Date/Time: Tue, 04 Nov 2025 14:57:32 +0000
Reason for: "UpdateChart CurrentQuoteIsForNewSession" Message
View Count: 3280
|   [2013-03-23 22:49:07]     |
                When using Historical Daily charts, you may see a message like this in the Sierra Chart Message Log: UpdateChart CurrentQuoteIsForNewSession: TempSD.High=531, SD.High=561, TempSD.Low=-551, SD.Low=-551, Symbol=$TICK | 2013-03-21 10:41:33 This has been frequently occurring with Historical Daily market statistics charts. There is a technical reason why this occurs and it has to do with the daily high and low from the source data feed not updating immediately. We have worked around this issue and have implemented a solution. So these messages should really only be occurring at the start of a new trading session. You should notice a difference on Monday. One thing to note is that when you see a message like this, it does cause a full reload and recalculation of the Historical Daily chart. This should only occur infrequently. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-23 22:50:16
|   [2013-04-08 09:05:36]     |
                In order to fully resolve this problem, it is necessary to update to the current version of Sierra Chart which is 961.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
