Date/Time: Wed, 23 Apr 2025 03:19:24 +0000
Trade Dom total and percentage text
View Count: 161
[2024-12-11 13:23:36]
User185210 - Posts: 66
I would like to get the total and percentage values from the trade Dom in a spreadsheet.
Is there a study extracting these values?
Thank you for your help.
[2024-12-11 16:49:37]
John - SC Support - Posts: 39428
Exactly what Total and Percentage values are you referring to?
[2024-12-11 18:58:25]
The ones from the trade Dom or Chart Dom
above the "Ask size/Sell column"
and
below the "Bid Size/Buy column"
[2024-12-11 21:06:13]
Those are the Totals of the Bid/Ask Market Depth and the relative percentages for each side of the total of both.
The totals are available through the "Bid and Ask Depth Bars" study. You would need to set the "Calculation Mode" to "Bid Depth vs Ask Depth" and then it will give the Ask as positive values and the Bid as negative values. Refer to the following:
Bid & Ask Depth Bars
To get the percentage, you would need to use any number of options to add the values and divide each side by the total. Refer to the following for options:
Using the Basic Arithmetic Studies
Spreadsheet Formula
Using the Spreadsheet Study
