Date/Time: Fri, 22 Nov 2024 06:43:13 +0000
our account has been tagged as a Professional. If this is not valid...
View Count: 118
[2024-10-19 01:07:14] |
User175867 - Posts: 1 |
I am not a Professional Trader, please could you adjust this please so I can renew , I have done an account support Ticket, but I have had no reply for more than 2 days. Also could you specify If a Topstep account can have real time futures CME DATA. I had this for some time during my trading combine. So I don't know what has changed. I understand the problem may be on Topstep's side. My Real Time data was working before then it stopped, but I believe this may be on Topsteps side. Could you make clear the situation for me please? Also I have set up a Stage 5 account just in case |
Attachment Deleted. Private File |
[2024-10-20 01:15:51] |
John - SC Support - Posts: 36203 |
To start with, in order to get the CME Group data at the non-professional rates, you need to have a live, funded, futures trading account, and Prop Firms, such as TopStep, do not count towards this requirement. You also need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following for more on this: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges When you filled out the agreements for the CME Group data, you did not specify a "Clearing Firm" or an "Account Number". As such, we could not process those agreements as a non-professional. Since you state that you have an account with Stage 5, you will need to redo the agreements at the following link and enter your "Clearing Firm" and your account number. If you do not know your Clearing Firm, then enter "Stage 5". https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements Once you have the above done and we process the agreements, then you will be able to activate (and pay for) the CME Group exchange(s) for which you want real-time data at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges -- The Account Support Ticket you referenced was responded to on the same day. We do not see any Account Support Tickets that have not been responded to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
