Date/Time: Fri, 14 Mar 2025 12:34:46 +0000
Server timeout
View Count: 178
[2024-12-27 10:37:04] |
User213910 - Posts: 17 |
Sierracharts is loading charts very slow since a week or so. In the LOG there are several Windows error codes 10060. If i try to ping ds24.sierracharts.com and ds14.sierracharts.com i get timeout. ds13.sierracharts.com and ds32.sierracharts.com are working. |
[2024-12-27 11:10:03] |
User144206 - Posts: 1 |
I also have the same problem.
[2024-12-27 15:10:28] |
John - SC Support - Posts: 38653 |
The ping does not tell you anything. The fact that ds24 and ds14 do not respond is only because we have set them to not respond to pings. The error 10060 means that you are having a connectivity issue. Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-27 15:26:38] |
Sierra_Chart Engineering - Posts: 18778 |
We think we know what the problem is. We will resolve now. There should be permanent resolution to this problem this evening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-27 15:29:55] |
This will be resolved, in about 10 minutes. We have implemented a workaround for now. We apologize for this. It has to do with the new infrastructure for our EUREX data and there is a problem with one of the Internet connections that has still yet to be resolved. It should be resolved tonight.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-27 15:31:46
[2024-12-27 15:33:34] |
Thank you for your quick help and hard work!
