Date/Time: Wed, 27 Nov 2024 12:23:58 +0000
Unable To Login
View Count: 1005
[2014-09-08 10:26:57] |
User36553 - Posts: 25 |
Dear All, I'm unable to login to Rthmic Trading Server this morning, is that anything you can help me. Cheers Michael Date Time Of Last Edit: 2014-09-08 10:27:35
MessageLog.docx - Attached On 2014-09-08 10:26:00 UTC - Size: 15.71 KB - 419 views |
[2014-09-08 10:35:03] |
We have had many reports of this. It is a Rithmic issue clearly. So we cannot help with it. You need to contact Rithmic or your broker/trading service. Also, when providing the Message Log it needs to be provided using this method only: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
