Date/Time: Thu, 13 Mar 2025 20:29:10 +0000
[Programming Help] - Cant type certain numbers into the price box in the trade window
View Count: 109
[2025-02-03 15:57:07] |
User813832 - Posts: 12 |
Hi, I am not sure if this is a bug or what. But I am using the order window and trading with limit orders. I normally type the price into the box, it says 'Limit: ' then I type in the price next to it. However right now I cannot type in certain prices. The current price of MES is 6019. I cant type in any prices in that box that have a 1 or a 2 after 60. I type '60' then when I press 1 or 2 just nothing happens - it doesnt enter any character. I can select prices that have a 1 or a 2 after the 60 from the dropdown menu and I can place order further away and then drag them to the correct price. But why can I not enter any prices such as 601x or 602x? Is this a bug or am I missing something? Thanks Sorry after I made this post I actually had a moment where it dawned on me what might be causing the problem. I realised that actually I cannot type 1 or 2 into that window at all no matter what the price. I have hotkeys (shortcuts to tools) assigned to 1 and 2. I changed them off that and I can now type prices in. But still then, question remains, can I not use any of the number keys for shortcuts if I want to type number into the chart trade window? Date Time Of Last Edit: 2025-02-03 16:02:13
[2025-02-03 17:43:44] |
John - SC Support - Posts: 38647 |
As you found out - you can not. The system is interpreting the 1 and 2 as the keyboard shortcuts and not as inputs to the window. Although we do allow you to setup keyboard shortcuts using a single key, we recommend always using a modifier key (shift, control, alt) with each shortcut to avoid this kind of problem. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
