Date/Time: Tue, 22 Apr 2025 14:38:20 +0000
daily POC on volume profile not in sync
View Count: 234
[2025-01-03 18:31:37] |
Trade with ICE - Posts: 25 |
Why is my daily profile POC not syncing? Sometimes it syncs late, or it doesn't sync at all. This often confuses my bias, which is why I’m seeking help. Thank you!
![]() Attachment Deleted. |
[2025-01-03 19:54:58] |
Sierra_Chart Engineering - Posts: 19305 |
We do not understand the question. Also the chart image is too complex and hardly visible. We only accept chart images following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) If you want to show two different charts, then provide two separate chart images following the above instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-03 20:17:29
[2025-01-08 23:19:18] |
i have daily volume profile on my execution chart (flex renko) and on my reference chart 5 min. both have the same settings but the POC is somewhat not in sync. attached are the two photos. one in flex renko and one on 5min. both have volume profile but POC are different. |
[2025-01-09 15:33:42] |
Please get us a chartbook with those charts in it so we can take a look at it. Follow these instructions to get us the charts, just ignore the fact that it states for 1 chart, we need 2: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-10 20:38:51] |
This is definitely going to be the case because one is based on fixed timeframe bars and another is variable timeframe bars (Renko): i have daily volume profile on my execution chart (flex renko) and on my reference chart 5 min.
both have the same settings but the POC is somewhat not in sync. The point of control will differ between these charts. Refer to: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
