Date/Time: Wed, 12 Mar 2025 05:00:33 +0000
Order Allocation and Changing Trade Window Configuration Configuration
View Count: 170
[2024-12-25 00:16:40]
User276813 - Posts: 68
Is there a way to leave Order Allocation to Trade Accounts ENABLED when changing between Trade Window Configurations?
If I change from a 12 pt stop to a 7 pt stop configuration, it disables the Order Allocation to Trade Accounts setting. I would like to leave that ON when shifting between Trade Window Configurations (i.e. take profit / stops).
[2024-12-26 15:52:59]
John - SC Support - Posts: 38598
Refer to the following setting:
Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Save Trade Window Configuration
[2024-12-26 15:56:03]
Thanks, I understand. I'd have to save the order allocation into the trade window configuration settings.
[2024-12-26 16:37:56]
Actually, we were trying to point out the opposite. If the order allocation status is changing with the Trade Window Configuration and that is not what you want, then set the setting to "No".
If the setting is already "No" and the order allocation status is changing with changes in the trade configuration, then this should not be occurring.
[2024-12-26 16:46:38]
I have it set to "No" and it changes.
I can make a quick video as well if that'd be helpful.
I thought the "yes" setting would "CODE" the order allocations into the trade window configuration itself.
imageScreenshot 2024-12-26 114457.png / V - Attached On 2024-12-26 16:45:34 UTC - Size: 9.47 KB - 29 views
[2024-12-26 18:01:01]
You can set it to "Yes" and then resave the configurations with the Order Allocation set as you want.
We do see that if you have saved a configuration with the option to save the "Order Allocation to Trade Accounts" settings included, then those settings will always apply, regardless of whether you have the option to save the "Order Allocation to Trade Accounts" with Trade Configurations or not. In other words, once the Order Allocation to Trade Accounts options are saved to a configuration, that configuration will always apply those settings.
This must be why you are seeing what you are with some Trade Configurations modifying the Order Allocation to Trade Accounts settings. You would either need to delete and resave those configurations without the Order Allocation to Trade Account options saved into them, or you can redo those configurations with the Order Allocation to Trade Accounts options enabled.
But you will need to do one or the other in order to get everything to a consistent state.
