Date/Time: Fri, 20 Sep 2024 03:46:16 +0000
Missing Charts
View Count: 895
[2014-09-11 04:11:52] |
apollofl - Posts: 95 |
in chart books After going back to version 1187 from version 1189. How do I get my old Chart books back.....Help Help Thanks |
[2014-09-11 04:23:23] |
We have run a test and we did not see any problem with Chartbooks opened and saved in 1189 and using those same Chartbooks in 1187. However, to access your back up Chartbooks, refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#BackupChartbook There would have been a problem with saving a Chartbook with 1188 and trying to use it in another or same version. The Chartbook would have been damaged. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-11 05:10:41] |
Thanks, got the backup.
[2014-09-11 05:41:40] |
This is good. Let us know if you need more help.
