Date/Time: Fri, 22 Nov 2024 11:26:34 +0000
Menu Issues
View Count: 79
[2024-10-14 10:22:37] |
ImKamil - Posts: 5 |
Hi SC, I have an issue with my menus in SC. When I right Click on the chart my options (Commands) arent showing in the menu Also none of the short cuts work for drawing tools. I have tried updating to the latest version but it made it even worst so had to restore it to the previous version. |
Screenshot 2024-10-14 112037.png / V - Attached On 2024-10-14 10:21:52 UTC - Size: 36.36 KB - 27 views Attachment Deleted. |
[2024-10-14 12:03:36] |
Sierra_Chart Engineering - Posts: 17143 |
You definitely do need to update Sierra Chart to the current version. Instructions: Software Download: Fast Update And if there are any further issues, then set the menu commands with this command: Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu) This issue is the result of going to a newer version and then back to an older version. Although you do need to go to the current version and then reset the Chart Shortcut Menu, if there still is this issue on the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-14 12:04:22
