Date/Time: Fri, 18 Apr 2025 06:47:26 +0000
Customize Menu Item Name Stopped working
View Count: 536
[2024-10-10 13:22:44] |
user_xyz - Posts: 464 |
Global Settings > Customize Menu Items > Main Menu > Custom Menu Item Name assigning a new value isn't registering. |
[2024-10-10 15:34:03] |
John - SC Support - Posts: 39353 |
We just tested this on the latest release (v 2691) and we are not seeing a problem. Make sure you are on the latest release. There were some issues with menu items in previous releases that might have affected this as well. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-10 15:53:30] |
I'm on 2691 Assigning this doesn't register in the menu still shows Charts |
Attachment Deleted. |
[2024-10-12 10:27:02] |
I've tested this up to pre-release 2694 and it still doesn't work. I've rolled back to stable version 2678 and this functions as expected. Site Note: Versions 2678 and prior kept my color scheme in the Menu bar along with being able to Customize Menu Bar. The newer versions up to 2694 Customize Menu Bar isn't working and color scheme is default grey. Date Time Of Last Edit: 2024-10-12 10:32:32
[2024-10-12 23:12:09] |
Sierra_Chart Engineering - Posts: 19259 |
We are still working on a solution to be able to change the top level menu item names. Regarding this: Site Note: Versions 2678 and prior kept my color scheme in the Menu bar along with being able to Customize Menu Bar. The newer versions up to 2694 Customize Menu Bar isn't working and color scheme is default grey. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-13 12:03:09] |
The color comment was more for reference that whatever changes you all are working on has that impact too (at the os level) Note - if I rollback to 2678, make the changes in Top Level Menu items and then install current version the changes stick. Date Time Of Last Edit: 2024-10-13 12:03:42
[2024-10-13 17:26:36] |
We are not understanding the issue with menu colors. The menu colors is controlled by the operating system. Sierra Chart has absolutely no control over that at all. And it is not being changed by Sierra Chart. There is no color specification even being given to the operating system and we would not even know how to do that. We notice no issue at all with menu colors. The menu colors set by the operating system remain. We are aware of the issue, not being able to customize a top level menu name. That will be resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-13 17:27:26
[2025-03-23 15:35:06] |
Previous versions of Sierra Chart displayed and allowed changing the top level Help item name. This has been removed in last few releases, can you add this back?
[2025-03-23 22:23:11] |
We are checking.
