Date/Time: Mon, 21 Apr 2025 23:27:25 +0000
SR3 Data Feed Visibility Issue in Sierra Chart with Rithmic Connection
View Count: 153
[2025-01-30 18:35:42]
User226793 - Posts: 174
Subject: SR3 Data Feed Visibility Issue in Sierra Chart with Rithmic Connection
Dear Sierra Chart Support,
I am experiencing an issue where I cannot see the SR3 data feed in Sierra Chart while connected through Rithmic. I have confirmed directly with Rithmic that this feed exists, and I am attaching a screenshot from R | Trader Pro showing the SR3 exchange symbols with their 1-digit year codes for reference.
Could you please:
- Verify if there are any specific settings needed to enable viewing of these SR3 symbols in Sierra Chart
- Confirm if there are any known compatibility issues between Sierra Chart and this particular Rithmic feed
- Provide guidance on how to resolve this visibility issue
I can provide additional information if needed to help diagnose this problem.
Thank you for your assistance.
Best regards,
[2025-01-30 20:43:02]
John - SC Support - Posts: 39395
Please get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2025-02-11 18:45:04]
Sierra_Chart Engineering - Posts: 19290
Regarding the SR3 symbol when using Rithmic, we had to set this up and that is now done:
Date Time Of Last Edit: 2025-02-11 18:45:11
