Date/Time: Wed, 27 Nov 2024 12:25:34 +0000
Waiting to connect
View Count: 1085
[2014-09-08 16:00:23]
User19585 - Posts: 3
Cannot connect even though I have tried repeatedly to follow the connection problem FAQs on the website. Can you please help? I have sent a copy of the message log as well.
Thank You,
Cheryl Murakami
[2014-09-09 05:18:14]
This is from your Message Log:
OEC FIX/FAST | 9300. | 2014-09-07 11:04:56
OEC FIX Trading socket (0) | Resolved address sim.openecry.com to IP 64.94.37.207 | 2014-09-07 11:04:56
OEC FIX Trading socket (964) | Connected. | 2014-09-07 11:04:56
OEC FIX Trading: Sending the Logon message. | 2014-09-07 11:04:56
OEC FIX Trading: Received a Logout message. | 2014-09-07 11:04:56
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-09-07 11:04:56
OEC FIX Trading socket (964) | Shutdown and closed. | 2014-09-07 11:04:56
OEC FIX Trading: Logged out and disconnected. | 2014-09-07 11:04:56
We are not sure of the reason for OEC not accepting the connection. Do you have a live account with OEC? Have you contacted OEC about this.
[2014-09-09 12:02:54]
Contacted OEC and they said everything was good on their end. They suggested I contact Sierra Charts. Yes I have a live account.
Thank you.
[2014-09-09 21:29:50]
If you have a live account, then the problem is you are not connecting to the proper server.
Select Global Settings >> Data/Trade Service Settings. Set the Connection Details >> Server to prod.openecry.com.
Press OK.
Try connecting again with File >> Connect to Data Feed.
Here are the detailed set up instructions:
https://www.sierrachart.com/index.php?page=doc/openecry.php#SetupInstructions
