Date/Time: Tue, 22 Apr 2025 13:57:13 +0000
error
View Count: 282
[2025-01-09 21:21:13] |
ss1776 - Posts: 19 |
hi, I have a 5 min es footprint chart from A chartbook. when i duplicate to B chartbook the 5 min automatically switched to 900volume chart. it messes with other charts and disfgures other volume charts. none of the charts are linked. none of the studies are linked. please help |
[2025-01-09 21:21:16] |
Which chart is changing to a 900 Volume chart, the one in ChartbookA or the one in ChartbookB?
[2025-01-09 21:33:23] |
chartbook B . I have noticed this issue is happening based on # of bars calculated values study.
[2025-01-09 21:47:23] |
That chart must have a reference to a different chart. The "Numbers Bars Calculated Values" study has this ability, so that would make sense. When you duplicate the chart, it is changing to the same period as the chart that is being referenced in ChartbookB. Keep in mind that the referenced chart is being referenced through the Chart Number defined in the study. So if is is referencing Chart #7 in ChartbookA, it is going to be referencing Chart #7 in ChartbookB, which may not be a chart for which you want this to be occurring. You would need to update the study if this is the case. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-09 21:55:58] |
how do i make it standalone? i don't need for it to reference other charts. how can i update?
[2025-01-09 23:05:36] |
It depends on the particular study that is referencing another chart. You mentioned that you thought it was the "Numbers Bars Calculated Values" study, in which case either delete the study or change the Input for "Reference Other Intraday Chart" to "No". Refer to the following: Numbers Bars: Reference Other Intraday Chart If it is another study, then you would need to remove the study, or change the reference if there is something else you want to reference it to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-09 23:06:30] |
Sierra_Chart Engineering - Posts: 19305 |
Also refer to: Unable to Change the Bar Time Period for Charts The chart is being referenced by another chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-09 23:07:19
[2025-01-10 15:01:59] |
HI I have another problem, my trade attach window is always showing 0 for pnl. trade simulation on it says. why is this happening. to see correct pnl i have to go under TRADE ACCOUNT MONITOR WINDOW |
[2025-01-10 22:05:51] |
Are you referring to the open position profit loss? We need to know what specific value.
[2025-01-10 22:25:02] |
I see the open pnl but the dpl or closed pnl always showing 0.
[2025-01-11 17:59:47] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-13 13:55:43] |
ok i read your post . for some reason mine doesn't say DPL it only says D
[2025-01-13 18:04:23] |
Please get us an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
