Date/Time: Tue, 04 Nov 2025 15:12:40 +0000
Chart stats in activity log is sorted but not how i need
View Count: 305
[2024-12-20 16:40:01]
Spidur - Posts: 12
how do i sort the chart stats tab of the activity log. it seems to be sorted on some field but i can't/don't figure out which field.
I would expect, given it's design, that the sort would be in the display settings [so circa, 1990s, but hey i liked that too]. Also, it would be more likely that a click on the heading field would sort ...ah but no dice.
so how do i sort lets say on symbol??
[2024-12-21 22:50:11]
Sierra_Chart Engineering - Posts: 21301
This sorting cannot be controlled in that list. We may implement sorting later on but it is not supported now.
[2024-12-22 00:27:51]
Spidur - Posts: 12
okay -- that make sense; how about the current "sorting".. it changes like crazy what is it currently ordered by?
[2024-12-22 04:31:50]
The current sorting will be stable and unchanging unless you open or close a Chartbook. The ordering is based upon these fields of information:
m_Symbol;
m_TradeAccount;
m_OrderFillsStartDateTime;
m_IsReplaying
Starting or stopping a replay will also change the order.
Date Time Of Last Edit: 2024-12-22 04:32:12
[2024-12-22 14:13:12]
Spidur - Posts: 12
this is not what I have seen; it moves around so much I can't read a full line.
I presume your claim is the the above fields are sort(m_symbol)-> sub-sorted fields(remaining fields): if this is the case, I can definitely say this is not the case. the ordering is not by symbol field and it ordering is unintelligible by the naked eye. as far as making progress, if you get it ordered by symbol then this would be fine for me even with additional sub-sorting which is currently used, apparently, in the wild.
Date Time Of Last Edit: 2024-12-22 14:18:15
[2024-12-23 14:11:52]
This does not make sense.
At the current time go to the Chart Stats tab and select Edit >> Copy All and paste it into a text editor. And then when it changes again do a Copy All and paste that into the text editor.
And then provide that text here so we can look at it.
