Date/Time: Fri, 14 Mar 2025 12:41:58 +0000
NOT CONNECTED
View Count: 194
[2025-01-31 17:50:37]
indra1995 - Posts: 1
Hello. can somebody please help me. i paid for the subscription but it said "not connected" i couldn't figure it out
tHIS ARE THE ERRORS THAT I GET
2025-01-31 17:33:34.321 | Trade activity files set size: 0
2025-01-31 17:33:34.378 | DTC Protocol Server feature not enabled for Sierra Chart account. *
2025-01-31 17:33:34.378 | Reading Internal Order ID file.
2025-01-31 17:33:34.379 | Reading Trade Orders file.
2025-01-31 17:33:34.379 | Reading Trade Positions file.
2025-01-31 17:33:34.379 | Reading Trade Account Data files.
2025-01-31 17:33:34.380 | Software version: 2735 64-bit
2025-01-31 17:33:34.380 | Primary Thread ID: 27328
2025-01-31 17:33:34.380 | Usage end date: 2025-02-14
2025-01-31 17:33:34.380 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-01-31 17:33:34.380 | Current selected Data/Trading service: SC Data
2025-01-31 17:33:34.380 | Custom symbol settings values: enabled
2025-01-31 17:33:34.380 | Chart Update Interval: 400
2025-01-31 17:33:34.380 | Intraday Data Storage Time Unit: 1
2025-01-31 17:33:34.380 | Time Zone: +00:00:00 (UTC+00)
2025-01-31 17:33:34.380 | 2025-01-31 17:33:34 Local computer time in UTC
2025-01-31 17:33:34.380 | 2025-01-31 17:33:34 Local computer time in SC Time Zone
2025-01-31 17:33:34.380 | 2025-01-31 17:33:36 Server time in UTC
2025-01-31 17:33:34.380 | Local computer UTC time and Server UTC time difference: 2 seconds.
2025-01-31 17:33:34.380 | Program path: C:\SierraChart\
2025-01-31 17:33:34.380 | Data Files path: C:\SierraChart\Data\
2025-01-31 17:33:34.381 | OS Version Number: 10.0
2025-01-31 17:33:34.381 | Locale Setting: C
2025-01-31 17:33:34.381 | DLLs: UserContributedStudies_64.dll
2025-01-31 17:33:34.381 | Allowed protected custom studies:
2025-01-31 17:33:34.381 | Crash reporter started: true
2025-01-31 17:33:34.397 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1.
2025-01-31 17:33:34.432 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-01-31 17:33:34.458 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-01-31 17:33:34.458 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-01-31 17:33:34.568 | Received 5 login tokens.
2025-01-31 17:33:34.978 | Symbol settings MD5 received. Request ID: 1.
2025-01-31 17:33:34.978 | Symbol settings are up-to-date for scdataallservices.
2025-01-31 17:33:36.893 | Requested user files to download.
2025-01-31 17:33:38.901 | Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2025-01-31 17:33:42.108 | Files to Open on Startup | Opening file: ExampleChartbook.cht
2025-01-31 17:33:42.122 | MESH25-CME 10 Min #1 | Reloading chart.
2025-01-31 17:33:42.126 | MESH25-CME 10 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH25-CME.scid
2025-01-31 17:33:42.129 | MESH25-CME 10 Min #1 | Chart data loading complete.
2025-01-31 17:33:42.516 | Using symbol data fast lookup vector
2025-01-31 17:33:42.516 | Starting DelayedDownloadMonitoringTimer
2025-01-31 17:33:42.516 | Starting HDTimeoutTimer
2025-01-31 17:33:42.516 | Historical data service client indicated that downloads are not enabled. Symbol: MESH25-CME. Data Type: Intraday data.
2025-01-31 17:33:42.516 | Historical data download ID 1 not found when removing ID from outstanding request set.
2025-01-31 17:34:42.887 | Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2025-01-31 17:43:11.570 | Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2025-01-31 17:43:33.597 | Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
2025-01-31 17:43:50.946 | The message log has been sent to support. *
2025-01-31 17:43:50.949 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2.
2025-01-31 17:43:50.949 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 0
2025-01-31 17:43:50.949 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 64.152.155.19.
2025-01-31 17:43:51.120 | The Message Log was sent. Result: Message Log received. *
2025-01-31 17:43:51.361 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call.
2025-01-31 17:43:51.361 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-01-31 17:43:51.390 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-01-31 17:43:51.390 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-01-31 17:49:38.794 | Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
[2025-01-31 18:03:04]
John - SC Support - Posts: 38653
The log is stating that the account you are using is expired.
Make certain you are logging into your Sierra Chart software with the same Account Information as you used to post in this thread (the account you posted from is active and has Usage Time remaining). Refer to the following:
Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name
Otherwise, use the "Forced Login" to make sure that your local system is updating properly from our servers. Follow these instructions for this:
Sierra Chart - Software Login Instructions: Forced Login
[2025-02-05 07:41:33]
User233198 - Posts: 1
I reconnected to my live trading AMP acct per the instructions sent to me, and then returned to Rithmic and now the data service will not connect.
2025-02-05 07:22:33.456 | Trade activity files set size: 74
2025-02-05 07:22:33.467 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:22:33.467 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2025-02-05 07:22:33.467 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2025-02-05 07:22:33.467 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2025-02-05 07:22:33.489 | Reading Internal Order ID file.
2025-02-05 07:22:33.500 | Reading Trade Orders file.
2025-02-05 07:22:33.501 | Reading Trade Positions file.
2025-02-05 07:22:33.501 | Reading Trade Account Data files.
2025-02-05 07:22:33.501 | Software version: 2728 64-bit
2025-02-05 07:22:33.501 | Primary Thread ID: 824
2025-02-05 07:22:33.501 | Usage end date: 2025-05-05
2025-02-05 07:22:33.501 | Enabled for: Advanced Features 2.
2025-02-05 07:22:33.501 | Enabled for: Sierra Chart Historical Data Service.
2025-02-05 07:22:33.501 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-02-05 07:22:33.501 | Enabled for: Delayed Denali Exchange Data Feed.
2025-02-05 07:22:33.501 | Enabled for exchange2: CME
2025-02-05 07:22:33.501 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-02-05 07:22:33.501 | Current selected Data/Trading service: Rithmic Direct - DTC
2025-02-05 07:22:33.501 | Custom symbol settings values: enabled
2025-02-05 07:22:33.501 | Chart Update Interval: 400
2025-02-05 07:22:33.501 | Intraday Data Storage Time Unit: 0
2025-02-05 07:22:33.501 | Time Zone: +00:00:00 (UTC+00)
2025-02-05 07:22:33.501 | 2025-02-05 07:22:33 Local computer time in UTC
2025-02-05 07:22:33.501 | 2025-02-05 07:22:33 Local computer time in SC Time Zone
2025-02-05 07:22:33.501 | 2025-02-05 07:22:32 Server time in UTC
2025-02-05 07:22:33.501 | Local computer UTC time and Server UTC time difference: 1 seconds.
2025-02-05 07:22:33.501 | Program path: C:\SierraChart\
2025-02-05 07:22:33.501 | Data Files path: C:\SierraChart\Data\
2025-02-05 07:22:33.502 | OS Version Number: 10.0
2025-02-05 07:22:33.502 | Locale Setting: C
2025-02-05 07:22:33.502 | DLLs: UserContributedStudies_64.dll
2025-02-05 07:22:33.502 | Allowed protected custom studies:
2025-02-05 07:22:33.502 | Crash reporter started: true
2025-02-05 07:22:33.502 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2025-02-05 07:22:33.521 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-02-05 07:22:33.619 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-02-05 07:22:33.619 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-02-05 07:22:33.811 | Received 5 login tokens.
2025-02-05 07:22:34.169 | Symbol settings MD5 received. Request ID: 1.
2025-02-05 07:22:34.169 | Symbol settings are up-to-date for rithmic_v2.trading.
2025-02-05 07:22:34.318 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:22:34.320 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:22:34.566 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2025-02-05 07:22:34.567 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2025-02-05 07:22:34.667 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2025-02-05 07:22:34.667 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2025-02-05 07:22:36.004 | Requested user files to download.
2025-02-05 07:22:37.999 |
2025-02-05 07:22:37.999 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:22:37.999 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:22:37.999 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:22:38.000 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:22:38.001 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:22:38.001 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:22:58.011 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:22:58.011 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0
2025-02-05 07:22:58.011 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:22:58.875 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:22:58.877 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:22:58.877 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:22:58.877 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:22:58.889 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:22:58.889 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:22:58.889 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:22:58.890 | DTC Client socket (1) | Closed.
2025-02-05 07:22:59.126 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call.
2025-02-05 07:22:59.126 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:22:59.226 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side.
2025-02-05 07:22:59.226 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed.
2025-02-05 07:23:02.892 |
2025-02-05 07:23:02.892 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:23:02.892 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:23:02.892 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:23:02.894 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:23:02.894 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:23:02.894 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:23:22.910 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:23:22.910 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | New receive buffer size: 0
2025-02-05 07:23:22.910 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:23:23.692 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:23:23.693 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:23:23.693 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:23:23.693 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:23:23.701 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:23:23.701 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:23:23.701 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:23:23.702 | DTC Client socket (1) | Closed.
2025-02-05 07:23:23.937 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | CloseSocket call.
2025-02-05 07:23:23.937 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:23:24.023 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Socket gracefully closed by remote side.
2025-02-05 07:23:24.023 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Closed.
2025-02-05 07:23:27.712 |
2025-02-05 07:23:27.712 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:23:27.712 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:23:27.712 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:23:27.713 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:23:27.713 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:23:27.713 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:23:47.780 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:23:47.781 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | New receive buffer size: 0
2025-02-05 07:23:47.781 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:23:48.597 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:23:48.598 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:23:48.598 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:23:48.598 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:23:48.619 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:23:48.619 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:23:48.619 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:23:48.619 | DTC Client socket (1) | Closed.
2025-02-05 07:23:48.854 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | CloseSocket call.
2025-02-05 07:23:48.855 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:23:48.960 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Socket gracefully closed by remote side.
2025-02-05 07:23:48.960 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Closed.
2025-02-05 07:23:52.609 |
2025-02-05 07:23:52.609 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:23:52.609 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:23:52.609 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:23:52.611 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:23:52.611 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:23:52.611 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:24:12.609 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:24:12.610 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | New receive buffer size: 0
2025-02-05 07:24:12.610 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:24:13.659 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:24:13.659 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:24:13.659 | Rithmic Direct - DTC | Failed connections: 1
2025-02-05 07:24:13.659 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:24:13.659 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:24:13.659 | DTC Client socket (1) | Closed.
2025-02-05 07:24:13.674 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:24:13.674 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:24:13.674 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:24:13.757 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:24:13.758 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:24:14.012 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | CloseSocket call.
2025-02-05 07:24:14.012 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:24:14.127 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Socket gracefully closed by remote side.
2025-02-05 07:24:14.128 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Closed.
2025-02-05 07:24:17.675 |
2025-02-05 07:24:17.675 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:24:17.675 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:24:17.675 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:24:17.788 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:24:17.788 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:24:17.788 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:24:37.689 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:24:37.689 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | New receive buffer size: 0
2025-02-05 07:24:37.689 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:24:38.486 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:24:38.489 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:24:38.489 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:24:38.489 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:24:38.513 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:24:38.513 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:24:38.513 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:24:38.514 | DTC Client socket (1) | Closed.
2025-02-05 07:24:38.742 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | CloseSocket call.
2025-02-05 07:24:38.742 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:24:38.844 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Socket gracefully closed by remote side.
2025-02-05 07:24:38.844 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Closed.
2025-02-05 07:24:42.512 |
2025-02-05 07:24:42.518 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:24:42.518 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:24:42.518 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:24:42.530 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:24:42.531 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:24:42.532 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:25:02.526 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:25:02.527 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | New receive buffer size: 0
2025-02-05 07:25:02.527 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:25:03.292 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:25:03.294 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:25:03.294 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:25:03.294 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:25:03.314 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:25:03.314 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:25:03.314 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:25:03.315 | DTC Client socket (1) | Closed.
2025-02-05 07:25:03.548 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | CloseSocket call.
2025-02-05 07:25:03.548 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:25:03.632 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Socket gracefully closed by remote side.
2025-02-05 07:25:03.632 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Closed.
2025-02-05 07:25:07.313 |
2025-02-05 07:25:07.319 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:25:07.319 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:25:07.319 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:25:07.322 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:25:07.323 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:25:07.323 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:25:27.330 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:25:27.331 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | New receive buffer size: 0
2025-02-05 07:25:27.331 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:25:28.362 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:25:28.362 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:25:28.362 | Rithmic Direct - DTC | Failed connections: 2
2025-02-05 07:25:28.362 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:25:28.362 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:25:28.362 | DTC Client socket (1) | Closed.
2025-02-05 07:25:28.378 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:25:28.378 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:25:28.378 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:25:28.578 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:25:28.580 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:25:28.823 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | CloseSocket call.
2025-02-05 07:25:28.824 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:25:28.942 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Socket gracefully closed by remote side.
2025-02-05 07:25:28.943 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Closed.
2025-02-05 07:25:32.371 |
2025-02-05 07:25:32.379 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:25:32.379 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:25:32.379 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:25:32.386 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:25:32.386 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:25:32.386 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:25:52.390 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:25:52.390 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | New receive buffer size: 0
2025-02-05 07:25:52.390 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:25:53.396 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:25:53.397 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:25:53.397 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:25:53.397 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:25:53.418 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:25:53.418 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:25:53.418 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:25:53.419 | DTC Client socket (1) | Closed.
2025-02-05 07:25:53.649 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | CloseSocket call.
2025-02-05 07:25:53.650 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:25:53.822 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Socket gracefully closed by remote side.
2025-02-05 07:25:53.822 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Closed.
2025-02-05 07:25:57.417 |
2025-02-05 07:25:57.421 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:25:57.421 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:25:57.421 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:25:57.432 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:25:57.432 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:25:57.432 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:26:17.438 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:26:17.438 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (2) | New receive buffer size: 0
2025-02-05 07:26:17.438 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:26:18.258 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:26:18.259 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:26:18.259 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:26:18.259 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:26:18.272 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:26:18.272 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:26:18.272 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:26:18.274 | DTC Client socket (1) | Closed.
2025-02-05 07:26:18.504 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (2) | CloseSocket call.
2025-02-05 07:26:18.505 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:26:18.591 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (2) | Socket gracefully closed by remote side.
2025-02-05 07:26:18.592 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (2) | Closed.
2025-02-05 07:26:22.276 |
2025-02-05 07:26:22.280 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:26:22.280 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:26:22.280 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:26:22.282 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:26:22.282 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:26:22.282 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:26:42.289 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:26:42.289 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (2) | New receive buffer size: 0
2025-02-05 07:26:42.289 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:26:43.151 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:26:43.153 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:26:43.153 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:26:43.153 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:26:43.177 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:26:43.177 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:26:43.177 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:26:43.177 | DTC Client socket (1) | Closed.
2025-02-05 07:26:43.409 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (2) | CloseSocket call.
2025-02-05 07:26:43.410 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:26:43.550 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (2) | Socket gracefully closed by remote side.
2025-02-05 07:26:43.551 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (2) | Closed.
2025-02-05 07:26:47.183 |
2025-02-05 07:26:47.186 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:26:47.186 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:26:47.187 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:26:47.189 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:26:47.190 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:26:47.190 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:27:07.193 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:27:07.194 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | New receive buffer size: 0
2025-02-05 07:27:07.194 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:27:08.186 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:27:08.187 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:27:08.187 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:27:08.187 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:27:08.221 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:27:08.222 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:27:08.222 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:27:08.222 | DTC Client socket (1) | Closed.
2025-02-05 07:27:08.222 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:27:08.441 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | CloseSocket call.
2025-02-05 07:27:08.442 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:27:08.523 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Socket gracefully closed by remote side.
2025-02-05 07:27:08.524 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Closed.
2025-02-05 07:27:12.215 |
2025-02-05 07:27:12.219 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:27:12.219 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:27:12.219 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:27:12.223 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:27:12.223 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:27:12.223 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:27:32.231 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:27:32.231 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (2) | New receive buffer size: 0
2025-02-05 07:27:32.231 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:27:33.275 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:27:33.276 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:27:33.276 | Rithmic Direct - DTC | Failed connections: 3
2025-02-05 07:27:33.276 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:27:33.276 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:27:33.276 | DTC Client socket (1) | Closed.
2025-02-05 07:27:33.292 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:27:33.292 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:27:33.292 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:27:33.439 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:27:33.439 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:27:33.683 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (2) | CloseSocket call.
2025-02-05 07:27:33.683 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:27:33.765 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (2) | Socket gracefully closed by remote side.
2025-02-05 07:27:33.765 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (2) | Closed.
2025-02-05 07:27:37.293 |
2025-02-05 07:27:37.299 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:27:37.299 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:27:37.299 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:27:37.306 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:27:37.306 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:27:37.306 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:27:57.298 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:27:57.298 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (2) | New receive buffer size: 0
2025-02-05 07:27:57.298 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:27:58.384 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:27:58.384 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:27:58.384 | Rithmic Direct - DTC | Failed connections: 4
2025-02-05 07:27:58.384 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:27:58.384 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:27:58.384 | DTC Client socket (1) | Closed.
2025-02-05 07:27:58.403 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:27:58.403 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:27:58.403 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:27:58.612 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:27:58.613 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:27:58.875 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (2) | CloseSocket call.
2025-02-05 07:27:58.876 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:27:59.039 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (2) | Socket gracefully closed by remote side.
2025-02-05 07:27:59.039 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (2) | Closed.
2025-02-05 07:28:02.412 |
2025-02-05 07:28:02.416 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:28:02.416 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:28:02.420 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:28:02.423 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:28:02.424 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:28:02.424 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:28:22.427 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:28:22.428 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (2) | New receive buffer size: 0
2025-02-05 07:28:22.428 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:28:23.458 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:28:23.458 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:28:23.458 | Rithmic Direct - DTC | Failed connections: 5
2025-02-05 07:28:23.458 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:28:23.458 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:28:23.458 | DTC Client socket (1) | Closed.
2025-02-05 07:28:23.475 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:28:23.475 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:28:23.475 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:28:23.577 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:28:23.579 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:28:23.824 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (2) | CloseSocket call.
2025-02-05 07:28:23.824 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:28:23.946 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (2) | Socket gracefully closed by remote side.
2025-02-05 07:28:23.946 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (2) | Closed.
2025-02-05 07:28:27.472 |
2025-02-05 07:28:27.477 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:28:27.477 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:28:27.477 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:28:27.479 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:28:27.479 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:28:27.479 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:28:47.474 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:28:47.475 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (2) | New receive buffer size: 0
2025-02-05 07:28:47.475 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:28:48.522 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:28:48.522 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:28:48.522 | Rithmic Direct - DTC | Failed connections: 6
2025-02-05 07:28:48.522 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:28:48.522 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:28:48.522 | DTC Client socket (1) | Closed.
2025-02-05 07:28:48.538 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:28:48.538 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:28:48.539 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:28:48.578 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:28:48.579 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:28:48.825 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (2) | CloseSocket call.
2025-02-05 07:28:48.826 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:28:48.935 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (2) | Socket gracefully closed by remote side.
2025-02-05 07:28:48.936 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (2) | Closed.
2025-02-05 07:28:51.919 | File >> Disconnect selected.
2025-02-05 07:28:51.919 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:28:51.919 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:29:05.287 |
2025-02-05 07:29:05.287 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:29:05.287 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:29:05.287 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:29:05.294 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:29:05.295 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:29:05.295 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:29:25.352 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:29:25.353 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (2) | New receive buffer size: 0
2025-02-05 07:29:25.353 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:29:26.229 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:29:26.230 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:29:26.230 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:29:26.230 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:29:26.244 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:29:26.244 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:29:26.245 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:29:26.245 | DTC Client socket (1) | Closed.
2025-02-05 07:29:26.473 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (2) | CloseSocket call.
2025-02-05 07:29:26.473 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:29:26.594 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (2) | Socket gracefully closed by remote side.
2025-02-05 07:29:26.594 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (2) | Closed.
2025-02-05 07:29:30.258 |
2025-02-05 07:29:30.258 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:29:30.258 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:29:30.258 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:29:30.322 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:29:30.323 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:29:30.323 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:29:50.260 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:29:50.260 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (2) | New receive buffer size: 0
2025-02-05 07:29:50.260 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:29:51.055 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:29:51.056 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:29:51.056 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:29:51.056 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:29:51.072 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:29:51.072 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:29:51.072 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:29:51.074 | DTC Client socket (1) | Closed.
2025-02-05 07:29:51.296 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (2) | CloseSocket call.
2025-02-05 07:29:51.297 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:29:51.380 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (2) | Socket gracefully closed by remote side.
2025-02-05 07:29:51.380 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (2) | Closed.
2025-02-05 07:29:55.074 |
2025-02-05 07:29:55.074 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:29:55.074 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:29:55.074 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:29:55.079 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:29:55.080 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:29:55.080 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:30:15.100 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:30:15.100 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (2) | New receive buffer size: 0
2025-02-05 07:30:15.100 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:30:15.963 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:30:15.971 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:30:15.971 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:30:15.971 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:30:15.997 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:30:15.997 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:30:15.997 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:30:15.998 | DTC Client socket (1) | Closed.
2025-02-05 07:30:16.218 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (2) | CloseSocket call.
2025-02-05 07:30:16.218 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:30:16.323 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (2) | Socket gracefully closed by remote side.
2025-02-05 07:30:16.323 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (2) | Closed.
2025-02-05 07:30:20.004 |
2025-02-05 07:30:20.006 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:30:20.006 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:30:20.006 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:30:20.008 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:30:20.008 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:30:20.008 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:30:40.012 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:30:40.012 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (2) | New receive buffer size: 0
2025-02-05 07:30:40.012 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:30:40.847 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:30:40.851 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:30:40.851 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:30:40.851 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:30:40.862 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:30:40.862 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:30:40.862 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:30:40.862 | DTC Client socket (1) | Closed.
2025-02-05 07:30:41.104 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (2) | CloseSocket call.
2025-02-05 07:30:41.104 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:30:41.210 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (2) | Socket gracefully closed by remote side.
2025-02-05 07:30:41.210 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (2) | Closed.
2025-02-05 07:30:44.857 |
2025-02-05 07:30:44.857 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:30:44.857 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:30:44.857 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:30:44.858 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:30:44.858 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:30:44.858 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:31:04.868 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:31:04.869 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (2) | New receive buffer size: 0
2025-02-05 07:31:04.869 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:31:05.681 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:31:05.684 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:31:05.684 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:31:05.684 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:31:05.699 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:31:05.699 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:31:05.699 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:31:05.700 | DTC Client socket (1) | Closed.
2025-02-05 07:31:05.939 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (2) | CloseSocket call.
2025-02-05 07:31:05.939 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:31:06.020 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (2) | Socket gracefully closed by remote side.
2025-02-05 07:31:06.020 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (2) | Closed.
2025-02-05 07:31:09.703 |
2025-02-05 07:31:09.703 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:31:09.703 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:31:09.703 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:31:09.706 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:31:09.707 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:31:09.707 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:31:29.717 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:31:29.717 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (2) | New receive buffer size: 0
2025-02-05 07:31:29.717 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:31:30.748 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:31:30.748 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:31:30.748 | DTC Client socket (1) | Closed.
2025-02-05 07:31:30.748 | Rithmic Direct - DTC | Failed connections: 7
2025-02-05 07:31:30.748 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:31:30.748 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:31:30.764 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:31:30.764 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:31:30.764 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:31:30.844 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:31:30.844 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:31:31.096 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (2) | CloseSocket call.
2025-02-05 07:31:31.096 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:31:31.180 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (2) | Socket gracefully closed by remote side.
2025-02-05 07:31:31.180 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (2) | Closed.
2025-02-05 07:31:34.768 |
2025-02-05 07:31:34.768 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:31:34.768 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:31:34.768 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:31:34.773 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:31:34.774 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:31:34.774 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:31:54.780 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:31:54.780 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (2) | New receive buffer size: 0
2025-02-05 07:31:54.780 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:31:55.715 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:31:55.716 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:31:55.716 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:31:55.716 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:31:55.730 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:31:55.730 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:31:55.730 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:31:55.731 | DTC Client socket (1) | Closed.
2025-02-05 07:31:55.980 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (2) | CloseSocket call.
2025-02-05 07:31:55.980 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:31:56.097 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (2) | Socket gracefully closed by remote side.
2025-02-05 07:31:56.097 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (2) | Closed.
2025-02-05 07:31:59.745 |
2025-02-05 07:31:59.745 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:31:59.745 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:31:59.745 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:31:59.748 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:31:59.748 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:31:59.748 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:32:19.743 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:32:19.743 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (2) | New receive buffer size: 0
2025-02-05 07:32:19.743 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:32:20.565 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:32:20.567 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:32:20.567 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:32:20.567 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:32:20.586 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:32:20.586 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:32:20.586 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:32:20.586 | DTC Client socket (1) | Closed.
2025-02-05 07:32:20.813 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (2) | CloseSocket call.
2025-02-05 07:32:20.813 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:32:20.903 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (2) | Socket gracefully closed by remote side.
2025-02-05 07:32:20.903 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (2) | Closed.
2025-02-05 07:32:24.579 |
2025-02-05 07:32:24.579 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:32:24.579 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:32:24.579 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:32:24.582 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:32:24.582 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:32:24.582 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:32:34.020 | The message log has been sent to support. *
2025-02-05 07:32:34.021 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:32:34.023 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 0
2025-02-05 07:32:34.023 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 64.152.155.19.
2025-02-05 07:32:41.962 | The Message Log was sent. Result: Message Log received. *
2025-02-05 07:32:42.210 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call.
2025-02-05 07:32:42.210 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:32:42.294 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side.
2025-02-05 07:32:42.294 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed.
2025-02-05 07:32:44.579 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:32:44.579 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (2) | New receive buffer size: 0
2025-02-05 07:32:44.579 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:32:45.628 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:32:45.628 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:32:45.628 | Rithmic Direct - DTC | Failed connections: 8
2025-02-05 07:32:45.628 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:32:45.628 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:32:45.628 | DTC Client socket (1) | Closed.
2025-02-05 07:32:45.646 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:32:45.646 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:32:45.647 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:32:45.648 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:32:45.649 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:32:45.893 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (2) | CloseSocket call.
2025-02-05 07:32:45.893 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:32:45.987 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (2) | Socket gracefully closed by remote side.
2025-02-05 07:32:45.988 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (2) | Closed.
2025-02-05 07:32:49.645 |
2025-02-05 07:32:49.645 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:32:49.645 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:32:49.645 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:32:49.645 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:32:49.646 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:32:49.646 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:33:09.642 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:33:09.642 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (2) | New receive buffer size: 0
2025-02-05 07:33:09.642 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:33:10.663 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:33:10.663 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:33:10.664 | Rithmic Direct - DTC | Failed connections: 9
2025-02-05 07:33:10.664 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:33:10.664 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:33:10.664 | DTC Client socket (1) | Closed.
2025-02-05 07:33:10.679 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:33:10.679 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:33:10.679 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:33:11.311 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:33:11.313 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:33:11.571 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (2) | CloseSocket call.
2025-02-05 07:33:11.572 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:33:11.654 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (2) | Socket gracefully closed by remote side.
2025-02-05 07:33:11.654 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (2) | Closed.
2025-02-05 07:33:14.667 |
2025-02-05 07:33:14.667 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:33:14.667 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:33:14.667 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:33:14.668 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:33:14.668 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:33:14.668 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:33:34.680 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:33:34.680 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (2) | New receive buffer size: 0
2025-02-05 07:33:34.680 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:33:35.642 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:33:35.643 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:33:35.643 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:33:35.643 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:33:35.667 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:33:35.667 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:33:35.667 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:33:35.667 | DTC Client socket (1) | Closed.
2025-02-05 07:33:35.892 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (2) | CloseSocket call.
2025-02-05 07:33:35.892 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:33:35.975 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (2) | Socket gracefully closed by remote side.
2025-02-05 07:33:35.975 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (2) | Closed.
2025-02-05 07:33:39.667 |
2025-02-05 07:33:39.667 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:33:39.667 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:33:39.667 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:33:39.668 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:33:39.668 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:33:39.668 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:33:59.677 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:33:59.677 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (2) | New receive buffer size: 0
2025-02-05 07:33:59.677 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:34:00.717 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:34:00.717 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:34:00.717 | Rithmic Direct - DTC | Failed connections: 10
2025-02-05 07:34:00.717 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:34:00.717 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:34:00.717 | DTC Client socket (1) | Closed.
2025-02-05 07:34:00.734 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:34:00.734 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:34:00.734 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:34:01.056 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:34:01.057 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:34:01.317 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (2) | CloseSocket call.
2025-02-05 07:34:01.318 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:34:01.434 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (2) | Socket gracefully closed by remote side.
2025-02-05 07:34:01.434 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (2) | Closed.
2025-02-05 07:34:04.742 |
2025-02-05 07:34:04.742 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:34:04.742 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:34:04.742 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:34:04.748 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:34:04.748 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:34:04.748 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:34:24.927 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:34:24.928 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (2) | New receive buffer size: 0
2025-02-05 07:34:24.928 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:34:25.792 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:34:25.792 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:34:25.792 | Rithmic Direct - DTC | Failed connections: 11
2025-02-05 07:34:25.792 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:34:25.792 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:34:25.792 | DTC Client socket (1) | Closed.
2025-02-05 07:34:25.796 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:34:25.797 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:34:25.808 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:34:25.808 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:34:25.808 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:34:26.045 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (2) | CloseSocket call.
2025-02-05 07:34:26.046 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:34:26.174 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (2) | Socket gracefully closed by remote side.
2025-02-05 07:34:26.174 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (2) | Closed.
2025-02-05 07:34:29.816 |
2025-02-05 07:34:29.816 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:34:29.816 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:34:29.816 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:34:29.839 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:34:29.839 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:34:29.839 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:34:45.397 | File >> Disconnect selected.
2025-02-05 07:34:45.397 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:34:45.397 | DTC Client socket (1) | Closed.
2025-02-05 07:34:45.397 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:34:48.421 |
2025-02-05 07:34:48.422 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:34:48.422 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:34:48.422 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:34:48.423 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:34:48.423 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:34:48.423 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:35:08.431 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:35:08.432 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (2) | New receive buffer size: 0
2025-02-05 07:35:08.432 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:35:09.383 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:35:09.384 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:35:09.384 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:35:09.384 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:35:09.391 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:35:09.391 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:35:09.391 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:35:09.392 | DTC Client socket (1) | Closed.
2025-02-05 07:35:09.630 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (2) | CloseSocket call.
2025-02-05 07:35:09.630 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:35:09.740 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (2) | Socket gracefully closed by remote side.
2025-02-05 07:35:09.740 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (2) | Closed.
2025-02-05 07:35:13.394 |
2025-02-05 07:35:13.398 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:35:13.398 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:35:13.398 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:35:13.402 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:35:13.402 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:35:13.402 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:35:33.391 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:35:33.391 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (2) | New receive buffer size: 0
2025-02-05 07:35:33.391 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:35:34.451 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:35:34.452 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:35:34.452 | Rithmic Direct - DTC | Failed connections: 12
2025-02-05 07:35:34.452 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:35:34.452 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:35:34.452 | DTC Client socket (1) | Closed.
2025-02-05 07:35:34.467 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:35:34.467 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:35:34.467 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:35:34.854 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:35:34.855 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:35:35.097 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (2) | CloseSocket call.
2025-02-05 07:35:35.097 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:35:35.284 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (2) | Socket gracefully closed by remote side.
2025-02-05 07:35:35.284 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (2) | Closed.
2025-02-05 07:35:38.478 |
2025-02-05 07:35:38.486 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:35:38.486 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:35:38.486 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:35:38.488 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:35:38.489 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:35:38.489 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:35:58.483 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:35:58.483 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | New receive buffer size: 0
2025-02-05 07:35:58.483 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:35:59.512 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:35:59.513 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:35:59.513 | Rithmic Direct - DTC | Failed connections: 13
2025-02-05 07:35:59.513 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:35:59.513 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:35:59.514 | DTC Client socket (1) | Closed.
2025-02-05 07:35:59.533 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:35:59.533 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:35:59.533 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:36:00.625 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:36:00.626 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:36:00.870 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | CloseSocket call.
2025-02-05 07:36:00.870 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:36:00.971 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Socket gracefully closed by remote side.
2025-02-05 07:36:00.971 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Closed.
2025-02-05 07:36:03.542 |
2025-02-05 07:36:03.545 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:36:03.545 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:36:03.545 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:36:03.553 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:36:03.554 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:36:03.554 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:36:23.560 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:36:23.561 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (2) | New receive buffer size: 0
2025-02-05 07:36:23.561 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:36:24.536 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:36:24.538 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:36:24.538 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:36:24.538 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:36:24.558 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:36:24.558 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:36:24.558 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:36:24.558 | DTC Client socket (1) | Closed.
2025-02-05 07:36:24.793 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (2) | CloseSocket call.
2025-02-05 07:36:24.794 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:36:24.874 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (2) | Socket gracefully closed by remote side.
2025-02-05 07:36:24.874 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (2) | Closed.
2025-02-05 07:36:28.564 |
2025-02-05 07:36:28.565 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:36:28.565 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:36:28.565 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:36:28.568 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:36:28.568 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:36:28.568 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:36:48.571 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:36:48.571 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (2) | New receive buffer size: 0
2025-02-05 07:36:48.571 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:36:49.613 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:36:49.613 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:36:49.614 | Rithmic Direct - DTC | Failed connections: 14
2025-02-05 07:36:49.614 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:36:49.614 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:36:49.614 | DTC Client socket (1) | Closed.
2025-02-05 07:36:49.630 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:36:49.630 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:36:49.630 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:36:49.700 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:36:49.701 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:36:49.965 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (2) | CloseSocket call.
2025-02-05 07:36:49.965 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:36:50.139 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (2) | Socket gracefully closed by remote side.
2025-02-05 07:36:50.139 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (2) | Closed.
2025-02-05 07:36:53.622 |
2025-02-05 07:36:53.623 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:36:53.623 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:36:53.623 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:36:53.626 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:36:53.627 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:36:53.627 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:37:13.632 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:37:13.632 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (2) | New receive buffer size: 0
2025-02-05 07:37:13.632 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:37:14.405 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:37:14.406 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:37:14.406 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:37:14.406 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:37:14.429 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:37:14.429 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:37:14.429 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:37:14.429 | DTC Client socket (1) | Closed.
2025-02-05 07:37:14.664 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (2) | CloseSocket call.
2025-02-05 07:37:14.682 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:37:14.863 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (2) | Socket gracefully closed by remote side.
2025-02-05 07:37:14.864 | HTTPS connection ID:35 to downloads.rithmic.com:443 for request ID:35 (2) | Closed.
2025-02-05 07:37:18.432 |
2025-02-05 07:37:18.440 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:37:18.440 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:37:18.440 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:37:18.442 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:37:18.442 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:37:18.442 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-02-05 07:37:38.445 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:37:38.445 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (2) | New receive buffer size: 0
2025-02-05 07:37:38.445 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (2) | Connecting to IP: 216.66.0.130.
2025-02-05 07:37:39.475 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2025-02-05 07:37:39.476 | DTC Client socket (1) | CloseSocket call.
2025-02-05 07:37:39.476 | Rithmic Direct - DTC | Failed connections: 15
2025-02-05 07:37:39.476 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:37:39.476 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:37:39.476 | DTC Client socket (1) | Closed.
2025-02-05 07:37:39.492 | DTC Client socket (0) | CloseSocket call.
2025-02-05 07:37:39.492 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:37:39.492 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:37:39.505 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:37:39.505 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:37:39.747 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (2) | CloseSocket call.
2025-02-05 07:37:39.748 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (2) | Shutdown started. Waiting for graceful close.
2025-02-05 07:37:39.828 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (2) | Socket gracefully closed by remote side.
2025-02-05 07:37:39.828 | HTTPS connection ID:36 to downloads.rithmic.com:443 for request ID:36 (2) | Closed.
2025-02-05 07:37:43.483 |
2025-02-05 07:37:43.486 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:37:43.486 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:37:43.486 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:37:43.487 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-02-05 07:37:43.487 | DTC Client socket (2) | New receive buffer size: 0
2025-02-05 07:37:43.487 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-02-05 07:38:03.498 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:38:03.498 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | New receive buffer size: 0
2025-02-05 07:38:03.498 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Connecting to IP: 216.66.0.130.
2025-02-05 07:38:04.412 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131
2025-02-05 07:38:04.414 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-05 07:38:04.414 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-05 07:38:04.414 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:38:04.432 | DTC Client socket (2) | CloseSocket call.
2025-02-05 07:38:04.432 | Rithmic Direct - DTC | Disconnected.
2025-02-05 07:38:04.432 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-05 07:38:04.433 | DTC Client socket (2) | Closed.
2025-02-05 07:38:04.658 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | CloseSocket call.
2025-02-05 07:38:04.659 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Shutdown started. Waiting for graceful close.
2025-02-05 07:38:04.741 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Socket gracefully closed by remote side.
2025-02-05 07:38:04.741 | HTTPS connection ID:37 to downloads.rithmic.com:443 for request ID:37 (1) | Closed.
2025-02-05 07:38:08.423 |
2025-02-05 07:38:08.423 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2025-02-05 07:38:08.423 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-02-05 07:38:08.423 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-02-05 07:38:08.425 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-05 07:38:08.425 | DTC Client socket (1) | New receive buffer size: 0
2025-02-05 07:38:08.425 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
[2025-02-05 09:07:17]
Sierra_Chart Engineering - Posts: 18778
We have contacted Rithmic about this connectivity issue.
