Date/Time: Fri, 20 Sep 2024 02:52:08 +0000
YM no market depth and the chart aren´t updating
View Count: 1036
[2014-09-08 15:37:47] |
User49838 - Posts: 9 |
Hi SC, after opening Sierra Chart I use NQ, ES and YM chart. But YM aren´t updating current prices and have no market depth. NQ and ES is OK (prices are updating and maket depth is OK) I tryed connect/disconnect datfeed, close my SC and opened again 5x, but nothing helps me. Can you help me? Thanks a lot |
[2014-09-08 15:49:38] |
Restart Sierra Chart and post a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Also refer to help topic 3 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-08 16:03:05] |
Software version: 1187 | 2014-09-08 17:58:08 Usage end date: 2014-11-09 | 2014-09-08 17:58:08 Enabled for: Advanced Features. | 2014-09-08 17:58:08 Enabled for: Advanced Features 2. | 2014-09-08 17:58:08 Enabled for: Sierra Chart Historical Data Service. | 2014-09-08 17:58:08 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-09-08 17:58:08 Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2014-09-08 17:58:08 Received 1 data feed usernames. | 2014-09-08 17:58:08 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-09-08 17:58:08 Active service: AMP/TTNet | 2014-09-08 17:58:08 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-09-08 17:58:08 2014-09-08 17:58:08 Local computer clock time | 2014-09-08 17:58:08 2014-09-08 15:58:08 GMT time | 2014-09-08 17:58:08 2014-09-08 17:58:08 Time zone adjusted time | 2014-09-08 17:58:08 Time difference to server time: 1 seconds. | 2014-09-08 17:58:08 Program path: C:\SierraChart\ | 2014-09-08 17:58:08 Data Files path: C:\SierraChart\Data\ | 2014-09-08 17:58:08 OS Version Number: 5.1 | 2014-09-08 17:58:08 Checking for new symbol settings for tt | 2014-09-08 17:58:08 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-09-08 17:58:08 HTTP connection to www.sierrachart.com:80 (956) | Connected. | 2014-09-08 17:58:08 Symbol settings are up-to-date for tt | 2014-09-08 17:58:08 Checking for large (over 250 MB) intraday data files to move data out of. Please wait.... | 2014-09-08 17:58:10 HTTP connection to www.sierrachart.com:80 (956) | Closed. No error. | 2014-09-08 17:58:18 HTTP connection to www.sierrachart.com:80 (956) | Shutdown and closed. | 2014-09-08 17:58:18 Completed checking of 2 Intraday data files (*.scid). | 2014-09-08 17:58:29 Date rule based rollover from NQU11 to next contract occurs at 2011-09-08. | 2014-09-08 17:58:30 Date rule based rollover from NQZ11 to next contract occurs at 2011-12-08. | 2014-09-08 17:58:30 Date rule based rollover from NQH12 to next contract occurs at 2012-03-08. | 2014-09-08 17:58:30 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2014-09-08 17:58:30 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2014-09-08 17:58:30 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2014-09-08 17:58:30 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2014-09-08 17:58:30 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2014-09-08 17:58:30 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2014-09-08 17:58:30 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2014-09-08 17:58:30 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2014-09-08 17:58:30 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2014-09-08 17:58:30 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:30 Symbols used for NQU14 continuous contract chart: | 2014-09-08 17:58:30 NQU11 | 2014-09-08 17:58:30 NQZ11 | 2014-09-08 17:58:30 NQH12 | 2014-09-08 17:58:30 NQM12 | 2014-09-08 17:58:30 NQU12 | 2014-09-08 17:58:30 NQZ12 | 2014-09-08 17:58:30 NQH13 | 2014-09-08 17:58:30 NQM13 | 2014-09-08 17:58:30 NQU13 | 2014-09-08 17:58:30 NQZ13 | 2014-09-08 17:58:30 NQH14 | 2014-09-08 17:58:30 NQM14 | 2014-09-08 17:58:30 NQU14 | 2014-09-08 17:58:30 Volume based rollover from NQU11 to NQZ11 occurs at 2011-09-09 | 2014-09-08 17:58:30 Volume based rollover from NQZ11 to NQH12 occurs at 2011-12-09 | 2014-09-08 17:58:30 Volume based rollover from NQH12 to NQM12 occurs at 2012-03-09 | 2014-09-08 17:58:30 Volume based rollover from NQM12 to NQU12 occurs at 2012-06-08 | 2014-09-08 17:58:30 Volume based rollover from NQU12 to NQZ12 occurs at 2012-09-14 | 2014-09-08 17:58:30 Volume based rollover from NQZ12 to NQH13 occurs at 2012-12-14 | 2014-09-08 17:58:30 Volume based rollover from NQH13 to NQM13 occurs at 2013-03-08 | 2014-09-08 17:58:30 Volume based rollover from NQM13 to NQU13 occurs at 2013-06-14 | 2014-09-08 17:58:30 Volume based rollover from NQU13 to NQZ13 occurs at 2013-09-13 | 2014-09-08 17:58:30 Volume based rollover from NQZ13 to NQH14 occurs at 2013-12-13 | 2014-09-08 17:58:30 Volume based rollover from NQH14 to NQM14 occurs at 2014-03-14 | 2014-09-08 17:58:30 Volume based rollover from NQM14 to NQU14 occurs at 2014-06-13 | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU11 Open price on 2011-09-09 is 2216. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ11 Open price on 2011-09-09 is 2210.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU11 price difference to NQZ11 is -5.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ11 Open price on 2011-12-09 is 2284.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH12 Open price on 2011-12-09 is 2280.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ11 price difference to NQH12 is -3.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH12 Open price on 2012-03-09 is 2637.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM12 Open price on 2012-03-09 is 2634.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH12 price difference to NQM12 is -2.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM12 Open price on 2012-06-08 is 2536.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU12 Open price on 2012-06-08 is 2530. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM12 price difference to NQU12 is -6.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU12 Open price on 2012-09-14 is 2827.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ12 Open price on 2012-09-14 is 2820.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU12 price difference to NQZ12 is -7. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ12 Open price on 2012-12-14 is 2650.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH13 Open price on 2012-12-14 is 2645.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ12 price difference to NQH13 is -5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH13 Open price on 2013-03-08 is 2798.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM13 Open price on 2013-03-08 is 2794.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH13 price difference to NQM13 is -4. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM13 Open price on 2013-06-14 is 2966.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU13 Open price on 2013-06-14 is 2958. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM13 price difference to NQU13 is -8.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU13 Open price on 2013-09-13 is 3177.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ13 Open price on 2013-09-13 is 3171.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU13 price difference to NQZ13 is -5.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ13 Open price on 2013-12-13 is 3457. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH14 Open price on 2013-12-13 is 3452.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQZ13 price difference to NQH14 is -4.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH14 Open price on 2014-03-14 is 3655.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM14 Open price on 2014-03-14 is 3646.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQH14 price difference to NQM14 is -9.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM14 Open price on 2014-06-13 is 3773. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQU14 Open price on 2014-06-13 is 3766.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: NQM14 price difference to NQU14 is -6.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQU11 is -68.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQZ11 is -63. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQH12 is -59.5. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQM12 is -56.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQU12 is -50. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQZ12 is -43. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQH13 is -38. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQM13 is -34. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQU13 is -25.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQZ13 is -20.25. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQH14 is -15.75. | 2014-09-08 17:58:30 NQU14/NQ-201409-CME [CBV] Daily #6: Back adjust amount for symbol NQM14 is -6.5. | 2014-09-08 17:58:30 Date rule based rollover from NQ-201409-CME to next contract occurs at 2014-09-11. | 2014-09-08 17:58:30 Checking Intraday data file for symbol NQ-201409-CME for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:30 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:30 Symbols used for NQ-201409-CME continuous contract chart: | 2014-09-08 17:58:30 NQ-201409-CME | 2014-09-08 17:58:30 NQ-201409-CME [CBV] 30 Min #3: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:30 Date rule based rollover from ES-201409-CME to next contract occurs at 2014-09-11. | 2014-09-08 17:58:30 Checking Intraday data file for symbol ES-201409-CME for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:30 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:30 Symbols used for ES-201409-CME continuous contract chart: | 2014-09-08 17:58:30 ES-201409-CME | 2014-09-08 17:58:30 ES-201409-CME [CBV] 30 Min #5: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:30 Date rule based rollover from YMU11 to next contract occurs at 2011-09-08. | 2014-09-08 17:58:30 Date rule based rollover from YMZ11 to next contract occurs at 2011-12-08. | 2014-09-08 17:58:30 Date rule based rollover from YMH12 to next contract occurs at 2012-03-08. | 2014-09-08 17:58:30 Date rule based rollover from YMM12 to next contract occurs at 2012-06-07. | 2014-09-08 17:58:30 Date rule based rollover from YMU12 to next contract occurs at 2012-09-13. | 2014-09-08 17:58:30 Date rule based rollover from YMZ12 to next contract occurs at 2012-12-13. | 2014-09-08 17:58:30 Date rule based rollover from YMH13 to next contract occurs at 2013-03-07. | 2014-09-08 17:58:30 Date rule based rollover from YMM13 to next contract occurs at 2013-06-13. | 2014-09-08 17:58:30 Date rule based rollover from YMU13 to next contract occurs at 2013-09-12. | 2014-09-08 17:58:30 Date rule based rollover from YMZ13 to next contract occurs at 2013-12-12. | 2014-09-08 17:58:30 Date rule based rollover from YMH14 to next contract occurs at 2014-03-13. | 2014-09-08 17:58:30 Date rule based rollover from YMM14 to next contract occurs at 2014-06-12. | 2014-09-08 17:58:30 Date rule based rollover from YMU14 to next contract occurs at 2014-09-11. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-09-08 17:58:30 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:30 Symbols used for YMU14 continuous contract chart: | 2014-09-08 17:58:30 YMU11 | 2014-09-08 17:58:30 YMZ11 | 2014-09-08 17:58:30 YMH12 | 2014-09-08 17:58:30 YMM12 | 2014-09-08 17:58:30 YMU12 | 2014-09-08 17:58:30 YMZ12 | 2014-09-08 17:58:30 YMH13 | 2014-09-08 17:58:30 YMM13 | 2014-09-08 17:58:30 YMU13 | 2014-09-08 17:58:30 YMZ13 | 2014-09-08 17:58:30 YMH14 | 2014-09-08 17:58:30 YMM14 | 2014-09-08 17:58:30 YMU14 | 2014-09-08 17:58:30 Volume based rollover from YMU11 to YMZ11 occurs at 2011-09-09 | 2014-09-08 17:58:30 Volume based rollover from YMZ11 to YMH12 occurs at 2011-12-09 | 2014-09-08 17:58:30 Volume based rollover from YMH12 to YMM12 occurs at 2012-03-09 | 2014-09-08 17:58:30 Volume based rollover from YMM12 to YMU12 occurs at 2012-06-08 | 2014-09-08 17:58:30 Volume based rollover from YMU12 to YMZ12 occurs at 2012-09-14 | 2014-09-08 17:58:30 Volume based rollover from YMZ12 to YMH13 occurs at 2012-12-14 | 2014-09-08 17:58:31 Volume based rollover from YMH13 to YMM13 occurs at 2013-03-08 | 2014-09-08 17:58:31 Volume based rollover from YMM13 to YMU13 occurs at 2013-06-14 | 2014-09-08 17:58:31 Volume based rollover from YMU13 to YMZ13 occurs at 2013-09-13 | 2014-09-08 17:58:31 Volume based rollover from YMZ13 to YMH14 occurs at 2013-12-13 | 2014-09-08 17:58:31 Volume based rollover from YMH14 to YMM14 occurs at 2014-03-14 | 2014-09-08 17:58:31 Volume based rollover from YMM14 to YMU14 occurs at 2014-06-13 | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU11 Open price on 2011-09-09 is 11297. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ11 Open price on 2011-09-09 is 11228. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU11 price difference to YMZ11 is -69. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ11 Open price on 2011-12-09 is 12008. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH12 Open price on 2011-12-09 is 11934. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ11 price difference to YMH12 is -74. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH12 Open price on 2012-03-09 is 12908. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM12 Open price on 2012-03-09 is 12843. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH12 price difference to YMM12 is -65. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM12 Open price on 2012-06-08 is 12475. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU12 Open price on 2012-06-08 is 12403. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM12 price difference to YMU12 is -72. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU12 Open price on 2012-09-14 is 13513. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ12 Open price on 2012-09-14 is 13444. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU12 price difference to YMZ12 is -69. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ12 Open price on 2012-12-14 is 13157. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH13 Open price on 2012-12-14 is 13091. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ12 price difference to YMH13 is -66. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH13 Open price on 2013-03-08 is 14320. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM13 Open price on 2013-03-08 is 14259. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH13 price difference to YMM13 is -61. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM13 Open price on 2013-06-14 is 15192. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU13 Open price on 2013-06-14 is 15113. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM13 price difference to YMU13 is -79. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU13 Open price on 2013-09-13 is 15316. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ13 Open price on 2013-09-13 is 15250. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU13 price difference to YMZ13 is -66. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ13 Open price on 2013-12-13 is 15738. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH14 Open price on 2013-12-13 is 15674. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMZ13 price difference to YMH14 is -64. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH14 Open price on 2014-03-14 is 16124. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM14 Open price on 2014-03-14 is 16049. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMH14 price difference to YMM14 is -75. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM14 Open price on 2014-06-13 is 16751. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMU14 Open price on 2014-06-13 is 16683. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: YMM14 price difference to YMU14 is -68. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMU11 is -828. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMZ11 is -759. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMH12 is -685. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMM12 is -620. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMU12 is -548. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMZ12 is -479. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMH13 is -413. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMM13 is -352. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMU13 is -273. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMZ13 is -207. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMH14 is -143. | 2014-09-08 17:58:31 YMU14/YM-201409-CME [CBV] Daily #2: Back adjust amount for symbol YMM14 is -68. | 2014-09-08 17:58:31 Date rule based rollover from YM-201409-CBOT to next contract occurs at 2014-09-11. | 2014-09-08 17:58:31 Checking Intraday data file for symbol YM-201409-CBOT for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Symbols used for YM-201409-CBOT continuous contract chart: | 2014-09-08 17:58:31 YM-201409-CBOT | 2014-09-08 17:58:31 YM-201409-CBOT [CBV] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:31 Date rule based rollover from NQ-201409-CME to next contract occurs at 2014-09-11. | 2014-09-08 17:58:31 Checking Intraday data file for symbol NQ-201409-CME for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Symbols used for NQ-201409-CME continuous contract chart: | 2014-09-08 17:58:31 NQ-201409-CME | 2014-09-08 17:58:31 NQ-201409-CME [CBV] 2 Min #7: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:31 Date rule based rollover from NQ-201409-CME to next contract occurs at 2014-09-11. | 2014-09-08 17:58:31 Checking Intraday data file for symbol NQ-201409-CME for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Symbols used for NQ-201409-CME continuous contract chart: | 2014-09-08 17:58:31 NQ-201409-CME | 2014-09-08 17:58:31 NQ-201409-CME [CBV] 2 Min #1: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:31 Date rule based rollover from ES-201409-CME to next contract occurs at 2014-09-11. | 2014-09-08 17:58:31 Checking Intraday data file for symbol ES-201409-CME for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:31 Symbols used for ES-201409-CME continuous contract chart: | 2014-09-08 17:58:31 ES-201409-CME | 2014-09-08 17:58:31 ES-201409-CME [CBV] 2 Min #4: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:31 Date rule based rollover from YM-201409-CBOT to next contract occurs at 2014-09-11. | 2014-09-08 17:58:32 Checking Intraday data file for symbol YM-201409-CBOT for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:32 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:32 Symbols used for YM-201409-CBOT continuous contract chart: | 2014-09-08 17:58:32 YM-201409-CBOT | 2014-09-08 17:58:32 YM-201409-CBOT [CBV] 2 Min #6: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:32 Date rule based rollover from YM-201409-CBOT to next contract occurs at 2014-09-11. | 2014-09-08 17:58:32 Checking Intraday data file for symbol YM-201409-CBOT for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:32 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:32 Symbols used for YM-201409-CBOT continuous contract chart: | 2014-09-08 17:58:32 YM-201409-CBOT | 2014-09-08 17:58:32 YM-201409-CBOT [CBV] 2 Min #5: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:32 Date rule based rollover from NQ-201409-CME to next contract occurs at 2014-09-11. | 2014-09-08 17:58:32 Checking Intraday data file for symbol NQ-201409-CME for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:32 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:32 Symbols used for NQ-201409-CME continuous contract chart: | 2014-09-08 17:58:32 NQ-201409-CME | 2014-09-08 17:58:32 NQ-201409-CME [CBV] 2 Min #1: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:32 Date rule based rollover from YM-201409-CBOT to next contract occurs at 2014-09-11. | 2014-09-08 17:58:33 Checking Intraday data file for symbol YM-201409-CBOT for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:33 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:33 Symbols used for YM-201409-CBOT continuous contract chart: | 2014-09-08 17:58:33 YM-201409-CBOT | 2014-09-08 17:58:33 YM-201409-CBOT [CBV] 2 Min #2: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:33 Mapping NQ-201409-CME to NQU4. Service code: cme | 2014-09-08 17:58:34 Intraday data recording state for symbol NQ-201409-CME is set to pending. | 2014-09-08 17:58:34 HD Request # 2 | Downloading Intraday chart data for NQ-201409-CME to the file NQ-201409-CME.scid. Service: cme | 2014-09-08 17:58:34 HD Request # 2 | Download start Date-Time: 2014-09-08 17:57:57.0 | 2014-09-08 17:58:34 HD Request # 2 | Using server: scdf2.sierracharts.com port 10149 | 2014-09-08 17:58:34 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-09-08 17:58:34 Socket (1380) | Connected. | 2014-09-08 17:58:34 HD Request # 2 | Sending historical data logon request message. | 2014-09-08 17:58:34 Mapping YM-201409-CBOT to YMU4. Service code: cbot | 2014-09-08 17:58:34 Intraday data recording state for symbol YM-201409-CBOT is set to pending. | 2014-09-08 17:58:34 Intraday data recording state for symbol TICK-NYSE is set to pending. | 2014-09-08 17:58:34 Mapping ES-201409-CME to ESU4. Service code: cme | 2014-09-08 17:58:34 Intraday data recording state for symbol ES-201409-CME is set to pending. | 2014-09-08 17:58:34 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:57:57. Record interval: 0. Symbol: NQU4 | 2014-09-08 17:58:34 HD Request # 2 | Decompressing data. | 2014-09-08 17:58:34 Socket (1380) | Shutdown and closed. | 2014-09-08 17:58:34 The network socket for historical data has been closed. | 2014-09-08 17:58:34 HD Request # 2 | Historical data for NQ-201409-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-09-08 17:58:35 HD Request # 2 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201409-CME | 2014-09-08 17:58:35 HD Request # 2 | Intraday download COMPLETE for NQ-201409-CME. Completion time: 1s | 2014-09-08 17:58:35 HD Request # 3 | Downloading Intraday chart data for YM-201409-CBOT to the file YM-201409-CBOT.scid. Service: cbot | 2014-09-08 17:58:35 HD Request # 3 | Download start Date-Time: 2014-09-08 17:54:45.0 | 2014-09-08 17:58:35 HD Request # 3 | Using server: scdf1.sierracharts.com port 10149 | 2014-09-08 17:58:35 AMP/TTNet | Connecting. | 2014-09-08 17:58:36 Starting the Price Feed session. Connecting to 12.41.48.53 port 10501... | 2014-09-08 17:58:36 TT FIX Data socket (1388) | Connected. | 2014-09-08 17:58:36 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-09-08 17:58:36 Socket (1392) | Connected. | 2014-09-08 17:58:36 HD Request # 3 | Sending historical data logon request message. | 2014-09-08 17:58:36 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:54:45. Record interval: 0. Symbol: YMU4 | 2014-09-08 17:58:36 TT FIX Data: Sending the Logon message. | 2014-09-08 17:58:36 HD Request # 3 | Decompressing data. | 2014-09-08 17:58:36 Socket (1392) | Shutdown and closed. | 2014-09-08 17:58:36 The network socket for historical data has been closed. | 2014-09-08 17:58:36 HD Request # 3 | Historical data for YM-201409-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-09-08 17:58:36 HD Request # 3 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201409-CBOT | 2014-09-08 17:58:36 HD Request # 3 | Intraday download COMPLETE for YM-201409-CBOT. Completion time: 2s | 2014-09-08 17:58:37 TT FIX Price Feed session connected. | 2014-09-08 17:58:37 AMP/TTNet | Starting the Orders session. Connecting to 12.41.48.53 port 10500... | 2014-09-08 17:58:37 HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-09-08 17:58:37 HD Request # 4 | Download start Date-Time: 2014-09-08 17:58:02.0 | 2014-09-08 17:58:37 HD Request # 4 | Using server: ds5.sierracharts.com port 10149 | 2014-09-08 17:58:37 TT FIX Trading socket (1384) | Connected. | 2014-09-08 17:58:37 Mapping YM-201409-CME to YMU4. Service code: cbot | 2014-09-08 17:58:37 HD Request # 5 | Downloading Historical Daily chart data for YMU14. Starting date: 2014-09-05. Service: ttamp | 2014-09-08 17:58:37 HD Request # 5 | Using user Barchart Historical data account. | 2014-09-08 17:58:37 HD Request # 5 | Requesting historical Daily data for YMU14 starting at 2014-09-04 | 2014-09-08 17:58:37 TT FIX Trading: Sending the Logon message. | 2014-09-08 17:58:37 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-09-08 17:58:38 Socket (240) | Connected. | 2014-09-08 17:58:38 HD Request # 4 | Sending historical data logon request message. | 2014-09-08 17:58:38 TT FIX Orders session connected. | 2014-09-08 17:58:38 AMP/TTNet | Connected. | 2014-09-08 17:58:38 Mapping ES-201409-CME to ESU4. Service code: cme | 2014-09-08 17:58:38 SC Exchange Data | Starting real-time market data updates for: ESU4. ID: 1 | 2014-09-08 17:58:38 Using username 0 | 2014-09-08 17:58:38 SC Exchange Data | Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-09-08 17:58:38 Intraday data recording state for symbol ES-201409-CME is set to pending. | 2014-09-08 17:58:38 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-09-08 17:58:38 TT Gateway Status: Price server for the CME exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Order server for the CME exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Fill server for the CME exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Price server for the Eurex-B exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Order server for the Eurex-B exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Fill server for the Eurex-B exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Price server for the ICE_IPE exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Order server for the ICE_IPE exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Fill server for the ICE_IPE exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Price server for the TTSIM exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Order server for the TTSIM exchange is Open | 2014-09-08 17:58:38 TT Gateway Status: Fill server for the TTSIM exchange is Open | 2014-09-08 17:58:38 Socket (1412) | Connected. | 2014-09-08 17:58:38 SC Exchange Data | Connected to server. | 2014-09-08 17:58:38 SC Exchange Data | Sending logon request message. | 2014-09-08 17:58:38 Mapping NQ-201409-CME to NQU4. Service code: cme | 2014-09-08 17:58:38 SC Exchange Data | Starting real-time market data updates for: NQU4. ID: 2 | 2014-09-08 17:58:38 Intraday data recording state for symbol NQ-201409-CME is set to pending. | 2014-09-08 17:58:38 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:58:02. Record interval: 0. Symbol: TICK-NYSE | 2014-09-08 17:58:39 HD Request # 4 | Decompressing data. | 2014-09-08 17:58:39 HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2014-09-08 17:58:02 | 2014-09-08 17:58:39 HD Request # 4 | Timestamp of first Intraday data file record written: 2014-09-08 17:58:03 | 2014-09-08 17:58:39 Socket (240) | Shutdown and closed. | 2014-09-08 17:58:39 The network socket for historical data has been closed. | 2014-09-08 17:58:39 HD Request # 4 | Re-requesting historical data for TICK-NYSE to get the latest data since the download was started while not connected to primary service. | 2014-09-08 17:58:39 HD Request # 4 | Received 36 records from 2014-09-08 17:58:02 to 2014-09-08 17:58:37 (35.0 seconds) and wrote 35 records for TICK-NYSE | 2014-09-08 17:58:39 HD Request # 6 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-09-08 17:58:39 HD Request # 6 | Download start Date-Time: 2014-09-08 17:58:37.0 | 2014-09-08 17:58:39 HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2014-09-08 17:58:39 SC Exchange Data | Server Info - Server Name: . | 2014-09-08 17:58:39 SC Exchange Data | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-08 17:58:39 SC Exchange Data | Successfully connected. | 2014-09-08 17:58:39 SC Exchange Data | Restarting real-time data updates for symbol: ES-201409-CME -> ESU4 | 2014-09-08 17:58:39 SC Exchange Data | Restarting real-time data updates for symbol: NQ-201409-CME -> NQU4 | 2014-09-08 17:58:39 Mapping YM-201409-CBOT to YMU4. Service code: cbot | 2014-09-08 17:58:39 SC Exchange Data | Starting real-time market data updates for: YMU4. ID: 4 | 2014-09-08 17:58:39 Intraday data recording state for symbol YM-201409-CBOT is set to pending. | 2014-09-08 17:58:39 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-09-08 17:58:39 Socket (240) | Connected. | 2014-09-08 17:58:39 HD Request # 6 | Sending historical data logon request message. | 2014-09-08 17:58:39 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:58:37. Record interval: 0. Symbol: TICK-NYSE | 2014-09-08 17:58:40 HD Request # 6 | Decompressing data. | 2014-09-08 17:58:40 HD Request # 6 | Receiving Intraday data for TICK-NYSE starting at 2014-09-08 17:58:37 | 2014-09-08 17:58:40 HD Request # 6 | Timestamp of first Intraday data file record written: 2014-09-08 17:58:38 | 2014-09-08 17:58:40 Socket (240) | Shutdown and closed. | 2014-09-08 17:58:40 The network socket for historical data has been closed. | 2014-09-08 17:58:40 SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 3 | 2014-09-08 17:58:40 SC Market Stats | Connecting to the server ds4.sierracharts.com. Port 443 | 2014-09-08 17:58:40 HD Request # 6 | Received 2 records from 2014-09-08 17:58:37 to 2014-09-08 17:58:38 (1.0 seconds) and wrote 1 record for TICK-NYSE | 2014-09-08 17:58:41 HD Request # 6 | Intraday download COMPLETE for TICK-NYSE. Completion time: 3s | 2014-09-08 17:58:42 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-09-08 17:58:42 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-09-08 17:58:42 HD Request # 7 | Downloading Intraday chart data for ES-201409-CME to the file ES-201409-CME.scid. Service: cme | 2014-09-08 17:58:42 HD Request # 7 | Download start Date-Time: 2014-09-08 17:57:58.0 | 2014-09-08 17:58:42 HD Request # 7 | Using server: scdf2.sierracharts.com port 10149 | 2014-09-08 17:58:42 Socket (1408) | Connected. | 2014-09-08 17:58:42 SC Market Stats | Connected to server. | 2014-09-08 17:58:42 SC Market Stats | Sending logon request message. | 2014-09-08 17:58:42 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-09-08 17:58:42 Socket (1348) | Connected. | 2014-09-08 17:58:42 HD Request # 7 | Sending historical data logon request message. | 2014-09-08 17:58:42 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:57:58. Record interval: 0. Symbol: ESU4 | 2014-09-08 17:58:42 HD Request # 7 | Decompressing data. | 2014-09-08 17:58:42 HD Request # 7 | Receiving Intraday data for ES-201409-CME starting at 2014-09-08 17:57:58 | 2014-09-08 17:58:42 HD Request # 7 | Timestamp of first Intraday data file record written: 2014-09-08 17:58:04 | 2014-09-08 17:58:42 Socket (1348) | Shutdown and closed. | 2014-09-08 17:58:42 The network socket for historical data has been closed. | 2014-09-08 17:58:42 HD Request # 7 | Received 216 records from 2014-09-08 17:57:58 to 2014-09-08 17:58:40 (42.0 seconds) and wrote 214 records for ES-201409-CME | 2014-09-08 17:58:43 HD Request # 7 | Intraday download COMPLETE for ES-201409-CME. Completion time: 1s | 2014-09-08 17:58:43 Real-time Intraday chart data file updates started for ES-201409-CME | 2014-09-08 17:58:43 HD Request # 8 | Downloading Intraday chart data for NQ-201409-CME to the file NQ-201409-CME.scid. Service: cme | 2014-09-08 17:58:43 HD Request # 8 | Failed to open the file C:\SierraChart\Data\NQ-201409-CME.scid. Error: Windows error code 32: Proces nemá přístup k souboru, neboť jej právě využívá jiný proces. Failed to open the Intraday data file for download. | 2014-09-08 17:58:43 HD Request # 8 | Error downloading historical Intraday data for NQ-201409-CME. Not downloading any Intraday data for symbol NQ-201409-CME. | 2014-09-08 17:58:43 * HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201409-CME | 2014-09-08 17:58:43 HD Request # 8 | Error opening Intraday data files to add Time and Sales records. Failed to open the file C:\SierraChart\Data\NQ-201409-CME.scid for adding records. Error: Windows error code 32: Proces nemá přístup k souboru, neboť jej právě využívá jiný proces. | 2014-09-08 17:58:43 * HD Request # 8 | Intraday download COMPLETE for NQ-201409-CME. Completion time: 0s | 2014-09-08 17:58:43 Real-time Intraday chart data file updates started for NQ-201409-CME | 2014-09-08 17:58:43 SC Market Stats | Server Info - Server Name: . | 2014-09-08 17:58:43 SC Market Stats | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-08 17:58:43 SC Market Stats | Successfully connected. | 2014-09-08 17:58:43 Intraday data recording state for symbol TICK-NYSE is set to pending. | 2014-09-08 17:58:43 SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2014-09-08 17:58:43 HD Request # 9 | Downloading Intraday chart data for YM-201409-CBOT to the file YM-201409-CBOT.scid. Service: cbot | 2014-09-08 17:58:43 HD Request # 9 | Download start Date-Time: 2014-09-08 17:54:45.0 | 2014-09-08 17:58:43 HD Request # 9 | Using server: scdf1.sierracharts.com port 10149 | 2014-09-08 17:58:43 Requesting market depth updates for: NQ-201409-CME if supported. | 2014-09-08 17:58:43 Requesting market depth updates for: YM-201409-CBOT if supported. | 2014-09-08 17:58:43 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-09-08 17:58:44 Socket (1456) | Connected. | 2014-09-08 17:58:44 HD Request # 9 | Sending historical data logon request message. | 2014-09-08 17:58:44 Mapping YM-201409-CME to YMU4. Service code: cbot | 2014-09-08 17:58:44 SC Exchange Data | Starting real-time market data updates for: YMU4. ID: 5 | 2014-09-08 17:58:44 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:54:45. Record interval: 0. Symbol: YMU4 | 2014-09-08 17:58:44 HD Request # 9 | Decompressing data. | 2014-09-08 17:58:44 HD Request # 9 | Receiving Intraday data for YM-201409-CBOT starting at 2014-09-08 17:54:45 | 2014-09-08 17:58:44 HD Request # 9 | Timestamp of first Intraday data file record written: 2014-09-08 17:54:46 | 2014-09-08 17:58:44 Socket (1456) | Shutdown and closed. | 2014-09-08 17:58:44 The network socket for historical data has been closed. | 2014-09-08 17:58:44 HD Request # 9 | Received 352 records from 2014-09-08 17:54:45 to 2014-09-08 17:58:39 (3.9 minutes) and wrote 344 records for YM-201409-CBOT | 2014-09-08 17:58:44 HD Request # 9 | Intraday download COMPLETE for YM-201409-CBOT. Completion time: 2s | 2014-09-08 17:58:45 Real-time Intraday chart data file updates started for YM-201409-CBOT | 2014-09-08 17:58:45 HD Request # 10 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-09-08 17:58:45 HD Request # 10 | Download start Date-Time: 2014-09-08 17:58:38.0 | 2014-09-08 17:58:45 HD Request # 10 | Using server: ds5.sierracharts.com port 10149 | 2014-09-08 17:58:45 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-09-08 17:58:45 Socket (1348) | Connected. | 2014-09-08 17:58:45 HD Request # 10 | Sending historical data logon request message. | 2014-09-08 17:58:45 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:58:38. Record interval: 0. Symbol: TICK-NYSE | 2014-09-08 17:58:45 HD Request # 5 | Receiving historical Daily data for YMU14 starting at 2014-09-04 | 2014-09-08 17:58:46 Writing historical Daily data for YMU14 to the file YMU14.dly | 2014-09-08 17:58:46 HD Request # 5 | Received 3 records from 2014-09-04 00:00:00 to 2014-09-08 00:00:00 (5.0 days) and wrote 2 records for YMU14 | 2014-09-08 17:58:46 HD Request # 5 | Daily download COMPLETE for YMU14. Completion time: 9s | 2014-09-08 17:58:46 Date rule based rollover from YMU11 to next contract occurs at 2011-09-08. | 2014-09-08 17:58:46 Date rule based rollover from YMZ11 to next contract occurs at 2011-12-08. | 2014-09-08 17:58:46 Date rule based rollover from YMH12 to next contract occurs at 2012-03-08. | 2014-09-08 17:58:46 Date rule based rollover from YMM12 to next contract occurs at 2012-06-07. | 2014-09-08 17:58:46 Date rule based rollover from YMU12 to next contract occurs at 2012-09-13. | 2014-09-08 17:58:46 Date rule based rollover from YMZ12 to next contract occurs at 2012-12-13. | 2014-09-08 17:58:46 Date rule based rollover from YMH13 to next contract occurs at 2013-03-07. | 2014-09-08 17:58:46 Date rule based rollover from YMM13 to next contract occurs at 2013-06-13. | 2014-09-08 17:58:46 Date rule based rollover from YMU13 to next contract occurs at 2013-09-12. | 2014-09-08 17:58:46 Date rule based rollover from YMZ13 to next contract occurs at 2013-12-12. | 2014-09-08 17:58:46 Date rule based rollover from YMH14 to next contract occurs at 2014-03-13. | 2014-09-08 17:58:46 Date rule based rollover from YMM14 to next contract occurs at 2014-06-12. | 2014-09-08 17:58:46 Date rule based rollover from YMU14 to next contract occurs at 2014-09-11. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-09-08 17:58:46 HD Request # 10 | Decompressing data. | 2014-09-08 17:58:46 HD Request # 10 | Receiving Intraday data for TICK-NYSE starting at 2014-09-08 17:58:38 | 2014-09-08 17:58:46 HD Request # 10 | Timestamp of first Intraday data file record written: 2014-09-08 17:58:39 | 2014-09-08 17:58:46 Socket (1348) | Shutdown and closed. | 2014-09-08 17:58:46 The network socket for historical data has been closed. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-09-08 17:58:46 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:46 Symbols used for YMU14 continuous contract chart: | 2014-09-08 17:58:46 YMU11 | 2014-09-08 17:58:46 YMZ11 | 2014-09-08 17:58:46 YMH12 | 2014-09-08 17:58:46 YMM12 | 2014-09-08 17:58:46 YMU12 | 2014-09-08 17:58:46 YMZ12 | 2014-09-08 17:58:46 YMH13 | 2014-09-08 17:58:46 YMM13 | 2014-09-08 17:58:46 YMU13 | 2014-09-08 17:58:46 YMZ13 | 2014-09-08 17:58:46 YMH14 | 2014-09-08 17:58:46 YMM14 | 2014-09-08 17:58:46 YMU14 | 2014-09-08 17:58:46 HD Request # 10 | Received 7 records from 2014-09-08 17:58:38 to 2014-09-08 17:58:44 (6.0 seconds) and wrote 6 records for TICK-NYSE | 2014-09-08 17:58:46 HD Request # 10 | Intraday download COMPLETE for TICK-NYSE. Completion time: 2s | 2014-09-08 17:58:47 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-09-08 17:58:47 HD Request # 11 | Downloading Historical Daily chart data for NQU14. Starting date: 2014-09-05. Service: ttamp | 2014-09-08 17:58:47 HD Request # 11 | Using user Barchart Historical data account. | 2014-09-08 17:58:47 HD Request # 11 | Requesting historical Daily data for NQU14 starting at 2014-09-04 | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: Download is complete for all contract months in chart. Proceeding with data load. | 2014-09-08 17:58:47 Volume based rollover from YMU11 to YMZ11 occurs at 2011-09-09 | 2014-09-08 17:58:47 Volume based rollover from YMZ11 to YMH12 occurs at 2011-12-09 | 2014-09-08 17:58:47 Volume based rollover from YMH12 to YMM12 occurs at 2012-03-09 | 2014-09-08 17:58:47 Volume based rollover from YMM12 to YMU12 occurs at 2012-06-08 | 2014-09-08 17:58:47 Volume based rollover from YMU12 to YMZ12 occurs at 2012-09-14 | 2014-09-08 17:58:47 Volume based rollover from YMZ12 to YMH13 occurs at 2012-12-14 | 2014-09-08 17:58:47 Volume based rollover from YMH13 to YMM13 occurs at 2013-03-08 | 2014-09-08 17:58:47 Volume based rollover from YMM13 to YMU13 occurs at 2013-06-14 | 2014-09-08 17:58:47 Volume based rollover from YMU13 to YMZ13 occurs at 2013-09-13 | 2014-09-08 17:58:47 Volume based rollover from YMZ13 to YMH14 occurs at 2013-12-13 | 2014-09-08 17:58:47 Volume based rollover from YMH14 to YMM14 occurs at 2014-03-14 | 2014-09-08 17:58:47 Volume based rollover from YMM14 to YMU14 occurs at 2014-06-13 | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU11 Open price on 2011-09-09 is 11297. | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ11 Open price on 2011-09-09 is 11228. | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU11 price difference to YMZ11 is -69. | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ11 Open price on 2011-12-09 is 12008. | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH12 Open price on 2011-12-09 is 11934. | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ11 price difference to YMH12 is -74. | 2014-09-08 17:58:47 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH12 Open price on 2012-03-09 is 12908. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM12 Open price on 2012-03-09 is 12843. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH12 price difference to YMM12 is -65. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM12 Open price on 2012-06-08 is 12475. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU12 Open price on 2012-06-08 is 12403. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM12 price difference to YMU12 is -72. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU12 Open price on 2012-09-14 is 13513. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ12 Open price on 2012-09-14 is 13444. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU12 price difference to YMZ12 is -69. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ12 Open price on 2012-12-14 is 13157. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH13 Open price on 2012-12-14 is 13091. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ12 price difference to YMH13 is -66. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH13 Open price on 2013-03-08 is 14320. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM13 Open price on 2013-03-08 is 14259. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH13 price difference to YMM13 is -61. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM13 Open price on 2013-06-14 is 15192. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU13 Open price on 2013-06-14 is 15113. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM13 price difference to YMU13 is -79. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU13 Open price on 2013-09-13 is 15316. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ13 Open price on 2013-09-13 is 15250. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU13 price difference to YMZ13 is -66. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ13 Open price on 2013-12-13 is 15738. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH14 Open price on 2013-12-13 is 15674. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMZ13 price difference to YMH14 is -64. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH14 Open price on 2014-03-14 is 16124. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM14 Open price on 2014-03-14 is 16049. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMH14 price difference to YMM14 is -75. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM14 Open price on 2014-06-13 is 16751. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMU14 Open price on 2014-06-13 is 16683. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: YMM14 price difference to YMU14 is -68. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMU11 is -828. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMZ11 is -759. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMH12 is -685. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMM12 is -620. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMU12 is -548. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMZ12 is -479. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMH13 is -413. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMM13 is -352. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMU13 is -273. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMZ13 is -207. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMH14 is -143. | 2014-09-08 17:58:48 YMU14/YM-201409-CME [CBV] [M] Daily #2: Back adjust amount for symbol YMM14 is -68. | 2014-09-08 17:58:48 HD Request # 11 | Receiving historical Daily data for NQU14 starting at 2014-09-04 | 2014-09-08 17:58:49 Writing historical Daily data for NQU14 to the file NQU14.dly | 2014-09-08 17:58:49 HD Request # 11 | Received 3 records from 2014-09-04 00:00:00 to 2014-09-08 00:00:00 (5.0 days) and wrote 2 records for NQU14 | 2014-09-08 17:58:49 HD Request # 11 | Daily download COMPLETE for NQU14. Completion time: 2s | 2014-09-08 17:58:49 Date rule based rollover from NQU11 to next contract occurs at 2011-09-08. | 2014-09-08 17:58:49 Date rule based rollover from NQZ11 to next contract occurs at 2011-12-08. | 2014-09-08 17:58:49 Date rule based rollover from NQH12 to next contract occurs at 2012-03-08. | 2014-09-08 17:58:49 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2014-09-08 17:58:49 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2014-09-08 17:58:49 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2014-09-08 17:58:49 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2014-09-08 17:58:49 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2014-09-08 17:58:49 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2014-09-08 17:58:49 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2014-09-08 17:58:49 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2014-09-08 17:58:49 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2014-09-08 17:58:49 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-09-08 17:58:49 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 0. | 2014-09-08 17:58:49 Symbols used for NQU14 continuous contract chart: | 2014-09-08 17:58:49 NQU11 | 2014-09-08 17:58:49 NQZ11 | 2014-09-08 17:58:49 NQH12 | 2014-09-08 17:58:49 NQM12 | 2014-09-08 17:58:49 NQU12 | 2014-09-08 17:58:49 NQZ12 | 2014-09-08 17:58:49 NQH13 | 2014-09-08 17:58:49 NQM13 | 2014-09-08 17:58:49 NQU13 | 2014-09-08 17:58:49 NQZ13 | 2014-09-08 17:58:49 NQH14 | 2014-09-08 17:58:49 NQM14 | 2014-09-08 17:58:49 NQU14 | 2014-09-08 17:58:49 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Download is complete for all contract months in chart. Proceeding with data load. | 2014-09-08 17:58:50 Volume based rollover from NQU11 to NQZ11 occurs at 2011-09-09 | 2014-09-08 17:58:50 Volume based rollover from NQZ11 to NQH12 occurs at 2011-12-09 | 2014-09-08 17:58:50 Volume based rollover from NQH12 to NQM12 occurs at 2012-03-09 | 2014-09-08 17:58:50 Volume based rollover from NQM12 to NQU12 occurs at 2012-06-08 | 2014-09-08 17:58:50 Volume based rollover from NQU12 to NQZ12 occurs at 2012-09-14 | 2014-09-08 17:58:50 Volume based rollover from NQZ12 to NQH13 occurs at 2012-12-14 | 2014-09-08 17:58:50 Volume based rollover from NQH13 to NQM13 occurs at 2013-03-08 | 2014-09-08 17:58:50 Volume based rollover from NQM13 to NQU13 occurs at 2013-06-14 | 2014-09-08 17:58:50 Volume based rollover from NQU13 to NQZ13 occurs at 2013-09-13 | 2014-09-08 17:58:50 Volume based rollover from NQZ13 to NQH14 occurs at 2013-12-13 | 2014-09-08 17:58:50 Volume based rollover from NQH14 to NQM14 occurs at 2014-03-14 | 2014-09-08 17:58:50 Volume based rollover from NQM14 to NQU14 occurs at 2014-06-13 | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Performing continuous futures contract back adjustment calculations. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU11 Open price on 2011-09-09 is 2216. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ11 Open price on 2011-09-09 is 2210.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU11 price difference to NQZ11 is -5.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ11 Open price on 2011-12-09 is 2284.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH12 Open price on 2011-12-09 is 2280.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ11 price difference to NQH12 is -3.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH12 Open price on 2012-03-09 is 2637.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM12 Open price on 2012-03-09 is 2634.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH12 price difference to NQM12 is -2.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM12 Open price on 2012-06-08 is 2536.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU12 Open price on 2012-06-08 is 2530. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM12 price difference to NQU12 is -6.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU12 Open price on 2012-09-14 is 2827.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ12 Open price on 2012-09-14 is 2820.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU12 price difference to NQZ12 is -7. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ12 Open price on 2012-12-14 is 2650.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH13 Open price on 2012-12-14 is 2645.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ12 price difference to NQH13 is -5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH13 Open price on 2013-03-08 is 2798.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM13 Open price on 2013-03-08 is 2794.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH13 price difference to NQM13 is -4. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM13 Open price on 2013-06-14 is 2966.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU13 Open price on 2013-06-14 is 2958. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM13 price difference to NQU13 is -8.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU13 Open price on 2013-09-13 is 3177.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ13 Open price on 2013-09-13 is 3171.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU13 price difference to NQZ13 is -5.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ13 Open price on 2013-12-13 is 3457. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH14 Open price on 2013-12-13 is 3452.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQZ13 price difference to NQH14 is -4.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH14 Open price on 2014-03-14 is 3655.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM14 Open price on 2014-03-14 is 3646.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQH14 price difference to NQM14 is -9.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM14 Open price on 2014-06-13 is 3773. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQU14 Open price on 2014-06-13 is 3766.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: NQM14 price difference to NQU14 is -6.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQU11 is -68.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQZ11 is -63. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQH12 is -59.5. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQM12 is -56.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQU12 is -50. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQZ12 is -43. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQH13 is -38. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQM13 is -34. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQU13 is -25.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQZ13 is -20.25. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQH14 is -15.75. | 2014-09-08 17:58:50 NQU14/NQ-201409-CME [CBV] [M] Daily #6: Back adjust amount for symbol NQM14 is -6.5. | 2014-09-08 17:58:50 |
[2014-09-08 16:08:38] |
User49838 - Posts: 9 |
NQ vs. YM
SC_8.9.2014.png / V - Attached On 2014-09-08 16:07:11 UTC - Size: 39.43 KB - 325 views |
[2014-09-08 16:14:37] |
We see no problem from the Message Log: Mapping YM-201409-CME to YMU4. Service code: cbot | 2014-09-08 17:58:44 Therefore, refer to help topic 3.4 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Do you see real-time data being received for this symbol according to those instructions? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-08 16:47:45] |
I have done according to topic 3.4 but still have no real time streaming data. When I close SC and then open SC, the chart YM ist loaded, but that´s all. It´s not price updating and has no market depth. I tryed all of topic 3.4. but no result... |
[2014-09-08 17:03:59] |
We need to use remote assistance to connect to your system to look into the problem. Select Help >> Accept Remote Assistance. Within about 10 seconds you will see a window that says Team Viewer. We will need the ID number. Start an Account Support Ticket here with the ID number and password: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
