Date/Time: Thu, 31 Oct 2024 10:12:45 +0000
Control bar
View Count: 60
[2024-10-30 00:31:49]
Dennis B. - Posts: 268
SC running fine then had a pc crash. After booting back up I could only get the control bar working on one instance of SC I have 3 instances.
[2024-10-30 12:37:21]
Without a control bar I'm pretty much dead in the water. Can't make support resistances lines;etc.
[2024-10-30 15:59:03]
John - SC Support - Posts: 35639
Are you stating that you can not modify any control bar settings? Or that you can not display a Control Bar? Or something else?
If you are wanting the Global Settings (colors, control bars, keyboard shortcuts, etc.) to be all the same between instances, then you can copy the "Sierra4.config" file from the instance that is setup as you want it to the other instances. The file is located at the top level of the instance installation.
[2024-10-30 16:28:14]
Cannot display the control bar on 2 instances of SC. Click on control bar and nothing happens worked fine previously.I haven't a clue what you're talking about.
[2024-10-30 18:07:22]
Make sure the Control Bar you are wanting to display has items in it to display. Select "Global Settings >> Customize Control Bars >> Control Bar n" to select the particular Control Bar number you want.
After you have the Control Bar setup the way you want, select "Window >> Control Bars >> Control Bar n" to display the Control Bar.
[2024-10-30 20:16:16]
Tried that several times already..nothing. Working out some back ass way with the
shortcut menu. Sure miss that control bar.
[2024-10-30 21:49:09]
Are you selecting "Window >> Control Bars >> Control Bar n" or are you selecting "Window >> Control Bars - Chart >> Control Bar n"?
Are you selecting the "Window >> Control Bars.." from the main Sierra Chart window, or from a detached window?
