Date/Time: Fri, 27 Dec 2024 05:48:53 +0000
Consolidated Tape for US Equities (SIP Data)
View Count: 88
[2024-10-22 16:03:42]
Jupiter13 - Posts: 2
I seems to be able to manage to download data but I can't just do it for 1 day. It always goes back 6months. Is there a chartbook available with a few stocks in one chart?
[2024-10-22 19:09:10]
John - SC Support - Posts: 36873
The amount of data that is initially downloaded for a new symbol is determined by the setting for "Maximum Historical Intraday Days to Download". There are settings for 1-tick data and non-1-tick data. Refer to the following:
Data/Trade Service Settings: Maximum Historical Intraday Days to Download (Global Settings >> Data/Trade Service Settings >> Common Settings)
Regardless of the above, if you only want to view 1 day in your chart, then ensure that the setting for "Chart >> Chart Settings >> Data Limiting >> Days to Load for Intraday Charts" is set to 1.
After a new symbol has the data initially downloaded, then that full amount of data will show in your chart regardless of your Days to Load. You then just need to force a recalculation to get the 1 day to show. You can do this by selecting "Chart >> Recalculate".
We do not have a chartbook with a few stocks in it. We are not really sure what you are looking for from this.
