 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:43:13.208 | Socket (5) | Closed. 2025-02-06 10:43:13.226 | HD Request # 162 | Sending historical data logon request message. 2025-02-06 10:43:13.351 | HD Request # 162 | Requesting Intraday data. Start date-time: 2025-02-06 10:42:14. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:43:13.400 | HD Request # 162 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:42:14.481000 2025-02-06 10:43:13.441 | Socket (4) | CloseSocket call. 2025-02-06 10:43:13.441 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:43:13.441 | Historical data download thread signaled to stop. 2025-02-06 10:43:13.441 | HD Request # 162 | Timestamp of first Intraday data file record written: 2025-02-06 10:42:14.481000. 2025-02-06 10:43:13.441 | HD Request # 162 | Received 200 Intraday data records from 2025-02-06 10:42:14.481000 to 2025-02-06 10:43:14.444000 (60.0 seconds. Delay: -1.0 seconds) and wrote 200 records for MYMH5.CBOT 2025-02-06 10:43:13.457 | HD Request # 162 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:43:14.444000 2025-02-06 10:43:13.457 | HD Request # 162 | Completion time: 0s. 2025-02-06 10:43:13.457 | HD Request # 162 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 159 2025-02-06 10:43:13.457 | Removing historical data download ID 159. 2025-02-06 10:43:13.457 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 10:43:13.457 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 10:43:13.457 | HD Request # 162 | Enabling Intraday chart updating for symbol. 2025-02-06 10:43:13.457 | 2025-02-06 10:43:13.457 | No download requests in the queue to start downloads for. 2025-02-06 10:43:13.481 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:43:13.481 | Socket (4) | Closed. 2025-02-06 10:43:13.832 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:43:13.832 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:43:18.877 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 10:44:51.125 | MGCJ5.COMEX 15 Sec #6 | Reloading chart. 2025-02-06 10:44:52.819 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:16:00 2025-02-06 10:44:52.830 | MGCJ5.COMEX 15 Sec #6 | Chart data loading complete. 2025-02-06 10:48:05.941 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:48:05.941 | DTC Client socket (2) | CloseSocket call. 2025-02-06 10:48:05.941 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 10:48:05.941 | DTC Client socket (2) | Max send buffer size during socket life: 735 2025-02-06 10:48:05.941 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:48:05.941 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:48:05.941 | DTC Client socket (2) | Closed. 2025-02-06 10:48:05.942 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:48:05.942 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:48:05.942 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:48:07.945 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:48:07.945 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:48:07.988 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:48:07.988 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:48:07.988 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:48:08.034 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:48:08.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:48:08.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:48:08.034 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:48:08.160 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:48:08.160 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:48:08.160 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:48:08.160 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:48:08.160 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:48:08.160 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:48:08.160 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:48:08.161 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:48:08.161 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:48:08.161 | Triggering next historical data download in queue. 2025-02-06 10:48:08.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX 2025-02-06 10:48:08.161 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:48:08.161 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:48:08.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:48:08.161 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:48:08.161 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 10:48:08.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:48:08.161 | HD Request # 163 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:48:08.169 | HD Request # 163 | Download start date-time: 2025-02-06 10:48:04.000000. File last date-time: 2025-02-06 10:48:04.000000 2025-02-06 10:48:08.169 | HD Request # 163 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:48:08.169 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:48:08.169 | Socket (4) | New receive buffer size: 0 2025-02-06 10:48:08.169 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:48:08.202 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:48:08.204 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:48:08.204 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:48:08.204 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:48:08.212 | HD Request # 163 | Sending historical data logon request message. 2025-02-06 10:48:08.340 | HD Request # 163 | Requesting Intraday data. Start date-time: 2025-02-06 10:48:04. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:48:38.978 | HD Request # 163 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:48:04.358000 2025-02-06 10:48:38.979 | Socket (4) | CloseSocket call. 2025-02-06 10:48:38.979 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:48:38.979 | Historical data download thread signaled to stop. 2025-02-06 10:48:38.979 | HD Request # 163 | Timestamp of first Intraday data file record written: 2025-02-06 10:48:04.358000. 2025-02-06 10:48:38.979 | HD Request # 163 | Received 3 Intraday data records from 2025-02-06 10:48:04.358000 to 2025-02-06 10:48:08.034000 (3.7 seconds. Delay: 30.9 seconds) and wrote 3 records for MCLH5.NYMEX 2025-02-06 10:48:38.987 | HD Request # 163 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:48:08.034000 2025-02-06 10:48:38.987 | Added 20 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 10:48:38.988 | HD Request # 163 | Completion time: 30s. 2025-02-06 10:48:38.988 | HD Request # 163 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 160 2025-02-06 10:48:38.988 | Removing historical data download ID 160. 2025-02-06 10:48:38.988 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:48:38.988 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:48:38.988 | HD Request # 163 | Enabling Intraday chart updating for symbol. 2025-02-06 10:48:38.988 | 2025-02-06 10:48:38.988 | Triggering next historical data download in queue. 2025-02-06 10:48:38.988 | HD Request # 164 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:48:38.988 | HD Request # 164 | Download start date-time: 2025-02-06 10:48:04.000000. File last date-time: 2025-02-06 10:48:04.000003 2025-02-06 10:48:38.988 | HD Request # 164 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:48:38.988 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:48:38.988 | Socket (5) | New receive buffer size: 0 2025-02-06 10:48:38.988 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:48:39.019 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:48:39.019 | Socket (4) | Closed. 2025-02-06 10:48:39.034 | HD Request # 164 | Sending historical data logon request message. 2025-02-06 10:48:39.164 | HD Request # 164 | Requesting Intraday data. Start date-time: 2025-02-06 10:48:04. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:48:39.239 | HD Request # 164 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:48:04.230000 2025-02-06 10:48:41.634 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:49:15.033 | Socket (5) | CloseSocket call. 2025-02-06 10:49:15.033 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:49:15.039 | Historical data download thread signaled to stop. 2025-02-06 10:49:15.039 | HD Request # 164 | Timestamp of first Intraday data file record written: 2025-02-06 10:48:04.230000. 2025-02-06 10:49:15.039 | HD Request # 164 | Received 123 Intraday data records from 2025-02-06 10:48:04.230000 to 2025-02-06 10:48:39.201000 (35.0 seconds. Delay: 35.8 seconds) and wrote 123 records for MGCJ5.COMEX 2025-02-06 10:49:15.047 | HD Request # 164 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:48:39.201000 2025-02-06 10:49:15.047 | Added 226 Time and Sales records to Intraday data file for MGCJ5.COMEX after download. 2025-02-06 10:49:15.047 | HD Request # 164 | Completion time: 37s. 2025-02-06 10:49:15.047 | HD Request # 164 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 161 2025-02-06 10:49:15.047 | Removing historical data download ID 161. 2025-02-06 10:49:15.047 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:49:15.047 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:49:15.047 | HD Request # 164 | Enabling Intraday chart updating for symbol. 2025-02-06 10:49:15.047 | 2025-02-06 10:49:15.047 | Triggering next historical data download in queue. 2025-02-06 10:49:15.047 | HD Request # 165 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:49:15.048 | HD Request # 165 | Download start date-time: 2025-02-06 10:48:04.000000. File last date-time: 2025-02-06 10:48:04.000003 2025-02-06 10:49:15.048 | HD Request # 165 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:49:15.048 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:49:15.048 | Socket (4) | New receive buffer size: 0 2025-02-06 10:49:15.048 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:49:15.074 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:49:15.074 | Socket (5) | Closed. 2025-02-06 10:49:15.091 | HD Request # 165 | Sending historical data logon request message. 2025-02-06 10:49:15.217 | HD Request # 165 | Requesting Intraday data. Start date-time: 2025-02-06 10:48:04. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:49:15.309 | HD Request # 165 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:48:04.279000 2025-02-06 10:49:16.964 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:49:39.414 | Socket (4) | CloseSocket call. 2025-02-06 10:49:39.414 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:49:39.415 | Historical data download thread signaled to stop. 2025-02-06 10:49:39.415 | HD Request # 165 | Timestamp of first Intraday data file record written: 2025-02-06 10:48:04.279000. 2025-02-06 10:49:39.415 | HD Request # 165 | Received 298 Intraday data records from 2025-02-06 10:48:04.279000 to 2025-02-06 10:49:16.253000 (72.0 seconds. Delay: 23.2 seconds) and wrote 298 records for MYMH5.CBOT 2025-02-06 10:49:39.423 | HD Request # 165 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:49:16.253000 2025-02-06 10:49:39.423 | Added 71 Time and Sales records to Intraday data file for MYMH5.CBOT after download. 2025-02-06 10:49:39.423 | HD Request # 165 | Completion time: 24s. 2025-02-06 10:49:39.423 | HD Request # 165 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 162 2025-02-06 10:49:39.423 | Removing historical data download ID 162. 2025-02-06 10:49:39.423 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 10:49:39.423 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 10:49:39.423 | HD Request # 165 | Enabling Intraday chart updating for symbol. 2025-02-06 10:49:39.423 | 2025-02-06 10:49:39.423 | No download requests in the queue to start downloads for. 2025-02-06 10:49:39.462 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:49:39.462 | Socket (4) | Closed. 2025-02-06 10:49:42.178 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 10:50:35.411 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-02-06 10:50:35.411 | DTC Client socket (2) | CloseSocket call. 2025-02-06 10:50:35.411 | DTC Client socket (2) | Max send buffers used during socket life: 3 2025-02-06 10:50:35.411 | DTC Client socket (2) | Max send buffer size during socket life: 735 2025-02-06 10:50:35.411 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2025-02-06 10:50:35.411 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-02-06 10:50:35.411 | DTC Client socket (2) | Closed. 2025-02-06 10:50:35.412 | DTC Client socket (0) | CloseSocket call. 2025-02-06 10:50:35.412 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2025-02-06 10:50:35.412 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. 2025-02-06 10:50:37.417 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated 2025-02-06 10:50:37.417 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509 2025-02-06 10:50:37.418 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-02-06 10:50:37.418 | DTC Client socket (2) | New receive buffer size: 0 2025-02-06 10:50:37.418 | DTC Client socket (2) | Connecting to IP: 216.57.156.163. 2025-02-06 10:50:37.463 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2025-02-06 10:50:37.463 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2025-02-06 10:50:37.463 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2025-02-06 10:50:37.463 | Rithmic Direct - DTC (Data) | Sending logon request message. 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Received logon response. 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Server Name: . 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Successfully connected. 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Trading is not supported. 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2025-02-06 10:50:37.608 | Added historical Intraday data request for MCLH5.NYMEX to the queue. 2025-02-06 10:50:37.608 | Intraday data recording state for symbol MCLH5.NYMEX is set to download 'Pending'. 2025-02-06 10:50:37.608 | Triggering next historical data download in queue. 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MCLH5.NYMEX 2025-02-06 10:50:37.608 | Added historical Intraday data request for MGCJ5.COMEX to the queue. 2025-02-06 10:50:37.608 | Intraday data recording state for symbol MGCJ5.COMEX is set to download 'Pending'. 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MGCJ5.COMEX. Market Depth data restarted. 2025-02-06 10:50:37.608 | Added historical Intraday data request for MYMH5.CBOT to the queue. 2025-02-06 10:50:37.608 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'. 2025-02-06 10:50:37.608 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MYMH5.CBOT 2025-02-06 10:50:37.608 | HD Request # 166 | Downloading Intraday chart data for MCLH5.NYMEX to the file MCLH5.NYMEX.scid. Service: rithmic.trading 2025-02-06 10:50:37.617 | HD Request # 166 | Download start date-time: 2025-02-06 10:50:33.000000. File last date-time: 2025-02-06 10:50:33.000002 2025-02-06 10:50:37.617 | HD Request # 166 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:50:37.617 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:50:37.617 | Socket (4) | New receive buffer size: 0 2025-02-06 10:50:37.617 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:50:37.651 | Rithmic Direct - DTC (Data) | Market Depth data has been rejected for symbol: MGCJ5.COMEX. permission denied 2025-02-06 10:50:37.659 | HD Request # 166 | Sending historical data logon request message. 2025-02-06 10:50:37.786 | HD Request # 166 | Requesting Intraday data. Start date-time: 2025-02-06 10:50:33. Record interval: 0. Symbol: MCLH5.NYMEX 2025-02-06 10:50:38.255 | Rithmic Direct - DTC (Data) | Received security definition for symbol MCLH5.NYMEX 2025-02-06 10:50:38.255 | Rithmic Direct - DTC (Data) | Received security definition for symbol MGCJ5.COMEX 2025-02-06 10:50:38.256 | Rithmic Direct - DTC (Data) | Received security definition for symbol MYMH5.CBOT 2025-02-06 10:50:39.701 | HD Request # 166 | Receiving Intraday data for MCLH5.NYMEX starting at 2025-02-06 10:50:33.240000 2025-02-06 10:50:39.741 | Socket (4) | CloseSocket call. 2025-02-06 10:50:39.741 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:50:39.741 | Historical data download thread signaled to stop. 2025-02-06 10:50:39.741 | HD Request # 166 | Timestamp of first Intraday data file record written: 2025-02-06 10:50:33.240000. 2025-02-06 10:50:39.741 | HD Request # 166 | Received 12 Intraday data records from 2025-02-06 10:50:33.240000 to 2025-02-06 10:50:39.690001 (6.5 seconds. Delay: 0.1 seconds) and wrote 12 records for MCLH5.NYMEX 2025-02-06 10:50:39.750 | HD Request # 166 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:50:39.690001 2025-02-06 10:50:39.750 | Added 4 Time and Sales records to Intraday data file for MCLH5.NYMEX after download. 2025-02-06 10:50:39.750 | HD Request # 166 | Completion time: 2s. 2025-02-06 10:50:39.750 | HD Request # 166 | Intraday data download complete for MCLH5.NYMEX. Unique request ID: 163 2025-02-06 10:50:39.750 | Removing historical data download ID 163. 2025-02-06 10:50:39.750 | Real-time Intraday chart data file updates started for MCLH5.NYMEX 2025-02-06 10:50:39.750 | Intraday chart data file opened for MCLH5.NYMEX 2025-02-06 10:50:39.750 | HD Request # 166 | Enabling Intraday chart updating for symbol. 2025-02-06 10:50:39.750 | 2025-02-06 10:50:39.750 | Triggering next historical data download in queue. 2025-02-06 10:50:39.750 | HD Request # 167 | Downloading Intraday chart data for MGCJ5.COMEX to the file MGCJ5.COMEX.scid. Service: rithmic.trading 2025-02-06 10:50:39.750 | HD Request # 167 | Download start date-time: 2025-02-06 10:50:34.000000. File last date-time: 2025-02-06 10:50:34.000006 2025-02-06 10:50:39.750 | HD Request # 167 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:50:39.751 | Socket (5) | Creating socket. Using TLS 1.2. 2025-02-06 10:50:39.751 | Socket (5) | New receive buffer size: 0 2025-02-06 10:50:39.751 | Socket (5) | Connecting to IP: 216.57.156.163. 2025-02-06 10:50:39.781 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:50:39.781 | Socket (4) | Closed. 2025-02-06 10:50:39.794 | HD Request # 167 | Sending historical data logon request message. 2025-02-06 10:50:39.917 | HD Request # 167 | Requesting Intraday data. Start date-time: 2025-02-06 10:50:34. Record interval: 0. Symbol: MGCJ5.COMEX 2025-02-06 10:50:39.960 | HD Request # 167 | Receiving Intraday data for MGCJ5.COMEX starting at 2025-02-06 10:50:34.119000 2025-02-06 10:50:42.775 | Opened cached Intraday file: D:\SierraChart\Data\MCLH5.NYMEX.scid. Thread ID: 22756 2025-02-06 10:51:10.053 | Socket (5) | CloseSocket call. 2025-02-06 10:51:10.054 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-06 10:51:10.054 | Historical data download thread signaled to stop. 2025-02-06 10:51:10.054 | HD Request # 167 | Timestamp of first Intraday data file record written: 2025-02-06 10:50:34.119000. 2025-02-06 10:51:10.054 | HD Request # 167 | Received 22 Intraday data records from 2025-02-06 10:50:34.119000 to 2025-02-06 10:50:40.330000 (6.2 seconds. Delay: 29.7 seconds) and wrote 22 records for MGCJ5.COMEX 2025-02-06 10:51:10.085 | HD Request # 167 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:50:40.330000 2025-02-06 10:51:10.085 | Added 141 Time and Sales records to Intraday data file for MGCJ5.COMEX after download. 2025-02-06 10:51:10.085 | HD Request # 167 | Completion time: 31s. 2025-02-06 10:51:10.085 | HD Request # 167 | Intraday data download complete for MGCJ5.COMEX. Unique request ID: 164 2025-02-06 10:51:10.085 | Removing historical data download ID 164. 2025-02-06 10:51:10.085 | Real-time Intraday chart data file updates started for MGCJ5.COMEX 2025-02-06 10:51:10.085 | Intraday chart data file opened for MGCJ5.COMEX 2025-02-06 10:51:10.085 | HD Request # 167 | Enabling Intraday chart updating for symbol. 2025-02-06 10:51:10.085 | 2025-02-06 10:51:10.085 | Triggering next historical data download in queue. 2025-02-06 10:51:10.085 | HD Request # 168 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: rithmic.trading 2025-02-06 10:51:10.086 | HD Request # 168 | Download start date-time: 2025-02-06 10:50:34.000000. File last date-time: 2025-02-06 10:50:34.000003 2025-02-06 10:51:10.086 | HD Request # 168 | Using server: rsc.rithmic.com port 50510. Use encryption. 2025-02-06 10:51:10.086 | Socket (4) | Creating socket. Using TLS 1.2. 2025-02-06 10:51:10.086 | Socket (4) | New receive buffer size: 0 2025-02-06 10:51:10.086 | Socket (4) | Connecting to IP: 216.57.156.163. 2025-02-06 10:51:10.094 | Socket (5) | Socket gracefully closed by remote side. 2025-02-06 10:51:10.094 | Socket (5) | Closed. 2025-02-06 10:51:10.130 | HD Request # 168 | Sending historical data logon request message. 2025-02-06 10:51:10.255 | HD Request # 168 | Requesting Intraday data. Start date-time: 2025-02-06 10:50:34. Record interval: 0. Symbol: MYMH5.CBOT 2025-02-06 10:51:10.306 | HD Request # 168 | Receiving Intraday data for MYMH5.CBOT starting at 2025-02-06 10:50:34.278000 2025-02-06 10:51:12.994 | Opened cached Intraday file: D:\SierraChart\Data\MGCJ5.COMEX.scid. Thread ID: 22756 2025-02-06 10:51:38.554 | Socket (4) | CloseSocket call. 2025-02-06 10:51:38.554 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-06 10:51:38.555 | Historical data download thread signaled to stop. 2025-02-06 10:51:38.555 | HD Request # 168 | Timestamp of first Intraday data file record written: 2025-02-06 10:50:34.278000. 2025-02-06 10:51:38.555 | HD Request # 168 | Received 131 Intraday data records from 2025-02-06 10:50:34.278000 to 2025-02-06 10:51:10.972000 (36.7 seconds. Delay: 27.6 seconds) and wrote 131 records for MYMH5.CBOT 2025-02-06 10:51:38.591 | HD Request # 168 | Add time&sales data | Remembered last file record date-time: 2025-02-06 15:51:10.972000 2025-02-06 10:51:38.591 | Added 75 Time and Sales records to Intraday data file for MYMH5.CBOT after download. 2025-02-06 10:51:38.591 | HD Request # 168 | Completion time: 28s. 2025-02-06 10:51:38.591 | HD Request # 168 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 165 2025-02-06 10:51:38.591 | Removing historical data download ID 165. 2025-02-06 10:51:38.591 | Real-time Intraday chart data file updates started for MYMH5.CBOT 2025-02-06 10:51:38.591 | Intraday chart data file opened for MYMH5.CBOT 2025-02-06 10:51:38.591 | HD Request # 168 | Enabling Intraday chart updating for symbol. 2025-02-06 10:51:38.591 | 2025-02-06 10:51:38.591 | No download requests in the queue to start downloads for. 2025-02-06 10:51:38.594 | Socket (4) | Socket gracefully closed by remote side. 2025-02-06 10:51:38.594 | Socket (4) | Closed. 2025-02-06 10:51:43.240 | Opened cached Intraday file: D:\SierraChart\Data\MYMH5.CBOT.scid. Thread ID: 22756 2025-02-06 11:05:01.623 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:16:00 2025-02-06 11:18:21.614 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:16:00 2025-02-06 11:18:41.616 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:16:00 | Number times message previously added: 1 2025-02-06 11:19:05.544 | MNQH5.CME[M] 15 Sec #11 | StartDateTimeForLoadingOrderFills: 2025-01-23 11:19:06 2025-02-06 11:19:45.616 | MGCJ5.COMEX 15 Sec #6 | StartDateTimeForLoadingOrderFills: 2025-01-07 16:16:00 |
[2025-02-06 18:59:04] |
John - SC Support - Posts: 38653 |
We see a few of the following in your log: 2025-02-05 08:47:18.475 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
Refer to the following regarding this: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem But there are only a few of these and they are only at a certain point in time (they are not occurring over the 3 hours that the Message Log spans). We also see that there is a connection to the Teton Order Routing Service as well as Rithmic. We wonder if you are having this issue when connected to Teton as well? In particular, we wonder if you are having the issue outlined at the following link: Rithmic Trading Platform Service: Frequent Reconnections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-07 14:34:37] |
UserTLE - Posts: 8 |
Will check that out, No observed issue in Teton. I just had connected to that to see if the issue was there as well. |
