Date/Time: Wed, 27 Nov 2024 12:27:04 +0000
Hand Tool now has Crosshairs
View Count: 1066
[2014-09-07 05:19:20]
birdaa - Posts: 12
Since updating to version 1187, the hand tool now has crosshairs. Is this by design and if so is it possible to turn it off?
Also are the keyboard shortcuts for the TPO chart commands still happening?
Thanks alot guys.
Cheers,
Aaron
[2014-09-07 09:37:52]
The issue with the crosshairs will be resolved in the next release. For now uncheck Global Settings >> Tool Settings >> Chart Values >> Always on When Using Other Tools.
We realized keyboard shortcuts for the TPO chart commands are not possible because you have to right-click on the chart to indicate what pacific TPO Profile or TPO Profile subperiod you are referring to. So no, this will not happen because it is not possible.
[2014-09-07 11:32:25]
birdaa - Posts: 12
Would it be possible to do it with via holding shift and mouse click or something?
For example:
Shift + Left-click = Letters/Blocks in own column
Alt + Left-click = Split Profile Here
Shift + Alt + Left-click = Merge profile Right
[2014-09-07 20:48:48]
It is not likely we would add this. It is not consistent with the Sierra Chart use of the pointer and keyboard input.
