Date/Time: Tue, 22 Apr 2025 14:35:26 +0000
chart is frez no move
View Count: 344
[2025-01-08 12:42:14]
User651547 - Posts: 68
hi . i connected by Rithmic Direct DTC. Broker Topstep. Synbol M2KH5.CME . it is connected but chart no moved . what can be resone .
second quastion : how i set in sierra to see money value on the limit orders when i move it . see attached.
imagelimit.png / V - Attached On 2025-01-08 12:41:52 UTC - Size: 22.2 KB - 32 views
[2025-01-08 12:48:55]
added quastion : how can i open sierra two times togather and be conneted to different brokers ?
[2025-01-08 15:48:40]
John - SC Support - Posts: 39395
Everything on your account looks fine, so there is no reason for you to be having a problem with the data. If you are still having a problem then we need to see your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
Refer to the following setting:
Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display)
You need to have 2 different installations of Sierra Chart to do this. As long as they are on the same computer then there are no extra fees or anything special you need to setup apart from the separate installation. Follow these instructions to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
[2025-01-08 16:09:52]
now i use 2pc . each pc sierra , but when i connet in pc 1 to sierra , on pc 2 charts is no moved . i need close sierra on pc1 to use pc2. how i solve it
[2025-01-08 16:12:17]
Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
[2025-01-08 16:18:24]
2025-01-08 11:58:26.086 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:26.086 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:26.086 | Rithmic Direct - DTC (Data) | Failed connections: 2588
2025-01-08 11:58:26.086 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:26.087 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:26.087 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:26.087 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:26.087 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:26.383 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:26.383 | DTC Client socket (2) | Closed.
2025-01-08 11:58:28.088 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:28.088 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:28.088 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:28.089 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:28.089 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:28.089 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:28.388 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:28.388 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:28.388 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:28.388 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:29.527 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:29.527 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:29.527 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:29.527 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:29.527 | Rithmic Direct - DTC (Data) | Failed connections: 2589
2025-01-08 11:58:29.527 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:29.528 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:29.528 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:29.528 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:29.528 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:29.827 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:29.827 | DTC Client socket (2) | Closed.
2025-01-08 11:58:31.529 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:31.529 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:31.529 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:31.530 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:31.530 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:31.530 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:31.773 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:31.773 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:31.773 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:31.773 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:32.738 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:32.738 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:32.738 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:32.738 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:32.738 | Rithmic Direct - DTC (Data) | Failed connections: 2590
2025-01-08 11:58:32.738 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:32.739 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:32.739 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:32.739 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:32.739 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:32.982 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:32.982 | DTC Client socket (2) | Closed.
2025-01-08 11:58:34.749 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:34.749 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:34.749 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:34.750 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:34.750 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:34.750 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:35.005 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:35.005 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:35.005 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:35.005 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:36.003 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:36.003 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:36.003 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:36.003 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:36.003 | Rithmic Direct - DTC (Data) | Failed connections: 2591
2025-01-08 11:58:36.003 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:36.004 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:36.004 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:36.004 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:36.004 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:36.252 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:36.252 | DTC Client socket (2) | Closed.
2025-01-08 11:58:38.015 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:38.015 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:38.015 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:38.016 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:38.016 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:38.016 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:38.305 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:38.305 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:38.305 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:38.305 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:39.413 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:39.413 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:39.413 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:39.413 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:39.413 | Rithmic Direct - DTC (Data) | Failed connections: 2592
2025-01-08 11:58:39.413 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:39.414 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:39.414 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:39.414 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:39.414 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:39.702 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:39.702 | DTC Client socket (2) | Closed.
2025-01-08 11:58:41.414 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:41.414 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:41.414 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:41.415 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:41.415 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:41.415 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:41.737 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:41.737 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:41.737 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:41.737 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:42.932 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:42.932 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:42.932 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:42.932 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:42.932 | Rithmic Direct - DTC (Data) | Failed connections: 2593
2025-01-08 11:58:42.932 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:42.932 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:42.932 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:42.933 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:42.933 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:43.252 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:43.253 | DTC Client socket (2) | Closed.
2025-01-08 11:58:44.937 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:44.937 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:44.937 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:44.938 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:44.938 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:44.938 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:45.235 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:45.235 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:45.235 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:45.235 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:46.366 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:46.366 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:46.366 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:46.366 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:46.366 | Rithmic Direct - DTC (Data) | Failed connections: 2594
2025-01-08 11:58:46.366 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:46.367 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:46.367 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:46.367 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:46.367 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:46.661 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:46.662 | DTC Client socket (2) | Closed.
2025-01-08 11:58:48.364 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:48.364 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:48.364 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:48.365 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:48.365 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:48.365 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:48.692 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:48.692 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:48.692 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:48.692 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:49.915 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:49.915 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:49.915 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:49.915 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:49.915 | Rithmic Direct - DTC (Data) | Failed connections: 2595
2025-01-08 11:58:49.915 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:49.916 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:49.916 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:49.916 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:49.916 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:50.242 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:50.242 | DTC Client socket (2) | Closed.
2025-01-08 11:58:51.917 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:51.917 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:51.918 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:51.925 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:51.925 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:51.925 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:52.170 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:52.170 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:52.170 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:52.170 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:53.142 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:53.142 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:53.142 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:53.142 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:53.142 | Rithmic Direct - DTC (Data) | Failed connections: 2596
2025-01-08 11:58:53.142 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:53.142 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:53.143 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:53.143 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:53.143 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:53.387 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:53.387 | DTC Client socket (2) | Closed.
2025-01-08 11:58:55.154 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:55.154 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:55.154 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:55.155 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:55.155 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:55.155 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:55.447 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:55.447 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:55.448 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:55.448 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:56.576 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:56.576 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:56.576 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:56.576 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:56.576 | Rithmic Direct - DTC (Data) | Failed connections: 2597
2025-01-08 11:58:56.576 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:56.577 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:56.577 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:58:56.578 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:56.578 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:56.870 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:58:56.870 | DTC Client socket (2) | Closed.
2025-01-08 11:58:58.571 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:58:58.571 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:58:58.571 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:58:58.572 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:58:58.572 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:58:58.572 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:58:58.812 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:58:58.812 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:58:58.812 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:58:58.812 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:58:59.775 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:58:59.775 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:58:59.775 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:58:59.775 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:58:59.775 | Rithmic Direct - DTC (Data) | Failed connections: 2598
2025-01-08 11:58:59.775 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:58:59.776 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:58:59.776 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:58:59.776 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:58:59.776 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:00.016 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:00.016 | DTC Client socket (2) | Closed.
2025-01-08 11:59:01.368 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 10048
2025-01-08 11:59:01.773 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:01.773 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:01.773 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:02.303 | DTC Client socket (2) | Creating socket.
2025-01-08 11:59:02.303 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:02.303 | DTC Client socket (2) | Connecting to IP: 64.152.155.20.
2025-01-08 11:59:02.304 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:02.304 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 11:59:02.304 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:02.463 | Denali Data Feed | Network connection to server complete.
2025-01-08 11:59:02.463 | Denali Data Feed | Starting socket receive thread.
2025-01-08 11:59:02.463 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 11:59:02.551 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:02.551 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:02.551 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:02.551 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:02.632 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 11:59:02.632 | Denali Data Feed | Sending logon request message.
2025-01-08 11:59:03.147 | Denali Data Feed | Received logon response.
2025-01-08 11:59:03.147 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 11:59:03.147 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:03.147 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 11:59:03.147 | Denali Data Feed | Failed connections: 189
2025-01-08 11:59:03.147 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 11:59:03.147 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:03.147 | Denali Data Feed | Disconnected from the server.
2025-01-08 11:59:03.147 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 11:59:03.148 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:03.306 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:03.307 | DTC Client socket (2) | Closed.
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Failed connections: 2599
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:03.528 | DTC Client socket (3) | CloseSocket call.
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:03.528 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:03.528 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:03.774 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 11:59:03.774 | DTC Client socket (3) | Closed.
2025-01-08 11:59:05.517 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:05.517 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:05.517 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:05.518 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:05.518 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:05.518 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:05.764 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:05.764 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:05.764 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:05.764 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Failed connections: 2600
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:06.740 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:06.740 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:06.740 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:06.985 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:06.985 | DTC Client socket (2) | Closed.
2025-01-08 11:59:08.752 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:08.752 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:08.752 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:08.752 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:08.752 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:08.752 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:09.071 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:09.071 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:09.071 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:09.071 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:10.263 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:10.263 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:10.263 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:10.263 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:10.263 | Rithmic Direct - DTC (Data) | Failed connections: 2601
2025-01-08 11:59:10.263 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:10.264 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:10.265 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:10.265 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:10.265 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:10.581 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:10.581 | DTC Client socket (2) | Closed.
2025-01-08 11:59:12.262 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:12.262 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:12.262 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:12.262 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:12.262 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:12.263 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:12.522 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:12.522 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:12.522 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:12.522 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:13.512 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:13.512 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:13.512 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:13.512 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:13.512 | Rithmic Direct - DTC (Data) | Failed connections: 2602
2025-01-08 11:59:13.513 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:13.513 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:13.513 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:13.513 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:13.514 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:13.760 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:13.761 | DTC Client socket (2) | Closed.
2025-01-08 11:59:15.515 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:15.515 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:15.515 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:15.516 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:15.516 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:15.516 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:15.756 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:15.756 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:15.756 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:15.756 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:16.719 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:16.719 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:16.719 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:16.719 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:16.719 | Rithmic Direct - DTC (Data) | Failed connections: 2603
2025-01-08 11:59:16.719 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:16.720 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:16.720 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:16.720 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:16.720 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:16.962 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:16.962 | DTC Client socket (2) | Closed.
2025-01-08 11:59:18.734 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:18.734 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:18.734 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:18.735 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:18.736 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:18.736 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:18.984 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:18.984 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:18.984 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:18.984 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Failed connections: 2604
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:19.961 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:19.961 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:19.961 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:20.208 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:20.208 | DTC Client socket (2) | Closed.
2025-01-08 11:59:21.964 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:21.964 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:21.964 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:21.965 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:21.965 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:21.965 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:22.282 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:22.282 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:22.282 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:22.282 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:23.469 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:23.469 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:23.469 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:23.470 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:23.470 | Rithmic Direct - DTC (Data) | Failed connections: 2605
2025-01-08 11:59:23.470 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:23.470 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:23.470 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:23.470 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:23.470 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:23.787 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:23.787 | DTC Client socket (2) | Closed.
2025-01-08 11:59:25.463 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:25.463 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:25.463 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:25.464 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:25.464 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:25.464 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:25.705 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:25.705 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:25.706 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:25.706 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:26.668 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:26.668 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:26.668 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:26.668 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:26.668 | Rithmic Direct - DTC (Data) | Failed connections: 2606
2025-01-08 11:59:26.668 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:26.669 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:26.669 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:26.669 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:26.669 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:26.909 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:26.909 | DTC Client socket (2) | Closed.
2025-01-08 11:59:28.664 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:28.664 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:28.664 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:28.664 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:28.664 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:28.664 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:28.925 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:28.925 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:28.926 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:28.926 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:29.945 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:29.945 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:29.945 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:29.945 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:29.945 | Rithmic Direct - DTC (Data) | Failed connections: 2607
2025-01-08 11:59:29.945 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:29.946 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:29.946 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:29.946 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:29.946 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:30.204 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:30.204 | DTC Client socket (2) | Closed.
2025-01-08 11:59:31.943 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:31.943 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:31.943 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:31.944 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:31.944 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:31.944 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:32.184 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:32.184 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:32.184 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:32.184 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:33.146 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:33.146 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:33.146 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:33.146 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:33.146 | Rithmic Direct - DTC (Data) | Failed connections: 2608
2025-01-08 11:59:33.146 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:33.147 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:33.147 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:33.147 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:33.147 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:33.385 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:33.385 | DTC Client socket (2) | Closed.
2025-01-08 11:59:35.155 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:35.155 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:35.155 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:35.156 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:35.156 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:35.156 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:35.402 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:35.402 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:35.402 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:35.402 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:36.384 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:36.384 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:36.384 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:36.384 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:36.384 | Rithmic Direct - DTC (Data) | Failed connections: 2609
2025-01-08 11:59:36.384 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:36.385 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:36.385 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:36.385 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:36.385 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:36.630 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:36.630 | DTC Client socket (2) | Closed.
2025-01-08 11:59:38.379 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:38.379 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:38.379 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:38.380 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:38.380 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:38.380 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:38.622 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:38.622 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:38.622 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:38.622 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:39.586 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:39.586 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:39.586 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:39.586 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:39.586 | Rithmic Direct - DTC (Data) | Failed connections: 2610
2025-01-08 11:59:39.586 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:39.587 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:39.587 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:39.587 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:39.587 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:39.829 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:39.829 | DTC Client socket (2) | Closed.
2025-01-08 11:59:41.594 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:41.594 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:41.594 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:41.595 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:41.595 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:41.595 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:41.838 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:41.838 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:41.838 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:41.838 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:42.803 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:42.803 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:42.803 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:42.803 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:42.803 | Rithmic Direct - DTC (Data) | Failed connections: 2611
2025-01-08 11:59:42.803 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:42.804 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:42.804 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:42.804 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:42.804 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:43.045 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:43.045 | DTC Client socket (2) | Closed.
2025-01-08 11:59:44.808 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:44.808 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:44.808 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:44.808 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:44.808 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:44.808 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:45.058 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:45.058 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:45.058 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:45.058 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:46.042 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:46.042 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:46.042 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:46.042 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:46.042 | Rithmic Direct - DTC (Data) | Failed connections: 2612
2025-01-08 11:59:46.042 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:46.043 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:46.043 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:46.043 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:46.043 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:46.293 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:46.293 | DTC Client socket (2) | Closed.
2025-01-08 11:59:48.038 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:48.038 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:48.038 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:48.038 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:48.039 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:48.039 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:48.329 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:48.329 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:48.329 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:48.329 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:49.439 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:49.439 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:49.439 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:49.439 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:49.439 | Rithmic Direct - DTC (Data) | Failed connections: 2613
2025-01-08 11:59:49.439 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:49.440 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:49.440 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:49.440 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:49.440 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:49.730 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:49.730 | DTC Client socket (2) | Closed.
2025-01-08 11:59:51.454 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:51.454 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:51.454 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:51.596 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:51.596 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:51.596 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:51.892 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:51.892 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:51.893 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:51.893 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:53.014 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:53.014 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:53.014 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:53.014 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:53.014 | Rithmic Direct - DTC (Data) | Failed connections: 2614
2025-01-08 11:59:53.014 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:53.014 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:53.014 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:53.015 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:53.015 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:53.310 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:53.310 | DTC Client socket (2) | Closed.
2025-01-08 11:59:55.015 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:55.016 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:55.016 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:55.016 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:55.016 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:55.016 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:55.313 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:55.313 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:55.313 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:55.313 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:56.447 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:56.447 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:56.447 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:56.447 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:56.447 | Rithmic Direct - DTC (Data) | Failed connections: 2615
2025-01-08 11:59:56.447 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:56.448 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:56.448 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:56.448 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:56.448 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:56.745 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:56.745 | DTC Client socket (2) | Closed.
2025-01-08 11:59:58.454 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 11:59:58.454 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 11:59:58.454 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 11:59:58.454 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 11:59:58.454 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 11:59:58.454 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 11:59:58.699 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 11:59:58.699 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 11:59:58.699 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 11:59:58.699 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 11:59:59.679 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 11:59:59.679 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 11:59:59.679 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 11:59:59.679 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 11:59:59.679 | Rithmic Direct - DTC (Data) | Failed connections: 2616
2025-01-08 11:59:59.679 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 11:59:59.680 | DTC Client socket (2) | CloseSocket call.
2025-01-08 11:59:59.680 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 11:59:59.680 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 11:59:59.680 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 11:59:59.924 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 11:59:59.924 | DTC Client socket (2) | Closed.
2025-01-08 12:00:01.679 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:01.679 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:01.679 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:01.680 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:01.680 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:01.680 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:01.927 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:01.927 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:01.927 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:01.927 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:02.901 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:02.901 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:02.901 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:02.901 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:02.901 | Rithmic Direct - DTC (Data) | Failed connections: 2617
2025-01-08 12:00:02.901 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:02.902 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:02.902 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:02.902 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:02.902 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:03.144 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 443
2025-01-08 12:00:03.145 | DTC Client socket (3) | Creating socket.
2025-01-08 12:00:03.145 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:00:03.145 | DTC Client socket (3) | Connecting to IP: 67.214.125.4.
2025-01-08 12:00:03.147 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:03.147 | DTC Client socket (2) | Closed.
2025-01-08 12:00:03.299 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:00:03.299 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:00:03.299 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:00:03.476 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:00:03.476 | Denali Data Feed | Sending logon request message.
2025-01-08 12:00:04.012 | Denali Data Feed | Received logon response.
2025-01-08 12:00:04.012 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:00:04.012 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:04.012 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:00:04.012 | Denali Data Feed | Failed connections: 190
2025-01-08 12:00:04.012 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:00:04.012 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:00:04.012 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:00:04.012 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:00:04.012 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:04.165 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:00:04.165 | DTC Client socket (3) | Closed.
2025-01-08 12:00:04.904 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:04.904 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:04.904 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:04.905 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:04.905 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:04.905 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:05.208 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:05.208 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:05.208 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:05.208 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Failed connections: 2618
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:06.350 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:06.350 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:06.350 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:06.653 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:06.653 | DTC Client socket (2) | Closed.
2025-01-08 12:00:08.357 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:08.357 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:08.357 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:08.357 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:08.357 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:08.357 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:08.646 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:08.646 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:08.646 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:08.646 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Failed connections: 2619
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:09.747 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:09.747 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:09.747 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:10.036 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:10.036 | DTC Client socket (2) | Closed.
2025-01-08 12:00:11.745 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:11.745 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:11.745 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:11.746 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:11.746 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:11.746 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:11.991 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:11.991 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:11.991 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:11.991 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:12.964 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:12.964 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:12.964 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:12.964 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:12.964 | Rithmic Direct - DTC (Data) | Failed connections: 2620
2025-01-08 12:00:12.964 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:12.965 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:12.965 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:12.965 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:12.965 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:13.210 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:13.210 | DTC Client socket (2) | Closed.
2025-01-08 12:00:14.969 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:14.969 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:14.969 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:14.970 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:14.970 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:14.970 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:15.244 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:15.244 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:15.244 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:15.244 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:16.275 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:16.275 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:16.275 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:16.275 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:16.275 | Rithmic Direct - DTC (Data) | Failed connections: 2621
2025-01-08 12:00:16.275 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:16.276 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:16.276 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:16.276 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:16.276 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:16.547 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:16.547 | DTC Client socket (2) | Closed.
2025-01-08 12:00:18.282 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:18.282 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:18.282 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:18.283 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:18.283 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:18.284 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:18.587 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:18.587 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:18.587 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:18.587 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:19.740 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:19.740 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:19.740 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:19.740 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:19.740 | Rithmic Direct - DTC (Data) | Failed connections: 2622
2025-01-08 12:00:19.740 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:19.741 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:19.741 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:19.741 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:19.742 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:20.044 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:20.044 | DTC Client socket (2) | Closed.
2025-01-08 12:00:21.748 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:21.748 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:21.748 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:21.749 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:21.750 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:21.750 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:22.038 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:22.038 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:22.039 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:22.039 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Failed connections: 2623
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:23.143 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:23.143 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:23.143 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:23.432 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:23.432 | DTC Client socket (2) | Closed.
2025-01-08 12:00:25.154 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:25.154 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:25.154 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:25.155 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:25.155 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:25.155 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:25.452 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:25.452 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:25.452 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:25.452 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:26.586 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:26.586 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:26.586 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:26.586 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:26.586 | Rithmic Direct - DTC (Data) | Failed connections: 2624
2025-01-08 12:00:26.586 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:26.587 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:26.587 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:26.587 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:26.587 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:26.884 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:26.884 | DTC Client socket (2) | Closed.
2025-01-08 12:00:28.585 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:28.585 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:28.585 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:28.585 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:28.585 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:28.585 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:28.882 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:28.882 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:28.882 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:28.882 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:30.007 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:30.007 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:30.007 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:30.007 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:30.007 | Rithmic Direct - DTC (Data) | Failed connections: 2625
2025-01-08 12:00:30.007 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:30.009 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:30.009 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:30.009 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:30.009 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:30.305 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:30.305 | DTC Client socket (2) | Closed.
2025-01-08 12:00:32.004 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:32.004 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:32.004 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:32.005 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:32.005 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:32.005 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:32.235 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:32.235 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:32.235 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:32.235 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:33.165 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:33.165 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:33.165 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:33.165 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:33.165 | Rithmic Direct - DTC (Data) | Failed connections: 2626
2025-01-08 12:00:33.165 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:33.166 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:33.166 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:33.166 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:33.166 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:33.396 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:33.396 | DTC Client socket (2) | Closed.
2025-01-08 12:00:35.172 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:35.172 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:35.172 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:35.173 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:35.173 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:35.173 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:35.400 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:35.400 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:35.400 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:35.400 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:36.326 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:36.326 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:36.327 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:36.327 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:36.327 | Rithmic Direct - DTC (Data) | Failed connections: 2627
2025-01-08 12:00:36.327 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:36.327 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:36.328 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:36.328 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:36.328 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:36.555 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:36.556 | DTC Client socket (2) | Closed.
2025-01-08 12:00:38.325 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:38.325 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:38.325 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:38.326 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:38.326 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:38.326 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:38.566 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:38.566 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:38.566 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:38.566 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Failed connections: 2628
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:39.526 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:39.526 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:39.526 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:39.766 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:39.766 | DTC Client socket (2) | Closed.
2025-01-08 12:00:41.522 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:41.522 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:41.522 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:41.523 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:41.524 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:41.524 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:41.822 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:41.822 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:41.822 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:41.822 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:42.956 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:42.956 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:42.956 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:42.956 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:42.956 | Rithmic Direct - DTC (Data) | Failed connections: 2629
2025-01-08 12:00:42.956 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:42.957 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:42.957 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:42.957 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:42.957 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:43.255 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:43.255 | DTC Client socket (2) | Closed.
2025-01-08 12:00:44.964 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:44.964 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:44.964 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:44.964 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:44.965 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:44.965 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:45.242 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:45.242 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:45.242 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:45.242 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:46.254 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:46.254 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:46.254 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:46.254 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:46.254 | Rithmic Direct - DTC (Data) | Failed connections: 2630
2025-01-08 12:00:46.254 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:46.256 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:46.256 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:46.256 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:46.256 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:46.519 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:46.520 | DTC Client socket (2) | Closed.
2025-01-08 12:00:48.265 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:48.265 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:48.265 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:48.265 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:48.265 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:48.266 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:48.591 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:48.591 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:48.591 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:48.591 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:49.808 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:49.808 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:49.808 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:49.808 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:49.808 | Rithmic Direct - DTC (Data) | Failed connections: 2631
2025-01-08 12:00:49.808 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:49.809 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:49.809 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:49.809 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:49.809 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:50.134 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:50.134 | DTC Client socket (2) | Closed.
2025-01-08 12:00:51.800 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:51.801 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:51.801 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:51.802 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:51.802 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:51.802 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:52.099 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:52.099 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:52.099 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:52.099 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Failed connections: 2632
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:53.239 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:53.239 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:53.239 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:53.533 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:53.533 | DTC Client socket (2) | Closed.
2025-01-08 12:00:55.240 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:55.240 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:55.240 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:55.241 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:55.241 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:55.241 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:55.489 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:55.489 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:55.489 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:55.489 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:56.443 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:56.443 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:56.443 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:56.443 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:56.443 | Rithmic Direct - DTC (Data) | Failed connections: 2633
2025-01-08 12:00:56.443 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:56.444 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:56.444 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:56.444 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:56.444 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:56.685 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:56.685 | DTC Client socket (2) | Closed.
2025-01-08 12:00:58.453 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:00:58.453 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:00:58.453 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:00:58.453 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:00:58.454 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:00:58.454 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:00:58.698 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:00:58.698 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:00:58.699 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:00:58.699 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Failed connections: 2634
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:00:59.671 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:00:59.671 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:00:59.671 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:00:59.917 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:00:59.917 | DTC Client socket (2) | Closed.
2025-01-08 12:01:01.664 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:01.664 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:01.664 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:01.664 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:01.664 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:01.664 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:01.909 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:01.909 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:01.910 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:01.910 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:02.881 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:02.881 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:02.881 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:02.881 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:02.881 | Rithmic Direct - DTC (Data) | Failed connections: 2635
2025-01-08 12:01:02.881 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:02.882 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:02.882 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:02.882 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:02.882 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:03.126 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:03.126 | DTC Client socket (2) | Closed.
2025-01-08 12:01:04.017 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443
2025-01-08 12:01:04.890 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:04.890 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:04.890 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:08.065 | DTC Client socket (2) | Creating socket.
2025-01-08 12:01:08.065 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:08.065 | DTC Client socket (2) | Connecting to IP: 64.152.155.18.
2025-01-08 12:01:08.066 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:08.066 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:01:08.066 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:08.218 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:01:08.218 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:01:08.218 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:01:08.311 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:08.311 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:08.311 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:08.311 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:08.379 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:01:08.379 | Denali Data Feed | Sending logon request message.
2025-01-08 12:01:08.894 | Denali Data Feed | Received logon response.
2025-01-08 12:01:08.894 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:01:08.894 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:08.894 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:01:08.894 | Denali Data Feed | Failed connections: 191
2025-01-08 12:01:08.894 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:01:08.895 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:08.895 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:01:08.895 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:01:08.895 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:09.047 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:09.047 | DTC Client socket (2) | Closed.
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Failed connections: 2636
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:09.286 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:09.286 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:09.286 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:09.531 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:01:09.531 | DTC Client socket (3) | Closed.
2025-01-08 12:01:11.286 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:11.286 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:11.286 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:11.286 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:11.287 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:11.287 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:11.552 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:11.552 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:11.552 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:11.552 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Failed connections: 2637
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:12.530 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:12.530 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:12.530 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:12.794 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:12.794 | DTC Client socket (2) | Closed.
2025-01-08 12:01:14.532 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:14.532 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:14.532 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:14.532 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:14.533 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:14.533 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:14.770 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:14.770 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:14.770 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:14.770 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:15.721 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:15.721 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:15.721 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:15.721 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:15.721 | Rithmic Direct - DTC (Data) | Failed connections: 2638
2025-01-08 12:01:15.721 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:15.722 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:15.722 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:15.722 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:15.722 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:15.959 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:15.959 | DTC Client socket (2) | Closed.
2025-01-08 12:01:17.737 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:17.737 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:17.737 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:17.738 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:17.738 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:17.738 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:17.981 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:17.981 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:17.981 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:17.981 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:18.950 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:18.950 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:18.950 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:18.950 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:18.950 | Rithmic Direct - DTC (Data) | Failed connections: 2639
2025-01-08 12:01:18.950 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:18.951 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:18.951 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:18.951 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:18.951 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:19.193 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:19.193 | DTC Client socket (2) | Closed.
2025-01-08 12:01:20.945 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:20.945 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:20.945 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:20.946 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:20.946 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:20.946 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:21.189 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:21.189 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:21.189 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:21.189 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:22.156 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:22.156 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:22.156 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:22.156 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:22.156 | Rithmic Direct - DTC (Data) | Failed connections: 2640
2025-01-08 12:01:22.156 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:22.157 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:22.157 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:22.157 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:22.157 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:22.399 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:22.399 | DTC Client socket (2) | Closed.
2025-01-08 12:01:24.152 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:24.153 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:24.153 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:24.153 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:24.153 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:24.153 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:24.448 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:24.448 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:24.448 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:24.448 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Failed connections: 2641
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:25.590 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:25.590 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:25.591 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:25.884 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:25.884 | DTC Client socket (2) | Closed.
2025-01-08 12:01:27.584 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:27.584 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:27.584 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:27.585 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:27.585 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:27.585 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:27.819 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:27.819 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:27.819 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:27.819 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:28.790 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:28.790 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:28.790 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:28.790 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:28.790 | Rithmic Direct - DTC (Data) | Failed connections: 2642
2025-01-08 12:01:28.790 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:28.791 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:28.791 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:28.791 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:28.791 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:29.052 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:29.053 | DTC Client socket (2) | Closed.
2025-01-08 12:01:30.801 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:30.801 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:30.801 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:30.802 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:30.803 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:30.803 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:31.094 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:31.094 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:31.094 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:31.094 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:32.212 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:32.212 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:32.212 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:32.212 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:32.212 | Rithmic Direct - DTC (Data) | Failed connections: 2643
2025-01-08 12:01:32.213 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:32.214 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:32.214 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:32.214 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:32.214 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:32.508 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:32.508 | DTC Client socket (2) | Closed.
2025-01-08 12:01:34.210 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:34.210 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:34.210 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:34.210 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:34.211 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:34.211 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:34.466 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:34.466 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:34.466 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:34.466 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:35.501 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:35.501 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:35.501 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:35.501 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:35.501 | Rithmic Direct - DTC (Data) | Failed connections: 2644
2025-01-08 12:01:35.501 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:35.502 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:35.502 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:35.502 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:35.502 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:35.753 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:35.753 | DTC Client socket (2) | Closed.
2025-01-08 12:01:37.512 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:37.512 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:37.512 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:37.513 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:37.513 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:37.513 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:37.754 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:37.754 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:37.754 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:37.754 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:38.713 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:38.713 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:38.713 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:38.713 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:38.713 | Rithmic Direct - DTC (Data) | Failed connections: 2645
2025-01-08 12:01:38.713 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:38.714 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:38.714 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:38.714 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:38.714 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:38.952 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:38.952 | DTC Client socket (2) | Closed.
2025-01-08 12:01:40.716 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:40.716 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:40.717 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:40.717 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:40.717 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:40.717 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:41.010 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:41.010 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:41.010 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:41.010 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:42.130 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:42.130 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:42.130 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:42.130 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:42.130 | Rithmic Direct - DTC (Data) | Failed connections: 2646
2025-01-08 12:01:42.130 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:42.131 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:42.131 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:42.131 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:42.131 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:42.424 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:42.424 | DTC Client socket (2) | Closed.
2025-01-08 12:01:44.133 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:44.133 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:44.133 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:44.133 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:44.134 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:44.134 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:44.388 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:44.388 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:44.388 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:44.388 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:45.442 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:45.442 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:45.442 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:45.442 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:45.442 | Rithmic Direct - DTC (Data) | Failed connections: 2647
2025-01-08 12:01:45.442 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:45.443 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:45.443 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:45.443 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:45.443 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:45.687 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:45.687 | DTC Client socket (2) | Closed.
2025-01-08 12:01:47.452 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:47.452 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:47.452 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:47.453 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:47.453 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:47.453 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:47.695 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:47.695 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:47.695 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:47.695 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:48.661 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:48.661 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:48.661 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:48.661 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:48.661 | Rithmic Direct - DTC (Data) | Failed connections: 2648
2025-01-08 12:01:48.661 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:48.662 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:48.662 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:48.662 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:48.662 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:48.903 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:48.904 | DTC Client socket (2) | Closed.
2025-01-08 12:01:50.662 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:50.662 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:50.662 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:50.662 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:50.663 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:50.663 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:50.903 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:50.903 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:50.903 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:50.903 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:51.870 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:51.870 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:51.870 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:51.870 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:51.870 | Rithmic Direct - DTC (Data) | Failed connections: 2649
2025-01-08 12:01:51.870 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:51.870 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:51.870 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:51.871 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:51.871 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:52.112 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:52.112 | DTC Client socket (2) | Closed.
2025-01-08 12:01:53.863 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:53.863 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:53.863 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:53.863 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:53.863 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:53.863 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:54.114 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:54.114 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:54.115 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:54.115 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:55.098 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:55.098 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:55.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:55.098 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:55.098 | Rithmic Direct - DTC (Data) | Failed connections: 2650
2025-01-08 12:01:55.098 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:55.099 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:55.099 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:55.099 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:55.099 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:55.347 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:55.347 | DTC Client socket (2) | Closed.
2025-01-08 12:01:57.107 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:01:57.107 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:01:57.107 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:01:57.108 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:01:57.108 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:01:57.108 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:01:57.406 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:01:57.406 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:01:57.406 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:01:57.406 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Failed connections: 2651
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:01:58.535 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:01:58.535 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:01:58.535 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:01:58.832 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:01:58.832 | DTC Client socket (2) | Closed.
2025-01-08 12:02:00.547 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:00.547 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:00.547 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:00.547 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:00.547 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:00.547 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:00.841 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:00.841 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:00.841 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:00.841 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:01.968 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:01.968 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:01.968 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:01.968 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:01.968 | Rithmic Direct - DTC (Data) | Failed connections: 2652
2025-01-08 12:02:01.968 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:01.969 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:01.969 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:01.969 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:01.969 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:02.264 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:02.264 | DTC Client socket (2) | Closed.
2025-01-08 12:02:03.962 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:03.962 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:03.962 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:03.963 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:03.964 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:03.964 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:04.260 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:04.260 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:04.260 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:04.260 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:05.385 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:05.385 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:05.385 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:05.385 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:05.385 | Rithmic Direct - DTC (Data) | Failed connections: 2653
2025-01-08 12:02:05.385 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:05.386 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:05.386 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:05.386 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:05.386 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:05.684 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:05.684 | DTC Client socket (2) | Closed.
2025-01-08 12:02:07.378 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:07.378 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:07.378 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:07.379 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:07.379 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:07.379 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:07.672 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:07.672 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:07.673 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:07.673 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:08.792 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:08.792 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:08.792 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:08.792 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:08.792 | Rithmic Direct - DTC (Data) | Failed connections: 2654
2025-01-08 12:02:08.792 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:08.793 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:08.793 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:08.793 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:08.793 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:08.893 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048
2025-01-08 12:02:08.893 | DTC Client socket (3) | Creating socket.
2025-01-08 12:02:08.893 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:02:08.893 | DTC Client socket (3) | Connecting to IP: 208.185.224.131.
2025-01-08 12:02:09.051 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:02:09.051 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:02:09.051 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:02:09.086 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:09.086 | DTC Client socket (2) | Closed.
2025-01-08 12:02:09.214 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:02:09.214 | Denali Data Feed | Sending logon request message.
2025-01-08 12:02:09.387 | Denali Data Feed | Received logon response.
2025-01-08 12:02:09.387 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:02:09.387 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:09.387 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary.
2025-01-08 12:02:09.387 | Denali Data Feed | Failed connections: 192
2025-01-08 12:02:09.387 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:02:09.388 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:02:09.388 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:02:09.388 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 12:02:09.388 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:09.545 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:02:09.545 | DTC Client socket (3) | Closed.
2025-01-08 12:02:10.793 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:10.793 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:10.793 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:10.794 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:10.794 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:10.794 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:11.041 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:11.041 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:11.041 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:11.041 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Failed connections: 2655
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:12.018 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:12.018 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:12.019 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:12.264 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:12.264 | DTC Client socket (2) | Closed.
2025-01-08 12:02:12.379 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:02:12.379 | DTC Client socket (2) | Creating socket.
2025-01-08 12:02:12.379 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:12.379 | DTC Client socket (2) | Connecting to IP: 67.214.125.5.
2025-01-08 12:02:12.539 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:02:12.539 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:02:12.539 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:02:12.717 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:02:12.717 | Denali Data Feed | Sending logon request message.
2025-01-08 12:02:13.277 | Denali Data Feed | Received logon response.
2025-01-08 12:02:13.277 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:02:13.277 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:13.277 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:02:13.277 | Denali Data Feed | Failed connections: 193
2025-01-08 12:02:13.277 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:02:13.278 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:13.278 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:02:13.278 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:02:13.278 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:13.438 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:13.438 | DTC Client socket (2) | Closed.
2025-01-08 12:02:14.032 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:14.032 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:14.032 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:14.033 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:14.034 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:14.034 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:14.279 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:14.279 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:14.279 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:14.279 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:15.251 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:15.251 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:15.251 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:15.251 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:15.251 | Rithmic Direct - DTC (Data) | Failed connections: 2656
2025-01-08 12:02:15.251 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:15.252 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:15.252 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:15.252 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:15.252 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:15.494 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:15.494 | DTC Client socket (2) | Closed.
2025-01-08 12:02:17.242 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:17.242 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:17.242 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:17.243 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:17.243 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:17.243 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:17.490 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:17.490 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:17.490 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:17.490 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Failed connections: 2657
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:18.465 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:18.465 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:18.465 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:18.711 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:18.711 | DTC Client socket (2) | Closed.
2025-01-08 12:02:20.469 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:20.469 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:20.469 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:20.470 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:20.470 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:20.470 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:20.758 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:20.758 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:20.758 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:20.758 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:21.867 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:21.867 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:21.867 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:21.867 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:21.867 | Rithmic Direct - DTC (Data) | Failed connections: 2658
2025-01-08 12:02:21.867 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:21.867 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:21.868 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:21.868 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:21.868 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:22.155 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:22.155 | DTC Client socket (2) | Closed.
2025-01-08 12:02:23.875 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:23.875 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:23.875 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:23.876 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:23.876 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:23.876 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:24.123 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:24.123 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:24.123 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:24.123 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:25.098 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:25.098 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:25.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:25.098 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:25.098 | Rithmic Direct - DTC (Data) | Failed connections: 2659
2025-01-08 12:02:25.099 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:25.099 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:25.099 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:25.099 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:25.099 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:25.344 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:25.345 | DTC Client socket (2) | Closed.
2025-01-08 12:02:27.102 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:27.102 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:27.102 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:27.103 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:27.104 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:27.104 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:27.344 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:27.344 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:27.344 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:27.344 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:28.305 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:28.305 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:28.305 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:28.305 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:28.305 | Rithmic Direct - DTC (Data) | Failed connections: 2660
2025-01-08 12:02:28.305 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:28.305 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:28.305 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:28.306 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:28.306 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:28.545 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:28.545 | DTC Client socket (2) | Closed.
2025-01-08 12:02:30.306 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:30.306 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:30.306 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:30.306 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:30.307 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:30.307 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:30.599 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:30.599 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:30.599 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:30.599 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:31.718 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:31.718 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:31.718 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:31.718 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:31.718 | Rithmic Direct - DTC (Data) | Failed connections: 2661
2025-01-08 12:02:31.718 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:31.719 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:31.719 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:31.719 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:31.719 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:32.011 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:32.011 | DTC Client socket (2) | Closed.
2025-01-08 12:02:33.708 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:33.708 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:33.708 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:33.709 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:33.709 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:33.709 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:33.950 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:33.950 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:33.950 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:33.950 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:34.923 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:34.923 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:34.923 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:34.923 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:34.923 | Rithmic Direct - DTC (Data) | Failed connections: 2662
2025-01-08 12:02:34.923 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:34.924 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:34.924 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:34.924 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:34.924 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:35.164 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:35.164 | DTC Client socket (2) | Closed.
2025-01-08 12:02:36.937 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:36.937 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:36.937 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:36.938 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:36.939 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:36.939 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:37.169 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:37.169 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:37.169 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:37.169 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:38.095 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:38.095 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:38.095 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:38.095 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:38.095 | Rithmic Direct - DTC (Data) | Failed connections: 2663
2025-01-08 12:02:38.095 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:38.096 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:38.096 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:38.096 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:38.096 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:38.325 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:38.325 | DTC Client socket (2) | Closed.
2025-01-08 12:02:40.107 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:40.107 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:40.107 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:40.108 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:40.108 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:40.108 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:40.346 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:40.346 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:40.346 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:40.346 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:41.302 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:41.302 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:41.302 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:41.302 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:41.302 | Rithmic Direct - DTC (Data) | Failed connections: 2664
2025-01-08 12:02:41.302 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:41.303 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:41.303 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:41.303 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:41.303 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:41.541 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:41.541 | DTC Client socket (2) | Closed.
2025-01-08 12:02:43.300 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:43.301 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:43.301 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:43.302 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:43.302 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:43.302 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:43.601 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:43.601 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:43.601 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:43.601 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:44.735 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:44.735 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:44.735 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:44.735 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:44.735 | Rithmic Direct - DTC (Data) | Failed connections: 2665
2025-01-08 12:02:44.735 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:44.735 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:44.736 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:44.736 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:44.736 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:45.032 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:45.032 | DTC Client socket (2) | Closed.
2025-01-08 12:02:46.728 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:46.728 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:46.728 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:46.729 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:46.729 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:46.730 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:46.988 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:46.988 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:46.988 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:46.988 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:47.964 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:47.964 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:47.964 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:47.964 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:47.964 | Rithmic Direct - DTC (Data) | Failed connections: 2666
2025-01-08 12:02:47.964 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:47.965 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:47.965 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:47.965 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:47.965 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:48.211 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:48.211 | DTC Client socket (2) | Closed.
2025-01-08 12:02:49.962 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:49.962 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:49.962 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:49.962 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:49.962 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:49.962 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:50.253 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:50.253 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:50.253 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:50.253 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:51.367 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:51.367 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:51.367 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:51.367 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:51.367 | Rithmic Direct - DTC (Data) | Failed connections: 2667
2025-01-08 12:02:51.367 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:51.368 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:51.368 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:51.368 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:51.368 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:51.658 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:51.658 | DTC Client socket (2) | Closed.
2025-01-08 12:02:53.376 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:53.376 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:53.376 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:53.377 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:53.377 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:53.377 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:53.619 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:53.619 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:53.619 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:53.619 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:54.583 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:54.583 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:54.583 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:54.583 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:54.583 | Rithmic Direct - DTC (Data) | Failed connections: 2668
2025-01-08 12:02:54.583 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:54.584 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:54.584 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:54.584 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:54.584 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:54.826 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:54.826 | DTC Client socket (2) | Closed.
2025-01-08 12:02:56.594 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:56.594 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:56.594 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:56.594 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:56.595 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:56.595 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:02:56.834 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:02:56.834 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:02:56.834 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:02:56.834 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:02:57.788 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:02:57.788 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:02:57.788 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:02:57.788 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:02:57.788 | Rithmic Direct - DTC (Data) | Failed connections: 2669
2025-01-08 12:02:57.788 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:02:57.789 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:02:57.789 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:02:57.789 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:02:57.789 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:02:58.027 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:02:58.027 | DTC Client socket (2) | Closed.
2025-01-08 12:02:59.786 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:02:59.786 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:02:59.786 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:02:59.787 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:02:59.787 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:02:59.787 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:00.079 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:00.079 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:00.079 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:00.079 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Failed connections: 2670
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:01.191 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:01.191 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:01.191 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:01.483 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:01.483 | DTC Client socket (2) | Closed.
2025-01-08 12:03:03.201 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:03.201 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:03.201 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:03.201 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:03.202 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:03:03.202 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:03.495 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:03.495 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:03.496 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:03.496 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:04.642 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:04.642 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:04.642 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:04.642 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:04.642 | Rithmic Direct - DTC (Data) | Failed connections: 2671
2025-01-08 12:03:04.642 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:04.642 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:03:04.642 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:04.643 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:04.643 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:04.937 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:03:04.937 | DTC Client socket (3) | Closed.
2025-01-08 12:03:06.641 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:06.641 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:06.641 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:06.642 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:06.643 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:06.643 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:06.941 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:06.941 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:06.941 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:06.941 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:08.072 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:08.072 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:08.072 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:08.072 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:08.072 | Rithmic Direct - DTC (Data) | Failed connections: 2672
2025-01-08 12:03:08.072 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:08.073 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:08.073 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:08.073 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:08.073 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:08.370 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:08.370 | DTC Client socket (2) | Closed.
2025-01-08 12:03:10.069 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:10.069 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:10.069 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:10.069 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:10.069 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:10.069 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:10.310 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:10.310 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:10.311 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:10.311 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:11.278 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:11.278 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:11.278 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:11.278 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:11.278 | Rithmic Direct - DTC (Data) | Failed connections: 2673
2025-01-08 12:03:11.278 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:11.279 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:11.279 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:11.279 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:11.279 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:11.519 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:11.519 | DTC Client socket (2) | Closed.
2025-01-08 12:03:13.280 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-01-08 12:03:13.280 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:13.280 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:13.280 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:13.281 | DTC Client socket (2) | Creating socket.
2025-01-08 12:03:13.281 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:13.281 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-01-08 12:03:13.281 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:13.281 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:03:13.282 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:13.443 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:03:13.443 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:03:13.443 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:03:13.515 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:13.515 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:13.515 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:13.515 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:13.636 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:03:13.636 | Denali Data Feed | Sending logon request message.
2025-01-08 12:03:14.183 | Denali Data Feed | Received logon response.
2025-01-08 12:03:14.183 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:03:14.183 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:14.183 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:03:14.183 | Denali Data Feed | Failed connections: 194
2025-01-08 12:03:14.183 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:03:14.183 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:14.183 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:03:14.183 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:03:14.183 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:14.345 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:14.345 | DTC Client socket (2) | Closed.
2025-01-08 12:03:14.452 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:14.452 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:14.452 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:14.452 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:14.452 | Rithmic Direct - DTC (Data) | Failed connections: 2674
2025-01-08 12:03:14.452 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:14.452 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:03:14.452 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:14.453 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:14.453 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:14.686 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:03:14.686 | DTC Client socket (3) | Closed.
2025-01-08 12:03:16.451 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:16.451 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:16.451 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:16.452 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:16.452 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:16.452 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:16.696 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:16.696 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:16.696 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:16.696 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:17.647 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:17.647 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:17.647 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:17.647 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:17.647 | Rithmic Direct - DTC (Data) | Failed connections: 2675
2025-01-08 12:03:17.647 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:17.647 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:17.647 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:17.648 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:17.648 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:17.883 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:17.883 | DTC Client socket (2) | Closed.
2025-01-08 12:03:19.646 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:19.646 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:19.646 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:19.646 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:19.646 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:19.646 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:19.888 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:19.888 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:19.888 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:19.888 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:20.852 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:20.852 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:20.852 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:20.852 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:20.852 | Rithmic Direct - DTC (Data) | Failed connections: 2676
2025-01-08 12:03:20.852 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:20.853 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:20.853 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:20.853 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:20.853 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:21.095 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:21.095 | DTC Client socket (2) | Closed.
2025-01-08 12:03:22.856 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:22.856 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:22.856 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:22.857 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:22.857 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:22.857 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:23.151 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:23.151 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:23.151 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:23.151 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:24.271 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:24.271 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:24.271 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:24.271 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:24.271 | Rithmic Direct - DTC (Data) | Failed connections: 2677
2025-01-08 12:03:24.271 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:24.272 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:24.272 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:24.272 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:24.272 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:24.567 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:24.567 | DTC Client socket (2) | Closed.
2025-01-08 12:03:26.278 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:26.278 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:26.278 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:26.278 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:26.279 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:26.279 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:26.528 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:26.528 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:26.528 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:26.528 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:27.517 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:27.517 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:27.517 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:27.517 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:27.517 | Rithmic Direct - DTC (Data) | Failed connections: 2678
2025-01-08 12:03:27.518 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:27.518 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:27.518 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:27.518 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:27.518 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:27.769 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:27.769 | DTC Client socket (2) | Closed.
2025-01-08 12:03:29.531 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:29.531 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:29.531 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:29.532 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:29.532 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:29.532 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:29.822 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:29.822 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:29.823 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:29.823 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:30.936 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:30.936 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:30.936 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:30.936 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:30.936 | Rithmic Direct - DTC (Data) | Failed connections: 2679
2025-01-08 12:03:30.936 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:30.936 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:30.937 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:30.937 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:30.937 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:31.226 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:31.226 | DTC Client socket (2) | Closed.
2025-01-08 12:03:32.929 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:32.929 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:32.929 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:32.930 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:32.930 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:32.930 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:33.159 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:33.159 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:33.159 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:33.159 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:34.088 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:34.088 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:34.088 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:34.088 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:34.088 | Rithmic Direct - DTC (Data) | Failed connections: 2680
2025-01-08 12:03:34.088 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:34.089 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:34.089 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:34.089 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:34.089 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:34.317 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:34.317 | DTC Client socket (2) | Closed.
2025-01-08 12:03:36.081 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:36.081 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:36.081 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:36.082 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:36.082 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:36.082 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:36.396 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:36.396 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:36.396 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:36.396 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:37.582 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:37.582 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:37.582 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:37.582 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:37.582 | Rithmic Direct - DTC (Data) | Failed connections: 2681
2025-01-08 12:03:37.582 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:37.583 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:37.583 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:37.583 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:37.583 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:37.897 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:37.898 | DTC Client socket (2) | Closed.
2025-01-08 12:03:39.585 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:39.585 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:39.585 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:39.586 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:39.586 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:39.586 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:39.823 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:39.823 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:39.823 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:39.823 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Failed connections: 2682
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:40.777 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:40.777 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:40.777 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:41.015 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:41.015 | DTC Client socket (2) | Closed.
2025-01-08 12:03:42.775 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:42.775 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:42.775 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:42.776 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:42.776 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:42.776 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:43.027 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:43.027 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:43.027 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:43.027 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:44.018 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:44.018 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:44.018 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:44.018 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:44.018 | Rithmic Direct - DTC (Data) | Failed connections: 2683
2025-01-08 12:03:44.018 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:44.019 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:44.019 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:44.020 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:44.020 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:44.269 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:44.269 | DTC Client socket (2) | Closed.
2025-01-08 12:03:46.030 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:46.030 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:46.030 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:46.031 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:46.031 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:46.031 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:46.277 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:46.277 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:46.277 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:46.277 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:47.252 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:47.252 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:47.252 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:47.252 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:47.252 | Rithmic Direct - DTC (Data) | Failed connections: 2684
2025-01-08 12:03:47.252 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:47.253 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:47.253 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:47.253 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:47.253 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:47.497 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:47.497 | DTC Client socket (2) | Closed.
2025-01-08 12:03:49.268 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:49.268 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:49.268 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:49.269 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:49.269 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:49.269 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:49.519 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:49.519 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:49.519 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:49.519 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:50.508 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:50.508 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:50.508 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:50.508 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:50.508 | Rithmic Direct - DTC (Data) | Failed connections: 2685
2025-01-08 12:03:50.508 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:50.509 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:50.509 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:50.509 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:50.509 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:50.759 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:50.759 | DTC Client socket (2) | Closed.
2025-01-08 12:03:52.534 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:52.534 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:52.534 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:52.535 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:52.535 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:52.535 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:52.785 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:52.785 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:52.785 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:52.785 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:53.777 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:53.777 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:53.777 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:53.777 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:53.777 | Rithmic Direct - DTC (Data) | Failed connections: 2686
2025-01-08 12:03:53.777 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:53.778 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:53.778 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:53.778 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:53.778 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:54.029 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:54.029 | DTC Client socket (2) | Closed.
2025-01-08 12:03:55.782 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:55.782 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:55.782 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:55.783 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:55.783 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:55.783 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:56.078 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:56.078 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:56.079 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:56.079 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:03:57.209 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:03:57.209 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:03:57.209 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:03:57.209 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:03:57.209 | Rithmic Direct - DTC (Data) | Failed connections: 2687
2025-01-08 12:03:57.209 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:03:57.210 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:03:57.210 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:03:57.210 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:03:57.210 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:03:57.507 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:03:57.507 | DTC Client socket (2) | Closed.
2025-01-08 12:03:59.205 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:03:59.205 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:03:59.205 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:03:59.205 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:03:59.205 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:03:59.205 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:03:59.435 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:03:59.435 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:03:59.435 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:03:59.436 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:00.366 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:00.366 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:00.366 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:00.366 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:00.366 | Rithmic Direct - DTC (Data) | Failed connections: 2688
2025-01-08 12:04:00.366 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:00.367 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:00.367 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:00.367 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:00.367 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:00.597 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:00.597 | DTC Client socket (2) | Closed.
2025-01-08 12:04:02.369 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:02.369 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:02.369 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:02.370 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:02.370 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:02.370 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:02.665 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:02.665 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:02.666 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:02.666 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:03.799 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:03.799 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:03.799 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:03.799 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:03.799 | Rithmic Direct - DTC (Data) | Failed connections: 2689
2025-01-08 12:04:03.799 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:03.799 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:03.800 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:03.800 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:03.800 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:04.094 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:04.094 | DTC Client socket (2) | Closed.
2025-01-08 12:04:05.809 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:05.809 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:05.809 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:05.810 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:05.810 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:05.810 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:06.052 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:06.052 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:06.052 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:06.052 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:07.027 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:07.027 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:07.027 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:07.027 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:07.027 | Rithmic Direct - DTC (Data) | Failed connections: 2690
2025-01-08 12:04:07.028 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:07.029 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:07.029 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:07.029 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:07.029 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:07.269 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:07.269 | DTC Client socket (2) | Closed.
2025-01-08 12:04:09.032 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:09.032 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:09.032 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:09.032 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:09.033 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:09.033 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:09.278 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:09.278 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:09.278 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:09.278 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:10.247 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:10.247 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:10.247 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:10.247 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:10.247 | Rithmic Direct - DTC (Data) | Failed connections: 2691
2025-01-08 12:04:10.247 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:10.248 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:10.248 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:10.248 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:10.248 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:10.491 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:10.491 | DTC Client socket (2) | Closed.
2025-01-08 12:04:12.246 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:12.246 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:12.246 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:12.247 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:12.247 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:12.247 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:12.491 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:12.491 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:12.492 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:12.492 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:13.474 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:13.474 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:13.474 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:13.474 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:13.474 | Rithmic Direct - DTC (Data) | Failed connections: 2692
2025-01-08 12:04:13.474 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:13.475 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:13.475 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:13.475 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:13.475 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:13.747 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:13.748 | DTC Client socket (2) | Closed.
2025-01-08 12:04:14.180 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:04:14.181 | DTC Client socket (2) | Creating socket.
2025-01-08 12:04:14.181 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:14.182 | DTC Client socket (2) | Connecting to IP: 67.214.125.5.
2025-01-08 12:04:14.347 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:04:14.347 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:04:14.347 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:04:14.535 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:04:14.535 | Denali Data Feed | Sending logon request message.
2025-01-08 12:04:15.076 | Denali Data Feed | Received logon response.
2025-01-08 12:04:15.076 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:04:15.076 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:15.076 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:04:15.076 | Denali Data Feed | Failed connections: 195
2025-01-08 12:04:15.076 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:04:15.076 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:15.076 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:04:15.076 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:04:15.076 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:15.242 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:15.242 | DTC Client socket (2) | Closed.
2025-01-08 12:04:15.473 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:15.473 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:15.473 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:15.473 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:15.473 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:15.473 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:15.771 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:15.771 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:15.771 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:15.771 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:16.906 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:16.906 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:16.906 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:16.906 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:16.906 | Rithmic Direct - DTC (Data) | Failed connections: 2693
2025-01-08 12:04:16.906 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:16.906 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:16.907 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:16.907 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:16.907 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:17.204 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:17.204 | DTC Client socket (2) | Closed.
2025-01-08 12:04:18.907 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:18.907 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:18.907 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:18.908 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:18.908 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:18.908 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:19.135 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:19.135 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:19.136 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:19.136 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:20.057 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:20.057 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:20.057 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:20.057 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:20.057 | Rithmic Direct - DTC (Data) | Failed connections: 2694
2025-01-08 12:04:20.057 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:20.058 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:20.058 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:20.058 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:20.058 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:20.285 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:20.286 | DTC Client socket (2) | Closed.
2025-01-08 12:04:22.060 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:22.060 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:22.060 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:22.061 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:22.061 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:22.061 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:22.299 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:22.299 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:22.299 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:22.299 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:23.250 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:23.250 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:23.250 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:23.250 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:23.250 | Rithmic Direct - DTC (Data) | Failed connections: 2695
2025-01-08 12:04:23.250 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:23.251 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:23.251 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:23.251 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:23.251 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:23.489 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:23.489 | DTC Client socket (2) | Closed.
2025-01-08 12:04:25.239 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:25.239 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:25.239 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:25.240 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:25.240 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:25.240 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:25.534 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:25.534 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:25.534 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:25.534 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Failed connections: 2696
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:26.650 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:26.650 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:26.650 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:26.944 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:26.945 | DTC Client socket (2) | Closed.
2025-01-08 12:04:28.652 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:28.652 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:28.652 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:28.653 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:28.653 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:28.653 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:28.949 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:28.949 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:28.950 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:28.950 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Failed connections: 2697
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:30.081 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:30.081 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:30.081 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:30.376 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:30.376 | DTC Client socket (2) | Closed.
2025-01-08 12:04:32.089 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:32.089 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:32.089 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:32.089 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:32.090 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:32.090 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:32.319 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:32.319 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:32.319 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:32.319 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Failed connections: 2698
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:33.243 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:33.243 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:33.243 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:33.472 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:33.472 | DTC Client socket (2) | Closed.
2025-01-08 12:04:35.246 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:35.246 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:35.246 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:35.246 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:35.246 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:35.246 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:35.539 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:35.539 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:35.539 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:35.539 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:36.659 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:36.659 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:36.659 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:36.659 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:36.659 | Rithmic Direct - DTC (Data) | Failed connections: 2699
2025-01-08 12:04:36.659 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:36.660 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:36.660 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:36.660 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:36.660 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:36.953 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:36.953 | DTC Client socket (2) | Closed.
2025-01-08 12:04:38.665 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:38.665 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:38.665 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:38.665 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:38.665 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:38.665 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:38.908 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:38.908 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:38.909 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:38.909 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:39.873 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:39.873 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:39.873 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:39.873 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:39.873 | Rithmic Direct - DTC (Data) | Failed connections: 2700
2025-01-08 12:04:39.873 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:39.874 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:39.874 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:39.874 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:39.874 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:40.116 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:40.116 | DTC Client socket (2) | Closed.
2025-01-08 12:04:41.877 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:41.877 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:41.877 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:41.878 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:41.878 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:41.878 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:42.120 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:42.120 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:42.120 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:42.120 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Failed connections: 2701
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:43.083 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:43.083 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:43.083 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:43.336 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:43.336 | DTC Client socket (2) | Closed.
2025-01-08 12:04:45.084 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:45.084 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:45.084 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:45.085 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:45.085 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:45.085 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:45.376 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:45.376 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:45.376 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:45.376 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:46.490 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:46.490 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:46.490 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:46.490 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:46.490 | Rithmic Direct - DTC (Data) | Failed connections: 2702
2025-01-08 12:04:46.491 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:46.491 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:46.491 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:46.491 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:46.492 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:46.783 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:46.783 | DTC Client socket (2) | Closed.
2025-01-08 12:04:48.498 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:48.498 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:48.498 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:48.499 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:48.499 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:48.499 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:48.741 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:48.741 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:48.741 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:48.741 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:49.702 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:49.702 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:49.702 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:49.702 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:49.702 | Rithmic Direct - DTC (Data) | Failed connections: 2703
2025-01-08 12:04:49.702 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:49.703 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:49.703 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:49.703 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:49.703 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:49.944 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:49.944 | DTC Client socket (2) | Closed.
2025-01-08 12:04:51.693 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:51.693 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:51.693 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:51.844 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:51.844 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:51.844 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:52.137 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:52.137 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:52.137 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:52.137 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:53.269 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:53.269 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:53.269 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:53.269 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:53.269 | Rithmic Direct - DTC (Data) | Failed connections: 2704
2025-01-08 12:04:53.269 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:53.270 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:53.270 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:53.270 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:53.270 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:53.565 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:53.565 | DTC Client socket (2) | Closed.
2025-01-08 12:04:55.276 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:55.276 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:55.276 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:55.278 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:55.278 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:55.278 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:55.534 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:55.534 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:55.534 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:55.534 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:56.508 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:56.508 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:56.508 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:56.508 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:56.508 | Rithmic Direct - DTC (Data) | Failed connections: 2705
2025-01-08 12:04:56.508 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:56.510 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:56.510 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:56.510 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:56.510 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:04:56.750 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:04:56.750 | DTC Client socket (2) | Closed.
2025-01-08 12:04:58.526 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:04:58.526 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:04:58.526 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:04:58.527 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:04:58.528 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:04:58.528 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:04:58.775 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:04:58.775 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:04:58.775 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:04:58.775 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:04:59.771 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:04:59.771 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:04:59.771 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:04:59.771 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:04:59.771 | Rithmic Direct - DTC (Data) | Failed connections: 2706
2025-01-08 12:04:59.771 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:04:59.772 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:04:59.772 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:04:59.772 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:04:59.772 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:00.019 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:00.019 | DTC Client socket (2) | Closed.
2025-01-08 12:05:01.783 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:01.783 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:01.783 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:01.784 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:01.784 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:01.784 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:02.079 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:02.079 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:02.079 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:02.079 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:03.205 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:03.205 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:03.205 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:03.205 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:03.205 | Rithmic Direct - DTC (Data) | Failed connections: 2707
2025-01-08 12:05:03.205 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:03.206 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:03.206 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:03.207 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:03.207 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:03.505 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:03.505 | DTC Client socket (2) | Closed.
2025-01-08 12:05:05.219 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:05.219 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:05.219 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:05.220 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:05.220 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:05.220 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:05.468 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:05.468 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:05.468 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:05.468 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:06.454 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:06.454 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:06.454 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:06.454 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:06.454 | Rithmic Direct - DTC (Data) | Failed connections: 2708
2025-01-08 12:05:06.454 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:06.455 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:06.455 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:06.455 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:06.455 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:06.703 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:06.703 | DTC Client socket (2) | Closed.
2025-01-08 12:05:08.468 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:08.468 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:08.468 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:08.468 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:08.469 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:08.469 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:08.718 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:08.718 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:08.718 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:08.718 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Failed connections: 2709
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:09.711 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:09.711 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:09.711 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:09.961 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:09.961 | DTC Client socket (2) | Closed.
2025-01-08 12:05:11.711 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:11.711 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:11.711 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:11.713 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:11.713 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:11.713 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:12.007 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:12.007 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:12.007 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:12.007 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Failed connections: 2710
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:13.129 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:13.129 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:13.129 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:13.423 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:13.423 | DTC Client socket (2) | Closed.
2025-01-08 12:05:15.072 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443
2025-01-08 12:05:15.133 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:15.133 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:15.133 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:15.193 | DTC Client socket (2) | Creating socket.
2025-01-08 12:05:15.193 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:15.193 | DTC Client socket (2) | Connecting to IP: 64.152.155.21.
2025-01-08 12:05:15.193 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:15.193 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:05:15.193 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:15.354 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:05:15.354 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:05:15.354 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:05:15.433 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:15.433 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:15.434 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:15.434 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:15.529 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:05:15.529 | Denali Data Feed | Sending logon request message.
2025-01-08 12:05:16.053 | Denali Data Feed | Received logon response.
2025-01-08 12:05:16.053 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:05:16.053 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:16.053 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:05:16.053 | Denali Data Feed | Failed connections: 196
2025-01-08 12:05:16.053 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:05:16.054 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:16.054 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:05:16.054 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:05:16.054 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:16.213 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:16.213 | DTC Client socket (2) | Closed.
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Failed connections: 2711
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:16.391 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:16.391 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:16.391 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:16.631 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:05:16.631 | DTC Client socket (3) | Closed.
2025-01-08 12:05:18.390 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:18.390 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:18.391 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:18.391 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:18.392 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:18.392 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:18.639 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:18.639 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:18.639 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:18.639 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:19.619 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:19.619 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:19.619 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:19.619 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:19.619 | Rithmic Direct - DTC (Data) | Failed connections: 2712
2025-01-08 12:05:19.619 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:19.620 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:19.620 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:19.620 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:19.620 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:19.867 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:19.867 | DTC Client socket (2) | Closed.
2025-01-08 12:05:21.622 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:21.622 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:21.622 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:21.623 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:21.624 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:21.624 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:21.871 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:21.871 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:21.872 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:21.872 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:22.859 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:22.859 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:22.859 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:22.859 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:22.859 | Rithmic Direct - DTC (Data) | Failed connections: 2713
2025-01-08 12:05:22.859 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:22.860 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:22.860 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:22.860 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:22.860 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:23.108 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:23.108 | DTC Client socket (2) | Closed.
2025-01-08 12:05:24.852 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:24.852 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:24.852 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:24.853 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:24.854 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:24.854 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:25.103 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:25.103 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:25.103 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:25.103 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:26.089 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:26.089 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:26.089 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:26.089 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:26.089 | Rithmic Direct - DTC (Data) | Failed connections: 2714
2025-01-08 12:05:26.089 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:26.090 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:26.090 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:26.090 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:26.090 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:26.338 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:26.338 | DTC Client socket (2) | Closed.
2025-01-08 12:05:28.083 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:28.083 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:28.083 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:28.083 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:28.084 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:28.084 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:28.330 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:28.330 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:28.331 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:28.331 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:29.306 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:29.306 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:29.306 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:29.306 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:29.306 | Rithmic Direct - DTC (Data) | Failed connections: 2715
2025-01-08 12:05:29.306 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:29.307 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:29.307 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:29.307 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:29.307 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:29.553 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:29.553 | DTC Client socket (2) | Closed.
2025-01-08 12:05:31.306 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:31.306 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:31.306 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:31.306 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:31.306 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:31.306 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:31.551 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:31.551 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:31.552 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:31.552 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:32.538 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:32.538 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:32.538 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:32.538 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:32.538 | Rithmic Direct - DTC (Data) | Failed connections: 2716
2025-01-08 12:05:32.538 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:32.539 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:32.539 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:32.539 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:32.539 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:32.784 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:32.784 | DTC Client socket (2) | Closed.
2025-01-08 12:05:34.543 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:34.543 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:34.543 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:34.544 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:34.545 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:34.545 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:34.783 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:34.783 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:34.783 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:34.783 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:35.741 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:35.741 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:35.741 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:35.741 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:35.741 | Rithmic Direct - DTC (Data) | Failed connections: 2717
2025-01-08 12:05:35.741 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:35.742 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:35.742 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:35.743 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:35.743 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:35.982 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:35.982 | DTC Client socket (2) | Closed.
2025-01-08 12:05:37.739 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:37.739 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:37.739 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:37.740 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:37.740 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:37.740 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:38.034 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:38.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:38.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:38.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:39.158 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:39.158 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:39.158 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:39.158 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:39.158 | Rithmic Direct - DTC (Data) | Failed connections: 2718
2025-01-08 12:05:39.158 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:39.158 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:39.159 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:39.159 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:39.159 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:39.452 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:39.452 | DTC Client socket (2) | Closed.
2025-01-08 12:05:41.158 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:41.158 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:41.158 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:41.159 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:41.159 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:41.159 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:41.411 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:41.411 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:41.411 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:41.411 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:42.405 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:42.405 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:42.405 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:42.405 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:42.405 | Rithmic Direct - DTC (Data) | Failed connections: 2719
2025-01-08 12:05:42.405 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:42.406 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:42.406 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:42.406 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:42.406 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:42.657 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:42.658 | DTC Client socket (2) | Closed.
2025-01-08 12:05:44.404 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:44.405 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:44.405 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:44.406 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:44.406 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:44.406 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:44.649 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:44.649 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:44.649 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:44.649 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:45.614 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:45.614 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:45.614 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:45.614 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:45.614 | Rithmic Direct - DTC (Data) | Failed connections: 2720
2025-01-08 12:05:45.614 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:45.615 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:45.615 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:45.615 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:45.615 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:45.857 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:45.857 | DTC Client socket (2) | Closed.
2025-01-08 12:05:47.624 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:47.624 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:47.624 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:47.625 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:47.625 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:47.625 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:47.855 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:47.855 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:47.856 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:47.856 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:48.783 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:48.783 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:48.783 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:48.783 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:48.783 | Rithmic Direct - DTC (Data) | Failed connections: 2721
2025-01-08 12:05:48.783 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:48.784 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:48.784 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:48.784 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:48.784 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:49.015 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:49.015 | DTC Client socket (2) | Closed.
2025-01-08 12:05:50.795 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:50.795 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:50.795 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:50.796 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:50.796 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:50.796 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:51.087 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:51.087 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:51.088 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:51.088 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:52.202 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:52.202 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:52.202 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:52.202 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:52.202 | Rithmic Direct - DTC (Data) | Failed connections: 2722
2025-01-08 12:05:52.202 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:52.203 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:52.203 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:52.203 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:52.203 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:52.494 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:52.495 | DTC Client socket (2) | Closed.
2025-01-08 12:05:54.203 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:54.203 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:54.203 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:54.203 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:54.204 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:54.204 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:54.498 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:54.498 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:54.498 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:54.498 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:55.632 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:55.632 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:55.632 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:55.632 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:55.632 | Rithmic Direct - DTC (Data) | Failed connections: 2723
2025-01-08 12:05:55.632 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:55.633 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:55.633 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:55.633 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:55.633 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:55.928 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:55.928 | DTC Client socket (2) | Closed.
2025-01-08 12:05:57.633 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:05:57.633 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:05:57.633 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:05:57.634 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:05:57.634 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:05:57.634 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:05:57.960 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:05:57.960 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:05:57.960 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:05:57.960 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:05:59.173 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:05:59.173 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:05:59.173 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:05:59.173 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:05:59.173 | Rithmic Direct - DTC (Data) | Failed connections: 2724
2025-01-08 12:05:59.173 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:05:59.173 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:05:59.174 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:05:59.174 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:05:59.174 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:05:59.498 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:05:59.499 | DTC Client socket (2) | Closed.
2025-01-08 12:06:01.179 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:01.179 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:01.179 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:01.180 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:01.180 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:01.180 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:01.470 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:01.470 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:01.470 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:01.470 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Failed connections: 2725
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:02.581 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:02.581 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:02.581 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:02.871 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:02.871 | DTC Client socket (2) | Closed.
2025-01-08 12:06:04.587 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:04.587 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:04.587 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:04.587 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:04.587 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:04.587 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:04.869 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:04.869 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:04.869 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:04.869 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:05.845 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:05.845 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:05.845 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:05.845 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:05.845 | Rithmic Direct - DTC (Data) | Failed connections: 2726
2025-01-08 12:06:05.845 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:05.846 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:05.846 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:05.846 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:05.846 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:06.105 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:06.105 | DTC Client socket (2) | Closed.
2025-01-08 12:06:07.849 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:07.849 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:07.849 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:07.850 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:07.850 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:07.850 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:08.082 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:08.082 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:08.082 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:08.082 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:09.017 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:09.017 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:09.017 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:09.017 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:09.017 | Rithmic Direct - DTC (Data) | Failed connections: 2727
2025-01-08 12:06:09.017 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:09.018 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:09.018 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:09.018 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:09.018 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:09.248 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:09.248 | DTC Client socket (2) | Closed.
2025-01-08 12:06:11.030 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:11.030 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:11.030 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:11.031 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:11.031 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:11.031 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:11.328 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:11.328 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:11.328 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:11.328 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Failed connections: 2728
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:12.456 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:12.456 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:12.457 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:12.753 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:12.753 | DTC Client socket (2) | Closed.
2025-01-08 12:06:14.469 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:14.469 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:14.469 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:14.470 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:14.471 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:14.471 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:14.770 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:14.770 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:14.770 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:14.770 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:15.905 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:15.905 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:15.905 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:15.905 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:15.905 | Rithmic Direct - DTC (Data) | Failed connections: 2729
2025-01-08 12:06:15.905 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:15.906 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:15.906 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:15.906 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:15.906 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:16.058 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048
2025-01-08 12:06:16.204 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:16.204 | DTC Client socket (2) | Closed.
2025-01-08 12:06:17.688 | DTC Client socket (3) | Creating socket.
2025-01-08 12:06:17.688 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:06:17.688 | DTC Client socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:06:17.841 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:06:17.841 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:06:17.841 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:06:17.908 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:17.908 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:17.908 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:17.909 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:17.909 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:17.909 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:18.007 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:06:18.007 | Denali Data Feed | Sending logon request message.
2025-01-08 12:06:18.148 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:18.148 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:18.148 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:18.148 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:18.534 | Denali Data Feed | Received logon response.
2025-01-08 12:06:18.534 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:06:18.534 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:18.534 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:06:18.534 | Denali Data Feed | Failed connections: 197
2025-01-08 12:06:18.534 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:06:18.534 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:06:18.535 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:06:18.535 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:06:18.535 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:18.688 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:06:18.688 | DTC Client socket (3) | Closed.
2025-01-08 12:06:19.108 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:19.108 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:19.108 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:19.108 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:19.108 | Rithmic Direct - DTC (Data) | Failed connections: 2730
2025-01-08 12:06:19.108 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:19.109 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:19.109 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:19.109 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:19.109 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:19.348 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:19.348 | DTC Client socket (2) | Closed.
2025-01-08 12:06:21.106 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:21.106 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:21.106 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:21.107 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:21.107 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:21.107 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:21.354 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:21.354 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:21.354 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:21.354 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:22.332 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:22.332 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:22.332 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:22.332 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:22.332 | Rithmic Direct - DTC (Data) | Failed connections: 2731
2025-01-08 12:06:22.332 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:22.332 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:22.333 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:22.333 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:22.333 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:22.578 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:22.578 | DTC Client socket (2) | Closed.
2025-01-08 12:06:24.341 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:24.341 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:24.341 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:24.342 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:24.342 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:24.342 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:24.640 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:24.640 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:24.640 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:24.640 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:25.771 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:25.771 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:25.771 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:25.771 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:25.771 | Rithmic Direct - DTC (Data) | Failed connections: 2732
2025-01-08 12:06:25.771 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:25.772 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:25.772 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:25.772 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:25.772 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:26.067 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:26.067 | DTC Client socket (2) | Closed.
2025-01-08 12:06:27.783 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:27.783 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:27.783 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:27.783 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:27.783 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:27.783 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:28.033 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:28.033 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:28.033 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:28.033 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:28.998 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:28.998 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:28.998 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:28.998 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:28.998 | Rithmic Direct - DTC (Data) | Failed connections: 2733
2025-01-08 12:06:28.998 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:28.999 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:28.999 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:28.999 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:28.999 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:29.240 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:29.240 | DTC Client socket (2) | Closed.
2025-01-08 12:06:30.999 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:30.999 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:30.999 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:31.000 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:31.001 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:31.001 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:31.292 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:31.292 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:31.292 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:31.292 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Failed connections: 2734
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:32.401 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:32.401 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:32.401 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:32.693 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:32.693 | DTC Client socket (2) | Closed.
2025-01-08 12:06:34.404 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:34.404 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:34.404 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:34.404 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:34.404 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:34.404 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:34.697 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:34.697 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:34.697 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:34.697 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:35.824 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:35.824 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:35.824 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:35.824 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:35.824 | Rithmic Direct - DTC (Data) | Failed connections: 2735
2025-01-08 12:06:35.824 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:35.825 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:35.825 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:35.825 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:35.825 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:36.116 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:36.116 | DTC Client socket (2) | Closed.
2025-01-08 12:06:37.822 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:37.822 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:37.822 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:37.823 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:37.823 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:37.823 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:38.118 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:38.118 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:38.118 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:38.118 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:39.243 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:39.243 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:39.243 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:39.243 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:39.243 | Rithmic Direct - DTC (Data) | Failed connections: 2736
2025-01-08 12:06:39.243 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:39.244 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:39.244 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:39.244 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:39.244 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:39.539 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:39.539 | DTC Client socket (2) | Closed.
2025-01-08 12:06:41.265 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:41.265 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:41.265 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:41.266 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:41.266 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:41.266 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:41.558 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:41.558 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:41.558 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:41.558 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:42.676 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:42.676 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:42.676 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:42.676 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:42.676 | Rithmic Direct - DTC (Data) | Failed connections: 2737
2025-01-08 12:06:42.676 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:42.677 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:42.677 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:42.677 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:42.677 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:42.969 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:42.969 | DTC Client socket (2) | Closed.
2025-01-08 12:06:44.688 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:44.688 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:44.688 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:44.689 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:44.689 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:44.689 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:44.987 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:44.987 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:44.987 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:44.987 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:46.131 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:46.131 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:46.131 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:46.131 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:46.131 | Rithmic Direct - DTC (Data) | Failed connections: 2738
2025-01-08 12:06:46.131 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:46.132 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:46.132 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:46.132 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:46.132 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:46.431 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:46.431 | DTC Client socket (2) | Closed.
2025-01-08 12:06:48.129 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:48.129 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:48.129 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:48.129 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:48.130 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:48.130 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:48.418 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:48.418 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:48.418 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:48.418 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:49.530 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:49.530 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:49.530 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:49.530 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:49.530 | Rithmic Direct - DTC (Data) | Failed connections: 2739
2025-01-08 12:06:49.530 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:49.531 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:49.531 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:49.531 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:49.531 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:49.820 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:49.821 | DTC Client socket (2) | Closed.
2025-01-08 12:06:51.553 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:51.553 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:51.553 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:51.554 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:51.554 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:51.554 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:51.849 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:51.849 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:51.850 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:51.850 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:52.982 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:52.982 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:52.982 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:52.982 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:52.982 | Rithmic Direct - DTC (Data) | Failed connections: 2740
2025-01-08 12:06:52.982 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:52.983 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:52.983 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:52.983 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:52.983 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:53.281 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:53.282 | DTC Client socket (2) | Closed.
2025-01-08 12:06:54.984 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:54.984 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:54.984 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:54.985 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:54.986 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:54.986 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:55.232 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:55.232 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:55.232 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:55.232 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:56.207 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:56.207 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:56.207 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:56.207 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:56.207 | Rithmic Direct - DTC (Data) | Failed connections: 2741
2025-01-08 12:06:56.207 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:56.208 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:56.208 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:56.208 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:56.208 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:56.454 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:56.454 | DTC Client socket (2) | Closed.
2025-01-08 12:06:58.209 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:06:58.209 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:06:58.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:06:58.210 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:06:58.210 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:06:58.210 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:06:58.449 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:06:58.449 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:06:58.449 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:06:58.449 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Failed connections: 2742
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:06:59.410 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:06:59.410 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:06:59.410 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:06:59.649 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:06:59.649 | DTC Client socket (2) | Closed.
2025-01-08 12:07:01.408 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:01.408 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:01.408 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:01.409 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:01.409 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:01.409 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:01.658 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:01.658 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:01.658 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:01.658 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Failed connections: 2743
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:02.623 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:02.623 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:02.623 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:02.864 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:02.864 | DTC Client socket (2) | Closed.
2025-01-08 12:07:04.619 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:04.619 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:04.619 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:04.620 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:04.620 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:04.620 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:04.912 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:04.912 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:04.912 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:04.912 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:06.042 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:06.042 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:06.042 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:06.042 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:06.042 | Rithmic Direct - DTC (Data) | Failed connections: 2744
2025-01-08 12:07:06.042 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:06.043 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:06.043 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:06.043 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:06.043 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:06.334 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:06.335 | DTC Client socket (2) | Closed.
2025-01-08 12:07:08.040 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:08.040 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:08.040 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:08.041 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:08.042 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:08.042 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:08.280 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:08.280 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:08.280 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:08.280 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:09.231 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:09.231 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:09.232 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:09.232 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:09.232 | Rithmic Direct - DTC (Data) | Failed connections: 2745
2025-01-08 12:07:09.232 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:09.232 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:09.232 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:09.232 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:09.232 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:09.470 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:09.471 | DTC Client socket (2) | Closed.
2025-01-08 12:07:11.227 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:11.227 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:11.227 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:11.228 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:11.228 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:11.228 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:11.470 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:11.470 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:11.470 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:11.470 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:12.437 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:12.437 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:12.437 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:12.437 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:12.437 | Rithmic Direct - DTC (Data) | Failed connections: 2746
2025-01-08 12:07:12.437 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:12.438 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:12.438 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:12.438 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:12.438 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:12.679 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:12.679 | DTC Client socket (2) | Closed.
2025-01-08 12:07:14.430 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:14.430 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:14.430 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:14.431 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:14.431 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:14.431 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:14.718 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:14.718 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:14.718 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:14.718 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Failed connections: 2747
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:15.802 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:15.802 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:15.803 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:16.090 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:16.090 | DTC Client socket (2) | Closed.
2025-01-08 12:07:17.812 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:17.812 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:17.812 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:17.813 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:17.813 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:17.813 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:18.100 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:18.100 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:18.100 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:18.100 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:18.566 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048
2025-01-08 12:07:18.567 | DTC Client socket (3) | Creating socket.
2025-01-08 12:07:18.567 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:07:18.567 | DTC Client socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 12:07:18.723 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:07:18.723 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:07:18.723 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:07:18.881 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:07:18.881 | Denali Data Feed | Sending logon request message.
2025-01-08 12:07:19.192 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:19.192 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:19.192 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:19.192 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:19.192 | Rithmic Direct - DTC (Data) | Failed connections: 2748
2025-01-08 12:07:19.192 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:19.192 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:19.193 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:19.193 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:19.193 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:19.415 | Denali Data Feed | Received logon response.
2025-01-08 12:07:19.415 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:07:19.415 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:19.415 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:07:19.415 | Denali Data Feed | Failed connections: 198
2025-01-08 12:07:19.416 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:07:19.416 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:07:19.416 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:19.416 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:07:19.416 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:07:19.481 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:19.481 | DTC Client socket (2) | Closed.
2025-01-08 12:07:19.578 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:07:19.578 | DTC Client socket (3) | Closed.
2025-01-08 12:07:21.197 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:21.197 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:21.197 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:21.198 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:21.198 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:21.198 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:21.501 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:21.501 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:21.501 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:21.501 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Failed connections: 2749
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:22.627 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:22.627 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:22.627 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:22.929 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:22.930 | DTC Client socket (2) | Closed.
2025-01-08 12:07:24.631 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:24.631 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:24.631 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:24.632 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:24.632 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:24.632 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:24.872 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:24.872 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:24.872 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:24.872 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:25.817 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:25.817 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:25.817 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:25.817 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:25.817 | Rithmic Direct - DTC (Data) | Failed connections: 2750
2025-01-08 12:07:25.817 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:25.818 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:25.818 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:25.818 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:25.818 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:26.062 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:26.063 | DTC Client socket (2) | Closed.
2025-01-08 12:07:27.820 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:27.820 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:27.821 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:27.822 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:27.822 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:27.822 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:28.066 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:28.066 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:28.066 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:28.066 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:29.018 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:29.018 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:29.018 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:29.018 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:29.018 | Rithmic Direct - DTC (Data) | Failed connections: 2751
2025-01-08 12:07:29.018 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:29.019 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:29.019 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:29.019 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:29.019 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:29.262 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:29.262 | DTC Client socket (2) | Closed.
2025-01-08 12:07:31.019 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:31.019 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:31.019 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:31.020 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:31.020 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:31.020 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:31.321 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:31.321 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:31.321 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:31.321 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:32.441 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:32.441 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:32.441 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:32.441 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:32.441 | Rithmic Direct - DTC (Data) | Failed connections: 2752
2025-01-08 12:07:32.441 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:32.442 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:32.442 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:32.442 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:32.442 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:32.742 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:32.742 | DTC Client socket (2) | Closed.
2025-01-08 12:07:34.452 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:34.452 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:34.452 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:34.453 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:34.453 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:34.453 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:34.754 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:34.754 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:34.754 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:34.754 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:35.884 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:35.884 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:35.884 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:35.884 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:35.884 | Rithmic Direct - DTC (Data) | Failed connections: 2753
2025-01-08 12:07:35.884 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:35.885 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:35.885 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:35.885 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:35.885 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:36.186 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:36.186 | DTC Client socket (2) | Closed.
2025-01-08 12:07:37.878 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:37.878 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:37.878 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:37.879 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:37.879 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:37.879 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:38.128 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:38.128 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:38.128 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:38.128 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:39.095 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:39.095 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:39.095 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:39.095 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:39.095 | Rithmic Direct - DTC (Data) | Failed connections: 2754
2025-01-08 12:07:39.095 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:39.096 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:39.096 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:39.096 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:39.096 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:39.344 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:39.345 | DTC Client socket (2) | Closed.
2025-01-08 12:07:41.106 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:41.106 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:41.106 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:41.107 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:41.107 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:41.107 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:41.348 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:41.348 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:41.349 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:41.349 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Failed connections: 2755
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:42.297 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:42.297 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:42.297 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:42.570 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:42.570 | DTC Client socket (2) | Closed.
2025-01-08 12:07:44.284 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:44.284 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:44.284 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:44.284 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:44.285 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:44.285 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:44.583 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:44.583 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:44.583 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:44.583 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:45.703 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:45.703 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:45.703 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:45.703 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:45.703 | Rithmic Direct - DTC (Data) | Failed connections: 2756
2025-01-08 12:07:45.703 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:45.703 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:45.704 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:45.704 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:45.704 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:46.002 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:46.002 | DTC Client socket (2) | Closed.
2025-01-08 12:07:47.692 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:47.692 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:47.692 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:47.693 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:47.693 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:47.693 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:47.934 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:47.934 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:47.935 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:47.935 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:48.874 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:48.874 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:48.874 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:48.874 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:48.874 | Rithmic Direct - DTC (Data) | Failed connections: 2757
2025-01-08 12:07:48.874 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:48.875 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:48.875 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:48.875 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:48.875 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:49.112 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:49.112 | DTC Client socket (2) | Closed.
2025-01-08 12:07:50.872 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:50.872 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:50.872 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:50.873 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:50.873 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:50.873 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:51.115 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:51.115 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:51.115 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:51.115 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Failed connections: 2758
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:52.069 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:52.069 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:52.069 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:52.310 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:52.310 | DTC Client socket (2) | Closed.
2025-01-08 12:07:54.076 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:54.076 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:54.076 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:54.077 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:54.077 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:54.078 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:54.343 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:54.343 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:54.343 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:54.343 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:55.315 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:55.315 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:55.315 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:55.315 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:55.315 | Rithmic Direct - DTC (Data) | Failed connections: 2759
2025-01-08 12:07:55.315 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:55.316 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:55.316 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:55.316 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:55.316 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:55.582 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:55.582 | DTC Client socket (2) | Closed.
2025-01-08 12:07:57.320 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:07:57.320 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:07:57.320 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:07:57.321 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:07:57.321 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:07:57.321 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:07:57.565 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:07:57.565 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:07:57.565 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:07:57.565 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:07:58.514 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:07:58.514 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:07:58.514 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:07:58.514 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:07:58.514 | Rithmic Direct - DTC (Data) | Failed connections: 2760
2025-01-08 12:07:58.514 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:07:58.515 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:07:58.515 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:07:58.516 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:07:58.516 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:07:58.757 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:07:58.757 | DTC Client socket (2) | Closed.
2025-01-08 12:08:00.511 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:00.511 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:00.511 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:00.512 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:00.512 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:00.512 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:00.753 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:00.753 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:00.753 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:00.753 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Failed connections: 2761
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:01.689 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:01.689 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:01.689 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:01.926 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:01.926 | DTC Client socket (2) | Closed.
2025-01-08 12:08:03.680 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:03.680 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:03.680 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:03.681 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:03.681 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:08:03.681 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:03.982 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:03.982 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:03.983 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:03.983 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:05.118 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:05.118 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:05.118 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:05.118 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:05.118 | Rithmic Direct - DTC (Data) | Failed connections: 2762
2025-01-08 12:08:05.118 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:05.119 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:08:05.119 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:05.119 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:05.119 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:05.420 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:08:05.421 | DTC Client socket (3) | Closed.
2025-01-08 12:08:07.122 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:07.122 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:07.122 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:07.123 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:07.123 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:07.123 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:07.422 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:07.422 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:07.422 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:07.422 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:08.526 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:08.526 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:08.526 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:08.526 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:08.526 | Rithmic Direct - DTC (Data) | Failed connections: 2763
2025-01-08 12:08:08.526 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:08.527 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:08.527 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:08.527 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:08.527 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:08.823 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:08.823 | DTC Client socket (2) | Closed.
2025-01-08 12:08:10.546 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:10.546 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:10.547 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:10.547 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:10.547 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:10.547 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:10.839 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:10.839 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:10.839 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:10.839 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:11.930 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:11.930 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:11.930 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:11.930 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:11.930 | Rithmic Direct - DTC (Data) | Failed connections: 2764
2025-01-08 12:08:11.930 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:11.931 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:11.931 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:11.931 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:11.931 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:12.221 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:12.221 | DTC Client socket (2) | Closed.
2025-01-08 12:08:13.926 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:13.926 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:13.926 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:13.927 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:13.927 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:13.928 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:14.170 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:14.170 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:14.170 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:14.170 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Failed connections: 2765
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:15.122 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:15.122 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:15.122 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:15.363 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:15.363 | DTC Client socket (2) | Closed.
2025-01-08 12:08:17.122 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:17.122 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:17.122 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:17.122 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:17.122 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:17.122 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:17.370 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:17.370 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:17.370 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:17.370 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:18.306 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:18.306 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:18.306 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:18.306 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:18.306 | Rithmic Direct - DTC (Data) | Failed connections: 2766
2025-01-08 12:08:18.306 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:18.307 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:18.307 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:18.307 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:18.307 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:18.543 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:18.544 | DTC Client socket (2) | Closed.
2025-01-08 12:08:19.410 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443
2025-01-08 12:08:19.411 | DTC Client socket (2) | Creating socket.
2025-01-08 12:08:19.411 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:19.411 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-01-08 12:08:19.577 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:08:19.577 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:08:19.577 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:08:19.767 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:08:19.767 | Denali Data Feed | Sending logon request message.
2025-01-08 12:08:20.302 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:20.302 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:20.302 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:20.302 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:20.302 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:08:20.302 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:20.315 | Denali Data Feed | Received logon response.
2025-01-08 12:08:20.315 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:08:20.315 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:20.315 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:08:20.315 | Denali Data Feed | Failed connections: 199
2025-01-08 12:08:20.316 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:08:20.316 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:20.316 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:08:20.316 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:08:20.316 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:20.477 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:20.478 | DTC Client socket (2) | Closed.
2025-01-08 12:08:20.598 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:20.598 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:20.598 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:20.598 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Failed connections: 2767
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:21.698 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:08:21.698 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:21.698 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:21.995 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:08:21.995 | DTC Client socket (3) | Closed.
2025-01-08 12:08:23.689 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:23.689 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:23.689 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:23.690 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:23.690 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:23.690 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:23.933 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:23.933 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:23.933 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:23.933 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:24.880 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:24.880 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:24.880 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:24.880 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:24.880 | Rithmic Direct - DTC (Data) | Failed connections: 2768
2025-01-08 12:08:24.880 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:24.881 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:24.881 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:24.881 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:24.881 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:25.124 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:25.124 | DTC Client socket (2) | Closed.
2025-01-08 12:08:26.884 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:26.884 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:26.884 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:26.885 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:26.885 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:26.885 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:27.204 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:27.204 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:27.204 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:27.204 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Failed connections: 2769
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:28.381 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:28.381 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:28.382 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:28.700 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:28.700 | DTC Client socket (2) | Closed.
2025-01-08 12:08:30.383 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:30.383 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:30.383 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:30.383 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:30.383 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:30.383 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:30.625 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:30.625 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:30.626 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:30.626 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:31.593 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:31.593 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:31.593 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:31.593 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:31.593 | Rithmic Direct - DTC (Data) | Failed connections: 2770
2025-01-08 12:08:31.593 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:31.594 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:31.594 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:31.594 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:31.594 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:31.837 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:31.837 | DTC Client socket (2) | Closed.
2025-01-08 12:08:33.608 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:33.608 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:33.608 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:33.609 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:33.609 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:33.609 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:33.849 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:33.849 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:33.849 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:33.849 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Failed connections: 2771
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:34.789 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:34.789 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:34.790 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:35.029 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:35.029 | DTC Client socket (2) | Closed.
2025-01-08 12:08:36.794 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:36.794 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:36.794 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:36.794 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:36.795 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:36.795 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:37.024 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:37.024 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:37.024 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:37.024 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Failed connections: 2772
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:37.936 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:37.936 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:37.937 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:38.166 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:38.166 | DTC Client socket (2) | Closed.
2025-01-08 12:08:39.931 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:39.931 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:39.931 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:39.932 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:39.932 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:39.932 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:40.256 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:40.256 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:40.256 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:40.256 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:41.454 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:41.454 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:41.454 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:41.454 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:41.454 | Rithmic Direct - DTC (Data) | Failed connections: 2773
2025-01-08 12:08:41.454 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:41.455 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:41.455 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:41.455 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:41.455 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:41.778 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:41.778 | DTC Client socket (2) | Closed.
2025-01-08 12:08:43.463 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:43.463 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:43.463 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:43.464 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:43.465 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:43.465 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:43.754 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:43.754 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:43.754 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:43.754 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Failed connections: 2774
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:44.842 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:44.842 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:44.842 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:45.130 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:45.130 | DTC Client socket (2) | Closed.
2025-01-08 12:08:46.841 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:46.841 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:46.841 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:46.842 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:46.843 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:46.843 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:47.084 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:47.084 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:47.084 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:47.084 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:48.023 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:48.023 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:48.023 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:48.023 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:48.023 | Rithmic Direct - DTC (Data) | Failed connections: 2775
2025-01-08 12:08:48.023 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:48.024 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:48.024 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:48.024 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:48.024 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:48.265 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:48.265 | DTC Client socket (2) | Closed.
2025-01-08 12:08:50.023 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:50.023 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:50.023 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:50.024 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:50.025 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:50.025 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:50.275 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:50.275 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:50.275 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:50.275 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:51.250 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:51.250 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:51.250 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:51.250 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:51.250 | Rithmic Direct - DTC (Data) | Failed connections: 2776
2025-01-08 12:08:51.251 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:51.251 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:51.251 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:51.251 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:51.251 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:51.502 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:51.502 | DTC Client socket (2) | Closed.
2025-01-08 12:08:53.269 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:53.269 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:53.269 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:53.270 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:53.271 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:53.271 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:53.501 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:53.501 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:53.501 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:53.501 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:54.406 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:54.406 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:54.406 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:54.406 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:54.406 | Rithmic Direct - DTC (Data) | Failed connections: 2777
2025-01-08 12:08:54.406 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:54.407 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:54.407 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:54.407 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:54.407 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:54.636 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:54.636 | DTC Client socket (2) | Closed.
2025-01-08 12:08:56.396 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:56.396 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:56.396 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:56.397 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:56.397 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:56.397 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:08:56.692 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:08:56.692 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:08:56.692 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:08:56.692 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:08:57.799 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:08:57.799 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:08:57.799 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:08:57.799 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:08:57.799 | Rithmic Direct - DTC (Data) | Failed connections: 2778
2025-01-08 12:08:57.799 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:08:57.799 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:08:57.799 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:08:57.799 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:08:57.800 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:08:58.094 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:08:58.094 | DTC Client socket (2) | Closed.
2025-01-08 12:08:59.808 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:08:59.808 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:08:59.808 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:08:59.816 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:08:59.816 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:08:59.816 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:00.063 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:00.063 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:00.063 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:00.063 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:01.040 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:01.040 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:01.040 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:01.041 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:01.041 | Rithmic Direct - DTC (Data) | Failed connections: 2779
2025-01-08 12:09:01.041 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:01.041 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:01.042 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:01.042 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:01.042 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:01.293 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:01.293 | DTC Client socket (2) | Closed.
2025-01-08 12:09:03.042 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:03.042 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:03.042 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:03.043 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:03.043 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:03.043 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:03.290 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:03.290 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:03.290 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:03.290 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:04.307 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:04.307 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:04.307 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:04.307 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:04.307 | Rithmic Direct - DTC (Data) | Failed connections: 2780
2025-01-08 12:09:04.307 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:04.308 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:04.308 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:04.308 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:04.308 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:04.553 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:04.553 | DTC Client socket (2) | Closed.
2025-01-08 12:09:06.309 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:06.309 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:06.309 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:06.309 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:06.309 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:06.310 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:06.549 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:06.549 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:06.549 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:06.549 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:07.500 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:07.500 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:07.500 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:07.500 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:07.500 | Rithmic Direct - DTC (Data) | Failed connections: 2781
2025-01-08 12:09:07.500 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:07.501 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:07.501 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:07.501 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:07.501 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:07.741 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:07.741 | DTC Client socket (2) | Closed.
2025-01-08 12:09:09.490 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:09.490 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:09.490 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:09.491 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:09.491 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:09.491 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:09.730 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:09.730 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:09.730 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:09.730 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Failed connections: 2782
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:10.663 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:10.663 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:10.663 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:10.906 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:10.906 | DTC Client socket (2) | Closed.
2025-01-08 12:09:12.663 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:12.663 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:12.663 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:12.663 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:12.663 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:12.663 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:12.981 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:12.981 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:12.981 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:12.981 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:14.147 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:14.147 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:14.147 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:14.147 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:14.147 | Rithmic Direct - DTC (Data) | Failed connections: 2783
2025-01-08 12:09:14.147 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:14.148 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:14.148 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:14.148 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:14.148 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:14.463 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:14.463 | DTC Client socket (2) | Closed.
2025-01-08 12:09:16.154 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:16.154 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:16.154 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:16.154 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:16.154 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:16.154 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:16.446 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:16.446 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:16.446 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:16.446 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:17.541 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:17.541 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:17.542 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:17.542 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:17.542 | Rithmic Direct - DTC (Data) | Failed connections: 2784
2025-01-08 12:09:17.542 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:17.542 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:17.542 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:17.542 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:17.543 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:17.833 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:17.833 | DTC Client socket (2) | Closed.
2025-01-08 12:09:19.537 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:19.537 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:19.537 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:19.538 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:19.538 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:19.538 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:19.835 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:19.835 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:19.835 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:19.835 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:20.318 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443
2025-01-08 12:09:20.947 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:20.947 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:20.947 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:20.947 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:20.947 | Rithmic Direct - DTC (Data) | Failed connections: 2785
2025-01-08 12:09:20.947 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:20.948 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:20.948 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:20.948 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:20.948 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:21.244 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:21.244 | DTC Client socket (2) | Closed.
2025-01-08 12:09:22.947 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:22.947 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:22.947 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:23.449 | DTC Client socket (3) | Creating socket.
2025-01-08 12:09:23.449 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:09:23.449 | DTC Client socket (3) | Connecting to IP: 64.152.155.20.
2025-01-08 12:09:23.450 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:23.450 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:23.450 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:23.619 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:09:23.619 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:09:23.620 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:09:23.689 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:23.689 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:23.689 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:23.689 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:23.788 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:09:23.788 | Denali Data Feed | Sending logon request message.
2025-01-08 12:09:24.324 | Denali Data Feed | Received logon response.
2025-01-08 12:09:24.324 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:09:24.324 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:24.324 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:09:24.324 | Denali Data Feed | Failed connections: 200
2025-01-08 12:09:24.324 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:09:24.325 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:09:24.325 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:24.325 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:09:24.325 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:09:24.484 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:09:24.484 | DTC Client socket (3) | Closed.
2025-01-08 12:09:24.623 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:24.623 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:24.623 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:24.623 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:24.623 | Rithmic Direct - DTC (Data) | Failed connections: 2786
2025-01-08 12:09:24.623 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:24.624 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:24.624 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:24.624 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:24.624 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:24.862 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:24.862 | DTC Client socket (2) | Closed.
2025-01-08 12:09:26.628 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:26.628 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:26.628 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:26.629 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:26.629 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:26.629 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:26.929 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:26.929 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:26.929 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:26.929 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:28.044 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:28.044 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:28.044 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:28.044 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:28.044 | Rithmic Direct - DTC (Data) | Failed connections: 2787
2025-01-08 12:09:28.044 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:28.045 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:28.045 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:28.045 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:28.045 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:28.341 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:28.341 | DTC Client socket (2) | Closed.
2025-01-08 12:09:30.038 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:30.038 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:30.038 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:30.039 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:30.039 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:30.039 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:30.332 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:30.332 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:30.332 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:30.332 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:31.433 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:31.433 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:31.433 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:31.433 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:31.433 | Rithmic Direct - DTC (Data) | Failed connections: 2788
2025-01-08 12:09:31.433 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:31.434 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:31.434 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:31.434 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:31.434 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:31.727 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:31.727 | DTC Client socket (2) | Closed.
2025-01-08 12:09:33.439 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:33.439 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:33.439 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:33.439 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:33.440 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:33.440 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:33.688 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:33.688 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:33.688 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:33.688 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Failed connections: 2789
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:34.654 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:34.654 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:34.654 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:34.923 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:34.923 | DTC Client socket (2) | Closed.
2025-01-08 12:09:36.645 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:36.645 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:36.645 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:36.646 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:36.646 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:36.646 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:36.943 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:36.943 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:36.943 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:36.943 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:38.051 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:38.051 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:38.051 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:38.051 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:38.051 | Rithmic Direct - DTC (Data) | Failed connections: 2790
2025-01-08 12:09:38.051 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:38.052 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:38.052 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:38.052 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:38.052 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:38.349 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:38.349 | DTC Client socket (2) | Closed.
2025-01-08 12:09:40.062 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:40.062 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:40.062 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:40.063 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:40.064 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:40.064 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:40.363 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:40.363 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:40.363 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:40.363 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Failed connections: 2791
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:41.477 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:41.477 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:41.477 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:41.776 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:41.776 | DTC Client socket (2) | Closed.
2025-01-08 12:09:43.476 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:43.476 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:43.476 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:43.477 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:43.477 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:43.477 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:43.715 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:43.715 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:43.715 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:43.715 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:44.651 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:44.651 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:44.651 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:44.651 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:44.651 | Rithmic Direct - DTC (Data) | Failed connections: 2792
2025-01-08 12:09:44.652 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:44.653 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:44.653 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:44.653 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:44.653 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:44.891 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:44.891 | DTC Client socket (2) | Closed.
2025-01-08 12:09:46.655 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:46.655 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:46.655 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:46.656 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:46.656 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:09:46.656 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:46.901 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:46.901 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:46.901 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:46.901 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:47.862 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:47.862 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:47.862 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:47.862 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:47.862 | Rithmic Direct - DTC (Data) | Failed connections: 2793
2025-01-08 12:09:47.862 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:47.863 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:09:47.863 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:47.863 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:47.863 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:48.108 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:09:48.108 | DTC Client socket (3) | Closed.
2025-01-08 12:09:49.864 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:49.864 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:49.864 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:49.865 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:49.865 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:49.865 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:50.181 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:50.181 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:50.181 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:50.181 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:51.355 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:51.355 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:51.355 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:51.355 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:51.355 | Rithmic Direct - DTC (Data) | Failed connections: 2794
2025-01-08 12:09:51.355 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:51.356 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:51.356 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:51.356 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:51.356 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:51.672 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:51.672 | DTC Client socket (2) | Closed.
2025-01-08 12:09:53.359 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:53.359 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:53.359 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:53.505 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:53.505 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:53.505 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:53.786 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:53.786 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:53.786 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:53.786 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Failed connections: 2795
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:54.745 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:54.745 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:54.745 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:55.012 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:55.012 | DTC Client socket (2) | Closed.
2025-01-08 12:09:56.743 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:09:56.743 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:09:56.743 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:09:56.744 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:09:56.744 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:09:56.744 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:09:57.042 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:09:57.042 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:09:57.042 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:09:57.042 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:09:58.153 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:09:58.153 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:09:58.153 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:09:58.153 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:09:58.153 | Rithmic Direct - DTC (Data) | Failed connections: 2796
2025-01-08 12:09:58.153 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:09:58.154 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:09:58.154 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:09:58.154 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:09:58.154 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:09:58.450 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:09:58.450 | DTC Client socket (2) | Closed.
2025-01-08 12:10:00.145 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:00.146 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:00.146 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:00.146 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:00.146 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:00.146 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:00.393 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:00.393 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:00.393 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:00.393 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:01.350 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:01.350 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:01.350 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:01.350 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:01.350 | Rithmic Direct - DTC (Data) | Failed connections: 2797
2025-01-08 12:10:01.350 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:01.351 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:01.351 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:01.351 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:01.351 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:01.595 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:01.596 | DTC Client socket (2) | Closed.
2025-01-08 12:10:03.349 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:03.349 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:03.350 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:03.350 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:03.350 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:03.350 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:03.588 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:03.588 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:03.588 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:03.588 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:04.530 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:04.530 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:04.530 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:04.530 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:04.530 | Rithmic Direct - DTC (Data) | Failed connections: 2798
2025-01-08 12:10:04.531 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:04.531 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:04.532 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:04.532 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:04.532 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:04.801 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:04.801 | DTC Client socket (2) | Closed.
2025-01-08 12:10:06.531 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:06.531 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:06.531 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:06.532 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:06.533 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:06.533 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:06.781 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:06.781 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:06.781 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:06.781 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Failed connections: 2799
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:07.745 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:07.745 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:07.745 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:07.993 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:07.993 | DTC Client socket (2) | Closed.
2025-01-08 12:10:09.749 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:09.749 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:09.749 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:09.750 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:09.750 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:09.750 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:10.048 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:10.048 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:10.048 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:10.048 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:11.163 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:11.163 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:11.163 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:11.163 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:11.163 | Rithmic Direct - DTC (Data) | Failed connections: 2800
2025-01-08 12:10:11.163 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:11.164 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:11.164 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:11.164 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:11.164 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:11.462 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:11.462 | DTC Client socket (2) | Closed.
2025-01-08 12:10:13.159 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:13.159 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:13.159 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:13.159 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:13.160 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:13.160 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:13.404 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:13.404 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:13.404 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:13.404 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Failed connections: 2801
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:14.353 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:14.353 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:14.353 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:14.593 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:14.594 | DTC Client socket (2) | Closed.
2025-01-08 12:10:16.361 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:16.361 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:16.361 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:16.362 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:16.362 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:16.362 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:16.610 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:16.610 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:16.610 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:16.610 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Failed connections: 2802
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:17.569 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:17.569 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:17.569 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:17.814 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:17.814 | DTC Client socket (2) | Closed.
2025-01-08 12:10:19.572 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:19.572 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:19.572 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:19.573 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:19.573 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:19.573 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:19.868 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:19.868 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:19.868 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:19.868 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:20.974 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:20.974 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:20.974 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:20.974 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:20.974 | Rithmic Direct - DTC (Data) | Failed connections: 2803
2025-01-08 12:10:20.974 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:20.975 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:20.976 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:20.976 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:20.976 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:21.270 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:21.270 | DTC Client socket (2) | Closed.
2025-01-08 12:10:22.983 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:22.983 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:22.983 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:22.984 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:22.985 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:22.985 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:23.231 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:23.231 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:23.231 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:23.231 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Failed connections: 2804
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:24.190 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:24.190 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:24.190 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:24.325 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 443
2025-01-08 12:10:24.327 | DTC Client socket (3) | Creating socket.
2025-01-08 12:10:24.327 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:10:24.327 | DTC Client socket (3) | Connecting to IP: 67.214.125.4.
2025-01-08 12:10:24.435 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:24.436 | DTC Client socket (2) | Closed.
2025-01-08 12:10:24.487 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:10:24.487 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:10:24.487 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:10:24.663 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:10:24.663 | Denali Data Feed | Sending logon request message.
2025-01-08 12:10:25.220 | Denali Data Feed | Received logon response.
2025-01-08 12:10:25.220 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:10:25.220 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:25.220 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:10:25.220 | Denali Data Feed | Failed connections: 201
2025-01-08 12:10:25.220 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:10:25.221 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:10:25.221 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:10:25.221 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:10:25.221 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:25.389 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:10:25.390 | DTC Client socket (3) | Closed.
2025-01-08 12:10:26.204 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:26.204 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:26.204 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:26.204 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:26.204 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:26.204 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:26.455 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:26.455 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:26.455 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:26.455 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Failed connections: 2805
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:27.457 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:27.457 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:27.457 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:27.728 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:27.729 | DTC Client socket (2) | Closed.
2025-01-08 12:10:29.457 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:29.457 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:29.457 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:29.458 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:29.458 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:29.458 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:29.704 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:29.704 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:29.704 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:29.704 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:30.657 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:30.657 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:30.657 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:30.657 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:30.657 | Rithmic Direct - DTC (Data) | Failed connections: 2806
2025-01-08 12:10:30.657 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:30.658 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:30.658 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:30.658 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:30.658 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:30.904 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:30.904 | DTC Client socket (2) | Closed.
2025-01-08 12:10:32.663 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:32.663 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:32.663 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:32.663 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:32.664 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:32.664 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:32.904 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:32.904 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:32.904 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:32.904 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Failed connections: 2807
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:33.844 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:33.844 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:33.844 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:34.093 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:34.093 | DTC Client socket (2) | Closed.
2025-01-08 12:10:35.832 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:35.832 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:35.833 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:35.833 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:35.834 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:35.834 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:36.075 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:36.075 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:36.075 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:36.075 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:37.018 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:37.018 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:37.018 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:37.018 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:37.018 | Rithmic Direct - DTC (Data) | Failed connections: 2808
2025-01-08 12:10:37.018 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:37.019 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:37.019 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:37.019 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:37.019 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:37.260 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:37.260 | DTC Client socket (2) | Closed.
2025-01-08 12:10:39.024 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:39.025 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:39.025 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:39.025 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:39.025 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:39.025 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:39.271 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:39.271 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:39.271 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:39.271 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:40.238 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:40.238 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:40.238 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:40.238 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:40.238 | Rithmic Direct - DTC (Data) | Failed connections: 2809
2025-01-08 12:10:40.238 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:40.239 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:40.239 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:40.239 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:40.239 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:40.484 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:40.484 | DTC Client socket (2) | Closed.
2025-01-08 12:10:42.237 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:42.237 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:42.237 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:42.238 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:42.238 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:42.238 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:42.555 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:42.555 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:42.555 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:42.555 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:43.725 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:43.725 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:43.725 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:43.725 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:43.725 | Rithmic Direct - DTC (Data) | Failed connections: 2810
2025-01-08 12:10:43.725 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:43.726 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:43.726 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:43.726 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:43.726 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:44.042 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:44.042 | DTC Client socket (2) | Closed.
2025-01-08 12:10:45.729 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:45.729 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:45.729 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:45.730 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:45.730 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:45.730 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:45.979 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:45.979 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:45.979 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:45.979 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:46.943 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:46.943 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:46.943 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:46.943 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:46.943 | Rithmic Direct - DTC (Data) | Failed connections: 2811
2025-01-08 12:10:46.943 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:46.944 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:46.944 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:46.944 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:46.944 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:47.191 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:47.191 | DTC Client socket (2) | Closed.
2025-01-08 12:10:48.947 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:48.947 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:48.947 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:48.948 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:48.948 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:48.948 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:49.271 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:49.271 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:49.271 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:49.271 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Failed connections: 2812
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:50.445 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:50.445 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:50.445 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:50.762 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:50.762 | DTC Client socket (2) | Closed.
2025-01-08 12:10:52.440 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:52.440 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:52.440 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:52.441 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:52.441 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:52.441 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:52.686 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:52.686 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:52.686 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:52.686 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Failed connections: 2813
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:53.634 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:53.634 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:53.634 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:53.877 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:53.877 | DTC Client socket (2) | Closed.
2025-01-08 12:10:55.639 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:55.639 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:55.639 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:55.640 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:55.640 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:55.640 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:55.934 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:55.934 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:55.935 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:55.935 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:10:57.037 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:10:57.037 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:10:57.037 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:10:57.037 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:10:57.037 | Rithmic Direct - DTC (Data) | Failed connections: 2814
2025-01-08 12:10:57.037 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:10:57.039 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:10:57.039 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:10:57.039 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:10:57.039 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:10:57.332 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:10:57.332 | DTC Client socket (2) | Closed.
2025-01-08 12:10:59.035 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:10:59.036 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:10:59.036 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:10:59.036 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:10:59.036 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:10:59.036 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:10:59.279 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:10:59.279 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:10:59.279 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:10:59.279 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:00.223 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:00.223 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:00.223 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:00.223 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:00.223 | Rithmic Direct - DTC (Data) | Failed connections: 2815
2025-01-08 12:11:00.223 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:00.224 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:00.224 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:00.224 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:00.224 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:00.466 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:00.466 | DTC Client socket (2) | Closed.
2025-01-08 12:11:02.226 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:02.226 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:02.226 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:02.227 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:02.227 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:02.227 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:02.473 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:02.473 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:02.473 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:02.473 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:03.434 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:03.434 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:03.434 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:03.434 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:03.434 | Rithmic Direct - DTC (Data) | Failed connections: 2816
2025-01-08 12:11:03.434 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:03.435 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:03.435 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:03.435 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:03.435 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:03.680 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:03.680 | DTC Client socket (2) | Closed.
2025-01-08 12:11:05.437 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:05.437 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:05.437 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:05.438 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:05.438 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:05.438 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:05.726 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:05.726 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:05.726 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:05.726 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:06.817 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:06.817 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:06.817 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:06.817 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:06.817 | Rithmic Direct - DTC (Data) | Failed connections: 2817
2025-01-08 12:11:06.817 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:06.818 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:06.818 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:06.818 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:06.818 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:07.107 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:07.107 | DTC Client socket (2) | Closed.
2025-01-08 12:11:08.825 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:08.825 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:08.825 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:08.826 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:08.826 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:08.826 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:09.126 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:09.126 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:09.126 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:09.126 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:10.237 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:10.237 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:10.237 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:10.237 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:10.237 | Rithmic Direct - DTC (Data) | Failed connections: 2818
2025-01-08 12:11:10.237 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:10.238 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:10.238 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:10.238 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:10.238 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:10.535 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:10.535 | DTC Client socket (2) | Closed.
2025-01-08 12:11:12.237 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:12.237 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:12.237 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:12.238 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:12.238 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:12.238 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:12.526 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:12.526 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:12.527 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:12.527 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:13.620 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:13.620 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:13.620 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:13.620 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:13.620 | Rithmic Direct - DTC (Data) | Failed connections: 2819
2025-01-08 12:11:13.620 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:13.621 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:13.621 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:13.621 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:13.621 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:13.909 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:13.909 | DTC Client socket (2) | Closed.
2025-01-08 12:11:15.628 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:15.628 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:15.628 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:15.629 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:15.629 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:15.630 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:15.879 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:15.879 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:15.879 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:15.879 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:16.844 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:16.844 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:16.844 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:16.844 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:16.844 | Rithmic Direct - DTC (Data) | Failed connections: 2820
2025-01-08 12:11:16.844 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:16.845 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:16.845 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:16.845 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:16.845 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:17.091 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:17.092 | DTC Client socket (2) | Closed.
2025-01-08 12:11:18.839 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:18.839 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:18.839 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:18.840 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:18.840 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:18.840 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:19.081 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:19.081 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:19.081 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:19.081 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:20.029 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:20.029 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:20.029 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:20.029 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:20.029 | Rithmic Direct - DTC (Data) | Failed connections: 2821
2025-01-08 12:11:20.030 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:20.031 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:20.031 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:20.031 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:20.031 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:20.271 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:20.271 | DTC Client socket (2) | Closed.
2025-01-08 12:11:22.018 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:22.018 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:22.018 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:22.019 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:22.019 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:22.019 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:22.264 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:22.264 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:22.264 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:22.264 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:23.224 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:23.224 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:23.224 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:23.224 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:23.224 | Rithmic Direct - DTC (Data) | Failed connections: 2822
2025-01-08 12:11:23.224 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:23.225 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:23.225 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:23.225 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:23.225 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:23.472 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:23.472 | DTC Client socket (2) | Closed.
2025-01-08 12:11:25.227 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443
2025-01-08 12:11:25.227 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:25.227 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:25.227 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:28.359 | DTC Client socket (2) | Creating socket.
2025-01-08 12:11:28.359 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:28.359 | DTC Client socket (2) | Connecting to IP: 64.152.155.18.
2025-01-08 12:11:28.360 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:28.360 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:11:28.360 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:28.523 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:11:28.523 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:11:28.523 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:11:28.644 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:28.644 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:28.644 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:28.644 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:28.704 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:11:28.704 | Denali Data Feed | Sending logon request message.
2025-01-08 12:11:29.217 | Denali Data Feed | Received logon response.
2025-01-08 12:11:29.217 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:11:29.217 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:29.217 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:11:29.217 | Denali Data Feed | Failed connections: 202
2025-01-08 12:11:29.217 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:11:29.217 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:29.217 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:11:29.217 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:11:29.217 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:29.375 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:29.375 | DTC Client socket (2) | Closed.
2025-01-08 12:11:30.970 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:30.970 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:30.970 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:30.970 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:30.970 | Rithmic Direct - DTC (Data) | Failed connections: 2823
2025-01-08 12:11:30.971 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:30.971 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:11:30.971 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:30.971 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:30.971 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:31.256 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:11:31.256 | DTC Client socket (3) | Closed.
2025-01-08 12:11:32.985 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:32.985 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:32.985 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:32.986 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:32.987 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:32.987 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:33.234 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:33.234 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:33.234 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:33.234 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:34.201 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:34.201 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:34.201 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:34.201 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:34.201 | Rithmic Direct - DTC (Data) | Failed connections: 2824
2025-01-08 12:11:34.201 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:34.202 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:34.202 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:34.202 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:34.202 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:34.448 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:34.448 | DTC Client socket (2) | Closed.
2025-01-08 12:11:36.193 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:36.193 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:36.193 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:36.193 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:36.194 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:36.194 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:36.517 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:36.517 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:36.517 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:36.517 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:37.708 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:37.708 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:37.708 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:37.708 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:37.708 | Rithmic Direct - DTC (Data) | Failed connections: 2825
2025-01-08 12:11:37.708 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:37.709 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:37.709 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:37.709 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:37.709 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:38.033 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:38.033 | DTC Client socket (2) | Closed.
2025-01-08 12:11:39.708 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:39.708 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:39.708 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:39.709 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:39.709 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:39.709 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:40.003 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:40.003 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:40.003 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:40.003 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:41.102 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:41.102 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:41.102 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:41.102 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:41.102 | Rithmic Direct - DTC (Data) | Failed connections: 2826
2025-01-08 12:11:41.102 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:41.103 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:41.103 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:41.103 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:41.103 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:41.397 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:41.397 | DTC Client socket (2) | Closed.
2025-01-08 12:11:43.124 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:43.124 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:43.124 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:43.125 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:43.125 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:43.125 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:43.461 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:43.461 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:43.461 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:43.461 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:44.665 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:44.665 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:44.665 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:44.665 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:44.665 | Rithmic Direct - DTC (Data) | Failed connections: 2827
2025-01-08 12:11:44.665 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:44.666 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:44.666 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:44.666 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:44.666 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:45.002 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:45.003 | DTC Client socket (2) | Closed.
2025-01-08 12:11:46.664 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:46.664 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:46.664 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:46.665 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:46.665 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:46.665 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:46.953 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:46.953 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:46.953 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:46.953 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:48.039 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:48.039 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:48.039 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:48.039 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:48.039 | Rithmic Direct - DTC (Data) | Failed connections: 2828
2025-01-08 12:11:48.039 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:48.040 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:48.040 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:48.040 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:48.040 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:48.326 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:48.326 | DTC Client socket (2) | Closed.
2025-01-08 12:11:50.048 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:50.048 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:50.048 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:50.049 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:50.050 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:50.050 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:50.384 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:50.384 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:50.384 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:50.384 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:51.594 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:51.594 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:51.594 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:51.594 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:51.594 | Rithmic Direct - DTC (Data) | Failed connections: 2829
2025-01-08 12:11:51.594 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:51.594 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:51.595 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:51.595 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:51.595 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:51.924 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:51.924 | DTC Client socket (2) | Closed.
2025-01-08 12:11:53.595 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:53.595 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:53.595 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:53.596 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:53.596 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:53.596 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:53.878 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:53.878 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:53.878 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:53.878 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:54.945 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:54.945 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:54.945 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:54.945 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:54.945 | Rithmic Direct - DTC (Data) | Failed connections: 2830
2025-01-08 12:11:54.945 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:54.946 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:54.946 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:54.946 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:54.946 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:55.229 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:55.229 | DTC Client socket (2) | Closed.
2025-01-08 12:11:56.954 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:11:56.954 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:11:56.954 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:11:56.954 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:11:56.955 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:11:56.955 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:11:57.253 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:11:57.253 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:11:57.253 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:11:57.253 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:11:58.371 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:11:58.371 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:11:58.371 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:11:58.371 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:11:58.371 | Rithmic Direct - DTC (Data) | Failed connections: 2831
2025-01-08 12:11:58.371 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:11:58.372 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:11:58.372 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:11:58.372 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:11:58.372 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:11:58.670 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:11:58.670 | DTC Client socket (2) | Closed.
2025-01-08 12:12:00.374 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:00.374 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:00.374 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:00.375 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:00.375 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:00.375 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:00.670 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:00.670 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:00.670 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:00.670 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:01.774 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:01.774 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:01.774 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:01.774 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:01.774 | Rithmic Direct - DTC (Data) | Failed connections: 2832
2025-01-08 12:12:01.774 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:01.775 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:01.775 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:01.775 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:01.775 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:02.070 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:02.070 | DTC Client socket (2) | Closed.
2025-01-08 12:12:03.768 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:03.768 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:03.768 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:03.768 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:03.769 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:03.769 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:04.049 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:04.049 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:04.049 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:04.049 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:05.733 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:05.733 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:05.733 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:05.733 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:05.733 | Rithmic Direct - DTC (Data) | Failed connections: 2833
2025-01-08 12:12:05.733 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:05.733 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:05.734 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:05.734 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:05.734 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:06.013 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:06.013 | DTC Client socket (2) | Closed.
2025-01-08 12:12:07.722 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:07.722 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:07.722 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:07.722 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:07.722 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:07.722 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:07.967 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:07.967 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:07.967 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:07.967 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:08.922 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:08.922 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:08.922 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:08.922 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:08.922 | Rithmic Direct - DTC (Data) | Failed connections: 2834
2025-01-08 12:12:08.922 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:08.923 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:08.923 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:08.923 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:08.923 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:09.167 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:09.167 | DTC Client socket (2) | Closed.
2025-01-08 12:12:10.915 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:10.915 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:10.915 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:10.916 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:10.916 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:10.916 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:11.199 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:11.199 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:11.199 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:11.199 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:12.883 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:12.883 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:12.883 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:12.883 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:12.883 | Rithmic Direct - DTC (Data) | Failed connections: 2835
2025-01-08 12:12:12.884 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:12.884 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:12.884 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:12.885 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:12.885 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:13.167 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:13.167 | DTC Client socket (2) | Closed.
2025-01-08 12:12:14.883 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:14.884 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:14.884 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:14.885 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:14.885 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:14.885 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:15.190 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:15.190 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:15.190 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:15.190 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Failed connections: 2836
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:16.319 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:16.319 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:16.319 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:16.623 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:16.623 | DTC Client socket (2) | Closed.
2025-01-08 12:12:18.315 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:18.315 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:18.315 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:18.315 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:18.316 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:18.316 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:18.618 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:18.618 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:18.618 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:18.618 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:19.690 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:19.690 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:19.690 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:19.690 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:19.690 | Rithmic Direct - DTC (Data) | Failed connections: 2837
2025-01-08 12:12:19.690 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:19.691 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:19.691 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:19.691 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:19.691 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:20.531 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:20.531 | DTC Client socket (2) | Closed.
2025-01-08 12:12:21.692 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:21.692 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:21.692 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:21.692 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:21.692 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:21.692 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:21.988 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:21.988 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:21.988 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:21.988 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:23.080 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:23.080 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:23.080 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:23.080 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:23.081 | Rithmic Direct - DTC (Data) | Failed connections: 2838
2025-01-08 12:12:23.081 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:23.081 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:23.081 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:23.081 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:23.081 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:23.372 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:23.372 | DTC Client socket (2) | Closed.
2025-01-08 12:12:25.083 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:25.083 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:25.083 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:25.084 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:25.084 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:25.084 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:25.376 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:25.376 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:25.376 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:25.376 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Failed connections: 2839
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:26.472 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:26.472 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:26.472 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:26.764 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:26.764 | DTC Client socket (2) | Closed.
2025-01-08 12:12:28.472 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:28.472 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:28.472 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:28.473 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:28.473 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:28.473 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:29.218 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 443
2025-01-08 12:12:29.219 | DTC Client socket (3) | Creating socket.
2025-01-08 12:12:29.219 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:12:29.219 | DTC Client socket (3) | Connecting to IP: 208.185.224.131.
2025-01-08 12:12:29.386 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:12:29.386 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:12:29.386 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:12:29.556 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:12:29.556 | Denali Data Feed | Sending logon request message.
2025-01-08 12:12:29.728 | Denali Data Feed | Received logon response.
2025-01-08 12:12:29.728 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:12:29.728 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:29.728 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary.
2025-01-08 12:12:29.728 | Denali Data Feed | Failed connections: 203
2025-01-08 12:12:29.728 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:12:29.729 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:12:29.729 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:12:29.729 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 12:12:29.729 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:29.889 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:12:29.889 | DTC Client socket (3) | Closed.
2025-01-08 12:12:31.780 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:31.780 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:31.781 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:31.781 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:32.730 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:12:32.730 | DTC Client socket (3) | Creating socket.
2025-01-08 12:12:32.730 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:12:32.731 | DTC Client socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:12:32.850 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:32.850 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:32.850 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:32.850 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:32.850 | Rithmic Direct - DTC (Data) | Failed connections: 2840
2025-01-08 12:12:32.851 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:32.851 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:32.851 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:32.851 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:32.851 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:32.898 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:12:32.898 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:12:32.898 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:12:33.071 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:12:33.071 | Denali Data Feed | Sending logon request message.
2025-01-08 12:12:33.134 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:33.134 | DTC Client socket (2) | Closed.
2025-01-08 12:12:33.611 | Denali Data Feed | Received logon response.
2025-01-08 12:12:33.611 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:12:33.611 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:33.611 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:12:33.611 | Denali Data Feed | Failed connections: 204
2025-01-08 12:12:33.611 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:12:33.612 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:12:33.612 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:12:33.612 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:12:33.612 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:33.778 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:12:33.778 | DTC Client socket (3) | Closed.
2025-01-08 12:12:34.851 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:34.851 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:34.851 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:34.852 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:34.852 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:34.852 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:35.146 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:35.146 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:35.146 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:35.146 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Failed connections: 2841
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:36.253 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:36.253 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:36.253 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:36.547 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:36.547 | DTC Client socket (2) | Closed.
2025-01-08 12:12:38.255 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:38.255 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:38.255 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:38.255 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:38.256 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:38.256 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:38.554 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:38.554 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:38.554 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:38.554 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:39.672 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:39.672 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:39.672 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:39.672 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:39.672 | Rithmic Direct - DTC (Data) | Failed connections: 2842
2025-01-08 12:12:39.672 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:39.673 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:39.673 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:39.673 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:39.673 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:39.971 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:39.971 | DTC Client socket (2) | Closed.
2025-01-08 12:12:41.666 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:41.666 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:41.666 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:41.666 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:41.667 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:41.667 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:41.990 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:41.990 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:41.990 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:41.990 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:43.176 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:43.176 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:43.176 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:43.176 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:43.176 | Rithmic Direct - DTC (Data) | Failed connections: 2843
2025-01-08 12:12:43.176 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:43.176 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:43.177 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:43.177 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:43.177 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:43.499 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:43.499 | DTC Client socket (2) | Closed.
2025-01-08 12:12:45.185 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:45.185 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:45.185 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:45.186 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:45.186 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:45.186 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:45.427 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:45.427 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:45.428 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:45.428 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:46.369 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:46.369 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:46.369 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:46.369 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:46.369 | Rithmic Direct - DTC (Data) | Failed connections: 2844
2025-01-08 12:12:46.369 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:46.370 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:46.370 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:46.370 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:46.370 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:46.611 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:46.611 | DTC Client socket (2) | Closed.
2025-01-08 12:12:48.379 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:48.379 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:48.379 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:48.380 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:48.381 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:48.381 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:48.675 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:48.675 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:48.675 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:48.675 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Failed connections: 2845
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:49.782 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:49.782 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:49.783 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:50.075 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:50.075 | DTC Client socket (2) | Closed.
2025-01-08 12:12:51.769 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:51.769 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:51.769 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:51.770 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:51.771 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:51.771 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:52.059 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:52.059 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:52.059 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:52.059 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:53.764 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:53.764 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:53.764 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:53.764 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:53.764 | Rithmic Direct - DTC (Data) | Failed connections: 2846
2025-01-08 12:12:53.764 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:53.765 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:53.765 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:53.765 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:53.765 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:54.054 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:54.054 | DTC Client socket (2) | Closed.
2025-01-08 12:12:55.752 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:55.752 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:55.752 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:55.752 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:55.753 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:55.753 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:56.042 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:56.042 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:56.042 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:56.042 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Failed connections: 2847
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:12:57.133 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:12:57.133 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:12:57.133 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:12:57.424 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:12:57.425 | DTC Client socket (2) | Closed.
2025-01-08 12:12:59.132 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:12:59.132 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:12:59.132 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:12:59.133 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:12:59.133 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:12:59.133 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:12:59.422 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:12:59.422 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:12:59.422 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:12:59.422 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:00.510 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:00.510 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:00.510 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:00.510 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:00.510 | Rithmic Direct - DTC (Data) | Failed connections: 2848
2025-01-08 12:13:00.510 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:00.511 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:00.511 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:00.511 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:00.511 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:00.801 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:00.801 | DTC Client socket (2) | Closed.
2025-01-08 12:13:02.505 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:02.505 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:02.505 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:02.506 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:02.506 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:02.506 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:02.750 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:02.750 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:02.750 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:02.750 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:03.714 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:03.714 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:03.714 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:03.714 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:03.714 | Rithmic Direct - DTC (Data) | Failed connections: 2849
2025-01-08 12:13:03.714 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:03.714 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:03.714 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:03.715 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:03.715 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:03.959 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:03.959 | DTC Client socket (2) | Closed.
2025-01-08 12:13:05.718 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:05.718 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:05.718 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:05.719 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:05.720 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:05.720 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:06.011 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:06.011 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:06.011 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:06.011 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:07.130 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:07.130 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:07.130 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:07.130 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:07.130 | Rithmic Direct - DTC (Data) | Failed connections: 2850
2025-01-08 12:13:07.130 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:07.131 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:07.131 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:07.131 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:07.131 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:07.422 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:07.423 | DTC Client socket (2) | Closed.
2025-01-08 12:13:09.137 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:09.137 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:09.137 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:09.138 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:09.138 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:09.138 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:09.385 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:09.385 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:09.385 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:09.385 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Failed connections: 2851
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:10.353 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:10.353 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:10.354 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:10.604 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:10.605 | DTC Client socket (2) | Closed.
2025-01-08 12:13:12.359 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:12.359 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:12.359 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:12.359 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:12.359 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:12.360 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:12.643 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:12.643 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:12.643 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:12.643 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:14.308 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:14.308 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:14.308 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:14.308 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:14.308 | Rithmic Direct - DTC (Data) | Failed connections: 2852
2025-01-08 12:13:14.308 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:14.309 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:14.309 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:14.309 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:14.309 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:14.592 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:14.592 | DTC Client socket (2) | Closed.
2025-01-08 12:13:16.302 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:16.302 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:16.302 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:16.303 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:16.303 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:16.303 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:16.608 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:16.608 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:16.608 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:16.608 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:17.733 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:17.733 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:17.733 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:17.733 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:17.733 | Rithmic Direct - DTC (Data) | Failed connections: 2853
2025-01-08 12:13:17.733 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:17.734 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:17.734 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:17.734 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:17.735 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:18.033 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:18.033 | DTC Client socket (2) | Closed.
2025-01-08 12:13:19.737 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:19.737 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:19.737 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:19.738 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:19.738 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:19.738 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:20.008 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:20.008 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:20.008 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:20.008 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:21.048 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:21.048 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:21.048 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:21.048 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:21.048 | Rithmic Direct - DTC (Data) | Failed connections: 2854
2025-01-08 12:13:21.048 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:21.049 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:21.049 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:21.049 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:21.049 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:21.321 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:21.321 | DTC Client socket (2) | Closed.
2025-01-08 12:13:23.052 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:23.052 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:23.052 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:23.053 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:23.053 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:23.053 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:23.338 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:23.338 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:23.338 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:23.338 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Failed connections: 2855
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:25.005 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:25.005 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:25.005 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:25.289 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:25.289 | DTC Client socket (2) | Closed.
2025-01-08 12:13:27.008 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:27.008 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:27.008 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:27.009 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:27.010 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:27.010 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:27.336 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:27.336 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:27.336 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:27.336 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:28.534 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:28.534 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:28.534 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:28.534 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:28.534 | Rithmic Direct - DTC (Data) | Failed connections: 2856
2025-01-08 12:13:28.534 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:28.535 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:28.535 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:28.535 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:28.535 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:28.860 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:28.860 | DTC Client socket (2) | Closed.
2025-01-08 12:13:30.534 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:30.534 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:30.534 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:30.535 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:30.535 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:30.535 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:30.829 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:30.829 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:30.829 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:30.829 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:31.950 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:31.950 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:31.950 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:31.950 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:31.950 | Rithmic Direct - DTC (Data) | Failed connections: 2857
2025-01-08 12:13:31.950 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:31.951 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:31.951 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:31.951 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:31.951 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:32.245 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:32.245 | DTC Client socket (2) | Closed.
2025-01-08 12:13:33.619 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443
2025-01-08 12:13:33.619 | DTC Client socket (2) | Creating socket.
2025-01-08 12:13:33.619 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:33.619 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-01-08 12:13:33.778 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:13:33.778 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:13:33.778 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:13:33.948 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:33.948 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:33.948 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:33.949 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:33.949 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:13:33.949 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:33.956 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:13:33.956 | Denali Data Feed | Sending logon request message.
2025-01-08 12:13:34.196 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:34.196 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:34.196 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:34.196 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:34.502 | Denali Data Feed | Received logon response.
2025-01-08 12:13:34.502 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:13:34.502 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:34.502 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:13:34.502 | Denali Data Feed | Failed connections: 205
2025-01-08 12:13:34.502 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:13:34.502 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:34.502 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:13:34.502 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:13:34.502 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:34.661 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:34.661 | DTC Client socket (2) | Closed.
2025-01-08 12:13:35.154 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:35.154 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:35.154 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:35.154 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:35.154 | Rithmic Direct - DTC (Data) | Failed connections: 2858
2025-01-08 12:13:35.154 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:35.155 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:13:35.155 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:35.155 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:35.155 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:35.401 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:13:35.401 | DTC Client socket (3) | Closed.
2025-01-08 12:13:37.143 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:37.143 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:37.143 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:37.143 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:37.144 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:37.144 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:37.441 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:37.441 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:37.441 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:37.441 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:38.550 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:38.550 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:38.550 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:38.550 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:38.550 | Rithmic Direct - DTC (Data) | Failed connections: 2859
2025-01-08 12:13:38.550 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:38.551 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:38.551 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:38.551 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:38.551 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:38.846 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:38.846 | DTC Client socket (2) | Closed.
2025-01-08 12:13:40.550 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:40.550 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:40.550 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:40.551 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:40.551 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:40.551 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:40.788 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:40.788 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:40.788 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:40.788 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:41.719 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:41.719 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:41.719 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:41.719 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:41.719 | Rithmic Direct - DTC (Data) | Failed connections: 2860
2025-01-08 12:13:41.719 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:41.720 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:41.720 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:41.720 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:41.720 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:41.955 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:41.956 | DTC Client socket (2) | Closed.
2025-01-08 12:13:43.719 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:43.719 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:43.719 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:43.719 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:43.719 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:43.719 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:44.008 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:44.008 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:44.008 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:44.008 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:45.096 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:45.096 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:45.096 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:45.096 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:45.096 | Rithmic Direct - DTC (Data) | Failed connections: 2861
2025-01-08 12:13:45.096 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:45.097 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:45.097 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:45.097 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:45.097 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:45.386 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:45.386 | DTC Client socket (2) | Closed.
2025-01-08 12:13:47.109 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:47.109 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:47.109 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:47.110 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:47.110 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:47.110 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:47.436 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:47.436 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:47.436 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:47.436 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:48.647 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:48.647 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:48.647 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:48.647 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:48.647 | Rithmic Direct - DTC (Data) | Failed connections: 2862
2025-01-08 12:13:48.647 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:48.648 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:48.648 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:48.648 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:48.648 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:48.981 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:48.981 | DTC Client socket (2) | Closed.
2025-01-08 12:13:50.644 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:50.644 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:50.644 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:50.645 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:50.645 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:50.645 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:50.887 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:50.887 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:50.887 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:50.887 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:51.823 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:51.823 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:51.823 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:51.823 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:51.823 | Rithmic Direct - DTC (Data) | Failed connections: 2863
2025-01-08 12:13:51.823 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:51.824 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:51.824 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:51.824 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:51.824 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:52.061 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:52.061 | DTC Client socket (2) | Closed.
2025-01-08 12:13:53.832 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:53.832 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:53.832 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:53.833 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:53.833 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:53.833 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:54.131 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:54.131 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:54.131 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:54.131 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:55.240 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:55.240 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:55.240 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:55.240 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:55.240 | Rithmic Direct - DTC (Data) | Failed connections: 2864
2025-01-08 12:13:55.240 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:55.241 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:55.241 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:55.241 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:55.242 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:55.538 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:55.538 | DTC Client socket (2) | Closed.
2025-01-08 12:13:57.246 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:13:57.246 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:13:57.246 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:13:57.247 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:13:57.247 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:13:57.247 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:13:57.534 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:13:57.534 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:13:57.534 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:13:57.534 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Failed connections: 2865
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:13:58.614 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:13:58.614 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:13:58.614 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:13:58.900 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:13:58.900 | DTC Client socket (2) | Closed.
2025-01-08 12:14:00.632 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:00.632 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:00.632 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:00.632 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:00.633 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:00.633 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:00.931 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:00.931 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:00.931 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:00.931 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:02.057 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:02.057 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:02.057 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:02.057 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:02.057 | Rithmic Direct - DTC (Data) | Failed connections: 2866
2025-01-08 12:14:02.057 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:02.058 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:02.058 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:02.058 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:02.058 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:02.356 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:02.356 | DTC Client socket (2) | Closed.
2025-01-08 12:14:04.058 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:04.058 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:04.058 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:04.059 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:04.060 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:04.060 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:04.386 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:04.386 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:04.386 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:04.386 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:05.589 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:05.589 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:05.589 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:05.589 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:05.589 | Rithmic Direct - DTC (Data) | Failed connections: 2867
2025-01-08 12:14:05.589 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:05.590 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:05.590 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:05.590 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:05.590 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:05.917 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:05.917 | DTC Client socket (2) | Closed.
2025-01-08 12:14:07.586 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:07.586 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:07.586 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:07.587 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:07.588 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:07.588 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:07.826 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:07.826 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:07.826 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:07.826 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:08.754 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:08.754 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:08.754 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:08.754 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:08.754 | Rithmic Direct - DTC (Data) | Failed connections: 2868
2025-01-08 12:14:08.754 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:08.754 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:08.755 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:08.755 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:08.755 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:08.991 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:08.991 | DTC Client socket (2) | Closed.
2025-01-08 12:14:10.761 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:10.761 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:10.761 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:10.762 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:10.762 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:10.762 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:11.056 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:11.056 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:11.056 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:11.056 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:12.155 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:12.155 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:12.155 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:12.155 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:12.155 | Rithmic Direct - DTC (Data) | Failed connections: 2869
2025-01-08 12:14:12.155 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:12.156 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:12.156 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:12.156 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:12.156 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:12.465 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:12.465 | DTC Client socket (2) | Closed.
2025-01-08 12:14:14.142 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:14.142 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:14.142 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:14.143 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:14.143 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:14.143 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:14.387 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:14.387 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:14.388 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:14.388 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Failed connections: 2870
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:15.351 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:15.351 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:15.351 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:15.596 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:15.596 | DTC Client socket (2) | Closed.
2025-01-08 12:14:17.353 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:17.353 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:17.353 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:17.422 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:17.422 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:17.422 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:17.719 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:17.719 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:17.720 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:17.720 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:18.832 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:18.832 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:18.832 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:18.832 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:18.832 | Rithmic Direct - DTC (Data) | Failed connections: 2871
2025-01-08 12:14:18.832 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:18.833 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:18.833 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:18.833 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:18.833 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:19.131 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:19.131 | DTC Client socket (2) | Closed.
2025-01-08 12:14:20.832 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:20.832 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:20.832 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:20.833 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:20.833 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:20.833 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:21.070 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:21.070 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:21.070 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:21.070 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:22.005 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:22.005 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:22.005 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:22.005 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:22.005 | Rithmic Direct - DTC (Data) | Failed connections: 2872
2025-01-08 12:14:22.005 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:22.006 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:22.006 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:22.006 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:22.006 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:22.242 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:22.242 | DTC Client socket (2) | Closed.
2025-01-08 12:14:24.009 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:24.009 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:24.009 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:24.009 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:24.009 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:24.009 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:24.305 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:24.305 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:24.305 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:24.305 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:26.038 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:26.038 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:26.038 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:26.038 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:26.038 | Rithmic Direct - DTC (Data) | Failed connections: 2873
2025-01-08 12:14:26.038 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:26.039 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:26.039 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:26.039 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:26.039 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:26.330 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:26.330 | DTC Client socket (2) | Closed.
2025-01-08 12:14:28.040 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:28.040 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:28.040 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:28.040 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:28.040 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:28.041 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:28.279 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:28.279 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:28.279 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:28.279 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:29.211 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:29.211 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:29.211 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:29.211 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:29.211 | Rithmic Direct - DTC (Data) | Failed connections: 2874
2025-01-08 12:14:29.211 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:29.212 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:29.212 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:29.212 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:29.212 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:29.449 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:29.449 | DTC Client socket (2) | Closed.
2025-01-08 12:14:31.212 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:31.212 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:31.212 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:31.212 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:31.213 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:31.213 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:31.507 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:31.507 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:31.507 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:31.507 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:32.612 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:32.612 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:32.612 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:32.612 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:32.612 | Rithmic Direct - DTC (Data) | Failed connections: 2875
2025-01-08 12:14:32.612 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:32.613 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:32.613 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:32.613 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:32.613 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:32.906 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:32.906 | DTC Client socket (2) | Closed.
2025-01-08 12:14:34.508 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:14:34.509 | DTC Client socket (2) | Creating socket.
2025-01-08 12:14:34.509 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:34.509 | DTC Client socket (2) | Connecting to IP: 67.214.125.5.
2025-01-08 12:14:34.617 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:34.617 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:34.617 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:34.617 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:34.618 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:14:34.618 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:34.664 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:14:34.664 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:14:34.664 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:14:34.842 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:14:34.842 | Denali Data Feed | Sending logon request message.
2025-01-08 12:14:34.909 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:34.909 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:34.909 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:34.909 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:35.398 | Denali Data Feed | Received logon response.
2025-01-08 12:14:35.398 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:14:35.398 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:35.398 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:14:35.398 | Denali Data Feed | Failed connections: 206
2025-01-08 12:14:35.398 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:14:35.399 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:35.399 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:14:35.399 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:14:35.399 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:35.553 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:35.553 | DTC Client socket (2) | Closed.
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Failed connections: 2876
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:36.003 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:14:36.003 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:36.003 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:36.294 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:14:36.294 | DTC Client socket (3) | Closed.
2025-01-08 12:14:38.006 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:38.006 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:38.006 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:38.007 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:38.007 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:38.007 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:38.248 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:38.248 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:38.248 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:38.248 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Failed connections: 2877
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:39.187 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:39.187 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:39.187 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:39.428 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:39.428 | DTC Client socket (2) | Closed.
2025-01-08 12:14:41.189 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:41.189 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:41.189 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:41.189 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:41.189 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:41.189 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:41.433 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:41.433 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:41.433 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:41.433 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:42.393 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:42.393 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:42.393 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:42.393 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:42.393 | Rithmic Direct - DTC (Data) | Failed connections: 2878
2025-01-08 12:14:42.394 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:42.395 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:42.395 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:42.395 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:42.395 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:42.639 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:42.640 | DTC Client socket (2) | Closed.
2025-01-08 12:14:44.403 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:44.403 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:44.403 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:44.404 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:44.404 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:44.405 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:44.697 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:44.697 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:44.697 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:44.697 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:45.795 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:45.795 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:45.795 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:45.795 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:45.795 | Rithmic Direct - DTC (Data) | Failed connections: 2879
2025-01-08 12:14:45.795 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:45.796 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:45.796 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:45.796 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:45.796 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:46.089 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:46.089 | DTC Client socket (2) | Closed.
2025-01-08 12:14:47.790 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:47.790 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:47.790 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:47.791 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:47.791 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:47.791 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:48.033 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:48.033 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:48.033 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:48.033 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:48.980 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:48.980 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:48.980 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:48.980 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:48.980 | Rithmic Direct - DTC (Data) | Failed connections: 2880
2025-01-08 12:14:48.980 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:48.981 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:48.981 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:48.981 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:48.981 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:49.223 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:49.223 | DTC Client socket (2) | Closed.
2025-01-08 12:14:50.984 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:50.984 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:50.984 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:50.984 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:50.984 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:50.984 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:51.276 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:51.276 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:51.276 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:51.276 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:52.376 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:52.376 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:52.376 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:52.376 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:52.376 | Rithmic Direct - DTC (Data) | Failed connections: 2881
2025-01-08 12:14:52.376 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:52.376 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:52.377 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:52.377 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:52.377 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:52.668 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:52.668 | DTC Client socket (2) | Closed.
2025-01-08 12:14:54.387 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:54.387 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:54.387 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:54.516 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:54.517 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:54.517 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:54.780 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:54.780 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:54.780 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:54.780 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:55.798 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:55.798 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:55.798 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:55.798 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:55.798 | Rithmic Direct - DTC (Data) | Failed connections: 2882
2025-01-08 12:14:55.798 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:55.799 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:55.799 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:55.799 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:55.799 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:56.067 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:56.067 | DTC Client socket (2) | Closed.
2025-01-08 12:14:57.802 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:14:57.802 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:14:57.802 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:14:57.802 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:14:57.802 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:14:57.802 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:14:58.047 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:14:58.048 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:14:58.048 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:14:58.048 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:14:59.001 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:14:59.001 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:14:59.001 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:14:59.001 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:14:59.001 | Rithmic Direct - DTC (Data) | Failed connections: 2883
2025-01-08 12:14:59.001 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:14:59.002 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:14:59.002 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:14:59.002 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:14:59.002 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:14:59.247 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:14:59.247 | DTC Client socket (2) | Closed.
2025-01-08 12:15:01.012 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:01.012 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:01.012 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:01.013 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:01.013 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:01.013 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:01.262 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:01.262 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:01.262 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:01.262 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Failed connections: 2884
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:02.225 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:02.225 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:02.226 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:02.474 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:02.474 | DTC Client socket (2) | Closed.
2025-01-08 12:15:04.223 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:04.223 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:04.223 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:04.224 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:04.224 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:04.224 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:04.466 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:04.466 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:04.466 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:04.466 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:05.416 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:05.416 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:05.416 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:05.416 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:05.416 | Rithmic Direct - DTC (Data) | Failed connections: 2885
2025-01-08 12:15:05.416 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:05.417 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:05.417 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:05.417 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:05.417 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:05.664 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:05.664 | DTC Client socket (2) | Closed.
2025-01-08 12:15:07.413 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:07.413 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:07.413 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:07.414 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:07.414 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:07.414 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:07.713 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:07.713 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:07.713 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:07.713 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:08.851 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:08.851 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:08.851 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:08.851 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:08.851 | Rithmic Direct - DTC (Data) | Failed connections: 2886
2025-01-08 12:15:08.851 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:08.852 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:08.852 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:08.852 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:08.852 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:09.155 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:09.155 | DTC Client socket (2) | Closed.
2025-01-08 12:15:10.847 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:10.847 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:10.847 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:10.848 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:10.848 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:10.849 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:11.160 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:11.160 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:11.160 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:11.160 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:12.266 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:12.266 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:12.266 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:12.266 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:12.266 | Rithmic Direct - DTC (Data) | Failed connections: 2887
2025-01-08 12:15:12.266 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:12.267 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:12.267 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:12.267 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:12.267 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:12.562 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:12.562 | DTC Client socket (2) | Closed.
2025-01-08 12:15:14.271 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:14.271 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:14.272 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:14.273 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:14.273 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:14.273 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:17.591 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:17.591 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:17.591 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:17.591 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:18.683 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:18.683 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:18.683 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:18.683 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:18.683 | Rithmic Direct - DTC (Data) | Failed connections: 2888
2025-01-08 12:15:18.683 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:18.684 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:18.684 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:18.684 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:18.684 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:18.974 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:18.974 | DTC Client socket (2) | Closed.
2025-01-08 12:15:20.682 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:20.682 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:20.682 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:20.683 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:20.683 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:20.683 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:20.985 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:20.985 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:20.985 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:20.985 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:22.097 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:22.097 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:22.097 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:22.097 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:22.097 | Rithmic Direct - DTC (Data) | Failed connections: 2889
2025-01-08 12:15:22.097 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:22.098 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:22.098 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:22.098 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:22.098 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:22.396 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:22.396 | DTC Client socket (2) | Closed.
2025-01-08 12:15:24.099 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:24.099 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:24.099 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:24.099 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:24.100 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:24.100 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:24.388 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:24.388 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:24.388 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:24.388 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:25.474 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:25.474 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:25.474 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:25.474 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:25.474 | Rithmic Direct - DTC (Data) | Failed connections: 2890
2025-01-08 12:15:25.474 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:25.475 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:25.475 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:25.475 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:25.475 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:25.764 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:25.764 | DTC Client socket (2) | Closed.
2025-01-08 12:15:27.485 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:27.485 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:27.485 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:27.486 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:27.486 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:27.486 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:27.770 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:27.770 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:27.770 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:27.770 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:28.848 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:28.848 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:28.848 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:28.848 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:28.848 | Rithmic Direct - DTC (Data) | Failed connections: 2891
2025-01-08 12:15:28.848 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:28.849 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:28.849 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:28.849 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:28.849 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:29.706 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:29.706 | DTC Client socket (2) | Closed.
2025-01-08 12:15:30.864 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:30.864 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:30.864 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:30.865 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:30.865 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:30.865 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:31.162 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:31.162 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:31.163 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:31.163 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:32.265 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:32.265 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:32.265 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:32.265 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:32.265 | Rithmic Direct - DTC (Data) | Failed connections: 2892
2025-01-08 12:15:32.265 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:32.266 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:32.266 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:32.266 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:32.266 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:32.560 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:32.560 | DTC Client socket (2) | Closed.
2025-01-08 12:15:34.265 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:34.265 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:34.265 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:34.265 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:34.265 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:34.266 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:34.549 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:34.549 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:34.549 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:34.549 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:35.402 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443
2025-01-08 12:15:35.624 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:35.624 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:35.624 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:35.624 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:35.624 | Rithmic Direct - DTC (Data) | Failed connections: 2893
2025-01-08 12:15:35.624 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:35.625 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:35.625 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:35.625 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:35.625 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:35.907 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:35.907 | DTC Client socket (2) | Closed.
2025-01-08 12:15:36.339 | DTC Client socket (3) | Creating socket.
2025-01-08 12:15:36.339 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:15:36.339 | DTC Client socket (3) | Connecting to IP: 64.152.155.21.
2025-01-08 12:15:36.499 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:15:36.499 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:15:36.499 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:15:36.685 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:15:36.685 | Denali Data Feed | Sending logon request message.
2025-01-08 12:15:37.218 | Denali Data Feed | Received logon response.
2025-01-08 12:15:37.218 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:15:37.218 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:37.218 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:15:37.218 | Denali Data Feed | Failed connections: 207
2025-01-08 12:15:37.218 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:15:37.219 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:15:37.219 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:15:37.219 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:15:37.219 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:37.379 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:15:37.379 | DTC Client socket (3) | Closed.
2025-01-08 12:15:37.625 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:37.625 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:37.625 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:37.626 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:37.627 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:37.627 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:37.929 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:37.929 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:37.929 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:37.929 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:39.031 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:39.031 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:39.031 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:39.031 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:39.031 | Rithmic Direct - DTC (Data) | Failed connections: 2894
2025-01-08 12:15:39.031 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:39.032 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:39.032 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:39.032 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:39.032 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:39.323 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:39.323 | DTC Client socket (2) | Closed.
2025-01-08 12:15:41.022 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:41.022 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:41.022 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:41.023 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:41.023 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:41.023 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:41.270 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:41.270 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:41.270 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:41.270 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:42.216 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:42.216 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:42.216 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:42.216 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:42.216 | Rithmic Direct - DTC (Data) | Failed connections: 2895
2025-01-08 12:15:42.216 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:42.217 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:42.217 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:42.217 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:42.217 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:42.468 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:42.468 | DTC Client socket (2) | Closed.
2025-01-08 12:15:44.210 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:44.210 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:44.210 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:44.210 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:44.210 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:44.210 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:44.504 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:44.504 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:44.504 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:44.504 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Failed connections: 2896
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:45.611 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:45.611 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:45.612 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:45.904 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:45.905 | DTC Client socket (2) | Closed.
2025-01-08 12:15:47.623 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:47.624 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:47.624 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:47.625 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:47.625 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:47.625 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:47.958 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:47.958 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:47.958 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:47.958 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Failed connections: 2897
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:49.164 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:49.164 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:49.164 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:49.493 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:49.493 | DTC Client socket (2) | Closed.
2025-01-08 12:15:51.165 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:51.165 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:51.165 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:51.166 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:51.166 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:51.166 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:51.410 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:51.410 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:51.410 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:51.410 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:52.365 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:52.365 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:52.365 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:52.365 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:52.365 | Rithmic Direct - DTC (Data) | Failed connections: 2898
2025-01-08 12:15:52.365 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:52.366 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:52.366 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:52.367 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:52.367 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:52.610 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:52.610 | DTC Client socket (2) | Closed.
2025-01-08 12:15:54.377 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:54.377 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:54.377 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:54.378 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:54.378 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:54.378 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:55.676 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:55.676 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:55.676 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:55.676 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:15:57.379 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:15:57.379 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:15:57.379 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:15:57.379 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:15:57.379 | Rithmic Direct - DTC (Data) | Failed connections: 2899
2025-01-08 12:15:57.379 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:15:57.381 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:15:57.381 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:15:57.381 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:15:57.381 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:15:57.664 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:15:57.664 | DTC Client socket (2) | Closed.
2025-01-08 12:15:59.390 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:15:59.390 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:15:59.390 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:15:59.391 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:15:59.391 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:15:59.391 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:15:59.689 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:15:59.689 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:15:59.689 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:15:59.689 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:00.788 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:00.788 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:00.788 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:00.788 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:00.788 | Rithmic Direct - DTC (Data) | Failed connections: 2900
2025-01-08 12:16:00.788 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:00.788 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:00.788 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:00.788 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:00.789 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:01.082 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:01.082 | DTC Client socket (2) | Closed.
2025-01-08 12:16:02.785 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:02.785 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:02.785 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:02.786 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:02.786 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:02.786 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:04.081 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:04.081 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:04.081 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:04.081 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:05.177 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:05.177 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:05.177 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:05.177 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:05.177 | Rithmic Direct - DTC (Data) | Failed connections: 2901
2025-01-08 12:16:05.177 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:05.178 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:05.178 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:05.178 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:05.178 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:06.120 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:06.120 | DTC Client socket (2) | Closed.
2025-01-08 12:16:07.186 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:07.186 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:07.186 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:07.187 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:07.187 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:07.187 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:07.480 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:07.480 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:07.480 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:07.480 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:08.591 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:08.591 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:08.591 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:08.591 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:08.591 | Rithmic Direct - DTC (Data) | Failed connections: 2902
2025-01-08 12:16:08.591 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:08.592 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:08.592 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:08.592 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:08.592 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:08.885 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:08.885 | DTC Client socket (2) | Closed.
2025-01-08 12:16:10.591 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:10.591 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:10.591 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:10.592 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:10.592 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:10.592 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:10.841 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:10.841 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:10.841 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:10.841 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:11.811 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:11.811 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:11.811 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:11.811 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:11.811 | Rithmic Direct - DTC (Data) | Failed connections: 2903
2025-01-08 12:16:11.811 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:11.812 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:11.812 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:11.812 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:11.812 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:12.062 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:12.062 | DTC Client socket (2) | Closed.
2025-01-08 12:16:13.799 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:13.799 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:13.799 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:13.800 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:13.800 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:13.800 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:14.037 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:14.037 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:14.037 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:14.037 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:14.969 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:14.969 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:14.969 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:14.969 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:14.969 | Rithmic Direct - DTC (Data) | Failed connections: 2904
2025-01-08 12:16:14.969 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:14.970 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:14.970 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:14.970 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:14.970 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:15.206 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:15.206 | DTC Client socket (2) | Closed.
2025-01-08 12:16:16.984 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:16.984 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:16.984 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:16.985 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:16.985 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:16.985 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:17.233 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:17.233 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:17.233 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:17.233 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:18.195 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:18.195 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:18.195 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:18.195 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:18.195 | Rithmic Direct - DTC (Data) | Failed connections: 2905
2025-01-08 12:16:18.195 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:18.196 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:18.196 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:18.196 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:18.196 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:18.442 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:18.442 | DTC Client socket (2) | Closed.
2025-01-08 12:16:20.190 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:20.190 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:20.190 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:20.191 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:20.191 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:20.191 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:20.434 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:20.434 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:20.435 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:20.435 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Failed connections: 2906
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:21.381 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:21.381 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:21.381 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:21.623 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:21.623 | DTC Client socket (2) | Closed.
2025-01-08 12:16:23.384 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:23.384 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:23.384 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:23.384 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:23.385 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:23.385 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:23.676 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:23.676 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:23.676 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:23.676 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:24.771 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:24.771 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:24.771 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:24.771 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:24.771 | Rithmic Direct - DTC (Data) | Failed connections: 2907
2025-01-08 12:16:24.771 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:24.772 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:24.772 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:24.772 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:24.772 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:25.062 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:25.062 | DTC Client socket (2) | Closed.
2025-01-08 12:16:26.770 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:26.770 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:26.770 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:26.770 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:26.770 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:26.770 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:27.012 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:27.012 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:27.012 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:27.012 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Failed connections: 2908
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:27.963 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:27.963 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:27.963 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:28.205 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:28.205 | DTC Client socket (2) | Closed.
2025-01-08 12:16:29.963 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:29.963 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:29.963 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:29.964 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:29.964 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:29.964 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:30.265 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:30.265 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:30.265 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:30.265 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:31.380 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:31.380 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:31.380 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:31.380 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:31.380 | Rithmic Direct - DTC (Data) | Failed connections: 2909
2025-01-08 12:16:31.380 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:31.381 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:31.381 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:31.381 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:31.381 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:31.679 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:31.679 | DTC Client socket (2) | Closed.
2025-01-08 12:16:33.388 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:33.388 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:33.388 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:33.389 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:33.389 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:33.389 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:33.626 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:33.626 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:33.627 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:33.627 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:34.566 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:34.566 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:34.566 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:34.566 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:34.566 | Rithmic Direct - DTC (Data) | Failed connections: 2910
2025-01-08 12:16:34.566 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:34.567 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:34.567 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:34.567 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:34.567 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:34.805 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:34.805 | DTC Client socket (2) | Closed.
2025-01-08 12:16:36.578 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:36.578 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:36.578 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:36.579 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:36.579 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:36.579 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:36.822 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:36.822 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:36.822 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:36.822 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:37.218 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443
2025-01-08 12:16:37.821 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:37.821 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:37.821 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:37.821 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:37.821 | Rithmic Direct - DTC (Data) | Failed connections: 2911
2025-01-08 12:16:37.821 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:37.821 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:37.821 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:37.822 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:37.822 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:38.065 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:38.065 | DTC Client socket (2) | Closed.
2025-01-08 12:16:39.546 | DTC Client socket (3) | Creating socket.
2025-01-08 12:16:39.546 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:16:39.546 | DTC Client socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:16:39.708 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:16:39.708 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:16:39.708 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:16:39.827 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:39.827 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:39.827 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:39.828 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:39.828 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:39.828 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:39.880 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:16:39.880 | Denali Data Feed | Sending logon request message.
2025-01-08 12:16:40.120 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:40.120 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:40.121 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:40.121 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:40.397 | Denali Data Feed | Received logon response.
2025-01-08 12:16:40.397 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:16:40.397 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:40.397 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:16:40.397 | Denali Data Feed | Failed connections: 208
2025-01-08 12:16:40.397 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:16:40.397 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:16:40.397 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:40.398 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:16:40.398 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:16:40.561 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:16:40.562 | DTC Client socket (3) | Closed.
2025-01-08 12:16:41.212 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:41.212 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:41.212 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:41.212 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:41.212 | Rithmic Direct - DTC (Data) | Failed connections: 2912
2025-01-08 12:16:41.212 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:41.213 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:41.213 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:41.213 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:41.213 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:41.504 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:41.504 | DTC Client socket (2) | Closed.
2025-01-08 12:16:43.207 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:43.207 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:43.207 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:43.208 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:43.209 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:43.209 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:43.504 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:43.504 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:43.505 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:43.505 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:44.625 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:44.625 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:44.625 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:44.625 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:44.625 | Rithmic Direct - DTC (Data) | Failed connections: 2913
2025-01-08 12:16:44.625 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:44.626 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:44.626 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:44.626 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:44.626 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:44.919 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:44.920 | DTC Client socket (2) | Closed.
2025-01-08 12:16:46.626 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:46.626 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:46.626 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:46.627 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:46.627 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:46.627 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:46.917 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:46.917 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:46.917 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:46.917 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Failed connections: 2914
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:48.639 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:48.639 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:48.640 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:48.930 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:48.930 | DTC Client socket (2) | Closed.
2025-01-08 12:16:50.655 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:50.655 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:50.655 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:50.656 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:50.657 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:50.657 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:50.947 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:50.947 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:50.947 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:50.947 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:52.034 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:52.034 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:52.034 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:52.034 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:52.034 | Rithmic Direct - DTC (Data) | Failed connections: 2915
2025-01-08 12:16:52.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:52.035 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:52.035 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:52.035 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:52.035 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:52.324 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:52.324 | DTC Client socket (2) | Closed.
2025-01-08 12:16:54.041 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:54.041 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:54.041 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:54.042 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:54.042 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:54.042 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:54.332 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:54.332 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:54.332 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:54.332 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:55.420 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:55.420 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:55.420 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:55.420 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:55.420 | Rithmic Direct - DTC (Data) | Failed connections: 2916
2025-01-08 12:16:55.420 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:55.421 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:55.421 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:55.421 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:55.421 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:55.710 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:55.710 | DTC Client socket (2) | Closed.
2025-01-08 12:16:57.409 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:16:57.409 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:16:57.409 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:16:57.410 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:16:57.410 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:16:57.411 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:16:57.699 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:16:57.699 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:16:57.699 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:16:57.699 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Failed connections: 2917
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:16:58.797 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:16:58.797 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:16:58.797 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:16:59.087 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:16:59.087 | DTC Client socket (2) | Closed.
2025-01-08 12:17:00.794 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:00.794 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:00.794 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:00.795 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:00.796 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:00.796 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:01.038 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:01.038 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:01.038 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:01.038 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:01.986 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:01.986 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:01.986 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:01.986 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:01.986 | Rithmic Direct - DTC (Data) | Failed connections: 2918
2025-01-08 12:17:01.986 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:01.986 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:01.987 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:01.987 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:01.987 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:02.227 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:02.227 | DTC Client socket (2) | Closed.
2025-01-08 12:17:03.994 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:03.994 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:03.994 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:03.995 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:03.995 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:03.995 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:04.285 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:04.285 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:04.285 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:04.285 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:05.380 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:05.380 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:05.380 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:05.380 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:05.380 | Rithmic Direct - DTC (Data) | Failed connections: 2919
2025-01-08 12:17:05.380 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:05.381 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:05.381 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:05.381 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:05.381 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:05.669 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:05.669 | DTC Client socket (2) | Closed.
2025-01-08 12:17:07.379 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:07.379 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:07.379 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:07.380 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:07.380 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:07.380 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:07.671 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:07.671 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:07.671 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:07.671 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:08.764 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:08.764 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:08.764 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:08.764 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:08.764 | Rithmic Direct - DTC (Data) | Failed connections: 2920
2025-01-08 12:17:08.764 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:08.765 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:08.765 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:08.765 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:08.765 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:09.054 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:09.054 | DTC Client socket (2) | Closed.
2025-01-08 12:17:10.757 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:10.757 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:10.757 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:10.758 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:10.759 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:10.759 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:10.996 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:10.996 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:10.996 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:10.996 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:11.930 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:11.930 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:11.930 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:11.930 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:11.930 | Rithmic Direct - DTC (Data) | Failed connections: 2921
2025-01-08 12:17:11.930 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:11.931 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:11.931 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:11.931 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:11.931 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:12.167 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:12.167 | DTC Client socket (2) | Closed.
2025-01-08 12:17:13.924 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:13.924 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:13.924 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:13.925 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:13.925 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:13.925 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:14.216 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:14.216 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:14.216 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:14.216 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:15.315 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:15.315 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:15.315 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:15.315 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:15.315 | Rithmic Direct - DTC (Data) | Failed connections: 2922
2025-01-08 12:17:15.315 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:15.316 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:15.316 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:15.316 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:15.316 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:15.606 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:15.606 | DTC Client socket (2) | Closed.
2025-01-08 12:17:17.327 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:17.327 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:17.327 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:17.328 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:17.328 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:17.328 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:17.569 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:17.569 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:17.570 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:17.570 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:18.518 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:18.518 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:18.518 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:18.518 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:18.518 | Rithmic Direct - DTC (Data) | Failed connections: 2923
2025-01-08 12:17:18.518 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:18.519 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:18.519 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:18.519 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:18.519 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:18.760 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:18.760 | DTC Client socket (2) | Closed.
2025-01-08 12:17:20.523 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:20.523 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:20.523 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:20.524 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:20.524 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:20.524 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:20.826 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:20.826 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:20.826 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:20.826 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Failed connections: 2924
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:21.952 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:21.952 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:21.952 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:22.254 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:22.254 | DTC Client socket (2) | Closed.
2025-01-08 12:17:23.953 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:23.953 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:23.953 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:23.954 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:23.954 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:23.954 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:24.193 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:24.193 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:24.193 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:24.193 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Failed connections: 2925
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:25.126 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:25.126 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:25.126 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:25.363 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:25.363 | DTC Client socket (2) | Closed.
2025-01-08 12:17:27.154 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:27.154 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:27.154 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:27.155 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:27.155 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:27.155 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:27.445 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:27.445 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:27.445 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:27.445 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:28.535 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:28.535 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:28.535 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:28.535 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:28.535 | Rithmic Direct - DTC (Data) | Failed connections: 2926
2025-01-08 12:17:28.535 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:28.536 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:28.536 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:28.536 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:28.536 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:28.825 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:28.825 | DTC Client socket (2) | Closed.
2025-01-08 12:17:30.534 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:30.534 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:30.534 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:30.534 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:30.534 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:30.534 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:30.771 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:30.771 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:30.771 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:30.771 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:31.699 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:31.699 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:31.699 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:31.699 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:31.699 | Rithmic Direct - DTC (Data) | Failed connections: 2927
2025-01-08 12:17:31.699 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:31.700 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:31.700 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:31.700 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:31.700 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:31.936 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:31.936 | DTC Client socket (2) | Closed.
2025-01-08 12:17:33.700 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:33.700 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:33.700 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:33.701 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:33.701 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:33.701 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:34.003 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:34.003 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:34.003 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:34.003 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:35.127 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:35.127 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:35.127 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:35.127 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:35.127 | Rithmic Direct - DTC (Data) | Failed connections: 2928
2025-01-08 12:17:35.128 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:35.129 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:35.129 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:35.129 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:35.129 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:35.432 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:35.432 | DTC Client socket (2) | Closed.
2025-01-08 12:17:37.147 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:37.148 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:37.148 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:37.148 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:37.149 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:37.149 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:37.442 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:37.442 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:37.442 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:37.442 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:38.533 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:38.534 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:38.534 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:38.534 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:38.534 | Rithmic Direct - DTC (Data) | Failed connections: 2929
2025-01-08 12:17:38.534 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:38.534 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:38.534 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:38.534 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:38.534 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:38.824 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:38.824 | DTC Client socket (2) | Closed.
2025-01-08 12:17:40.399 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048
2025-01-08 12:17:40.400 | DTC Client socket (2) | Creating socket.
2025-01-08 12:17:40.400 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:40.400 | DTC Client socket (2) | Connecting to IP: 67.214.125.3.
2025-01-08 12:17:40.533 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:40.533 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:40.533 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:40.533 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:40.534 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:17:40.534 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:40.567 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:17:40.567 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:17:40.567 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:17:40.737 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:17:40.737 | Denali Data Feed | Sending logon request message.
2025-01-08 12:17:40.827 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:40.827 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:40.827 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:40.827 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:41.298 | Denali Data Feed | Received logon response.
2025-01-08 12:17:41.298 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:17:41.298 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:41.298 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:17:41.298 | Denali Data Feed | Failed connections: 209
2025-01-08 12:17:41.298 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:17:41.298 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:41.298 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:41.298 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:17:41.298 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:17:41.464 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:41.464 | DTC Client socket (2) | Closed.
2025-01-08 12:17:41.926 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:41.926 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:41.926 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:41.926 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:41.926 | Rithmic Direct - DTC (Data) | Failed connections: 2930
2025-01-08 12:17:41.926 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:41.927 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:17:41.927 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:41.927 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:41.927 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:42.221 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:17:42.221 | DTC Client socket (3) | Closed.
2025-01-08 12:17:43.934 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:43.934 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:43.934 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:43.936 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:43.936 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:43.936 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:44.223 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:44.223 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:44.223 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:44.223 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:45.309 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:45.309 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:45.309 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:45.309 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:45.309 | Rithmic Direct - DTC (Data) | Failed connections: 2931
2025-01-08 12:17:45.309 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:45.311 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:45.311 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:45.311 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:45.311 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:45.580 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:45.580 | DTC Client socket (2) | Closed.
2025-01-08 12:17:47.300 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:47.300 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:47.300 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:47.301 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:47.301 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:47.301 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:47.593 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:47.593 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:47.593 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:47.593 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:48.695 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:48.695 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:48.695 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:48.695 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:48.695 | Rithmic Direct - DTC (Data) | Failed connections: 2932
2025-01-08 12:17:48.695 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:48.696 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:48.696 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:48.696 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:48.696 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:48.988 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:48.988 | DTC Client socket (2) | Closed.
2025-01-08 12:17:50.694 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:50.694 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:50.694 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:50.695 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:50.695 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:50.695 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:50.986 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:50.986 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:50.986 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:50.986 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:52.082 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:52.082 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:52.082 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:52.082 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:52.082 | Rithmic Direct - DTC (Data) | Failed connections: 2933
2025-01-08 12:17:52.082 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:52.082 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:52.083 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:52.083 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:52.083 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:52.372 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:52.372 | DTC Client socket (2) | Closed.
2025-01-08 12:17:54.089 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:54.089 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:54.089 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:54.089 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:54.089 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:54.089 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:54.377 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:54.377 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:54.377 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:54.377 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Failed connections: 2934
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:55.463 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:55.463 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:55.463 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:55.751 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:55.751 | DTC Client socket (2) | Closed.
2025-01-08 12:17:57.455 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:17:57.455 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:17:57.455 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:17:57.456 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:17:57.456 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:17:57.456 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:17:57.698 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:17:57.698 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:17:57.698 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:17:57.698 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:17:58.653 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:17:58.653 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:17:58.653 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:17:58.653 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:17:58.653 | Rithmic Direct - DTC (Data) | Failed connections: 2935
2025-01-08 12:17:58.653 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:17:58.654 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:17:58.654 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:17:58.654 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:17:58.654 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:17:58.900 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:17:58.900 | DTC Client socket (2) | Closed.
2025-01-08 12:18:00.653 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:00.653 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:00.653 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:00.654 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:00.654 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:00.654 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:00.950 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:00.950 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:00.950 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:00.950 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Failed connections: 2936
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:02.055 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:02.055 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:02.055 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:02.351 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:02.351 | DTC Client socket (2) | Closed.
2025-01-08 12:18:04.060 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:04.060 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:04.060 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:04.061 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:04.061 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:04.061 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:04.306 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:04.306 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:04.306 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:04.306 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:05.269 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:05.269 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:05.269 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:05.269 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:05.269 | Rithmic Direct - DTC (Data) | Failed connections: 2937
2025-01-08 12:18:05.269 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:05.270 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:05.270 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:05.270 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:05.270 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:05.514 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:05.514 | DTC Client socket (2) | Closed.
2025-01-08 12:18:07.290 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:07.290 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:07.290 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:07.291 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:07.291 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:07.291 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:07.533 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:07.533 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:07.533 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:07.533 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:08.478 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:08.478 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:08.478 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:08.478 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:08.478 | Rithmic Direct - DTC (Data) | Failed connections: 2938
2025-01-08 12:18:08.478 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:08.479 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:08.479 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:08.479 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:08.479 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:08.720 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:08.720 | DTC Client socket (2) | Closed.
2025-01-08 12:18:10.478 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:10.478 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:10.478 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:10.479 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:10.479 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:10.479 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:10.726 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:10.726 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:10.726 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:10.726 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:11.684 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:11.684 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:11.684 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:11.684 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:11.684 | Rithmic Direct - DTC (Data) | Failed connections: 2939
2025-01-08 12:18:11.684 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:11.685 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:11.685 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:11.685 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:11.685 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:11.930 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:11.930 | DTC Client socket (2) | Closed.
2025-01-08 12:18:13.688 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:13.688 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:13.688 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:13.689 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:13.689 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:13.689 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:13.992 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:13.992 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:13.992 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:13.992 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Failed connections: 2940
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:15.111 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:15.111 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:15.111 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:15.409 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:15.409 | DTC Client socket (2) | Closed.
2025-01-08 12:18:17.098 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:17.098 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:17.098 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:17.098 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:17.098 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:17.098 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:17.337 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:17.337 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:17.337 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:17.337 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:18.286 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:18.286 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:18.286 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:18.286 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:18.286 | Rithmic Direct - DTC (Data) | Failed connections: 2941
2025-01-08 12:18:18.286 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:18.287 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:18.287 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:18.287 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:18.287 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:18.525 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:18.525 | DTC Client socket (2) | Closed.
2025-01-08 12:18:20.295 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:20.295 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:20.295 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:20.296 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:20.297 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:20.297 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:20.584 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:20.584 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:20.584 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:20.584 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:21.670 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:21.670 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:21.670 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:21.670 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:21.670 | Rithmic Direct - DTC (Data) | Failed connections: 2942
2025-01-08 12:18:21.670 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:21.671 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:21.671 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:21.671 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:21.671 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:21.956 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:21.956 | DTC Client socket (2) | Closed.
2025-01-08 12:18:23.670 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:23.670 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:23.670 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:23.670 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:23.671 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:23.671 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:23.994 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:23.994 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:23.994 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:23.994 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Failed connections: 2943
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:25.190 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:25.190 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:25.190 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:25.514 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:25.514 | DTC Client socket (2) | Closed.
2025-01-08 12:18:27.193 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:27.193 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:27.193 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:27.194 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:27.194 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:27.194 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:27.433 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:27.433 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:27.433 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:27.433 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:28.371 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:28.371 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:28.371 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:28.371 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:28.371 | Rithmic Direct - DTC (Data) | Failed connections: 2944
2025-01-08 12:18:28.371 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:28.372 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:28.372 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:28.372 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:28.372 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:28.609 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:28.610 | DTC Client socket (2) | Closed.
2025-01-08 12:18:30.366 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:30.366 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:30.366 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:30.367 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:30.367 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:30.367 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:30.615 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:30.615 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:30.615 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:30.615 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Failed connections: 2945
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:31.575 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:31.575 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:31.575 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:31.822 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:31.822 | DTC Client socket (2) | Closed.
2025-01-08 12:18:33.567 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:33.567 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:33.567 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:33.568 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:33.568 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:33.568 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:33.896 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:33.896 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:33.896 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:33.896 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:35.092 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:35.092 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:35.092 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:35.092 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:35.092 | Rithmic Direct - DTC (Data) | Failed connections: 2946
2025-01-08 12:18:35.092 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:35.093 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:35.093 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:35.093 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:35.094 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:35.418 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:35.418 | DTC Client socket (2) | Closed.
2025-01-08 12:18:37.100 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:37.100 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:37.100 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:37.101 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:37.101 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:37.101 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:37.344 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:37.344 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:37.344 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:37.344 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:38.352 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:38.352 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:38.352 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:38.352 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:38.352 | Rithmic Direct - DTC (Data) | Failed connections: 2947
2025-01-08 12:18:38.352 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:38.353 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:38.353 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:38.353 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:38.353 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:38.616 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:38.616 | DTC Client socket (2) | Closed.
2025-01-08 12:18:40.346 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:40.346 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:40.346 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:40.347 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:40.347 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:40.347 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:40.690 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:40.691 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:40.691 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:40.691 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:41.312 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-01-08 12:18:41.313 | DTC Client socket (3) | Creating socket.
2025-01-08 12:18:41.313 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:18:41.313 | DTC Client socket (3) | Connecting to IP: 67.214.125.6.
2025-01-08 12:18:41.478 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:18:41.478 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:18:41.478 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:18:41.651 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:18:41.651 | Denali Data Feed | Sending logon request message.
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Failed connections: 2948
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:41.897 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:41.897 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:41.898 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:42.190 | Denali Data Feed | Received logon response.
2025-01-08 12:18:42.190 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:18:42.190 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:42.190 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:18:42.190 | Denali Data Feed | Failed connections: 210
2025-01-08 12:18:42.190 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:18:42.191 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:18:42.191 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:42.191 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:18:42.191 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:18:42.226 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:42.226 | DTC Client socket (2) | Closed.
2025-01-08 12:18:42.353 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:18:42.353 | DTC Client socket (3) | Closed.
2025-01-08 12:18:43.895 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:43.895 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:43.895 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:43.896 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:43.896 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:43.896 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:44.156 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:44.156 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:44.157 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:44.157 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:45.107 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:45.107 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:45.107 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:45.107 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:45.107 | Rithmic Direct - DTC (Data) | Failed connections: 2949
2025-01-08 12:18:45.107 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:45.108 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:45.108 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:45.108 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:45.108 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:45.359 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:45.360 | DTC Client socket (2) | Closed.
2025-01-08 12:18:47.097 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:47.097 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:47.097 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:47.098 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:47.098 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:18:47.098 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:47.396 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:47.396 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:47.396 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:47.396 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:48.509 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:48.509 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:48.509 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:48.509 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:48.509 | Rithmic Direct - DTC (Data) | Failed connections: 2950
2025-01-08 12:18:48.509 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:48.510 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:18:48.510 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:48.510 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:48.510 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:48.808 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:18:48.809 | DTC Client socket (3) | Closed.
2025-01-08 12:18:50.511 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:50.511 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:50.511 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:50.512 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:50.512 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:50.512 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:50.793 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:50.793 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:50.793 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:50.793 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:51.860 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:51.860 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:51.860 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:51.860 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:51.860 | Rithmic Direct - DTC (Data) | Failed connections: 2951
2025-01-08 12:18:51.860 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:51.861 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:51.861 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:51.861 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:51.861 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:52.142 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:52.142 | DTC Client socket (2) | Closed.
2025-01-08 12:18:53.873 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:53.873 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:53.873 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:53.874 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:53.874 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:53.874 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:54.114 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:54.114 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:54.114 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:54.114 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:55.064 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:55.064 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:55.064 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:55.064 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:55.064 | Rithmic Direct - DTC (Data) | Failed connections: 2952
2025-01-08 12:18:55.064 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:55.065 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:55.065 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:55.065 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:55.065 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:55.322 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:55.322 | DTC Client socket (2) | Closed.
2025-01-08 12:18:57.064 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:18:57.064 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:18:57.064 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:18:57.065 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:18:57.065 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:18:57.065 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:18:57.308 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:18:57.308 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:18:57.308 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:18:57.308 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:18:58.257 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:18:58.257 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:18:58.257 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:18:58.257 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:18:58.257 | Rithmic Direct - DTC (Data) | Failed connections: 2953
2025-01-08 12:18:58.257 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:18:58.258 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:18:58.258 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:18:58.258 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:18:58.258 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:18:58.501 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:18:58.501 | DTC Client socket (2) | Closed.
2025-01-08 12:19:00.262 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:00.262 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:00.262 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:00.263 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:00.263 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:00.263 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:00.543 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:00.543 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:00.543 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:00.543 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:01.613 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:01.613 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:01.613 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:01.613 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:01.613 | Rithmic Direct - DTC (Data) | Failed connections: 2954
2025-01-08 12:19:01.613 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:01.615 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:01.615 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:01.615 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:01.615 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:01.895 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:01.895 | DTC Client socket (2) | Closed.
2025-01-08 12:19:03.624 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:03.624 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:03.624 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:03.624 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:03.625 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:03.625 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:03.866 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:03.866 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:03.866 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:03.866 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:04.809 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:04.809 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:04.809 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:04.809 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:04.809 | Rithmic Direct - DTC (Data) | Failed connections: 2955
2025-01-08 12:19:04.809 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:04.810 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:04.810 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:04.810 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:04.810 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:05.050 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:05.050 | DTC Client socket (2) | Closed.
2025-01-08 12:19:06.810 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:06.810 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:06.810 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:06.811 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:06.811 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:06.811 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:07.059 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:07.059 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:07.059 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:07.059 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:08.022 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:08.023 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:08.023 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:08.023 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:08.023 | Rithmic Direct - DTC (Data) | Failed connections: 2956
2025-01-08 12:19:08.023 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:08.023 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:08.023 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:08.023 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:08.023 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:08.271 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:08.272 | DTC Client socket (2) | Closed.
2025-01-08 12:19:10.028 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:10.028 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:10.028 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:10.029 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:10.029 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:10.030 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:10.267 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:10.267 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:10.267 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:10.267 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Failed connections: 2957
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:11.200 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:11.200 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:11.200 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:11.439 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:11.439 | DTC Client socket (2) | Closed.
2025-01-08 12:19:13.209 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:13.209 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:13.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:13.210 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:13.210 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:13.210 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:13.495 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:13.495 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:13.495 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:13.495 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:14.570 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:14.570 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:14.570 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:14.570 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:14.570 | Rithmic Direct - DTC (Data) | Failed connections: 2958
2025-01-08 12:19:14.570 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:14.571 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:14.571 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:14.571 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:14.571 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:14.856 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:14.856 | DTC Client socket (2) | Closed.
2025-01-08 12:19:16.575 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:16.575 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:16.575 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:16.576 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:16.576 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:16.576 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:16.825 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:16.825 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:16.826 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:16.826 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:17.802 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:17.802 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:17.802 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:17.802 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:17.802 | Rithmic Direct - DTC (Data) | Failed connections: 2959
2025-01-08 12:19:17.802 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:17.802 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:17.803 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:17.803 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:17.803 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:18.052 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:18.052 | DTC Client socket (2) | Closed.
2025-01-08 12:19:19.801 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:19.801 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:19.801 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:19.802 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:19.802 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:19.802 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:20.060 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:20.060 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:20.060 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:20.060 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Failed connections: 2960
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:21.082 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:21.082 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:21.082 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:21.366 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:21.366 | DTC Client socket (2) | Closed.
2025-01-08 12:19:23.082 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:23.082 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:23.082 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:23.083 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:23.083 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:23.083 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:23.334 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:23.334 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:23.334 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:23.334 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Failed connections: 2961
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:24.312 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:24.312 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:24.312 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:24.581 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:24.582 | DTC Client socket (2) | Closed.
2025-01-08 12:19:26.312 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:26.312 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:26.312 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:26.313 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:26.313 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:26.313 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:26.562 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:26.562 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:26.562 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:26.562 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:27.527 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:27.527 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:27.527 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:27.527 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:27.527 | Rithmic Direct - DTC (Data) | Failed connections: 2962
2025-01-08 12:19:27.527 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:27.528 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:27.528 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:27.528 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:27.528 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:27.774 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:27.774 | DTC Client socket (2) | Closed.
2025-01-08 12:19:29.519 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:29.519 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:29.519 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:29.519 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:29.520 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:29.520 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:29.764 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:29.764 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:29.764 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:29.764 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:30.728 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:30.728 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:30.728 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:30.728 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:30.728 | Rithmic Direct - DTC (Data) | Failed connections: 2963
2025-01-08 12:19:30.729 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:30.730 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:30.730 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:30.730 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:30.730 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:30.975 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:30.975 | DTC Client socket (2) | Closed.
2025-01-08 12:19:32.736 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:32.736 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:32.736 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:32.737 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:32.737 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:32.737 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:33.033 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:33.033 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:33.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:33.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Failed connections: 2964
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:34.137 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:34.137 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:34.137 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:34.433 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:34.433 | DTC Client socket (2) | Closed.
2025-01-08 12:19:36.128 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:36.128 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:36.128 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:36.129 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:36.129 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:36.129 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:36.419 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:36.419 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:36.419 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:36.419 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Failed connections: 2965
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:37.507 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:37.507 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:37.507 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:37.797 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:37.798 | DTC Client socket (2) | Closed.
2025-01-08 12:19:39.514 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:39.514 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:39.514 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:39.515 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:39.515 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:39.515 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:39.801 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:39.801 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:39.801 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:39.801 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:40.879 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:40.879 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:40.879 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:40.879 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:40.879 | Rithmic Direct - DTC (Data) | Failed connections: 2966
2025-01-08 12:19:40.879 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:40.880 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:40.880 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:40.880 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:40.880 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:41.167 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:41.167 | DTC Client socket (2) | Closed.
2025-01-08 12:19:42.196 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 10048
2025-01-08 12:19:42.328 | DTC Client socket (2) | Creating socket.
2025-01-08 12:19:42.328 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:42.328 | DTC Client socket (2) | Connecting to IP: 64.152.155.20.
2025-01-08 12:19:42.484 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:19:42.484 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:19:42.484 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:19:42.666 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:19:42.666 | Denali Data Feed | Sending logon request message.
2025-01-08 12:19:42.884 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:42.884 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:42.884 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:42.885 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:42.885 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:19:42.885 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:43.127 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:43.127 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:43.127 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:43.127 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:43.191 | Denali Data Feed | Received logon response.
2025-01-08 12:19:43.191 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:19:43.191 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:43.191 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:19:43.191 | Denali Data Feed | Failed connections: 211
2025-01-08 12:19:43.191 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:19:43.192 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:43.192 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:43.192 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:19:43.192 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:19:43.344 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:43.344 | DTC Client socket (2) | Closed.
2025-01-08 12:19:44.075 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:44.075 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:44.075 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:44.075 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:44.075 | Rithmic Direct - DTC (Data) | Failed connections: 2967
2025-01-08 12:19:44.075 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:44.075 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:19:44.076 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:44.076 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:44.076 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:44.316 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:19:44.316 | DTC Client socket (3) | Closed.
2025-01-08 12:19:46.074 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:46.074 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:46.074 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:46.075 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:46.075 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:46.075 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:46.370 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:46.370 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:46.370 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:46.370 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:47.471 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:47.471 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:47.471 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:47.471 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:47.471 | Rithmic Direct - DTC (Data) | Failed connections: 2968
2025-01-08 12:19:47.471 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:47.472 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:47.472 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:47.472 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:47.472 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:47.765 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:47.766 | DTC Client socket (2) | Closed.
2025-01-08 12:19:49.479 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:49.479 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:49.479 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:49.480 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:49.480 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:49.480 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:49.762 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:49.762 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:49.762 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:49.762 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:51.456 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:51.456 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:51.456 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:51.456 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:51.456 | Rithmic Direct - DTC (Data) | Failed connections: 2969
2025-01-08 12:19:51.456 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:51.457 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:51.457 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:51.457 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:51.457 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:51.739 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:51.739 | DTC Client socket (2) | Closed.
2025-01-08 12:19:53.468 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:53.468 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:53.468 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:53.469 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:53.469 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:53.469 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:53.757 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:53.757 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:53.757 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:53.757 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:54.844 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:54.844 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:54.844 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:54.844 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:54.844 | Rithmic Direct - DTC (Data) | Failed connections: 2970
2025-01-08 12:19:54.844 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:54.845 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:54.845 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:54.845 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:54.845 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:55.133 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:55.133 | DTC Client socket (2) | Closed.
2025-01-08 12:19:56.858 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:19:56.858 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:19:56.858 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:19:57.075 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:19:57.075 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:19:57.075 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:19:57.323 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:19:57.323 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:19:57.323 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:19:57.323 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:19:58.300 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:19:58.300 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:19:58.300 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:19:58.300 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:19:58.300 | Rithmic Direct - DTC (Data) | Failed connections: 2971
2025-01-08 12:19:58.300 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:19:58.301 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:19:58.301 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:19:58.301 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:19:58.301 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:19:58.548 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:19:58.548 | DTC Client socket (2) | Closed.
2025-01-08 12:20:00.312 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:00.312 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:00.312 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:00.313 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:00.313 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:00.313 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:00.552 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:00.552 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:00.552 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:00.552 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Failed connections: 2972
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:01.495 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:01.495 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:01.495 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:01.734 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:01.735 | DTC Client socket (2) | Closed.
2025-01-08 12:20:03.497 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:03.497 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:03.497 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:03.498 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:03.498 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:03.498 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:03.747 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:03.747 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:03.747 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:03.747 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Failed connections: 2973
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:04.679 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:04.679 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:04.679 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:04.918 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:04.918 | DTC Client socket (2) | Closed.
2025-01-08 12:20:06.686 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:06.686 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:06.686 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:06.687 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:06.687 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:06.687 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:06.990 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:06.990 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:06.990 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:06.990 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:08.113 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:08.113 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:08.113 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:08.113 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:08.113 | Rithmic Direct - DTC (Data) | Failed connections: 2974
2025-01-08 12:20:08.113 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:08.114 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:08.114 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:08.114 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:08.114 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:08.411 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:08.411 | DTC Client socket (2) | Closed.
2025-01-08 12:20:10.114 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:10.114 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:10.114 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:10.115 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:10.116 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:10.116 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:10.398 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:10.398 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:10.398 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:10.398 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:12.071 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:12.071 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:12.071 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:12.071 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:12.071 | Rithmic Direct - DTC (Data) | Failed connections: 2975
2025-01-08 12:20:12.071 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:12.072 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:12.072 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:12.072 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:12.072 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:12.948 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:12.948 | DTC Client socket (2) | Closed.
2025-01-08 12:20:14.066 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:14.066 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:14.066 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:14.067 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:14.067 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:14.067 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:14.305 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:14.305 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:14.305 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:14.305 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:15.249 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:15.249 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:15.249 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:15.249 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:15.249 | Rithmic Direct - DTC (Data) | Failed connections: 2976
2025-01-08 12:20:15.249 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:15.250 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:15.250 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:15.250 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:15.250 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:15.487 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:15.487 | DTC Client socket (2) | Closed.
2025-01-08 12:20:17.241 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:17.241 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:17.241 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:17.242 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:17.242 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:17.242 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:17.484 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:17.484 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:17.484 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:17.484 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:18.414 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:18.414 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:18.414 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:18.414 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:18.414 | Rithmic Direct - DTC (Data) | Failed connections: 2977
2025-01-08 12:20:18.414 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:18.415 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:18.415 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:18.415 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:18.415 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:18.652 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:18.652 | DTC Client socket (2) | Closed.
2025-01-08 12:20:20.410 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:20.411 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:20.411 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:20.411 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:20.411 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:20.411 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:20.651 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:20.651 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:20.651 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:20.651 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:21.594 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:21.594 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:21.594 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:21.594 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:21.594 | Rithmic Direct - DTC (Data) | Failed connections: 2978
2025-01-08 12:20:21.594 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:21.595 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:21.595 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:21.596 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:21.596 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:21.836 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:21.836 | DTC Client socket (2) | Closed.
2025-01-08 12:20:23.597 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:23.598 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:23.598 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:23.599 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:23.599 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:23.599 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:23.892 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:23.892 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:23.892 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:23.892 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:24.979 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:24.979 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:24.979 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:24.979 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:24.979 | Rithmic Direct - DTC (Data) | Failed connections: 2979
2025-01-08 12:20:24.979 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:24.979 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:24.979 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:24.980 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:24.980 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:25.269 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:25.269 | DTC Client socket (2) | Closed.
2025-01-08 12:20:26.975 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:26.975 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:26.975 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:26.976 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:26.976 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:26.976 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:27.271 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:27.271 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:27.272 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:27.272 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Failed connections: 2980
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:28.373 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:28.373 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:28.374 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:28.667 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:28.667 | DTC Client socket (2) | Closed.
2025-01-08 12:20:30.372 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:30.372 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:30.372 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:30.373 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:30.374 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:30.374 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:30.666 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:30.666 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:30.666 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:30.666 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:31.761 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:31.761 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:31.761 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:31.761 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:31.761 | Rithmic Direct - DTC (Data) | Failed connections: 2981
2025-01-08 12:20:31.761 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:31.762 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:31.762 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:31.762 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:31.762 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:32.053 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:32.053 | DTC Client socket (2) | Closed.
2025-01-08 12:20:33.760 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:33.761 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:33.761 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:33.761 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:33.761 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:33.761 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:34.003 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:34.003 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:34.003 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:34.003 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:34.960 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:34.960 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:34.960 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:34.960 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:34.960 | Rithmic Direct - DTC (Data) | Failed connections: 2982
2025-01-08 12:20:34.960 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:34.961 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:34.961 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:34.961 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:34.961 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:35.202 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:35.202 | DTC Client socket (2) | Closed.
2025-01-08 12:20:36.960 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:36.960 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:36.960 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:36.961 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:36.961 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:36.961 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:37.250 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:37.250 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:37.250 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:37.250 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Failed connections: 2983
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:38.337 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:38.337 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:38.337 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:38.625 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:38.625 | DTC Client socket (2) | Closed.
2025-01-08 12:20:40.334 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:40.334 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:40.334 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:40.335 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:40.335 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:40.335 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:40.577 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:40.577 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:40.577 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:40.577 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:41.529 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:41.529 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:41.529 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:41.529 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:41.529 | Rithmic Direct - DTC (Data) | Failed connections: 2984
2025-01-08 12:20:41.529 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:41.530 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:41.530 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:41.530 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:41.530 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:41.772 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:41.772 | DTC Client socket (2) | Closed.
2025-01-08 12:20:43.199 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048
2025-01-08 12:20:43.200 | DTC Client socket (2) | Creating socket.
2025-01-08 12:20:43.200 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:43.200 | DTC Client socket (2) | Connecting to IP: 67.214.125.4.
2025-01-08 12:20:43.366 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:20:43.366 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:20:43.366 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:20:43.526 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:43.526 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:43.526 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:43.527 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:43.527 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:20:43.527 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:43.552 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:20:43.552 | Denali Data Feed | Sending logon request message.
2025-01-08 12:20:43.816 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:43.816 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:43.816 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:43.816 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:44.101 | Denali Data Feed | Received logon response.
2025-01-08 12:20:44.101 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:20:44.101 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:44.101 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:20:44.101 | Denali Data Feed | Failed connections: 212
2025-01-08 12:20:44.101 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:20:44.102 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:44.102 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:20:44.102 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:20:44.102 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:44.264 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:44.264 | DTC Client socket (2) | Closed.
2025-01-08 12:20:44.928 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:44.928 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:44.928 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:44.928 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:44.928 | Rithmic Direct - DTC (Data) | Failed connections: 2985
2025-01-08 12:20:44.928 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:44.929 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:20:44.929 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:44.929 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:44.929 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:45.219 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:20:45.219 | DTC Client socket (3) | Closed.
2025-01-08 12:20:46.936 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:46.936 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:46.936 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:46.937 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:46.937 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:46.937 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:47.243 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:47.243 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:47.243 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:47.243 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:48.340 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:48.340 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:48.340 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:48.340 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:48.340 | Rithmic Direct - DTC (Data) | Failed connections: 2986
2025-01-08 12:20:48.340 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:48.341 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:48.341 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:48.341 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:48.341 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:48.634 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:48.634 | DTC Client socket (2) | Closed.
2025-01-08 12:20:50.344 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:50.344 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:50.344 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:50.345 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:50.346 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:50.346 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:50.639 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:50.639 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:50.640 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:50.640 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:51.740 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:51.740 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:51.740 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:51.740 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:51.740 | Rithmic Direct - DTC (Data) | Failed connections: 2987
2025-01-08 12:20:51.740 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:51.741 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:51.741 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:51.741 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:51.741 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:52.036 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:52.037 | DTC Client socket (2) | Closed.
2025-01-08 12:20:53.745 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:53.745 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:53.745 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:53.746 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:53.746 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:53.746 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:53.996 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:53.996 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:53.996 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:53.996 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:54.966 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:54.966 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:54.966 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:54.966 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:54.966 | Rithmic Direct - DTC (Data) | Failed connections: 2988
2025-01-08 12:20:54.966 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:54.967 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:54.967 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:54.967 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:54.967 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:55.216 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:55.216 | DTC Client socket (2) | Closed.
2025-01-08 12:20:56.959 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:20:56.959 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:20:56.959 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:20:56.960 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:20:56.961 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:20:56.961 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:20:57.204 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:20:57.204 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:20:57.204 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:20:57.204 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:20:58.154 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:20:58.154 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:20:58.154 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:20:58.154 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:20:58.154 | Rithmic Direct - DTC (Data) | Failed connections: 2989
2025-01-08 12:20:58.154 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:20:58.155 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:20:58.155 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:20:58.155 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:20:58.155 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:20:58.399 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:20:58.399 | DTC Client socket (2) | Closed.
2025-01-08 12:21:00.157 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:00.157 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:00.157 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:00.157 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:00.157 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:00.157 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:00.404 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:00.404 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:00.404 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:00.404 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:01.359 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:01.359 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:01.359 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:01.359 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:01.359 | Rithmic Direct - DTC (Data) | Failed connections: 2990
2025-01-08 12:21:01.359 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:01.360 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:01.360 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:01.360 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:01.360 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:01.603 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:01.603 | DTC Client socket (2) | Closed.
2025-01-08 12:21:03.352 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:03.352 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:03.352 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:03.352 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:03.352 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:03.352 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:03.644 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:03.644 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:03.644 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:03.644 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:04.743 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:04.743 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:04.743 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:04.743 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:04.743 | Rithmic Direct - DTC (Data) | Failed connections: 2991
2025-01-08 12:21:04.743 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:04.744 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:04.744 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:04.744 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:04.744 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:05.035 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:05.035 | DTC Client socket (2) | Closed.
2025-01-08 12:21:06.740 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:06.740 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:06.740 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:06.741 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:06.741 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:06.741 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:07.042 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:07.042 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:07.042 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:07.042 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:08.174 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:08.174 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:08.174 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:08.174 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:08.174 | Rithmic Direct - DTC (Data) | Failed connections: 2992
2025-01-08 12:21:08.174 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:08.175 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:08.175 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:08.175 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:08.175 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:08.476 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:08.476 | DTC Client socket (2) | Closed.
2025-01-08 12:21:10.180 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:10.180 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:10.180 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:10.181 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:10.181 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:10.181 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:10.472 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:10.472 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:10.472 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:10.472 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:11.566 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:11.566 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:11.566 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:11.566 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:11.566 | Rithmic Direct - DTC (Data) | Failed connections: 2993
2025-01-08 12:21:11.566 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:11.567 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:11.567 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:11.567 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:11.567 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:11.859 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:11.859 | DTC Client socket (2) | Closed.
2025-01-08 12:21:13.576 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:13.576 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:13.576 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:13.577 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:13.577 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:13.577 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:13.821 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:13.821 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:13.821 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:13.821 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Failed connections: 2994
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:14.771 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:14.771 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:14.771 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:15.016 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:15.016 | DTC Client socket (2) | Closed.
2025-01-08 12:21:16.779 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:16.779 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:16.779 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:16.780 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:16.781 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:16.781 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:17.082 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:17.082 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:17.082 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:17.082 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:18.228 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:18.228 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:18.228 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:18.228 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:18.228 | Rithmic Direct - DTC (Data) | Failed connections: 2995
2025-01-08 12:21:18.228 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:18.229 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:18.229 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:18.229 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:18.229 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:18.530 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:18.530 | DTC Client socket (2) | Closed.
2025-01-08 12:21:20.237 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:20.237 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:20.237 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:20.237 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:20.238 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:20.238 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:20.531 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:20.531 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:20.531 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:20.531 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:21.638 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:21.638 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:21.638 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:21.638 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:21.638 | Rithmic Direct - DTC (Data) | Failed connections: 2996
2025-01-08 12:21:21.638 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:21.639 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:21.639 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:21.639 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:21.639 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:21.933 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:21.933 | DTC Client socket (2) | Closed.
2025-01-08 12:21:23.633 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:23.633 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:23.633 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:23.634 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:23.635 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:23.635 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:23.935 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:23.935 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:23.935 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:23.935 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Failed connections: 2997
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:25.057 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:25.057 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:25.058 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:25.358 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:25.358 | DTC Client socket (2) | Closed.
2025-01-08 12:21:27.061 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:27.061 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:27.061 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:27.062 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:27.062 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:27.062 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:27.351 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:27.351 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:27.351 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:27.351 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Failed connections: 2998
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:28.437 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:28.437 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:28.437 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:28.727 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:28.727 | DTC Client socket (2) | Closed.
2025-01-08 12:21:30.430 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:30.430 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:30.430 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:30.431 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:30.431 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:30.431 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:30.730 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:30.730 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:30.730 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:30.730 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Failed connections: 2999
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:31.839 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:31.839 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:31.840 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:32.139 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:32.139 | DTC Client socket (2) | Closed.
2025-01-08 12:21:33.845 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:33.846 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:33.846 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:33.847 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:33.847 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:33.847 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:34.084 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:34.084 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:34.085 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:34.085 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:35.009 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:35.009 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:35.009 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:35.009 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:35.009 | Rithmic Direct - DTC (Data) | Failed connections: 3000
2025-01-08 12:21:35.009 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:35.010 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:35.010 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:35.010 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:35.010 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:35.245 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:35.245 | DTC Client socket (2) | Closed.
2025-01-08 12:21:37.008 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:37.009 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:37.009 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:37.009 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:37.009 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:37.009 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:37.301 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:37.301 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:37.301 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:37.301 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:38.394 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:38.394 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:38.394 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:38.394 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:38.394 | Rithmic Direct - DTC (Data) | Failed connections: 3001
2025-01-08 12:21:38.394 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:38.395 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:38.395 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:38.395 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:38.395 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:38.686 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:38.686 | DTC Client socket (2) | Closed.
2025-01-08 12:21:40.407 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:40.407 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:40.407 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:40.408 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:40.408 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:40.408 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:40.712 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:40.712 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:40.712 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:40.712 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:41.832 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:41.832 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:41.832 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:41.832 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:41.832 | Rithmic Direct - DTC (Data) | Failed connections: 3002
2025-01-08 12:21:41.832 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:41.833 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:41.833 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:41.833 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:41.833 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:42.134 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:42.134 | DTC Client socket (2) | Closed.
2025-01-08 12:21:43.838 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:43.838 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:43.838 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:43.839 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:43.839 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:43.839 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:44.103 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048
2025-01-08 12:21:44.124 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:44.124 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:44.124 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:44.124 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:44.232 | DTC Client socket (3) | Creating socket.
2025-01-08 12:21:44.232 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:21:44.232 | DTC Client socket (3) | Connecting to IP: 64.152.155.18.
2025-01-08 12:21:44.479 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:21:44.479 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:21:44.479 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:21:44.662 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:21:44.662 | Denali Data Feed | Sending logon request message.
2025-01-08 12:21:45.389 | DTC Client socket (3) | Socket gracefully closed by remote side. | Number times message added: 1
2025-01-08 12:21:45.499 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:21:45.499 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-01-08 12:21:45.499 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-01-08 12:21:45.499 | DTC Client socket (3) | Closed.
2025-01-08 12:21:45.500 | Denali Data Feed | Failed connections: 213
2025-01-08 12:21:45.500 | DTC Client socket (0) | CloseSocket call.
2025-01-08 12:21:45.500 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:21:45.500 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 12:21:46.052 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:46.052 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:46.052 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:46.052 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:46.052 | Rithmic Direct - DTC (Data) | Failed connections: 3003
2025-01-08 12:21:46.052 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:46.053 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:46.053 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:46.053 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:46.053 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:46.335 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:46.336 | DTC Client socket (2) | Closed.
2025-01-08 12:21:48.063 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:48.063 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:48.063 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:48.065 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:48.065 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:48.065 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:48.358 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:48.358 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:48.359 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:48.359 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:48.496 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048
2025-01-08 12:21:48.496 | DTC Client socket (3) | Creating socket.
2025-01-08 12:21:48.496 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:21:48.496 | DTC Client socket (3) | Connecting to IP: 208.185.224.131.
2025-01-08 12:21:48.654 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:21:48.654 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:21:48.654 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:21:48.829 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:21:48.829 | Denali Data Feed | Sending logon request message.
2025-01-08 12:21:48.999 | Denali Data Feed | Received logon response.
2025-01-08 12:21:48.999 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:21:48.999 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:48.999 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary.
2025-01-08 12:21:48.999 | Denali Data Feed | Failed connections: 214
2025-01-08 12:21:48.999 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:21:48.999 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:21:48.999 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:21:48.999 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 12:21:48.999 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:49.156 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:21:49.156 | DTC Client socket (3) | Closed.
2025-01-08 12:21:49.455 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:49.455 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:49.455 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:49.455 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:49.455 | Rithmic Direct - DTC (Data) | Failed connections: 3004
2025-01-08 12:21:49.455 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:49.456 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:49.456 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:49.456 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:49.456 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:49.749 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:49.749 | DTC Client socket (2) | Closed.
2025-01-08 12:21:51.466 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:51.466 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:51.466 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:51.467 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:51.467 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:51.467 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:51.826 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:51.826 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:51.827 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:51.827 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:52.144 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:21:52.144 | DTC Client socket (3) | Creating socket.
2025-01-08 12:21:52.144 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:21:52.144 | DTC Client socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:21:52.304 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:21:52.304 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:21:52.304 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:21:52.469 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:21:52.469 | Denali Data Feed | Sending logon request message.
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Failed connections: 3005
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:53.007 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:53.007 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:53.007 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:53.009 | Denali Data Feed | Received logon response.
2025-01-08 12:21:53.009 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:21:53.009 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:53.009 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:21:53.009 | Denali Data Feed | Failed connections: 215
2025-01-08 12:21:53.009 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:21:53.010 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:21:53.010 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:21:53.010 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:21:53.010 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:53.169 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:21:53.169 | DTC Client socket (3) | Closed.
2025-01-08 12:21:53.254 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:53.254 | DTC Client socket (2) | Closed.
2025-01-08 12:21:55.167 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:55.167 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:55.167 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:55.167 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:55.168 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:55.168 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:55.525 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:55.525 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:55.525 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:55.525 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:56.594 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:56.594 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:56.594 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:56.594 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:56.594 | Rithmic Direct - DTC (Data) | Failed connections: 3006
2025-01-08 12:21:56.594 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:56.595 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:56.595 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:56.595 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:56.595 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:21:56.845 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:21:56.845 | DTC Client socket (2) | Closed.
2025-01-08 12:21:58.585 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:21:58.585 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:21:58.585 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:21:58.586 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:21:58.586 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:21:58.586 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:21:58.833 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:21:58.833 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:21:58.833 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:21:58.833 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:21:59.792 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:21:59.792 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:21:59.792 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:21:59.792 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:21:59.792 | Rithmic Direct - DTC (Data) | Failed connections: 3007
2025-01-08 12:21:59.792 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:21:59.793 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:21:59.793 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:21:59.793 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:21:59.793 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:00.042 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:00.042 | DTC Client socket (2) | Closed.
2025-01-08 12:22:01.789 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:01.789 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:01.789 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:01.790 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:01.790 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:01.790 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:02.088 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:02.088 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:02.088 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:02.089 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:03.205 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:03.205 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:03.205 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:03.205 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:03.205 | Rithmic Direct - DTC (Data) | Failed connections: 3008
2025-01-08 12:22:03.205 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:03.206 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:03.206 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:03.206 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:03.206 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:03.504 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:03.504 | DTC Client socket (2) | Closed.
2025-01-08 12:22:05.216 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:05.216 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:05.216 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:05.216 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:05.217 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:05.217 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:05.734 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:05.734 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:05.735 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:05.735 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:06.670 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:06.670 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:06.670 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:06.670 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:06.670 | Rithmic Direct - DTC (Data) | Failed connections: 3009
2025-01-08 12:22:06.670 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:06.670 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:06.671 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:06.671 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:06.671 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:06.910 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:06.910 | DTC Client socket (2) | Closed.
2025-01-08 12:22:08.668 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:08.668 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:08.668 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:08.669 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:08.669 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:08.669 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:08.966 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:08.966 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:08.966 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:08.966 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:10.067 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:10.067 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:10.067 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:10.067 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:10.067 | Rithmic Direct - DTC (Data) | Failed connections: 3010
2025-01-08 12:22:10.067 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:10.068 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:10.068 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:10.068 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:10.068 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:10.363 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:10.363 | DTC Client socket (2) | Closed.
2025-01-08 12:22:12.070 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:12.070 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:12.070 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:12.070 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:12.071 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:12.071 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:12.312 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:12.312 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:12.312 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:12.312 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:13.264 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:13.264 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:13.264 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:13.264 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:13.264 | Rithmic Direct - DTC (Data) | Failed connections: 3011
2025-01-08 12:22:13.264 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:13.265 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:13.265 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:13.265 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:13.265 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:13.505 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:13.505 | DTC Client socket (2) | Closed.
2025-01-08 12:22:15.557 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:15.557 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:15.557 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:15.557 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:15.557 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:15.557 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:15.807 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:15.807 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:15.807 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:15.807 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:16.773 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:16.773 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:16.773 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:16.773 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:16.773 | Rithmic Direct - DTC (Data) | Failed connections: 3012
2025-01-08 12:22:16.773 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:16.774 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:16.774 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:16.774 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:16.774 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:17.024 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:17.024 | DTC Client socket (2) | Closed.
2025-01-08 12:22:18.813 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:18.813 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:18.813 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:18.814 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:18.815 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:18.815 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:19.123 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:19.123 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:19.123 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:19.123 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:20.338 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:20.338 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:20.338 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:20.338 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:20.338 | Rithmic Direct - DTC (Data) | Failed connections: 3013
2025-01-08 12:22:20.338 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:20.339 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:20.339 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:20.339 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:20.339 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:20.641 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:20.641 | DTC Client socket (2) | Closed.
2025-01-08 12:22:22.336 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:22.336 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:22.336 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:22.337 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:22.337 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:22.337 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:22.927 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:22.927 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:22.927 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:22.927 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Failed connections: 3014
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:24.173 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:24.173 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:24.173 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:24.470 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:24.470 | DTC Client socket (2) | Closed.
2025-01-08 12:22:26.164 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:26.164 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:26.164 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:26.164 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:26.164 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:26.164 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:26.408 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:26.408 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:26.408 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:26.408 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:27.506 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:27.506 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:27.506 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:27.506 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:27.506 | Rithmic Direct - DTC (Data) | Failed connections: 3015
2025-01-08 12:22:27.506 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:27.507 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:27.507 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:27.507 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:27.507 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:27.751 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:27.751 | DTC Client socket (2) | Closed.
2025-01-08 12:22:29.510 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:29.510 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:29.510 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:29.517 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:29.517 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:29.517 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:29.801 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:29.801 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:29.801 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:29.801 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:30.783 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:30.783 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:30.783 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:30.783 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:30.783 | Rithmic Direct - DTC (Data) | Failed connections: 3016
2025-01-08 12:22:30.783 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:30.784 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:30.784 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:30.785 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:30.785 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:31.062 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:31.062 | DTC Client socket (2) | Closed.
2025-01-08 12:22:32.987 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:32.987 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:32.987 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:32.988 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:32.988 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:32.988 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:33.276 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:33.276 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:33.277 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:33.277 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Failed connections: 3017
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:34.360 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:34.360 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:34.360 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:34.649 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:34.649 | DTC Client socket (2) | Closed.
2025-01-08 12:22:36.346 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:36.346 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:36.346 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:36.347 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:36.347 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:36.347 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:36.750 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:36.750 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:36.750 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:36.750 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:37.840 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:37.840 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:37.840 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:37.840 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:37.840 | Rithmic Direct - DTC (Data) | Failed connections: 3018
2025-01-08 12:22:37.840 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:37.841 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:37.842 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:37.842 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:37.842 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:38.131 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:38.131 | DTC Client socket (2) | Closed.
2025-01-08 12:22:39.842 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:39.842 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:39.842 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:39.843 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:39.843 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:39.843 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:40.135 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:40.135 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:40.135 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:40.135 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:41.241 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:41.241 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:41.241 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:41.241 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:41.241 | Rithmic Direct - DTC (Data) | Failed connections: 3019
2025-01-08 12:22:41.241 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:41.241 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:41.242 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:41.242 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:41.242 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:41.535 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:41.535 | DTC Client socket (2) | Closed.
2025-01-08 12:22:43.253 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:43.253 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:43.253 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:43.253 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:43.254 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:43.254 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:43.495 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:43.495 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:43.495 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:43.495 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:44.452 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:44.452 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:44.452 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:44.452 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:44.452 | Rithmic Direct - DTC (Data) | Failed connections: 3020
2025-01-08 12:22:44.453 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:44.453 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:44.453 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:44.453 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:44.453 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:44.695 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:44.695 | DTC Client socket (2) | Closed.
2025-01-08 12:22:46.775 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:46.775 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:46.775 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:46.776 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:46.777 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:46.777 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:47.026 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:47.026 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:47.026 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:47.026 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:48.016 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:48.016 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:48.016 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:48.016 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:48.016 | Rithmic Direct - DTC (Data) | Failed connections: 3021
2025-01-08 12:22:48.017 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:48.018 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:48.018 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:48.018 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:48.018 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:48.268 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:48.269 | DTC Client socket (2) | Closed.
2025-01-08 12:22:50.019 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:50.019 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:50.019 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:50.020 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:50.020 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:50.020 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:50.317 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:50.317 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:50.317 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:50.317 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:51.419 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:51.419 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:51.419 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:51.419 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:51.419 | Rithmic Direct - DTC (Data) | Failed connections: 3022
2025-01-08 12:22:51.420 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:51.421 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:51.421 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:51.421 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:51.421 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:51.716 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:51.716 | DTC Client socket (2) | Closed.
2025-01-08 12:22:53.381 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-01-08 12:22:53.382 | DTC Client socket (2) | Creating socket.
2025-01-08 12:22:53.382 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:53.382 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-01-08 12:22:53.412 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:53.413 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:53.413 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:53.413 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:53.414 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:22:53.414 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:53.717 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:22:53.717 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:22:53.717 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:22:53.720 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:53.720 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:53.720 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:53.720 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:53.904 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:22:53.904 | Denali Data Feed | Sending logon request message.
2025-01-08 12:22:54.436 | Denali Data Feed | Received logon response.
2025-01-08 12:22:54.436 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:22:54.436 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:54.436 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:22:54.436 | Denali Data Feed | Failed connections: 216
2025-01-08 12:22:54.437 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:22:54.437 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:54.438 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:54.438 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:22:54.438 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:22:54.596 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:54.596 | DTC Client socket (2) | Closed.
2025-01-08 12:22:54.784 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:54.784 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:54.784 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:54.784 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:54.784 | Rithmic Direct - DTC (Data) | Failed connections: 3023
2025-01-08 12:22:54.784 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:54.785 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:22:54.785 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:54.785 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:54.785 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:55.067 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:22:55.067 | DTC Client socket (3) | Closed.
2025-01-08 12:22:56.784 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:22:56.785 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:22:56.785 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:22:56.786 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:22:56.786 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:22:56.786 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:22:57.080 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:22:57.080 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:22:57.080 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:22:57.080 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:22:58.180 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:22:58.180 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:22:58.180 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:22:58.180 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:22:58.180 | Rithmic Direct - DTC (Data) | Failed connections: 3024
2025-01-08 12:22:58.180 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:22:58.180 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:22:58.180 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:22:58.181 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:22:58.181 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:22:58.474 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:22:58.474 | DTC Client socket (2) | Closed.
2025-01-08 12:23:00.180 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:00.180 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:00.180 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:00.181 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:00.181 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:00.181 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:00.475 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:00.475 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:00.475 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:00.475 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:01.572 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:01.572 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:01.572 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:01.572 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:01.572 | Rithmic Direct - DTC (Data) | Failed connections: 3025
2025-01-08 12:23:01.572 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:01.573 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:01.573 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:01.573 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:01.573 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:01.867 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:01.867 | DTC Client socket (2) | Closed.
2025-01-08 12:23:03.569 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:03.569 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:03.569 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:03.570 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:03.570 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:23:03.570 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:03.867 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:03.867 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:03.867 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:03.867 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:04.975 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:04.975 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:04.975 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:04.975 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:04.975 | Rithmic Direct - DTC (Data) | Failed connections: 3026
2025-01-08 12:23:04.975 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:04.976 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:23:04.976 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:04.976 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:04.976 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:05.272 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:23:05.272 | DTC Client socket (3) | Closed.
2025-01-08 12:23:06.975 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:06.975 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:06.975 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:06.976 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:06.976 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:06.976 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:07.221 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:07.221 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:07.222 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:07.222 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:08.170 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:08.170 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:08.170 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:08.170 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:08.170 | Rithmic Direct - DTC (Data) | Failed connections: 3027
2025-01-08 12:23:08.171 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:08.171 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:08.171 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:08.171 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:08.171 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:08.416 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:08.416 | DTC Client socket (2) | Closed.
2025-01-08 12:23:10.167 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:10.167 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:10.167 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:10.168 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:10.168 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:10.168 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:10.461 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:10.461 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:10.461 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:10.461 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:11.557 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:11.557 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:11.557 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:11.557 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:11.558 | Rithmic Direct - DTC (Data) | Failed connections: 3028
2025-01-08 12:23:11.558 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:11.558 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:11.558 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:11.558 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:11.558 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:11.851 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:11.851 | DTC Client socket (2) | Closed.
2025-01-08 12:23:13.556 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:13.556 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:13.556 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:13.557 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:13.557 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:13.557 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:13.803 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:13.803 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:13.803 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:13.803 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Failed connections: 3029
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:14.756 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:14.756 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:14.756 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:15.002 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:15.002 | DTC Client socket (2) | Closed.
2025-01-08 12:23:16.766 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:16.766 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:16.766 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:16.767 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:16.767 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:16.767 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:17.063 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:17.063 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:17.063 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:17.063 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:18.164 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:18.164 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:18.164 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:18.164 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:18.164 | Rithmic Direct - DTC (Data) | Failed connections: 3030
2025-01-08 12:23:18.164 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:18.165 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:18.165 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:18.165 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:18.165 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:18.459 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:18.459 | DTC Client socket (2) | Closed.
2025-01-08 12:23:20.159 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:20.160 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:20.160 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:20.161 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:20.161 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:20.161 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:20.454 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:20.454 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:20.454 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:20.454 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:21.549 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:21.549 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:21.549 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:21.549 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:21.549 | Rithmic Direct - DTC (Data) | Failed connections: 3031
2025-01-08 12:23:21.549 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:21.550 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:21.550 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:21.550 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:21.550 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:21.842 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:21.842 | DTC Client socket (2) | Closed.
2025-01-08 12:23:23.554 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:23.554 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:23.554 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:23.554 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:23.554 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:23.555 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:23.849 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:23.849 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:23.849 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:23.849 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:25.153 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:25.153 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:25.153 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:25.153 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:25.153 | Rithmic Direct - DTC (Data) | Failed connections: 3032
2025-01-08 12:23:25.153 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:25.154 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:25.154 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:25.154 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:25.154 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:25.453 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:25.454 | DTC Client socket (2) | Closed.
2025-01-08 12:23:27.152 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:27.152 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:27.152 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:27.153 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:27.154 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:27.154 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:27.448 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:27.448 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:27.448 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:27.448 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:28.811 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:28.811 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:28.811 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:28.811 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:28.811 | Rithmic Direct - DTC (Data) | Failed connections: 3033
2025-01-08 12:23:28.811 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:28.812 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:28.812 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:28.812 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:28.812 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:29.106 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:29.106 | DTC Client socket (2) | Closed.
2025-01-08 12:23:31.012 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:31.012 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:31.012 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:31.012 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:31.012 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:31.012 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:31.305 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:31.305 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:31.305 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:31.305 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:32.398 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:32.398 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:32.398 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:32.398 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:32.398 | Rithmic Direct - DTC (Data) | Failed connections: 3034
2025-01-08 12:23:32.398 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:32.399 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:32.399 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:32.399 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:32.399 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:32.692 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:32.692 | DTC Client socket (2) | Closed.
2025-01-08 12:23:34.406 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:34.406 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:34.406 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:34.407 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:34.407 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:34.407 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:34.706 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:34.706 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:34.706 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:34.706 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:35.816 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:35.816 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:35.816 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:35.816 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:35.816 | Rithmic Direct - DTC (Data) | Failed connections: 3035
2025-01-08 12:23:35.816 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:35.817 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:35.817 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:35.817 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:35.817 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:36.115 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:36.115 | DTC Client socket (2) | Closed.
2025-01-08 12:23:37.821 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:37.821 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:37.821 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:37.822 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:37.822 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:37.822 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:38.302 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:38.302 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:38.302 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:38.302 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:39.447 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:39.447 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:39.447 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:39.447 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:39.447 | Rithmic Direct - DTC (Data) | Failed connections: 3036
2025-01-08 12:23:39.448 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:39.448 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:39.448 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:39.448 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:39.448 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:39.741 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:39.741 | DTC Client socket (2) | Closed.
2025-01-08 12:23:41.458 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:41.458 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:41.458 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:41.459 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:41.459 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:41.459 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:41.698 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:41.699 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:41.699 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:41.699 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:42.634 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:42.634 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:42.634 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:42.634 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:42.634 | Rithmic Direct - DTC (Data) | Failed connections: 3037
2025-01-08 12:23:42.634 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:42.635 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:42.635 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:42.635 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:42.635 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:42.877 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:42.877 | DTC Client socket (2) | Closed.
2025-01-08 12:23:44.629 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:44.630 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:44.630 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:44.631 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:44.631 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:44.631 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:44.919 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:44.919 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:44.920 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:44.920 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:46.002 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:46.002 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:46.002 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:46.002 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:46.002 | Rithmic Direct - DTC (Data) | Failed connections: 3038
2025-01-08 12:23:46.002 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:46.003 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:46.003 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:46.003 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:46.003 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:46.291 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:46.291 | DTC Client socket (2) | Closed.
2025-01-08 12:23:48.008 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:48.008 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:48.009 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:48.009 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:48.010 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:48.010 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:48.259 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:48.259 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:48.259 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:48.259 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:49.224 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:49.224 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:49.224 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:49.224 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:49.224 | Rithmic Direct - DTC (Data) | Failed connections: 3039
2025-01-08 12:23:49.224 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:49.224 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:49.225 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:49.225 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:49.225 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:49.473 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:49.473 | DTC Client socket (2) | Closed.
2025-01-08 12:23:51.231 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:51.231 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:51.231 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:51.232 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:51.232 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:51.232 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:51.472 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:51.472 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:51.472 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:51.472 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:52.408 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:52.408 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:52.408 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:52.408 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:52.408 | Rithmic Direct - DTC (Data) | Failed connections: 3040
2025-01-08 12:23:52.408 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:52.409 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:52.409 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:52.409 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:52.409 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:52.648 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:52.648 | DTC Client socket (2) | Closed.
2025-01-08 12:23:54.558 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:54.558 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:54.558 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:54.558 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:23:54.558 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:54.558 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:54.558 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:54.559 | DTC Client socket (3) | Creating socket.
2025-01-08 12:23:54.559 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:23:54.559 | DTC Client socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:23:54.723 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:23:54.723 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:23:54.723 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:23:54.803 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:54.803 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:54.803 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:54.803 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:54.892 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:23:54.892 | Denali Data Feed | Sending logon request message.
2025-01-08 12:23:55.438 | Denali Data Feed | Received logon response.
2025-01-08 12:23:55.438 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:23:55.438 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:55.438 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:23:55.438 | Denali Data Feed | Failed connections: 217
2025-01-08 12:23:55.438 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:23:55.439 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:23:55.439 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:55.439 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:23:55.439 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:23:55.601 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:23:55.601 | DTC Client socket (3) | Closed.
2025-01-08 12:23:55.754 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:55.754 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:55.754 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:55.754 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:55.754 | Rithmic Direct - DTC (Data) | Failed connections: 3041
2025-01-08 12:23:55.754 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:55.755 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:55.755 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:55.755 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:55.755 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:55.999 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:55.999 | DTC Client socket (2) | Closed.
2025-01-08 12:23:57.790 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:23:57.790 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:23:57.790 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:23:57.791 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:23:57.792 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:23:57.792 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:23:58.082 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:23:58.082 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:23:58.082 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:23:58.082 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Failed connections: 3042
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:23:59.174 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:23:59.174 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:23:59.175 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:23:59.462 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:23:59.462 | DTC Client socket (2) | Closed.
2025-01-08 12:24:01.184 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:01.184 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:01.184 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:01.185 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:01.185 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:01.185 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:01.476 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:01.476 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:01.476 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:01.476 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:02.579 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:02.579 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:02.579 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:02.579 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:02.579 | Rithmic Direct - DTC (Data) | Failed connections: 3043
2025-01-08 12:24:02.579 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:02.580 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:02.581 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:02.581 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:02.581 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:02.872 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:02.872 | DTC Client socket (2) | Closed.
2025-01-08 12:24:04.591 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:04.591 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:04.591 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:04.592 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:04.592 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:04.592 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:04.830 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:04.830 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:04.831 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:04.831 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:05.759 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:05.759 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:05.759 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:05.759 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:05.759 | Rithmic Direct - DTC (Data) | Failed connections: 3044
2025-01-08 12:24:05.759 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:05.760 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:05.760 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:05.760 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:05.760 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:05.996 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:05.996 | DTC Client socket (2) | Closed.
2025-01-08 12:24:07.777 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:07.777 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:07.777 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:07.778 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:07.779 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:07.779 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:08.023 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:08.023 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:08.024 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:08.024 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:08.974 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:08.974 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:08.974 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:08.974 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:08.974 | Rithmic Direct - DTC (Data) | Failed connections: 3045
2025-01-08 12:24:08.974 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:08.975 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:08.975 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:08.975 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:08.975 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:09.219 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:09.219 | DTC Client socket (2) | Closed.
2025-01-08 12:24:10.986 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:10.986 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:10.986 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:10.987 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:10.988 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:10.988 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:11.238 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:11.238 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:11.239 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:11.239 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:12.193 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:12.193 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:12.193 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:12.193 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:12.193 | Rithmic Direct - DTC (Data) | Failed connections: 3046
2025-01-08 12:24:12.193 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:12.194 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:12.194 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:12.194 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:12.194 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:12.437 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:12.437 | DTC Client socket (2) | Closed.
2025-01-08 12:24:14.198 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:14.198 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:14.198 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:14.199 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:14.199 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:14.199 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:14.497 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:14.497 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:14.497 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:14.497 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:15.605 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:15.605 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:15.605 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:15.605 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:15.605 | Rithmic Direct - DTC (Data) | Failed connections: 3047
2025-01-08 12:24:15.605 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:15.606 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:15.606 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:15.606 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:15.606 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:15.894 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:15.895 | DTC Client socket (2) | Closed.
2025-01-08 12:24:17.605 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:17.605 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:17.605 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:17.606 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:17.606 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:17.606 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:17.889 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:17.889 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:17.889 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:17.889 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:19.571 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:19.571 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:19.571 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:19.571 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:19.571 | Rithmic Direct - DTC (Data) | Failed connections: 3048
2025-01-08 12:24:19.572 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:19.572 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:19.572 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:19.572 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:19.572 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:19.854 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:19.854 | DTC Client socket (2) | Closed.
2025-01-08 12:24:21.574 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:21.574 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:21.574 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:21.574 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:21.574 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:21.575 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:21.811 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:21.811 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:21.811 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:21.811 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:22.736 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:22.736 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:22.736 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:22.736 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:22.736 | Rithmic Direct - DTC (Data) | Failed connections: 3049
2025-01-08 12:24:22.736 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:22.737 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:22.737 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:22.737 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:22.737 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:22.972 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:22.972 | DTC Client socket (2) | Closed.
2025-01-08 12:24:24.741 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:24.741 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:24.741 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:24.742 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:24.742 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:24.742 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:25.042 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:25.042 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:25.042 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:25.042 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:26.173 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:26.173 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:26.173 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:26.173 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:26.173 | Rithmic Direct - DTC (Data) | Failed connections: 3050
2025-01-08 12:24:26.173 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:26.174 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:26.174 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:26.174 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:26.174 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:26.472 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:26.472 | DTC Client socket (2) | Closed.
2025-01-08 12:24:28.182 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:28.182 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:28.182 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:28.183 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:28.183 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:28.183 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:28.473 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:28.473 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:28.473 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:28.473 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:29.561 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:29.561 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:29.561 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:29.561 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:29.561 | Rithmic Direct - DTC (Data) | Failed connections: 3051
2025-01-08 12:24:29.561 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:29.562 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:29.562 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:29.562 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:29.562 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:29.853 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:29.853 | DTC Client socket (2) | Closed.
2025-01-08 12:24:31.555 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:31.555 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:31.555 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:31.556 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:31.556 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:31.556 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:31.836 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:31.836 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:31.836 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:31.836 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:32.897 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:32.897 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:32.897 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:32.897 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:32.897 | Rithmic Direct - DTC (Data) | Failed connections: 3052
2025-01-08 12:24:32.897 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:32.898 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:32.898 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:32.898 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:32.898 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:33.180 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:33.180 | DTC Client socket (2) | Closed.
2025-01-08 12:24:34.900 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:34.900 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:34.900 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:34.901 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:34.901 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:34.901 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:35.193 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:35.193 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:35.193 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:35.193 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:36.287 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:36.287 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:36.287 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:36.287 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:36.287 | Rithmic Direct - DTC (Data) | Failed connections: 3053
2025-01-08 12:24:36.287 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:36.288 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:36.288 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:36.289 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:36.289 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:36.580 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:36.580 | DTC Client socket (2) | Closed.
2025-01-08 12:24:38.293 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:38.294 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:38.294 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:38.295 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:38.295 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:38.295 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:38.543 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:38.543 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:38.543 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:38.543 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:39.501 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:39.501 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:39.501 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:39.501 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:39.501 | Rithmic Direct - DTC (Data) | Failed connections: 3054
2025-01-08 12:24:39.501 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:39.502 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:39.502 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:39.502 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:39.502 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:39.749 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:39.749 | DTC Client socket (2) | Closed.
2025-01-08 12:24:41.509 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:41.509 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:41.510 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:41.511 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:41.511 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:41.511 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:41.752 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:41.752 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:41.752 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:41.752 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:42.692 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:42.692 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:42.692 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:42.692 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:42.692 | Rithmic Direct - DTC (Data) | Failed connections: 3055
2025-01-08 12:24:42.692 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:42.693 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:42.693 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:42.693 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:42.693 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:42.933 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:42.933 | DTC Client socket (2) | Closed.
2025-01-08 12:24:44.694 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:44.694 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:44.694 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:44.695 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:44.695 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:44.695 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:44.985 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:44.985 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:44.985 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:44.985 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:46.074 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:46.074 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:46.074 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:46.074 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:46.074 | Rithmic Direct - DTC (Data) | Failed connections: 3056
2025-01-08 12:24:46.074 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:46.075 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:46.075 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:46.075 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:46.075 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:46.364 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:46.364 | DTC Client socket (2) | Closed.
2025-01-08 12:24:48.074 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:48.074 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:48.074 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:48.075 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:48.075 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:48.076 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:48.370 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:48.370 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:48.370 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:48.370 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:49.470 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:49.470 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:49.470 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:49.470 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:49.470 | Rithmic Direct - DTC (Data) | Failed connections: 3057
2025-01-08 12:24:49.470 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:49.471 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:49.471 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:49.471 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:49.471 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:49.764 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:49.764 | DTC Client socket (2) | Closed.
2025-01-08 12:24:51.479 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:51.479 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:51.479 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:51.480 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:51.480 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:51.480 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:51.769 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:51.769 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:51.769 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:51.769 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:51.879 | Source file does not exist when saving backup of C:\SierraChart-1\SymbolSettings\CustomSymbolSettings.rithmic_v2.trading.xml. No backup made.
2025-01-08 12:24:52.833 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:52.833 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:52.833 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:52.833 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:52.833 | Rithmic Direct - DTC (Data) | Failed connections: 3058
2025-01-08 12:24:52.833 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:52.834 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:52.834 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:52.834 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:52.834 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:53.116 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:53.116 | DTC Client socket (2) | Closed.
2025-01-08 12:24:54.840 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:54.840 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:54.840 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:54.841 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:54.842 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:54.842 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:55.100 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:55.100 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:55.100 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:55.100 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:55.447 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10048
2025-01-08 12:24:56.074 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:56.074 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:56.074 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:56.074 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:56.074 | Rithmic Direct - DTC (Data) | Failed connections: 3059
2025-01-08 12:24:56.074 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:56.075 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:56.075 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:56.075 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:56.075 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:56.325 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:24:56.325 | DTC Client socket (2) | Closed.
2025-01-08 12:24:56.384 | DTC Client socket (3) | Creating socket.
2025-01-08 12:24:56.384 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:24:56.384 | DTC Client socket (3) | Connecting to IP: 64.152.155.21.
2025-01-08 12:24:56.546 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:24:56.546 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:24:56.547 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:24:56.719 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:24:56.719 | Denali Data Feed | Sending logon request message.
2025-01-08 12:24:57.246 | Denali Data Feed | Received logon response.
2025-01-08 12:24:57.246 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:24:57.246 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:57.246 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:24:57.246 | Denali Data Feed | Failed connections: 218
2025-01-08 12:24:57.246 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:24:57.246 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:24:57.246 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:24:57.246 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:24:57.246 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:24:57.408 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:24:57.408 | DTC Client socket (3) | Closed.
2025-01-08 12:24:58.078 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:24:58.078 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:24:58.078 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:24:58.291 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:24:58.292 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:24:58.292 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:24:58.589 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:24:58.589 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:24:58.589 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:24:58.589 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:24:59.705 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:24:59.705 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:24:59.705 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:24:59.705 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:24:59.705 | Rithmic Direct - DTC (Data) | Failed connections: 3060
2025-01-08 12:24:59.705 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:24:59.706 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:24:59.706 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:24:59.706 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:24:59.706 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:00.011 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:00.011 | DTC Client socket (2) | Closed.
2025-01-08 12:25:01.707 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:01.707 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:01.707 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:01.708 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:01.708 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:01.708 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:01.989 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:01.989 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:01.989 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:01.989 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:03.054 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:03.054 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:03.054 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:03.054 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:03.054 | Rithmic Direct - DTC (Data) | Failed connections: 3061
2025-01-08 12:25:03.054 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:03.054 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:03.055 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:03.055 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:03.055 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:03.336 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:03.337 | DTC Client socket (2) | Closed.
2025-01-08 12:25:05.064 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:05.064 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:05.064 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:05.065 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:05.065 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:05.065 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:05.305 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:05.305 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:05.305 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:05.305 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:06.249 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:06.249 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:06.249 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:06.249 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:06.249 | Rithmic Direct - DTC (Data) | Failed connections: 3062
2025-01-08 12:25:06.249 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:06.250 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:06.250 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:06.250 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:06.250 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:06.490 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:06.490 | DTC Client socket (2) | Closed.
2025-01-08 12:25:08.240 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:08.240 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:08.240 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:08.241 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:08.241 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:08.241 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:08.538 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:08.538 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:08.538 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:08.538 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:09.634 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:09.634 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:09.634 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:09.634 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:09.634 | Rithmic Direct - DTC (Data) | Failed connections: 3063
2025-01-08 12:25:09.635 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:09.635 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:09.635 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:09.635 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:09.635 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:09.928 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:09.928 | DTC Client socket (2) | Closed.
2025-01-08 12:25:11.639 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:11.639 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:11.639 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:11.639 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:11.639 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:11.639 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:11.935 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:11.935 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:11.935 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:11.935 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Failed connections: 3064
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:13.037 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:13.037 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:13.037 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:13.332 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:13.332 | DTC Client socket (2) | Closed.
2025-01-08 12:25:15.048 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:15.048 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:15.048 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:15.049 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:15.050 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:15.050 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:15.334 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:15.334 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:15.334 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:15.334 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:16.401 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:16.401 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:16.401 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:16.401 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:16.401 | Rithmic Direct - DTC (Data) | Failed connections: 3065
2025-01-08 12:25:16.401 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:16.402 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:16.402 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:16.403 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:16.403 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:16.686 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:16.686 | DTC Client socket (2) | Closed.
2025-01-08 12:25:18.406 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:18.406 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:18.406 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:18.407 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:18.407 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:18.407 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:18.655 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:18.655 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:18.655 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:18.655 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:19.604 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:19.604 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:19.604 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:19.604 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:19.604 | Rithmic Direct - DTC (Data) | Failed connections: 3066
2025-01-08 12:25:19.604 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:19.605 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:19.605 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:19.605 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:19.605 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:19.845 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:19.845 | DTC Client socket (2) | Closed.
2025-01-08 12:25:21.606 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:21.606 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:21.606 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:21.607 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:21.607 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:21.607 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:21.977 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:21.977 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:21.977 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:21.977 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:23.098 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:23.098 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:23.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:23.098 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:23.098 | Rithmic Direct - DTC (Data) | Failed connections: 3067
2025-01-08 12:25:23.098 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:23.099 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:23.099 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:23.099 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:23.099 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:23.397 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:23.397 | DTC Client socket (2) | Closed.
2025-01-08 12:25:25.097 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:25.097 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:25.097 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:25.098 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:25.098 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:25.098 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:25.389 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:25.389 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:25.389 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:25.389 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Failed connections: 3068
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:26.478 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:26.478 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:26.479 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:26.768 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:26.768 | DTC Client socket (2) | Closed.
2025-01-08 12:25:28.485 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:28.485 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:28.485 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:28.494 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:28.495 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:28.495 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:28.798 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:28.798 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:28.798 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:28.798 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Failed connections: 3069
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:29.934 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:29.934 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:29.935 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:30.235 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:30.235 | DTC Client socket (2) | Closed.
2025-01-08 12:25:31.932 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:31.932 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:31.932 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:31.932 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:31.933 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:31.933 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:32.229 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:32.229 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:32.229 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:32.229 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:33.336 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:33.336 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:33.336 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:33.336 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:33.336 | Rithmic Direct - DTC (Data) | Failed connections: 3070
2025-01-08 12:25:33.336 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:33.336 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:33.337 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:33.337 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:33.337 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:33.632 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:33.632 | DTC Client socket (2) | Closed.
2025-01-08 12:25:35.333 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:35.333 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:35.333 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:35.333 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:35.333 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:35.333 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:35.625 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:35.625 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:35.625 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:35.625 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:36.726 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:36.726 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:36.726 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:36.726 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:36.726 | Rithmic Direct - DTC (Data) | Failed connections: 3071
2025-01-08 12:25:36.726 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:36.727 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:36.727 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:36.727 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:36.727 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:37.019 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:37.019 | DTC Client socket (2) | Closed.
2025-01-08 12:25:38.728 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:38.728 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:38.728 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:38.729 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:38.729 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:38.729 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:39.020 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:39.020 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:39.020 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:39.020 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:40.101 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:40.101 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:40.101 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:40.101 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:40.101 | Rithmic Direct - DTC (Data) | Failed connections: 3072
2025-01-08 12:25:40.101 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:40.102 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:40.102 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:40.102 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:40.102 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:40.382 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:40.382 | DTC Client socket (2) | Closed.
2025-01-08 12:25:42.099 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:42.099 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:42.099 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:42.100 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:42.100 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:42.100 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:42.335 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:42.335 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:42.335 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:42.335 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:43.332 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:43.332 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:43.332 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:43.332 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:43.332 | Rithmic Direct - DTC (Data) | Failed connections: 3073
2025-01-08 12:25:43.332 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:43.333 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:43.333 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:43.333 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:43.333 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:43.568 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:43.568 | DTC Client socket (2) | Closed.
2025-01-08 12:25:45.338 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:45.338 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:45.338 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:45.339 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:45.339 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:45.339 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:45.586 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:45.586 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:45.586 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:45.586 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:46.548 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:46.548 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:46.548 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:46.548 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:46.548 | Rithmic Direct - DTC (Data) | Failed connections: 3074
2025-01-08 12:25:46.548 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:46.549 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:46.549 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:46.549 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:46.549 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:46.797 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:46.797 | DTC Client socket (2) | Closed.
2025-01-08 12:25:48.564 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:48.564 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:48.564 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:48.564 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:48.564 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:48.564 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:48.888 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:48.888 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:48.888 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:48.888 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Failed connections: 3075
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:50.097 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:50.097 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:50.097 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:50.422 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:50.422 | DTC Client socket (2) | Closed.
2025-01-08 12:25:52.101 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:52.101 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:52.101 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:52.102 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:52.103 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:52.103 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:52.405 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:52.405 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:52.405 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:52.405 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:53.532 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:53.532 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:53.532 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:53.532 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:53.532 | Rithmic Direct - DTC (Data) | Failed connections: 3076
2025-01-08 12:25:53.532 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:53.533 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:53.533 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:53.533 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:53.533 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:53.835 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:53.835 | DTC Client socket (2) | Closed.
2025-01-08 12:25:55.521 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:55.521 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:55.521 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:55.522 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:55.522 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:55.522 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:55.823 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:55.823 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:55.823 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:55.823 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Failed connections: 3077
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:25:56.951 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:25:56.951 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:25:56.951 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:57.250 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443
2025-01-08 12:25:57.253 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:25:57.253 | DTC Client socket (2) | Closed.
2025-01-08 12:25:57.379 | DTC Client socket (3) | Creating socket.
2025-01-08 12:25:57.379 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:25:57.379 | DTC Client socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:25:57.539 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:25:57.539 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:25:57.540 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:25:57.716 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:25:57.716 | Denali Data Feed | Sending logon request message.
2025-01-08 12:25:58.234 | Denali Data Feed | Received logon response.
2025-01-08 12:25:58.234 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:25:58.234 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:25:58.235 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:25:58.235 | Denali Data Feed | Failed connections: 219
2025-01-08 12:25:58.235 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:25:58.235 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:25:58.235 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:25:58.236 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:25:58.236 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:25:58.395 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:25:58.395 | DTC Client socket (3) | Closed.
2025-01-08 12:25:58.950 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:25:58.950 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:25:58.950 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:25:58.951 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:25:58.951 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:25:58.951 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:25:59.279 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:25:59.279 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:25:59.279 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:25:59.279 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Failed connections: 3078
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:00.488 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:00.488 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:00.489 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:00.817 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:00.817 | DTC Client socket (2) | Closed.
2025-01-08 12:26:02.492 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:02.492 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:02.492 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:02.493 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:02.493 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:02.494 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:02.740 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:02.740 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:02.740 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:02.740 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:03.720 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:03.720 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:03.720 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:03.720 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:03.720 | Rithmic Direct - DTC (Data) | Failed connections: 3079
2025-01-08 12:26:03.721 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:03.721 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:03.721 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:03.721 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:03.721 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:03.963 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:03.963 | DTC Client socket (2) | Closed.
2025-01-08 12:26:05.727 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:05.727 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:05.727 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:05.727 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:05.728 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:05.728 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:05.972 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:05.972 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:05.972 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:05.972 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Failed connections: 3080
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:06.930 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:06.930 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:06.930 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:07.177 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:07.177 | DTC Client socket (2) | Closed.
2025-01-08 12:26:08.925 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:08.925 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:08.925 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:08.926 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:08.927 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:08.927 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:09.255 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:09.255 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:09.255 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:09.255 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:10.460 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:10.460 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:10.460 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:10.460 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:10.460 | Rithmic Direct - DTC (Data) | Failed connections: 3081
2025-01-08 12:26:10.460 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:10.461 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:10.461 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:10.461 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:10.461 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:10.789 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:10.789 | DTC Client socket (2) | Closed.
2025-01-08 12:26:12.467 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:12.467 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:12.467 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:12.468 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:12.468 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:12.468 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:12.713 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:12.713 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:12.713 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:12.713 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:13.668 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:13.668 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:13.668 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:13.668 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:13.668 | Rithmic Direct - DTC (Data) | Failed connections: 3082
2025-01-08 12:26:13.668 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:13.669 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:13.669 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:13.669 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:13.669 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:13.914 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:13.915 | DTC Client socket (2) | Closed.
2025-01-08 12:26:15.672 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:15.672 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:15.672 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:15.672 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:15.672 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:15.672 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:15.915 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:15.915 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:15.915 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:15.915 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:16.892 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:16.892 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:16.892 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:16.892 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:16.892 | Rithmic Direct - DTC (Data) | Failed connections: 3083
2025-01-08 12:26:16.892 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:16.893 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:16.893 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:16.893 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:16.893 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:17.136 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:17.136 | DTC Client socket (2) | Closed.
2025-01-08 12:26:18.903 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:18.903 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:18.903 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:18.904 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:18.904 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:18.904 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:19.201 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:19.201 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:19.201 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:19.201 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:20.323 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:20.323 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:20.323 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:20.323 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:20.323 | Rithmic Direct - DTC (Data) | Failed connections: 3084
2025-01-08 12:26:20.323 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:20.324 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:20.324 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:20.324 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:20.325 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:20.622 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:20.623 | DTC Client socket (2) | Closed.
2025-01-08 12:26:22.319 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:22.319 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:22.319 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:22.320 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:22.320 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:22.320 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:22.569 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:22.569 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:22.570 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:22.570 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:23.512 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:23.512 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:23.512 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:23.512 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:23.512 | Rithmic Direct - DTC (Data) | Failed connections: 3085
2025-01-08 12:26:23.513 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:23.516 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:23.516 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:23.516 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:23.516 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:23.756 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:23.756 | DTC Client socket (2) | Closed.
2025-01-08 12:26:25.519 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:25.519 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:25.519 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:25.520 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:25.520 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:25.520 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:25.821 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:25.821 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:25.821 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:25.821 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Failed connections: 3086
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:26.941 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:26.941 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:26.942 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:27.241 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:27.242 | DTC Client socket (2) | Closed.
2025-01-08 12:26:28.947 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:28.947 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:28.947 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:28.948 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:28.948 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:28.948 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:29.245 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:29.245 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:29.245 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:29.245 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:30.357 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:30.357 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:30.357 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:30.357 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:30.357 | Rithmic Direct - DTC (Data) | Failed connections: 3087
2025-01-08 12:26:30.357 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:30.357 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:30.358 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:30.358 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:30.358 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:30.655 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:30.655 | DTC Client socket (2) | Closed.
2025-01-08 12:26:32.358 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:32.358 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:32.358 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:32.359 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:32.359 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:32.359 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:32.650 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:32.651 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:32.651 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:32.651 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:33.741 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:33.741 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:33.741 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:33.741 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:33.741 | Rithmic Direct - DTC (Data) | Failed connections: 3088
2025-01-08 12:26:33.741 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:33.742 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:33.742 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:33.742 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:33.742 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:34.032 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:34.033 | DTC Client socket (2) | Closed.
2025-01-08 12:26:35.739 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:35.739 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:35.739 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:35.740 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:35.740 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:35.740 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:36.036 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:36.036 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:36.036 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:36.036 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:37.142 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:37.142 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:37.142 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:37.142 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:37.142 | Rithmic Direct - DTC (Data) | Failed connections: 3089
2025-01-08 12:26:37.143 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:37.143 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:37.143 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:37.143 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:37.143 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:37.440 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:37.440 | DTC Client socket (2) | Closed.
2025-01-08 12:26:39.156 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:39.156 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:39.156 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:39.157 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:39.157 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:39.157 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:39.445 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:39.445 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:39.445 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:39.445 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Failed connections: 3090
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:40.829 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:40.829 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:40.829 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:41.117 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:41.117 | DTC Client socket (2) | Closed.
2025-01-08 12:26:42.822 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:42.822 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:42.822 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:42.822 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:42.822 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:42.822 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:43.122 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:43.122 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:43.122 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:43.122 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Failed connections: 3091
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:44.247 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:44.247 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:44.248 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:44.547 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:44.547 | DTC Client socket (2) | Closed.
2025-01-08 12:26:46.249 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:46.249 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:46.249 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:46.250 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:46.250 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:46.250 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:46.535 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:46.535 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:46.535 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:46.535 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:47.595 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:47.595 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:47.595 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:47.595 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:47.595 | Rithmic Direct - DTC (Data) | Failed connections: 3092
2025-01-08 12:26:47.595 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:47.595 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:47.596 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:47.596 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:47.596 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:47.875 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:47.875 | DTC Client socket (2) | Closed.
2025-01-08 12:26:49.610 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:49.610 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:49.610 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:49.611 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:49.611 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:49.611 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:50.010 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:50.010 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:50.010 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:50.010 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:51.388 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:51.388 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:51.388 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:51.388 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:51.388 | Rithmic Direct - DTC (Data) | Failed connections: 3093
2025-01-08 12:26:51.388 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:51.389 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:51.389 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:51.389 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:51.389 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:51.788 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:51.788 | DTC Client socket (2) | Closed.
2025-01-08 12:26:53.378 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:53.378 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:53.378 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:53.379 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:53.380 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:53.380 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:53.619 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:53.619 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:53.619 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:53.619 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:54.550 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:54.550 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:54.550 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:54.550 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:54.550 | Rithmic Direct - DTC (Data) | Failed connections: 3094
2025-01-08 12:26:54.550 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:54.551 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:54.551 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:54.551 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:54.551 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:54.786 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:54.786 | DTC Client socket (2) | Closed.
2025-01-08 12:26:56.553 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:56.553 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:56.553 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:56.554 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:56.554 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:56.554 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:26:56.809 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:26:56.809 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:26:56.809 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:26:56.809 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:26:57.786 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:26:57.786 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:26:57.786 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:57.786 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:26:57.786 | Rithmic Direct - DTC (Data) | Failed connections: 3095
2025-01-08 12:26:57.786 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:26:57.787 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:57.787 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:26:57.787 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:26:57.787 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:58.036 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:58.036 | DTC Client socket (2) | Closed.
2025-01-08 12:26:58.245 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048
2025-01-08 12:26:58.246 | DTC Client socket (2) | Creating socket.
2025-01-08 12:26:58.246 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:58.246 | DTC Client socket (2) | Connecting to IP: 67.214.125.3.
2025-01-08 12:26:58.397 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:26:58.397 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:26:58.397 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:26:58.559 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:26:58.559 | Denali Data Feed | Sending logon request message.
2025-01-08 12:26:59.093 | Denali Data Feed | Received logon response.
2025-01-08 12:26:59.093 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:26:59.093 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:26:59.093 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:26:59.093 | Denali Data Feed | Failed connections: 220
2025-01-08 12:26:59.093 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:26:59.094 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:26:59.094 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:26:59.094 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:26:59.094 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:26:59.244 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:26:59.244 | DTC Client socket (2) | Closed.
2025-01-08 12:26:59.803 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:26:59.803 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:26:59.803 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:26:59.804 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:26:59.805 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:26:59.805 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:00.046 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:00.046 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:00.046 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:00.046 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:00.987 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:00.987 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:00.987 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:00.987 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:00.987 | Rithmic Direct - DTC (Data) | Failed connections: 3096
2025-01-08 12:27:00.987 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:00.988 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:00.988 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:00.988 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:00.988 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:01.228 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:01.228 | DTC Client socket (2) | Closed.
2025-01-08 12:27:02.998 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:02.998 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:02.998 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:02.999 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:02.999 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:02.999 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:03.286 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:03.286 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:03.286 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:03.286 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:04.371 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:04.371 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:04.371 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:04.371 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:04.371 | Rithmic Direct - DTC (Data) | Failed connections: 3097
2025-01-08 12:27:04.371 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:04.372 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:04.372 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:04.372 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:04.372 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:04.658 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:04.658 | DTC Client socket (2) | Closed.
2025-01-08 12:27:06.374 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:06.374 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:06.374 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:06.375 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:06.375 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:06.375 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:06.620 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:06.620 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:06.620 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:06.620 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:07.580 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:07.580 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:07.580 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:07.580 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:07.580 | Rithmic Direct - DTC (Data) | Failed connections: 3098
2025-01-08 12:27:07.580 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:07.581 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:07.581 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:07.581 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:07.581 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:07.827 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:07.827 | DTC Client socket (2) | Closed.
2025-01-08 12:27:09.581 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:09.581 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:09.581 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:09.582 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:09.582 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:09.582 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:09.999 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:09.999 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:09.999 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:09.999 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:11.446 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:11.446 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:11.446 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:11.446 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:11.446 | Rithmic Direct - DTC (Data) | Failed connections: 3099
2025-01-08 12:27:11.446 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:11.447 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:11.447 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:11.447 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:11.447 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:11.869 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:11.869 | DTC Client socket (2) | Closed.
2025-01-08 12:27:13.460 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:13.460 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:13.460 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:13.460 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:13.460 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:13.460 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:13.759 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:13.759 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:13.759 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:13.759 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:14.880 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:14.880 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:14.880 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:14.880 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:14.880 | Rithmic Direct - DTC (Data) | Failed connections: 3100
2025-01-08 12:27:14.880 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:14.881 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:14.881 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:14.881 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:14.881 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:15.181 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:15.181 | DTC Client socket (2) | Closed.
2025-01-08 12:27:16.877 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:16.877 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:16.877 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:16.878 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:16.878 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:16.878 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:17.167 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:17.167 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:17.167 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:17.167 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:18.245 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:18.245 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:18.245 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:18.245 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:18.245 | Rithmic Direct - DTC (Data) | Failed connections: 3101
2025-01-08 12:27:18.245 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:18.246 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:18.246 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:18.246 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:18.246 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:18.532 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:18.532 | DTC Client socket (2) | Closed.
2025-01-08 12:27:20.238 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:20.238 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:20.238 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:20.239 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:20.240 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:20.240 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:20.608 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:20.608 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:20.608 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:20.608 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:21.956 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:21.956 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:21.956 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:21.956 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:21.956 | Rithmic Direct - DTC (Data) | Failed connections: 3102
2025-01-08 12:27:21.956 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:21.957 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:21.957 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:21.958 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:21.958 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:22.330 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:22.330 | DTC Client socket (2) | Closed.
2025-01-08 12:27:23.965 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:23.965 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:23.965 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:23.966 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:23.966 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:23.966 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:24.252 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:24.252 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:24.252 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:24.252 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:25.336 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:25.336 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:25.336 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:25.336 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:25.336 | Rithmic Direct - DTC (Data) | Failed connections: 3103
2025-01-08 12:27:25.337 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:25.338 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:25.338 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:25.338 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:25.338 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:25.624 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:25.624 | DTC Client socket (2) | Closed.
2025-01-08 12:27:27.346 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:27.346 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:27.346 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:27.347 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:27.347 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:27.347 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:27.743 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:27.743 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:27.743 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:27.743 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:29.136 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:29.136 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:29.136 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:29.136 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:29.136 | Rithmic Direct - DTC (Data) | Failed connections: 3104
2025-01-08 12:27:29.136 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:29.137 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:29.137 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:29.137 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:29.137 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:29.507 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:29.507 | DTC Client socket (2) | Closed.
2025-01-08 12:27:31.138 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:31.138 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:31.138 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:31.139 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:31.140 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:31.140 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:31.438 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:31.438 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:31.438 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:31.438 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:32.544 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:32.544 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:32.544 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:32.544 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:32.544 | Rithmic Direct - DTC (Data) | Failed connections: 3105
2025-01-08 12:27:32.544 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:32.545 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:32.545 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:32.545 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:32.545 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:32.841 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:32.841 | DTC Client socket (2) | Closed.
2025-01-08 12:27:34.536 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:34.536 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:34.536 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:34.537 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:34.537 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:34.537 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:34.784 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:34.784 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:34.784 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:34.784 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Failed connections: 3106
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:35.738 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:35.738 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:35.738 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:35.985 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:35.985 | DTC Client socket (2) | Closed.
2025-01-08 12:27:37.750 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:37.750 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:37.750 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:37.750 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:37.750 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:37.750 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:38.030 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:38.030 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:38.030 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:38.030 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:39.100 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:39.100 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:39.100 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:39.100 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:39.100 | Rithmic Direct - DTC (Data) | Failed connections: 3107
2025-01-08 12:27:39.100 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:39.101 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:39.101 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:39.101 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:39.101 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:39.379 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:39.380 | DTC Client socket (2) | Closed.
2025-01-08 12:27:41.100 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:41.100 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:41.100 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:41.101 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:41.101 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:41.101 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:41.393 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:41.393 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:41.393 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:41.393 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Failed connections: 3108
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:42.495 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:42.495 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:42.495 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:42.787 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:42.787 | DTC Client socket (2) | Closed.
2025-01-08 12:27:44.500 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:44.501 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:44.501 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:44.502 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:44.502 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:44.502 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:44.744 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:44.744 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:44.744 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:44.744 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Failed connections: 3109
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:45.689 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:45.689 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:45.689 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:45.931 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:45.931 | DTC Client socket (2) | Closed.
2025-01-08 12:27:47.699 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:47.699 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:47.699 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:47.700 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:47.700 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:47.700 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:48.037 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:48.037 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:48.037 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:48.037 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:49.271 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:49.271 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:49.271 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:49.271 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:49.271 | Rithmic Direct - DTC (Data) | Failed connections: 3110
2025-01-08 12:27:49.271 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:49.272 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:49.272 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:49.272 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:49.272 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:49.617 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:49.617 | DTC Client socket (2) | Closed.
2025-01-08 12:27:51.274 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:51.274 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:51.274 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:51.275 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:51.275 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:51.275 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:51.570 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:51.570 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:51.570 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:51.570 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Failed connections: 3111
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:52.679 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:52.679 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:52.679 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:52.975 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:52.975 | DTC Client socket (2) | Closed.
2025-01-08 12:27:54.679 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:54.679 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:54.679 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:54.680 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:54.680 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:54.680 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:54.977 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:54.977 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:54.977 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:54.977 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:56.094 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:56.094 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:56.094 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:56.094 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:56.094 | Rithmic Direct - DTC (Data) | Failed connections: 3112
2025-01-08 12:27:56.095 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:56.095 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:56.095 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:56.095 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:56.096 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:56.393 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:56.393 | DTC Client socket (2) | Closed.
2025-01-08 12:27:58.085 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:27:58.085 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:27:58.085 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:27:58.086 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:27:58.086 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:27:58.086 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:27:58.380 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:27:58.380 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:27:58.380 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:27:58.380 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:27:59.084 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443
2025-01-08 12:27:59.084 | DTC Client socket (3) | Creating socket.
2025-01-08 12:27:59.084 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:27:59.084 | DTC Client socket (3) | Connecting to IP: 67.214.125.6.
2025-01-08 12:27:59.245 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:27:59.245 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:27:59.246 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:27:59.412 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:27:59.412 | Denali Data Feed | Sending logon request message.
2025-01-08 12:27:59.494 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:27:59.494 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:27:59.494 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:59.494 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:27:59.494 | Rithmic Direct - DTC (Data) | Failed connections: 3113
2025-01-08 12:27:59.494 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:27:59.495 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:27:59.495 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:27:59.495 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:27:59.495 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:27:59.789 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:27:59.789 | DTC Client socket (2) | Closed.
2025-01-08 12:27:59.959 | Denali Data Feed | Received logon response.
2025-01-08 12:27:59.959 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:27:59.959 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:27:59.959 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:27:59.959 | Denali Data Feed | Failed connections: 221
2025-01-08 12:27:59.959 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:27:59.959 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:27:59.959 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:27:59.959 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:27:59.959 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:00.127 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:28:00.127 | DTC Client socket (3) | Closed.
2025-01-08 12:28:01.500 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:01.500 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:01.500 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:01.500 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:01.501 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:01.501 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:01.751 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:01.751 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:01.751 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:01.751 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:02.724 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:02.724 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:02.724 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:02.724 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:02.724 | Rithmic Direct - DTC (Data) | Failed connections: 3114
2025-01-08 12:28:02.724 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:02.725 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:02.725 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:02.725 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:02.725 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:02.976 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:02.976 | DTC Client socket (2) | Closed.
2025-01-08 12:28:04.722 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:04.722 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:04.722 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:04.723 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:04.723 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:04.723 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:04.964 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:04.964 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:04.964 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:04.964 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:05.905 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:05.905 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:05.905 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:05.905 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:05.905 | Rithmic Direct - DTC (Data) | Failed connections: 3115
2025-01-08 12:28:05.905 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:05.906 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:05.906 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:05.906 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:05.906 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:06.146 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:06.146 | DTC Client socket (2) | Closed.
2025-01-08 12:28:07.893 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:07.893 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:07.893 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:07.894 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:07.894 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:07.894 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:08.139 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:08.139 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:08.139 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:08.139 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:09.095 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:09.095 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:09.095 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:09.095 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:09.095 | Rithmic Direct - DTC (Data) | Failed connections: 3116
2025-01-08 12:28:09.096 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:09.096 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:09.096 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:09.096 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:09.096 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:09.341 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:09.342 | DTC Client socket (2) | Closed.
2025-01-08 12:28:11.109 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:11.109 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:11.109 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:11.110 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:11.111 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:11.111 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:11.399 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:11.399 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:11.399 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:11.399 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:12.478 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:12.478 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:12.478 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:12.478 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:12.478 | Rithmic Direct - DTC (Data) | Failed connections: 3117
2025-01-08 12:28:12.478 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:12.479 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:12.480 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:12.480 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:12.480 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:12.771 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:12.771 | DTC Client socket (2) | Closed.
2025-01-08 12:28:14.478 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:14.478 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:14.478 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:14.479 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:14.479 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:14.479 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:14.727 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:14.727 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:14.727 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:14.727 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:15.682 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:15.682 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:15.682 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:15.682 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:15.682 | Rithmic Direct - DTC (Data) | Failed connections: 3118
2025-01-08 12:28:15.682 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:15.682 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:15.682 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:15.683 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:15.683 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:15.925 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:15.926 | DTC Client socket (2) | Closed.
2025-01-08 12:28:17.677 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:17.677 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:17.677 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:17.677 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:17.677 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:17.677 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:17.989 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:17.989 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:17.989 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:17.989 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:19.098 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:19.098 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:19.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:19.098 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:19.098 | Rithmic Direct - DTC (Data) | Failed connections: 3119
2025-01-08 12:28:19.098 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:19.098 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:19.098 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:19.099 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:19.099 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:19.395 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:19.395 | DTC Client socket (2) | Closed.
2025-01-08 12:28:21.097 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:21.097 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:21.097 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:21.097 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:21.097 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:21.098 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:21.340 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:21.340 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:21.340 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:21.340 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:22.289 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:22.289 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:22.289 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:22.289 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:22.289 | Rithmic Direct - DTC (Data) | Failed connections: 3120
2025-01-08 12:28:22.289 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:22.290 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:22.290 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:22.290 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:22.290 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:22.533 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:22.533 | DTC Client socket (2) | Closed.
2025-01-08 12:28:24.297 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:24.297 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:24.297 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:24.298 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:24.298 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:24.298 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:24.540 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:24.540 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:24.540 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:24.540 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:25.519 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:25.519 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:25.519 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:25.519 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:25.519 | Rithmic Direct - DTC (Data) | Failed connections: 3121
2025-01-08 12:28:25.519 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:25.520 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:25.520 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:25.520 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:25.520 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:25.767 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:25.767 | DTC Client socket (2) | Closed.
2025-01-08 12:28:27.521 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:27.521 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:27.521 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:27.522 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:27.522 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:27.522 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:27.770 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:27.770 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:27.770 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:27.770 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:28.735 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:28.735 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:28.735 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:28.735 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:28.735 | Rithmic Direct - DTC (Data) | Failed connections: 3122
2025-01-08 12:28:28.735 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:28.736 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:28.736 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:28.736 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:28.736 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:28.984 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:28.984 | DTC Client socket (2) | Closed.
2025-01-08 12:28:30.722 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:30.722 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:30.722 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:30.723 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:30.723 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:30.723 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:30.965 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:30.965 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:30.965 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:30.965 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:31.914 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:31.914 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:31.914 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:31.914 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:31.914 | Rithmic Direct - DTC (Data) | Failed connections: 3123
2025-01-08 12:28:31.914 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:31.915 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:31.915 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:31.915 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:31.915 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:32.157 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:32.157 | DTC Client socket (2) | Closed.
2025-01-08 12:28:33.916 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:33.916 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:33.916 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:33.917 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:33.917 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:33.917 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:34.154 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:34.154 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:34.155 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:34.155 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Failed connections: 3124
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:35.090 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:35.090 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:35.090 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:35.327 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:35.327 | DTC Client socket (2) | Closed.
2025-01-08 12:28:37.094 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:37.094 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:37.094 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:37.095 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:37.095 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:37.095 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:37.344 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:37.344 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:37.345 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:37.345 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Failed connections: 3125
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:38.298 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:38.298 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:38.299 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:38.541 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:38.541 | DTC Client socket (2) | Closed.
2025-01-08 12:28:40.310 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:40.310 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:40.310 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:40.311 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:40.311 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:40.311 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:40.560 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:40.560 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:40.560 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:40.560 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Failed connections: 3126
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:41.524 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:41.524 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:41.524 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:41.773 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:41.773 | DTC Client socket (2) | Closed.
2025-01-08 12:28:43.519 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:43.519 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:43.519 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:43.520 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:43.520 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:43.520 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:43.828 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:43.828 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:43.828 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:43.828 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:44.915 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:44.915 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:44.915 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:44.915 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:44.915 | Rithmic Direct - DTC (Data) | Failed connections: 3127
2025-01-08 12:28:44.915 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:44.916 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:44.916 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:44.916 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:44.916 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:45.205 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:45.205 | DTC Client socket (2) | Closed.
2025-01-08 12:28:46.920 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:46.920 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:46.920 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:46.921 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:46.922 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:46.922 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:47.162 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:47.162 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:47.162 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:47.162 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:48.108 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:48.108 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:48.108 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:48.108 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:48.108 | Rithmic Direct - DTC (Data) | Failed connections: 3128
2025-01-08 12:28:48.108 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:48.108 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:48.109 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:48.109 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:48.109 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:48.349 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:48.349 | DTC Client socket (2) | Closed.
2025-01-08 12:28:50.100 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:50.100 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:50.100 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:50.101 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:50.101 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:50.101 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:50.390 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:50.390 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:50.390 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:50.390 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:51.468 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:51.468 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:51.468 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:51.468 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:51.468 | Rithmic Direct - DTC (Data) | Failed connections: 3129
2025-01-08 12:28:51.468 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:51.469 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:51.469 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:51.470 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:51.470 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:51.756 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:51.756 | DTC Client socket (2) | Closed.
2025-01-08 12:28:53.472 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:53.472 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:53.472 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:53.473 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:53.474 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:53.474 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:53.778 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:53.778 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:53.778 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:53.778 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Failed connections: 3130
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:54.882 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:54.882 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:54.882 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:55.176 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:55.176 | DTC Client socket (2) | Closed.
2025-01-08 12:28:56.887 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:28:56.887 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:28:56.887 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:28:56.888 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:28:56.888 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:28:56.888 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:28:57.185 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:28:57.185 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:28:57.186 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:28:57.186 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:28:58.292 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:28:58.292 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:28:58.292 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:28:58.292 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:28:58.292 | Rithmic Direct - DTC (Data) | Failed connections: 3131
2025-01-08 12:28:58.292 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:28:58.293 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:28:58.293 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:28:58.293 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:28:58.293 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:28:58.588 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:28:58.588 | DTC Client socket (2) | Closed.
2025-01-08 12:28:59.964 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443
2025-01-08 12:29:00.105 | DTC Client socket (2) | Creating socket.
2025-01-08 12:29:00.105 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:00.105 | DTC Client socket (2) | Connecting to IP: 64.152.155.20.
2025-01-08 12:29:00.258 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:29:00.258 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:29:00.258 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:29:00.293 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:00.293 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:00.293 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:00.294 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:00.294 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:29:00.294 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:00.418 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:29:00.418 | Denali Data Feed | Sending logon request message.
2025-01-08 12:29:00.539 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:00.539 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:00.539 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:00.539 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:00.922 | Denali Data Feed | Received logon response.
2025-01-08 12:29:00.922 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:29:00.922 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:00.922 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:29:00.922 | Denali Data Feed | Failed connections: 222
2025-01-08 12:29:00.922 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:29:00.923 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:00.923 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:29:00.923 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:29:00.923 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:01.078 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:01.078 | DTC Client socket (2) | Closed.
2025-01-08 12:29:01.499 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:01.499 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:01.499 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:01.499 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:01.499 | Rithmic Direct - DTC (Data) | Failed connections: 3132
2025-01-08 12:29:01.499 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:01.500 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:29:01.500 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:01.500 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:01.500 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:01.744 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:29:01.744 | DTC Client socket (3) | Closed.
2025-01-08 12:29:03.493 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:03.493 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:03.493 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:03.493 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:03.494 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:03.494 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:03.795 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:03.795 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:03.795 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:03.795 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:04.918 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:04.918 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:04.918 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:04.918 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:04.918 | Rithmic Direct - DTC (Data) | Failed connections: 3133
2025-01-08 12:29:04.918 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:04.919 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:04.919 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:04.919 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:04.919 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:05.220 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:05.220 | DTC Client socket (2) | Closed.
2025-01-08 12:29:06.917 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:06.917 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:06.917 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:06.918 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:06.918 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:06.918 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:07.205 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:07.205 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:07.205 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:07.205 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Failed connections: 3134
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:08.289 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:08.289 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:08.289 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:08.577 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:08.577 | DTC Client socket (2) | Closed.
2025-01-08 12:29:10.298 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:10.298 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:10.298 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:10.299 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:10.299 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:10.299 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:10.537 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:10.537 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:10.537 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:10.537 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:11.469 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:11.469 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:11.469 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:11.469 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:11.469 | Rithmic Direct - DTC (Data) | Failed connections: 3135
2025-01-08 12:29:11.469 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:11.470 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:11.470 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:11.470 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:11.470 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:11.716 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:11.716 | DTC Client socket (2) | Closed.
2025-01-08 12:29:13.458 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:13.458 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:13.458 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:13.459 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:13.459 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:13.459 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:13.745 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:13.745 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:13.745 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:13.745 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:14.824 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:14.824 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:14.824 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:14.824 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:14.824 | Rithmic Direct - DTC (Data) | Failed connections: 3136
2025-01-08 12:29:14.824 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:14.825 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:14.825 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:14.825 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:14.825 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:15.110 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:15.110 | DTC Client socket (2) | Closed.
2025-01-08 12:29:16.822 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:16.822 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:16.822 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:16.823 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:16.823 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:16.823 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:17.071 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:17.071 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:17.071 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:17.071 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:18.048 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:18.048 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:18.048 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:18.048 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:18.048 | Rithmic Direct - DTC (Data) | Failed connections: 3137
2025-01-08 12:29:18.048 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:18.049 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:18.049 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:18.049 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:18.049 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:18.300 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:18.301 | DTC Client socket (2) | Closed.
2025-01-08 12:29:20.070 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:20.070 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:20.070 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:20.092 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:20.092 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:20.092 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:20.333 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:20.333 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:20.333 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:20.333 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:21.280 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:21.280 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:21.280 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:21.280 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:21.280 | Rithmic Direct - DTC (Data) | Failed connections: 3138
2025-01-08 12:29:21.280 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:21.281 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:21.281 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:21.281 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:21.281 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:21.520 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:21.521 | DTC Client socket (2) | Closed.
2025-01-08 12:29:23.281 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:23.281 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:23.281 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:23.282 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:23.283 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:23.283 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:23.573 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:23.573 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:23.573 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:23.573 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:24.665 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:24.665 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:24.665 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:24.665 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:24.665 | Rithmic Direct - DTC (Data) | Failed connections: 3139
2025-01-08 12:29:24.665 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:24.666 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:24.666 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:24.666 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:24.666 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:24.956 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:24.956 | DTC Client socket (2) | Closed.
2025-01-08 12:29:26.662 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:26.662 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:26.662 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:26.663 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:26.663 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:26.663 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:26.902 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:26.902 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:26.902 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:26.902 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Failed connections: 3140
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:27.838 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:27.838 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:27.838 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:28.076 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:28.077 | DTC Client socket (2) | Closed.
2025-01-08 12:29:29.854 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:29.854 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:29.854 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:29.854 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:29.854 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:29.854 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:30.095 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:30.095 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:30.095 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:30.095 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:31.060 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:31.060 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:31.060 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:31.060 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:31.060 | Rithmic Direct - DTC (Data) | Failed connections: 3141
2025-01-08 12:29:31.060 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:31.061 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:31.061 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:31.061 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:31.061 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:31.299 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:31.300 | DTC Client socket (2) | Closed.
2025-01-08 12:29:33.052 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:33.052 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:33.052 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:33.052 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:33.052 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:33.052 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:33.353 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:33.353 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:33.353 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:33.353 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:34.483 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:34.483 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:34.483 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:34.483 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:34.483 | Rithmic Direct - DTC (Data) | Failed connections: 3142
2025-01-08 12:29:34.483 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:34.484 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:34.484 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:34.484 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:34.484 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:34.785 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:34.785 | DTC Client socket (2) | Closed.
2025-01-08 12:29:36.481 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:36.481 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:36.481 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:36.483 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:36.484 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:36.484 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:36.725 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:36.725 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:36.725 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:36.725 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:37.669 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:37.669 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:37.669 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:37.669 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:37.669 | Rithmic Direct - DTC (Data) | Failed connections: 3143
2025-01-08 12:29:37.669 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:37.670 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:37.670 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:37.670 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:37.670 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:37.910 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:37.911 | DTC Client socket (2) | Closed.
2025-01-08 12:29:39.659 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:39.659 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:39.659 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:39.660 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:39.660 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:39.660 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:39.957 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:39.957 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:39.957 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:39.957 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:41.080 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:41.080 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:41.080 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:41.080 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:41.080 | Rithmic Direct - DTC (Data) | Failed connections: 3144
2025-01-08 12:29:41.080 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:41.081 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:41.081 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:41.081 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:41.081 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:41.379 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:41.379 | DTC Client socket (2) | Closed.
2025-01-08 12:29:43.085 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:43.085 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:43.085 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:43.086 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:43.087 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:43.087 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:43.331 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:43.331 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:43.331 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:43.331 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:44.290 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:44.290 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:44.290 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:44.290 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:44.290 | Rithmic Direct - DTC (Data) | Failed connections: 3145
2025-01-08 12:29:44.290 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:44.291 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:44.291 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:44.292 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:44.292 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:44.535 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:44.535 | DTC Client socket (2) | Closed.
2025-01-08 12:29:46.290 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:46.290 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:46.291 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:46.292 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:46.292 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:46.292 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:46.533 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:46.533 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:46.533 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:46.533 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:47.471 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:47.471 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:47.471 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:47.471 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:47.471 | Rithmic Direct - DTC (Data) | Failed connections: 3146
2025-01-08 12:29:47.471 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:47.472 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:47.472 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:47.472 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:47.472 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:47.712 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:47.712 | DTC Client socket (2) | Closed.
2025-01-08 12:29:49.483 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:49.483 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:49.483 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:49.483 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:49.483 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:49.483 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:49.730 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:49.730 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:49.730 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:49.730 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:50.689 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:50.689 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:50.689 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:50.689 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:50.689 | Rithmic Direct - DTC (Data) | Failed connections: 3147
2025-01-08 12:29:50.690 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:50.691 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:50.691 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:50.691 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:50.691 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:50.939 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:50.939 | DTC Client socket (2) | Closed.
2025-01-08 12:29:52.699 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:52.699 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:52.699 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:52.700 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:52.700 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:52.700 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:52.996 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:52.996 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:52.996 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:52.996 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:54.098 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:54.098 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:54.098 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:54.098 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:54.098 | Rithmic Direct - DTC (Data) | Failed connections: 3148
2025-01-08 12:29:54.098 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:54.099 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:54.099 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:54.099 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:54.099 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:54.393 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:54.393 | DTC Client socket (2) | Closed.
2025-01-08 12:29:56.106 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:56.106 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:56.106 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:56.107 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:56.107 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:56.107 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:56.393 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:56.393 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:56.393 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:56.393 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:29:57.460 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:29:57.460 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:29:57.460 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:29:57.460 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:29:57.460 | Rithmic Direct - DTC (Data) | Failed connections: 3149
2025-01-08 12:29:57.460 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:29:57.461 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:29:57.461 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:29:57.461 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:29:57.461 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:29:57.730 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:29:57.730 | DTC Client socket (2) | Closed.
2025-01-08 12:29:59.467 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:29:59.467 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:29:59.467 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:29:59.629 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:29:59.630 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:29:59.630 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:29:59.869 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:29:59.869 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:29:59.869 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:29:59.869 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:00.816 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:00.816 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:00.816 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:00.816 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:00.816 | Rithmic Direct - DTC (Data) | Failed connections: 3150
2025-01-08 12:30:00.816 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:00.817 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:00.817 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:00.817 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:00.817 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:00.912 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048
2025-01-08 12:30:00.913 | DTC Client socket (3) | Creating socket.
2025-01-08 12:30:00.913 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:30:00.913 | DTC Client socket (3) | Connecting to IP: 67.214.125.4.
2025-01-08 12:30:01.057 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:01.057 | DTC Client socket (2) | Closed.
2025-01-08 12:30:01.070 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:30:01.070 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:30:01.071 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:30:01.230 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:30:01.230 | Denali Data Feed | Sending logon request message.
2025-01-08 12:30:01.765 | Denali Data Feed | Received logon response.
2025-01-08 12:30:01.765 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:30:01.765 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:01.765 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:30:01.765 | Denali Data Feed | Failed connections: 223
2025-01-08 12:30:01.765 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:30:01.766 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:30:01.766 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:30:01.766 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:30:01.766 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:01.922 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:30:01.922 | DTC Client socket (3) | Closed.
2025-01-08 12:30:02.828 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:02.828 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:02.828 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:02.829 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:02.830 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:02.830 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:03.123 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:03.123 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:03.123 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:03.123 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:04.228 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:04.228 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:04.228 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:04.228 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:04.228 | Rithmic Direct - DTC (Data) | Failed connections: 3151
2025-01-08 12:30:04.229 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:04.229 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:04.229 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:04.229 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:04.229 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:04.523 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:04.523 | DTC Client socket (2) | Closed.
2025-01-08 12:30:06.228 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:06.228 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:06.228 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:06.229 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:06.229 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:06.229 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:06.468 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:06.468 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:06.468 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:06.468 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:07.410 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:07.410 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:07.410 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:07.410 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:07.410 | Rithmic Direct - DTC (Data) | Failed connections: 3152
2025-01-08 12:30:07.410 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:07.411 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:07.411 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:07.411 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:07.412 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:07.650 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:07.650 | DTC Client socket (2) | Closed.
2025-01-08 12:30:09.423 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:09.423 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:09.423 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:09.423 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:09.423 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:09.423 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:09.662 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:09.662 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:09.662 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:09.662 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:10.610 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:10.610 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:10.610 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:10.610 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:10.610 | Rithmic Direct - DTC (Data) | Failed connections: 3153
2025-01-08 12:30:10.610 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:10.611 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:10.611 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:10.611 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:10.611 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:10.850 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:10.850 | DTC Client socket (2) | Closed.
2025-01-08 12:30:12.623 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:12.623 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:12.623 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:12.623 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:12.624 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:12.624 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:12.921 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:12.921 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:12.921 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:12.921 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Failed connections: 3154
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:14.029 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:14.029 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:14.029 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:14.326 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:14.326 | DTC Client socket (2) | Closed.
2025-01-08 12:30:16.033 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:16.033 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:16.033 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:16.034 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:16.034 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:16.035 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:16.280 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:16.280 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:16.280 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:16.280 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:17.243 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:17.243 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:17.243 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:17.243 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:17.243 | Rithmic Direct - DTC (Data) | Failed connections: 3155
2025-01-08 12:30:17.243 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:17.245 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:17.245 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:17.245 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:17.245 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:17.490 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:17.490 | DTC Client socket (2) | Closed.
2025-01-08 12:30:19.242 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:19.242 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:19.242 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:19.243 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:19.243 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:19.243 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:19.486 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:19.486 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:19.486 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:19.486 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:20.439 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:20.439 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:20.439 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:20.439 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:20.439 | Rithmic Direct - DTC (Data) | Failed connections: 3156
2025-01-08 12:30:20.439 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:20.440 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:20.440 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:20.440 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:20.440 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:20.682 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:20.682 | DTC Client socket (2) | Closed.
2025-01-08 12:30:22.439 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:22.439 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:22.439 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:22.440 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:22.440 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:22.440 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:22.732 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:22.732 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:22.732 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:22.732 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:23.834 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:23.834 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:23.834 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:23.834 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:23.834 | Rithmic Direct - DTC (Data) | Failed connections: 3157
2025-01-08 12:30:23.834 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:23.835 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:23.835 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:23.835 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:23.835 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:24.131 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:24.131 | DTC Client socket (2) | Closed.
2025-01-08 12:30:25.832 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:25.832 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:25.832 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:25.833 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:25.833 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:25.833 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:26.208 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:26.208 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:26.208 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:26.208 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:27.641 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:27.641 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:27.641 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:27.641 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:27.641 | Rithmic Direct - DTC (Data) | Failed connections: 3158
2025-01-08 12:30:27.641 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:27.642 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:27.642 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:27.642 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:27.642 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:28.021 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:28.021 | DTC Client socket (2) | Closed.
2025-01-08 12:30:29.634 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:29.634 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:29.634 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:29.635 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:29.636 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:29.636 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:29.968 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:29.968 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:29.968 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:29.968 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Failed connections: 3159
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:31.179 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:31.179 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:31.179 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:31.509 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:31.509 | DTC Client socket (2) | Closed.
2025-01-08 12:30:33.186 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:33.186 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:33.186 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:33.187 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:33.188 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:33.188 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:33.481 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:33.481 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:33.481 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:33.481 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Failed connections: 3160
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:34.578 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:34.578 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:34.578 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:34.871 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:34.871 | DTC Client socket (2) | Closed.
2025-01-08 12:30:36.577 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:36.577 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:36.577 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:36.577 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:36.577 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:36.577 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:36.876 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:36.876 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:36.876 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:36.876 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:37.994 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:37.994 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:37.994 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:37.994 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:37.994 | Rithmic Direct - DTC (Data) | Failed connections: 3161
2025-01-08 12:30:37.994 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:37.995 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:37.995 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:37.995 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:37.995 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:38.294 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:38.295 | DTC Client socket (2) | Closed.
2025-01-08 12:30:39.998 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:39.998 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:39.998 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:39.999 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:39.999 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:39.999 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:40.237 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:40.237 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:40.237 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:40.237 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:41.167 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:41.167 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:41.167 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:41.167 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:41.167 | Rithmic Direct - DTC (Data) | Failed connections: 3162
2025-01-08 12:30:41.167 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:41.168 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:41.168 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:41.168 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:41.168 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:41.406 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:41.406 | DTC Client socket (2) | Closed.
2025-01-08 12:30:43.171 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:43.171 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:43.172 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:43.173 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:43.173 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:43.173 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:43.461 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:43.461 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:43.462 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:43.462 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Failed connections: 3163
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:44.512 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:44.512 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:44.512 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:44.798 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:44.798 | DTC Client socket (2) | Closed.
2025-01-08 12:30:46.504 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:46.504 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:46.504 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:46.505 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:46.505 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:30:46.505 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:46.797 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:46.797 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:46.798 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:46.798 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:48.531 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:48.531 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:48.531 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:48.531 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:48.531 | Rithmic Direct - DTC (Data) | Failed connections: 3164
2025-01-08 12:30:48.531 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:48.532 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:30:48.532 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:48.532 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:48.532 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:48.828 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:30:48.828 | DTC Client socket (3) | Closed.
2025-01-08 12:30:50.519 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:50.519 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:50.519 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:50.520 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:50.520 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:50.520 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:50.814 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:50.814 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:50.814 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:50.814 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Failed connections: 3165
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:51.915 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:51.915 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:51.915 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:52.210 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:52.210 | DTC Client socket (2) | Closed.
2025-01-08 12:30:53.918 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:53.918 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:53.918 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:53.919 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:53.920 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:53.920 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:54.210 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:54.210 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:54.210 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:54.210 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:55.271 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:55.271 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:55.271 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:55.271 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:55.271 | Rithmic Direct - DTC (Data) | Failed connections: 3166
2025-01-08 12:30:55.271 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:55.272 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:55.272 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:55.272 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:55.272 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:56.117 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:56.117 | DTC Client socket (2) | Closed.
2025-01-08 12:30:57.286 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:30:57.286 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:30:57.286 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:30:57.287 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:30:57.288 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:30:57.288 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:30:57.518 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:30:57.518 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:30:57.518 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:30:57.518 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:30:58.425 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:30:58.425 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:30:58.425 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:30:58.425 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:30:58.425 | Rithmic Direct - DTC (Data) | Failed connections: 3167
2025-01-08 12:30:58.425 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:30:58.425 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:30:58.426 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:30:58.426 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:30:58.426 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:30:58.655 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:30:58.655 | DTC Client socket (2) | Closed.
2025-01-08 12:31:00.434 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:00.434 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:00.434 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:00.434 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:00.435 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:00.435 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:00.726 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:00.726 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:00.726 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:00.726 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:01.752 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443
2025-01-08 12:31:01.829 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:01.829 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:01.829 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:01.829 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:01.829 | Rithmic Direct - DTC (Data) | Failed connections: 3168
2025-01-08 12:31:01.829 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:01.830 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:01.830 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:01.830 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:01.830 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:01.883 | DTC Client socket (3) | Creating socket.
2025-01-08 12:31:01.883 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:31:01.883 | DTC Client socket (3) | Connecting to IP: 64.152.155.18.
2025-01-08 12:31:02.036 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:31:02.036 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:31:02.036 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:31:02.120 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:02.120 | DTC Client socket (2) | Closed.
2025-01-08 12:31:02.207 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:31:02.207 | Denali Data Feed | Sending logon request message.
2025-01-08 12:31:02.729 | Denali Data Feed | Received logon response.
2025-01-08 12:31:02.729 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:31:02.729 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:02.729 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:31:02.729 | Denali Data Feed | Failed connections: 224
2025-01-08 12:31:02.729 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:31:02.730 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:31:02.730 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:31:02.730 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:02.730 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:31:02.882 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:31:02.882 | DTC Client socket (3) | Closed.
2025-01-08 12:31:03.834 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:03.834 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:03.834 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:03.835 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:03.836 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:03.836 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:04.126 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:04.126 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:04.126 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:04.126 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:05.222 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:05.222 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:05.222 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:05.222 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:05.222 | Rithmic Direct - DTC (Data) | Failed connections: 3169
2025-01-08 12:31:05.222 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:05.223 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:05.223 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:05.223 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:05.223 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:05.513 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:05.513 | DTC Client socket (2) | Closed.
2025-01-08 12:31:07.229 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:07.229 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:07.229 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:07.230 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:07.230 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:07.230 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:07.521 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:07.521 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:07.521 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:07.521 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:08.618 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:08.618 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:08.618 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:08.618 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:08.618 | Rithmic Direct - DTC (Data) | Failed connections: 3170
2025-01-08 12:31:08.618 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:08.619 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:08.619 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:08.619 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:08.619 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:08.910 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:08.910 | DTC Client socket (2) | Closed.
2025-01-08 12:31:10.612 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:10.612 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:10.612 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:10.613 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:10.613 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:10.613 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:10.857 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:10.857 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:10.857 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:10.857 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Failed connections: 3171
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:11.787 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:11.787 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:11.787 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:12.024 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:12.024 | DTC Client socket (2) | Closed.
2025-01-08 12:31:13.784 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:13.784 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:13.785 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:13.785 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:13.785 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:13.785 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:14.034 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:14.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:14.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:14.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:14.997 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:14.997 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:14.997 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:14.997 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:14.997 | Rithmic Direct - DTC (Data) | Failed connections: 3172
2025-01-08 12:31:14.997 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:14.998 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:14.998 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:14.998 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:14.998 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:15.246 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:15.246 | DTC Client socket (2) | Closed.
2025-01-08 12:31:16.991 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:16.991 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:16.991 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:16.992 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:16.992 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:16.992 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:17.234 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:17.234 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:17.234 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:17.234 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Failed connections: 3173
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:18.177 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:18.177 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:18.177 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:18.418 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:18.418 | DTC Client socket (2) | Closed.
2025-01-08 12:31:20.191 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:20.191 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:20.191 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:20.192 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:20.192 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:20.192 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:20.483 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:20.483 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:20.483 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:20.483 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:21.573 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:21.573 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:21.573 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:21.573 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:21.573 | Rithmic Direct - DTC (Data) | Failed connections: 3174
2025-01-08 12:31:21.573 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:21.574 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:21.574 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:21.574 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:21.574 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:21.865 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:21.865 | DTC Client socket (2) | Closed.
2025-01-08 12:31:23.570 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:23.570 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:23.570 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:23.570 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:23.571 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:23.571 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:23.896 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:23.896 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:23.896 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:23.896 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:25.088 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:25.088 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:25.088 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:25.088 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:25.088 | Rithmic Direct - DTC (Data) | Failed connections: 3175
2025-01-08 12:31:25.088 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:25.089 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:25.089 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:25.089 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:25.089 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:25.413 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:25.413 | DTC Client socket (2) | Closed.
2025-01-08 12:31:27.089 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:27.089 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:27.089 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:27.089 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:27.090 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:27.090 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:27.337 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:27.337 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:27.338 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:27.338 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Failed connections: 3176
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:28.295 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:28.295 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:28.295 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:28.541 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:28.541 | DTC Client socket (2) | Closed.
2025-01-08 12:31:30.292 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:30.292 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:30.292 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:30.292 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:30.292 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:30.292 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:31.595 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:31.595 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:31.595 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:31.595 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:33.309 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:33.309 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:33.309 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:33.309 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:33.309 | Rithmic Direct - DTC (Data) | Failed connections: 3177
2025-01-08 12:31:33.309 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:33.310 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:33.310 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:33.310 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:33.310 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:33.590 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:33.591 | DTC Client socket (2) | Closed.
2025-01-08 12:31:35.304 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:35.304 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:35.304 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:35.304 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:35.304 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:35.304 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:35.607 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:35.607 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:35.607 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:35.607 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:36.746 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:36.746 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:36.746 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:36.746 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:36.746 | Rithmic Direct - DTC (Data) | Failed connections: 3178
2025-01-08 12:31:36.746 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:36.747 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:36.747 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:36.747 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:36.747 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:37.051 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:37.052 | DTC Client socket (2) | Closed.
2025-01-08 12:31:38.738 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:38.739 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:38.739 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:38.740 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:38.740 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:38.740 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:39.029 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:39.030 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:39.030 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:39.030 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:40.118 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:40.118 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:40.118 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:40.118 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:40.118 | Rithmic Direct - DTC (Data) | Failed connections: 3179
2025-01-08 12:31:40.118 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:40.119 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:40.119 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:40.119 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:40.119 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:40.408 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:40.408 | DTC Client socket (2) | Closed.
2025-01-08 12:31:42.127 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:42.127 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:42.127 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:42.128 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:42.128 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:42.128 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:42.428 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:42.428 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:42.429 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:42.429 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:43.561 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:43.561 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:43.561 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:43.561 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:43.561 | Rithmic Direct - DTC (Data) | Failed connections: 3180
2025-01-08 12:31:43.561 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:43.562 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:43.562 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:43.562 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:43.562 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:43.863 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:43.863 | DTC Client socket (2) | Closed.
2025-01-08 12:31:45.563 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:45.563 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:45.563 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:45.564 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:45.564 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:45.564 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:45.854 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:45.854 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:45.854 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:45.854 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:46.943 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:46.943 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:46.943 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:46.943 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:46.943 | Rithmic Direct - DTC (Data) | Failed connections: 3181
2025-01-08 12:31:46.943 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:46.943 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:46.944 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:46.944 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:46.944 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:47.233 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:47.233 | DTC Client socket (2) | Closed.
2025-01-08 12:31:48.941 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:48.941 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:48.941 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:48.942 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:48.942 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:48.942 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:49.244 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:49.244 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:49.244 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:49.244 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:50.371 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:50.371 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:50.371 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:50.371 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:50.371 | Rithmic Direct - DTC (Data) | Failed connections: 3182
2025-01-08 12:31:50.371 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:50.372 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:50.372 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:50.372 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:50.372 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:50.670 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:50.670 | DTC Client socket (2) | Closed.
2025-01-08 12:31:52.372 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:52.372 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:52.372 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:52.372 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:52.373 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:52.373 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:52.669 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:52.669 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:52.669 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:52.669 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:53.775 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:53.775 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:53.775 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:53.775 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:53.775 | Rithmic Direct - DTC (Data) | Failed connections: 3183
2025-01-08 12:31:53.775 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:53.776 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:53.776 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:53.776 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:53.776 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:54.073 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:54.074 | DTC Client socket (2) | Closed.
2025-01-08 12:31:55.769 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:55.769 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:55.769 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:55.769 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:55.769 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:55.770 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:56.070 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:56.070 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:56.070 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:56.070 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Failed connections: 3184
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:31:57.182 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:31:57.182 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:31:57.182 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:31:57.477 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:31:57.477 | DTC Client socket (2) | Closed.
2025-01-08 12:31:59.176 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:31:59.176 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:31:59.176 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:31:59.177 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:31:59.177 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:31:59.177 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:31:59.472 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:31:59.472 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:31:59.472 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:31:59.472 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:00.575 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:00.575 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:00.575 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:00.575 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:00.575 | Rithmic Direct - DTC (Data) | Failed connections: 3185
2025-01-08 12:32:00.575 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:00.576 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:00.576 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:00.576 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:00.576 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:00.870 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:00.870 | DTC Client socket (2) | Closed.
2025-01-08 12:32:02.571 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:02.571 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:02.571 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:02.572 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:02.572 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:02.572 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:02.727 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048
2025-01-08 12:32:02.728 | DTC Client socket (3) | Creating socket.
2025-01-08 12:32:02.728 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:32:02.728 | DTC Client socket (3) | Connecting to IP: 208.185.224.131.
2025-01-08 12:32:02.874 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:02.874 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:02.875 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:02.875 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:02.903 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:32:02.903 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:32:02.904 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:32:03.104 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:32:03.104 | Denali Data Feed | Sending logon request message.
2025-01-08 12:32:03.292 | Denali Data Feed | Received logon response.
2025-01-08 12:32:03.292 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:32:03.292 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:03.292 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary.
2025-01-08 12:32:03.292 | Denali Data Feed | Failed connections: 225
2025-01-08 12:32:03.292 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:32:03.292 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:32:03.292 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:03.293 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:32:03.293 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 12:32:03.467 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:32:03.467 | DTC Client socket (3) | Closed.
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Failed connections: 3186
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:03.985 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:03.985 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:03.985 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:04.282 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:04.282 | DTC Client socket (2) | Closed.
2025-01-08 12:32:05.972 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:05.972 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:05.973 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:05.973 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:05.973 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:05.973 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:06.229 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:06.229 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:06.229 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:06.229 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:06.289 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:32:06.290 | DTC Client socket (3) | Creating socket.
2025-01-08 12:32:06.290 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:32:06.290 | DTC Client socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:32:06.451 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:32:06.451 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:32:06.451 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:32:06.638 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:32:06.638 | Denali Data Feed | Sending logon request message.
2025-01-08 12:32:07.185 | Denali Data Feed | Received logon response.
2025-01-08 12:32:07.185 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:32:07.185 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:07.185 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:32:07.185 | Denali Data Feed | Failed connections: 226
2025-01-08 12:32:07.185 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:32:07.185 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:32:07.185 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:32:07.185 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:32:07.185 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:07.268 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:07.268 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:07.268 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:07.268 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:07.268 | Rithmic Direct - DTC (Data) | Failed connections: 3187
2025-01-08 12:32:07.268 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:07.269 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:07.269 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:07.269 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:07.269 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:07.346 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:32:07.346 | DTC Client socket (3) | Closed.
2025-01-08 12:32:07.548 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:07.548 | DTC Client socket (2) | Closed.
2025-01-08 12:32:09.283 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:09.283 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:09.284 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:09.285 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:09.285 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:09.285 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:09.584 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:09.584 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:09.584 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:09.584 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:10.709 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:10.709 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:10.709 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:10.709 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:10.709 | Rithmic Direct - DTC (Data) | Failed connections: 3188
2025-01-08 12:32:10.709 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:10.710 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:10.710 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:10.710 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:10.710 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:11.009 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:11.009 | DTC Client socket (2) | Closed.
2025-01-08 12:32:12.716 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:12.716 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:12.716 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:12.717 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:12.717 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:12.717 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:12.986 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:12.986 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:12.986 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:12.986 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:14.026 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:14.026 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:14.026 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:14.026 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:14.026 | Rithmic Direct - DTC (Data) | Failed connections: 3189
2025-01-08 12:32:14.026 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:14.027 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:14.027 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:14.027 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:14.027 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:14.295 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:14.295 | DTC Client socket (2) | Closed.
2025-01-08 12:32:16.021 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:16.021 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:16.021 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:16.022 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:16.023 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:16.023 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:16.270 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:16.270 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:16.270 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:16.270 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:17.227 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:17.227 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:17.227 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:17.227 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:17.227 | Rithmic Direct - DTC (Data) | Failed connections: 3190
2025-01-08 12:32:17.227 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:17.227 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:17.228 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:17.228 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:17.228 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:17.473 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:17.473 | DTC Client socket (2) | Closed.
2025-01-08 12:32:19.225 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:19.225 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:19.225 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:19.226 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:19.226 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:19.226 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:19.490 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:19.490 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:19.490 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:19.490 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:20.538 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:20.538 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:20.538 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:20.538 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:20.538 | Rithmic Direct - DTC (Data) | Failed connections: 3191
2025-01-08 12:32:20.538 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:20.539 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:20.539 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:20.539 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:20.539 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:20.801 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:20.801 | DTC Client socket (2) | Closed.
2025-01-08 12:32:22.536 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:22.536 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:22.536 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:22.537 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:22.537 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:22.537 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:22.829 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:22.829 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:22.829 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:22.829 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:23.918 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:23.918 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:23.918 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:23.918 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:23.918 | Rithmic Direct - DTC (Data) | Failed connections: 3192
2025-01-08 12:32:23.918 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:23.919 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:23.919 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:23.919 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:23.919 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:24.208 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:24.209 | DTC Client socket (2) | Closed.
2025-01-08 12:32:25.916 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:25.916 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:25.916 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:25.917 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:25.917 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:25.917 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:26.217 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:26.217 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:26.217 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:26.217 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:27.340 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:27.340 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:27.340 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:27.340 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:27.340 | Rithmic Direct - DTC (Data) | Failed connections: 3193
2025-01-08 12:32:27.340 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:27.341 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:27.341 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:27.341 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:27.341 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:27.641 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:27.641 | DTC Client socket (2) | Closed.
2025-01-08 12:32:29.342 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:29.342 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:29.342 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:29.343 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:29.344 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:29.344 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:29.584 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:29.584 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:29.584 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:29.584 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:30.530 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:30.530 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:30.530 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:30.530 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:30.530 | Rithmic Direct - DTC (Data) | Failed connections: 3194
2025-01-08 12:32:30.530 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:30.531 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:30.531 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:30.531 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:30.531 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:30.771 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:30.772 | DTC Client socket (2) | Closed.
2025-01-08 12:32:32.528 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:32.528 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:32.528 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:32.529 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:32.529 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:32.529 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:32.778 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:32.778 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:32.778 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:32.778 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Failed connections: 3195
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:33.733 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:33.733 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:33.733 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:33.979 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:33.979 | DTC Client socket (2) | Closed.
2025-01-08 12:32:35.732 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:35.732 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:35.732 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:35.733 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:35.733 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:35.733 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:36.025 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:36.025 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:36.025 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:36.025 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:37.120 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:37.120 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:37.120 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:37.120 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:37.120 | Rithmic Direct - DTC (Data) | Failed connections: 3196
2025-01-08 12:32:37.120 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:37.121 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:37.121 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:37.121 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:37.121 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:37.412 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:37.412 | DTC Client socket (2) | Closed.
2025-01-08 12:32:39.115 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:39.115 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:39.115 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:39.116 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:39.116 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:39.116 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:39.500 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:39.500 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:39.501 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:39.501 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:40.966 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:40.966 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:40.966 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:40.966 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:40.966 | Rithmic Direct - DTC (Data) | Failed connections: 3197
2025-01-08 12:32:40.966 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:40.967 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:40.967 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:40.967 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:40.967 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:41.388 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:41.388 | DTC Client socket (2) | Closed.
2025-01-08 12:32:42.958 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:42.959 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:42.959 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:42.959 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:42.959 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:42.959 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:43.259 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:43.259 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:43.259 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:43.259 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:44.383 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:44.383 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:44.383 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:44.383 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:44.383 | Rithmic Direct - DTC (Data) | Failed connections: 3198
2025-01-08 12:32:44.383 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:44.384 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:44.384 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:44.384 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:44.384 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:44.683 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:44.683 | DTC Client socket (2) | Closed.
2025-01-08 12:32:46.380 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:46.380 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:46.381 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:46.381 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:46.381 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:46.381 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:46.662 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:46.662 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:46.663 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:46.663 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Failed connections: 3199
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:47.721 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:47.721 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:47.721 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:47.995 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:47.995 | DTC Client socket (2) | Closed.
2025-01-08 12:32:49.729 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:49.729 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:49.729 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:49.733 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:49.733 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:49.733 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:50.023 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:50.023 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:50.023 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:50.023 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:51.123 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:51.123 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:51.123 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:51.123 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:51.123 | Rithmic Direct - DTC (Data) | Failed connections: 3200
2025-01-08 12:32:51.123 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:51.123 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:51.123 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:51.124 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:51.124 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:51.412 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:51.412 | DTC Client socket (2) | Closed.
2025-01-08 12:32:53.120 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:53.120 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:53.120 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:53.120 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:53.120 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:53.120 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:53.416 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:53.416 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:53.416 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:53.416 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:54.524 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:54.524 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:54.524 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:54.524 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:54.524 | Rithmic Direct - DTC (Data) | Failed connections: 3201
2025-01-08 12:32:54.524 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:54.525 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:54.525 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:54.525 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:54.525 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:54.821 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:54.821 | DTC Client socket (2) | Closed.
2025-01-08 12:32:56.533 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:56.533 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:56.533 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:56.535 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:56.535 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:56.535 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:56.784 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:56.784 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:56.785 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:56.785 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Failed connections: 3202
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:32:57.749 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:32:57.749 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:32:57.749 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:32:57.998 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:32:57.999 | DTC Client socket (2) | Closed.
2025-01-08 12:32:59.747 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:32:59.747 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:32:59.747 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:32:59.748 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:32:59.748 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:32:59.748 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:32:59.996 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:32:59.996 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:32:59.996 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:32:59.996 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:00.966 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:00.966 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:00.966 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:00.966 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:00.966 | Rithmic Direct - DTC (Data) | Failed connections: 3203
2025-01-08 12:33:00.966 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:00.967 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:00.967 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:00.967 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:00.967 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:01.215 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:01.216 | DTC Client socket (2) | Closed.
2025-01-08 12:33:02.968 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:02.968 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:02.968 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:02.974 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:02.975 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:33:02.975 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:03.265 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:03.265 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:03.265 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:03.265 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:04.356 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:04.356 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:04.356 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:04.356 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:04.356 | Rithmic Direct - DTC (Data) | Failed connections: 3204
2025-01-08 12:33:04.356 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:04.357 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:33:04.357 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:04.357 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:04.357 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:04.647 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:33:04.647 | DTC Client socket (3) | Closed.
2025-01-08 12:33:06.360 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:06.360 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:06.360 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:06.361 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:06.361 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:06.361 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:06.604 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:06.604 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:06.604 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:06.604 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:07.175 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-01-08 12:33:07.175 | DTC Client socket (3) | Creating socket.
2025-01-08 12:33:07.175 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:33:07.175 | DTC Client socket (3) | Connecting to IP: 67.214.125.6.
2025-01-08 12:33:07.332 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:33:07.332 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:33:07.332 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:33:07.490 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:33:07.490 | Denali Data Feed | Sending logon request message.
2025-01-08 12:33:07.560 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:07.560 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:07.560 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:07.560 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:07.560 | Rithmic Direct - DTC (Data) | Failed connections: 3205
2025-01-08 12:33:07.560 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:07.561 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:07.561 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:07.561 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:07.561 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:07.803 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:07.803 | DTC Client socket (2) | Closed.
2025-01-08 12:33:08.035 | Denali Data Feed | Received logon response.
2025-01-08 12:33:08.035 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:33:08.035 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:08.035 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:33:08.035 | Denali Data Feed | Failed connections: 227
2025-01-08 12:33:08.035 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:33:08.036 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:33:08.036 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:33:08.036 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:33:08.036 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:08.191 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:33:08.191 | DTC Client socket (3) | Closed.
2025-01-08 12:33:09.551 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:09.551 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:09.551 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:09.552 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:09.552 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:09.552 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:09.844 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:09.844 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:09.844 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:09.844 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Failed connections: 3206
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:10.936 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:10.936 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:10.936 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:11.228 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:11.228 | DTC Client socket (2) | Closed.
2025-01-08 12:33:12.928 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:12.928 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:12.928 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:12.934 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:12.934 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:12.934 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:13.230 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:13.230 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:13.230 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:13.230 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Failed connections: 3207
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:14.340 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:14.340 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:14.340 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:14.636 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:14.636 | DTC Client socket (2) | Closed.
2025-01-08 12:33:16.340 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:16.340 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:16.340 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:16.340 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:16.340 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:16.340 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:16.589 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:16.589 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:16.589 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:16.589 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:17.559 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:17.559 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:17.559 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:17.559 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:17.559 | Rithmic Direct - DTC (Data) | Failed connections: 3208
2025-01-08 12:33:17.559 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:17.560 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:17.560 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:17.560 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:17.560 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:17.809 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:17.809 | DTC Client socket (2) | Closed.
2025-01-08 12:33:19.561 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:19.561 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:19.561 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:19.562 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:19.563 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:19.563 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:19.859 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:19.859 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:19.859 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:19.859 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:20.972 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:20.972 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:20.972 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:20.972 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:20.972 | Rithmic Direct - DTC (Data) | Failed connections: 3209
2025-01-08 12:33:20.972 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:20.973 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:20.973 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:20.973 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:20.973 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:21.268 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:21.269 | DTC Client socket (2) | Closed.
2025-01-08 12:33:22.977 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:22.977 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:22.977 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:22.977 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:22.977 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:22.977 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:23.273 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:23.273 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:23.273 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:23.273 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:24.392 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:24.392 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:24.392 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:24.392 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:24.392 | Rithmic Direct - DTC (Data) | Failed connections: 3210
2025-01-08 12:33:24.392 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:24.393 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:24.393 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:24.393 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:24.393 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:24.689 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:24.689 | DTC Client socket (2) | Closed.
2025-01-08 12:33:26.407 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:26.407 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:26.407 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:26.408 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:26.408 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:26.408 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:26.705 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:26.705 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:26.706 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:26.706 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:27.819 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:27.819 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:27.819 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:27.819 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:27.819 | Rithmic Direct - DTC (Data) | Failed connections: 3211
2025-01-08 12:33:27.819 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:27.820 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:27.820 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:27.820 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:27.820 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:28.117 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:28.117 | DTC Client socket (2) | Closed.
2025-01-08 12:33:29.826 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:29.826 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:29.826 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:29.827 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:29.827 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:29.827 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:30.216 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:30.216 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:30.217 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:30.217 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Failed connections: 3212
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:31.644 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:31.644 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:31.644 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:32.057 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:32.057 | DTC Client socket (2) | Closed.
2025-01-08 12:33:33.645 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:33.645 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:33.645 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:33.645 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:33.646 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:33.646 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:33.941 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:33.941 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:33.941 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:33.941 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Failed connections: 3213
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:35.050 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:35.050 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:35.050 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:35.345 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:35.345 | DTC Client socket (2) | Closed.
2025-01-08 12:33:37.049 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:37.049 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:37.049 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:37.050 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:37.051 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:37.051 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:37.343 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:37.343 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:37.343 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:37.343 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:38.449 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:38.449 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:38.449 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:38.449 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:38.449 | Rithmic Direct - DTC (Data) | Failed connections: 3214
2025-01-08 12:33:38.449 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:38.450 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:38.450 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:38.450 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:38.450 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:38.743 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:38.743 | DTC Client socket (2) | Closed.
2025-01-08 12:33:40.449 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:40.449 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:40.449 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:40.450 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:40.450 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:40.450 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:40.750 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:40.750 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:40.750 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:40.750 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:41.854 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:41.854 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:41.854 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:41.854 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:41.854 | Rithmic Direct - DTC (Data) | Failed connections: 3215
2025-01-08 12:33:41.854 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:41.855 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:41.855 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:41.855 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:41.855 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:42.149 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:42.149 | DTC Client socket (2) | Closed.
2025-01-08 12:33:43.855 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:43.855 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:43.855 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:43.856 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:43.857 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:43.857 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:44.106 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:44.106 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:44.106 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:44.106 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:45.073 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:45.073 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:45.073 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:45.073 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:45.073 | Rithmic Direct - DTC (Data) | Failed connections: 3216
2025-01-08 12:33:45.073 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:45.073 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:45.074 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:45.074 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:45.074 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:45.323 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:45.323 | DTC Client socket (2) | Closed.
2025-01-08 12:33:47.074 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:47.074 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:47.074 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:47.075 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:47.075 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:33:47.075 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:47.320 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:47.320 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:47.320 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:47.320 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:48.272 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:48.272 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:48.272 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:48.272 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:48.272 | Rithmic Direct - DTC (Data) | Failed connections: 3217
2025-01-08 12:33:48.273 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:48.273 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:33:48.273 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:48.273 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:48.274 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:48.518 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:33:48.518 | DTC Client socket (3) | Closed.
2025-01-08 12:33:50.273 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:50.273 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:50.273 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:50.274 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:50.274 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:50.274 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:50.571 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:50.571 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:50.571 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:50.571 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:51.688 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:51.688 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:51.688 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:51.688 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:51.688 | Rithmic Direct - DTC (Data) | Failed connections: 3218
2025-01-08 12:33:51.689 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:51.689 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:51.690 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:51.690 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:51.690 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:51.986 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:51.986 | DTC Client socket (2) | Closed.
2025-01-08 12:33:53.698 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:53.698 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:53.698 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:53.699 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:53.700 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:53.700 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:53.949 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:53.949 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:53.949 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:53.949 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:54.915 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:54.915 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:54.915 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:54.915 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:54.915 | Rithmic Direct - DTC (Data) | Failed connections: 3219
2025-01-08 12:33:54.915 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:54.915 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:54.915 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:54.916 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:54.916 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:55.164 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:55.164 | DTC Client socket (2) | Closed.
2025-01-08 12:33:56.915 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:33:56.915 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:33:56.915 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:33:56.916 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:33:56.916 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:33:56.916 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:33:57.160 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:33:57.160 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:33:57.160 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:33:57.160 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Failed connections: 3220
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:33:58.115 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:33:58.115 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:33:58.115 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:33:58.360 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:33:58.360 | DTC Client socket (2) | Closed.
2025-01-08 12:34:00.126 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:00.126 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:00.126 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:00.126 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:00.126 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:00.126 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:00.417 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:00.417 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:00.417 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:00.417 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:01.518 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:01.518 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:01.518 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:01.518 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:01.518 | Rithmic Direct - DTC (Data) | Failed connections: 3221
2025-01-08 12:34:01.518 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:01.519 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:01.519 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:01.519 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:01.519 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:01.814 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:01.814 | DTC Client socket (2) | Closed.
2025-01-08 12:34:03.522 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:03.522 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:03.522 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:03.523 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:03.523 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:03.523 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:03.822 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:03.822 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:03.822 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:03.822 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Failed connections: 3222
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:04.928 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:04.928 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:04.928 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:05.224 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:05.224 | DTC Client socket (2) | Closed.
2025-01-08 12:34:06.930 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:06.930 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:06.930 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:06.930 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:06.931 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:06.931 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:07.221 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:07.221 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:07.221 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:07.221 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:08.039 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:34:08.040 | DTC Client socket (3) | Creating socket.
2025-01-08 12:34:08.040 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:34:08.040 | DTC Client socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:34:08.197 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:34:08.197 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:34:08.197 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:34:08.310 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:08.310 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:08.310 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:08.310 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:08.310 | Rithmic Direct - DTC (Data) | Failed connections: 3223
2025-01-08 12:34:08.310 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:08.311 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:08.311 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:08.311 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:08.311 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:08.363 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:34:08.363 | Denali Data Feed | Sending logon request message.
2025-01-08 12:34:08.601 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:08.601 | DTC Client socket (2) | Closed.
2025-01-08 12:34:08.915 | Denali Data Feed | Received logon response.
2025-01-08 12:34:08.915 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:34:08.915 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:08.915 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:34:08.915 | Denali Data Feed | Failed connections: 228
2025-01-08 12:34:08.915 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:34:08.916 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:34:08.916 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:34:08.916 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:34:08.916 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:09.073 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:34:09.073 | DTC Client socket (3) | Closed.
2025-01-08 12:34:10.309 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:10.309 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:10.309 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:10.309 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:10.309 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:10.309 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:10.596 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:10.596 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:10.596 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:10.596 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:11.692 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:11.692 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:11.692 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:11.692 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:11.692 | Rithmic Direct - DTC (Data) | Failed connections: 3224
2025-01-08 12:34:11.692 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:11.693 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:11.693 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:11.693 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:11.693 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:11.978 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:11.978 | DTC Client socket (2) | Closed.
2025-01-08 12:34:13.700 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:13.700 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:13.700 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:13.701 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:13.701 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:13.701 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:13.948 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:13.948 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:13.948 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:13.948 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:14.898 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:14.898 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:14.898 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:14.898 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:14.898 | Rithmic Direct - DTC (Data) | Failed connections: 3225
2025-01-08 12:34:14.898 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:14.899 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:14.899 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:14.899 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:14.899 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:15.147 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:15.147 | DTC Client socket (2) | Closed.
2025-01-08 12:34:16.902 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:16.902 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:16.902 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:16.903 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:16.903 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:16.903 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:17.143 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:17.144 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:17.144 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:17.144 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Failed connections: 3226
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:18.086 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:18.086 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:18.086 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:18.326 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:18.326 | DTC Client socket (2) | Closed.
2025-01-08 12:34:20.088 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:20.088 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:20.088 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:20.088 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:20.088 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:20.088 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:20.380 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:20.380 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:20.380 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:20.380 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Failed connections: 3227
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:21.476 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:21.476 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:21.476 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:21.769 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:21.769 | DTC Client socket (2) | Closed.
2025-01-08 12:34:23.486 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:23.486 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:23.486 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:23.486 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:23.487 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:23.487 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:23.732 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:23.732 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:23.732 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:23.732 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:24.689 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:24.689 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:24.689 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:24.689 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:24.689 | Rithmic Direct - DTC (Data) | Failed connections: 3228
2025-01-08 12:34:24.689 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:24.690 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:24.690 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:24.690 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:24.690 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:24.936 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:24.936 | DTC Client socket (2) | Closed.
2025-01-08 12:34:26.695 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:26.695 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:26.695 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:26.696 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:26.696 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:26.696 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:26.982 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:26.982 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:26.982 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:26.982 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Failed connections: 3229
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:28.043 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:28.043 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:28.043 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:28.331 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:28.331 | DTC Client socket (2) | Closed.
2025-01-08 12:34:30.045 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:30.045 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:30.045 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:30.045 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:30.046 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:30.046 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:30.289 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:30.289 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:30.289 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:30.289 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:31.241 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:31.241 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:31.241 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:31.241 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:31.241 | Rithmic Direct - DTC (Data) | Failed connections: 3230
2025-01-08 12:34:31.241 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:31.242 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:31.242 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:31.242 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:31.242 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:31.486 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:31.486 | DTC Client socket (2) | Closed.
2025-01-08 12:34:33.242 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:33.242 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:33.242 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:33.244 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:33.244 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:33.244 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:33.523 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:33.523 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:33.523 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:33.523 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:34.583 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:34.583 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:34.583 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:34.583 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:34.583 | Rithmic Direct - DTC (Data) | Failed connections: 3231
2025-01-08 12:34:34.584 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:34.584 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:34.584 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:34.584 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:34.584 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:34.852 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:34.852 | DTC Client socket (2) | Closed.
2025-01-08 12:34:36.593 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:36.593 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:36.593 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:36.593 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:36.594 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:36.594 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:36.835 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:36.835 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:36.835 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:36.835 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Failed connections: 3232
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:37.778 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:37.778 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:37.778 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:38.019 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:38.019 | DTC Client socket (2) | Closed.
2025-01-08 12:34:39.769 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:39.769 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:39.769 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:39.770 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:39.770 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:39.770 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:40.063 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:40.063 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:40.063 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:40.063 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:41.158 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:41.158 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:41.158 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:41.158 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:41.158 | Rithmic Direct - DTC (Data) | Failed connections: 3233
2025-01-08 12:34:41.158 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:41.159 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:41.159 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:41.159 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:41.159 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:41.452 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:41.452 | DTC Client socket (2) | Closed.
2025-01-08 12:34:43.167 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:43.167 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:43.167 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:43.167 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:43.168 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:43.168 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:43.409 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:43.409 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:43.409 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:43.409 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Failed connections: 3234
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:44.351 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:44.351 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:44.351 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:44.592 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:44.593 | DTC Client socket (2) | Closed.
2025-01-08 12:34:46.354 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:46.354 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:46.354 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:46.355 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:46.355 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:46.355 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:46.600 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:46.600 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:46.600 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:46.600 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:47.565 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:47.565 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:47.565 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:47.565 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:47.565 | Rithmic Direct - DTC (Data) | Failed connections: 3235
2025-01-08 12:34:47.565 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:47.566 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:47.566 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:47.566 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:47.566 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:47.811 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:47.811 | DTC Client socket (2) | Closed.
2025-01-08 12:34:49.578 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:49.578 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:49.578 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:49.579 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:49.579 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:49.579 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:49.874 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:49.874 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:49.874 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:49.874 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Failed connections: 3236
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:50.976 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:50.976 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:50.977 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:51.270 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:51.270 | DTC Client socket (2) | Closed.
2025-01-08 12:34:52.986 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:52.986 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:52.986 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:52.987 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:52.987 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:52.987 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:53.273 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:53.273 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:53.273 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:53.273 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:54.332 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:54.332 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:54.332 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:54.332 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:54.332 | Rithmic Direct - DTC (Data) | Failed connections: 3237
2025-01-08 12:34:54.332 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:54.333 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:54.333 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:54.333 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:54.333 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:54.612 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:54.612 | DTC Client socket (2) | Closed.
2025-01-08 12:34:56.337 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:56.337 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:56.337 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:56.338 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:56.339 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:56.339 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:56.580 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:56.580 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:56.580 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:56.580 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:34:57.528 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:34:57.528 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:34:57.528 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:34:57.528 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:34:57.528 | Rithmic Direct - DTC (Data) | Failed connections: 3238
2025-01-08 12:34:57.528 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:34:57.529 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:34:57.529 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:34:57.529 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:34:57.529 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:34:57.770 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:34:57.770 | DTC Client socket (2) | Closed.
2025-01-08 12:34:59.529 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:34:59.529 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:34:59.529 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:34:59.705 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:34:59.705 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:34:59.705 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:34:59.947 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:34:59.947 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:34:59.947 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:34:59.947 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:00.903 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:00.903 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:00.903 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:00.903 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:00.903 | Rithmic Direct - DTC (Data) | Failed connections: 3239
2025-01-08 12:35:00.903 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:00.904 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:00.904 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:00.904 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:00.904 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:01.145 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:01.145 | DTC Client socket (2) | Closed.
2025-01-08 12:35:02.913 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:02.913 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:02.913 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:02.914 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:02.915 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:02.915 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:03.209 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:03.209 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:03.209 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:03.209 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:04.316 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:04.316 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:04.316 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:04.316 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:04.316 | Rithmic Direct - DTC (Data) | Failed connections: 3240
2025-01-08 12:35:04.316 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:04.317 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:04.317 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:04.317 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:04.318 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:04.610 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:04.611 | DTC Client socket (2) | Closed.
2025-01-08 12:35:06.327 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:06.327 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:06.327 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:06.328 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:06.328 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:06.328 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:06.620 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:06.620 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:06.620 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:06.620 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:07.716 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:07.716 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:07.716 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:07.716 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:07.716 | Rithmic Direct - DTC (Data) | Failed connections: 3241
2025-01-08 12:35:07.716 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:07.717 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:07.717 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:07.717 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:07.717 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:08.009 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:08.009 | DTC Client socket (2) | Closed.
2025-01-08 12:35:08.911 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443
2025-01-08 12:35:09.716 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:09.716 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:09.716 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:10.605 | DTC Client socket (2) | Creating socket.
2025-01-08 12:35:10.605 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:10.606 | DTC Client socket (2) | Connecting to IP: 64.152.155.21.
2025-01-08 12:35:10.606 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:10.606 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:35:10.606 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:10.767 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:35:10.767 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:35:10.768 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:35:10.847 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:10.847 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:10.848 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:10.848 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:10.945 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:35:10.945 | Denali Data Feed | Sending logon request message.
2025-01-08 12:35:11.465 | Denali Data Feed | Received logon response.
2025-01-08 12:35:11.465 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:35:11.465 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:11.465 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:35:11.465 | Denali Data Feed | Failed connections: 229
2025-01-08 12:35:11.465 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:35:11.465 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:11.465 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:11.465 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:35:11.465 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:35:11.626 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:11.626 | DTC Client socket (2) | Closed.
2025-01-08 12:35:11.792 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:11.792 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:11.792 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:11.792 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:11.792 | Rithmic Direct - DTC (Data) | Failed connections: 3242
2025-01-08 12:35:11.793 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:11.794 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:35:11.794 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:11.794 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:11.794 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:12.039 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:35:12.039 | DTC Client socket (3) | Closed.
2025-01-08 12:35:13.792 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:13.792 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:13.792 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:13.793 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:13.793 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:13.793 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:14.039 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:14.039 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:14.039 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:14.039 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Failed connections: 3243
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:14.983 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:14.983 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:14.983 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:15.225 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:15.225 | DTC Client socket (2) | Closed.
2025-01-08 12:35:16.984 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:16.984 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:16.984 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:16.984 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:16.984 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:16.984 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:17.277 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:17.277 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:17.277 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:17.277 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:18.373 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:18.373 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:18.373 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:18.373 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:18.373 | Rithmic Direct - DTC (Data) | Failed connections: 3244
2025-01-08 12:35:18.373 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:18.374 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:18.374 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:18.374 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:18.374 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:18.667 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:18.667 | DTC Client socket (2) | Closed.
2025-01-08 12:35:20.365 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:20.365 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:20.365 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:20.366 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:20.366 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:20.366 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:20.650 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:20.650 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:20.650 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:20.650 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:21.733 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:21.733 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:21.733 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:21.733 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:21.733 | Rithmic Direct - DTC (Data) | Failed connections: 3245
2025-01-08 12:35:21.733 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:21.734 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:21.734 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:21.734 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:21.734 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:22.008 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:22.008 | DTC Client socket (2) | Closed.
2025-01-08 12:35:23.727 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:23.727 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:23.727 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:23.728 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:23.728 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:23.728 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:23.970 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:23.970 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:23.970 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:23.970 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:24.914 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:24.914 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:24.914 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:24.914 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:24.914 | Rithmic Direct - DTC (Data) | Failed connections: 3246
2025-01-08 12:35:24.914 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:24.915 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:24.915 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:24.915 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:24.915 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:25.157 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:25.157 | DTC Client socket (2) | Closed.
2025-01-08 12:35:26.910 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:26.910 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:26.910 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:26.911 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:26.911 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:26.911 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:27.213 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:27.213 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:27.213 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:27.213 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:28.343 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:28.343 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:28.343 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:28.343 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:28.343 | Rithmic Direct - DTC (Data) | Failed connections: 3247
2025-01-08 12:35:28.343 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:28.344 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:28.344 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:28.344 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:28.344 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:28.645 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:28.645 | DTC Client socket (2) | Closed.
2025-01-08 12:35:30.339 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:30.339 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:30.339 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:30.340 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:30.340 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:30.340 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:30.582 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:30.582 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:30.582 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:30.582 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Failed connections: 3248
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:31.527 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:31.527 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:31.527 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:31.768 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:31.768 | DTC Client socket (2) | Closed.
2025-01-08 12:35:33.518 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:33.518 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:33.518 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:33.519 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:33.519 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:33.519 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:33.760 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:33.760 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:33.760 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:33.760 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:34.694 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:34.694 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:34.694 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:34.694 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:34.694 | Rithmic Direct - DTC (Data) | Failed connections: 3249
2025-01-08 12:35:34.694 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:34.695 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:34.695 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:34.695 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:34.695 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:34.933 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:34.933 | DTC Client socket (2) | Closed.
2025-01-08 12:35:36.692 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:36.692 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:36.692 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:36.693 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:36.694 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:36.694 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:36.945 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:36.945 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:36.945 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:36.945 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:37.923 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:37.923 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:37.923 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:37.923 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:37.923 | Rithmic Direct - DTC (Data) | Failed connections: 3250
2025-01-08 12:35:37.923 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:37.923 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:37.924 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:37.924 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:37.924 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:38.169 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:38.169 | DTC Client socket (2) | Closed.
2025-01-08 12:35:39.930 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:39.930 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:39.930 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:39.930 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:39.930 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:39.930 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:40.220 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:40.220 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:40.220 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:40.220 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Failed connections: 3251
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:41.309 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:41.309 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:41.309 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:41.599 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:41.599 | DTC Client socket (2) | Closed.
2025-01-08 12:35:43.320 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:43.320 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:43.320 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:43.321 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:43.321 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:43.321 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:43.601 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:43.601 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:43.602 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:43.602 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Failed connections: 3252
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:44.658 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:44.658 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:44.658 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:44.940 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:44.940 | DTC Client socket (2) | Closed.
2025-01-08 12:35:46.665 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:46.665 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:46.665 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:46.666 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:46.666 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:46.666 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:46.910 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:46.910 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:46.910 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:46.910 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:47.868 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:47.868 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:47.868 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:47.868 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:47.868 | Rithmic Direct - DTC (Data) | Failed connections: 3253
2025-01-08 12:35:47.868 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:47.869 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:47.869 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:47.869 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:47.869 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:48.113 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:48.113 | DTC Client socket (2) | Closed.
2025-01-08 12:35:49.861 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:49.861 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:49.861 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:49.862 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:49.862 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:49.862 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:50.271 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:50.271 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:50.271 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:50.271 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:51.549 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:51.549 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:51.549 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:51.549 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:51.549 | Rithmic Direct - DTC (Data) | Failed connections: 3254
2025-01-08 12:35:51.549 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:51.550 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:51.550 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:51.550 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:51.550 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:51.905 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:51.905 | DTC Client socket (2) | Closed.
2025-01-08 12:35:53.552 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:53.552 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:53.552 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:53.553 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:53.554 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:53.554 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:53.854 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:53.854 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:53.854 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:53.854 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:54.966 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:54.966 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:54.966 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:54.966 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:54.966 | Rithmic Direct - DTC (Data) | Failed connections: 3255
2025-01-08 12:35:54.967 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:54.967 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:54.967 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:54.967 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:54.967 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:55.263 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:55.263 | DTC Client socket (2) | Closed.
2025-01-08 12:35:56.957 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:35:56.957 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:35:56.957 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:35:56.958 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:35:56.959 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:35:56.959 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:35:57.251 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:35:57.251 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:35:57.251 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:35:57.251 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:35:58.347 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:35:58.347 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:35:58.347 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:35:58.347 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:35:58.347 | Rithmic Direct - DTC (Data) | Failed connections: 3256
2025-01-08 12:35:58.347 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:35:58.348 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:35:58.348 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:35:58.348 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:35:58.348 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:35:58.640 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:35:58.640 | DTC Client socket (2) | Closed.
2025-01-08 12:36:00.353 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:00.353 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:00.353 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:00.354 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:00.354 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:00.354 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:00.647 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:00.647 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:00.647 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:00.647 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:01.747 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:01.747 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:01.748 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:01.748 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:01.748 | Rithmic Direct - DTC (Data) | Failed connections: 3257
2025-01-08 12:36:01.748 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:01.748 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:01.748 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:01.748 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:01.748 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:02.040 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:02.040 | DTC Client socket (2) | Closed.
2025-01-08 12:36:03.750 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:03.750 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:03.750 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:03.750 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:03.750 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:03.750 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:03.987 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:03.987 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:03.987 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:03.987 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:04.923 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:04.923 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:04.923 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:04.923 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:04.923 | Rithmic Direct - DTC (Data) | Failed connections: 3258
2025-01-08 12:36:04.923 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:04.924 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:04.924 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:04.924 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:04.924 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:05.160 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:05.160 | DTC Client socket (2) | Closed.
2025-01-08 12:36:06.930 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:06.930 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:06.930 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:06.930 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:06.931 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:06.931 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:07.172 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:07.172 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:07.172 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:07.172 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:08.150 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:08.150 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:08.150 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:08.150 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:08.150 | Rithmic Direct - DTC (Data) | Failed connections: 3259
2025-01-08 12:36:08.150 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:08.151 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:08.151 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:08.151 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:08.151 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:08.392 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:08.392 | DTC Client socket (2) | Closed.
2025-01-08 12:36:10.145 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:10.145 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:10.145 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:10.146 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:10.147 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:10.147 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:10.429 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:10.429 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:10.429 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:10.429 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:11.469 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443
2025-01-08 12:36:11.504 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:11.504 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:11.504 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:11.504 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:11.504 | Rithmic Direct - DTC (Data) | Failed connections: 3260
2025-01-08 12:36:11.504 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:11.505 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:11.505 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:11.505 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:11.505 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:11.541 | DTC Client socket (3) | Creating socket.
2025-01-08 12:36:11.541 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:36:11.541 | DTC Client socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:36:11.702 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:36:11.702 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:36:11.703 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:36:11.789 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:11.789 | DTC Client socket (2) | Closed.
2025-01-08 12:36:11.887 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:36:11.887 | Denali Data Feed | Sending logon request message.
2025-01-08 12:36:12.418 | Denali Data Feed | Received logon response.
2025-01-08 12:36:12.418 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:36:12.418 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:12.418 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:36:12.418 | Denali Data Feed | Failed connections: 230
2025-01-08 12:36:12.418 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:36:12.419 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:36:12.419 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:36:12.419 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:36:12.419 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:12.578 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:36:12.578 | DTC Client socket (3) | Closed.
2025-01-08 12:36:13.504 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:13.504 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:13.504 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:13.505 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:13.506 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:13.506 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:13.800 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:13.800 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:13.800 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:13.800 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:14.913 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:14.913 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:14.913 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:14.913 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:14.913 | Rithmic Direct - DTC (Data) | Failed connections: 3261
2025-01-08 12:36:14.913 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:14.914 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:14.914 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:14.914 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:14.914 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:15.207 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:15.207 | DTC Client socket (2) | Closed.
2025-01-08 12:36:16.919 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:16.919 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:16.919 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:16.920 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:16.920 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:16.920 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:17.218 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:17.218 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:17.219 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:17.219 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:18.336 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:18.336 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:18.336 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:18.336 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:18.336 | Rithmic Direct - DTC (Data) | Failed connections: 3262
2025-01-08 12:36:18.336 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:18.337 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:18.337 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:18.337 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:18.337 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:18.635 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:18.636 | DTC Client socket (2) | Closed.
2025-01-08 12:36:20.343 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:20.343 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:20.343 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:20.344 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:20.345 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:20.345 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:20.637 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:20.637 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:20.637 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:20.637 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:21.737 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:21.737 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:21.737 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:21.737 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:21.737 | Rithmic Direct - DTC (Data) | Failed connections: 3263
2025-01-08 12:36:21.737 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:21.738 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:21.738 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:21.738 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:21.738 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:22.030 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:22.030 | DTC Client socket (2) | Closed.
2025-01-08 12:36:23.740 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:23.740 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:23.740 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:23.741 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:23.741 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:23.742 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:24.034 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:24.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:24.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:24.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:25.134 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:25.134 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:25.134 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:25.134 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:25.134 | Rithmic Direct - DTC (Data) | Failed connections: 3264
2025-01-08 12:36:25.134 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:25.135 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:25.135 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:25.135 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:25.135 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:25.426 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:25.426 | DTC Client socket (2) | Closed.
2025-01-08 12:36:27.149 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:27.150 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:27.150 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:27.151 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:27.151 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:27.151 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:27.406 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:27.406 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:27.406 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:27.406 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:28.370 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:28.370 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:28.370 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:28.370 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:28.370 | Rithmic Direct - DTC (Data) | Failed connections: 3265
2025-01-08 12:36:28.370 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:28.371 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:28.371 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:28.371 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:28.371 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:28.618 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:28.619 | DTC Client socket (2) | Closed.
2025-01-08 12:36:30.375 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:30.375 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:30.375 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:30.376 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:30.376 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:30.376 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:30.664 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:30.664 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:30.664 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:30.664 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:31.751 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:31.751 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:31.751 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:31.751 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:31.751 | Rithmic Direct - DTC (Data) | Failed connections: 3266
2025-01-08 12:36:31.752 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:31.752 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:31.752 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:31.752 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:31.753 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:32.041 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:32.041 | DTC Client socket (2) | Closed.
2025-01-08 12:36:33.762 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:33.762 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:33.762 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:33.763 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:33.763 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:33.763 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:34.013 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:34.013 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:34.013 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:34.013 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:34.981 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:34.981 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:34.981 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:34.981 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:34.981 | Rithmic Direct - DTC (Data) | Failed connections: 3267
2025-01-08 12:36:34.981 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:34.982 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:34.982 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:34.982 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:34.982 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:35.231 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:35.231 | DTC Client socket (2) | Closed.
2025-01-08 12:36:36.982 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:36.982 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:36.982 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:36.983 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:36.984 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:36.984 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:37.273 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:37.273 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:37.273 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:37.273 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Failed connections: 3268
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:38.350 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:38.350 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:38.351 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:38.639 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:38.639 | DTC Client socket (2) | Closed.
2025-01-08 12:36:40.351 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:40.351 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:40.351 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:40.351 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:40.352 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:40.352 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:40.589 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:40.589 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:40.589 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:40.589 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:41.521 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:41.521 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:41.521 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:41.521 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:41.521 | Rithmic Direct - DTC (Data) | Failed connections: 3269
2025-01-08 12:36:41.521 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:41.522 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:41.522 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:41.522 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:41.522 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:41.759 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:41.759 | DTC Client socket (2) | Closed.
2025-01-08 12:36:43.532 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:43.532 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:43.532 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:43.532 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:43.533 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:43.533 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:43.831 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:43.831 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:43.831 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:43.831 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:44.943 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:44.943 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:44.943 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:44.943 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:44.943 | Rithmic Direct - DTC (Data) | Failed connections: 3270
2025-01-08 12:36:44.943 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:44.944 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:44.944 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:44.944 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:44.944 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:45.242 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:45.242 | DTC Client socket (2) | Closed.
2025-01-08 12:36:46.953 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:46.953 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:46.953 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:46.954 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:46.954 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:36:46.954 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:47.193 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:47.193 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:47.194 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:47.194 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Failed connections: 3271
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:48.133 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:48.133 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:48.133 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:48.373 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:36:48.373 | DTC Client socket (3) | Closed.
2025-01-08 12:36:50.141 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:50.141 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:50.141 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:50.142 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:50.143 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:50.143 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:50.439 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:50.439 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:50.440 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:50.440 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:51.506 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:51.506 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:51.506 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:51.506 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:51.506 | Rithmic Direct - DTC (Data) | Failed connections: 3272
2025-01-08 12:36:51.506 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:51.507 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:51.507 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:51.507 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:51.507 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:51.790 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:51.790 | DTC Client socket (2) | Closed.
2025-01-08 12:36:53.511 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:53.511 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:53.512 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:53.512 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:53.513 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:53.513 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:53.763 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:53.763 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:53.763 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:53.763 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:54.725 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:54.725 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:54.725 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:54.725 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:54.725 | Rithmic Direct - DTC (Data) | Failed connections: 3273
2025-01-08 12:36:54.725 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:54.726 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:54.726 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:54.726 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:54.726 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:54.973 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:54.974 | DTC Client socket (2) | Closed.
2025-01-08 12:36:56.725 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:36:56.725 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:36:56.725 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:36:56.726 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:36:56.726 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:36:56.726 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:36:57.015 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:36:57.015 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:36:57.015 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:36:57.015 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:36:58.110 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:36:58.110 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:36:58.110 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:36:58.110 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:36:58.110 | Rithmic Direct - DTC (Data) | Failed connections: 3274
2025-01-08 12:36:58.110 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:36:58.111 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:36:58.111 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:36:58.112 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:36:58.112 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:36:58.401 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:36:58.401 | DTC Client socket (2) | Closed.
2025-01-08 12:37:00.122 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:00.122 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:00.122 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:00.122 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:00.123 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:00.123 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:00.414 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:00.414 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:00.414 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:00.414 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:01.509 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:01.509 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:01.509 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:01.509 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:01.509 | Rithmic Direct - DTC (Data) | Failed connections: 3275
2025-01-08 12:37:01.509 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:01.510 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:01.510 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:01.510 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:01.510 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:01.796 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:01.796 | DTC Client socket (2) | Closed.
2025-01-08 12:37:03.502 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:03.502 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:03.502 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:03.502 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:03.502 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:03.502 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:03.787 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:03.787 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:03.787 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:03.787 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:05.471 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:05.471 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:05.471 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:05.471 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:05.471 | Rithmic Direct - DTC (Data) | Failed connections: 3276
2025-01-08 12:37:05.471 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:05.472 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:05.472 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:05.472 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:05.472 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:05.754 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:05.754 | DTC Client socket (2) | Closed.
2025-01-08 12:37:07.472 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:07.472 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:07.472 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:07.473 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:07.473 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:07.473 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:07.720 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:07.720 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:07.720 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:07.720 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:08.684 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:08.684 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:08.684 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:08.684 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:08.684 | Rithmic Direct - DTC (Data) | Failed connections: 3277
2025-01-08 12:37:08.685 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:08.685 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:08.686 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:08.686 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:08.686 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:08.932 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:08.932 | DTC Client socket (2) | Closed.
2025-01-08 12:37:10.683 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:10.683 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:10.683 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:10.683 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:10.684 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:10.684 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:10.979 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:10.979 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:10.979 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:10.979 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:12.095 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:12.095 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:12.095 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:12.095 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:12.095 | Rithmic Direct - DTC (Data) | Failed connections: 3278
2025-01-08 12:37:12.095 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:12.096 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:12.096 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:12.096 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:12.096 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:12.392 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:12.392 | DTC Client socket (2) | Closed.
2025-01-08 12:37:12.416 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048
2025-01-08 12:37:12.417 | DTC Client socket (2) | Creating socket.
2025-01-08 12:37:12.417 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:12.417 | DTC Client socket (2) | Connecting to IP: 67.214.125.3.
2025-01-08 12:37:12.584 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:37:12.584 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:37:12.584 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:37:12.778 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:37:12.778 | Denali Data Feed | Sending logon request message.
2025-01-08 12:37:13.331 | Denali Data Feed | Received logon response.
2025-01-08 12:37:13.331 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:37:13.331 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:13.331 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:37:13.331 | Denali Data Feed | Failed connections: 231
2025-01-08 12:37:13.331 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:37:13.332 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:13.332 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:37:13.332 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:37:13.332 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:13.494 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:13.494 | DTC Client socket (2) | Closed.
2025-01-08 12:37:14.100 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:14.100 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:14.100 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:14.100 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:14.100 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:14.100 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:14.392 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:14.392 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:14.392 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:14.392 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:15.489 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:15.489 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:15.489 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:15.489 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:15.489 | Rithmic Direct - DTC (Data) | Failed connections: 3279
2025-01-08 12:37:15.489 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:15.490 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:15.490 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:15.490 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:15.490 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:15.781 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:15.782 | DTC Client socket (2) | Closed.
2025-01-08 12:37:17.500 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:17.500 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:17.500 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:17.501 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:17.501 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:17.501 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:17.797 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:17.797 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:17.797 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:17.797 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:18.906 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:18.906 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:18.906 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:18.906 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:18.906 | Rithmic Direct - DTC (Data) | Failed connections: 3280
2025-01-08 12:37:18.906 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:18.907 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:18.907 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:18.907 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:18.907 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:19.203 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:19.203 | DTC Client socket (2) | Closed.
2025-01-08 12:37:20.896 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:20.896 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:20.896 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:20.897 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:20.897 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:20.897 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:21.195 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:21.195 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:21.195 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:21.195 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:22.315 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:22.315 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:22.315 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:22.315 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:22.315 | Rithmic Direct - DTC (Data) | Failed connections: 3281
2025-01-08 12:37:22.315 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:22.316 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:22.316 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:22.316 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:22.316 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:22.613 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:22.613 | DTC Client socket (2) | Closed.
2025-01-08 12:37:24.321 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:24.321 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:24.321 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:24.322 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:24.322 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:24.322 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:24.617 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:24.617 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:24.617 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:24.617 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:26.361 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:26.361 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:26.361 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:26.361 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:26.361 | Rithmic Direct - DTC (Data) | Failed connections: 3282
2025-01-08 12:37:26.361 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:26.362 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:26.362 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:26.362 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:26.362 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:26.657 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:26.657 | DTC Client socket (2) | Closed.
2025-01-08 12:37:28.375 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:28.375 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:28.376 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:28.377 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:28.377 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:28.377 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:28.673 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:28.673 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:28.673 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:28.673 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:29.779 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:29.779 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:29.779 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:29.779 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:29.779 | Rithmic Direct - DTC (Data) | Failed connections: 3283
2025-01-08 12:37:29.779 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:29.780 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:29.780 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:29.780 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:29.780 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:30.075 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:30.075 | DTC Client socket (2) | Closed.
2025-01-08 12:37:31.776 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:31.776 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:31.776 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:31.776 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:31.776 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:31.776 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:32.075 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:32.075 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:32.075 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:32.075 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Failed connections: 3284
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:33.198 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:33.198 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:33.199 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:33.497 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:33.497 | DTC Client socket (2) | Closed.
2025-01-08 12:37:35.193 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:35.193 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:35.193 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:35.194 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:35.194 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:35.194 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:35.451 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:35.451 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:35.451 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:35.451 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:36.421 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:36.421 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:36.421 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:36.421 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:36.421 | Rithmic Direct - DTC (Data) | Failed connections: 3285
2025-01-08 12:37:36.421 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:36.422 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:36.422 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:36.422 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:36.422 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:36.673 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:36.673 | DTC Client socket (2) | Closed.
2025-01-08 12:37:38.415 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:38.415 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:38.415 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:38.416 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:38.416 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:38.416 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:38.708 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:38.708 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:38.708 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:38.708 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:39.814 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:39.814 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:39.814 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:39.814 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:39.814 | Rithmic Direct - DTC (Data) | Failed connections: 3286
2025-01-08 12:37:39.814 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:39.816 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:39.816 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:39.816 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:39.816 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:40.109 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:40.109 | DTC Client socket (2) | Closed.
2025-01-08 12:37:41.818 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:41.818 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:41.818 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:41.819 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:41.819 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:41.819 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:43.111 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:43.111 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:43.111 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:43.111 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:44.773 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:44.773 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:44.773 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:44.773 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:44.773 | Rithmic Direct - DTC (Data) | Failed connections: 3287
2025-01-08 12:37:44.773 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:44.774 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:44.774 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:44.774 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:44.774 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:45.053 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:45.053 | DTC Client socket (2) | Closed.
2025-01-08 12:37:46.781 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:46.781 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:46.781 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:46.782 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:46.782 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:46.782 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:47.032 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:47.032 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:47.032 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:47.032 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:48.001 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:48.001 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:48.001 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:48.001 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:48.001 | Rithmic Direct - DTC (Data) | Failed connections: 3288
2025-01-08 12:37:48.001 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:48.002 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:48.002 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:48.002 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:48.002 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:48.251 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:48.251 | DTC Client socket (2) | Closed.
2025-01-08 12:37:50.009 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:50.009 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:50.009 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:50.010 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:50.011 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:50.011 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:50.299 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:50.299 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:50.299 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:50.299 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:51.518 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:51.518 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:51.518 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:51.518 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:51.518 | Rithmic Direct - DTC (Data) | Failed connections: 3289
2025-01-08 12:37:51.518 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:51.519 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:51.519 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:51.519 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:51.519 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:51.807 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:51.807 | DTC Client socket (2) | Closed.
2025-01-08 12:37:53.527 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:53.527 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:53.527 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:53.527 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:53.527 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:53.528 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:53.775 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:53.775 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:53.775 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:53.775 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:54.742 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:54.742 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:54.742 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:54.742 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:54.742 | Rithmic Direct - DTC (Data) | Failed connections: 3290
2025-01-08 12:37:54.742 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:54.743 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:54.743 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:54.743 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:54.743 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:54.991 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:54.991 | DTC Client socket (2) | Closed.
2025-01-08 12:37:56.749 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:37:56.749 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:37:56.749 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:37:56.749 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:37:56.749 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:37:56.749 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:37:57.041 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:37:57.041 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:37:57.041 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:37:57.041 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:37:58.137 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:37:58.137 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:37:58.137 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:37:58.137 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:37:58.137 | Rithmic Direct - DTC (Data) | Failed connections: 3291
2025-01-08 12:37:58.137 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:37:58.138 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:37:58.138 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:37:58.138 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:37:58.138 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:37:58.430 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:37:58.430 | DTC Client socket (2) | Closed.
2025-01-08 12:38:00.139 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:00.139 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:00.139 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:00.140 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:00.140 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:00.140 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:00.385 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:00.385 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:00.385 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:00.385 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Failed connections: 3292
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:01.344 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:01.344 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:01.345 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:01.591 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:01.591 | DTC Client socket (2) | Closed.
2025-01-08 12:38:03.330 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:03.330 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:03.330 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:03.331 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:03.331 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:38:03.331 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:03.726 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:03.726 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:03.726 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:03.726 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:05.102 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:05.102 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:05.102 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:05.102 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:05.102 | Rithmic Direct - DTC (Data) | Failed connections: 3293
2025-01-08 12:38:05.102 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:05.103 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:38:05.103 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:05.103 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:05.103 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:05.466 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:38:05.466 | DTC Client socket (3) | Closed.
2025-01-08 12:38:07.118 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:07.118 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:07.118 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:07.119 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:07.119 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:07.119 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:07.369 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:07.369 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:07.369 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:07.369 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:08.352 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:08.352 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:08.352 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:08.352 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:08.352 | Rithmic Direct - DTC (Data) | Failed connections: 3294
2025-01-08 12:38:08.352 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:08.353 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:08.353 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:08.353 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:08.353 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:08.597 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:08.598 | DTC Client socket (2) | Closed.
2025-01-08 12:38:10.357 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:10.357 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:10.358 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:10.358 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:10.358 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:10.358 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:10.599 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:10.599 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:10.599 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:10.599 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:11.567 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:11.567 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:11.567 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:11.567 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:11.567 | Rithmic Direct - DTC (Data) | Failed connections: 3295
2025-01-08 12:38:11.567 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:11.568 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:11.568 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:11.568 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:11.568 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:11.808 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:11.808 | DTC Client socket (2) | Closed.
2025-01-08 12:38:13.343 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-01-08 12:38:13.344 | DTC Client socket (2) | Creating socket.
2025-01-08 12:38:13.344 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:13.344 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-01-08 12:38:13.501 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:38:13.501 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:38:13.501 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:38:13.577 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:13.577 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:13.577 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:13.578 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:13.579 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:38:13.579 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:13.682 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:38:13.682 | Denali Data Feed | Sending logon request message.
2025-01-08 12:38:13.827 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:13.827 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:13.827 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:13.827 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:14.277 | Denali Data Feed | Received logon response.
2025-01-08 12:38:14.277 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:38:14.277 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:14.277 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:38:14.277 | Denali Data Feed | Failed connections: 232
2025-01-08 12:38:14.277 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:38:14.278 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:14.278 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:38:14.278 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:38:14.278 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:14.434 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:14.434 | DTC Client socket (2) | Closed.
2025-01-08 12:38:14.792 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:14.792 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:14.792 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:14.792 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:14.792 | Rithmic Direct - DTC (Data) | Failed connections: 3296
2025-01-08 12:38:14.792 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:14.793 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:38:14.793 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:14.793 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:14.793 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:15.043 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:38:15.043 | DTC Client socket (3) | Closed.
2025-01-08 12:38:16.791 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:16.791 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:16.791 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:16.792 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:16.792 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:16.792 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:17.087 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:17.087 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:17.087 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:17.087 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:18.196 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:18.196 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:18.196 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:18.196 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:18.196 | Rithmic Direct - DTC (Data) | Failed connections: 3297
2025-01-08 12:38:18.196 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:18.197 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:18.197 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:18.197 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:18.197 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:18.490 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:18.491 | DTC Client socket (2) | Closed.
2025-01-08 12:38:20.193 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:20.193 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:20.193 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:20.194 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:20.194 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:20.194 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:20.444 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:20.444 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:20.444 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:20.444 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:21.391 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:21.391 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:21.391 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:21.391 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:21.391 | Rithmic Direct - DTC (Data) | Failed connections: 3298
2025-01-08 12:38:21.391 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:21.392 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:21.392 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:21.392 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:21.392 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:21.634 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:21.635 | DTC Client socket (2) | Closed.
2025-01-08 12:38:23.381 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:23.381 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:23.381 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:23.382 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:23.382 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:23.382 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:23.632 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:23.632 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:23.632 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:23.632 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:24.598 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:24.598 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:24.598 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:24.598 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:24.598 | Rithmic Direct - DTC (Data) | Failed connections: 3299
2025-01-08 12:38:24.598 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:24.599 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:24.599 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:24.599 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:24.599 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:24.848 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:24.848 | DTC Client socket (2) | Closed.
2025-01-08 12:38:26.598 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:26.598 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:26.598 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:26.623 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:26.623 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:26.623 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:26.918 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:26.918 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:26.918 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:26.918 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Failed connections: 3300
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:28.034 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:28.034 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:28.034 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:28.330 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:28.330 | DTC Client socket (2) | Closed.
2025-01-08 12:38:30.042 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:30.043 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:30.043 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:30.043 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:30.044 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:30.044 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:30.335 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:30.335 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:30.335 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:30.335 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:31.436 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:31.436 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:31.436 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:31.436 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:31.436 | Rithmic Direct - DTC (Data) | Failed connections: 3301
2025-01-08 12:38:31.436 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:31.437 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:31.437 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:31.437 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:31.437 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:31.728 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:31.728 | DTC Client socket (2) | Closed.
2025-01-08 12:38:33.444 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:33.444 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:33.444 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:33.444 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:33.445 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:33.445 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:33.680 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:33.680 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:33.680 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:33.680 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:34.615 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:34.615 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:34.615 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:34.615 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:34.615 | Rithmic Direct - DTC (Data) | Failed connections: 3302
2025-01-08 12:38:34.615 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:34.616 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:34.616 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:34.616 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:34.616 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:34.854 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:34.855 | DTC Client socket (2) | Closed.
2025-01-08 12:38:36.621 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:36.621 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:36.621 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:36.622 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:36.622 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:36.622 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:36.917 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:36.917 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:36.917 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:36.917 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:38.017 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:38.017 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:38.017 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:38.017 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:38.017 | Rithmic Direct - DTC (Data) | Failed connections: 3303
2025-01-08 12:38:38.017 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:38.018 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:38.018 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:38.018 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:38.018 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:38.311 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:38.312 | DTC Client socket (2) | Closed.
2025-01-08 12:38:40.018 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:40.018 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:40.018 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:40.019 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:40.019 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:40.019 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:40.255 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:40.255 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:40.256 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:40.256 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:41.180 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:41.180 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:41.180 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:41.180 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:41.180 | Rithmic Direct - DTC (Data) | Failed connections: 3304
2025-01-08 12:38:41.180 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:41.181 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:41.181 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:41.181 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:41.181 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:41.417 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:41.417 | DTC Client socket (2) | Closed.
2025-01-08 12:38:43.179 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:43.179 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:43.179 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:43.180 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:43.180 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:43.180 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:43.417 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:43.417 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:43.418 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:43.418 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Failed connections: 3305
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:44.357 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:44.357 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:44.357 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:44.597 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:44.597 | DTC Client socket (2) | Closed.
2025-01-08 12:38:46.361 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:46.361 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:46.361 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:46.361 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:46.361 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:46.361 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:46.658 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:46.658 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:46.659 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:46.659 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Failed connections: 3306
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:47.781 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:47.781 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:47.781 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:48.079 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:48.079 | DTC Client socket (2) | Closed.
2025-01-08 12:38:49.782 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:49.782 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:49.783 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:49.783 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:49.783 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:49.783 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:50.034 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:50.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:50.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:50.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:51.007 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:51.007 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:51.007 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:51.007 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:51.007 | Rithmic Direct - DTC (Data) | Failed connections: 3307
2025-01-08 12:38:51.007 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:51.008 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:51.008 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:51.008 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:51.008 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:51.260 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:51.261 | DTC Client socket (2) | Closed.
2025-01-08 12:38:53.005 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:53.005 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:53.005 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:53.006 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:53.007 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:53.007 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:53.253 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:53.253 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:53.253 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:53.253 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:54.212 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:54.212 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:54.212 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:54.212 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:54.212 | Rithmic Direct - DTC (Data) | Failed connections: 3308
2025-01-08 12:38:54.212 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:54.213 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:54.213 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:54.213 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:54.213 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:54.458 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:54.458 | DTC Client socket (2) | Closed.
2025-01-08 12:38:56.217 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:56.217 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:56.217 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:56.218 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:56.218 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:56.218 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:56.463 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:56.463 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:56.463 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:56.463 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:38:57.413 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:38:57.413 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:38:57.413 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:38:57.413 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:38:57.413 | Rithmic Direct - DTC (Data) | Failed connections: 3309
2025-01-08 12:38:57.413 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:38:57.414 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:38:57.414 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:38:57.414 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:38:57.414 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:38:57.655 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:38:57.655 | DTC Client socket (2) | Closed.
2025-01-08 12:38:59.409 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:38:59.409 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:38:59.409 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:38:59.410 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:38:59.411 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:38:59.411 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:38:59.698 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:38:59.698 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:38:59.698 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:38:59.698 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:00.793 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:00.793 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:00.793 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:00.793 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:00.793 | Rithmic Direct - DTC (Data) | Failed connections: 3310
2025-01-08 12:39:00.793 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:00.794 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:00.794 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:00.794 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:00.794 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:01.082 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:01.082 | DTC Client socket (2) | Closed.
2025-01-08 12:39:02.784 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:02.784 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:02.784 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:02.785 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:02.785 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:02.785 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:03.079 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:03.079 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:03.079 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:03.079 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:04.183 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:04.183 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:04.183 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:04.183 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:04.183 | Rithmic Direct - DTC (Data) | Failed connections: 3311
2025-01-08 12:39:04.183 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:04.184 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:04.184 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:04.184 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:04.184 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:04.478 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:04.479 | DTC Client socket (2) | Closed.
2025-01-08 12:39:06.185 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:06.185 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:06.185 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:06.186 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:06.186 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:06.186 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:06.429 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:06.429 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:06.430 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:06.430 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Failed connections: 3312
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:07.377 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:07.377 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:07.377 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:07.620 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:07.620 | DTC Client socket (2) | Closed.
2025-01-08 12:39:09.382 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:09.382 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:09.382 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:09.383 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:09.383 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:09.383 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:09.673 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:09.673 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:09.673 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:09.673 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:10.767 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:10.767 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:10.767 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:10.767 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:10.767 | Rithmic Direct - DTC (Data) | Failed connections: 3313
2025-01-08 12:39:10.767 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:10.768 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:10.768 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:10.768 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:10.768 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:11.059 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:11.059 | DTC Client socket (2) | Closed.
2025-01-08 12:39:12.780 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:12.780 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:12.780 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:12.781 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:12.781 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:12.781 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:13.074 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:13.074 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:13.074 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:13.074 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Failed connections: 3314
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:14.175 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:14.175 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:14.175 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:14.273 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 10048
2025-01-08 12:39:14.405 | DTC Client socket (3) | Creating socket.
2025-01-08 12:39:14.405 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:39:14.405 | DTC Client socket (3) | Connecting to IP: 64.152.155.20.
2025-01-08 12:39:14.469 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:14.469 | DTC Client socket (2) | Closed.
2025-01-08 12:39:14.565 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:39:14.565 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:39:14.565 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:39:14.753 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:39:14.753 | Denali Data Feed | Sending logon request message.
2025-01-08 12:39:15.271 | Denali Data Feed | Received logon response.
2025-01-08 12:39:15.271 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:39:15.271 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:15.271 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:39:15.271 | Denali Data Feed | Failed connections: 233
2025-01-08 12:39:15.271 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:39:15.271 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:39:15.271 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:15.272 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:39:15.272 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:39:15.430 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:39:15.431 | DTC Client socket (3) | Closed.
2025-01-08 12:39:16.188 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:16.188 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:16.188 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:16.189 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:16.189 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:16.189 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:16.431 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:16.431 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:16.431 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:16.431 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Failed connections: 3315
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:17.376 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:17.376 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:17.376 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:17.618 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:17.618 | DTC Client socket (2) | Closed.
2025-01-08 12:39:19.377 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:19.377 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:19.377 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:19.377 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:19.378 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:19.378 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:19.626 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:19.626 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:19.626 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:19.626 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Failed connections: 3316
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:20.591 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:20.591 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:20.591 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:20.840 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:20.840 | DTC Client socket (2) | Closed.
2025-01-08 12:39:22.592 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:22.592 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:22.592 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:22.592 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:22.592 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:22.593 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:22.838 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:22.838 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:22.838 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:22.838 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:23.853 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:23.853 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:23.853 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:23.853 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:23.853 | Rithmic Direct - DTC (Data) | Failed connections: 3317
2025-01-08 12:39:23.854 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:23.855 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:23.855 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:23.855 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:23.855 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:24.099 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:24.099 | DTC Client socket (2) | Closed.
2025-01-08 12:39:25.862 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:25.862 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:25.862 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:25.862 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:25.862 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:25.862 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:26.109 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:26.109 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:26.109 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:26.109 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:27.072 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:27.072 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:27.072 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:27.072 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:27.072 | Rithmic Direct - DTC (Data) | Failed connections: 3318
2025-01-08 12:39:27.072 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:27.072 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:27.072 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:27.073 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:27.073 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:27.320 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:27.320 | DTC Client socket (2) | Closed.
2025-01-08 12:39:29.080 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:29.080 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:29.080 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:29.081 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:29.081 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:29.081 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:29.383 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:29.383 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:29.383 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:29.383 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:30.486 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:30.486 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:30.486 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:30.486 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:30.486 | Rithmic Direct - DTC (Data) | Failed connections: 3319
2025-01-08 12:39:30.486 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:30.487 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:30.487 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:30.487 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:30.487 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:30.785 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:30.785 | DTC Client socket (2) | Closed.
2025-01-08 12:39:32.494 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:32.494 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:32.494 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:32.495 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:32.495 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:32.495 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:33.795 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:33.795 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:33.795 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:33.795 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:34.885 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:34.885 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:34.885 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:34.885 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:34.885 | Rithmic Direct - DTC (Data) | Failed connections: 3320
2025-01-08 12:39:34.885 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:34.886 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:34.886 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:34.886 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:34.886 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:35.177 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:35.177 | DTC Client socket (2) | Closed.
2025-01-08 12:39:36.878 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:36.878 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:36.878 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:36.879 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:36.879 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:36.879 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:37.175 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:37.175 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:37.175 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:37.175 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:38.277 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:38.277 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:38.277 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:38.277 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:38.277 | Rithmic Direct - DTC (Data) | Failed connections: 3321
2025-01-08 12:39:38.278 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:38.278 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:38.278 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:38.278 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:38.279 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:38.574 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:38.574 | DTC Client socket (2) | Closed.
2025-01-08 12:39:40.270 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:40.270 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:40.270 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:40.271 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:40.271 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:40.271 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:40.562 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:40.562 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:40.562 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:40.562 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Failed connections: 3322
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:41.657 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:41.657 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:41.657 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:41.947 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:41.947 | DTC Client socket (2) | Closed.
2025-01-08 12:39:43.650 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:43.650 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:43.650 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:43.651 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:43.651 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:43.651 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:43.960 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:43.960 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:43.960 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:43.960 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:45.064 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:45.064 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:45.064 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:45.064 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:45.064 | Rithmic Direct - DTC (Data) | Failed connections: 3323
2025-01-08 12:39:45.064 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:45.065 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:45.065 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:45.065 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:45.065 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:45.359 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:45.359 | DTC Client socket (2) | Closed.
2025-01-08 12:39:47.068 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:47.068 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:47.068 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:47.069 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:47.070 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:39:47.070 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:47.358 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:47.358 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:47.358 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:47.358 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:48.449 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:48.449 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:48.449 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:48.449 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:48.449 | Rithmic Direct - DTC (Data) | Failed connections: 3324
2025-01-08 12:39:48.449 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:48.450 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:39:48.450 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:48.450 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:48.450 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:48.738 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:39:48.738 | DTC Client socket (3) | Closed.
2025-01-08 12:39:50.453 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:50.453 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:50.453 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:50.454 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:50.454 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:50.454 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:50.689 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:50.689 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:50.690 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:50.690 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:51.625 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:51.625 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:51.625 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:51.625 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:51.625 | Rithmic Direct - DTC (Data) | Failed connections: 3325
2025-01-08 12:39:51.625 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:51.626 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:51.626 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:51.626 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:51.626 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:51.862 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:51.863 | DTC Client socket (2) | Closed.
2025-01-08 12:39:53.621 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:53.621 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:53.621 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:53.622 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:53.622 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:53.622 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:53.904 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:53.904 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:53.904 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:53.904 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:54.982 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:54.982 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:54.982 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:54.982 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:54.982 | Rithmic Direct - DTC (Data) | Failed connections: 3326
2025-01-08 12:39:54.983 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:54.983 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:54.983 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:54.983 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:54.983 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:55.267 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:55.267 | DTC Client socket (2) | Closed.
2025-01-08 12:39:56.979 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:39:56.979 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:39:56.979 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:39:56.980 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:39:56.981 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:39:56.981 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:39:57.278 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:39:57.278 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:39:57.278 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:39:57.278 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:39:58.387 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:39:58.387 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:39:58.387 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:39:58.387 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:39:58.387 | Rithmic Direct - DTC (Data) | Failed connections: 3327
2025-01-08 12:39:58.387 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:39:58.387 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:39:58.388 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:39:58.388 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:39:58.388 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:39:58.686 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:39:58.686 | DTC Client socket (2) | Closed.
2025-01-08 12:40:00.381 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:00.381 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:00.381 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:00.540 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:00.541 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:00.541 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:01.828 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:01.828 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:01.828 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:01.828 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:02.894 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:02.894 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:02.894 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:02.894 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:02.894 | Rithmic Direct - DTC (Data) | Failed connections: 3328
2025-01-08 12:40:02.895 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:02.895 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:02.896 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:02.896 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:02.896 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:03.176 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:03.176 | DTC Client socket (2) | Closed.
2025-01-08 12:40:04.896 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:04.896 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:04.896 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:04.896 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:04.896 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:04.896 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:05.142 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:05.142 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:05.142 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:05.142 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:06.100 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:06.100 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:06.100 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:06.100 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:06.100 | Rithmic Direct - DTC (Data) | Failed connections: 3329
2025-01-08 12:40:06.100 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:06.101 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:06.101 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:06.101 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:06.101 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:06.345 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:06.345 | DTC Client socket (2) | Closed.
2025-01-08 12:40:08.100 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:08.100 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:08.100 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:08.100 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:08.101 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:08.101 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:08.399 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:08.399 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:08.399 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:08.399 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:09.513 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:09.513 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:09.513 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:09.513 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:09.513 | Rithmic Direct - DTC (Data) | Failed connections: 3330
2025-01-08 12:40:09.513 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:09.514 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:09.514 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:09.514 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:09.514 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:09.812 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:09.812 | DTC Client socket (2) | Closed.
2025-01-08 12:40:11.502 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:11.502 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:11.502 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:11.503 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:11.503 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:11.503 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:11.804 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:11.804 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:11.804 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:11.804 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:12.916 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:12.916 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:12.916 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:12.916 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:12.916 | Rithmic Direct - DTC (Data) | Failed connections: 3331
2025-01-08 12:40:12.916 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:12.917 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:12.917 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:12.917 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:12.917 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:13.215 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:13.215 | DTC Client socket (2) | Closed.
2025-01-08 12:40:14.910 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:14.910 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:14.910 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:14.911 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:14.911 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:14.911 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:15.208 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:15.208 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:15.208 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:15.208 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:15.289 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 443
2025-01-08 12:40:15.290 | DTC Client socket (3) | Creating socket.
2025-01-08 12:40:15.290 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:40:15.290 | DTC Client socket (3) | Connecting to IP: 67.214.125.4.
2025-01-08 12:40:15.458 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:40:15.458 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:40:15.458 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:40:15.635 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:40:15.635 | Denali Data Feed | Sending logon request message.
2025-01-08 12:40:16.174 | Denali Data Feed | Received logon response.
2025-01-08 12:40:16.174 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:40:16.174 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:16.174 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:40:16.174 | Denali Data Feed | Failed connections: 234
2025-01-08 12:40:16.174 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:40:16.175 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:40:16.175 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:40:16.175 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:40:16.175 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:16.330 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:40:16.330 | DTC Client socket (3) | Closed.
2025-01-08 12:40:16.331 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:16.331 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:16.331 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:16.331 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:16.331 | Rithmic Direct - DTC (Data) | Failed connections: 3332
2025-01-08 12:40:16.331 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:16.332 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:16.332 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:16.332 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:16.332 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:16.630 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:16.630 | DTC Client socket (2) | Closed.
2025-01-08 12:40:18.337 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:18.337 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:18.337 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:18.338 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:18.338 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:18.338 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:18.579 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:18.579 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:18.580 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:18.580 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:19.519 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:19.519 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:19.519 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:19.519 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:19.519 | Rithmic Direct - DTC (Data) | Failed connections: 3333
2025-01-08 12:40:19.519 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:19.520 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:19.520 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:19.520 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:19.520 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:19.760 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:19.761 | DTC Client socket (2) | Closed.
2025-01-08 12:40:21.519 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:21.519 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:21.519 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:21.519 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:21.519 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:21.519 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:21.763 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:21.763 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:21.763 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:21.763 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:22.711 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:22.711 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:22.711 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:22.711 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:22.711 | Rithmic Direct - DTC (Data) | Failed connections: 3334
2025-01-08 12:40:22.711 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:22.712 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:22.712 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:22.712 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:22.712 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:22.953 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:22.953 | DTC Client socket (2) | Closed.
2025-01-08 12:40:24.717 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:24.718 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:24.718 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:24.718 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:24.718 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:24.718 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:25.015 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:25.015 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:25.015 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:25.015 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:26.123 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:26.123 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:26.123 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:26.123 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:26.123 | Rithmic Direct - DTC (Data) | Failed connections: 3335
2025-01-08 12:40:26.123 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:26.124 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:26.124 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:26.124 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:26.125 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:26.420 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:26.420 | DTC Client socket (2) | Closed.
2025-01-08 12:40:28.125 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:28.125 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:28.125 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:28.126 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:28.126 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:28.126 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:28.430 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:28.430 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:28.430 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:28.430 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:29.553 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:29.553 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:29.553 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:29.553 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:29.553 | Rithmic Direct - DTC (Data) | Failed connections: 3336
2025-01-08 12:40:29.553 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:29.554 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:29.554 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:29.554 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:29.554 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:29.854 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:29.855 | DTC Client socket (2) | Closed.
2025-01-08 12:40:31.551 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:31.551 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:31.551 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:31.551 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:31.552 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:31.552 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:31.922 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:31.922 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:31.922 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:31.922 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Failed connections: 3337
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:33.258 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:33.258 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:33.258 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:33.684 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:33.684 | DTC Client socket (2) | Closed.
2025-01-08 12:40:35.253 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:35.253 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:35.253 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:35.254 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:35.254 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:35.254 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:35.556 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:35.556 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:35.556 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:35.556 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Failed connections: 3338
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:36.682 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:36.682 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:36.682 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:36.984 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:36.984 | DTC Client socket (2) | Closed.
2025-01-08 12:40:38.680 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:38.680 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:38.680 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:38.680 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:38.681 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:38.681 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:38.919 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:38.919 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:38.919 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:38.919 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:39.853 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:39.853 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:39.853 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:39.853 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:39.853 | Rithmic Direct - DTC (Data) | Failed connections: 3339
2025-01-08 12:40:39.854 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:39.854 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:39.854 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:39.854 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:39.854 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:40.092 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:40.092 | DTC Client socket (2) | Closed.
2025-01-08 12:40:41.852 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:41.852 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:41.852 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:41.852 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:41.852 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:41.852 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:42.150 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:42.150 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:42.150 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:42.150 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:43.265 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:43.265 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:43.265 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:43.265 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:43.265 | Rithmic Direct - DTC (Data) | Failed connections: 3340
2025-01-08 12:40:43.265 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:43.266 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:43.266 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:43.266 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:43.266 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:43.562 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:43.563 | DTC Client socket (2) | Closed.
2025-01-08 12:40:45.264 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:45.264 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:45.264 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:45.265 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:45.265 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:45.265 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:45.548 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:45.548 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:45.548 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:45.548 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:46.620 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:46.620 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:46.620 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:46.620 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:46.620 | Rithmic Direct - DTC (Data) | Failed connections: 3341
2025-01-08 12:40:46.620 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:46.620 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:46.620 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:46.621 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:46.621 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:46.905 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:46.905 | DTC Client socket (2) | Closed.
2025-01-08 12:40:48.624 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:48.624 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:48.624 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:48.625 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:48.625 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:48.625 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:48.925 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:48.925 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:48.925 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:48.925 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:50.028 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:50.028 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:50.028 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:50.028 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:50.028 | Rithmic Direct - DTC (Data) | Failed connections: 3342
2025-01-08 12:40:50.028 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:50.029 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:50.029 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:50.029 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:50.029 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:50.321 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:50.321 | DTC Client socket (2) | Closed.
2025-01-08 12:40:52.100 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:52.100 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:52.100 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:52.103 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:52.103 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:52.103 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:52.442 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:52.442 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:52.442 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:52.442 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:53.694 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:53.694 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:53.694 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:53.694 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:53.694 | Rithmic Direct - DTC (Data) | Failed connections: 3343
2025-01-08 12:40:53.694 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:53.695 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:53.695 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:53.695 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:53.695 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:54.053 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:54.053 | DTC Client socket (2) | Closed.
2025-01-08 12:40:55.701 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:55.701 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:55.701 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:55.701 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:55.702 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:55.702 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:55.986 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:55.986 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:55.986 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:55.986 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Failed connections: 3344
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:40:57.659 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:40:57.659 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:40:57.659 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:40:57.945 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:40:57.945 | DTC Client socket (2) | Closed.
2025-01-08 12:40:59.660 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:40:59.660 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:40:59.660 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:40:59.661 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:40:59.662 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:40:59.662 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:40:59.949 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:40:59.949 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:40:59.949 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:40:59.949 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:01.025 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:01.025 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:01.025 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:01.025 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:01.025 | Rithmic Direct - DTC (Data) | Failed connections: 3345
2025-01-08 12:41:01.025 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:01.026 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:01.026 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:01.026 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:01.026 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:01.312 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:01.312 | DTC Client socket (2) | Closed.
2025-01-08 12:41:03.031 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:03.031 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:03.031 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:03.032 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:03.032 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:03.032 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:03.323 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:03.323 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:03.323 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:03.323 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Failed connections: 3346
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:04.415 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:04.415 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:04.415 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:04.706 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:04.706 | DTC Client socket (2) | Closed.
2025-01-08 12:41:06.416 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:06.416 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:06.416 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:06.418 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:06.419 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:06.419 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:06.818 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:06.818 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:06.818 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:06.818 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:08.251 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:08.251 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:08.251 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:08.251 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:08.251 | Rithmic Direct - DTC (Data) | Failed connections: 3347
2025-01-08 12:41:08.251 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:08.252 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:08.252 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:08.252 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:08.252 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:08.650 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:08.650 | DTC Client socket (2) | Closed.
2025-01-08 12:41:10.264 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:10.264 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:10.264 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:10.264 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:10.264 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:10.264 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:10.503 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:10.503 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:10.503 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:10.503 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:11.450 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:11.450 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:11.450 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:11.450 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:11.450 | Rithmic Direct - DTC (Data) | Failed connections: 3348
2025-01-08 12:41:11.451 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:11.451 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:11.451 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:11.451 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:11.451 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:11.702 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:11.703 | DTC Client socket (2) | Closed.
2025-01-08 12:41:13.450 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:13.450 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:13.450 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:13.451 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:13.451 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:13.451 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:13.690 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:13.690 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:13.690 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:13.690 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Failed connections: 3349
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:14.620 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:14.620 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:14.621 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:14.857 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:14.857 | DTC Client socket (2) | Closed.
2025-01-08 12:41:16.187 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048
2025-01-08 12:41:16.320 | DTC Client socket (2) | Creating socket.
2025-01-08 12:41:16.321 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:16.321 | DTC Client socket (2) | Connecting to IP: 64.152.155.18.
2025-01-08 12:41:16.482 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:41:16.482 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:41:16.482 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:41:16.622 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:16.622 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:16.622 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:16.623 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:16.623 | DTC Client socket (3) | New receive buffer size: 0
2025-01-08 12:41:16.623 | DTC Client socket (3) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:16.671 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:41:16.671 | Denali Data Feed | Sending logon request message.
2025-01-08 12:41:16.926 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:16.926 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:16.926 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:16.926 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:17.199 | Denali Data Feed | Received logon response.
2025-01-08 12:41:17.199 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:41:17.199 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:17.199 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:41:17.199 | Denali Data Feed | Failed connections: 235
2025-01-08 12:41:17.199 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:41:17.200 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:17.200 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:41:17.200 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:41:17.200 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:17.361 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:17.361 | DTC Client socket (2) | Closed.
2025-01-08 12:41:18.049 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:18.049 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:18.049 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:18.049 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:18.050 | Rithmic Direct - DTC (Data) | Failed connections: 3350
2025-01-08 12:41:18.050 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:18.050 | DTC Client socket (3) | CloseSocket call.
2025-01-08 12:41:18.050 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:18.050 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:18.051 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:18.350 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:41:18.350 | DTC Client socket (3) | Closed.
2025-01-08 12:41:20.055 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:20.055 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:20.055 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:20.056 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:20.056 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:20.056 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:20.353 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:20.353 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:20.353 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:20.353 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:21.466 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:21.466 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:21.466 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:21.466 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:21.466 | Rithmic Direct - DTC (Data) | Failed connections: 3351
2025-01-08 12:41:21.466 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:21.467 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:21.467 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:21.467 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:21.467 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:21.764 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:21.764 | DTC Client socket (2) | Closed.
2025-01-08 12:41:23.478 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:23.478 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:23.478 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:23.479 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:23.479 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:23.479 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:23.779 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:23.779 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:23.779 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:23.779 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:24.899 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:24.899 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:24.899 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:24.899 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:24.899 | Rithmic Direct - DTC (Data) | Failed connections: 3352
2025-01-08 12:41:24.899 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:24.900 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:24.900 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:24.900 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:24.900 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:25.198 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:25.198 | DTC Client socket (2) | Closed.
2025-01-08 12:41:26.899 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:26.899 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:26.899 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:26.902 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:26.902 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:26.902 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:27.192 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:27.192 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:27.192 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:27.192 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:28.270 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:28.270 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:28.270 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:28.270 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:28.270 | Rithmic Direct - DTC (Data) | Failed connections: 3353
2025-01-08 12:41:28.270 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:28.271 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:28.271 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:28.271 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:28.271 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:28.559 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:28.559 | DTC Client socket (2) | Closed.
2025-01-08 12:41:30.276 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:30.276 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:30.276 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:30.277 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:30.277 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:30.277 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:31.560 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:31.560 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:31.560 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:31.560 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:32.642 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:32.642 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:32.642 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:32.642 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:32.642 | Rithmic Direct - DTC (Data) | Failed connections: 3354
2025-01-08 12:41:32.642 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:32.643 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:32.643 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:32.643 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:32.643 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:32.921 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:32.921 | DTC Client socket (2) | Closed.
2025-01-08 12:41:34.649 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:34.649 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:34.649 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:34.650 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:34.650 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:34.650 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:34.939 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:34.939 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:34.940 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:34.940 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:36.022 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:36.022 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:36.022 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:36.022 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:36.022 | Rithmic Direct - DTC (Data) | Failed connections: 3355
2025-01-08 12:41:36.022 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:36.023 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:36.023 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:36.023 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:36.023 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:36.309 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:36.309 | DTC Client socket (2) | Closed.
2025-01-08 12:41:38.027 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:38.027 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:38.027 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:38.027 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:38.027 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:38.027 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:38.271 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:38.271 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:38.271 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:38.271 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:39.225 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:39.225 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:39.225 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:39.225 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:39.225 | Rithmic Direct - DTC (Data) | Failed connections: 3356
2025-01-08 12:41:39.225 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:39.226 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:39.226 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:39.226 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:39.226 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:39.470 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:39.470 | DTC Client socket (2) | Closed.
2025-01-08 12:41:41.222 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:41.222 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:41.222 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:41.223 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:41.223 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:41.223 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:41.511 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:41.511 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:41.511 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:41.511 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:42.591 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:42.591 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:42.591 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:42.591 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:42.591 | Rithmic Direct - DTC (Data) | Failed connections: 3357
2025-01-08 12:41:42.591 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:42.592 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:42.592 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:42.592 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:42.592 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:42.878 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:42.878 | DTC Client socket (2) | Closed.
2025-01-08 12:41:44.581 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:44.581 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:44.581 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:44.582 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:44.582 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:44.582 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:44.874 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:44.874 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:44.874 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:44.874 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:45.962 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:45.962 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:45.962 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:45.962 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:45.962 | Rithmic Direct - DTC (Data) | Failed connections: 3358
2025-01-08 12:41:45.962 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:45.963 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:45.963 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:45.963 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:45.963 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:46.255 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:46.255 | DTC Client socket (2) | Closed.
2025-01-08 12:41:47.962 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:47.962 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:47.962 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:47.963 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:47.963 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:47.963 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:48.346 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:48.346 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:48.346 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:48.346 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Failed connections: 3359
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:49.755 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:49.755 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:49.755 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:50.169 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:50.169 | DTC Client socket (2) | Closed.
2025-01-08 12:41:51.754 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:51.754 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:51.754 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:51.756 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:51.756 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:51.756 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:52.049 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:52.049 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:52.049 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:52.049 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:53.145 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:53.145 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:53.145 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:53.145 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:53.145 | Rithmic Direct - DTC (Data) | Failed connections: 3360
2025-01-08 12:41:53.145 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:53.146 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:53.146 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:53.146 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:53.146 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:53.440 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:53.440 | DTC Client socket (2) | Closed.
2025-01-08 12:41:55.149 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:55.149 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:55.149 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:55.149 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:55.149 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:55.149 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:55.399 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:55.399 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:55.400 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:55.400 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Failed connections: 3361
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:56.365 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:56.365 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:56.365 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:41:56.613 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:41:56.613 | DTC Client socket (2) | Closed.
2025-01-08 12:41:58.374 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:41:58.374 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:41:58.374 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:41:58.375 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:41:58.375 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:41:58.375 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:41:58.666 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:41:58.666 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:41:58.666 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:41:58.666 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:41:59.765 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:41:59.765 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:41:59.765 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:41:59.765 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:41:59.765 | Rithmic Direct - DTC (Data) | Failed connections: 3362
2025-01-08 12:41:59.765 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:41:59.766 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:41:59.766 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:41:59.766 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:41:59.766 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:00.056 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:00.057 | DTC Client socket (2) | Closed.
2025-01-08 12:42:01.755 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:01.755 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:01.755 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:01.755 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:01.755 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:01.755 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:01.995 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:01.995 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:01.995 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:01.995 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:02.933 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:02.933 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:02.933 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:02.933 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:02.933 | Rithmic Direct - DTC (Data) | Failed connections: 3363
2025-01-08 12:42:02.933 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:02.933 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:02.934 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:02.934 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:02.934 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:03.172 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:03.172 | DTC Client socket (2) | Closed.
2025-01-08 12:42:04.940 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:04.940 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:04.940 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:04.941 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:04.941 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:04.941 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:05.191 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:05.191 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:05.191 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:05.191 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Failed connections: 3364
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:06.171 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:06.171 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:06.172 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:06.420 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:06.421 | DTC Client socket (2) | Closed.
2025-01-08 12:42:08.162 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:08.162 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:08.162 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:08.162 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:08.163 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:08.163 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:08.411 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:08.411 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:08.411 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:08.411 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:09.374 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:09.374 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:09.374 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:09.374 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:09.374 | Rithmic Direct - DTC (Data) | Failed connections: 3365
2025-01-08 12:42:09.374 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:09.375 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:09.375 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:09.375 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:09.375 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:09.624 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:09.624 | DTC Client socket (2) | Closed.
2025-01-08 12:42:11.374 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:11.374 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:11.374 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:11.374 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:11.375 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:11.375 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:11.669 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:11.669 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:11.669 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:11.669 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:12.774 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:12.774 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:12.774 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:12.774 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:12.774 | Rithmic Direct - DTC (Data) | Failed connections: 3366
2025-01-08 12:42:12.774 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:12.775 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:12.775 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:12.775 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:12.775 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:13.072 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:13.072 | DTC Client socket (2) | Closed.
2025-01-08 12:42:14.773 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:14.773 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:14.773 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:14.774 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:14.774 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:14.774 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:15.030 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:15.030 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:15.030 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:15.030 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:15.992 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:15.992 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:15.992 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:15.992 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:15.992 | Rithmic Direct - DTC (Data) | Failed connections: 3367
2025-01-08 12:42:15.992 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:15.993 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:15.993 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:15.993 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:15.993 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:16.240 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:16.240 | DTC Client socket (2) | Closed.
2025-01-08 12:42:17.204 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 443
2025-01-08 12:42:17.205 | DTC Client socket (2) | Creating socket.
2025-01-08 12:42:17.205 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:17.205 | DTC Client socket (2) | Connecting to IP: 208.185.224.131.
2025-01-08 12:42:17.362 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:42:17.362 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:42:17.363 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:42:17.530 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:42:17.530 | Denali Data Feed | Sending logon request message.
2025-01-08 12:42:17.695 | Denali Data Feed | Received logon response.
2025-01-08 12:42:17.695 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:42:17.695 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:17.695 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary.
2025-01-08 12:42:17.695 | Denali Data Feed | Failed connections: 236
2025-01-08 12:42:17.695 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:42:17.695 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:17.695 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:42:17.695 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2025-01-08 12:42:17.695 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:17.851 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:17.851 | DTC Client socket (2) | Closed.
2025-01-08 12:42:17.988 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:17.988 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:17.988 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:17.989 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:17.989 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:17.989 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:18.285 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:18.285 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:18.286 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:18.286 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Failed connections: 3368
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:20.038 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:20.038 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:20.038 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:20.323 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:20.323 | DTC Client socket (2) | Closed.
2025-01-08 12:42:20.696 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:42:20.697 | DTC Client socket (2) | Creating socket.
2025-01-08 12:42:20.697 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:20.698 | DTC Client socket (2) | Connecting to IP: 67.214.125.5.
2025-01-08 12:42:20.853 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:42:20.853 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:42:20.853 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:42:21.018 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:42:21.018 | Denali Data Feed | Sending logon request message.
2025-01-08 12:42:21.553 | Denali Data Feed | Received logon response.
2025-01-08 12:42:21.553 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 12:42:21.553 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:21.553 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 12:42:21.553 | Denali Data Feed | Failed connections: 237
2025-01-08 12:42:21.553 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:42:21.554 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:21.554 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:42:21.554 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 12:42:21.554 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:21.710 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:21.710 | DTC Client socket (2) | Closed.
2025-01-08 12:42:22.036 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:22.036 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:22.036 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:22.037 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:22.037 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:22.037 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:22.341 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:22.341 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:22.341 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:22.341 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Failed connections: 3369
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:23.460 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:23.460 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:23.460 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:23.760 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:23.760 | DTC Client socket (2) | Closed.
2025-01-08 12:42:25.467 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:25.467 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:25.467 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:25.470 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:25.470 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:25.470 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:25.711 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:25.711 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:25.711 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:25.711 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:26.660 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:26.660 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:26.660 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:26.660 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:26.660 | Rithmic Direct - DTC (Data) | Failed connections: 3370
2025-01-08 12:42:26.660 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:26.661 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:26.661 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:26.661 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:26.661 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:26.902 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:26.902 | DTC Client socket (2) | Closed.
2025-01-08 12:42:28.659 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:28.659 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:28.659 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:28.660 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:28.660 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:28.660 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:28.954 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:28.954 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:28.954 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:28.954 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:30.059 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:30.059 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:30.059 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:30.059 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:30.059 | Rithmic Direct - DTC (Data) | Failed connections: 3371
2025-01-08 12:42:30.059 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:30.060 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:30.061 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:30.061 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:30.061 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:30.355 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:30.355 | DTC Client socket (2) | Closed.
2025-01-08 12:42:32.051 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:32.051 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:32.051 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:32.052 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:32.052 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:32.052 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:32.344 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:32.344 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:32.344 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:32.344 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Failed connections: 3372
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:33.439 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:33.439 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:33.439 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:33.731 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:33.731 | DTC Client socket (2) | Closed.
2025-01-08 12:42:35.448 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:35.448 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:35.448 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:35.449 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:35.449 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:35.449 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:35.738 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:35.738 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:35.738 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:35.738 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Failed connections: 3373
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:36.830 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:36.830 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:36.830 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:37.119 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:37.119 | DTC Client socket (2) | Closed.
2025-01-08 12:42:38.830 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:38.830 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:38.830 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:38.831 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:38.831 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:38.831 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:39.119 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:39.119 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:39.119 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:39.119 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:40.200 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:40.200 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:40.200 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:40.200 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:40.200 | Rithmic Direct - DTC (Data) | Failed connections: 3374
2025-01-08 12:42:40.200 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:40.201 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:40.201 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:40.201 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:40.201 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:40.489 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:40.489 | DTC Client socket (2) | Closed.
2025-01-08 12:42:42.196 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:42.196 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:42.196 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:42.197 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:42.198 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:42.198 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:42.502 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:42.502 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:42.502 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:42.502 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:44.216 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:44.216 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:44.216 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:44.216 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:44.216 | Rithmic Direct - DTC (Data) | Failed connections: 3375
2025-01-08 12:42:44.216 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:44.217 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:44.217 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:44.217 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:44.217 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:44.508 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:44.508 | DTC Client socket (2) | Closed.
2025-01-08 12:42:46.206 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:46.206 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:46.206 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:46.207 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:46.207 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:46.207 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:46.502 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:46.502 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:46.502 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:46.502 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:47.607 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:47.607 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:47.607 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:47.607 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:47.607 | Rithmic Direct - DTC (Data) | Failed connections: 3376
2025-01-08 12:42:47.607 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:47.608 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:47.608 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:47.608 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:47.608 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:47.903 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:47.903 | DTC Client socket (2) | Closed.
2025-01-08 12:42:49.609 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:49.609 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:49.609 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:49.610 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:49.611 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:49.611 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:49.898 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:49.898 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:49.898 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:49.898 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:50.987 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:50.987 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:50.987 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:50.987 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:50.987 | Rithmic Direct - DTC (Data) | Failed connections: 3377
2025-01-08 12:42:50.987 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:50.988 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:50.988 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:50.988 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:50.988 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:51.275 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:51.275 | DTC Client socket (2) | Closed.
2025-01-08 12:42:52.989 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:52.989 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:52.989 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-hk.rithmic.com. Port 40807
2025-01-08 12:42:52.990 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:52.990 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:52.990 | DTC Client socket (2) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:53.257 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-01-08 12:42:53.257 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-01-08 12:42:53.257 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-01-08 12:42:53.257 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Received logon response.
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Server Name: .
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Failed connections: 3378
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2025-01-08 12:42:54.224 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:54.224 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-01-08 12:42:54.224 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:54.487 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:42:54.487 | DTC Client socket (2) | Closed.
2025-01-08 12:42:54.823 | File >> Disconnect selected.
2025-01-08 12:42:54.823 | DTC Client socket (0) | CloseSocket call.
2025-01-08 12:42:54.823 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-01-08 12:42:54.835 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-01-08 12:42:54.836 | DTC Client socket (1) | CloseSocket call.
2025-01-08 12:42:54.836 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 12:42:54.837 | DTC Client socket (0) | CloseSocket call.
2025-01-08 12:42:54.837 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:42:54.838 | Rithmic Direct - DTC | Disconnected.
2025-01-08 12:42:55.131 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-08 12:42:55.131 | DTC Client socket (1) | Closed.
2025-01-08 12:42:56.816 |
2025-01-08 12:42:56.816 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:42:56.816 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:42:56.816 | Rithmic Direct - DTC | Connecting to the server rsc-hk.rithmic.com. Port 40804
2025-01-08 12:42:56.817 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-08 12:42:56.817 | DTC Client socket (1) | New receive buffer size: 0
2025-01-08 12:42:56.817 | DTC Client socket (1) | Connecting to IP: 18.163.3.182.
2025-01-08 12:42:57.113 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-08 12:42:57.113 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-08 12:42:57.113 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-08 12:42:57.113 | Rithmic Direct - DTC | Sending logon request message.
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Received logon response.
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Server Name: .
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Successfully connected.
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Trading is supported.
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-08 12:42:58.227 | Rithmic Direct - DTC | Connected to server complete.
2025-01-08 12:42:58.230 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-08 12:42:58.296 | Mapping MNQH1.CME to MNQH21. Service code: cme
2025-01-08 12:42:58.296 | Using symbol data fast lookup vector
2025-01-08 12:42:58.296 | Denali Data Feed | Starting real-time market data updates for: MNQH1.CME (MNQH21). ID: 1 Service code: cme
2025-01-08 12:42:58.296 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443
2025-01-08 12:42:58.296 | Denali Data Feed | Requesting security definition data for: MNQH1.CME (MNQH21). ID: 1
2025-01-08 12:42:58.296 | Added historical Intraday data request for MNQH1.CME to the queue.
2025-01-08 12:42:58.296 | Intraday data recording state for symbol MNQH1.CME is set to download 'Pending'.
2025-01-08 12:42:58.296 | Triggering next historical data download in queue.
2025-01-08 12:42:58.297 | DTC Client socket (2) | Creating socket.
2025-01-08 12:42:58.297 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:42:58.297 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-01-08 12:42:58.297 | Delaying start of download for MNQH1.CME.
2025-01-08 12:42:58.297 | Mapping M2KH1.CME to M2KH21. Service code: cme
2025-01-08 12:42:58.298 | Denali Data Feed | Starting real-time market data updates for: M2KH1.CME (M2KH21). ID: 2 Service code: cme
2025-01-08 12:42:58.298 | Denali Data Feed | Requesting security definition data for: M2KH1.CME (M2KH21). ID: 2
2025-01-08 12:42:58.298 | Added historical Intraday data request for M2KH1.CME to the queue.
2025-01-08 12:42:58.298 | Intraday data recording state for symbol M2KH1.CME is set to download 'Pending'.
2025-01-08 12:42:58.298 | Triggering next historical data download in queue.
2025-01-08 12:42:58.299 | Mapping MESH1.CME to MESH21. Service code: cme
2025-01-08 12:42:58.299 | Denali Data Feed | Starting real-time market data updates for: MESH1.CME (MESH21). ID: 3 Service code: cme
2025-01-08 12:42:58.299 | Denali Data Feed | Requesting security definition data for: MESH1.CME (MESH21). ID: 3
2025-01-08 12:42:58.299 | Added historical Intraday data request for MESH1.CME to the queue.
2025-01-08 12:42:58.299 | Intraday data recording state for symbol MESH1.CME is set to download 'Pending'.
2025-01-08 12:42:58.299 | Triggering next historical data download in queue.
2025-01-08 12:42:58.300 | Mapping YMH5.CBOT to YMH25. Service code: cbot
2025-01-08 12:42:58.300 | Denali Data Feed | Starting real-time market data updates for: YMH5.CBOT (YMH25). ID: 4 Service code: cbot
2025-01-08 12:42:58.300 | Denali Data Feed | Requesting security definition data for: YMH5.CBOT (YMH25). ID: 4
2025-01-08 12:42:58.300 | Added historical Intraday data request for YMH5.CBOT to the queue.
2025-01-08 12:42:58.300 | Intraday data recording state for symbol YMH5.CBOT is set to download 'Pending'.
2025-01-08 12:42:58.300 | Triggering next historical data download in queue.
2025-01-08 12:42:58.302 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-08 12:42:58.302 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 5 Service code: cme
2025-01-08 12:42:58.302 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 5
2025-01-08 12:42:58.302 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-08 12:42:58.302 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-08 12:42:58.302 | Triggering next historical data download in queue.
2025-01-08 12:42:58.304 | Mapping RTYH5.CME to RTYH25. Service code: cme
2025-01-08 12:42:58.304 | Denali Data Feed | Starting real-time market data updates for: RTYH5.CME (RTYH25). ID: 6 Service code: cme
2025-01-08 12:42:58.304 | Denali Data Feed | Requesting security definition data for: RTYH5.CME (RTYH25). ID: 6
2025-01-08 12:42:58.305 | Added historical Intraday data request for RTYH5.CME to the queue.
2025-01-08 12:42:58.305 | Intraday data recording state for symbol RTYH5.CME is set to download 'Pending'.
2025-01-08 12:42:58.305 | Triggering next historical data download in queue.
2025-01-08 12:42:58.306 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-08 12:42:58.306 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 7 Service code: cme
2025-01-08 12:42:58.306 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 7
2025-01-08 12:42:58.306 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-08 12:42:58.306 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-08 12:42:58.306 | Triggering next historical data download in queue.
2025-01-08 12:42:58.307 | Mapping M2KH5.CME to M2KH25. Service code: cme
2025-01-08 12:42:58.307 | Denali Data Feed | Starting real-time market data updates for: M2KH5.CME (M2KH25). ID: 8 Service code: cme
2025-01-08 12:42:58.307 | Denali Data Feed | Requesting security definition data for: M2KH5.CME (M2KH25). ID: 8
2025-01-08 12:42:58.307 | Added historical Intraday data request for M2KH5.CME to the queue.
2025-01-08 12:42:58.307 | Intraday data recording state for symbol M2KH5.CME is set to download 'Pending'.
2025-01-08 12:42:58.307 | Triggering next historical data download in queue.
2025-01-08 12:42:58.390 | Mapping MYMH5.CBOT to MYMH25. Service code: cbot
2025-01-08 12:42:58.390 | Denali Data Feed | Starting real-time market data updates for: MYMH5.CBOT (MYMH25). ID: 9 Service code: cbot
2025-01-08 12:42:58.390 | Denali Data Feed | Requesting security definition data for: MYMH5.CBOT (MYMH25). ID: 9
2025-01-08 12:42:58.390 | Added historical Intraday data request for MYMH5.CBOT to the queue.
2025-01-08 12:42:58.390 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'.
2025-01-08 12:42:58.390 | Triggering next historical data download in queue.
2025-01-08 12:42:58.392 | Mapping MYMH1.CBOT to MYMH21. Service code: cbot
2025-01-08 12:42:58.392 | Denali Data Feed | Starting real-time market data updates for: MYMH1.CBOT (MYMH21). ID: 10 Service code: cbot
2025-01-08 12:42:58.392 | Denali Data Feed | Requesting security definition data for: MYMH1.CBOT (MYMH21). ID: 10
2025-01-08 12:42:58.392 | Added historical Intraday data request for MYMH1.CBOT to the queue.
2025-01-08 12:42:58.392 | Intraday data recording state for symbol MYMH1.CBOT is set to download 'Pending'.
2025-01-08 12:42:58.392 | Triggering next historical data download in queue.
2025-01-08 12:42:58.394 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-08 12:42:58.394 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 11 Service code: cme
2025-01-08 12:42:58.394 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 11
2025-01-08 12:42:58.394 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-08 12:42:58.394 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-08 12:42:58.394 | Triggering next historical data download in queue.
2025-01-08 12:42:58.396 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-08 12:42:58.397 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 12 Service code: cme
2025-01-08 12:42:58.397 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 12
2025-01-08 12:42:58.397 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-08 12:42:58.397 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-08 12:42:58.397 | Triggering next historical data download in queue.
2025-01-08 12:42:58.458 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:42:58.458 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:42:58.458 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:42:58.642 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:42:58.642 | Denali Data Feed | Sending logon request message.
2025-01-08 12:42:59.267 | Denali Data Feed | Received logon response.
2025-01-08 12:42:59.267 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-08 12:42:59.267 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:42:59.267 | Denali Data Feed | Successfully connected.
2025-01-08 12:42:59.267 | Denali Data Feed | Trading is not supported.
2025-01-08 12:42:59.267 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: M2KH1.CME -> M2KH21
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: M2KH5.CME -> M2KH25
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: MESH1.CME -> MESH21
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH1.CME -> MNQH21
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH5.CME -> MNQH25
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: MYMH1.CBOT -> MYMH21
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: MYMH5.CBOT -> MYMH25
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: NQH5.CME -> NQH25
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH5.CME -> RTYH25
2025-01-08 12:42:59.267 | Denali Data Feed | Restarting real-time data updates for symbol: YMH5.CBOT -> YMH25
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Real-time data for symbol M2KH1.CME is currently unavailable.
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol M2KH1.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol M2KH5.CME to 42005649
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol M2KH5.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Real-time data for symbol MESH1.CME is currently unavailable.
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol MESH1.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Real-time data for symbol MNQH1.CME is currently unavailable.
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol MNQH1.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Real-time data for symbol MYMH1.CBOT is currently unavailable.
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol MYMH1.CBOT
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol MYMH5.CBOT to 42011026
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol MYMH5.CBOT
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol RTYH5.CME to 42001620
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol RTYH5.CME
2025-01-08 12:42:59.520 | Denali Data Feed | Setting external service identifier for symbol YMH5.CBOT to 42002868
2025-01-08 12:42:59.520 | Denali Data Feed | Received security definition for symbol YMH5.CBOT
2025-01-08 12:43:03.233 | Requesting market depth updates for: M2KH1.CME if supported. NumLevels=100
2025-01-08 12:43:03.233 | Requesting market depth updates for: MESH1.CME if supported. NumLevels=100
2025-01-08 12:43:03.233 | Requesting market depth updates for: MNQH1.CME if supported. NumLevels=100
2025-01-08 12:43:03.233 | Requesting market depth updates for: MYMH1.CBOT if supported. NumLevels=100
2025-01-08 12:43:03.496 | Denali Data Feed | Market Depth data has been rejected for symbol: M2KH1.CME. Not authorized for market depth.
2025-01-08 12:43:03.496 | Denali Data Feed | Market Depth data has been rejected for symbol: MESH1.CME. Not authorized for market depth.
2025-01-08 12:43:03.496 | Denali Data Feed | Market Depth data has been rejected for symbol: MNQH1.CME. Not authorized for market depth.
2025-01-08 12:43:03.496 | Denali Data Feed | Market Depth data has been rejected for symbol: MYMH1.CBOT. Not authorized for market depth.
2025-01-08 12:43:04.877 | HD Request # 28 | Downloading Intraday chart data for MNQH1.CME to the file MNQH1.CME.scid. Service: cme
2025-01-08 12:43:04.879 | HD Request # 28 | Download start date-time: 2021-03-19 13:29:59.000000. File last date-time: 2021-03-19 13:29:59.647000
2025-01-08 12:43:04.879 | HD Request # 28 | Using server: ds26.sierracharts.com port 10150
2025-01-08 12:43:04.880 | Socket (3) | Creating socket.
2025-01-08 12:43:04.880 | Socket (3) | New receive buffer size: 0
2025-01-08 12:43:04.880 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:43:05.223 | HD Request # 28 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:05.223 | HD Request # 28 | Sending historical data logon request message.
2025-01-08 12:43:05.427 | HD Request # 28 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:59. Record interval: 1. Symbol: MNQH21
2025-01-08 12:43:05.587 | HD Request # 28 | Decompressing data.
2025-01-08 12:43:05.746 | HD Request # 28 | Receiving Intraday data for MNQH1.CME starting at 2021-03-19 13:29:59.647000
2025-01-08 12:43:05.746 | Socket (3) | CloseSocket call.
2025-01-08 12:43:05.747 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:05.747 | Historical data download thread signaled to stop.
2025-01-08 12:43:05.747 | HD Request # 28 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:59.647000.
2025-01-08 12:43:05.748 | HD Request # 28 | Received 1 Intraday data record from 2021-03-19 13:29:59.647000 to 2021-03-19 13:29:59.647000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MNQH1.CME
2025-01-08 12:43:05.763 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:59.647000
2025-01-08 12:43:05.763 | HD Request # 28 | Completion time: 1s.
2025-01-08 12:43:05.763 | HD Request # 28 | Intraday data download complete for MNQH1.CME. Unique request ID: 24
2025-01-08 12:43:05.763 | Removing historical data download ID 24.
2025-01-08 12:43:05.763 | Real-time Intraday chart data file updates started for MNQH1.CME
2025-01-08 12:43:05.763 | Opened cached Intraday file: C:\SierraChart-1\Data\MNQH1.CME.scid. Thread ID: 12492
2025-01-08 12:43:05.763 | Intraday chart data file opened for MNQH1.CME
2025-01-08 12:43:05.763 | HD Request # 28 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:05.763 | Triggering next historical data download in queue.
2025-01-08 12:43:05.763 | HD Request # 29 | Downloading Intraday chart data for M2KH1.CME to the file M2KH1.CME.scid. Service: cme
2025-01-08 12:43:05.764 | HD Request # 29 | Download start date-time: 2021-03-19 13:29:43.000000. File last date-time: 2021-03-19 13:29:43.853000
2025-01-08 12:43:05.764 | HD Request # 29 | Using server: ds28.sierracharts.com port 10149
2025-01-08 12:43:05.764 | Socket (4) | Creating socket.
2025-01-08 12:43:05.764 | Socket (4) | New receive buffer size: 0
2025-01-08 12:43:05.764 | Socket (4) | Connecting to IP: 67.214.125.5.
2025-01-08 12:43:05.907 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:43:05.907 | Socket (3) | Closed.
2025-01-08 12:43:06.101 | HD Request # 29 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:06.101 | HD Request # 29 | Sending historical data logon request message.
2025-01-08 12:43:06.307 | HD Request # 29 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:43. Record interval: 1. Symbol: M2KH21
2025-01-08 12:43:06.470 | HD Request # 29 | Decompressing data.
2025-01-08 12:43:06.628 | HD Request # 29 | Receiving Intraday data for M2KH1.CME starting at 2021-03-19 13:29:43.853000
2025-01-08 12:43:06.629 | Socket (4) | CloseSocket call.
2025-01-08 12:43:06.629 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:06.635 | Historical data download thread signaled to stop.
2025-01-08 12:43:06.635 | HD Request # 29 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:43.853000.
2025-01-08 12:43:06.636 | HD Request # 29 | Received 1 Intraday data record from 2021-03-19 13:29:43.853000 to 2021-03-19 13:29:43.853000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for M2KH1.CME
2025-01-08 12:43:06.659 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:43.853000
2025-01-08 12:43:06.659 | HD Request # 29 | Completion time: 1s.
2025-01-08 12:43:06.659 | HD Request # 29 | Intraday data download complete for M2KH1.CME. Unique request ID: 25
2025-01-08 12:43:06.659 | Removing historical data download ID 25.
2025-01-08 12:43:06.659 | Real-time Intraday chart data file updates started for M2KH1.CME
2025-01-08 12:43:06.659 | Opened cached Intraday file: C:\SierraChart-1\Data\M2KH1.CME.scid. Thread ID: 12492
2025-01-08 12:43:06.660 | Intraday chart data file opened for M2KH1.CME
2025-01-08 12:43:06.660 | HD Request # 29 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:06.660 | Triggering next historical data download in queue.
2025-01-08 12:43:06.660 | HD Request # 30 | Downloading Intraday chart data for MESH1.CME to the file MESH1.CME.scid. Service: cme
2025-01-08 12:43:06.661 | HD Request # 30 | Download start date-time: 2021-03-19 13:29:54.000000. File last date-time: 2021-03-19 13:29:54.945000
2025-01-08 12:43:06.661 | HD Request # 30 | Using server: ds32.sierracharts.com port 10150
2025-01-08 12:43:06.661 | Socket (3) | Creating socket.
2025-01-08 12:43:06.661 | Socket (3) | New receive buffer size: 0
2025-01-08 12:43:06.661 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 12:43:06.788 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:43:06.788 | Socket (4) | Closed.
2025-01-08 12:43:06.983 | HD Request # 30 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:06.983 | HD Request # 30 | Sending historical data logon request message.
2025-01-08 12:43:07.180 | HD Request # 30 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:54. Record interval: 1. Symbol: MESH21
2025-01-08 12:43:07.335 | HD Request # 30 | Decompressing data.
2025-01-08 12:43:07.494 | HD Request # 30 | Receiving Intraday data for MESH1.CME starting at 2021-03-19 13:29:54.945000
2025-01-08 12:43:07.495 | Socket (3) | CloseSocket call.
2025-01-08 12:43:07.495 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:07.514 | Historical data download thread signaled to stop.
2025-01-08 12:43:07.515 | HD Request # 30 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:54.945000.
2025-01-08 12:43:07.515 | HD Request # 30 | Received 1 Intraday data record from 2021-03-19 13:29:54.945000 to 2021-03-19 13:29:54.945000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MESH1.CME
2025-01-08 12:43:07.543 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:54.945000
2025-01-08 12:43:07.543 | HD Request # 30 | Completion time: 1s.
2025-01-08 12:43:07.543 | HD Request # 30 | Intraday data download complete for MESH1.CME. Unique request ID: 26
2025-01-08 12:43:07.543 | Removing historical data download ID 26.
2025-01-08 12:43:07.543 | Real-time Intraday chart data file updates started for MESH1.CME
2025-01-08 12:43:07.544 | Opened cached Intraday file: C:\SierraChart-1\Data\MESH1.CME.scid. Thread ID: 12492
2025-01-08 12:43:07.544 | Intraday chart data file opened for MESH1.CME
2025-01-08 12:43:07.544 | HD Request # 30 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:07.544 | Triggering next historical data download in queue.
2025-01-08 12:43:07.552 | HD Request # 31 | Downloading Intraday chart data for YMH5.CBOT to the file YMH5.CBOT.scid. Service: cbot
2025-01-08 12:43:07.553 | HD Request # 31 | Download start date-time: 2025-01-08 09:06:54.000000. File last date-time: 2025-01-08 09:06:54.493000
2025-01-08 12:43:07.553 | HD Request # 31 | Using server: ds26.sierracharts.com port 10149
2025-01-08 12:43:07.553 | Socket (4) | Creating socket.
2025-01-08 12:43:07.553 | Socket (4) | New receive buffer size: 0
2025-01-08 12:43:07.554 | Socket (4) | Connecting to IP: 64.152.155.17.
2025-01-08 12:43:07.650 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:43:07.650 | Socket (3) | Closed.
2025-01-08 12:43:07.887 | HD Request # 31 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:07.887 | HD Request # 31 | Sending historical data logon request message.
2025-01-08 12:43:08.091 | HD Request # 31 | Requesting Intraday data. Start date-time: 2025-01-08 09:06:54. Record interval: 1. Symbol: YMH25
2025-01-08 12:43:08.252 | HD Request # 31 | Decompressing data.
2025-01-08 12:43:08.431 | HD Request # 31 | Receiving Intraday data for YMH5.CBOT starting at 2025-01-08 09:06:54.493000
2025-01-08 12:43:08.591 | Socket (4) | CloseSocket call.
2025-01-08 12:43:08.591 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:08.593 | Historical data download thread signaled to stop.
2025-01-08 12:43:08.593 | HD Request # 31 | Timestamp of first Intraday data file record written: 2025-01-08 09:06:54.493000.
2025-01-08 12:43:08.593 | HD Request # 31 | Received 4111 Intraday data records from 2025-01-08 09:06:54.493000 to 2025-01-08 12:43:05.079000 (3.6 hours. Delay: 3.5 seconds) and wrote 4111 records for YMH5.CBOT
2025-01-08 12:43:08.605 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:05.079000
2025-01-08 12:43:08.605 | HD Request # 31 | Completion time: 1s.
2025-01-08 12:43:08.605 | HD Request # 31 | Intraday data download complete for YMH5.CBOT. Unique request ID: 27
2025-01-08 12:43:08.605 | Removing historical data download ID 27.
2025-01-08 12:43:08.605 | Real-time Intraday chart data file updates started for YMH5.CBOT
2025-01-08 12:43:08.605 | Opened cached Intraday file: C:\SierraChart-1\Data\YMH5.CBOT.scid. Thread ID: 12492
2025-01-08 12:43:08.606 | Intraday chart data file opened for YMH5.CBOT
2025-01-08 12:43:08.606 | HD Request # 31 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:08.606 | Triggering next historical data download in queue.
2025-01-08 12:43:08.606 | HD Request # 32 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-08 12:43:08.606 | HD Request # 32 | Download start date-time: 2025-01-08 09:06:26.000000. File last date-time: 2025-01-08 09:06:26.723000
2025-01-08 12:43:08.606 | HD Request # 32 | Using server: ds28.sierracharts.com port 10150
2025-01-08 12:43:08.606 | Socket (3) | Creating socket.
2025-01-08 12:43:08.606 | Socket (3) | New receive buffer size: 0
2025-01-08 12:43:08.606 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:43:08.753 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:43:08.753 | Socket (4) | Closed.
2025-01-08 12:43:08.934 | HD Request # 32 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:08.934 | HD Request # 32 | Sending historical data logon request message.
2025-01-08 12:43:09.139 | HD Request # 32 | Requesting Intraday data. Start date-time: 2025-01-08 09:06:26. Record interval: 1. Symbol: NQH25
2025-01-08 12:43:09.299 | HD Request # 32 | Decompressing data.
2025-01-08 12:43:09.641 | HD Request # 32 | Receiving Intraday data for NQH5.CME starting at 2025-01-08 09:06:26.723000
2025-01-08 12:43:09.799 | Socket (3) | CloseSocket call.
2025-01-08 12:43:09.799 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:09.801 | Historical data download thread signaled to stop.
2025-01-08 12:43:09.802 | HD Request # 32 | Timestamp of first Intraday data file record written: 2025-01-08 09:06:26.723000.
2025-01-08 12:43:09.802 | HD Request # 32 | Received 7734 Intraday data records from 2025-01-08 09:06:26.723000 to 2025-01-08 12:43:08.165000 (3.6 hours. Delay: 1.6 seconds) and wrote 7734 records for NQH5.CME
2025-01-08 12:43:09.814 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:08.165000
2025-01-08 12:43:09.814 | HD Request # 32 | Completion time: 1s.
2025-01-08 12:43:09.814 | HD Request # 32 | Intraday data download complete for NQH5.CME. Unique request ID: 28
2025-01-08 12:43:09.814 | Removing historical data download ID 28.
2025-01-08 12:43:09.814 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-08 12:43:09.814 | Opened cached Intraday file: C:\SierraChart-1\Data\NQH5.CME.scid. Thread ID: 12492
2025-01-08 12:43:09.814 | Intraday chart data file opened for NQH5.CME
2025-01-08 12:43:09.814 | HD Request # 32 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:09.814 | Triggering next historical data download in queue.
2025-01-08 12:43:09.814 | HD Request # 33 | Downloading Intraday chart data for RTYH5.CME to the file RTYH5.CME.scid. Service: cme
2025-01-08 12:43:09.815 | HD Request # 33 | Download start date-time: 2025-01-08 09:06:31.000000. File last date-time: 2025-01-08 09:06:31.251000
2025-01-08 12:43:09.815 | HD Request # 33 | Using server: ds32.sierracharts.com port 10149
2025-01-08 12:43:09.815 | Socket (4) | Creating socket.
2025-01-08 12:43:09.815 | Socket (4) | New receive buffer size: 0
2025-01-08 12:43:09.815 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-08 12:43:09.955 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:43:09.956 | Socket (3) | Closed.
2025-01-08 12:43:10.129 | HD Request # 33 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:10.129 | HD Request # 33 | Sending historical data logon request message.
2025-01-08 12:43:10.326 | HD Request # 33 | Requesting Intraday data. Start date-time: 2025-01-08 09:06:31. Record interval: 1. Symbol: RTYH25
2025-01-08 12:43:10.478 | HD Request # 33 | Decompressing data.
2025-01-08 12:43:10.640 | HD Request # 33 | Receiving Intraday data for RTYH5.CME starting at 2025-01-08 09:06:31.251000
2025-01-08 12:43:10.793 | Socket (4) | CloseSocket call.
2025-01-08 12:43:10.793 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:10.810 | Historical data download thread signaled to stop.
2025-01-08 12:43:10.811 | HD Request # 33 | Timestamp of first Intraday data file record written: 2025-01-08 09:06:31.251000.
2025-01-08 12:43:10.811 | HD Request # 33 | Received 3258 Intraday data records from 2025-01-08 09:06:31.251000 to 2025-01-08 12:43:05.080000 (3.6 hours. Delay: 5.7 seconds) and wrote 3258 records for RTYH5.CME
2025-01-08 12:43:10.821 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:05.080000
2025-01-08 12:43:10.821 | HD Request # 33 | Completion time: 1s.
2025-01-08 12:43:10.821 | HD Request # 33 | Intraday data download complete for RTYH5.CME. Unique request ID: 29
2025-01-08 12:43:10.821 | Removing historical data download ID 29.
2025-01-08 12:43:10.822 | Real-time Intraday chart data file updates started for RTYH5.CME
2025-01-08 12:43:10.822 | Opened cached Intraday file: C:\SierraChart-1\Data\RTYH5.CME.scid. Thread ID: 12492
2025-01-08 12:43:10.822 | Intraday chart data file opened for RTYH5.CME
2025-01-08 12:43:10.822 | HD Request # 33 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:10.822 | Triggering next historical data download in queue.
2025-01-08 12:43:10.822 | HD Request # 34 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-08 12:43:10.823 | HD Request # 34 | Download start date-time: 2025-01-08 09:05:57.000000. File last date-time: 2025-01-08 09:05:57.143000
2025-01-08 12:43:10.823 | HD Request # 34 | Using server: ds26.sierracharts.com port 10150
2025-01-08 12:43:10.823 | Socket (3) | Creating socket.
2025-01-08 12:43:10.823 | Socket (3) | New receive buffer size: 0
2025-01-08 12:43:10.823 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:43:10.951 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:43:10.951 | Socket (4) | Closed.
2025-01-08 12:43:11.143 | HD Request # 34 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:11.143 | HD Request # 34 | Sending historical data logon request message.
2025-01-08 12:43:11.296 | HD Request # 34 | Requesting Intraday data. Start date-time: 2025-01-08 09:05:57. Record interval: 1. Symbol: ESH25
2025-01-08 12:43:11.449 | HD Request # 34 | Decompressing data.
2025-01-08 12:43:11.787 | HD Request # 34 | Receiving Intraday data for ESH5.CME starting at 2025-01-08 09:05:57.143000
2025-01-08 12:43:11.940 | Socket (3) | CloseSocket call.
2025-01-08 12:43:11.940 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:11.942 | Historical data download thread signaled to stop.
2025-01-08 12:43:11.942 | HD Request # 34 | Timestamp of first Intraday data file record written: 2025-01-08 09:05:57.143000.
2025-01-08 12:43:11.942 | HD Request # 34 | Received 6367 Intraday data records from 2025-01-08 09:05:57.143000 to 2025-01-08 12:43:10.211000 (3.6 hours. Delay: 1.7 seconds) and wrote 6367 records for ESH5.CME
2025-01-08 12:43:11.952 | HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:10.211000
2025-01-08 12:43:11.952 | Added 1 Time and Sales records to Intraday data file for ESH5.CME after download.
2025-01-08 12:43:11.952 | HD Request # 34 | Completion time: 1s.
2025-01-08 12:43:11.952 | HD Request # 34 | Intraday data download complete for ESH5.CME. Unique request ID: 30
2025-01-08 12:43:11.952 | Removing historical data download ID 30.
2025-01-08 12:43:11.953 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-08 12:43:11.961 | Opened cached Intraday file: C:\SierraChart-1\Data\ESH5.CME.scid. Thread ID: 12492
2025-01-08 12:43:11.961 | Intraday chart data file opened for ESH5.CME
2025-01-08 12:43:11.961 | HD Request # 34 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:11.961 | Triggering next historical data download in queue.
2025-01-08 12:43:11.962 | HD Request # 35 | Downloading Intraday chart data for M2KH5.CME to the file M2KH5.CME.scid. Service: cme
2025-01-08 12:43:11.962 | HD Request # 35 | Download start date-time: 2025-01-08 09:08:04.000000. File last date-time: 2025-01-08 09:08:04.006000
2025-01-08 12:43:11.962 | HD Request # 35 | Using server: ds28.sierracharts.com port 10149
2025-01-08 12:43:11.962 | Socket (4) | Creating socket.
2025-01-08 12:43:11.962 | Socket (4) | New receive buffer size: 0
2025-01-08 12:43:11.962 | Socket (4) | Connecting to IP: 67.214.125.5.
2025-01-08 12:43:12.093 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:43:12.093 | Socket (3) | Closed.
2025-01-08 12:43:12.296 | HD Request # 35 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:12.296 | HD Request # 35 | Sending historical data logon request message.
2025-01-08 12:43:12.452 | HD Request # 35 | Requesting Intraday data. Start date-time: 2025-01-08 09:08:04. Record interval: 1. Symbol: M2KH25
2025-01-08 12:43:12.610 | HD Request # 35 | Decompressing data.
2025-01-08 12:43:12.776 | HD Request # 35 | Receiving Intraday data for M2KH5.CME starting at 2025-01-08 09:08:04.006000
2025-01-08 12:43:12.931 | Socket (4) | CloseSocket call.
2025-01-08 12:43:12.931 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:12.934 | Historical data download thread signaled to stop.
2025-01-08 12:43:12.935 | HD Request # 35 | Timestamp of first Intraday data file record written: 2025-01-08 09:08:04.006000.
2025-01-08 12:43:12.935 | HD Request # 35 | Received 2427 Intraday data records from 2025-01-08 09:08:04.006000 to 2025-01-08 12:43:11.801000 (3.6 hours. Delay: 1.1 seconds) and wrote 2427 records for M2KH5.CME
2025-01-08 12:43:12.953 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:11.801000
2025-01-08 12:43:12.953 | Added 1 Time and Sales records to Intraday data file for M2KH5.CME after download.
2025-01-08 12:43:12.953 | HD Request # 35 | Completion time: 1s.
2025-01-08 12:43:12.953 | HD Request # 35 | Intraday data download complete for M2KH5.CME. Unique request ID: 31
2025-01-08 12:43:12.953 | Removing historical data download ID 31.
2025-01-08 12:43:12.953 | Real-time Intraday chart data file updates started for M2KH5.CME
2025-01-08 12:43:12.965 | Opened cached Intraday file: C:\SierraChart-1\Data\M2KH5.CME.scid. Thread ID: 12492
2025-01-08 12:43:12.965 | Intraday chart data file opened for M2KH5.CME
2025-01-08 12:43:12.965 | HD Request # 35 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:12.966 | Triggering next historical data download in queue.
2025-01-08 12:43:12.966 | HD Request # 36 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: cbot
2025-01-08 12:43:12.966 | HD Request # 36 | Download start date-time: 2025-01-08 09:08:20.000000. File last date-time: 2025-01-08 09:08:20.843000
2025-01-08 12:43:12.967 | HD Request # 36 | Using server: ds32.sierracharts.com port 10150
2025-01-08 12:43:12.967 | Socket (3) | Creating socket.
2025-01-08 12:43:12.967 | Socket (3) | New receive buffer size: 0
2025-01-08 12:43:12.967 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 12:43:13.091 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:43:13.091 | Socket (4) | Closed.
2025-01-08 12:43:13.289 | HD Request # 36 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:13.289 | HD Request # 36 | Sending historical data logon request message.
2025-01-08 12:43:13.446 | HD Request # 36 | Requesting Intraday data. Start date-time: 2025-01-08 09:08:20. Record interval: 1. Symbol: MYMH25
2025-01-08 12:43:13.604 | HD Request # 36 | Decompressing data.
2025-01-08 12:43:13.776 | HD Request # 36 | Receiving Intraday data for MYMH5.CBOT starting at 2025-01-08 09:08:20.843000
2025-01-08 12:43:13.936 | Socket (3) | CloseSocket call.
2025-01-08 12:43:13.936 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:13.940 | Historical data download thread signaled to stop.
2025-01-08 12:43:13.941 | HD Request # 36 | Timestamp of first Intraday data file record written: 2025-01-08 09:08:20.843000.
2025-01-08 12:43:13.941 | HD Request # 36 | Received 3488 Intraday data records from 2025-01-08 09:08:20.843000 to 2025-01-08 12:43:05.081000 (3.6 hours. Delay: 8.9 seconds) and wrote 3488 records for MYMH5.CBOT
2025-01-08 12:43:13.968 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:05.081000
2025-01-08 12:43:13.968 | Added 1 Time and Sales records to Intraday data file for MYMH5.CBOT after download.
2025-01-08 12:43:13.968 | HD Request # 36 | Completion time: 1s.
2025-01-08 12:43:13.968 | HD Request # 36 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 32
2025-01-08 12:43:13.968 | Removing historical data download ID 32.
2025-01-08 12:43:13.968 | Real-time Intraday chart data file updates started for MYMH5.CBOT
2025-01-08 12:43:13.983 | Opened cached Intraday file: C:\SierraChart-1\Data\MYMH5.CBOT.scid. Thread ID: 12492
2025-01-08 12:43:13.983 | Intraday chart data file opened for MYMH5.CBOT
2025-01-08 12:43:13.983 | HD Request # 36 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:13.983 | Triggering next historical data download in queue.
2025-01-08 12:43:13.997 | HD Request # 37 | Downloading Intraday chart data for MYMH1.CBOT to the file MYMH1.CBOT.scid. Service: cbot
2025-01-08 12:43:13.998 | HD Request # 37 | Download start date-time: 2021-03-19 13:29:43.000000. File last date-time: 2021-03-19 13:29:43.603000
2025-01-08 12:43:13.998 | HD Request # 37 | Using server: ds26.sierracharts.com port 10149
2025-01-08 12:43:13.998 | Socket (4) | Creating socket.
2025-01-08 12:43:13.998 | Socket (4) | New receive buffer size: 0
2025-01-08 12:43:13.998 | Socket (4) | Connecting to IP: 64.152.155.17.
2025-01-08 12:43:14.096 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:43:14.096 | Socket (3) | Closed.
2025-01-08 12:43:14.331 | HD Request # 37 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:14.331 | HD Request # 37 | Sending historical data logon request message.
2025-01-08 12:43:14.493 | HD Request # 37 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:43. Record interval: 1. Symbol: MYMH21
2025-01-08 12:43:14.655 | HD Request # 37 | Decompressing data.
2025-01-08 12:43:14.817 | HD Request # 37 | Receiving Intraday data for MYMH1.CBOT starting at 2021-03-19 13:29:43.603000
2025-01-08 12:43:14.818 | Socket (4) | CloseSocket call.
2025-01-08 12:43:14.818 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:14.820 | Historical data download thread signaled to stop.
2025-01-08 12:43:14.821 | HD Request # 37 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:43.603000.
2025-01-08 12:43:14.821 | HD Request # 37 | Received 1 Intraday data record from 2021-03-19 13:29:43.603000 to 2021-03-19 13:29:43.603000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MYMH1.CBOT
2025-01-08 12:43:14.840 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:43.603000
2025-01-08 12:43:14.840 | HD Request # 37 | Completion time: 1s.
2025-01-08 12:43:14.840 | HD Request # 37 | Intraday data download complete for MYMH1.CBOT. Unique request ID: 33
2025-01-08 12:43:14.840 | Removing historical data download ID 33.
2025-01-08 12:43:14.840 | Real-time Intraday chart data file updates started for MYMH1.CBOT
2025-01-08 12:43:14.841 | Opened cached Intraday file: C:\SierraChart-1\Data\MYMH1.CBOT.scid. Thread ID: 12492
2025-01-08 12:43:14.841 | Intraday chart data file opened for MYMH1.CBOT
2025-01-08 12:43:14.841 | HD Request # 37 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:14.841 | Triggering next historical data download in queue.
2025-01-08 12:43:14.841 | HD Request # 38 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-08 12:43:14.842 | HD Request # 38 | Download start date-time: 2025-01-08 09:07:27.000000. File last date-time: 2025-01-08 09:07:27.398000
2025-01-08 12:43:14.842 | HD Request # 38 | Using server: ds28.sierracharts.com port 10150
2025-01-08 12:43:14.843 | Socket (3) | Creating socket.
2025-01-08 12:43:14.843 | Socket (3) | New receive buffer size: 0
2025-01-08 12:43:14.843 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:43:14.981 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:43:14.981 | Socket (4) | Closed.
2025-01-08 12:43:15.174 | HD Request # 38 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:15.174 | HD Request # 38 | Sending historical data logon request message.
2025-01-08 12:43:15.328 | HD Request # 38 | Requesting Intraday data. Start date-time: 2025-01-08 09:07:27. Record interval: 1. Symbol: MESH25
2025-01-08 12:43:15.485 | HD Request # 38 | Decompressing data.
2025-01-08 12:43:15.836 | HD Request # 38 | Receiving Intraday data for MESH5.CME starting at 2025-01-08 09:07:27.398000
2025-01-08 12:43:15.986 | Socket (3) | CloseSocket call.
2025-01-08 12:43:15.986 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:16.008 | Historical data download thread signaled to stop.
2025-01-08 12:43:16.009 | HD Request # 38 | Timestamp of first Intraday data file record written: 2025-01-08 09:07:27.398000.
2025-01-08 12:43:16.009 | HD Request # 38 | Received 6898 Intraday data records from 2025-01-08 09:07:27.398000 to 2025-01-08 12:43:11.646000 (3.6 hours. Delay: 4.4 seconds) and wrote 6898 records for MESH5.CME
2025-01-08 12:43:16.025 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:11.646000
2025-01-08 12:43:16.025 | Added 4 Time and Sales records to Intraday data file for MESH5.CME after download.
2025-01-08 12:43:16.025 | HD Request # 38 | Completion time: 2s.
2025-01-08 12:43:16.025 | HD Request # 38 | Intraday data download complete for MESH5.CME. Unique request ID: 34
2025-01-08 12:43:16.025 | Removing historical data download ID 34.
2025-01-08 12:43:16.025 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-08 12:43:16.038 | Opened cached Intraday file: C:\SierraChart-1\Data\MESH5.CME.scid. Thread ID: 12492
2025-01-08 12:43:16.038 | Intraday chart data file opened for MESH5.CME
2025-01-08 12:43:16.038 | HD Request # 38 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:16.038 | Triggering next historical data download in queue.
2025-01-08 12:43:16.039 | HD Request # 39 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-08 12:43:16.039 | HD Request # 39 | Download start date-time: 2025-01-08 09:07:43.000000. File last date-time: 2025-01-08 09:07:43.010000
2025-01-08 12:43:16.039 | HD Request # 39 | Using server: ds32.sierracharts.com port 10149
2025-01-08 12:43:16.039 | Socket (4) | Creating socket.
2025-01-08 12:43:16.039 | Socket (4) | New receive buffer size: 0
2025-01-08 12:43:16.039 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-08 12:43:16.141 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:43:16.141 | Socket (3) | Closed.
2025-01-08 12:43:16.367 | HD Request # 39 | Setting DTC encoding to Binary VLS
2025-01-08 12:43:16.367 | HD Request # 39 | Sending historical data logon request message.
2025-01-08 12:43:16.524 | HD Request # 39 | Requesting Intraday data. Start date-time: 2025-01-08 09:07:43. Record interval: 1. Symbol: MNQH25
2025-01-08 12:43:16.680 | HD Request # 39 | Decompressing data.
2025-01-08 12:43:17.051 | HD Request # 39 | Receiving Intraday data for MNQH5.CME starting at 2025-01-08 09:07:43.010000
2025-01-08 12:43:17.348 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:43:17.348 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0
2025-01-08 12:43:17.348 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 216.66.0.130.
2025-01-08 12:43:17.359 | Socket (4) | CloseSocket call.
2025-01-08 12:43:17.359 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:17.361 | Historical data download thread signaled to stop.
2025-01-08 12:43:17.361 | HD Request # 39 | Timestamp of first Intraday data file record written: 2025-01-08 09:07:43.010000.
2025-01-08 12:43:17.361 | HD Request # 39 | Received 10163 Intraday data records from 2025-01-08 09:07:43.010000 to 2025-01-08 12:43:14.036000 (3.6 hours. Delay: 3.3 seconds) and wrote 10163 records for MNQH5.CME
2025-01-08 12:43:17.375 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:43:14.036000
2025-01-08 12:43:17.375 | Added 2 Time and Sales records to Intraday data file for MNQH5.CME after download.
2025-01-08 12:43:17.375 | HD Request # 39 | Completion time: 1s.
2025-01-08 12:43:17.375 | HD Request # 39 | Intraday data download complete for MNQH5.CME. Unique request ID: 35
2025-01-08 12:43:17.375 | Removing historical data download ID 35.
2025-01-08 12:43:17.375 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-08 12:43:17.387 | Opened cached Intraday file: C:\SierraChart-1\Data\MNQH5.CME.scid. Thread ID: 12492
2025-01-08 12:43:17.387 | Intraday chart data file opened for MNQH5.CME
2025-01-08 12:43:17.387 | HD Request # 39 | Enabling Intraday chart updating for symbol.
2025-01-08 12:43:17.387 | No download requests in the queue to start downloads for.
2025-01-08 12:43:17.517 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:43:17.517 | Socket (4) | Closed.
2025-01-08 12:43:18.176 | Rithmic Direct - DTC | Wrote file: C:\SierraChart-1\RithmicConnections.json. Size: 81131
2025-01-08 12:43:18.178 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-08 12:43:18.433 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | CloseSocket call.
2025-01-08 12:43:18.433 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:43:18.571 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side.
2025-01-08 12:43:18.571 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Closed.
2025-01-08 12:45:16.053 | File >> Disconnect selected.
2025-01-08 12:45:16.059 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-01-08 12:45:16.059 | DTC Client socket (1) | CloseSocket call.
2025-01-08 12:45:16.059 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 12:45:16.060 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:45:16.060 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:45:16.065 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:45:16.065 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:45:16.065 | Rithmic Direct - DTC | Disconnected.
2025-01-08 12:45:16.356 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-08 12:45:16.356 | DTC Client socket (1) | Closed.
2025-01-08 12:45:16.386 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:45:16.386 | DTC Client socket (2) | Closed.
2025-01-08 12:46:43.177 |
2025-01-08 12:46:43.177 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 12:46:43.177 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 12:46:43.177 | Rithmic Direct - DTC | Connecting to the server rsc-hk.rithmic.com. Port 40804
2025-01-08 12:46:43.334 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-08 12:46:43.334 | DTC Client socket (1) | New receive buffer size: 0
2025-01-08 12:46:43.334 | DTC Client socket (1) | Connecting to IP: 18.163.3.182.
2025-01-08 12:46:43.639 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-08 12:46:43.639 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-08 12:46:43.639 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-08 12:46:43.639 | Rithmic Direct - DTC | Sending logon request message.
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Received logon response.
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Server Name: .
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Successfully connected.
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Trading is supported.
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-08 12:46:44.778 | Rithmic Direct - DTC | Connected to server complete.
2025-01-08 12:46:44.779 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-08 12:46:44.847 | Mapping MYMH5.CBOT to MYMH25. Service code: cbot
2025-01-08 12:46:44.847 | Using symbol data fast lookup vector
2025-01-08 12:46:44.847 | Denali Data Feed | Starting real-time market data updates for: MYMH5.CBOT (MYMH25). ID: 1 Service code: cbot
2025-01-08 12:46:44.847 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443
2025-01-08 12:46:44.847 | Denali Data Feed | Requesting security definition data for: MYMH5.CBOT (MYMH25). ID: 1
2025-01-08 12:46:44.847 | Added historical Intraday data request for MYMH5.CBOT to the queue.
2025-01-08 12:46:44.847 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'.
2025-01-08 12:46:44.847 | Triggering next historical data download in queue.
2025-01-08 12:46:44.848 | DTC Client socket (2) | Creating socket.
2025-01-08 12:46:44.848 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 12:46:44.848 | DTC Client socket (2) | Connecting to IP: 67.214.125.5.
2025-01-08 12:46:44.851 | Delaying start of download for MYMH5.CBOT.
2025-01-08 12:46:44.852 | Mapping MYMH1.CBOT to MYMH21. Service code: cbot
2025-01-08 12:46:44.852 | Denali Data Feed | Starting real-time market data updates for: MYMH1.CBOT (MYMH21). ID: 2 Service code: cbot
2025-01-08 12:46:44.852 | Denali Data Feed | Requesting security definition data for: MYMH1.CBOT (MYMH21). ID: 2
2025-01-08 12:46:44.852 | Added historical Intraday data request for MYMH1.CBOT to the queue.
2025-01-08 12:46:44.852 | Intraday data recording state for symbol MYMH1.CBOT is set to download 'Pending'.
2025-01-08 12:46:44.852 | Triggering next historical data download in queue.
2025-01-08 12:46:44.854 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-08 12:46:44.854 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 3 Service code: cme
2025-01-08 12:46:44.854 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 3
2025-01-08 12:46:44.854 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-08 12:46:44.854 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-08 12:46:44.854 | Triggering next historical data download in queue.
2025-01-08 12:46:44.858 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-08 12:46:44.858 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 4 Service code: cme
2025-01-08 12:46:44.858 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 4
2025-01-08 12:46:44.858 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-08 12:46:44.858 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-08 12:46:44.858 | Triggering next historical data download in queue.
2025-01-08 12:46:44.862 | Mapping MNQH1.CME to MNQH21. Service code: cme
2025-01-08 12:46:44.863 | Denali Data Feed | Starting real-time market data updates for: MNQH1.CME (MNQH21). ID: 5 Service code: cme
2025-01-08 12:46:44.863 | Denali Data Feed | Requesting security definition data for: MNQH1.CME (MNQH21). ID: 5
2025-01-08 12:46:44.863 | Added historical Intraday data request for MNQH1.CME to the queue.
2025-01-08 12:46:44.863 | Intraday data recording state for symbol MNQH1.CME is set to download 'Pending'.
2025-01-08 12:46:44.863 | Triggering next historical data download in queue.
2025-01-08 12:46:44.864 | Mapping M2KH1.CME to M2KH21. Service code: cme
2025-01-08 12:46:44.865 | Denali Data Feed | Starting real-time market data updates for: M2KH1.CME (M2KH21). ID: 6 Service code: cme
2025-01-08 12:46:44.865 | Denali Data Feed | Requesting security definition data for: M2KH1.CME (M2KH21). ID: 6
2025-01-08 12:46:44.865 | Added historical Intraday data request for M2KH1.CME to the queue.
2025-01-08 12:46:44.865 | Intraday data recording state for symbol M2KH1.CME is set to download 'Pending'.
2025-01-08 12:46:44.865 | Triggering next historical data download in queue.
2025-01-08 12:46:44.866 | Mapping MESH1.CME to MESH21. Service code: cme
2025-01-08 12:46:44.866 | Denali Data Feed | Starting real-time market data updates for: MESH1.CME (MESH21). ID: 7 Service code: cme
2025-01-08 12:46:44.866 | Denali Data Feed | Requesting security definition data for: MESH1.CME (MESH21). ID: 7
2025-01-08 12:46:44.866 | Added historical Intraday data request for MESH1.CME to the queue.
2025-01-08 12:46:44.866 | Intraday data recording state for symbol MESH1.CME is set to download 'Pending'.
2025-01-08 12:46:44.866 | Triggering next historical data download in queue.
2025-01-08 12:46:44.868 | Mapping YMH5.CBOT to YMH25. Service code: cbot
2025-01-08 12:46:44.868 | Denali Data Feed | Starting real-time market data updates for: YMH5.CBOT (YMH25). ID: 8 Service code: cbot
2025-01-08 12:46:44.868 | Denali Data Feed | Requesting security definition data for: YMH5.CBOT (YMH25). ID: 8
2025-01-08 12:46:44.868 | Added historical Intraday data request for YMH5.CBOT to the queue.
2025-01-08 12:46:44.868 | Intraday data recording state for symbol YMH5.CBOT is set to download 'Pending'.
2025-01-08 12:46:44.868 | Triggering next historical data download in queue.
2025-01-08 12:46:44.869 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-08 12:46:44.869 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 9 Service code: cme
2025-01-08 12:46:44.869 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 9
2025-01-08 12:46:44.869 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-08 12:46:44.869 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-08 12:46:44.869 | Triggering next historical data download in queue.
2025-01-08 12:46:44.871 | Mapping RTYH5.CME to RTYH25. Service code: cme
2025-01-08 12:46:44.871 | Denali Data Feed | Starting real-time market data updates for: RTYH5.CME (RTYH25). ID: 10 Service code: cme
2025-01-08 12:46:44.871 | Denali Data Feed | Requesting security definition data for: RTYH5.CME (RTYH25). ID: 10
2025-01-08 12:46:44.871 | Added historical Intraday data request for RTYH5.CME to the queue.
2025-01-08 12:46:44.871 | Intraday data recording state for symbol RTYH5.CME is set to download 'Pending'.
2025-01-08 12:46:44.871 | Triggering next historical data download in queue.
2025-01-08 12:46:44.872 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-08 12:46:44.872 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 11 Service code: cme
2025-01-08 12:46:44.872 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 11
2025-01-08 12:46:44.872 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-08 12:46:44.872 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-08 12:46:44.872 | Triggering next historical data download in queue.
2025-01-08 12:46:44.873 | Mapping M2KH5.CME to M2KH25. Service code: cme
2025-01-08 12:46:44.873 | Denali Data Feed | Starting real-time market data updates for: M2KH5.CME (M2KH25). ID: 12 Service code: cme
2025-01-08 12:46:44.873 | Denali Data Feed | Requesting security definition data for: M2KH5.CME (M2KH25). ID: 12
2025-01-08 12:46:44.873 | Added historical Intraday data request for M2KH5.CME to the queue.
2025-01-08 12:46:44.873 | Intraday data recording state for symbol M2KH5.CME is set to download 'Pending'.
2025-01-08 12:46:44.873 | Triggering next historical data download in queue.
2025-01-08 12:46:45.001 | Denali Data Feed | Network connection to server complete.
2025-01-08 12:46:45.001 | Denali Data Feed | Starting socket receive thread.
2025-01-08 12:46:45.001 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 12:46:45.168 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 12:46:45.168 | Denali Data Feed | Sending logon request message.
2025-01-08 12:46:45.794 | Denali Data Feed | Received logon response.
2025-01-08 12:46:45.794 | Denali Data Feed | Server Name: SC Realtime Server.
2025-01-08 12:46:45.794 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 12:46:45.794 | Denali Data Feed | Successfully connected.
2025-01-08 12:46:45.794 | Denali Data Feed | Trading is not supported.
2025-01-08 12:46:45.794 | Denali Data Feed | MarketDepthIsSupported: 1
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: ESH5.CME -> ESH25
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: M2KH1.CME -> M2KH21
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: M2KH5.CME -> M2KH25
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: MESH1.CME -> MESH21
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: MESH5.CME -> MESH25
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH1.CME -> MNQH21
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH5.CME -> MNQH25
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: MYMH1.CBOT -> MYMH21
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: MYMH5.CBOT -> MYMH25
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: NQH5.CME -> NQH25
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH5.CME -> RTYH25
2025-01-08 12:46:45.794 | Denali Data Feed | Restarting real-time data updates for symbol: YMH5.CBOT -> YMH25
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol ESH5.CME to 5002
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol ESH5.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Real-time data for symbol M2KH1.CME is currently unavailable.
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol M2KH1.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol M2KH5.CME to 42005649
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol M2KH5.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Real-time data for symbol MESH1.CME is currently unavailable.
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol MESH1.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol MESH5.CME to 42005347
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol MESH5.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Real-time data for symbol MNQH1.CME is currently unavailable.
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol MNQH1.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol MNQH5.CME to 42003617
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol MNQH5.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Real-time data for symbol MYMH1.CBOT is currently unavailable.
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol MYMH1.CBOT
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol MYMH5.CBOT to 42011026
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol MYMH5.CBOT
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol NQH5.CME to 42288528
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol NQH5.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol RTYH5.CME to 42001620
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol RTYH5.CME
2025-01-08 12:46:46.052 | Denali Data Feed | Setting external service identifier for symbol YMH5.CBOT to 42002868
2025-01-08 12:46:46.052 | Denali Data Feed | Received security definition for symbol YMH5.CBOT
2025-01-08 12:46:49.771 | Requesting market depth updates for: M2KH1.CME if supported. NumLevels=100
2025-01-08 12:46:49.771 | Requesting market depth updates for: MESH1.CME if supported. NumLevels=100
2025-01-08 12:46:49.771 | Requesting market depth updates for: MNQH1.CME if supported. NumLevels=100
2025-01-08 12:46:49.771 | Requesting market depth updates for: MYMH1.CBOT if supported. NumLevels=100
2025-01-08 12:46:50.013 | Denali Data Feed | Market Depth data has been rejected for symbol: M2KH1.CME. Not authorized for market depth.
2025-01-08 12:46:50.013 | Denali Data Feed | Market Depth data has been rejected for symbol: MESH1.CME. Not authorized for market depth.
2025-01-08 12:46:50.013 | Denali Data Feed | Market Depth data has been rejected for symbol: MNQH1.CME. Not authorized for market depth.
2025-01-08 12:46:50.013 | Denali Data Feed | Market Depth data has been rejected for symbol: MYMH1.CBOT. Not authorized for market depth.
2025-01-08 12:46:51.888 | HD Request # 40 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: cbot
2025-01-08 12:46:51.888 | HD Request # 40 | Download start date-time: 2025-01-08 12:45:14.000000. File last date-time: 2025-01-08 12:45:14.000000
2025-01-08 12:46:51.889 | HD Request # 40 | Using server: ds26.sierracharts.com port 10150
2025-01-08 12:46:51.889 | Socket (3) | Creating socket.
2025-01-08 12:46:51.889 | Socket (3) | New receive buffer size: 0
2025-01-08 12:46:51.889 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:46:52.223 | HD Request # 40 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:52.223 | HD Request # 40 | Sending historical data logon request message.
2025-01-08 12:46:52.429 | HD Request # 40 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:14. Record interval: 1. Symbol: MYMH25
2025-01-08 12:46:52.590 | HD Request # 40 | Decompressing data.
2025-01-08 12:46:52.749 | HD Request # 40 | Receiving Intraday data for MYMH5.CBOT starting at 2025-01-08 12:45:14.748000
2025-01-08 12:46:52.749 | Socket (3) | CloseSocket call.
2025-01-08 12:46:52.749 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:52.751 | Historical data download thread signaled to stop.
2025-01-08 12:46:52.751 | HD Request # 40 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:14.748000.
2025-01-08 12:46:52.751 | HD Request # 40 | Received 29 Intraday data records from 2025-01-08 12:45:14.748000 to 2025-01-08 12:46:48.395000 (93.6 seconds. Delay: 4.4 seconds) and wrote 29 records for MYMH5.CBOT
2025-01-08 12:46:52.760 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:48.395000
2025-01-08 12:46:52.760 | Added 2 Time and Sales records to Intraday data file for MYMH5.CBOT after download.
2025-01-08 12:46:52.760 | HD Request # 40 | Completion time: 1s.
2025-01-08 12:46:52.760 | HD Request # 40 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 36
2025-01-08 12:46:52.760 | Removing historical data download ID 36.
2025-01-08 12:46:52.760 | Real-time Intraday chart data file updates started for MYMH5.CBOT
2025-01-08 12:46:52.772 | Opened cached Intraday file: C:\SierraChart-1\Data\MYMH5.CBOT.scid. Thread ID: 12492
2025-01-08 12:46:52.772 | Intraday chart data file opened for MYMH5.CBOT
2025-01-08 12:46:52.772 | HD Request # 40 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:52.772 | Triggering next historical data download in queue.
2025-01-08 12:46:52.772 | HD Request # 41 | Downloading Intraday chart data for MYMH1.CBOT to the file MYMH1.CBOT.scid. Service: cbot
2025-01-08 12:46:52.772 | HD Request # 41 | Download start date-time: 2021-03-19 13:29:43.000000. File last date-time: 2021-03-19 13:29:43.603000
2025-01-08 12:46:52.773 | HD Request # 41 | Using server: ds28.sierracharts.com port 10149
2025-01-08 12:46:52.773 | Socket (4) | Creating socket.
2025-01-08 12:46:52.773 | Socket (4) | New receive buffer size: 0
2025-01-08 12:46:52.773 | Socket (4) | Connecting to IP: 67.214.125.5.
2025-01-08 12:46:52.911 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:46:52.911 | Socket (3) | Closed.
2025-01-08 12:46:53.103 | HD Request # 41 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:53.103 | HD Request # 41 | Sending historical data logon request message.
2025-01-08 12:46:53.307 | HD Request # 41 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:43. Record interval: 1. Symbol: MYMH21
2025-01-08 12:46:53.467 | HD Request # 41 | Decompressing data.
2025-01-08 12:46:53.622 | HD Request # 41 | Receiving Intraday data for MYMH1.CBOT starting at 2021-03-19 13:29:43.603000
2025-01-08 12:46:53.623 | Socket (4) | CloseSocket call.
2025-01-08 12:46:53.623 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:53.624 | Historical data download thread signaled to stop.
2025-01-08 12:46:53.624 | HD Request # 41 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:43.603000.
2025-01-08 12:46:53.624 | HD Request # 41 | Received 1 Intraday data record from 2021-03-19 13:29:43.603000 to 2021-03-19 13:29:43.603000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MYMH1.CBOT
2025-01-08 12:46:53.636 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:43.603000
2025-01-08 12:46:53.636 | HD Request # 41 | Completion time: 1s.
2025-01-08 12:46:53.636 | HD Request # 41 | Intraday data download complete for MYMH1.CBOT. Unique request ID: 37
2025-01-08 12:46:53.636 | Removing historical data download ID 37.
2025-01-08 12:46:53.636 | Real-time Intraday chart data file updates started for MYMH1.CBOT
2025-01-08 12:46:53.636 | Opened cached Intraday file: C:\SierraChart-1\Data\MYMH1.CBOT.scid. Thread ID: 12492
2025-01-08 12:46:53.636 | Intraday chart data file opened for MYMH1.CBOT
2025-01-08 12:46:53.636 | HD Request # 41 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:53.636 | Triggering next historical data download in queue.
2025-01-08 12:46:53.636 | HD Request # 42 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-08 12:46:53.637 | HD Request # 42 | Download start date-time: 2025-01-08 12:45:15.000000. File last date-time: 2025-01-08 12:45:15.000000
2025-01-08 12:46:53.637 | HD Request # 42 | Using server: ds32.sierracharts.com port 10150
2025-01-08 12:46:53.637 | Socket (3) | Creating socket.
2025-01-08 12:46:53.637 | Socket (3) | New receive buffer size: 0
2025-01-08 12:46:53.637 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 12:46:53.779 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:46:53.779 | Socket (4) | Closed.
2025-01-08 12:46:53.967 | HD Request # 42 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:53.967 | HD Request # 42 | Sending historical data logon request message.
2025-01-08 12:46:54.170 | HD Request # 42 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:15. Record interval: 1. Symbol: MESH25
2025-01-08 12:46:54.330 | HD Request # 42 | Decompressing data.
2025-01-08 12:46:54.489 | HD Request # 42 | Receiving Intraday data for MESH5.CME starting at 2025-01-08 12:45:15.083000
2025-01-08 12:46:54.490 | Socket (3) | CloseSocket call.
2025-01-08 12:46:54.490 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:54.508 | Historical data download thread signaled to stop.
2025-01-08 12:46:54.508 | HD Request # 42 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:15.083000.
2025-01-08 12:46:54.508 | HD Request # 42 | Received 87 Intraday data records from 2025-01-08 12:45:15.083000 to 2025-01-08 12:46:52.267000 (97.2 seconds. Delay: 2.2 seconds) and wrote 87 records for MESH5.CME
2025-01-08 12:46:54.517 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:52.267000
2025-01-08 12:46:54.517 | Added 1 Time and Sales records to Intraday data file for MESH5.CME after download.
2025-01-08 12:46:54.517 | HD Request # 42 | Completion time: 1s.
2025-01-08 12:46:54.517 | HD Request # 42 | Intraday data download complete for MESH5.CME. Unique request ID: 38
2025-01-08 12:46:54.517 | Removing historical data download ID 38.
2025-01-08 12:46:54.517 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-08 12:46:54.527 | Opened cached Intraday file: C:\SierraChart-1\Data\MESH5.CME.scid. Thread ID: 12492
2025-01-08 12:46:54.527 | Intraday chart data file opened for MESH5.CME
2025-01-08 12:46:54.527 | HD Request # 42 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:54.527 | Triggering next historical data download in queue.
2025-01-08 12:46:54.528 | HD Request # 43 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-08 12:46:54.528 | HD Request # 43 | Download start date-time: 2025-01-08 12:45:15.000000. File last date-time: 2025-01-08 12:45:15.000000
2025-01-08 12:46:54.528 | HD Request # 43 | Using server: ds26.sierracharts.com port 10149
2025-01-08 12:46:54.528 | Socket (4) | Creating socket.
2025-01-08 12:46:54.528 | Socket (4) | New receive buffer size: 0
2025-01-08 12:46:54.528 | Socket (4) | Connecting to IP: 64.152.155.17.
2025-01-08 12:46:54.650 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:46:54.650 | Socket (3) | Closed.
2025-01-08 12:46:54.858 | HD Request # 43 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:54.858 | HD Request # 43 | Sending historical data logon request message.
2025-01-08 12:46:55.056 | HD Request # 43 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:15. Record interval: 1. Symbol: MNQH25
2025-01-08 12:46:55.214 | HD Request # 43 | Decompressing data.
2025-01-08 12:46:55.374 | HD Request # 43 | Receiving Intraday data for MNQH5.CME starting at 2025-01-08 12:45:15.014000
2025-01-08 12:46:55.375 | Socket (4) | CloseSocket call.
2025-01-08 12:46:55.375 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:55.376 | Historical data download thread signaled to stop.
2025-01-08 12:46:55.376 | HD Request # 43 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:15.014000.
2025-01-08 12:46:55.376 | HD Request # 43 | Received 99 Intraday data records from 2025-01-08 12:45:15.014000 to 2025-01-08 12:46:53.232000 (98.2 seconds. Delay: 2.1 seconds) and wrote 99 records for MNQH5.CME
2025-01-08 12:46:55.386 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:53.232000
2025-01-08 12:46:55.386 | Added 2 Time and Sales records to Intraday data file for MNQH5.CME after download.
2025-01-08 12:46:55.386 | HD Request # 43 | Completion time: 1s.
2025-01-08 12:46:55.386 | HD Request # 43 | Intraday data download complete for MNQH5.CME. Unique request ID: 39
2025-01-08 12:46:55.386 | Removing historical data download ID 39.
2025-01-08 12:46:55.386 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-08 12:46:55.396 | Opened cached Intraday file: C:\SierraChart-1\Data\MNQH5.CME.scid. Thread ID: 12492
2025-01-08 12:46:55.396 | Intraday chart data file opened for MNQH5.CME
2025-01-08 12:46:55.396 | HD Request # 43 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:55.396 | Triggering next historical data download in queue.
2025-01-08 12:46:55.396 | HD Request # 44 | Downloading Intraday chart data for MNQH1.CME to the file MNQH1.CME.scid. Service: cme
2025-01-08 12:46:55.396 | HD Request # 44 | Download start date-time: 2021-03-19 13:29:59.000000. File last date-time: 2021-03-19 13:29:59.647000
2025-01-08 12:46:55.397 | HD Request # 44 | Using server: ds28.sierracharts.com port 10150
2025-01-08 12:46:55.397 | Socket (3) | Creating socket.
2025-01-08 12:46:55.397 | Socket (3) | New receive buffer size: 0
2025-01-08 12:46:55.397 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:46:55.534 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:46:55.534 | Socket (4) | Closed.
2025-01-08 12:46:55.722 | HD Request # 44 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:55.722 | HD Request # 44 | Sending historical data logon request message.
2025-01-08 12:46:55.927 | HD Request # 44 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:59. Record interval: 1. Symbol: MNQH21
2025-01-08 12:46:56.086 | HD Request # 44 | Decompressing data.
2025-01-08 12:46:56.240 | HD Request # 44 | Receiving Intraday data for MNQH1.CME starting at 2021-03-19 13:29:59.647000
2025-01-08 12:46:56.241 | Socket (3) | CloseSocket call.
2025-01-08 12:46:56.241 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:56.245 | Historical data download thread signaled to stop.
2025-01-08 12:46:56.246 | HD Request # 44 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:59.647000.
2025-01-08 12:46:56.246 | HD Request # 44 | Received 1 Intraday data record from 2021-03-19 13:29:59.647000 to 2021-03-19 13:29:59.647000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MNQH1.CME
2025-01-08 12:46:56.273 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:59.647000
2025-01-08 12:46:56.273 | HD Request # 44 | Completion time: 1s.
2025-01-08 12:46:56.273 | HD Request # 44 | Intraday data download complete for MNQH1.CME. Unique request ID: 40
2025-01-08 12:46:56.273 | Removing historical data download ID 40.
2025-01-08 12:46:56.273 | Real-time Intraday chart data file updates started for MNQH1.CME
2025-01-08 12:46:56.274 | Opened cached Intraday file: C:\SierraChart-1\Data\MNQH1.CME.scid. Thread ID: 12492
2025-01-08 12:46:56.274 | Intraday chart data file opened for MNQH1.CME
2025-01-08 12:46:56.274 | HD Request # 44 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:56.274 | Triggering next historical data download in queue.
2025-01-08 12:46:56.274 | HD Request # 45 | Downloading Intraday chart data for M2KH1.CME to the file M2KH1.CME.scid. Service: cme
2025-01-08 12:46:56.275 | HD Request # 45 | Download start date-time: 2021-03-19 13:29:43.000000. File last date-time: 2021-03-19 13:29:43.853000
2025-01-08 12:46:56.276 | HD Request # 45 | Using server: ds32.sierracharts.com port 10149
2025-01-08 12:46:56.276 | Socket (4) | Creating socket.
2025-01-08 12:46:56.276 | Socket (4) | New receive buffer size: 0
2025-01-08 12:46:56.276 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-08 12:46:56.397 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:46:56.397 | Socket (3) | Closed.
2025-01-08 12:46:56.590 | HD Request # 45 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:56.590 | HD Request # 45 | Sending historical data logon request message.
2025-01-08 12:46:56.792 | HD Request # 45 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:43. Record interval: 1. Symbol: M2KH21
2025-01-08 12:46:56.945 | HD Request # 45 | Decompressing data.
2025-01-08 12:46:57.098 | HD Request # 45 | Receiving Intraday data for M2KH1.CME starting at 2021-03-19 13:29:43.853000
2025-01-08 12:46:57.098 | Socket (4) | CloseSocket call.
2025-01-08 12:46:57.098 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:57.100 | Historical data download thread signaled to stop.
2025-01-08 12:46:57.100 | HD Request # 45 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:43.853000.
2025-01-08 12:46:57.100 | HD Request # 45 | Received 1 Intraday data record from 2021-03-19 13:29:43.853000 to 2021-03-19 13:29:43.853000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for M2KH1.CME
2025-01-08 12:46:57.112 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:43.853000
2025-01-08 12:46:57.112 | HD Request # 45 | Completion time: 1s.
2025-01-08 12:46:57.112 | HD Request # 45 | Intraday data download complete for M2KH1.CME. Unique request ID: 41
2025-01-08 12:46:57.112 | Removing historical data download ID 41.
2025-01-08 12:46:57.112 | Real-time Intraday chart data file updates started for M2KH1.CME
2025-01-08 12:46:57.113 | Opened cached Intraday file: C:\SierraChart-1\Data\M2KH1.CME.scid. Thread ID: 12492
2025-01-08 12:46:57.113 | Intraday chart data file opened for M2KH1.CME
2025-01-08 12:46:57.113 | HD Request # 45 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:57.113 | Triggering next historical data download in queue.
2025-01-08 12:46:57.113 | HD Request # 46 | Downloading Intraday chart data for MESH1.CME to the file MESH1.CME.scid. Service: cme
2025-01-08 12:46:57.113 | HD Request # 46 | Download start date-time: 2021-03-19 13:29:54.000000. File last date-time: 2021-03-19 13:29:54.945000
2025-01-08 12:46:57.114 | HD Request # 46 | Using server: ds26.sierracharts.com port 10150
2025-01-08 12:46:57.114 | Socket (3) | Creating socket.
2025-01-08 12:46:57.114 | Socket (3) | New receive buffer size: 0
2025-01-08 12:46:57.114 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 12:46:57.252 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:46:57.252 | Socket (4) | Closed.
2025-01-08 12:46:57.431 | HD Request # 46 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:57.431 | HD Request # 46 | Sending historical data logon request message.
2025-01-08 12:46:57.584 | HD Request # 46 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:54. Record interval: 1. Symbol: MESH21
2025-01-08 12:46:57.737 | HD Request # 46 | Decompressing data.
2025-01-08 12:46:57.889 | HD Request # 46 | Receiving Intraday data for MESH1.CME starting at 2021-03-19 13:29:54.945000
2025-01-08 12:46:57.890 | Socket (3) | CloseSocket call.
2025-01-08 12:46:57.890 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:57.891 | Historical data download thread signaled to stop.
2025-01-08 12:46:57.891 | HD Request # 46 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:54.945000.
2025-01-08 12:46:57.891 | HD Request # 46 | Received 1 Intraday data record from 2021-03-19 13:29:54.945000 to 2021-03-19 13:29:54.945000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MESH1.CME
2025-01-08 12:46:57.902 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:54.945000
2025-01-08 12:46:57.902 | HD Request # 46 | Completion time: 0s.
2025-01-08 12:46:57.902 | HD Request # 46 | Intraday data download complete for MESH1.CME. Unique request ID: 42
2025-01-08 12:46:57.902 | Removing historical data download ID 42.
2025-01-08 12:46:57.902 | Real-time Intraday chart data file updates started for MESH1.CME
2025-01-08 12:46:57.902 | Opened cached Intraday file: C:\SierraChart-1\Data\MESH1.CME.scid. Thread ID: 12492
2025-01-08 12:46:57.903 | Intraday chart data file opened for MESH1.CME
2025-01-08 12:46:57.903 | HD Request # 46 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:57.903 | Triggering next historical data download in queue.
2025-01-08 12:46:57.903 | HD Request # 47 | Downloading Intraday chart data for YMH5.CBOT to the file YMH5.CBOT.scid. Service: cbot
2025-01-08 12:46:57.903 | HD Request # 47 | Download start date-time: 2025-01-08 12:45:15.000000. File last date-time: 2025-01-08 12:45:15.000000
2025-01-08 12:46:57.904 | HD Request # 47 | Using server: ds28.sierracharts.com port 10149
2025-01-08 12:46:57.904 | Socket (4) | Creating socket.
2025-01-08 12:46:57.904 | Socket (4) | New receive buffer size: 0
2025-01-08 12:46:57.904 | Socket (4) | Connecting to IP: 67.214.125.5.
2025-01-08 12:46:58.044 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:46:58.044 | Socket (3) | Closed.
2025-01-08 12:46:58.239 | HD Request # 47 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:58.239 | HD Request # 47 | Sending historical data logon request message.
2025-01-08 12:46:58.398 | HD Request # 47 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:15. Record interval: 1. Symbol: YMH25
2025-01-08 12:46:58.559 | HD Request # 47 | Decompressing data.
2025-01-08 12:46:58.720 | HD Request # 47 | Receiving Intraday data for YMH5.CBOT starting at 2025-01-08 12:45:15.948000
2025-01-08 12:46:58.721 | Socket (4) | CloseSocket call.
2025-01-08 12:46:58.721 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:58.722 | Historical data download thread signaled to stop.
2025-01-08 12:46:58.722 | HD Request # 47 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:15.948000.
2025-01-08 12:46:58.722 | HD Request # 47 | Received 41 Intraday data records from 2025-01-08 12:45:15.948000 to 2025-01-08 12:46:54.601000 (98.7 seconds. Delay: 4.1 seconds) and wrote 41 records for YMH5.CBOT
2025-01-08 12:46:58.731 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:54.601000
2025-01-08 12:46:58.731 | Added 1 Time and Sales records to Intraday data file for YMH5.CBOT after download.
2025-01-08 12:46:58.731 | HD Request # 47 | Completion time: 1s.
2025-01-08 12:46:58.731 | HD Request # 47 | Intraday data download complete for YMH5.CBOT. Unique request ID: 43
2025-01-08 12:46:58.731 | Removing historical data download ID 43.
2025-01-08 12:46:58.731 | Real-time Intraday chart data file updates started for YMH5.CBOT
2025-01-08 12:46:58.740 | Opened cached Intraday file: C:\SierraChart-1\Data\YMH5.CBOT.scid. Thread ID: 12492
2025-01-08 12:46:58.740 | Intraday chart data file opened for YMH5.CBOT
2025-01-08 12:46:58.740 | HD Request # 47 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:58.740 | Triggering next historical data download in queue.
2025-01-08 12:46:58.740 | HD Request # 48 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-08 12:46:58.740 | HD Request # 48 | Download start date-time: 2025-01-08 12:45:16.000000. File last date-time: 2025-01-08 12:45:16.000000
2025-01-08 12:46:58.740 | HD Request # 48 | Using server: ds32.sierracharts.com port 10150
2025-01-08 12:46:58.740 | Socket (3) | Creating socket.
2025-01-08 12:46:58.740 | Socket (3) | New receive buffer size: 0
2025-01-08 12:46:58.740 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 12:46:58.885 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:46:58.885 | Socket (4) | Closed.
2025-01-08 12:46:59.060 | HD Request # 48 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:59.060 | HD Request # 48 | Sending historical data logon request message.
2025-01-08 12:46:59.215 | HD Request # 48 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:16. Record interval: 1. Symbol: NQH25
2025-01-08 12:46:59.370 | HD Request # 48 | Decompressing data.
2025-01-08 12:46:59.528 | HD Request # 48 | Receiving Intraday data for NQH5.CME starting at 2025-01-08 12:45:16.058000
2025-01-08 12:46:59.529 | Socket (3) | CloseSocket call.
2025-01-08 12:46:59.529 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:46:59.539 | Historical data download thread signaled to stop.
2025-01-08 12:46:59.539 | HD Request # 48 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:16.058000.
2025-01-08 12:46:59.540 | HD Request # 48 | Received 79 Intraday data records from 2025-01-08 12:45:16.058000 to 2025-01-08 12:46:55.159000 (99.1 seconds. Delay: 4.4 seconds) and wrote 79 records for NQH5.CME
2025-01-08 12:46:59.549 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:55.159000
2025-01-08 12:46:59.549 | Added 3 Time and Sales records to Intraday data file for NQH5.CME after download.
2025-01-08 12:46:59.549 | HD Request # 48 | Completion time: 1s.
2025-01-08 12:46:59.549 | HD Request # 48 | Intraday data download complete for NQH5.CME. Unique request ID: 44
2025-01-08 12:46:59.549 | Removing historical data download ID 44.
2025-01-08 12:46:59.549 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-08 12:46:59.558 | Opened cached Intraday file: C:\SierraChart-1\Data\NQH5.CME.scid. Thread ID: 12492
2025-01-08 12:46:59.558 | Intraday chart data file opened for NQH5.CME
2025-01-08 12:46:59.558 | HD Request # 48 | Enabling Intraday chart updating for symbol.
2025-01-08 12:46:59.558 | Triggering next historical data download in queue.
2025-01-08 12:46:59.560 | HD Request # 49 | Downloading Intraday chart data for RTYH5.CME to the file RTYH5.CME.scid. Service: cme
2025-01-08 12:46:59.560 | HD Request # 49 | Download start date-time: 2025-01-08 12:45:11.000000. File last date-time: 2025-01-08 12:45:11.000000
2025-01-08 12:46:59.560 | HD Request # 49 | Using server: ds26.sierracharts.com port 10149
2025-01-08 12:46:59.560 | Socket (4) | Creating socket.
2025-01-08 12:46:59.560 | Socket (4) | New receive buffer size: 0
2025-01-08 12:46:59.560 | Socket (4) | Connecting to IP: 64.152.155.17.
2025-01-08 12:46:59.690 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:46:59.690 | Socket (3) | Closed.
2025-01-08 12:46:59.898 | HD Request # 49 | Setting DTC encoding to Binary VLS
2025-01-08 12:46:59.898 | HD Request # 49 | Sending historical data logon request message.
2025-01-08 12:47:00.059 | HD Request # 49 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:11. Record interval: 1. Symbol: RTYH25
2025-01-08 12:47:00.218 | HD Request # 49 | Decompressing data.
2025-01-08 12:47:00.381 | HD Request # 49 | Receiving Intraday data for RTYH5.CME starting at 2025-01-08 12:45:11.833000
2025-01-08 12:47:00.382 | Socket (4) | CloseSocket call.
2025-01-08 12:47:00.382 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:47:00.383 | Historical data download thread signaled to stop.
2025-01-08 12:47:00.383 | HD Request # 49 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:11.833000.
2025-01-08 12:47:00.383 | HD Request # 49 | Received 27 Intraday data records from 2025-01-08 12:45:11.833000 to 2025-01-08 12:46:55.690000 (103.9 seconds. Delay: 4.7 seconds) and wrote 27 records for RTYH5.CME
2025-01-08 12:47:00.393 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:55.690000
2025-01-08 12:47:00.393 | Added 1 Time and Sales records to Intraday data file for RTYH5.CME after download.
2025-01-08 12:47:00.393 | HD Request # 49 | Completion time: 1s.
2025-01-08 12:47:00.393 | HD Request # 49 | Intraday data download complete for RTYH5.CME. Unique request ID: 45
2025-01-08 12:47:00.393 | Removing historical data download ID 45.
2025-01-08 12:47:00.393 | Real-time Intraday chart data file updates started for RTYH5.CME
2025-01-08 12:47:00.402 | Opened cached Intraday file: C:\SierraChart-1\Data\RTYH5.CME.scid. Thread ID: 12492
2025-01-08 12:47:00.402 | Intraday chart data file opened for RTYH5.CME
2025-01-08 12:47:00.402 | HD Request # 49 | Enabling Intraday chart updating for symbol.
2025-01-08 12:47:00.402 | Triggering next historical data download in queue.
2025-01-08 12:47:00.402 | HD Request # 50 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-08 12:47:00.402 | HD Request # 50 | Download start date-time: 2025-01-08 12:45:15.000000. File last date-time: 2025-01-08 12:45:15.000000
2025-01-08 12:47:00.403 | HD Request # 50 | Using server: ds28.sierracharts.com port 10150
2025-01-08 12:47:00.403 | Socket (3) | Creating socket.
2025-01-08 12:47:00.403 | Socket (3) | New receive buffer size: 0
2025-01-08 12:47:00.403 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 12:47:00.544 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:47:00.544 | Socket (4) | Closed.
2025-01-08 12:47:00.750 | HD Request # 50 | Setting DTC encoding to Binary VLS
2025-01-08 12:47:00.750 | HD Request # 50 | Sending historical data logon request message.
2025-01-08 12:47:00.912 | HD Request # 50 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:15. Record interval: 1. Symbol: ESH25
2025-01-08 12:47:01.076 | HD Request # 50 | Decompressing data.
2025-01-08 12:47:01.238 | HD Request # 50 | Receiving Intraday data for ESH5.CME starting at 2025-01-08 12:45:15.083000
2025-01-08 12:47:01.238 | Socket (3) | CloseSocket call.
2025-01-08 12:47:01.239 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:47:01.244 | Historical data download thread signaled to stop.
2025-01-08 12:47:01.244 | HD Request # 50 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:15.083000.
2025-01-08 12:47:01.244 | HD Request # 50 | Received 76 Intraday data records from 2025-01-08 12:45:15.083000 to 2025-01-08 12:46:57.306000 (102.2 seconds. Delay: 3.9 seconds) and wrote 76 records for ESH5.CME
2025-01-08 12:47:01.253 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:57.306000
2025-01-08 12:47:01.253 | Added 2 Time and Sales records to Intraday data file for ESH5.CME after download.
2025-01-08 12:47:01.253 | HD Request # 50 | Completion time: 1s.
2025-01-08 12:47:01.253 | HD Request # 50 | Intraday data download complete for ESH5.CME. Unique request ID: 46
2025-01-08 12:47:01.253 | Removing historical data download ID 46.
2025-01-08 12:47:01.253 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-08 12:47:01.264 | Opened cached Intraday file: C:\SierraChart-1\Data\ESH5.CME.scid. Thread ID: 12492
2025-01-08 12:47:01.264 | Intraday chart data file opened for ESH5.CME
2025-01-08 12:47:01.264 | HD Request # 50 | Enabling Intraday chart updating for symbol.
2025-01-08 12:47:01.264 | Triggering next historical data download in queue.
2025-01-08 12:47:01.264 | HD Request # 51 | Downloading Intraday chart data for M2KH5.CME to the file M2KH5.CME.scid. Service: cme
2025-01-08 12:47:01.264 | HD Request # 51 | Download start date-time: 2025-01-08 12:45:11.000000. File last date-time: 2025-01-08 12:45:11.000000
2025-01-08 12:47:01.264 | HD Request # 51 | Using server: ds32.sierracharts.com port 10149
2025-01-08 12:47:01.265 | Socket (4) | Creating socket.
2025-01-08 12:47:01.265 | Socket (4) | New receive buffer size: 0
2025-01-08 12:47:01.265 | Socket (4) | Connecting to IP: 67.214.125.3.
2025-01-08 12:47:01.401 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 12:47:01.401 | Socket (3) | Closed.
2025-01-08 12:47:01.585 | HD Request # 51 | Setting DTC encoding to Binary VLS
2025-01-08 12:47:01.585 | HD Request # 51 | Sending historical data logon request message.
2025-01-08 12:47:01.740 | HD Request # 51 | Requesting Intraday data. Start date-time: 2025-01-08 12:45:11. Record interval: 1. Symbol: M2KH25
2025-01-08 12:47:01.895 | HD Request # 51 | Decompressing data.
2025-01-08 12:47:02.048 | HD Request # 51 | Receiving Intraday data for M2KH5.CME starting at 2025-01-08 12:45:11.749000
2025-01-08 12:47:02.049 | Socket (4) | CloseSocket call.
2025-01-08 12:47:02.049 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-08 12:47:02.050 | Historical data download thread signaled to stop.
2025-01-08 12:47:02.050 | HD Request # 51 | Timestamp of first Intraday data file record written: 2025-01-08 12:45:11.749000.
2025-01-08 12:47:02.051 | HD Request # 51 | Received 29 Intraday data records from 2025-01-08 12:45:11.749000 to 2025-01-08 12:46:58.640000 (106.9 seconds. Delay: 3.4 seconds) and wrote 29 records for M2KH5.CME
2025-01-08 12:47:02.059 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2025-01-08 12:46:58.640000
2025-01-08 12:47:02.059 | Added 1 Time and Sales records to Intraday data file for M2KH5.CME after download.
2025-01-08 12:47:02.059 | HD Request # 51 | Completion time: 1s.
2025-01-08 12:47:02.059 | HD Request # 51 | Intraday data download complete for M2KH5.CME. Unique request ID: 47
2025-01-08 12:47:02.059 | Removing historical data download ID 47.
2025-01-08 12:47:02.059 | Real-time Intraday chart data file updates started for M2KH5.CME
2025-01-08 12:47:02.068 | Opened cached Intraday file: C:\SierraChart-1\Data\M2KH5.CME.scid. Thread ID: 12492
2025-01-08 12:47:02.068 | Intraday chart data file opened for M2KH5.CME
2025-01-08 12:47:02.068 | HD Request # 51 | Enabling Intraday chart updating for symbol.
2025-01-08 12:47:02.068 | No download requests in the queue to start downloads for.
2025-01-08 12:47:02.204 | Socket (4) | Socket gracefully closed by remote side.
2025-01-08 12:47:02.204 | Socket (4) | Closed.
2025-01-08 12:47:03.204 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Creating socket. Using TLS 1.2.
2025-01-08 12:47:03.204 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | New receive buffer size: 0
2025-01-08 12:47:03.204 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Connecting to IP: 216.66.0.130.
2025-01-08 12:47:03.954 | Rithmic Direct - DTC | Wrote file: C:\SierraChart-1\RithmicConnections.json. Size: 81131
2025-01-08 12:47:03.955 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-08 12:47:04.207 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | CloseSocket call.
2025-01-08 12:47:04.207 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Shutdown started. Waiting for graceful close.
2025-01-08 12:47:04.339 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Socket gracefully closed by remote side.
2025-01-08 12:47:04.339 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Closed.
2025-01-08 12:48:37.856 | File >> Disconnect selected.
2025-01-08 12:48:37.862 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-01-08 12:48:37.862 | DTC Client socket (1) | CloseSocket call.
2025-01-08 12:48:37.862 | DTC Client socket (1) | Max send buffers used during socket life: 3
2025-01-08 12:48:37.862 | DTC Client socket (1) | Max send buffer size during socket life: 406
2025-01-08 12:48:37.862 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-08 12:48:37.863 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 12:48:37.863 | DTC Client socket (2) | CloseSocket call.
2025-01-08 12:48:37.863 | Denali Data Feed | Disconnected from the server.
2025-01-08 12:48:37.863 | Rithmic Direct - DTC | Disconnected.
2025-01-08 12:48:37.865 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 12:48:38.104 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 12:48:38.104 | DTC Client socket (2) | Closed.
2025-01-08 12:48:38.167 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-08 12:48:38.167 | DTC Client socket (1) | Closed.
2025-01-08 16:15:50.811 | M2KH1.CME[M] #7 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.812 | MESH1.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.813 | YMH5.CBOT[M] 5 Min #5 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.814 | NQH5.CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.815 | MNQH1.CME[M] #6 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.823 | M2KH1.CME[M] #7 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.823 | RTYH5.CME[M] 15 Min #2 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.824 | MESH1.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.824 | ESH5.CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.825 | M2KH5.CME[M] 15 Min #2 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.870 | MYMH5.CBOT[M] 5 Min #5 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.896 | MESH5.CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.966 | MNQH5.CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.998 | MNQH1.CME[M] #6 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:50.999 | MYMH1.CBOT[M] #8 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00 | Number times message added: 1
2025-01-08 16:15:54.762 | MYMH5.CBOT[M] 5 Min #5 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.812 | MESH5.CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.829 | M2KH5.CME[M] 15 Min #2 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.847 | MNQH5.CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.945 | M2KH1.CME[M] #7 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.945 | MESH1.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.946 | MNQH1.CME[M] #6 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.946 | M2KH1.CME[M] #7 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.946 | MYMH1.CBOT[M] #8 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.947 | YMH5.CBOT[M] 5 Min #5 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.947 | ESH5.CME[M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.948 | RTYH5.CME[M] 15 Min #2 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.948 | NQH5.CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.948 | MESH1.CME[M] #4 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.949 | MNQH1.CME[M] #6 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:15:54.949 | MYMH1.CBOT[M] #8 | StartDateTimeForLoadingOrderFills: 2024-01-02 00:00:00
2025-01-08 16:16:44.461 |
2025-01-08 16:16:44.462 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Hongkong-Aggregated
2025-01-08 16:16:44.462 | Rithmic Direct - DTC | Trading server address/port: rsc-hk.rithmic.com:40804
2025-01-08 16:16:44.462 | Rithmic Direct - DTC | Connecting to the server rsc-hk.rithmic.com. Port 40804
2025-01-08 16:16:44.950 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-01-08 16:16:44.950 | DTC Client socket (1) | New receive buffer size: 0
2025-01-08 16:16:44.950 | DTC Client socket (1) | Connecting to IP: 18.163.3.182.
2025-01-08 16:16:45.250 | Rithmic Direct - DTC | Network connection to server complete.
2025-01-08 16:16:45.250 | Rithmic Direct - DTC | Starting socket receive thread.
2025-01-08 16:16:45.250 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-01-08 16:16:45.250 | Rithmic Direct - DTC | Sending logon request message.
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Received logon response.
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Server Name: .
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Successfully connected.
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Trading is supported.
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | OCO Orders supported.
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-01-08 16:16:46.362 | Rithmic Direct - DTC | Connected to server complete.
2025-01-08 16:16:46.363 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-08 16:16:46.455 | Mapping MESH1.CME to MESH21. Service code: cme
2025-01-08 16:16:46.455 | Using symbol data fast lookup vector
2025-01-08 16:16:46.456 | Denali Data Feed | Starting real-time market data updates for: MESH1.CME (MESH21). ID: 1 Service code: cme
2025-01-08 16:16:46.456 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 10048
2025-01-08 16:16:46.456 | Denali Data Feed | Requesting security definition data for: MESH1.CME (MESH21). ID: 1
2025-01-08 16:16:46.456 | Added historical Intraday data request for MESH1.CME to the queue.
2025-01-08 16:16:46.456 | Intraday data recording state for symbol MESH1.CME is set to download 'Pending'.
2025-01-08 16:16:46.456 | Triggering next historical data download in queue.
2025-01-08 16:16:46.458 | Delaying start of download for MESH1.CME.
2025-01-08 16:16:46.458 | Mapping YMH5.CBOT to YMH25. Service code: cbot
2025-01-08 16:16:46.458 | Denali Data Feed | Starting real-time market data updates for: YMH5.CBOT (YMH25). ID: 2 Service code: cbot
2025-01-08 16:16:46.458 | Denali Data Feed | Requesting security definition data for: YMH5.CBOT (YMH25). ID: 2
2025-01-08 16:16:46.458 | Added historical Intraday data request for YMH5.CBOT to the queue.
2025-01-08 16:16:46.458 | Intraday data recording state for symbol YMH5.CBOT is set to download 'Pending'.
2025-01-08 16:16:46.458 | Triggering next historical data download in queue.
2025-01-08 16:16:46.461 | Mapping NQH5.CME to NQH25. Service code: cme
2025-01-08 16:16:46.461 | Denali Data Feed | Starting real-time market data updates for: NQH5.CME (NQH25). ID: 3 Service code: cme
2025-01-08 16:16:46.461 | Denali Data Feed | Requesting security definition data for: NQH5.CME (NQH25). ID: 3
2025-01-08 16:16:46.461 | Added historical Intraday data request for NQH5.CME to the queue.
2025-01-08 16:16:46.461 | Intraday data recording state for symbol NQH5.CME is set to download 'Pending'.
2025-01-08 16:16:46.461 | Triggering next historical data download in queue.
2025-01-08 16:16:46.464 | Mapping MNQH1.CME to MNQH21. Service code: cme
2025-01-08 16:16:46.465 | Denali Data Feed | Starting real-time market data updates for: MNQH1.CME (MNQH21). ID: 4 Service code: cme
2025-01-08 16:16:46.465 | Denali Data Feed | Requesting security definition data for: MNQH1.CME (MNQH21). ID: 4
2025-01-08 16:16:46.465 | Added historical Intraday data request for MNQH1.CME to the queue.
2025-01-08 16:16:46.465 | Intraday data recording state for symbol MNQH1.CME is set to download 'Pending'.
2025-01-08 16:16:46.465 | Triggering next historical data download in queue.
2025-01-08 16:16:46.467 | Mapping M2KH1.CME to M2KH21. Service code: cme
2025-01-08 16:16:46.468 | Denali Data Feed | Starting real-time market data updates for: M2KH1.CME (M2KH21). ID: 5 Service code: cme
2025-01-08 16:16:46.468 | Denali Data Feed | Requesting security definition data for: M2KH1.CME (M2KH21). ID: 5
2025-01-08 16:16:46.468 | Added historical Intraday data request for M2KH1.CME to the queue.
2025-01-08 16:16:46.468 | Intraday data recording state for symbol M2KH1.CME is set to download 'Pending'.
2025-01-08 16:16:46.468 | Triggering next historical data download in queue.
2025-01-08 16:16:46.471 | Mapping RTYH5.CME to RTYH25. Service code: cme
2025-01-08 16:16:46.471 | Denali Data Feed | Starting real-time market data updates for: RTYH5.CME (RTYH25). ID: 6 Service code: cme
2025-01-08 16:16:46.471 | Denali Data Feed | Requesting security definition data for: RTYH5.CME (RTYH25). ID: 6
2025-01-08 16:16:46.471 | Added historical Intraday data request for RTYH5.CME to the queue.
2025-01-08 16:16:46.471 | Intraday data recording state for symbol RTYH5.CME is set to download 'Pending'.
2025-01-08 16:16:46.471 | Triggering next historical data download in queue.
2025-01-08 16:16:46.475 | Mapping ESH5.CME to ESH25. Service code: cme
2025-01-08 16:16:46.475 | Denali Data Feed | Starting real-time market data updates for: ESH5.CME (ESH25). ID: 7 Service code: cme
2025-01-08 16:16:46.475 | Denali Data Feed | Requesting security definition data for: ESH5.CME (ESH25). ID: 7
2025-01-08 16:16:46.475 | Added historical Intraday data request for ESH5.CME to the queue.
2025-01-08 16:16:46.475 | Intraday data recording state for symbol ESH5.CME is set to download 'Pending'.
2025-01-08 16:16:46.475 | Triggering next historical data download in queue.
2025-01-08 16:16:46.478 | Mapping M2KH5.CME to M2KH25. Service code: cme
2025-01-08 16:16:46.478 | Denali Data Feed | Starting real-time market data updates for: M2KH5.CME (M2KH25). ID: 8 Service code: cme
2025-01-08 16:16:46.478 | Denali Data Feed | Requesting security definition data for: M2KH5.CME (M2KH25). ID: 8
2025-01-08 16:16:46.478 | Added historical Intraday data request for M2KH5.CME to the queue.
2025-01-08 16:16:46.478 | Intraday data recording state for symbol M2KH5.CME is set to download 'Pending'.
2025-01-08 16:16:46.478 | Triggering next historical data download in queue.
2025-01-08 16:16:46.524 | Mapping MYMH5.CBOT to MYMH25. Service code: cbot
2025-01-08 16:16:46.524 | Denali Data Feed | Starting real-time market data updates for: MYMH5.CBOT (MYMH25). ID: 9 Service code: cbot
2025-01-08 16:16:46.524 | Denali Data Feed | Requesting security definition data for: MYMH5.CBOT (MYMH25). ID: 9
2025-01-08 16:16:46.524 | Added historical Intraday data request for MYMH5.CBOT to the queue.
2025-01-08 16:16:46.524 | Intraday data recording state for symbol MYMH5.CBOT is set to download 'Pending'.
2025-01-08 16:16:46.524 | Triggering next historical data download in queue.
2025-01-08 16:16:46.561 | Mapping MYMH1.CBOT to MYMH21. Service code: cbot
2025-01-08 16:16:46.562 | Denali Data Feed | Starting real-time market data updates for: MYMH1.CBOT (MYMH21). ID: 10 Service code: cbot
2025-01-08 16:16:46.562 | Denali Data Feed | Requesting security definition data for: MYMH1.CBOT (MYMH21). ID: 10
2025-01-08 16:16:46.562 | Added historical Intraday data request for MYMH1.CBOT to the queue.
2025-01-08 16:16:46.562 | Intraday data recording state for symbol MYMH1.CBOT is set to download 'Pending'.
2025-01-08 16:16:46.562 | Triggering next historical data download in queue.
2025-01-08 16:16:46.563 | Mapping MESH5.CME to MESH25. Service code: cme
2025-01-08 16:16:46.563 | Denali Data Feed | Starting real-time market data updates for: MESH5.CME (MESH25). ID: 11 Service code: cme
2025-01-08 16:16:46.563 | Denali Data Feed | Requesting security definition data for: MESH5.CME (MESH25). ID: 11
2025-01-08 16:16:46.563 | Added historical Intraday data request for MESH5.CME to the queue.
2025-01-08 16:16:46.563 | Intraday data recording state for symbol MESH5.CME is set to download 'Pending'.
2025-01-08 16:16:46.563 | Triggering next historical data download in queue.
2025-01-08 16:16:46.583 | Mapping MNQH5.CME to MNQH25. Service code: cme
2025-01-08 16:16:46.583 | Denali Data Feed | Starting real-time market data updates for: MNQH5.CME (MNQH25). ID: 12 Service code: cme
2025-01-08 16:16:46.583 | Denali Data Feed | Requesting security definition data for: MNQH5.CME (MNQH25). ID: 12
2025-01-08 16:16:46.583 | Added historical Intraday data request for MNQH5.CME to the queue.
2025-01-08 16:16:46.583 | Intraday data recording state for symbol MNQH5.CME is set to download 'Pending'.
2025-01-08 16:16:46.583 | Triggering next historical data download in queue.
2025-01-08 16:16:49.775 | DTC Client socket (2) | Creating socket.
2025-01-08 16:16:49.775 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 16:16:49.775 | DTC Client socket (2) | Connecting to IP: 64.152.155.21.
2025-01-08 16:16:49.938 | Denali Data Feed | Network connection to server complete.
2025-01-08 16:16:49.938 | Denali Data Feed | Starting socket receive thread.
2025-01-08 16:16:49.938 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 16:16:50.107 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 16:16:50.107 | Denali Data Feed | Sending logon request message.
2025-01-08 16:16:50.629 | Denali Data Feed | Received logon response.
2025-01-08 16:16:50.629 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 16:16:50.629 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 16:16:50.629 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 16:16:50.629 | Denali Data Feed | Failed connections: 1
2025-01-08 16:16:50.629 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 16:16:50.630 | DTC Client socket (2) | CloseSocket call.
2025-01-08 16:16:50.630 | Denali Data Feed | Disconnected from the server.
2025-01-08 16:16:50.630 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 16:16:50.630 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:16:50.791 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:16:50.791 | DTC Client socket (2) | Closed.
2025-01-08 16:16:51.374 | Requesting market depth updates for: M2KH1.CME if supported. NumLevels=100
2025-01-08 16:16:51.374 | Requesting market depth updates for: MESH1.CME if supported. NumLevels=100
2025-01-08 16:16:51.374 | Requesting market depth updates for: MNQH1.CME if supported. NumLevels=100
2025-01-08 16:16:51.374 | Requesting market depth updates for: MYMH1.CBOT if supported. NumLevels=100
2025-01-08 16:17:04.637 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2.
2025-01-08 16:17:04.638 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | New receive buffer size: 0
2025-01-08 16:17:04.638 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Connecting to IP: 216.66.0.130.
2025-01-08 16:17:05.476 | Rithmic Direct - DTC | Wrote file: C:\SierraChart-1\RithmicConnections.json. Size: 81131
2025-01-08 16:17:05.477 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-01-08 16:17:05.720 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | CloseSocket call.
2025-01-08 16:17:05.720 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:05.860 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:05.860 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Closed.
2025-01-08 16:17:17.822 | HD Request # 52 | Downloading Intraday chart data for MESH1.CME to the file MESH1.CME.scid. Service: cme
2025-01-08 16:17:17.839 | HD Request # 52 | Download start date-time: 2021-03-19 13:29:54.000000. File last date-time: 2021-03-19 13:29:54.945000
2025-01-08 16:17:17.839 | HD Request # 52 | Using server: ds26.sierracharts.com port 10150
2025-01-08 16:17:17.910 | Socket (2) | Creating socket.
2025-01-08 16:17:17.910 | Socket (2) | New receive buffer size: 0
2025-01-08 16:17:17.910 | Socket (2) | Connecting to IP: 64.152.155.17.
2025-01-08 16:17:18.247 | HD Request # 52 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:18.247 | HD Request # 52 | Sending historical data logon request message.
2025-01-08 16:17:18.449 | HD Request # 52 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:54. Record interval: 1. Symbol: MESH21
2025-01-08 16:17:18.610 | HD Request # 52 | Decompressing data.
2025-01-08 16:17:18.771 | HD Request # 52 | Receiving Intraday data for MESH1.CME starting at 2021-03-19 13:29:54.945000
2025-01-08 16:17:18.772 | Socket (2) | CloseSocket call.
2025-01-08 16:17:18.772 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:18.773 | Historical data download thread signaled to stop.
2025-01-08 16:17:18.773 | HD Request # 52 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:54.945000.
2025-01-08 16:17:18.773 | HD Request # 52 | Received 1 Intraday data record from 2021-03-19 13:29:54.945000 to 2021-03-19 13:29:54.945000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MESH1.CME
2025-01-08 16:17:18.790 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:54.945000
2025-01-08 16:17:18.790 | HD Request # 52 | Completion time: 1s.
2025-01-08 16:17:18.790 | HD Request # 52 | Intraday data download complete for MESH1.CME. Unique request ID: 48
2025-01-08 16:17:18.790 | Removing historical data download ID 48.
2025-01-08 16:17:18.790 | Real-time Intraday chart data file updates started for MESH1.CME
2025-01-08 16:17:18.791 | Opened cached Intraday file: C:\SierraChart-1\Data\MESH1.CME.scid. Thread ID: 12492
2025-01-08 16:17:18.791 | Intraday chart data file opened for MESH1.CME
2025-01-08 16:17:18.791 | HD Request # 52 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:18.791 | Triggering next historical data download in queue.
2025-01-08 16:17:18.791 | Historical data for MESH1.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:18.791 | HD Request # 53 | Downloading Intraday chart data for YMH5.CBOT to the file YMH5.CBOT.scid. Service: cbot
2025-01-08 16:17:18.804 | HD Request # 53 | Download start date-time: 2025-01-08 12:48:33.000000. File last date-time: 2025-01-08 12:48:33.000000
2025-01-08 16:17:18.804 | HD Request # 53 | Using server: ds28.sierracharts.com port 10149
2025-01-08 16:17:18.873 | Socket (3) | Creating socket.
2025-01-08 16:17:18.873 | Socket (3) | New receive buffer size: 0
2025-01-08 16:17:18.873 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 16:17:18.934 | Socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:18.934 | Socket (2) | Closed.
2025-01-08 16:17:19.212 | HD Request # 53 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:19.212 | HD Request # 53 | Sending historical data logon request message.
2025-01-08 16:17:19.415 | HD Request # 53 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:33. Record interval: 1. Symbol: YMH25
2025-01-08 16:17:19.574 | HD Request # 53 | Decompressing data.
2025-01-08 16:17:19.917 | HD Request # 53 | Receiving Intraday data for YMH5.CBOT starting at 2025-01-08 12:48:33.136000
2025-01-08 16:17:20.075 | Socket (3) | CloseSocket call.
2025-01-08 16:17:20.075 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:20.076 | Historical data download thread signaled to stop.
2025-01-08 16:17:20.077 | HD Request # 53 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:33.136000.
2025-01-08 16:17:20.077 | HD Request # 53 | Received 7735 Intraday data records from 2025-01-08 12:48:33.136000 to 2025-01-08 16:17:15.165000 (3.5 hours. Delay: 4.9 seconds) and wrote 7735 records for YMH5.CBOT
2025-01-08 16:17:20.089 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:15.165000
2025-01-08 16:17:20.089 | HD Request # 53 | Completion time: 2s.
2025-01-08 16:17:20.089 | HD Request # 53 | Intraday data download complete for YMH5.CBOT. Unique request ID: 49
2025-01-08 16:17:20.089 | Removing historical data download ID 49.
2025-01-08 16:17:20.089 | Real-time Intraday chart data file updates started for YMH5.CBOT
2025-01-08 16:17:20.089 | Opened cached Intraday file: C:\SierraChart-1\Data\YMH5.CBOT.scid. Thread ID: 12492
2025-01-08 16:17:20.089 | Intraday chart data file opened for YMH5.CBOT
2025-01-08 16:17:20.089 | HD Request # 53 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:20.089 | Triggering next historical data download in queue.
2025-01-08 16:17:20.089 | Historical data for YMH5.CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:20.089 | HD Request # 54 | Downloading Intraday chart data for NQH5.CME to the file NQH5.CME.scid. Service: cme
2025-01-08 16:17:20.103 | HD Request # 54 | Download start date-time: 2025-01-08 12:48:36.000000. File last date-time: 2025-01-08 12:48:36.000000
2025-01-08 16:17:20.103 | HD Request # 54 | Using server: ds32.sierracharts.com port 10150
2025-01-08 16:17:20.235 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 16:17:20.235 | Socket (3) | Closed.
2025-01-08 16:17:20.980 | Socket (2) | Creating socket.
2025-01-08 16:17:20.980 | Socket (2) | New receive buffer size: 0
2025-01-08 16:17:20.980 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-08 16:17:21.303 | HD Request # 54 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:21.303 | HD Request # 54 | Sending historical data logon request message.
2025-01-08 16:17:21.503 | HD Request # 54 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:36. Record interval: 1. Symbol: NQH25
2025-01-08 16:17:21.658 | HD Request # 54 | Decompressing data.
2025-01-08 16:17:22.036 | HD Request # 54 | Receiving Intraday data for NQH5.CME starting at 2025-01-08 12:48:36.707000
2025-01-08 16:17:22.345 | Socket (2) | CloseSocket call.
2025-01-08 16:17:22.345 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:22.348 | Historical data download thread signaled to stop.
2025-01-08 16:17:22.349 | HD Request # 54 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:36.707000.
2025-01-08 16:17:22.349 | HD Request # 54 | Received 11733 Intraday data records from 2025-01-08 12:48:36.707000 to 2025-01-08 16:17:19.622000 (3.5 hours. Delay: 2.7 seconds) and wrote 11733 records for NQH5.CME
2025-01-08 16:17:22.371 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:19.622000
2025-01-08 16:17:22.371 | HD Request # 54 | Completion time: 2s.
2025-01-08 16:17:22.371 | HD Request # 54 | Intraday data download complete for NQH5.CME. Unique request ID: 50
2025-01-08 16:17:22.371 | Removing historical data download ID 50.
2025-01-08 16:17:22.372 | Real-time Intraday chart data file updates started for NQH5.CME
2025-01-08 16:17:22.372 | Opened cached Intraday file: C:\SierraChart-1\Data\NQH5.CME.scid. Thread ID: 12492
2025-01-08 16:17:22.372 | Intraday chart data file opened for NQH5.CME
2025-01-08 16:17:22.372 | HD Request # 54 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:22.372 | Triggering next historical data download in queue.
2025-01-08 16:17:22.372 | Historical data for NQH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:22.372 | HD Request # 55 | Downloading Intraday chart data for MNQH1.CME to the file MNQH1.CME.scid. Service: cme
2025-01-08 16:17:22.390 | HD Request # 55 | Download start date-time: 2021-03-19 13:29:59.000000. File last date-time: 2021-03-19 13:29:59.647000
2025-01-08 16:17:22.390 | HD Request # 55 | Using server: ds26.sierracharts.com port 10149
2025-01-08 16:17:22.390 | Socket (3) | Creating socket.
2025-01-08 16:17:22.390 | Socket (3) | New receive buffer size: 0
2025-01-08 16:17:22.390 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 16:17:22.502 | Socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:22.502 | Socket (2) | Closed.
2025-01-08 16:17:22.718 | HD Request # 55 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:22.718 | HD Request # 55 | Sending historical data logon request message.
2025-01-08 16:17:22.921 | HD Request # 55 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:59. Record interval: 1. Symbol: MNQH21
2025-01-08 16:17:23.079 | HD Request # 55 | Decompressing data.
2025-01-08 16:17:23.237 | HD Request # 55 | Receiving Intraday data for MNQH1.CME starting at 2021-03-19 13:29:59.647000
2025-01-08 16:17:23.239 | Socket (3) | CloseSocket call.
2025-01-08 16:17:23.239 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:23.241 | Historical data download thread signaled to stop.
2025-01-08 16:17:23.241 | HD Request # 55 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:59.647000.
2025-01-08 16:17:23.241 | HD Request # 55 | Received 1 Intraday data record from 2021-03-19 13:29:59.647000 to 2021-03-19 13:29:59.647000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MNQH1.CME
2025-01-08 16:17:23.259 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:59.647000
2025-01-08 16:17:23.259 | HD Request # 55 | Completion time: 1s.
2025-01-08 16:17:23.259 | HD Request # 55 | Intraday data download complete for MNQH1.CME. Unique request ID: 51
2025-01-08 16:17:23.259 | Removing historical data download ID 51.
2025-01-08 16:17:23.259 | Real-time Intraday chart data file updates started for MNQH1.CME
2025-01-08 16:17:23.259 | Opened cached Intraday file: C:\SierraChart-1\Data\MNQH1.CME.scid. Thread ID: 12492
2025-01-08 16:17:23.259 | Intraday chart data file opened for MNQH1.CME
2025-01-08 16:17:23.259 | HD Request # 55 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:23.259 | Triggering next historical data download in queue.
2025-01-08 16:17:23.259 | Historical data for MNQH1.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:23.259 | HD Request # 56 | Downloading Intraday chart data for M2KH1.CME to the file M2KH1.CME.scid. Service: cme
2025-01-08 16:17:23.278 | HD Request # 56 | Download start date-time: 2021-03-19 13:29:43.000000. File last date-time: 2021-03-19 13:29:43.853000
2025-01-08 16:17:23.278 | HD Request # 56 | Using server: ds28.sierracharts.com port 10150
2025-01-08 16:17:23.278 | Socket (2) | Creating socket.
2025-01-08 16:17:23.278 | Socket (2) | New receive buffer size: 0
2025-01-08 16:17:23.278 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-08 16:17:23.399 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 16:17:23.399 | Socket (3) | Closed.
2025-01-08 16:17:23.601 | HD Request # 56 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:23.601 | HD Request # 56 | Sending historical data logon request message.
2025-01-08 16:17:23.807 | HD Request # 56 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:43. Record interval: 1. Symbol: M2KH21
2025-01-08 16:17:23.965 | HD Request # 56 | Decompressing data.
2025-01-08 16:17:24.121 | HD Request # 56 | Receiving Intraday data for M2KH1.CME starting at 2021-03-19 13:29:43.853000
2025-01-08 16:17:24.121 | Socket (2) | CloseSocket call.
2025-01-08 16:17:24.122 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:24.122 | Historical data download thread signaled to stop.
2025-01-08 16:17:24.122 | HD Request # 56 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:43.853000.
2025-01-08 16:17:24.123 | HD Request # 56 | Received 1 Intraday data record from 2021-03-19 13:29:43.853000 to 2021-03-19 13:29:43.853000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for M2KH1.CME
2025-01-08 16:17:24.140 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:43.853000
2025-01-08 16:17:24.140 | HD Request # 56 | Completion time: 1s.
2025-01-08 16:17:24.140 | HD Request # 56 | Intraday data download complete for M2KH1.CME. Unique request ID: 52
2025-01-08 16:17:24.140 | Removing historical data download ID 52.
2025-01-08 16:17:24.140 | Real-time Intraday chart data file updates started for M2KH1.CME
2025-01-08 16:17:24.140 | Opened cached Intraday file: C:\SierraChart-1\Data\M2KH1.CME.scid. Thread ID: 12492
2025-01-08 16:17:24.140 | Intraday chart data file opened for M2KH1.CME
2025-01-08 16:17:24.140 | HD Request # 56 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:24.140 | Triggering next historical data download in queue.
2025-01-08 16:17:24.140 | Historical data for M2KH1.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:24.140 | HD Request # 57 | Downloading Intraday chart data for RTYH5.CME to the file RTYH5.CME.scid. Service: cme
2025-01-08 16:17:24.149 | HD Request # 57 | Download start date-time: 2025-01-08 12:48:36.000000. File last date-time: 2025-01-08 12:48:36.000000
2025-01-08 16:17:24.149 | HD Request # 57 | Using server: ds32.sierracharts.com port 10149
2025-01-08 16:17:24.149 | Socket (3) | Creating socket.
2025-01-08 16:17:24.149 | Socket (3) | New receive buffer size: 0
2025-01-08 16:17:24.149 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 16:17:24.278 | Socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:24.278 | Socket (2) | Closed.
2025-01-08 16:17:24.475 | HD Request # 57 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:24.475 | HD Request # 57 | Sending historical data logon request message.
2025-01-08 16:17:24.675 | HD Request # 57 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:36. Record interval: 1. Symbol: RTYH25
2025-01-08 16:17:24.834 | HD Request # 57 | Decompressing data.
2025-01-08 16:17:25.190 | HD Request # 57 | Receiving Intraday data for RTYH5.CME starting at 2025-01-08 12:48:36.643000
2025-01-08 16:17:25.348 | Socket (3) | CloseSocket call.
2025-01-08 16:17:25.348 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:25.351 | Historical data download thread signaled to stop.
2025-01-08 16:17:25.352 | HD Request # 57 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:36.643000.
2025-01-08 16:17:25.352 | HD Request # 57 | Received 8250 Intraday data records from 2025-01-08 12:48:36.643000 to 2025-01-08 16:17:22.433000 (3.5 hours. Delay: 2.9 seconds) and wrote 8250 records for RTYH5.CME
2025-01-08 16:17:25.373 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:22.433000
2025-01-08 16:17:25.373 | HD Request # 57 | Completion time: 1s.
2025-01-08 16:17:25.373 | HD Request # 57 | Intraday data download complete for RTYH5.CME. Unique request ID: 53
2025-01-08 16:17:25.373 | Removing historical data download ID 53.
2025-01-08 16:17:25.373 | Real-time Intraday chart data file updates started for RTYH5.CME
2025-01-08 16:17:25.374 | Opened cached Intraday file: C:\SierraChart-1\Data\RTYH5.CME.scid. Thread ID: 12492
2025-01-08 16:17:25.374 | Intraday chart data file opened for RTYH5.CME
2025-01-08 16:17:25.374 | HD Request # 57 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:25.374 | Triggering next historical data download in queue.
2025-01-08 16:17:25.374 | Historical data for RTYH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:25.374 | HD Request # 58 | Downloading Intraday chart data for ESH5.CME to the file ESH5.CME.scid. Service: cme
2025-01-08 16:17:25.388 | HD Request # 58 | Download start date-time: 2025-01-08 12:48:34.000000. File last date-time: 2025-01-08 12:48:34.000000
2025-01-08 16:17:25.388 | HD Request # 58 | Using server: ds26.sierracharts.com port 10150
2025-01-08 16:17:25.388 | Socket (2) | Creating socket.
2025-01-08 16:17:25.388 | Socket (2) | New receive buffer size: 0
2025-01-08 16:17:25.388 | Socket (2) | Connecting to IP: 64.152.155.17.
2025-01-08 16:17:25.507 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 16:17:25.507 | Socket (3) | Closed.
2025-01-08 16:17:25.705 | HD Request # 58 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:25.705 | HD Request # 58 | Sending historical data logon request message.
2025-01-08 16:17:25.857 | HD Request # 58 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:34. Record interval: 1. Symbol: ESH25
2025-01-08 16:17:26.008 | HD Request # 58 | Decompressing data.
2025-01-08 16:17:26.574 | HD Request # 58 | Receiving Intraday data for ESH5.CME starting at 2025-01-08 12:48:34.137000
2025-01-08 16:17:26.721 | Socket (2) | CloseSocket call.
2025-01-08 16:17:26.721 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:26.723 | Historical data download thread signaled to stop.
2025-01-08 16:17:26.724 | HD Request # 58 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:34.137000.
2025-01-08 16:17:26.724 | HD Request # 58 | Received 11508 Intraday data records from 2025-01-08 12:48:34.137000 to 2025-01-08 16:17:22.431000 (3.5 hours. Delay: 4.3 seconds) and wrote 11508 records for ESH5.CME
2025-01-08 16:17:26.749 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:22.431000
2025-01-08 16:17:26.749 | HD Request # 58 | Completion time: 1s.
2025-01-08 16:17:26.749 | HD Request # 58 | Intraday data download complete for ESH5.CME. Unique request ID: 54
2025-01-08 16:17:26.749 | Removing historical data download ID 54.
2025-01-08 16:17:26.749 | Real-time Intraday chart data file updates started for ESH5.CME
2025-01-08 16:17:26.749 | Opened cached Intraday file: C:\SierraChart-1\Data\ESH5.CME.scid. Thread ID: 12492
2025-01-08 16:17:26.750 | Intraday chart data file opened for ESH5.CME
2025-01-08 16:17:26.750 | HD Request # 58 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:26.750 | Triggering next historical data download in queue.
2025-01-08 16:17:26.750 | Historical data for ESH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:26.750 | HD Request # 59 | Downloading Intraday chart data for M2KH5.CME to the file M2KH5.CME.scid. Service: cme
2025-01-08 16:17:26.763 | HD Request # 59 | Download start date-time: 2025-01-08 12:48:36.000000. File last date-time: 2025-01-08 12:48:36.000000
2025-01-08 16:17:26.763 | HD Request # 59 | Using server: ds28.sierracharts.com port 10149
2025-01-08 16:17:26.763 | Socket (3) | Creating socket.
2025-01-08 16:17:26.763 | Socket (3) | New receive buffer size: 0
2025-01-08 16:17:26.763 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-08 16:17:26.874 | Socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:26.874 | Socket (2) | Closed.
2025-01-08 16:17:27.104 | HD Request # 59 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:27.104 | HD Request # 59 | Sending historical data logon request message.
2025-01-08 16:17:27.265 | HD Request # 59 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:36. Record interval: 1. Symbol: M2KH25
2025-01-08 16:17:27.427 | HD Request # 59 | Decompressing data.
2025-01-08 16:17:27.774 | HD Request # 59 | Receiving Intraday data for M2KH5.CME starting at 2025-01-08 12:48:36.643000
2025-01-08 16:17:27.977 | Socket (3) | CloseSocket call.
2025-01-08 16:17:27.977 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:27.979 | Historical data download thread signaled to stop.
2025-01-08 16:17:27.980 | HD Request # 59 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:36.643000.
2025-01-08 16:17:27.980 | HD Request # 59 | Received 7809 Intraday data records from 2025-01-08 12:48:36.643000 to 2025-01-08 16:17:24.131000 (3.5 hours. Delay: 3.8 seconds) and wrote 7809 records for M2KH5.CME
2025-01-08 16:17:27.994 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:24.131000
2025-01-08 16:17:27.995 | HD Request # 59 | Completion time: 1s.
2025-01-08 16:17:27.995 | HD Request # 59 | Intraday data download complete for M2KH5.CME. Unique request ID: 55
2025-01-08 16:17:27.995 | Removing historical data download ID 55.
2025-01-08 16:17:27.995 | Real-time Intraday chart data file updates started for M2KH5.CME
2025-01-08 16:17:27.995 | Opened cached Intraday file: C:\SierraChart-1\Data\M2KH5.CME.scid. Thread ID: 12492
2025-01-08 16:17:27.995 | Intraday chart data file opened for M2KH5.CME
2025-01-08 16:17:27.995 | HD Request # 59 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:27.995 | Triggering next historical data download in queue.
2025-01-08 16:17:27.995 | Historical data for M2KH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:27.995 | HD Request # 60 | Downloading Intraday chart data for MYMH5.CBOT to the file MYMH5.CBOT.scid. Service: cbot
2025-01-08 16:17:28.009 | HD Request # 60 | Download start date-time: 2025-01-08 12:48:36.000000. File last date-time: 2025-01-08 12:48:36.000000
2025-01-08 16:17:28.010 | HD Request # 60 | Using server: ds32.sierracharts.com port 10150
2025-01-08 16:17:28.010 | Socket (2) | Creating socket.
2025-01-08 16:17:28.010 | Socket (2) | New receive buffer size: 0
2025-01-08 16:17:28.010 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-08 16:17:28.138 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 16:17:28.138 | Socket (3) | Closed.
2025-01-08 16:17:28.342 | HD Request # 60 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:28.342 | HD Request # 60 | Sending historical data logon request message.
2025-01-08 16:17:28.502 | HD Request # 60 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:36. Record interval: 1. Symbol: MYMH25
2025-01-08 16:17:28.663 | HD Request # 60 | Decompressing data.
2025-01-08 16:17:29.022 | HD Request # 60 | Receiving Intraday data for MYMH5.CBOT starting at 2025-01-08 12:48:36.710000
2025-01-08 16:17:29.182 | Socket (2) | CloseSocket call.
2025-01-08 16:17:29.182 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:29.184 | Historical data download thread signaled to stop.
2025-01-08 16:17:29.185 | HD Request # 60 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:36.710000.
2025-01-08 16:17:29.185 | HD Request # 60 | Received 8425 Intraday data records from 2025-01-08 12:48:36.710000 to 2025-01-08 16:17:24.213000 (3.5 hours. Delay: 5.0 seconds) and wrote 8425 records for MYMH5.CBOT
2025-01-08 16:17:29.210 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:24.213000
2025-01-08 16:17:29.210 | HD Request # 60 | Completion time: 2s.
2025-01-08 16:17:29.210 | HD Request # 60 | Intraday data download complete for MYMH5.CBOT. Unique request ID: 56
2025-01-08 16:17:29.210 | Removing historical data download ID 56.
2025-01-08 16:17:29.210 | Real-time Intraday chart data file updates started for MYMH5.CBOT
2025-01-08 16:17:29.210 | Opened cached Intraday file: C:\SierraChart-1\Data\MYMH5.CBOT.scid. Thread ID: 12492
2025-01-08 16:17:29.210 | Intraday chart data file opened for MYMH5.CBOT
2025-01-08 16:17:29.210 | HD Request # 60 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:29.210 | Triggering next historical data download in queue.
2025-01-08 16:17:29.210 | Historical data for MYMH5.CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:29.210 | HD Request # 61 | Downloading Intraday chart data for MYMH1.CBOT to the file MYMH1.CBOT.scid. Service: cbot
2025-01-08 16:17:29.225 | HD Request # 61 | Download start date-time: 2021-03-19 13:29:43.000000. File last date-time: 2021-03-19 13:29:43.603000
2025-01-08 16:17:29.225 | HD Request # 61 | Using server: ds26.sierracharts.com port 10149
2025-01-08 16:17:29.225 | Socket (3) | Creating socket.
2025-01-08 16:17:29.225 | Socket (3) | New receive buffer size: 0
2025-01-08 16:17:29.225 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-08 16:17:29.344 | Socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:29.344 | Socket (2) | Closed.
2025-01-08 16:17:29.553 | HD Request # 61 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:29.553 | HD Request # 61 | Sending historical data logon request message.
2025-01-08 16:17:29.711 | HD Request # 61 | Requesting Intraday data. Start date-time: 2021-03-19 13:29:43. Record interval: 1. Symbol: MYMH21
2025-01-08 16:17:29.868 | HD Request # 61 | Decompressing data.
2025-01-08 16:17:30.026 | HD Request # 61 | Receiving Intraday data for MYMH1.CBOT starting at 2021-03-19 13:29:43.603000
2025-01-08 16:17:30.027 | Socket (3) | CloseSocket call.
2025-01-08 16:17:30.027 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:30.029 | Historical data download thread signaled to stop.
2025-01-08 16:17:30.030 | HD Request # 61 | Timestamp of first Intraday data file record written: 2021-03-19 13:29:43.603000.
2025-01-08 16:17:30.030 | HD Request # 61 | Received 1 Intraday data record from 2021-03-19 13:29:43.603000 to 2021-03-19 13:29:43.603000 (0.0 seconds. Delay: 3.8 years) and wrote 1 record for MYMH1.CBOT
2025-01-08 16:17:30.052 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2021-03-19 13:29:43.603000
2025-01-08 16:17:30.052 | HD Request # 61 | Completion time: 1s.
2025-01-08 16:17:30.052 | HD Request # 61 | Intraday data download complete for MYMH1.CBOT. Unique request ID: 57
2025-01-08 16:17:30.052 | Removing historical data download ID 57.
2025-01-08 16:17:30.052 | Real-time Intraday chart data file updates started for MYMH1.CBOT
2025-01-08 16:17:30.053 | Opened cached Intraday file: C:\SierraChart-1\Data\MYMH1.CBOT.scid. Thread ID: 12492
2025-01-08 16:17:30.053 | Intraday chart data file opened for MYMH1.CBOT
2025-01-08 16:17:30.053 | HD Request # 61 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:30.053 | Triggering next historical data download in queue.
2025-01-08 16:17:30.053 | Historical data for MYMH1.CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:30.053 | HD Request # 62 | Downloading Intraday chart data for MESH5.CME to the file MESH5.CME.scid. Service: cme
2025-01-08 16:17:30.066 | HD Request # 62 | Download start date-time: 2025-01-08 12:48:37.000000. File last date-time: 2025-01-08 12:48:37.000000
2025-01-08 16:17:30.066 | HD Request # 62 | Using server: ds28.sierracharts.com port 10150
2025-01-08 16:17:30.066 | Socket (2) | Creating socket.
2025-01-08 16:17:30.066 | Socket (2) | New receive buffer size: 0
2025-01-08 16:17:30.066 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-08 16:17:30.187 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 16:17:30.187 | Socket (3) | Closed.
2025-01-08 16:17:30.395 | HD Request # 62 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:30.395 | HD Request # 62 | Sending historical data logon request message.
2025-01-08 16:17:30.551 | HD Request # 62 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:37. Record interval: 1. Symbol: MESH25
2025-01-08 16:17:30.711 | HD Request # 62 | Decompressing data.
2025-01-08 16:17:31.092 | HD Request # 62 | Receiving Intraday data for MESH5.CME starting at 2025-01-08 12:48:37.030000
2025-01-08 16:17:31.399 | Socket (2) | CloseSocket call.
2025-01-08 16:17:31.399 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:31.400 | Historical data download thread signaled to stop.
2025-01-08 16:17:31.401 | HD Request # 62 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:37.030000.
2025-01-08 16:17:31.401 | HD Request # 62 | Received 11938 Intraday data records from 2025-01-08 12:48:37.030000 to 2025-01-08 16:17:29.151000 (3.5 hours. Delay: 2.3 seconds) and wrote 11938 records for MESH5.CME
2025-01-08 16:17:31.411 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:29.151000
2025-01-08 16:17:31.412 | HD Request # 62 | Completion time: 1s.
2025-01-08 16:17:31.412 | HD Request # 62 | Intraday data download complete for MESH5.CME. Unique request ID: 58
2025-01-08 16:17:31.412 | Removing historical data download ID 58.
2025-01-08 16:17:31.412 | Real-time Intraday chart data file updates started for MESH5.CME
2025-01-08 16:17:31.412 | Opened cached Intraday file: C:\SierraChart-1\Data\MESH5.CME.scid. Thread ID: 12492
2025-01-08 16:17:31.412 | Intraday chart data file opened for MESH5.CME
2025-01-08 16:17:31.412 | HD Request # 62 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:31.412 | Triggering next historical data download in queue.
2025-01-08 16:17:31.412 | Historical data for MESH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:31.412 | HD Request # 63 | Downloading Intraday chart data for MNQH5.CME to the file MNQH5.CME.scid. Service: cme
2025-01-08 16:17:31.424 | HD Request # 63 | Download start date-time: 2025-01-08 12:48:37.000000. File last date-time: 2025-01-08 12:48:37.000000
2025-01-08 16:17:31.425 | HD Request # 63 | Using server: ds32.sierracharts.com port 10149
2025-01-08 16:17:31.425 | Socket (3) | Creating socket.
2025-01-08 16:17:31.425 | Socket (3) | New receive buffer size: 0
2025-01-08 16:17:31.425 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-08 16:17:31.556 | Socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:31.556 | Socket (2) | Closed.
2025-01-08 16:17:31.749 | HD Request # 63 | Setting DTC encoding to Binary VLS
2025-01-08 16:17:31.749 | HD Request # 63 | Sending historical data logon request message.
2025-01-08 16:17:31.905 | HD Request # 63 | Requesting Intraday data. Start date-time: 2025-01-08 12:48:37. Record interval: 1. Symbol: MNQH25
2025-01-08 16:17:32.061 | HD Request # 63 | Decompressing data.
2025-01-08 16:17:32.666 | HD Request # 63 | Receiving Intraday data for MNQH5.CME starting at 2025-01-08 12:48:37.541000
2025-01-08 16:17:32.975 | Socket (3) | CloseSocket call.
2025-01-08 16:17:32.975 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:32.976 | Historical data download thread signaled to stop.
2025-01-08 16:17:32.977 | HD Request # 63 | Timestamp of first Intraday data file record written: 2025-01-08 12:48:37.541000.
2025-01-08 16:17:32.977 | HD Request # 63 | Received 12464 Intraday data records from 2025-01-08 12:48:37.541000 to 2025-01-08 16:17:31.011000 (3.5 hours. Delay: 2.0 seconds) and wrote 12464 records for MNQH5.CME
2025-01-08 16:17:33.003 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2025-01-08 16:17:31.011000
2025-01-08 16:17:33.003 | HD Request # 63 | Completion time: 2s.
2025-01-08 16:17:33.003 | HD Request # 63 | Intraday data download complete for MNQH5.CME. Unique request ID: 59
2025-01-08 16:17:33.003 | Removing historical data download ID 59.
2025-01-08 16:17:33.003 | Real-time Intraday chart data file updates started for MNQH5.CME
2025-01-08 16:17:33.004 | Opened cached Intraday file: C:\SierraChart-1\Data\MNQH5.CME.scid. Thread ID: 12492
2025-01-08 16:17:33.004 | Intraday chart data file opened for MNQH5.CME
2025-01-08 16:17:33.004 | HD Request # 63 | Enabling Intraday chart updating for symbol.
2025-01-08 16:17:33.004 | No download requests in the queue to start downloads for.
2025-01-08 16:17:33.004 | Historical data for MNQH5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-01-08 16:17:33.132 | Socket (3) | Socket gracefully closed by remote side.
2025-01-08 16:17:33.133 | Socket (3) | Closed.
2025-01-08 16:17:50.630 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443
2025-01-08 16:17:50.631 | DTC Client socket (2) | Creating socket.
2025-01-08 16:17:50.631 | DTC Client socket (2) | New receive buffer size: 0
2025-01-08 16:17:50.631 | DTC Client socket (2) | Connecting to IP: 64.152.155.17.
2025-01-08 16:17:50.791 | Denali Data Feed | Network connection to server complete.
2025-01-08 16:17:50.791 | Denali Data Feed | Starting socket receive thread.
2025-01-08 16:17:50.791 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-01-08 16:17:50.968 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-01-08 16:17:50.968 | Denali Data Feed | Sending logon request message.
2025-01-08 16:17:51.493 | Denali Data Feed | Received logon response.
2025-01-08 16:17:51.493 | Denali Data Feed | Server Name: RealTimeServer.
2025-01-08 16:17:51.493 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-01-08 16:17:51.493 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-01-08 16:17:51.493 | Denali Data Feed | Failed connections: 2
2025-01-08 16:17:51.493 | Denali Data Feed | Waiting for socket receive thread to end
2025-01-08 16:17:51.493 | DTC Client socket (2) | CloseSocket call.
2025-01-08 16:17:51.493 | Denali Data Feed | Disconnected from the server.
2025-01-08 16:17:51.493 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-01-08 16:17:51.493 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-01-08 16:17:51.653 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-01-08 16:17:51.653 | DTC Client socket (2) | Closed.
[2025-01-08 16:21:01]
User651547 - Posts: 68
if i have open order or sl and tp and i close terminal or disconect the orders will comleted even my pc not online ?
[2025-01-08 19:13:44]
John - SC Support - Posts: 39395
You are getting a "Permission Denied" error from Rithmic. Refer to the following:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
With regards to the attached orders it depends on what service you are using. Refer to the following:
Attached Orders: Introduction
[2025-01-16 07:03:32]
HI. I trade for example 3 contracts . each contract have his tp and sl , now they are mixed order 1 can be closed with Tp 3 or sl 2. how can i set that the eech order will colsed just with him tp or sl . so order1 can be closed just with tp1 even the price cross tp 2 or tp3
[2025-01-16 07:43:43]
Sierra_Chart Engineering - Posts: 19305
Look at the different example configurations here:
Attached Orders: Attached Orders Examples
Sounds like you do not want to use a common stop. Instead use multiple independent Stop Attached Orders each in their own separate OCO Group.
Date Time Of Last Edit: 2025-01-16 07:44:53
