Date/Time: Tue, 22 Apr 2025 22:38:01 +0000
[Programming Help] - Build Custom Study
View Count: 497
[2024-12-13 20:37:58]
User377189 - Posts: 215
See attached video, When i click build under analysis > Build Custom Studies DLL
Private File
[2024-12-13 20:44:47]
John - SC Support - Posts: 39428
You need to open up the window so you can see what is being reported in the "Build Output" area. Grab a corner of the window and when the pointer changes to the double arrow, click and stretch open the window. Then you can respond to what is being reported.
[2024-12-13 21:31:22]
i do not see any window but in message log i see the following:
2024-12-13 16:01:07.904 | Trade activity files set size: 4
2024-12-13 16:01:07.969 | Created the DTC Protocol server.
2024-12-13 16:01:07.971 | DTC Protocol Server listening on port 11111.
2024-12-13 16:01:07.972 | Reading Internal Order ID file.
2024-12-13 16:01:07.984 | Reading Trade Orders file.
2024-12-13 16:01:07.985 | Reading Trade Positions file.
2024-12-13 16:01:07.985 | Reading Trade Account Data files.
2024-12-13 16:01:07.997 | UDPListener (2272). Port 22904 | Listening on UDP port 22904.
2024-12-13 16:01:07.997 | Software version: 2700 64-bit
2024-12-13 16:01:07.998 | OpenGL enabled (ATI Technologies Inc./Radeon RX Vega M GH Graphics)
2024-12-13 16:01:07.998 | Primary Thread ID: 21008
2024-12-13 16:01:07.998 | Usage end date: 2025-01-06
2024-12-13 16:01:07.998 | Enabled for: Advanced Features 2.
2024-12-13 16:01:07.998 | Enabled for: Sierra Chart Historical Data Service.
2024-12-13 16:01:07.998 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-12-13 16:01:07.998 | Enabled for: Delayed Denali Exchange Data Feed.
2024-12-13 16:01:07.998 | Enabled for exchange2: CME (Trading Account Required)
2024-12-13 16:01:07.998 | Enabled for exchange2: CBOT (Trading Account Required)
2024-12-13 16:01:07.998 | Enabled for exchange2: COMEX (Trading Account Required)
2024-12-13 16:01:07.998 | Enabled for exchange2: NYMEX (Trading Account Required)
2024-12-13 16:01:07.998 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-12-13 16:01:07.998 | Current selected Data/Trading service: DTC - Sub Instance
2024-12-13 16:01:07.998 | Custom symbol settings values: disabled
2024-12-13 16:01:07.998 | Chart Update Interval: 10
2024-12-13 16:01:07.998 | Intraday Data Storage Time Unit: 0
2024-12-13 16:01:07.998 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-12-13 16:01:07.998 | 2024-12-13 21:01:07 Local computer time in UTC
2024-12-13 16:01:07.998 | 2024-12-13 16:01:07 Local computer time in SC Time Zone
2024-12-13 16:01:07.998 | 2024-12-13 21:01:07 Server time in UTC
2024-12-13 16:01:07.998 | Local computer UTC time and Server UTC time difference: 0 seconds.
2024-12-13 16:01:07.998 | Program path: D:\SierraChart\SierraChartInstance_2\
2024-12-13 16:01:07.998 | Data Files path: D:\SierraChart\SierraChartInstance_2\Data\
2024-12-13 16:01:07.998 | OS Version Number: 10.0
2024-12-13 16:01:07.998 | Locale Setting: C
2024-12-13 16:01:07.998 | DLLs: PMStrat_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll
2024-12-13 16:01:07.998 | Allowed protected custom studies:
2024-12-13 16:01:07.998 | Crash reporter started: true
2024-12-13 16:01:07.998 | Created the DTC Protocol historical data server.
2024-12-13 16:01:08.000 | HD Server Manager | Listening on port 11110.
2024-12-13 16:01:08.055 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2024-12-13 16:01:08.089 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2024-12-13 16:01:08.089 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2024-12-13 16:01:08.126 | Received 5 login tokens.
2024-12-13 16:01:10.496 | Requested user files to download.
2024-12-13 16:01:12.494 |
2024-12-13 16:01:12.498 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:12.498 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:12.498 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:12.498 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:14.523 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:14.524 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:14.524 | DTC Client socket (1) | Closed.
2024-12-13 16:01:14.526 | DTC - Sub Instance | Failed connections: 1
2024-12-13 16:01:14.526 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:14.526 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:14.539 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:14.539 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:14.540 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:16.540 |
2024-12-13 16:01:16.542 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:16.543 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:16.543 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:16.543 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:18.575 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:18.576 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:18.576 | DTC Client socket (1) | Closed.
2024-12-13 16:01:18.578 | DTC - Sub Instance | Failed connections: 2
2024-12-13 16:01:18.578 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:18.578 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:18.582 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:18.583 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:18.584 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:20.589 |
2024-12-13 16:01:20.592 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:20.592 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:20.592 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:20.592 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:22.621 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:22.724 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:22.724 | DTC Client socket (1) | Closed.
2024-12-13 16:01:22.725 | DTC - Sub Instance | Failed connections: 3
2024-12-13 16:01:22.725 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:22.725 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:22.749 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:22.749 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:22.750 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:24.747 |
2024-12-13 16:01:24.752 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:24.752 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:24.752 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:24.752 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:26.783 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:26.785 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:26.785 | DTC Client socket (1) | Closed.
2024-12-13 16:01:26.786 | DTC - Sub Instance | Failed connections: 4
2024-12-13 16:01:26.786 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:26.786 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:26.801 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:26.801 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:26.801 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:28.801 |
2024-12-13 16:01:28.803 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:28.803 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:28.804 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:28.804 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:30.846 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:30.849 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:30.849 | DTC Client socket (1) | Closed.
2024-12-13 16:01:30.850 | DTC - Sub Instance | Failed connections: 5
2024-12-13 16:01:30.850 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:30.850 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:30.902 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:30.902 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:30.902 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:32.900 |
2024-12-13 16:01:32.900 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:32.901 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:32.901 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:32.901 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:34.929 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:34.931 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:34.931 | DTC Client socket (1) | Closed.
2024-12-13 16:01:34.934 | DTC - Sub Instance | Failed connections: 6
2024-12-13 16:01:34.934 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:34.934 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:34.945 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:34.945 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:34.946 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:36.949 |
2024-12-13 16:01:36.951 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:36.951 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:36.951 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:36.951 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:38.971 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:38.973 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:38.973 | DTC Client socket (1) | Closed.
2024-12-13 16:01:38.974 | DTC - Sub Instance | Failed connections: 7
2024-12-13 16:01:38.974 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:38.974 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:38.988 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:38.988 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:38.988 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:40.989 |
2024-12-13 16:01:40.990 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:40.991 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:40.991 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:40.991 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:43.010 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:43.010 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:43.010 | DTC Client socket (1) | Closed.
2024-12-13 16:01:43.011 | DTC - Sub Instance | Failed connections: 8
2024-12-13 16:01:43.011 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:43.011 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:43.016 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:43.017 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:43.017 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:45.020 |
2024-12-13 16:01:45.023 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:45.023 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:45.023 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:45.023 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:47.062 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:47.062 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:47.063 | DTC Client socket (1) | Closed.
2024-12-13 16:01:47.063 | DTC - Sub Instance | Failed connections: 9
2024-12-13 16:01:47.063 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:47.063 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:47.065 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:47.065 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:47.065 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:49.076 |
2024-12-13 16:01:49.079 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:49.079 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:49.079 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:49.079 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:51.102 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:51.104 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:51.104 | DTC Client socket (1) | Closed.
2024-12-13 16:01:51.105 | DTC - Sub Instance | Failed connections: 10
2024-12-13 16:01:51.105 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:51.105 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:51.121 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:51.121 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:51.121 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:53.122 |
2024-12-13 16:01:53.124 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:53.125 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:53.125 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:53.125 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:55.140 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:55.141 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:55.141 | DTC Client socket (1) | Closed.
2024-12-13 16:01:55.143 | DTC - Sub Instance | Failed connections: 11
2024-12-13 16:01:55.143 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:55.143 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:55.175 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:55.175 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:55.176 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:57.183 |
2024-12-13 16:01:57.186 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:01:57.186 | DTC Client socket (1) | Creating socket.
2024-12-13 16:01:57.187 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:01:57.187 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:01:59.207 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:01:59.208 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:01:59.209 | DTC Client socket (1) | Closed.
2024-12-13 16:01:59.210 | DTC - Sub Instance | Failed connections: 12
2024-12-13 16:01:59.210 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:01:59.210 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:01:59.225 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:01:59.225 | DTC - Sub Instance | Disconnected.
2024-12-13 16:01:59.225 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:01.225 |
2024-12-13 16:02:01.228 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:01.228 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:01.228 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:01.228 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:03.252 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:03.253 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:03.253 | DTC Client socket (1) | Closed.
2024-12-13 16:02:03.255 | DTC - Sub Instance | Failed connections: 13
2024-12-13 16:02:03.255 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:03.255 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:03.269 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:03.269 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:03.270 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:05.269 |
2024-12-13 16:02:05.273 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:05.273 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:05.273 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:05.273 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:07.301 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:07.303 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:07.303 | DTC Client socket (1) | Closed.
2024-12-13 16:02:07.304 | DTC - Sub Instance | Failed connections: 14
2024-12-13 16:02:07.304 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:07.304 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:07.319 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:07.319 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:07.319 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:09.323 |
2024-12-13 16:02:09.325 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:09.326 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:09.326 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:09.326 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:11.336 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:11.337 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:11.337 | DTC Client socket (1) | Closed.
2024-12-13 16:02:11.339 | DTC - Sub Instance | Failed connections: 15
2024-12-13 16:02:11.339 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:11.339 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:11.353 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:11.354 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:11.354 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:13.353 |
2024-12-13 16:02:13.356 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:13.356 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:13.356 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:13.356 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:15.379 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:15.382 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:15.382 | DTC Client socket (1) | Closed.
2024-12-13 16:02:15.382 | DTC - Sub Instance | Failed connections: 16
2024-12-13 16:02:15.382 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:15.382 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:15.419 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:15.419 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:15.419 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:17.408 |
2024-12-13 16:02:17.410 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:17.410 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:17.410 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:17.410 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:19.428 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:19.430 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:19.430 | DTC Client socket (1) | Closed.
2024-12-13 16:02:19.431 | DTC - Sub Instance | Failed connections: 17
2024-12-13 16:02:19.431 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:19.431 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:19.446 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:19.446 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:19.446 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:21.439 |
2024-12-13 16:02:21.440 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:21.440 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:21.441 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:21.441 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:23.467 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:23.469 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:23.469 | DTC Client socket (1) | Closed.
2024-12-13 16:02:23.470 | DTC - Sub Instance | Failed connections: 18
2024-12-13 16:02:23.470 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:23.470 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:23.501 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:23.501 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:23.502 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:25.507 |
2024-12-13 16:02:25.510 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:25.510 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:25.511 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:25.511 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:27.523 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:27.524 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:27.524 | DTC Client socket (1) | Closed.
2024-12-13 16:02:27.525 | DTC - Sub Instance | Failed connections: 19
2024-12-13 16:02:27.525 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:27.525 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:27.541 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:27.541 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:27.541 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:29.536 |
2024-12-13 16:02:29.539 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:29.539 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:29.539 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:29.539 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:31.564 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:31.565 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:31.565 | DTC Client socket (1) | Closed.
2024-12-13 16:02:31.566 | DTC - Sub Instance | Failed connections: 20
2024-12-13 16:02:31.566 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:31.566 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:31.580 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:31.581 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:31.581 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:33.581 |
2024-12-13 16:02:33.584 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:33.584 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:33.584 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:33.584 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:35.611 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:35.613 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:35.613 | DTC Client socket (1) | Closed.
2024-12-13 16:02:35.614 | DTC - Sub Instance | Failed connections: 21
2024-12-13 16:02:35.614 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:35.614 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:35.629 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:35.629 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:35.630 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:37.641 |
2024-12-13 16:02:37.644 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:37.644 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:37.644 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:37.644 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:39.665 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:39.667 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:39.667 | DTC Client socket (1) | Closed.
2024-12-13 16:02:39.667 | DTC - Sub Instance | Failed connections: 22
2024-12-13 16:02:39.667 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:39.667 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:39.683 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:39.684 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:39.684 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:41.678 |
2024-12-13 16:02:41.680 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:41.680 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:41.680 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:41.681 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:43.707 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:43.708 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:43.708 | DTC Client socket (1) | Closed.
2024-12-13 16:02:43.709 | DTC - Sub Instance | Failed connections: 23
2024-12-13 16:02:43.709 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:43.709 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:43.724 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:43.725 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:43.725 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:45.723 |
2024-12-13 16:02:45.726 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:45.726 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:45.727 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:45.727 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:47.756 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:47.758 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:47.758 | DTC Client socket (1) | Closed.
2024-12-13 16:02:47.759 | DTC - Sub Instance | Failed connections: 24
2024-12-13 16:02:47.759 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:47.759 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:47.774 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:47.774 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:47.775 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:49.777 |
2024-12-13 16:02:49.780 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:49.780 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:49.780 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:49.780 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:51.804 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:51.806 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:51.806 | DTC Client socket (1) | Closed.
2024-12-13 16:02:51.807 | DTC - Sub Instance | Failed connections: 25
2024-12-13 16:02:51.807 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:51.807 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:51.822 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:51.822 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:51.822 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:53.821 |
2024-12-13 16:02:53.823 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:53.823 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:53.823 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:53.823 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:55.860 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:55.860 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:55.860 | DTC - Sub Instance | Failed connections: 26
2024-12-13 16:02:55.860 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:55.860 | DTC Client socket (1) | Closed.
2024-12-13 16:02:55.860 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:55.877 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:55.877 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:55.878 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:57.888 |
2024-12-13 16:02:57.890 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:02:57.890 | DTC Client socket (1) | Creating socket.
2024-12-13 16:02:57.890 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:02:57.890 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:02:59.917 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:02:59.918 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:02:59.918 | DTC Client socket (1) | Closed.
2024-12-13 16:02:59.918 | DTC - Sub Instance | Failed connections: 27
2024-12-13 16:02:59.918 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:02:59.918 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:02:59.934 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:02:59.934 | DTC - Sub Instance | Disconnected.
2024-12-13 16:02:59.935 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:01.934 |
2024-12-13 16:03:01.935 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:01.935 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:01.936 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:01.936 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:03.951 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:03.953 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:03.953 | DTC Client socket (1) | Closed.
2024-12-13 16:03:03.955 | DTC - Sub Instance | Failed connections: 28
2024-12-13 16:03:03.955 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:03.955 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:03.982 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:03.982 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:03.983 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:05.972 |
2024-12-13 16:03:05.972 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:05.972 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:05.972 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:05.972 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:08.002 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:08.004 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:08.004 | DTC Client socket (1) | Closed.
2024-12-13 16:03:08.006 | DTC - Sub Instance | Failed connections: 29
2024-12-13 16:03:08.006 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:08.006 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:08.021 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:08.021 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:08.022 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:10.021 |
2024-12-13 16:03:10.023 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:10.023 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:10.023 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:10.023 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:12.038 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:12.041 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:12.041 | DTC Client socket (1) | Closed.
2024-12-13 16:03:12.043 | DTC - Sub Instance | Failed connections: 30
2024-12-13 16:03:12.043 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:12.043 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:12.052 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:12.052 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:12.052 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:14.053 |
2024-12-13 16:03:14.057 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:14.057 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:14.057 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:14.058 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:16.080 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:16.081 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:16.081 | DTC Client socket (1) | Closed.
2024-12-13 16:03:16.081 | DTC - Sub Instance | Failed connections: 31
2024-12-13 16:03:16.081 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:16.081 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:16.096 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:16.096 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:16.096 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:18.096 |
2024-12-13 16:03:18.097 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:18.097 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:18.097 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:18.097 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:20.120 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:20.121 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:20.121 | DTC Client socket (1) | Closed.
2024-12-13 16:03:20.122 | DTC - Sub Instance | Failed connections: 32
2024-12-13 16:03:20.122 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:20.122 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:20.136 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:20.136 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:20.136 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:22.132 |
2024-12-13 16:03:22.135 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:22.135 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:22.136 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:22.136 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:24.153 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:24.155 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:24.155 | DTC Client socket (1) | Closed.
2024-12-13 16:03:24.157 | DTC - Sub Instance | Failed connections: 33
2024-12-13 16:03:24.157 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:24.157 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:24.186 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:24.187 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:24.187 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:26.181 |
2024-12-13 16:03:26.184 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:26.184 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:26.184 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:26.184 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:28.220 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:28.221 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:28.222 | DTC Client socket (1) | Closed.
2024-12-13 16:03:28.223 | DTC - Sub Instance | Failed connections: 34
2024-12-13 16:03:28.223 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:28.223 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:28.238 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:28.238 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:28.238 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:30.250 |
2024-12-13 16:03:30.253 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:30.254 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:30.254 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:30.254 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:32.278 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:32.279 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:32.279 | DTC Client socket (1) | Closed.
2024-12-13 16:03:32.281 | DTC - Sub Instance | Failed connections: 35
2024-12-13 16:03:32.281 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:32.281 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:32.285 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:32.285 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:32.285 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:34.286 |
2024-12-13 16:03:34.288 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:34.288 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:34.289 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:34.289 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:36.309 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:36.311 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:36.311 | DTC Client socket (1) | Closed.
2024-12-13 16:03:36.313 | DTC - Sub Instance | Failed connections: 36
2024-12-13 16:03:36.313 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:36.313 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:36.319 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:36.319 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:36.319 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:38.326 |
2024-12-13 16:03:38.330 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:38.330 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:38.330 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:38.330 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:40.358 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:40.359 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:40.359 | DTC Client socket (1) | Closed.
2024-12-13 16:03:40.362 | DTC - Sub Instance | Failed connections: 37
2024-12-13 16:03:40.362 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:40.362 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:40.391 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:40.392 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:40.392 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:42.391 |
2024-12-13 16:03:42.393 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:42.393 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:42.394 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:42.394 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:44.415 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:44.416 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:44.416 | DTC Client socket (1) | Closed.
2024-12-13 16:03:44.417 | DTC - Sub Instance | Failed connections: 38
2024-12-13 16:03:44.417 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:44.417 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:44.432 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:44.432 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:44.432 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:46.436 |
2024-12-13 16:03:46.439 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:46.439 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:46.439 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:46.439 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:48.463 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:48.465 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:48.465 | DTC Client socket (1) | Closed.
2024-12-13 16:03:48.467 | DTC - Sub Instance | Failed connections: 39
2024-12-13 16:03:48.467 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:48.467 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:48.473 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:48.473 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:48.473 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:50.478 |
2024-12-13 16:03:50.481 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:50.481 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:50.481 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:50.481 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:52.490 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:52.491 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:52.491 | DTC Client socket (1) | Closed.
2024-12-13 16:03:52.493 | DTC - Sub Instance | Failed connections: 40
2024-12-13 16:03:52.493 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:52.493 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:52.507 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:52.507 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:52.507 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:54.504 |
2024-12-13 16:03:54.507 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:54.507 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:54.508 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:54.508 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:03:56.526 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:03:56.529 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:03:56.529 | DTC Client socket (1) | Closed.
2024-12-13 16:03:56.531 | DTC - Sub Instance | Failed connections: 41
2024-12-13 16:03:56.531 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:03:56.531 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:56.538 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:03:56.538 | DTC - Sub Instance | Disconnected.
2024-12-13 16:03:56.539 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:03:58.535 |
2024-12-13 16:03:58.537 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:03:58.537 | DTC Client socket (1) | Creating socket.
2024-12-13 16:03:58.538 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:03:58.538 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:00.568 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:00.570 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:00.570 | DTC Client socket (1) | Closed.
2024-12-13 16:04:00.572 | DTC - Sub Instance | Failed connections: 42
2024-12-13 16:04:00.572 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:00.572 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:00.586 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:00.587 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:00.587 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:02.583 |
2024-12-13 16:04:02.583 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:02.584 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:02.584 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:02.584 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:04.607 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:04.609 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:04.609 | DTC Client socket (1) | Closed.
2024-12-13 16:04:04.610 | DTC - Sub Instance | Failed connections: 43
2024-12-13 16:04:04.610 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:04.610 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:04.641 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:04.641 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:04.642 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:06.632 |
2024-12-13 16:04:06.634 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:06.635 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:06.635 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:06.635 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:08.657 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:08.658 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:08.658 | DTC Client socket (1) | Closed.
2024-12-13 16:04:08.659 | DTC - Sub Instance | Failed connections: 44
2024-12-13 16:04:08.659 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:08.659 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:08.691 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:08.691 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:08.692 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:10.691 |
2024-12-13 16:04:10.694 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:10.694 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:10.694 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:10.694 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:12.716 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:12.717 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:12.717 | DTC Client socket (1) | Closed.
2024-12-13 16:04:12.718 | DTC - Sub Instance | Failed connections: 45
2024-12-13 16:04:12.718 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:12.718 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:12.735 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:12.735 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:12.736 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:14.740 |
2024-12-13 16:04:14.741 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:14.741 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:14.741 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:14.741 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:16.759 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:16.761 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:16.761 | DTC Client socket (1) | Closed.
2024-12-13 16:04:16.763 | DTC - Sub Instance | Failed connections: 46
2024-12-13 16:04:16.763 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:16.763 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:16.778 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:16.778 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:16.779 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:18.780 |
2024-12-13 16:04:18.783 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:18.783 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:18.784 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:18.784 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:20.796 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:20.797 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:20.797 | DTC Client socket (1) | Closed.
2024-12-13 16:04:20.798 | DTC - Sub Instance | Failed connections: 47
2024-12-13 16:04:20.798 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:20.798 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:20.830 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:20.831 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:20.831 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:22.829 |
2024-12-13 16:04:22.829 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:22.830 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:22.830 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:22.830 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:24.844 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:24.844 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:24.844 | DTC Client socket (1) | Closed.
2024-12-13 16:04:24.844 | DTC - Sub Instance | Failed connections: 48
2024-12-13 16:04:24.844 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:24.844 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:24.862 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:24.862 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:24.862 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:26.877 |
2024-12-13 16:04:26.880 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:26.880 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:26.880 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:26.880 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:28.900 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:28.900 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:28.900 | DTC Client socket (1) | Closed.
2024-12-13 16:04:28.900 | DTC - Sub Instance | Failed connections: 49
2024-12-13 16:04:28.900 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:28.900 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:28.917 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:28.917 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:28.918 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:30.913 |
2024-12-13 16:04:30.914 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:04:30.914 | DTC Client socket (1) | Creating socket.
2024-12-13 16:04:30.915 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:04:30.915 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:04:32.934 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:04:32.936 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:04:32.936 | DTC Client socket (1) | Closed.
2024-12-13 16:04:32.938 | DTC - Sub Instance | Failed connections: 50
2024-12-13 16:04:32.938 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:04:32.938 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:04:32.953 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:04:32.953 | DTC - Sub Instance | Disconnected.
2024-12-13 16:04:32.953 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:06:32.941 |
2024-12-13 16:06:32.941 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:06:32.941 | DTC Client socket (1) | Creating socket.
2024-12-13 16:06:32.942 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:06:32.942 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:06:34.976 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:06:34.976 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:06:34.977 | DTC Client socket (1) | Closed.
2024-12-13 16:06:34.978 | DTC - Sub Instance | Failed connections: 51
2024-12-13 16:06:34.978 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:06:34.978 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:06:34.992 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:06:34.992 | DTC - Sub Instance | Disconnected.
2024-12-13 16:06:34.993 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:08:34.997 |
2024-12-13 16:08:34.997 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:08:34.998 | DTC Client socket (1) | Creating socket.
2024-12-13 16:08:34.998 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:08:34.998 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:08:37.026 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:08:37.028 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:08:37.028 | DTC Client socket (1) | Closed.
2024-12-13 16:08:37.030 | DTC - Sub Instance | Failed connections: 52
2024-12-13 16:08:37.030 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:08:37.030 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:08:37.038 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:08:37.038 | DTC - Sub Instance | Disconnected.
2024-12-13 16:08:37.039 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:10:37.048 |
2024-12-13 16:10:37.052 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:10:37.052 | DTC Client socket (1) | Creating socket.
2024-12-13 16:10:37.052 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:10:37.052 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:10:39.081 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:10:39.081 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:10:39.081 | DTC Client socket (1) | Closed.
2024-12-13 16:10:39.082 | DTC - Sub Instance | Failed connections: 53
2024-12-13 16:10:39.082 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:10:39.082 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:10:39.097 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:10:39.098 | DTC - Sub Instance | Disconnected.
2024-12-13 16:10:39.098 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:12:39.099 |
2024-12-13 16:12:39.104 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:12:39.104 | DTC Client socket (1) | Creating socket.
2024-12-13 16:12:39.104 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:12:39.104 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:12:41.124 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:12:41.125 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:12:41.125 | DTC Client socket (1) | Closed.
2024-12-13 16:12:41.126 | DTC - Sub Instance | Failed connections: 54
2024-12-13 16:12:41.126 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:12:41.126 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:12:41.158 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:12:41.158 | DTC - Sub Instance | Disconnected.
2024-12-13 16:12:41.158 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:14:41.173 |
2024-12-13 16:14:41.174 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:14:41.174 | DTC Client socket (1) | Creating socket.
2024-12-13 16:14:41.174 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:14:41.174 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:14:43.198 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:14:43.199 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:14:43.199 | DTC Client socket (1) | Closed.
2024-12-13 16:14:43.200 | DTC - Sub Instance | Failed connections: 55
2024-12-13 16:14:43.200 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:14:43.200 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:14:43.216 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:14:43.216 | DTC - Sub Instance | Disconnected.
2024-12-13 16:14:43.217 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:16:43.205 |
2024-12-13 16:16:43.208 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:16:43.208 | DTC Client socket (1) | Creating socket.
2024-12-13 16:16:43.208 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:16:43.208 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:16:45.236 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:16:45.237 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:16:45.237 | DTC Client socket (1) | Closed.
2024-12-13 16:16:45.239 | DTC - Sub Instance | Failed connections: 56
2024-12-13 16:16:45.239 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:16:45.239 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:16:45.253 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:16:45.253 | DTC - Sub Instance | Disconnected.
2024-12-13 16:16:45.253 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:18:45.262 |
2024-12-13 16:18:45.266 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:18:45.266 | DTC Client socket (1) | Creating socket.
2024-12-13 16:18:45.266 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:18:45.266 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:18:47.286 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:18:47.287 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:18:47.288 | DTC Client socket (1) | Closed.
2024-12-13 16:18:47.288 | DTC - Sub Instance | Failed connections: 57
2024-12-13 16:18:47.288 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:18:47.288 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:18:47.304 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:18:47.304 | DTC - Sub Instance | Disconnected.
2024-12-13 16:18:47.305 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:19:06.211 | Error creating process C:\SierraChart\NPP\notepad++.exe. Windows error code 2: The system cannot find the file specified. *
2024-12-13 16:19:06.211 | Error creating the Advanced Custom Studies editor process. *
2024-12-13 16:20:47.303 |
2024-12-13 16:20:47.304 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:20:47.304 | DTC Client socket (1) | Creating socket.
2024-12-13 16:20:47.304 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:20:47.304 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:20:49.319 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:20:49.321 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:20:49.321 | DTC Client socket (1) | Closed.
2024-12-13 16:20:49.322 | DTC - Sub Instance | Failed connections: 58
2024-12-13 16:20:49.322 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:20:49.322 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:20:49.337 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:20:49.337 | DTC - Sub Instance | Disconnected.
2024-12-13 16:20:49.337 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:22:49.333 |
2024-12-13 16:22:49.335 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:22:49.335 | DTC Client socket (1) | Creating socket.
2024-12-13 16:22:49.335 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:22:49.335 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:22:51.363 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:22:51.365 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:22:51.365 | DTC Client socket (1) | Closed.
2024-12-13 16:22:51.368 | DTC - Sub Instance | Failed connections: 59
2024-12-13 16:22:51.368 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:22:51.368 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:22:51.381 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:22:51.382 | DTC - Sub Instance | Disconnected.
2024-12-13 16:22:51.382 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:24:51.376 |
2024-12-13 16:24:51.379 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:24:51.379 | DTC Client socket (1) | Creating socket.
2024-12-13 16:24:51.380 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:24:51.380 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:24:53.394 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:24:53.396 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:24:53.396 | DTC Client socket (1) | Closed.
2024-12-13 16:24:53.398 | DTC - Sub Instance | Failed connections: 60
2024-12-13 16:24:53.398 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:24:53.398 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:24:53.401 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:24:53.401 | DTC - Sub Instance | Disconnected.
2024-12-13 16:24:53.402 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:26:53.403 |
2024-12-13 16:26:53.404 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:26:53.404 | DTC Client socket (1) | Creating socket.
2024-12-13 16:26:53.404 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:26:53.404 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:26:55.430 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:26:55.432 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:26:55.432 | DTC Client socket (1) | Closed.
2024-12-13 16:26:55.434 | DTC - Sub Instance | Failed connections: 61
2024-12-13 16:26:55.434 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:26:55.434 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:26:55.448 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:26:55.448 | DTC - Sub Instance | Disconnected.
2024-12-13 16:26:55.449 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:28:55.455 |
2024-12-13 16:28:55.456 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2024-12-13 16:28:55.456 | DTC Client socket (1) | Creating socket.
2024-12-13 16:28:55.457 | DTC Client socket (1) | New receive buffer size: 0
2024-12-13 16:28:55.457 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2024-12-13 16:28:57.476 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2024-12-13 16:28:57.478 | DTC Client socket (1) | CloseSocket call.
2024-12-13 16:28:57.478 | DTC Client socket (1) | Closed.
2024-12-13 16:28:57.478 | DTC - Sub Instance | Failed connections: 62
2024-12-13 16:28:57.478 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-12-13 16:28:57.478 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:28:57.496 | DTC Client socket (0) | CloseSocket call.
2024-12-13 16:28:57.497 | DTC - Sub Instance | Disconnected.
2024-12-13 16:28:57.497 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2024-12-13 16:29:32.576 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2.
2024-12-13 16:29:32.576 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 0
2024-12-13 16:29:32.576 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 67.214.125.8.
2024-12-13 16:29:35.859 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (1) | CloseSocket call.
2024-12-13 16:29:35.859 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2024-12-13 16:29:35.891 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2024-12-13 16:29:35.892 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (1) | Closed.
2024-12-13 16:29:38.839 | Disallowing loading of DLL: D:\SierraChart\SierraChartInstance_2\Data\OpenRangeBreakoutBacktest.dll
2024-12-13 16:29:38.839 | Setting study DLL module function objects to indicate DLL is not loaded: D:\SierraChart\SierraChartInstance_2\Data\OpenRangeBreakoutBacktest.dll
2024-12-13 16:29:38.839 | Study DLL module not found for: D:\SierraChart\SierraChartInstance_2\Data\OpenRangeBreakoutBacktest.dll
2024-12-13 16:29:48.256 | Disallowing loading of DLL: D:\SierraChart\SierraChartInstance_2\Data\OpenRangeBreakoutBacktest.dll
2024-12-13 16:29:48.256 | Setting study DLL module function objects to indicate DLL is not loaded: D:\SierraChart\SierraChartInstance_2\Data\OpenRangeBreakoutBacktest.dll
2024-12-13 16:29:48.256 | Study DLL module not found for: D:\SierraChart\SierraChartInstance_2\Data\OpenRangeBreakoutBacktest.dll
[2024-12-13 21:35:29]
John - SC Support - Posts: 39428
Is this actually a Sub-Instance, started by selecting "File >> New Instance"? Or was this started in another way?
The "window" we were referring to in our first response was the "Build Custom Study" window that you showed in your video. Nothing was occurring, which might have been because of what is in your log, but it also looked like you did not have the window expanded enough to see anything in the "Build Output" section on that window. As we stated, you need to expand that window to see more information.
[2024-12-13 22:32:04]
User377189 - Posts: 215
It is a sub-instance, initially created by file >> New instance. But i have set to open instance on startup
Ok i expanded the window and got the following:
-- Starting remote build of Custom Studies Source files: OpenRangeBreakoutBacktest.cpp. 64-bit -- 17:26:05
Allow time for the server to compile the files and build the DLL.
Server: https://build.sierrachart.com
The remote build is complete.
The build succeeded.
The compiler response is empty.
Writing file to: D:\SierraChart\SierraChartInstance_2\Data\OpenRangeBreakoutBacktest_64.dll
-- End of Build -- 17:26:09
Whats the difference between the builds and which one should be used? I used remote build
- Remote build
- Build with Visual C++- Release
- Build with Visual C++- Debug
[2024-12-14 13:25:15]
The build was complete but i do not see the study (see attached screenshot)
2024-12-14 08:17:45.156 | DTC - Sub Instance | Received security definition for symbol F.US.EPZ24
2024-12-14 08:17:45.591 | Requesting market depth updates for: F.US.EPZ24 if supported. NumLevels=1400
2024-12-14 08:17:45.594 | DTC - Sub Instance | Clearing market depth for F.US.EPZ24
2024-12-14 08:17:50.146 | HD Request # 1 | Downloading Intraday chart data for F.US.EPZ24 to the file F.US.EPZ24.scid. Service: cme
2024-12-14 08:17:50.146 | HD Request # 1 | Download start date-time: 2024-12-13 16:59:59.000000. File last date-time: 2024-12-13 16:59:59.759001
2024-12-14 08:17:50.146 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149
2024-12-14 08:17:50.147 | Socket (2) | Creating socket.
2024-12-14 08:17:50.147 | Socket (2) | New receive buffer size: 0
2024-12-14 08:17:50.147 | Socket (2) | Connecting to IP: 67.214.125.5.
2024-12-14 08:17:50.224 | HD Request # 1 | Setting DTC encoding to Binary VLS
2024-12-14 08:17:50.224 | HD Request # 1 | Sending historical data logon request message.
2024-12-14 08:17:50.255 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-12-13 16:59:59. Record interval: 0. Symbol: ESZ24
2024-12-14 08:17:50.286 | HD Request # 1 | Decompressing data.
2024-12-14 08:17:50.318 | HD Request # 1 | Receiving Intraday data for F.US.EPZ24 starting at 2024-12-13 16:59:59.372000
2024-12-14 08:17:50.319 | Socket (2) | CloseSocket call.
2024-12-14 08:17:50.319 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-12-14 08:17:50.330 | Historical data download thread signaled to stop.
2024-12-14 08:17:50.330 | HD Request # 1 | Received 4 Intraday data records from 2024-12-13 16:59:59.372000 to 2024-12-13 16:59:59.759001 (0.4 seconds. Delay: 15.3 hours) and wrote 0 records for F.US.EPZ24
2024-12-14 08:17:50.331 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-12-13 21:59:59.759001
2024-12-14 08:17:50.331 | HD Request # 1 | Completion time: 0s.
2024-12-14 08:17:50.331 | HD Request # 1 | Intraday data download complete for F.US.EPZ24. Unique request ID: 1
2024-12-14 08:17:50.331 | Removing historical data download ID 1.
2024-12-14 08:17:50.331 | Real-time Intraday chart data file updates started for F.US.EPZ24
2024-12-14 08:17:50.331 | Intraday chart data file opened for F.US.EPZ24
2024-12-14 08:17:50.331 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2024-12-14 08:17:50.331 | No download requests in the queue to start downloads for.
2024-12-14 08:17:50.349 | Socket (2) | Socket gracefully closed by remote side.
2024-12-14 08:17:50.349 | Socket (2) | Closed.
2024-12-14 08:17:59.732 | F.US.EPZ24 #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-12-14 08:18:00.171 | F.US.EPZ24 #1 | Chart data loading complete.
2024-12-14 08:18:09.361 | Found DLL: OpeningRangeBreakoutAutomation_64.dll
2024-12-14 08:18:09.361 | Found DLL: PMStrat_64.dll
2024-12-14 08:18:09.361 | Found DLL: UserContributedStudies.dll
2024-12-14 08:18:09.361 | Found DLL: UserContributedStudies_64.dll
2024-12-14 08:18:09.363 | No custom study function names found in D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation_64.dll
2024-12-14 08:18:09.363 | InternalVersionNumberToFileNameMap is empty for OpeningRangeBreakoutAutomation
2024-12-14 08:18:09.363 | Closest match search for: D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation.dll returned empty result. *
2024-12-14 08:18:09.372 | Loading DLL: D:\SierraChart\SierraChartInstance_2\Data\PMStrat.dll (PMStrat_64.dll). Handle: 66000000
2024-12-14 08:18:09.372 | UserContributedStudies.dll is not 64-bit | Number times message added: 1
2024-12-14 08:18:09.390 | Loading DLL: D:\SierraChart\SierraChartInstance_2\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffcae6b0000
2024-12-14 08:18:37.991 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2.
2024-12-14 08:18:37.991 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 0
2024-12-14 08:18:37.991 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 67.214.125.8.
2024-12-14 08:18:41.553 | The compiler response is empty.
2024-12-14 08:18:41.559 | Setting study DLL module function objects to indicate DLL is not loaded: D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation.dll
2024-12-14 08:18:41.559 | Study DLL module not found for: D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation.dll
2024-12-14 08:18:41.814 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | CloseSocket call.
2024-12-14 08:18:41.814 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close.
2024-12-14 08:18:41.855 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side.
2024-12-14 08:18:41.855 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Closed.
2024-12-14 08:19:46.377 | Found DLL: OpeningRangeBreakoutAutomation_64.dll
2024-12-14 08:19:46.377 | Found DLL: PMStrat_64.dll
2024-12-14 08:19:46.377 | Found DLL: UserContributedStudies.dll
2024-12-14 08:19:46.377 | Found DLL: UserContributedStudies_64.dll
2024-12-14 08:19:46.381 | No custom study function names found in D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation_64.dll
2024-12-14 08:19:46.381 | InternalVersionNumberToFileNameMap is empty for OpeningRangeBreakoutAutomation
2024-12-14 08:19:46.381 | Closest match search for: D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation.dll returned empty result. *
2024-12-14 08:19:46.390 | UserContributedStudies.dll is not 64-bit
2024-12-14 08:20:33.986 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2.
2024-12-14 08:20:33.986 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 0
2024-12-14 08:20:33.986 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 67.214.125.8.
2024-12-14 08:20:37.626 | The compiler response is empty.
2024-12-14 08:20:37.632 | Setting study DLL module function objects to indicate DLL is not loaded: D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation.dll
2024-12-14 08:20:37.632 | Study DLL module not found for: D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation.dll
2024-12-14 08:20:37.904 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | CloseSocket call.
2024-12-14 08:20:37.904 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close.
2024-12-14 08:20:37.937 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side.
2024-12-14 08:20:37.937 | HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Closed.
2024-12-14 08:23:53.381 | Found DLL: OpeningRangeBreakoutAutomation_64.dll
2024-12-14 08:23:53.381 | Found DLL: PMStrat_64.dll
2024-12-14 08:23:53.381 | Found DLL: UserContributedStudies.dll
2024-12-14 08:23:53.381 | Found DLL: UserContributedStudies_64.dll
2024-12-14 08:23:53.382 | No custom study function names found in D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation_64.dll
2024-12-14 08:23:53.382 | InternalVersionNumberToFileNameMap is empty for OpeningRangeBreakoutAutomation
2024-12-14 08:23:53.382 | Closest match search for: D:\SierraChart\SierraChartInstance_2\Data\OpeningRangeBreakoutAutomation.dll returned empty result. *
2024-12-14 08:23:53.388 | UserContributedStudies.dll is not 64-bit
Date Time Of Last Edit: 2024-12-17 19:37:16
Private File
[2024-12-14 19:24:20]
Sierra_Chart Engineering - Posts: 19305
Provide us the CPP source code for the custom studies file you are building.
You can make it a private attachment.
[2024-12-16 16:25:59]
Please see attached
Date Time Of Last Edit: 2024-12-17 19:36:43
[2024-12-17 19:36:16]
We see where you have gone wrong. Change the declaration of the function like this:
SCSFExport scsf_OpeningRangeBreakoutAutomation(SCStudyInterfaceRef sc)
Otherwise, the DLL has no exported functions.
Date Time Of Last Edit: 2024-12-17 19:36:22
[2024-12-18 09:12:32]
the attached .cpp file was used to build a custom study. This was compiled and built without errors but it just does not seem to work.
No matter the start or end times put in it will spill out the result and give me the correct price levels. Also it will not trigger trades.
Private File
[2024-12-18 14:58:04]
If your study is not doing what you are expecting it to do, then we can not help you with this. We do not give any programming help.
We recommend opening a new thread and posting your issue as a "Programming Help". Others from the community will probably help you. But you do need to open another thread, as most people will not see the issue in this thread due to this being about a different issue.
[2024-12-19 06:41:38]
For an example of how to improve the logging and provide an actual meaningful message, refer to:
Automated Trading From an Advanced Custom Study: Debugging/Troubleshooting Automated Trading Systems
That particular Error Code means:
SCT_SKIPPED_ONLY_ONE_TRADE_PER_BAR
Date Time Of Last Edit: 2024-12-19 06:42:01
[2024-12-20 01:05:12]
I used the attached .cpp file to build the study. The build was successful but OCO orders are not triggering. I am not seeing any errors in the logs
Private File
[2024-12-22 03:32:14]
When i use the custom study that was built using qty.1 my orders get triggered. When i use qty.4 i keep getting errors
all of the trades are in SIM and chart replay yet i got the following error on my log
2024-12-21 22:28:30.437 | Chart: F.US.EPH25 #1 | Study: ORBR | Trade order submission failed. Check broker limits. * | Number times message added: 701
Why is there broker limits issue for sim trading?
[2024-12-23 02:48:48]
ForgivingComputers.com - Posts: 1042
Have you tried setting the value:
sc.MaximumPositionAllowed = 4;
By default, it is one.
[2024-12-23 05:46:33]
This message is not from Sierra Chart:
