Date/Time: Fri, 22 Nov 2024 10:49:46 +0000
Migrated a chartbook from one PC to another issue
View Count: 110
[2024-10-08 15:32:35] |
User518718 - Posts: 5 |
Hi, I have migrated a chartbook from PC to another. It only loads if I translate symbols to current service. How do I fix it that it automatically is loading correctly? Please see message log below 2024-10-08 15:42:33.479 | Trade activity files set size: 68 2024-10-08 15:42:33.587 | Created the DTC Protocol server. 2024-10-08 15:42:33.591 | DTC Protocol Server listening on port 11111. 2024-10-08 15:42:33.591 | Reading Internal Order ID file. 2024-10-08 15:42:33.644 | Reading Trade Orders file. 2024-10-08 15:42:33.644 | Reading Trade Positions file. 2024-10-08 15:42:33.644 | Reading Trade Account Data files. 2024-10-08 15:42:33.648 | Software version: 2621 64-bit 2024-10-08 15:42:33.648 | Primary Thread ID: 6960 2024-10-08 15:42:33.648 | Usage end date: 2024-10-25 2024-10-08 15:42:33.648 | Enabled for: Advanced Features 2. 2024-10-08 15:42:33.648 | Enabled for: Sierra Chart Historical Data Service. 2024-10-08 15:42:33.648 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-10-08 15:42:33.648 | Enabled for: Delayed Denali Exchange Data Feed. 2024-10-08 15:42:33.648 | Enabled for exchange2: CME (Trading Account Required) 2024-10-08 15:42:33.648 | Enabled for exchange2: CBOT (Trading Account Required) 2024-10-08 15:42:33.648 | Enabled for exchange2: COMEX (Trading Account Required) 2024-10-08 15:42:33.648 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-10-08 15:42:33.648 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-10-08 15:42:33.648 | Current selected Data/Trading service: DTC - Sub Instance 2024-10-08 15:42:33.648 | Custom symbol settings values: enabled 2024-10-08 15:42:33.648 | Chart Update Interval: 400 2024-10-08 15:42:33.648 | Intraday Data Storage Time Unit: 0 2024-10-08 15:42:33.648 | Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) 2024-10-08 15:42:33.648 | 2024-10-08 14:42:33 Local computer time in UTC 2024-10-08 15:42:33.648 | 2024-10-08 15:42:33 Local computer time in SC Time Zone 2024-10-08 15:42:33.648 | 2024-10-08 14:42:30 Server time in UTC 2024-10-08 15:42:33.648 | Local computer UTC time and Server UTC time difference: 3 seconds. 2024-10-08 15:42:33.648 | Program path: C:\Sierra\SierraChartInstance_2\ 2024-10-08 15:42:33.648 | Data Files path: C:\Sierra\SierraChartInstance_2\Data\ 2024-10-08 15:42:33.648 | OS Version Number: 10.0 2024-10-08 15:42:33.649 | Locale Setting: C 2024-10-08 15:42:33.649 | Allowed protected custom studies: 2024-10-08 15:42:33.649 | Crash reporter started: true 2024-10-08 15:42:33.649 | 2024-10-08 15:42:33.649 | Created the DTC Protocol historical data server. 2024-10-08 15:42:33.653 | HD Server Manager | Listening on port 11110. 2024-10-08 15:42:33.702 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-10-08 15:42:33.765 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-10-08 15:42:33.765 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-10-08 15:42:33.870 | Received 5 login tokens. 2024-10-08 15:42:36.158 | Requested user files to download. 2024-10-08 15:42:38.153 | 2024-10-08 15:42:38.161 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-10-08 15:42:38.162 | DTC Client socket (1) | Creating socket. 2024-10-08 15:42:38.162 | DTC Client socket (1) | New receive buffer size: 0 2024-10-08 15:42:38.162 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-10-08 15:42:38.169 | DTC - Sub Instance | Network connection to server complete. 2024-10-08 15:42:38.169 | DTC - Sub Instance | Starting socket receive thread. 2024-10-08 15:42:38.169 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-10-08 15:42:38.181 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-10-08 15:42:38.181 | DTC - Sub Instance | Sending logon request message. 2024-10-08 15:42:38.181 | DTC - Sub Instance | Received logon response. 2024-10-08 15:42:38.181 | DTC - Sub Instance | Server Name: SC DTC Server. Build=49642. 2024-10-08 15:42:38.181 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-10-08 15:42:38.181 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading. 2024-10-08 15:42:38.181 | DTC - Sub Instance | Trading is supported. 2024-10-08 15:42:38.181 | DTC - Sub Instance | Order cancel and replace is supported. 2024-10-08 15:42:38.181 | DTC - Sub Instance | OCO Orders supported. 2024-10-08 15:42:38.181 | DTC - Sub Instance | Bracket Orders supported. 2024-10-08 15:42:38.181 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-10-08 15:42:38.181 | DTC - Sub Instance | Connected to server complete. 2024-10-08 15:42:38.182 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-10-08 15:42:41.396 | Files to Open on Startup | Opening file: TPO.Cht 2024-10-08 15:42:41.421 | Searching for files containing UserContributedStudies returned empty result. * 2024-10-08 15:42:41.421 | Error loading: C:\Sierra\SierraChartInstance_2\Data\UserContributedStudies.dll. File not found or may be missing SCDLLName line. 2024-10-08 15:42:41.485 | HGZ24_FUT_CME [CV] Daily #3 | Reloading chart. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGN22_FUT_CME.dly, HGU22_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGU22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGU22_FUT_CME.dly, HGZ22_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGZ22_FUT_CME.dly, HGH23_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGH23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGH23_FUT_CME.dly, HGK23_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGK23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGK23_FUT_CME.dly, HGN23_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGN23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGN23_FUT_CME.dly, HGU23_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGU23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGU23_FUT_CME.dly, HGZ23_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.163 | Unable to determine transition date based on volume from files: HGZ23_FUT_CME.dly, HGH24_FUT_CME.dly 2024-10-08 15:42:43.163 | The HGH24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.164 | Unable to determine transition date based on volume from files: HGH24_FUT_CME.dly, HGK24_FUT_CME.dly 2024-10-08 15:42:43.164 | The HGK24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.164 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:42:43.164 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.164 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:42:43.164 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.164 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:42:43.164 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:43.210 | HGZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 15:42:43.215 | Starting DelayedDownloadMonitoringTimer 2024-10-08 15:42:43.215 | Starting HDTimeoutTimer 2024-10-08 15:42:43.215 | Added historical Intraday data request for HGZ24_FUT_CME to the queue. 2024-10-08 15:42:43.223 | Triggering next historical data download in queue. 2024-10-08 15:42:43.228 | HGZ24_FUT_CME [CBV] 60 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2024-10-08 15:42:43.248 | HGZ24_FUT_CME [CBV] #6 | Reloading chart. 2024-10-08 15:42:43.258 | Added historical Intraday data request for HGH13_FUT_CME to the queue. 2024-10-08 15:42:43.259 | Added historical Intraday data request for HGK13_FUT_CME to the queue. 2024-10-08 15:42:43.260 | Added historical Intraday data request for HGN13_FUT_CME to the queue. 2024-10-08 15:42:43.262 | Added historical Intraday data request for HGU13_FUT_CME to the queue. 2024-10-08 15:42:43.263 | Added historical Intraday data request for HGZ13_FUT_CME to the queue. 2024-10-08 15:42:43.265 | Added historical Intraday data request for HGH14_FUT_CME to the queue. 2024-10-08 15:42:43.266 | Added historical Intraday data request for HGK14_FUT_CME to the queue. 2024-10-08 15:42:43.267 | Added historical Intraday data request for HGN14_FUT_CME to the queue. 2024-10-08 15:42:43.269 | Added historical Intraday data request for HGU14_FUT_CME to the queue. 2024-10-08 15:42:43.270 | Added historical Intraday data request for HGZ14_FUT_CME to the queue. 2024-10-08 15:42:43.273 | Added historical Intraday data request for HGH15_FUT_CME to the queue. 2024-10-08 15:42:43.274 | Added historical Intraday data request for HGK15_FUT_CME to the queue. 2024-10-08 15:42:43.276 | Added historical Intraday data request for HGN15_FUT_CME to the queue. 2024-10-08 15:42:43.277 | Added historical Intraday data request for HGU15_FUT_CME to the queue. 2024-10-08 15:42:43.278 | Added historical Intraday data request for HGZ15_FUT_CME to the queue. 2024-10-08 15:42:43.280 | Added historical Intraday data request for HGH16_FUT_CME to the queue. 2024-10-08 15:42:43.281 | Added historical Intraday data request for HGK16_FUT_CME to the queue. 2024-10-08 15:42:43.283 | Added historical Intraday data request for HGN16_FUT_CME to the queue. 2024-10-08 15:42:43.284 | Added historical Intraday data request for HGU16_FUT_CME to the queue. 2024-10-08 15:42:43.286 | Added historical Intraday data request for HGZ16_FUT_CME to the queue. 2024-10-08 15:42:43.288 | Added historical Intraday data request for HGH17_FUT_CME to the queue. 2024-10-08 15:42:43.289 | Added historical Intraday data request for HGK17_FUT_CME to the queue. 2024-10-08 15:42:43.290 | Added historical Intraday data request for HGN17_FUT_CME to the queue. 2024-10-08 15:42:43.292 | Added historical Intraday data request for HGU17_FUT_CME to the queue. 2024-10-08 15:42:43.293 | Added historical Intraday data request for HGZ17_FUT_CME to the queue. 2024-10-08 15:42:43.295 | Added historical Intraday data request for HGH18_FUT_CME to the queue. 2024-10-08 15:42:43.296 | Added historical Intraday data request for HGK18_FUT_CME to the queue. 2024-10-08 15:42:43.297 | Added historical Intraday data request for HGN18_FUT_CME to the queue. 2024-10-08 15:42:43.299 | Added historical Intraday data request for HGU18_FUT_CME to the queue. 2024-10-08 15:42:43.300 | Added historical Intraday data request for HGZ18_FUT_CME to the queue. 2024-10-08 15:42:43.301 | Added historical Intraday data request for HGH19_FUT_CME to the queue. 2024-10-08 15:42:43.304 | Added historical Intraday data request for HGK19_FUT_CME to the queue. 2024-10-08 15:42:43.306 | Added historical Intraday data request for HGN19_FUT_CME to the queue. 2024-10-08 15:42:43.308 | Added historical Intraday data request for HGU19_FUT_CME to the queue. 2024-10-08 15:42:43.310 | Added historical Intraday data request for HGZ19_FUT_CME to the queue. 2024-10-08 15:42:43.312 | Added historical Intraday data request for HGH20_FUT_CME to the queue. 2024-10-08 15:42:43.314 | Added historical Intraday data request for HGK20_FUT_CME to the queue. 2024-10-08 15:42:43.316 | Added historical Intraday data request for HGN20_FUT_CME to the queue. 2024-10-08 15:42:43.318 | Added historical Intraday data request for HGU20_FUT_CME to the queue. 2024-10-08 15:42:43.329 | Added historical Intraday data request for HGK22_FUT_CME to the queue. 2024-10-08 15:42:43.331 | Added historical Intraday data request for HGN22_FUT_CME to the queue. 2024-10-08 15:42:43.332 | Added historical Intraday data request for HGU22_FUT_CME to the queue. 2024-10-08 15:42:43.333 | Added historical Intraday data request for HGZ22_FUT_CME to the queue. 2024-10-08 15:42:43.335 | Added historical Intraday data request for HGH23_FUT_CME to the queue. 2024-10-08 15:42:43.337 | Added historical Intraday data request for HGK23_FUT_CME to the queue. 2024-10-08 15:42:43.338 | Added historical Intraday data request for HGN23_FUT_CME to the queue. 2024-10-08 15:42:43.339 | Added historical Intraday data request for HGU23_FUT_CME to the queue. 2024-10-08 15:42:43.341 | Added historical Intraday data request for HGZ23_FUT_CME to the queue. 2024-10-08 15:42:43.342 | Added historical Intraday data request for HGH24_FUT_CME to the queue. 2024-10-08 15:42:43.343 | Added historical Intraday data request for HGK24_FUT_CME to the queue. 2024-10-08 15:42:43.344 | Added historical Intraday data request for HGN24_FUT_CME to the queue. 2024-10-08 15:42:43.346 | Added historical Intraday data request for HGU24_FUT_CME to the queue. 2024-10-08 15:42:44.147 | HGZ24_FUT_CME [CBV] #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 2024-10-08 15:42:44.193 | HGZ24_FUT_CME [CBV] #5 | Reloading chart. 2024-10-08 15:42:44.342 | HGZ24_FUT_CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 1, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 2024-10-08 15:42:44.365 | HGZ24_FUT_CME [CV] #4 | Reloading chart. 2024-10-08 15:42:44.372 | HGZ24_FUT_CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 1, 49, 50, 51, 52, 53, 2024-10-08 15:42:44.395 | HGZ24_FUT_CME [CV] 5 Min #7 | Reloading chart. 2024-10-08 15:42:44.398 | HGZ24_FUT_CME [CV] 5 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 52, 53, 2024-10-08 15:42:44.421 | Using symbol data fast lookup vector 2024-10-08 15:42:44.421 | HD Request # 1 | Downloading Intraday chart data for HGZ24_FUT_CME to the file HGZ24_FUT_CME.scid. Service: comex 2024-10-08 15:42:44.422 | HD Request # 1 | Download start date-time: 2024-10-08 15:42:15.000000. File last date-time: 2024-10-08 15:42:15.074000 2024-10-08 15:42:44.422 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2024-10-08 15:42:44.422 | Socket (2) | Creating socket. 2024-10-08 15:42:44.422 | Socket (2) | New receive buffer size: 0 2024-10-08 15:42:44.422 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-10-08 15:42:44.450 | HGZ24_FUT_CME [CV] Daily #3 | Chart data loading complete. 2024-10-08 15:42:44.535 | DTC - Sub Instance | Starting real-time market data updates for: HGZ24_FUT_CME. ID: 1 2024-10-08 15:42:44.535 | DTC - Sub Instance | Requesting security definition data for: HGZ24_FUT_CME. ID: 1 2024-10-08 15:42:44.537 | DTC - Sub Instance | Received security definition for symbol HGZ24_FUT_CME 2024-10-08 15:42:44.915 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-10-08 15:42:44.915 | HD Request # 1 | Sending historical data logon request message. 2024-10-08 15:42:45.132 | Added historical Daily data request for HGZ24_FUT_CME to the queue. 2024-10-08 15:42:45.132 | Triggering next historical data download in queue. 2024-10-08 15:42:45.501 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-10-08 15:42:15. Record interval: 0. Symbol: HGZ24 2024-10-08 15:42:45.595 | HD Request # 1 | Decompressing data. 2024-10-08 15:42:45.683 | HD Request # 1 | Receiving Intraday data for HGZ24_FUT_CME starting at 2024-10-08 15:42:15.074000 2024-10-08 15:42:45.684 | Socket (2) | CloseSocket call. 2024-10-08 15:42:45.684 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 15:42:45.684 | Historical data download thread signaled to stop. 2024-10-08 15:42:45.684 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-10-08 15:42:16.624000. 2024-10-08 15:42:45.684 | HD Request # 1 | Received 67 Intraday data records from 2024-10-08 15:42:15.074000 to 2024-10-08 15:42:40.676005 (25.6 seconds. Delay: 5.0 seconds) and wrote 66 records for HGZ24_FUT_CME 2024-10-08 15:42:45.692 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-10-08 14:42:40.676005 2024-10-08 15:42:45.692 | HD Request # 1 | Completion time: 1s. 2024-10-08 15:42:45.692 | HD Request # 1 | Intraday data download complete for HGZ24_FUT_CME. Unique request ID: 1 2024-10-08 15:42:45.692 | Removing historical data download ID 1. 2024-10-08 15:42:45.692 | Real-time Intraday chart data file updates started for HGZ24_FUT_CME 2024-10-08 15:42:45.692 | Intraday chart data file opened for HGZ24_FUT_CME 2024-10-08 15:42:45.692 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-10-08 15:42:45.692 | 2024-10-08 15:42:45.692 | Triggering next historical data download in queue. 2024-10-08 15:42:45.692 | HD Request # 2 | Downloading Intraday chart data for HGH13_FUT_CME to the file HGH13_FUT_CME.scid. Service: comex 2024-10-08 15:42:45.692 | HD Request # 2 | Download start date-time: 2012-11-13 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:42:45.692 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149 2024-10-08 15:42:45.693 | Socket (3) | Creating socket. 2024-10-08 15:42:45.693 | Socket (3) | New receive buffer size: 0 2024-10-08 15:42:45.693 | Socket (3) | Connecting to IP: 67.214.125.3. 2024-10-08 15:42:45.771 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 15:42:45.771 | Socket (2) | Closed. 2024-10-08 15:42:45.890 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-10-08 15:42:45.890 | HD Request # 2 | Sending historical data logon request message. 2024-10-08 15:42:46.039 | HGZ24_FUT_CME [CBV] 60 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 15:42:46.040 | HGZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 15:42:46.041 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:42:46.041 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:46.042 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:42:46.042 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:46.042 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:42:46.042 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:42:46.046 | HGZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:42:46.047 | HGZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:42:46.051 | HGZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-06-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:42:46.051 | HGZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:42:46.055 | HGZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-09-01 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:42:46.055 | HGZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:42:46.445 | HGZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 15:42:46.451 | HGZ24_FUT_CME [CBV] 60 Min #2 | Waiting for historical downloads to complete with the IDs: 51, 52, 53, 54, 2024-10-08 15:42:46.487 | HD Request # 2 | Requesting Intraday data. Start date-time: 2012-11-13 00:00:00. Record interval: 0. Symbol: HGH13 2024-10-08 15:42:46.766 | HGZ24_FUT_CME [CBV] 60 Min #2 | Chart data loading complete. 2024-10-08 15:42:47.259 | HD Request # 2 | Decompressing data. 2024-10-08 15:42:47.263 | HD Request # 2 | Receiving Intraday data for HGH13_FUT_CME starting at 2012-11-13 00:13:37.000000 2024-10-08 15:42:48.179 | HD Request # 2 | Timestamp of first Intraday data file record written: 2012-11-13 00:13:37.000000. 2024-10-08 15:42:48.779 | Opened cached Intraday file: C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.scid. Thread ID: 5928 2024-10-08 15:43:29.628 | Socket (3) | CloseSocket call. 2024-10-08 15:43:29.628 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-10-08 15:43:29.628 | Historical data download thread signaled to stop. 2024-10-08 15:43:29.629 | HD Request # 2 | Received 1914941 Intraday data records from 2012-11-13 00:13:37.000000 to 2013-03-26 15:39:38.000000 (133.6 days. Delay: 11.5 years) and wrote 1914941 records for HGH13_FUT_CME 2024-10-08 15:43:29.643 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2013-03-26 15:39:38.000000 2024-10-08 15:43:29.643 | HD Request # 2 | Completion time: 44s. 2024-10-08 15:43:29.643 | HD Request # 2 | Intraday data download complete for HGH13_FUT_CME. Unique request ID: 2 2024-10-08 15:43:29.643 | Removing historical data download ID 2. 2024-10-08 15:43:29.643 | Real-time Intraday chart data file updates started for HGH13_FUT_CME 2024-10-08 15:43:29.643 | Intraday chart data file opened for HGH13_FUT_CME 2024-10-08 15:43:29.643 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-10-08 15:43:29.643 | 2024-10-08 15:43:29.643 | Triggering next historical data download in queue. 2024-10-08 15:43:29.644 | HD Request # 3 | Downloading Intraday chart data for HGK13_FUT_CME to the file HGK13_FUT_CME.scid. Service: comex 2024-10-08 15:43:29.644 | HD Request # 3 | Download start date-time: 2013-02-11 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:43:29.644 | HD Request # 3 | Using server: ds26.sierracharts.com port 10150 2024-10-08 15:43:29.663 | Socket (2) | Creating socket. 2024-10-08 15:43:29.664 | Socket (2) | New receive buffer size: 0 2024-10-08 15:43:29.664 | Socket (2) | Connecting to IP: 69.39.70.243. 2024-10-08 15:43:29.713 | Socket (3) | Socket gracefully closed by remote side. 2024-10-08 15:43:29.713 | Socket (3) | Closed. 2024-10-08 15:43:29.846 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-10-08 15:43:29.846 | HD Request # 3 | Sending historical data logon request message. 2024-10-08 15:43:30.434 | HD Request # 3 | Requesting Intraday data. Start date-time: 2013-02-11 00:00:00. Record interval: 0. Symbol: HGK13 2024-10-08 15:43:30.550 | HD Request # 3 | Decompressing data. 2024-10-08 15:43:30.743 | HD Request # 3 | Receiving Intraday data for HGK13_FUT_CME starting at 2013-02-11 00:08:26.000000 2024-10-08 15:43:30.922 | HD Request # 3 | Timestamp of first Intraday data file record written: 2013-02-11 00:08:26.000000. 2024-10-08 15:44:15.879 | Socket (2) | CloseSocket call. 2024-10-08 15:44:15.879 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 15:44:15.879 | Historical data download thread signaled to stop. 2024-10-08 15:44:15.880 | HD Request # 3 | Received 1852630 Intraday data records from 2013-02-11 00:08:26.000000 to 2013-05-29 16:40:20.000000 (107.6 days. Delay: 11.4 years) and wrote 1852630 records for HGK13_FUT_CME 2024-10-08 15:44:15.893 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2013-05-29 15:40:20.000000 2024-10-08 15:44:15.893 | HD Request # 3 | Completion time: 46s. 2024-10-08 15:44:15.893 | HD Request # 3 | Intraday data download complete for HGK13_FUT_CME. Unique request ID: 3 2024-10-08 15:44:15.893 | Removing historical data download ID 3. 2024-10-08 15:44:15.893 | Real-time Intraday chart data file updates started for HGK13_FUT_CME 2024-10-08 15:44:15.893 | Intraday chart data file opened for HGK13_FUT_CME 2024-10-08 15:44:15.893 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-10-08 15:44:15.893 | 2024-10-08 15:44:15.893 | Triggering next historical data download in queue. 2024-10-08 15:44:15.893 | HD Request # 4 | Downloading Intraday chart data for HGN13_FUT_CME to the file HGN13_FUT_CME.scid. Service: comex 2024-10-08 15:44:15.894 | HD Request # 4 | Download start date-time: 2013-04-11 01:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:44:15.894 | HD Request # 4 | Using server: ds28.sierracharts.com port 10149 2024-10-08 15:44:15.894 | Socket (3) | Creating socket. 2024-10-08 15:44:15.894 | Socket (3) | New receive buffer size: 0 2024-10-08 15:44:15.894 | Socket (3) | Connecting to IP: 67.214.125.5. 2024-10-08 15:44:15.969 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 15:44:15.969 | Socket (2) | Closed. 2024-10-08 15:44:16.075 | HD Request # 4 | Setting DTC encoding to Binary VLS 2024-10-08 15:44:16.075 | HD Request # 4 | Sending historical data logon request message. 2024-10-08 15:44:16.654 | HD Request # 4 | Requesting Intraday data. Start date-time: 2013-04-11 01:00:00. Record interval: 0. Symbol: HGN13 2024-10-08 15:44:16.742 | HD Request # 4 | Decompressing data. 2024-10-08 15:44:16.945 | HD Request # 4 | Receiving Intraday data for HGN13_FUT_CME starting at 2013-04-11 01:40:00.000000 2024-10-08 15:44:17.544 | HD Request # 4 | Timestamp of first Intraday data file record written: 2013-04-11 01:40:00.000000. 2024-10-08 15:44:18.443 | Socket (3) | CloseSocket call. 2024-10-08 15:44:18.443 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-10-08 15:44:18.444 | Historical data download thread signaled to stop. 2024-10-08 15:44:18.444 | HD Request # 4 | Received 67534 Intraday data records from 2013-04-11 01:40:00.000000 to 2013-07-29 15:41:00.000000 (109.6 days. Delay: 11.2 years) and wrote 67534 records for HGN13_FUT_CME 2024-10-08 15:44:18.457 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2013-07-29 14:41:00.000000 2024-10-08 15:44:18.457 | HD Request # 4 | Completion time: 3s. 2024-10-08 15:44:18.457 | HD Request # 4 | Intraday data download complete for HGN13_FUT_CME. Unique request ID: 4 2024-10-08 15:44:18.457 | Removing historical data download ID 4. 2024-10-08 15:44:18.457 | Real-time Intraday chart data file updates started for HGN13_FUT_CME 2024-10-08 15:44:18.457 | Intraday chart data file opened for HGN13_FUT_CME 2024-10-08 15:44:18.457 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2024-10-08 15:44:18.457 | 2024-10-08 15:44:18.457 | Triggering next historical data download in queue. 2024-10-08 15:44:18.457 | HD Request # 5 | Downloading Intraday chart data for HGU13_FUT_CME to the file HGU13_FUT_CME.scid. Service: comex 2024-10-08 15:44:18.458 | HD Request # 5 | Download start date-time: 2013-06-11 01:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:44:18.458 | HD Request # 5 | Using server: ds32.sierracharts.com port 10150 2024-10-08 15:44:18.458 | Socket (2) | Creating socket. 2024-10-08 15:44:18.459 | Socket (2) | New receive buffer size: 0 2024-10-08 15:44:18.459 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-10-08 15:44:18.529 | Socket (3) | Socket gracefully closed by remote side. 2024-10-08 15:44:18.529 | Socket (3) | Closed. 2024-10-08 15:44:18.645 | HD Request # 5 | Setting DTC encoding to Binary VLS 2024-10-08 15:44:18.645 | HD Request # 5 | Sending historical data logon request message. 2024-10-08 15:44:19.221 | HD Request # 5 | Requesting Intraday data. Start date-time: 2013-06-11 01:00:00. Record interval: 0. Symbol: HGU13 2024-10-08 15:44:19.310 | HD Request # 5 | Decompressing data. 2024-10-08 15:44:19.503 | HD Request # 5 | Receiving Intraday data for HGU13_FUT_CME starting at 2013-06-11 01:00:01.000000 2024-10-08 15:44:19.705 | HD Request # 5 | Timestamp of first Intraday data file record written: 2013-06-11 01:00:01.000000. 2024-10-08 15:44:28.916 | Socket (2) | CloseSocket call. 2024-10-08 15:44:28.916 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 15:44:28.916 | Historical data download thread signaled to stop. 2024-10-08 15:44:28.917 | HD Request # 5 | Received 1685343 Intraday data records from 2013-06-11 01:00:01.000000 to 2013-09-26 17:59:47.001000 (107.7 days. Delay: 11.0 years) and wrote 1685343 records for HGU13_FUT_CME 2024-10-08 15:44:28.931 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2013-09-26 16:59:47.001000 2024-10-08 15:44:28.932 | HD Request # 5 | Completion time: 10s. 2024-10-08 15:44:28.932 | HD Request # 5 | Intraday data download complete for HGU13_FUT_CME. Unique request ID: 5 2024-10-08 15:44:28.932 | Removing historical data download ID 5. 2024-10-08 15:44:28.932 | Real-time Intraday chart data file updates started for HGU13_FUT_CME 2024-10-08 15:44:28.932 | Intraday chart data file opened for HGU13_FUT_CME 2024-10-08 15:44:28.932 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2024-10-08 15:44:28.932 | 2024-10-08 15:44:28.932 | Triggering next historical data download in queue. 2024-10-08 15:44:28.933 | HD Request # 6 | Downloading Intraday chart data for HGZ13_FUT_CME to the file HGZ13_FUT_CME.scid. Service: comex 2024-10-08 15:44:28.933 | HD Request # 6 | Download start date-time: 2013-08-13 01:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:44:28.933 | HD Request # 6 | Using server: ds26.sierracharts.com port 10149 2024-10-08 15:44:28.934 | Socket (3) | Creating socket. 2024-10-08 15:44:28.934 | Socket (3) | New receive buffer size: 0 2024-10-08 15:44:28.934 | Socket (3) | Connecting to IP: 69.39.70.243. 2024-10-08 15:44:29.024 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 15:44:29.024 | Socket (2) | Closed. 2024-10-08 15:44:29.128 | HD Request # 6 | Setting DTC encoding to Binary VLS 2024-10-08 15:44:29.128 | HD Request # 6 | Sending historical data logon request message. 2024-10-08 15:44:29.705 | HD Request # 6 | Requesting Intraday data. Start date-time: 2013-08-13 01:00:00. Record interval: 0. Symbol: HGZ13 2024-10-08 15:44:29.807 | HD Request # 6 | Decompressing data. 2024-10-08 15:44:30.091 | HD Request # 6 | Receiving Intraday data for HGZ13_FUT_CME starting at 2013-08-13 01:00:01.000000 2024-10-08 15:44:30.878 | HD Request # 6 | Timestamp of first Intraday data file record written: 2013-08-13 01:00:01.000000. 2024-10-08 15:44:53.382 | HGZ24_FUT_CME [CBV] #1 | Reloading chart. 2024-10-08 15:44:53.556 | HGZ24_FUT_CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 2024-10-08 15:44:53.582 | HGZ24_FUT_CME [CBV] #2 | Reloading chart. 2024-10-08 15:44:53.743 | HGZ24_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 2024-10-08 15:44:53.808 | HGZ24_FUT_CME [CBV] #5 | Reloading chart. 2024-10-08 15:44:53.970 | HGZ24_FUT_CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 2024-10-08 15:45:52.497 | Socket (3) | CloseSocket call. 2024-10-08 15:45:52.498 | Historical data download thread signaled to stop. 2024-10-08 15:45:52.498 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-10-08 15:45:52.499 | HD Request # 6 | Received 2069987 Intraday data records from 2013-08-13 01:00:01.000000 to 2013-12-27 16:59:52.001000 (136.7 days. Delay: 10.8 years) and wrote 2069987 records for HGZ13_FUT_CME 2024-10-08 15:45:52.513 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2013-12-27 16:59:52.001000 2024-10-08 15:45:52.513 | HD Request # 6 | Completion time: 1m 24s. 2024-10-08 15:45:52.513 | HD Request # 6 | Intraday data download complete for HGZ13_FUT_CME. Unique request ID: 6 2024-10-08 15:45:52.513 | Removing historical data download ID 6. 2024-10-08 15:45:52.513 | Real-time Intraday chart data file updates started for HGZ13_FUT_CME 2024-10-08 15:45:52.513 | Intraday chart data file opened for HGZ13_FUT_CME 2024-10-08 15:45:52.513 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2024-10-08 15:45:52.513 | 2024-10-08 15:45:52.513 | Triggering next historical data download in queue. 2024-10-08 15:45:52.513 | HD Request # 7 | Downloading Intraday chart data for HGH14_FUT_CME to the file HGH14_FUT_CME.scid. Service: comex 2024-10-08 15:45:52.514 | HD Request # 7 | Download start date-time: 2013-11-12 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:45:52.514 | HD Request # 7 | Using server: ds28.sierracharts.com port 10150 2024-10-08 15:45:52.514 | Socket (2) | Creating socket. 2024-10-08 15:45:52.514 | Socket (2) | New receive buffer size: 0 2024-10-08 15:45:52.514 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-10-08 15:45:52.589 | Socket (3) | Socket gracefully closed by remote side. 2024-10-08 15:45:52.590 | Socket (3) | Closed. 2024-10-08 15:45:52.708 | HD Request # 7 | Setting DTC encoding to Binary VLS 2024-10-08 15:45:52.708 | HD Request # 7 | Sending historical data logon request message. 2024-10-08 15:45:53.282 | HD Request # 7 | Requesting Intraday data. Start date-time: 2013-11-12 00:00:00. Record interval: 0. Symbol: HGH14 2024-10-08 15:45:53.371 | HD Request # 7 | Decompressing data. 2024-10-08 15:45:53.753 | HD Request # 7 | Receiving Intraday data for HGH14_FUT_CME starting at 2013-11-12 00:01:01.000000 2024-10-08 15:45:54.235 | HD Request # 7 | Timestamp of first Intraday data file record written: 2013-11-12 00:01:01.000000. 2024-10-08 15:47:00.464 | Socket (2) | CloseSocket call. 2024-10-08 15:47:00.464 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 15:47:00.464 | Historical data download thread signaled to stop. 2024-10-08 15:47:00.465 | HD Request # 7 | Received 1702627 Intraday data records from 2013-11-12 00:01:01.000000 to 2014-03-27 16:59:57.002000 (135.7 days. Delay: 10.5 years) and wrote 1702627 records for HGH14_FUT_CME 2024-10-08 15:47:00.474 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2014-03-27 16:59:57.002000 2024-10-08 15:47:00.474 | HD Request # 7 | Completion time: 1m 8s. 2024-10-08 15:47:00.474 | HD Request # 7 | Intraday data download complete for HGH14_FUT_CME. Unique request ID: 7 2024-10-08 15:47:00.474 | Removing historical data download ID 7. 2024-10-08 15:47:00.474 | Real-time Intraday chart data file updates started for HGH14_FUT_CME 2024-10-08 15:47:00.474 | Intraday chart data file opened for HGH14_FUT_CME 2024-10-08 15:47:00.474 | HD Request # 7 | Enabling Intraday chart updating for symbol. 2024-10-08 15:47:00.474 | 2024-10-08 15:47:00.474 | Triggering next historical data download in queue. 2024-10-08 15:47:00.475 | HD Request # 8 | Downloading Intraday chart data for HGK14_FUT_CME to the file HGK14_FUT_CME.scid. Service: comex 2024-10-08 15:47:00.475 | HD Request # 8 | Download start date-time: 2014-02-11 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:47:00.475 | HD Request # 8 | Using server: ds32.sierracharts.com port 10149 2024-10-08 15:47:00.475 | Socket (3) | Creating socket. 2024-10-08 15:47:00.475 | Socket (3) | New receive buffer size: 0 2024-10-08 15:47:00.475 | Socket (3) | Connecting to IP: 67.214.125.3. 2024-10-08 15:47:00.556 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 15:47:00.556 | Socket (2) | Closed. 2024-10-08 15:47:21.519 | Socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2024-10-08 15:47:21.519 | Socket (3) | CloseSocket call. 2024-10-08 15:47:21.519 | Socket (0) | CloseSocket call. 2024-10-08 15:47:21.519 | Socket (3) | Closed. 2024-10-08 15:47:21.519 | HD Request # 8 | Error downloading historical Intraday data for HGK14_FUT_CME. The network socket has been closed. Retrying download. 2024-10-08 15:47:21.519 | Added historical Intraday data request for HGK14_FUT_CME to the queue. 2024-10-08 15:47:21.519 | Triggering next historical data download in queue. 2024-10-08 15:47:21.519 | Historical data download thread signaled to stop. 2024-10-08 15:47:21.519 | HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for HGK14_FUT_CME 2024-10-08 15:47:21.520 | HD Request # 8 | Completion time: 21s. 2024-10-08 15:47:21.520 | 2024-10-08 15:47:21.520 | HD Request # 9 | Downloading Intraday chart data for HGK14_FUT_CME to the file HGK14_FUT_CME.scid. Service: comex 2024-10-08 15:47:21.520 | HD Request # 9 | Download start date-time: 2014-02-11 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:47:21.521 | HD Request # 9 | Using server: ds26.sierracharts.com port 10150 2024-10-08 15:47:21.521 | Socket (2) | Creating socket. 2024-10-08 15:47:21.521 | Socket (2) | New receive buffer size: 0 2024-10-08 15:47:21.521 | Socket (2) | Connecting to IP: 69.39.70.243. 2024-10-08 15:47:21.704 | HD Request # 9 | Setting DTC encoding to Binary VLS 2024-10-08 15:47:21.704 | HD Request # 9 | Sending historical data logon request message. 2024-10-08 15:47:22.279 | HD Request # 9 | Requesting Intraday data. Start date-time: 2014-02-11 00:00:00. Record interval: 0. Symbol: HGK14 2024-10-08 15:47:22.371 | HD Request # 9 | Decompressing data. 2024-10-08 15:47:22.478 | HD Request # 9 | Receiving Intraday data for HGK14_FUT_CME starting at 2014-02-11 00:34:18.000000 2024-10-08 15:47:22.883 | HD Request # 9 | Timestamp of first Intraday data file record written: 2014-02-11 00:34:18.000000. 2024-10-08 15:47:36.880 | Socket (2) | CloseSocket call. 2024-10-08 15:47:36.880 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 15:47:36.880 | Historical data download thread signaled to stop. 2024-10-08 15:47:36.880 | HD Request # 9 | Received 1484395 Intraday data records from 2014-02-11 00:34:18.000000 to 2014-05-28 16:52:08.012000 (106.6 days. Delay: 10.4 years) and wrote 1484395 records for HGK14_FUT_CME 2024-10-08 15:47:36.889 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2014-05-28 15:52:08.012000 2024-10-08 15:47:36.889 | HD Request # 9 | Completion time: 15s. 2024-10-08 15:47:36.889 | HD Request # 9 | Intraday data download complete for HGK14_FUT_CME. Unique request ID: 8 2024-10-08 15:47:36.889 | Removing historical data download ID 8. 2024-10-08 15:47:36.889 | Real-time Intraday chart data file updates started for HGK14_FUT_CME 2024-10-08 15:47:36.889 | Intraday chart data file opened for HGK14_FUT_CME 2024-10-08 15:47:36.889 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2024-10-08 15:47:36.889 | 2024-10-08 15:47:36.889 | Triggering next historical data download in queue. 2024-10-08 15:47:36.889 | HD Request # 10 | Downloading Intraday chart data for HGN14_FUT_CME to the file HGN14_FUT_CME.scid. Service: comex 2024-10-08 15:47:36.889 | HD Request # 10 | Download start date-time: 2014-04-11 01:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:47:36.889 | HD Request # 10 | Using server: ds28.sierracharts.com port 10149 2024-10-08 15:47:36.889 | Socket (3) | Creating socket. 2024-10-08 15:47:36.889 | Socket (3) | New receive buffer size: 0 2024-10-08 15:47:36.889 | Socket (3) | Connecting to IP: 67.214.125.5. 2024-10-08 15:47:36.969 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 15:47:36.969 | Socket (2) | Closed. 2024-10-08 15:47:37.075 | HD Request # 10 | Setting DTC encoding to Binary VLS 2024-10-08 15:47:37.075 | HD Request # 10 | Sending historical data logon request message. 2024-10-08 15:47:37.649 | HD Request # 10 | Requesting Intraday data. Start date-time: 2014-04-11 01:00:00. Record interval: 0. Symbol: HGN14 2024-10-08 15:47:37.739 | HD Request # 10 | Decompressing data. 2024-10-08 15:47:37.933 | HD Request # 10 | Receiving Intraday data for HGN14_FUT_CME starting at 2014-04-11 01:01:05.000000 2024-10-08 15:47:38.124 | HD Request # 10 | Timestamp of first Intraday data file record written: 2014-04-11 01:01:05.000000. 2024-10-08 15:47:44.993 | Saved Chartbook: TPO.Cht. Time: 0.0077 seconds. 2024-10-08 15:47:45.340 | Socket (3) | CloseSocket call. 2024-10-08 15:47:45.340 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-10-08 15:47:45.340 | Historical data download thread signaled to stop. 2024-10-08 15:47:45.377 | HD Request # 10 | Received 1172665 Intraday data records from 2014-04-11 01:01:05.000000 to 2014-07-29 17:38:20.000000 (109.7 days. Delay: 10.2 years) and wrote 1172665 records for HGN14_FUT_CME 2024-10-08 15:47:45.386 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2014-07-29 16:38:20.000000 2024-10-08 15:47:45.386 | HD Request # 10 | Completion time: 9s. 2024-10-08 15:47:45.386 | HD Request # 10 | Intraday data download complete for HGN14_FUT_CME. Unique request ID: 9 2024-10-08 15:47:45.386 | Removing historical data download ID 9. 2024-10-08 15:47:45.386 | Real-time Intraday chart data file updates started for HGN14_FUT_CME 2024-10-08 15:47:45.386 | Intraday chart data file opened for HGN14_FUT_CME 2024-10-08 15:47:45.386 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2024-10-08 15:47:45.386 | 2024-10-08 15:47:45.386 | Triggering next historical data download in queue. 2024-10-08 15:47:45.386 | HD Request # 11 | Downloading Intraday chart data for HGU14_FUT_CME to the file HGU14_FUT_CME.scid. Service: comex 2024-10-08 15:47:45.386 | HD Request # 11 | Download start date-time: 2014-06-11 01:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:47:45.387 | HD Request # 11 | Using server: ds32.sierracharts.com port 10150 2024-10-08 15:47:45.387 | Socket (2) | Creating socket. 2024-10-08 15:47:45.387 | Socket (2) | New receive buffer size: 0 2024-10-08 15:47:45.387 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-10-08 15:47:45.426 | Socket (3) | Socket gracefully closed by remote side. 2024-10-08 15:47:45.426 | Socket (3) | Closed. 2024-10-08 15:47:45.569 | HD Request # 11 | Setting DTC encoding to Binary VLS 2024-10-08 15:47:45.569 | HD Request # 11 | Sending historical data logon request message. 2024-10-08 15:47:46.145 | HD Request # 11 | Requesting Intraday data. Start date-time: 2014-06-11 01:00:00. Record interval: 0. Symbol: HGU14 2024-10-08 15:47:46.234 | HD Request # 11 | Decompressing data. 2024-10-08 15:47:46.427 | HD Request # 11 | Receiving Intraday data for HGU14_FUT_CME starting at 2014-06-11 01:13:35.000000 2024-10-08 15:47:46.618 | HD Request # 11 | Timestamp of first Intraday data file record written: 2014-06-11 01:13:35.000000. 2024-10-08 15:47:55.273 | Socket (2) | CloseSocket call. 2024-10-08 15:47:55.273 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 15:47:55.273 | Historical data download thread signaled to stop. 2024-10-08 15:47:55.273 | HD Request # 11 | Received 1219571 Intraday data records from 2014-06-11 01:13:35.000000 to 2014-09-26 17:11:57.000000 (107.7 days. Delay: 10.0 years) and wrote 1219571 records for HGU14_FUT_CME 2024-10-08 15:47:55.281 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2014-09-26 16:11:57.000000 2024-10-08 15:47:55.281 | HD Request # 11 | Completion time: 10s. 2024-10-08 15:47:55.281 | HD Request # 11 | Intraday data download complete for HGU14_FUT_CME. Unique request ID: 10 2024-10-08 15:47:55.281 | Removing historical data download ID 10. 2024-10-08 15:47:55.281 | Real-time Intraday chart data file updates started for HGU14_FUT_CME 2024-10-08 15:47:55.281 | Intraday chart data file opened for HGU14_FUT_CME 2024-10-08 15:47:55.281 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2024-10-08 15:47:55.281 | 2024-10-08 15:47:55.281 | Triggering next historical data download in queue. 2024-10-08 15:47:55.281 | HD Request # 12 | Downloading Intraday chart data for HGZ14_FUT_CME to the file HGZ14_FUT_CME.scid. Service: comex 2024-10-08 15:47:55.282 | HD Request # 12 | Download start date-time: 2014-08-12 01:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 15:47:55.282 | HD Request # 12 | Using server: ds26.sierracharts.com port 10149 2024-10-08 15:47:55.282 | Socket (3) | Creating socket. 2024-10-08 15:47:55.282 | Socket (3) | New receive buffer size: 0 2024-10-08 15:47:55.282 | Socket (3) | Connecting to IP: 69.39.70.243. 2024-10-08 15:47:55.364 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 15:47:55.364 | Socket (2) | Closed. 2024-10-08 15:47:55.466 | HD Request # 12 | Setting DTC encoding to Binary VLS 2024-10-08 15:47:55.466 | HD Request # 12 | Sending historical data logon request message. 2024-10-08 15:47:56.045 | HD Request # 12 | Requesting Intraday data. Start date-time: 2014-08-12 01:00:00. Record interval: 0. Symbol: HGZ14 2024-10-08 15:47:56.137 | HD Request # 12 | Decompressing data. 2024-10-08 15:47:56.330 | HD Request # 12 | Receiving Intraday data for HGZ14_FUT_CME starting at 2014-08-12 01:15:59.000000 2024-10-08 15:47:56.533 | HD Request # 12 | Timestamp of first Intraday data file record written: 2014-08-12 01:15:59.000000. 2024-10-08 15:48:07.533 | DTC - Sub Instance | Waiting for socket receive thread to end 2024-10-08 15:48:07.533 | DTC Client socket (1) | CloseSocket call. 2024-10-08 15:48:07.533 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-10-08 15:48:07.534 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-10-08 15:48:07.534 | DTC Client socket (1) | Closed. 2024-10-08 15:48:07.534 | DTC - Sub Instance | Disconnected. 2024-10-08 15:48:07.534 | Canceling queued historical data download request for HGH15_FUT_CME Intraday data. 2024-10-08 15:48:07.534 | Removing historical data download ID 12. 2024-10-08 15:48:07.535 | Canceling queued historical data download request for HGK15_FUT_CME Intraday data. 2024-10-08 15:48:07.535 | Removing historical data download ID 13. 2024-10-08 15:48:07.535 | Canceling queued historical data download request for HGN15_FUT_CME Intraday data. 2024-10-08 15:48:07.535 | Removing historical data download ID 14. 2024-10-08 15:48:07.535 | Canceling queued historical data download request for HGU15_FUT_CME Intraday data. 2024-10-08 15:48:07.535 | Removing historical data download ID 15. 2024-10-08 15:48:07.535 | Canceling queued historical data download request for HGZ15_FUT_CME Intraday data. 2024-10-08 15:48:07.535 | Removing historical data download ID 16. 2024-10-08 15:48:07.536 | Canceling queued historical data download request for HGH16_FUT_CME Intraday data. 2024-10-08 15:48:07.536 | Removing historical data download ID 17. 2024-10-08 15:48:07.536 | Canceling queued historical data download request for HGK16_FUT_CME Intraday data. 2024-10-08 15:48:07.536 | Removing historical data download ID 18. 2024-10-08 15:48:07.536 | Canceling queued historical data download request for HGN16_FUT_CME Intraday data. 2024-10-08 15:48:07.536 | Removing historical data download ID 19. 2024-10-08 15:48:07.536 | Canceling queued historical data download request for HGU16_FUT_CME Intraday data. 2024-10-08 15:48:07.536 | Removing historical data download ID 20. 2024-10-08 15:48:07.536 | Canceling queued historical data download request for HGZ16_FUT_CME Intraday data. 2024-10-08 15:48:07.536 | Removing historical data download ID 21. 2024-10-08 15:48:07.537 | Canceling queued historical data download request for HGH17_FUT_CME Intraday data. 2024-10-08 15:48:07.537 | Removing historical data download ID 22. 2024-10-08 15:48:07.537 | Canceling queued historical data download request for HGK17_FUT_CME Intraday data. 2024-10-08 15:48:07.537 | Removing historical data download ID 23. 2024-10-08 15:48:07.537 | Canceling queued historical data download request for HGN17_FUT_CME Intraday data. 2024-10-08 15:48:07.537 | Removing historical data download ID 24. 2024-10-08 15:48:07.537 | Canceling queued historical data download request for HGU17_FUT_CME Intraday data. 2024-10-08 15:48:07.537 | Removing historical data download ID 25. 2024-10-08 15:48:07.538 | Canceling queued historical data download request for HGZ17_FUT_CME Intraday data. 2024-10-08 15:48:07.538 | Removing historical data download ID 26. 2024-10-08 15:48:07.538 | Canceling queued historical data download request for HGH18_FUT_CME Intraday data. 2024-10-08 15:48:07.538 | Removing historical data download ID 27. 2024-10-08 15:48:07.538 | Canceling queued historical data download request for HGK18_FUT_CME Intraday data. 2024-10-08 15:48:07.538 | Removing historical data download ID 28. 2024-10-08 15:48:07.538 | Canceling queued historical data download request for HGN18_FUT_CME Intraday data. 2024-10-08 15:48:07.538 | Removing historical data download ID 29. 2024-10-08 15:48:07.538 | Canceling queued historical data download request for HGU18_FUT_CME Intraday data. 2024-10-08 15:48:07.538 | Removing historical data download ID 30. 2024-10-08 15:48:07.539 | Canceling queued historical data download request for HGZ18_FUT_CME Intraday data. 2024-10-08 15:48:07.539 | Removing historical data download ID 31. 2024-10-08 15:48:07.539 | Canceling queued historical data download request for HGH19_FUT_CME Intraday data. 2024-10-08 15:48:07.539 | Removing historical data download ID 32. 2024-10-08 15:48:07.539 | Canceling queued historical data download request for HGK19_FUT_CME Intraday data. 2024-10-08 15:48:07.539 | Removing historical data download ID 33. 2024-10-08 15:48:07.539 | Canceling queued historical data download request for HGN19_FUT_CME Intraday data. 2024-10-08 15:48:07.539 | Removing historical data download ID 34. 2024-10-08 15:48:07.539 | Canceling queued historical data download request for HGU19_FUT_CME Intraday data. 2024-10-08 15:48:07.539 | Removing historical data download ID 35. 2024-10-08 15:48:07.540 | Canceling queued historical data download request for HGZ19_FUT_CME Intraday data. 2024-10-08 15:48:07.540 | Removing historical data download ID 36. 2024-10-08 15:48:07.540 | Canceling queued historical data download request for HGH20_FUT_CME Intraday data. 2024-10-08 15:48:07.540 | Removing historical data download ID 37. 2024-10-08 15:48:07.540 | Canceling queued historical data download request for HGK20_FUT_CME Intraday data. 2024-10-08 15:48:07.540 | Removing historical data download ID 38. 2024-10-08 15:48:07.540 | Canceling queued historical data download request for HGN20_FUT_CME Intraday data. 2024-10-08 15:48:07.540 | Removing historical data download ID 39. 2024-10-08 15:48:07.540 | Canceling queued historical data download request for HGU20_FUT_CME Intraday data. 2024-10-08 15:48:07.540 | Removing historical data download ID 40. 2024-10-08 15:48:07.540 | Canceling queued historical data download request for HGK22_FUT_CME Intraday data. 2024-10-08 15:48:07.540 | Removing historical data download ID 41. 2024-10-08 15:48:07.541 | Canceling queued historical data download request for HGN22_FUT_CME Intraday data. 2024-10-08 15:48:07.541 | Removing historical data download ID 42. 2024-10-08 15:48:07.541 | Canceling queued historical data download request for HGU22_FUT_CME Intraday data. 2024-10-08 15:48:07.541 | Removing historical data download ID 43. 2024-10-08 15:48:07.541 | Canceling queued historical data download request for HGZ22_FUT_CME Intraday data. 2024-10-08 15:48:07.541 | Removing historical data download ID 44. 2024-10-08 15:48:07.541 | Canceling queued historical data download request for HGH23_FUT_CME Intraday data. 2024-10-08 15:48:07.541 | Removing historical data download ID 45. 2024-10-08 15:48:07.541 | Canceling queued historical data download request for HGK23_FUT_CME Intraday data. 2024-10-08 15:48:07.541 | Removing historical data download ID 46. 2024-10-08 15:48:07.542 | Canceling queued historical data download request for HGN23_FUT_CME Intraday data. 2024-10-08 15:48:07.542 | Removing historical data download ID 47. 2024-10-08 15:48:07.542 | Canceling queued historical data download request for HGU23_FUT_CME Intraday data. 2024-10-08 15:48:07.542 | Removing historical data download ID 48. 2024-10-08 15:48:07.542 | Canceling queued historical data download request for HGZ23_FUT_CME Intraday data. 2024-10-08 15:48:07.542 | Removing historical data download ID 49. 2024-10-08 15:48:07.542 | Canceling queued historical data download request for HGH24_FUT_CME Intraday data. 2024-10-08 15:48:07.542 | Removing historical data download ID 50. 2024-10-08 15:48:07.542 | Canceling queued historical data download request for HGK24_FUT_CME Intraday data. 2024-10-08 15:48:07.542 | Removing historical data download ID 51. 2024-10-08 15:48:07.543 | Canceling queued historical data download request for HGN24_FUT_CME Intraday data. 2024-10-08 15:48:07.543 | Removing historical data download ID 52. 2024-10-08 15:48:07.543 | Canceling queued historical data download request for HGU24_FUT_CME Intraday data. 2024-10-08 15:48:07.543 | Removing historical data download ID 53. 2024-10-08 15:48:07.543 | Canceling queued historical data download request for HGZ24_FUT_CME Daily data. 2024-10-08 15:48:07.543 | Removing historical data download ID 54. 2024-10-08 15:48:07.543 | HD Request # 12 | Active download canceled. 2024-10-08 15:48:07.543 | Historical data download thread signaled to stop. 2024-10-08 15:48:07.543 | Socket (3) | CloseSocket call. 2024-10-08 15:48:07.543 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-10-08 15:48:07.544 | HD Request # 12 | Received 1888248 Intraday data records from 2014-08-12 01:15:59.000000 to 2014-11-21 15:27:29.004000 (101.6 days. Delay: 9.9 years) and wrote 1888248 records for HGZ14_FUT_CME 2024-10-08 15:48:07.544 | HD Request # 12 | Completion time: 12s. 2024-10-08 15:48:07.544 | HD Request # 12 | Intraday data download complete for HGZ14_FUT_CME. Unique request ID: 11 2024-10-08 15:48:07.544 | Removing historical data download ID 11. 2024-10-08 15:48:07.544 | HD Request # 12 | Enabling Intraday chart updating for symbol. 2024-10-08 15:48:07.544 | 2024-10-08 15:48:07.544 | No download requests in the queue to start downloads for. 2024-10-08 15:48:07.545 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-08 15:48:08.008 | HGZ24_FUT_CME [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 15:48:08.009 | HGZ24_FUT_CME [CBV] #2 | Reloading chart. 2024-10-08 15:48:08.074 | Socket (3) | Socket gracefully closed by remote side. 2024-10-08 15:48:08.074 | Socket (3) | Closed. 2024-10-08 15:48:08.178 | Unable to determine transition date based on volume from files: HGN22_FUT_CME.dly, HGU22_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGU22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.179 | Unable to determine transition date based on volume from files: HGU22_FUT_CME.dly, HGZ22_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.179 | Unable to determine transition date based on volume from files: HGZ22_FUT_CME.dly, HGH23_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGH23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.179 | Unable to determine transition date based on volume from files: HGH23_FUT_CME.dly, HGK23_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGK23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.179 | Unable to determine transition date based on volume from files: HGK23_FUT_CME.dly, HGN23_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGN23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.179 | Unable to determine transition date based on volume from files: HGN23_FUT_CME.dly, HGU23_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGU23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.179 | Unable to determine transition date based on volume from files: HGU23_FUT_CME.dly, HGZ23_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.179 | Unable to determine transition date based on volume from files: HGZ23_FUT_CME.dly, HGH24_FUT_CME.dly 2024-10-08 15:48:08.179 | The HGH24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.180 | Unable to determine transition date based on volume from files: HGH24_FUT_CME.dly, HGK24_FUT_CME.dly 2024-10-08 15:48:08.180 | The HGK24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.180 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:48:08.180 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.180 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:48:08.180 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.180 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:48:08.180 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.606 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-05-25 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.609 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.609 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.611 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.611 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.614 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.614 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.617 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-02-28 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.617 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.619 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.619 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.622 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.622 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.625 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.625 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.628 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.628 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.630 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-03-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.630 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.633 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.633 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.635 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-06-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.635 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.637 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-09-01 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.637 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:08.646 | HGZ24_FUT_CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 15:48:08.647 | HGZ24_FUT_CME [CBV] #1 | Reloading chart. 2024-10-08 15:48:08.810 | Unable to determine transition date based on volume from files: HGN22_FUT_CME.dly, HGU22_FUT_CME.dly 2024-10-08 15:48:08.810 | The HGU22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.810 | Unable to determine transition date based on volume from files: HGU22_FUT_CME.dly, HGZ22_FUT_CME.dly 2024-10-08 15:48:08.810 | The HGZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.810 | Unable to determine transition date based on volume from files: HGZ22_FUT_CME.dly, HGH23_FUT_CME.dly 2024-10-08 15:48:08.810 | The HGH23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.811 | Unable to determine transition date based on volume from files: HGH23_FUT_CME.dly, HGK23_FUT_CME.dly 2024-10-08 15:48:08.811 | The HGK23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.811 | Unable to determine transition date based on volume from files: HGK23_FUT_CME.dly, HGN23_FUT_CME.dly 2024-10-08 15:48:08.811 | The HGN23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.811 | Unable to determine transition date based on volume from files: HGN23_FUT_CME.dly, HGU23_FUT_CME.dly 2024-10-08 15:48:08.811 | The HGU23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.812 | Unable to determine transition date based on volume from files: HGU23_FUT_CME.dly, HGZ23_FUT_CME.dly 2024-10-08 15:48:08.812 | The HGZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.812 | Unable to determine transition date based on volume from files: HGZ23_FUT_CME.dly, HGH24_FUT_CME.dly 2024-10-08 15:48:08.812 | The HGH24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.812 | Unable to determine transition date based on volume from files: HGH24_FUT_CME.dly, HGK24_FUT_CME.dly 2024-10-08 15:48:08.812 | The HGK24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.812 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:48:08.812 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.812 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:48:08.812 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:08.812 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:48:08.812 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.254 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-05-25 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.255 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.255 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.256 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.256 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.258 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.258 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.259 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-02-28 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.259 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.260 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.260 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.261 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.261 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.263 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.263 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.265 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.265 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.266 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-03-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.266 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.268 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.268 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.270 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-06-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.270 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.271 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-09-01 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.271 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.283 | HGZ24_FUT_CME [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 15:48:09.284 | HGZ24_FUT_CME [CBV] #5 | Reloading chart. 2024-10-08 15:48:09.453 | Unable to determine transition date based on volume from files: HGN22_FUT_CME.dly, HGU22_FUT_CME.dly 2024-10-08 15:48:09.453 | The HGU22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.453 | Unable to determine transition date based on volume from files: HGU22_FUT_CME.dly, HGZ22_FUT_CME.dly 2024-10-08 15:48:09.453 | The HGZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.453 | Unable to determine transition date based on volume from files: HGZ22_FUT_CME.dly, HGH23_FUT_CME.dly 2024-10-08 15:48:09.453 | The HGH23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.453 | Unable to determine transition date based on volume from files: HGH23_FUT_CME.dly, HGK23_FUT_CME.dly 2024-10-08 15:48:09.453 | The HGK23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.453 | Unable to determine transition date based on volume from files: HGK23_FUT_CME.dly, HGN23_FUT_CME.dly 2024-10-08 15:48:09.453 | The HGN23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.453 | Unable to determine transition date based on volume from files: HGN23_FUT_CME.dly, HGU23_FUT_CME.dly 2024-10-08 15:48:09.453 | The HGU23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.453 | Unable to determine transition date based on volume from files: HGU23_FUT_CME.dly, HGZ23_FUT_CME.dly 2024-10-08 15:48:09.453 | The HGZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.454 | Unable to determine transition date based on volume from files: HGZ23_FUT_CME.dly, HGH24_FUT_CME.dly 2024-10-08 15:48:09.454 | The HGH24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.454 | Unable to determine transition date based on volume from files: HGH24_FUT_CME.dly, HGK24_FUT_CME.dly 2024-10-08 15:48:09.454 | The HGK24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.454 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:48:09.454 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.454 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:48:09.454 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.454 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:48:09.454 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:09.883 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-05-25 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.885 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.885 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.886 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.886 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.888 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.888 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.890 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-02-28 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.890 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.892 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.892 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.894 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.894 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.895 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.895 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.897 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.897 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.898 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-03-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.898 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.900 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.900 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.901 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-06-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.901 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.903 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-09-01 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.903 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:09.910 | HGZ24_FUT_CME [CBV] #2 | Reloading chart. 2024-10-08 15:48:10.275 | Unable to determine transition date based on volume from files: HGN22_FUT_CME.dly, HGU22_FUT_CME.dly 2024-10-08 15:48:10.275 | The HGU22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.275 | Unable to determine transition date based on volume from files: HGU22_FUT_CME.dly, HGZ22_FUT_CME.dly 2024-10-08 15:48:10.275 | The HGZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.275 | Unable to determine transition date based on volume from files: HGZ22_FUT_CME.dly, HGH23_FUT_CME.dly 2024-10-08 15:48:10.275 | The HGH23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.275 | Unable to determine transition date based on volume from files: HGH23_FUT_CME.dly, HGK23_FUT_CME.dly 2024-10-08 15:48:10.275 | The HGK23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGK23_FUT_CME.dly, HGN23_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGN23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGN23_FUT_CME.dly, HGU23_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGU23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGU23_FUT_CME.dly, HGZ23_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGZ23_FUT_CME.dly, HGH24_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGH24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGH24_FUT_CME.dly, HGK24_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGK24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.276 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:48:10.276 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:10.738 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-05-25 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.740 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.740 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.741 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.741 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.743 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2022-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.743 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.745 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-02-28 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.745 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.747 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.747 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.749 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.749 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.751 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.751 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.752 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2023-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.752 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.754 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-03-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.754 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.755 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.755 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.757 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-06-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.757 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.758 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 2024-09-01 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.758 | HGZ24_FUT_CME [CBV] #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:10.760 | HGZ24_FUT_CME [CBV] #1 | Reloading chart. 2024-10-08 15:48:11.138 | Unable to determine transition date based on volume from files: HGN22_FUT_CME.dly, HGU22_FUT_CME.dly 2024-10-08 15:48:11.138 | The HGU22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.138 | Unable to determine transition date based on volume from files: HGU22_FUT_CME.dly, HGZ22_FUT_CME.dly 2024-10-08 15:48:11.138 | The HGZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.138 | Unable to determine transition date based on volume from files: HGZ22_FUT_CME.dly, HGH23_FUT_CME.dly 2024-10-08 15:48:11.138 | The HGH23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.138 | Unable to determine transition date based on volume from files: HGH23_FUT_CME.dly, HGK23_FUT_CME.dly 2024-10-08 15:48:11.138 | The HGK23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.139 | Unable to determine transition date based on volume from files: HGK23_FUT_CME.dly, HGN23_FUT_CME.dly 2024-10-08 15:48:11.139 | The HGN23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.139 | Unable to determine transition date based on volume from files: HGN23_FUT_CME.dly, HGU23_FUT_CME.dly 2024-10-08 15:48:11.139 | The HGU23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.139 | Unable to determine transition date based on volume from files: HGU23_FUT_CME.dly, HGZ23_FUT_CME.dly 2024-10-08 15:48:11.139 | The HGZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.140 | Unable to determine transition date based on volume from files: HGZ23_FUT_CME.dly, HGH24_FUT_CME.dly 2024-10-08 15:48:11.140 | The HGH24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.141 | Unable to determine transition date based on volume from files: HGH24_FUT_CME.dly, HGK24_FUT_CME.dly 2024-10-08 15:48:11.141 | The HGK24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.141 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:48:11.141 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.141 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:48:11.141 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.142 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:48:11.142 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:11.629 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-05-25 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.630 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.630 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.632 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.632 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.634 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2022-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.634 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.635 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-02-28 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.635 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.637 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.637 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.638 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.638 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.640 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.640 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.641 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2023-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.641 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.643 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-03-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.643 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.644 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.644 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.646 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-06-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.646 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.648 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2024-09-01 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.648 | HGZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:11.678 | 2024-10-08 15:48:11.679 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-10-08 15:48:11.679 | DTC Client socket (1) | Creating socket. 2024-10-08 15:48:11.679 | DTC Client socket (1) | New receive buffer size: 0 2024-10-08 15:48:11.679 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-10-08 15:48:11.681 | DTC - Sub Instance | Network connection to server complete. 2024-10-08 15:48:11.681 | DTC - Sub Instance | Starting socket receive thread. 2024-10-08 15:48:11.681 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-10-08 15:48:11.682 | HGZ24_FUT_CME [CBV] #5 | Reloading chart. 2024-10-08 15:48:12.068 | Unable to determine transition date based on volume from files: HGN22_FUT_CME.dly, HGU22_FUT_CME.dly 2024-10-08 15:48:12.068 | The HGU22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.068 | Unable to determine transition date based on volume from files: HGU22_FUT_CME.dly, HGZ22_FUT_CME.dly 2024-10-08 15:48:12.068 | The HGZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.068 | Unable to determine transition date based on volume from files: HGZ22_FUT_CME.dly, HGH23_FUT_CME.dly 2024-10-08 15:48:12.068 | The HGH23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.069 | Unable to determine transition date based on volume from files: HGH23_FUT_CME.dly, HGK23_FUT_CME.dly 2024-10-08 15:48:12.069 | The HGK23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.069 | Unable to determine transition date based on volume from files: HGK23_FUT_CME.dly, HGN23_FUT_CME.dly 2024-10-08 15:48:12.069 | The HGN23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.069 | Unable to determine transition date based on volume from files: HGN23_FUT_CME.dly, HGU23_FUT_CME.dly 2024-10-08 15:48:12.069 | The HGU23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.069 | Unable to determine transition date based on volume from files: HGU23_FUT_CME.dly, HGZ23_FUT_CME.dly 2024-10-08 15:48:12.069 | The HGZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.069 | Unable to determine transition date based on volume from files: HGZ23_FUT_CME.dly, HGH24_FUT_CME.dly 2024-10-08 15:48:12.069 | The HGH24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.070 | Unable to determine transition date based on volume from files: HGH24_FUT_CME.dly, HGK24_FUT_CME.dly 2024-10-08 15:48:12.070 | The HGK24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.070 | Unable to determine transition date based on volume from files: HGK24_FUT_CME.dly, HGN24_FUT_CME.dly 2024-10-08 15:48:12.070 | The HGN24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.070 | Unable to determine transition date based on volume from files: HGN24_FUT_CME.dly, HGU24_FUT_CME.dly 2024-10-08 15:48:12.070 | The HGU24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.070 | Unable to determine transition date based on volume from files: HGU24_FUT_CME.dly, HGZ24_FUT_CME.dly 2024-10-08 15:48:12.070 | The HGZ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 15:48:12.566 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-05-25 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.567 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.567 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.568 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.568 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.569 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.569 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.571 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-02-28 from file. C:\Sierra\SierraChartInstance_2\Data\HGH23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.571 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.572 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.572 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.574 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-07-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGN23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.574 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.575 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-09-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGU23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.575 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.577 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.577 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.579 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-03-02 from file. C:\Sierra\SierraChartInstance_2\Data\HGH24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.579 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.580 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-04-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGK24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.580 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.581 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-06-30 from file. C:\Sierra\SierraChartInstance_2\Data\HGN24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.581 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.583 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-09-01 from file. C:\Sierra\SierraChartInstance_2\Data\HGU24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.583 | HGZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 15:48:12.583 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-10-08 15:48:12.583 | DTC - Sub Instance | Sending logon request message. 2024-10-08 15:48:12.593 | DTC - Sub Instance | Received logon response. 2024-10-08 15:48:12.594 | DTC - Sub Instance | Server Name: SC DTC Server. Build=49642. 2024-10-08 15:48:12.594 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-10-08 15:48:12.594 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading. 2024-10-08 15:48:12.594 | DTC - Sub Instance | Trading is supported. 2024-10-08 15:48:12.594 | DTC - Sub Instance | Order cancel and replace is supported. 2024-10-08 15:48:12.594 | DTC - Sub Instance | OCO Orders supported. 2024-10-08 15:48:12.594 | DTC - Sub Instance | Bracket Orders supported. 2024-10-08 15:48:12.594 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-10-08 15:48:12.594 | DTC - Sub Instance | Connected to server complete. 2024-10-08 15:48:12.605 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-10-08 15:48:12.609 | Using symbol data fast lookup vector 2024-10-08 15:48:12.609 | DTC - Sub Instance | Starting real-time market data updates for: HGZ24_FUT_CME. ID: 1 2024-10-08 15:48:12.609 | DTC - Sub Instance | Requesting security definition data for: HGZ24_FUT_CME. ID: 1 2024-10-08 15:48:12.609 | Added historical Intraday data request for HGZ24_FUT_CME to the queue. 2024-10-08 15:48:12.609 | Intraday data recording state for symbol HGZ24_FUT_CME is set to download 'Pending'. 2024-10-08 15:48:12.609 | Triggering next historical data download in queue. 2024-10-08 15:48:12.609 | Delaying start of download for HGZ24_FUT_CME. 2024-10-08 15:48:12.623 | DTC - Sub Instance | Received security definition for symbol HGZ24_FUT_CME 2024-10-08 15:48:17.621 | HGZ24_FUT_CME [CBV] #2 | Chart data loading complete. 2024-10-08 15:48:17.622 | HD Request # 13 | Downloading Intraday chart data for HGZ24_FUT_CME to the file HGZ24_FUT_CME.scid. Service: comex 2024-10-08 15:48:17.622 | HD Request # 13 | Download start date-time: 2024-10-08 15:48:00.000000. File last date-time: 2024-10-08 15:48:00.172000 2024-10-08 15:48:17.622 | HD Request # 13 | Using server: ds28.sierracharts.com port 10150 2024-10-08 15:48:17.622 | Socket (2) | Creating socket. 2024-10-08 15:48:17.622 | Socket (2) | New receive buffer size: 0 2024-10-08 15:48:17.622 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-10-08 15:48:17.802 | HD Request # 13 | Setting DTC encoding to Binary VLS 2024-10-08 15:48:17.802 | HD Request # 13 | Sending historical data logon request message. 2024-10-08 15:48:18.294 | HGZ24_FUT_CME [CBV] #1 | Chart data loading complete. 2024-10-08 15:48:18.376 | HD Request # 13 | Requesting Intraday data. Start date-time: 2024-10-08 15:48:00. Record interval: 0. Symbol: HGZ24 2024-10-08 15:48:18.462 | HD Request # 13 | Decompressing data. 2024-10-08 15:48:18.548 | HD Request # 13 | Receiving Intraday data for HGZ24_FUT_CME starting at 2024-10-08 15:48:00.160000 2024-10-08 15:48:18.548 | Socket (2) | CloseSocket call. 2024-10-08 15:48:18.548 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 15:48:18.619 | HGZ24_FUT_CME [CBV] #5 | Chart data loading complete. 2024-10-08 15:48:18.619 | Historical data download thread signaled to stop. 2024-10-08 15:48:18.619 | HD Request # 13 | Timestamp of first Intraday data file record written: 2024-10-08 15:48:06.887000. 2024-10-08 15:48:18.619 | HD Request # 13 | Received 7 Intraday data records from 2024-10-08 15:48:00.160000 to 2024-10-08 15:48:06.887003 (6.7 seconds. Delay: 11.7 seconds) and wrote 4 records for HGZ24_FUT_CME 2024-10-08 15:48:18.626 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2024-10-08 14:48:06.887003 2024-10-08 15:48:18.626 | HD Request # 13 | Completion time: 1s. 2024-10-08 15:48:18.626 | HD Request # 13 | Intraday data download complete for HGZ24_FUT_CME. Unique request ID: 55 2024-10-08 15:48:18.626 | Removing historical data download ID 55. 2024-10-08 15:48:18.626 | Real-time Intraday chart data file updates started for HGZ24_FUT_CME 2024-10-08 15:48:18.626 | Intraday chart data file opened for HGZ24_FUT_CME 2024-10-08 15:48:18.626 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2024-10-08 15:48:18.626 | 2024-10-08 15:48:18.626 | No download requests in the queue to start downloads for. 2024-10-08 15:48:18.637 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 15:48:18.637 | Socket (2) | Closed. 2024-10-08 15:48:26.741 | Opened cached Intraday file: C:\Sierra\SierraChartInstance_2\Data\HGZ24_FUT_CME.scid. Thread ID: 5928 2024-10-08 16:01:21.771 | GCZ24_FUT_CME [CV] Daily #3 | Reloading chart. 2024-10-08 16:01:22.633 | Unable to determine transition date based on volume from files: GCM16_FUT_CME.dly, GCQ16_FUT_CME.dly 2024-10-08 16:01:22.633 | The GCQ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.633 | Unable to determine transition date based on volume from files: GCQ16_FUT_CME.dly, GCZ16_FUT_CME.dly 2024-10-08 16:01:22.633 | The GCZ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.633 | Unable to determine transition date based on volume from files: GCZ16_FUT_CME.dly, GCG17_FUT_CME.dly 2024-10-08 16:01:22.633 | The GCG17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.633 | Unable to determine transition date based on volume from files: GCG17_FUT_CME.dly, GCJ17_FUT_CME.dly 2024-10-08 16:01:22.633 | The GCJ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.634 | Unable to determine transition date based on volume from files: GCJ17_FUT_CME.dly, GCM17_FUT_CME.dly 2024-10-08 16:01:22.634 | The GCM17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.634 | Unable to determine transition date based on volume from files: GCM17_FUT_CME.dly, GCQ17_FUT_CME.dly 2024-10-08 16:01:22.634 | The GCQ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.634 | Unable to determine transition date based on volume from files: GCQ17_FUT_CME.dly, GCZ17_FUT_CME.dly 2024-10-08 16:01:22.634 | The GCZ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.634 | Unable to determine transition date based on volume from files: GCZ17_FUT_CME.dly, GCG18_FUT_CME.dly 2024-10-08 16:01:22.634 | The GCG18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.634 | Unable to determine transition date based on volume from files: GCG18_FUT_CME.dly, GCJ18_FUT_CME.dly 2024-10-08 16:01:22.634 | The GCJ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.634 | Unable to determine transition date based on volume from files: GCJ18_FUT_CME.dly, GCM18_FUT_CME.dly 2024-10-08 16:01:22.634 | The GCM18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.634 | Unable to determine transition date based on volume from files: GCM18_FUT_CME.dly, GCQ18_FUT_CME.dly 2024-10-08 16:01:22.634 | The GCQ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.635 | Unable to determine transition date based on volume from files: GCQ18_FUT_CME.dly, GCZ18_FUT_CME.dly 2024-10-08 16:01:22.635 | The GCZ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.635 | Unable to determine transition date based on volume from files: GCZ18_FUT_CME.dly, GCG19_FUT_CME.dly 2024-10-08 16:01:22.635 | The GCG19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.635 | Unable to determine transition date based on volume from files: GCG19_FUT_CME.dly, GCJ19_FUT_CME.dly 2024-10-08 16:01:22.635 | The GCJ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.635 | Unable to determine transition date based on volume from files: GCJ19_FUT_CME.dly, GCM19_FUT_CME.dly 2024-10-08 16:01:22.635 | The GCM19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.635 | Unable to determine transition date based on volume from files: GCM19_FUT_CME.dly, GCQ19_FUT_CME.dly 2024-10-08 16:01:22.635 | The GCQ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.635 | Unable to determine transition date based on volume from files: GCQ19_FUT_CME.dly, GCZ19_FUT_CME.dly 2024-10-08 16:01:22.635 | The GCZ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.635 | Unable to determine transition date based on volume from files: GCZ19_FUT_CME.dly, GCG20_FUT_CME.dly 2024-10-08 16:01:22.635 | The GCG20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCG20_FUT_CME.dly, GCJ20_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCJ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCJ20_FUT_CME.dly, GCM20_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCM20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCM20_FUT_CME.dly, GCQ20_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCQ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCQ20_FUT_CME.dly, GCZ20_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCZ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.636 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:01:22.636 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.637 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:01:22.637 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.637 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:01:22.637 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.637 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:01:22.637 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.637 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:01:22.637 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.637 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:01:22.637 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.637 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:01:22.637 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.637 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:01:22.637 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.638 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:01:22.638 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:22.688 | GCZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 16:01:22.698 | Added historical Intraday data request for GCZ24_FUT_CME to the queue. 2024-10-08 16:01:22.698 | Triggering next historical data download in queue. 2024-10-08 16:01:22.714 | GCZ24_FUT_CME [CBV] 60 Min #2 | Waiting for historical downloads to complete with the IDs: 56, 2024-10-08 16:01:22.734 | GCZ24_FUT_CME [CBV] #6 | Reloading chart. 2024-10-08 16:01:22.762 | Added historical Intraday data request for GCG13_FUT_CME to the queue. 2024-10-08 16:01:22.765 | Added historical Intraday data request for GCJ13_FUT_CME to the queue. 2024-10-08 16:01:22.768 | Added historical Intraday data request for GCM13_FUT_CME to the queue. 2024-10-08 16:01:22.770 | Added historical Intraday data request for GCQ13_FUT_CME to the queue. 2024-10-08 16:01:22.772 | Added historical Intraday data request for GCZ13_FUT_CME to the queue. 2024-10-08 16:01:22.775 | Added historical Intraday data request for GCG14_FUT_CME to the queue. 2024-10-08 16:01:22.777 | Added historical Intraday data request for GCJ14_FUT_CME to the queue. 2024-10-08 16:01:22.780 | Added historical Intraday data request for GCM14_FUT_CME to the queue. 2024-10-08 16:01:22.783 | Added historical Intraday data request for GCQ14_FUT_CME to the queue. 2024-10-08 16:01:22.785 | Added historical Intraday data request for GCZ14_FUT_CME to the queue. 2024-10-08 16:01:22.788 | Added historical Intraday data request for GCG15_FUT_CME to the queue. 2024-10-08 16:01:22.791 | Added historical Intraday data request for GCJ15_FUT_CME to the queue. 2024-10-08 16:01:22.793 | Added historical Intraday data request for GCM15_FUT_CME to the queue. 2024-10-08 16:01:22.795 | Added historical Intraday data request for GCQ15_FUT_CME to the queue. 2024-10-08 16:01:22.798 | Added historical Intraday data request for GCZ15_FUT_CME to the queue. 2024-10-08 16:01:22.800 | Added historical Intraday data request for GCG16_FUT_CME to the queue. 2024-10-08 16:01:22.803 | Added historical Intraday data request for GCJ16_FUT_CME to the queue. 2024-10-08 16:01:22.805 | Added historical Intraday data request for GCM16_FUT_CME to the queue. 2024-10-08 16:01:22.807 | Added historical Intraday data request for GCQ16_FUT_CME to the queue. 2024-10-08 16:01:22.809 | Added historical Intraday data request for GCZ16_FUT_CME to the queue. 2024-10-08 16:01:22.811 | Added historical Intraday data request for GCG17_FUT_CME to the queue. 2024-10-08 16:01:22.813 | Added historical Intraday data request for GCJ17_FUT_CME to the queue. 2024-10-08 16:01:22.816 | Added historical Intraday data request for GCM17_FUT_CME to the queue. 2024-10-08 16:01:22.818 | Added historical Intraday data request for GCQ17_FUT_CME to the queue. 2024-10-08 16:01:22.819 | Added historical Intraday data request for GCZ17_FUT_CME to the queue. 2024-10-08 16:01:22.821 | Added historical Intraday data request for GCG18_FUT_CME to the queue. 2024-10-08 16:01:22.823 | Added historical Intraday data request for GCJ18_FUT_CME to the queue. 2024-10-08 16:01:22.825 | Added historical Intraday data request for GCM18_FUT_CME to the queue. 2024-10-08 16:01:22.827 | Added historical Intraday data request for GCQ18_FUT_CME to the queue. 2024-10-08 16:01:22.829 | Added historical Intraday data request for GCZ18_FUT_CME to the queue. 2024-10-08 16:01:22.831 | Added historical Intraday data request for GCG19_FUT_CME to the queue. 2024-10-08 16:01:22.834 | Added historical Intraday data request for GCJ19_FUT_CME to the queue. 2024-10-08 16:01:22.836 | Added historical Intraday data request for GCM19_FUT_CME to the queue. 2024-10-08 16:01:22.838 | Added historical Intraday data request for GCQ19_FUT_CME to the queue. 2024-10-08 16:01:22.840 | Added historical Intraday data request for GCZ19_FUT_CME to the queue. 2024-10-08 16:01:22.842 | Added historical Intraday data request for GCG20_FUT_CME to the queue. 2024-10-08 16:01:22.844 | Added historical Intraday data request for GCJ20_FUT_CME to the queue. 2024-10-08 16:01:22.846 | Added historical Intraday data request for GCM20_FUT_CME to the queue. 2024-10-08 16:01:22.849 | Added historical Intraday data request for GCQ20_FUT_CME to the queue. 2024-10-08 16:01:22.851 | Added historical Intraday data request for GCZ20_FUT_CME to the queue. 2024-10-08 16:01:22.853 | Added historical Intraday data request for GCG21_FUT_CME to the queue. 2024-10-08 16:01:22.854 | Added historical Intraday data request for GCJ21_FUT_CME to the queue. 2024-10-08 16:01:22.857 | Added historical Intraday data request for GCM21_FUT_CME to the queue. 2024-10-08 16:01:22.858 | Added historical Intraday data request for GCQ21_FUT_CME to the queue. 2024-10-08 16:01:22.861 | Added historical Intraday data request for GCZ21_FUT_CME to the queue. 2024-10-08 16:01:22.862 | Added historical Intraday data request for GCG22_FUT_CME to the queue. 2024-10-08 16:01:22.865 | Added historical Intraday data request for GCJ22_FUT_CME to the queue. 2024-10-08 16:01:22.866 | Added historical Intraday data request for GCM22_FUT_CME to the queue. 2024-10-08 16:01:22.868 | Added historical Intraday data request for GCQ22_FUT_CME to the queue. 2024-10-08 16:01:22.870 | Added historical Intraday data request for GCZ22_FUT_CME to the queue. 2024-10-08 16:01:22.872 | Added historical Intraday data request for GCG23_FUT_CME to the queue. 2024-10-08 16:01:22.874 | Added historical Intraday data request for GCJ23_FUT_CME to the queue. 2024-10-08 16:01:22.876 | Added historical Intraday data request for GCM23_FUT_CME to the queue. 2024-10-08 16:01:22.877 | Added historical Intraday data request for GCQ23_FUT_CME to the queue. 2024-10-08 16:01:22.879 | Added historical Intraday data request for GCZ23_FUT_CME to the queue. 2024-10-08 16:01:22.881 | Added historical Intraday data request for GCG24_FUT_CME to the queue. 2024-10-08 16:01:22.883 | Added historical Intraday data request for GCJ24_FUT_CME to the queue. 2024-10-08 16:01:22.884 | Added historical Intraday data request for GCM24_FUT_CME to the queue. 2024-10-08 16:01:22.885 | Added historical Intraday data request for GCQ24_FUT_CME to the queue. 2024-10-08 16:01:23.196 | GCZ24_FUT_CME [CBV] #6 | Waiting for historical downloads to complete with the IDs: 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 2024-10-08 16:01:23.255 | GCZ24_FUT_CME [CBV] #5 | Reloading chart. 2024-10-08 16:01:23.293 | GCZ24_FUT_CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 56, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 2024-10-08 16:01:23.317 | GCZ24_FUT_CME [CV] #4 | Reloading chart. 2024-10-08 16:01:23.334 | GCZ24_FUT_CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 56, 111, 112, 113, 114, 115, 2024-10-08 16:01:23.362 | GCZ24_FUT_CME [CV] Daily #8 | Reloading chart. 2024-10-08 16:01:23.938 | Unable to determine transition date based on volume from files: GCM16_FUT_CME.dly, GCQ16_FUT_CME.dly 2024-10-08 16:01:23.938 | The GCQ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.938 | Unable to determine transition date based on volume from files: GCQ16_FUT_CME.dly, GCZ16_FUT_CME.dly 2024-10-08 16:01:23.938 | The GCZ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.939 | Unable to determine transition date based on volume from files: GCZ16_FUT_CME.dly, GCG17_FUT_CME.dly 2024-10-08 16:01:23.939 | The GCG17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.939 | Unable to determine transition date based on volume from files: GCG17_FUT_CME.dly, GCJ17_FUT_CME.dly 2024-10-08 16:01:23.939 | The GCJ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.939 | Unable to determine transition date based on volume from files: GCJ17_FUT_CME.dly, GCM17_FUT_CME.dly 2024-10-08 16:01:23.939 | The GCM17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.939 | Unable to determine transition date based on volume from files: GCM17_FUT_CME.dly, GCQ17_FUT_CME.dly 2024-10-08 16:01:23.939 | The GCQ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.939 | Unable to determine transition date based on volume from files: GCQ17_FUT_CME.dly, GCZ17_FUT_CME.dly 2024-10-08 16:01:23.939 | The GCZ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.939 | Unable to determine transition date based on volume from files: GCZ17_FUT_CME.dly, GCG18_FUT_CME.dly 2024-10-08 16:01:23.939 | The GCG18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.939 | Unable to determine transition date based on volume from files: GCG18_FUT_CME.dly, GCJ18_FUT_CME.dly 2024-10-08 16:01:23.939 | The GCJ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCJ18_FUT_CME.dly, GCM18_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCM18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCM18_FUT_CME.dly, GCQ18_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCQ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCQ18_FUT_CME.dly, GCZ18_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCZ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCZ18_FUT_CME.dly, GCG19_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCG19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCG19_FUT_CME.dly, GCJ19_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCJ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCJ19_FUT_CME.dly, GCM19_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCM19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCM19_FUT_CME.dly, GCQ19_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCQ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.940 | Unable to determine transition date based on volume from files: GCQ19_FUT_CME.dly, GCZ19_FUT_CME.dly 2024-10-08 16:01:23.940 | The GCZ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCZ19_FUT_CME.dly, GCG20_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCG20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCG20_FUT_CME.dly, GCJ20_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCJ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCJ20_FUT_CME.dly, GCM20_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCM20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCM20_FUT_CME.dly, GCQ20_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCQ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCQ20_FUT_CME.dly, GCZ20_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCZ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.941 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:01:23.941 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.942 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:01:23.942 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.943 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:01:23.943 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.943 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:01:23.943 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.943 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:01:23.943 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.943 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:01:23.943 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.943 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:01:23.943 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.943 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:01:23.943 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.943 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:01:23.943 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:23.984 | HD Request # 14 | Downloading Intraday chart data for GCZ24_FUT_CME to the file GCZ24_FUT_CME.scid. Service: comex 2024-10-08 16:01:23.984 | HD Request # 14 | Download start date-time: 2024-10-08 15:23:10.000000. File last date-time: 2024-10-08 15:23:10.674000 2024-10-08 16:01:23.984 | HD Request # 14 | Using server: ds32.sierracharts.com port 10149 2024-10-08 16:01:23.985 | Socket (2) | Creating socket. 2024-10-08 16:01:23.985 | Socket (2) | New receive buffer size: 0 2024-10-08 16:01:23.985 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-10-08 16:01:24.002 | GCZ24_FUT_CME [CV] Daily #3 | Chart data loading complete. 2024-10-08 16:01:24.059 | DTC - Sub Instance | Starting real-time market data updates for: GCZ24_FUT_CME. ID: 2 2024-10-08 16:01:24.059 | DTC - Sub Instance | Requesting security definition data for: GCZ24_FUT_CME. ID: 2 2024-10-08 16:01:24.069 | DTC - Sub Instance | Received security definition for symbol GCZ24_FUT_CME 2024-10-08 16:01:24.122 | GCZ24_FUT_CME [CV] Daily #8 | Chart data loading complete. 2024-10-08 16:01:24.175 | Added historical Daily data request for GCZ24_FUT_CME to the queue. 2024-10-08 16:01:24.175 | Triggering next historical data download in queue. 2024-10-08 16:01:24.176 | HD Request # 14 | Setting DTC encoding to Binary VLS 2024-10-08 16:01:24.176 | HD Request # 14 | Sending historical data logon request message. 2024-10-08 16:01:24.772 | HD Request # 14 | Requesting Intraday data. Start date-time: 2024-10-08 15:23:10. Record interval: 0. Symbol: GCZ24 2024-10-08 16:01:24.870 | HD Request # 14 | Decompressing data. 2024-10-08 16:01:24.968 | HD Request # 14 | Receiving Intraday data for GCZ24_FUT_CME starting at 2024-10-08 15:23:10.272000 2024-10-08 16:01:25.238 | Socket (2) | CloseSocket call. 2024-10-08 16:01:25.238 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 16:01:25.238 | Historical data download thread signaled to stop. 2024-10-08 16:01:25.239 | HD Request # 14 | Timestamp of first Intraday data file record written: 2024-10-08 15:23:11.612000. 2024-10-08 16:01:25.240 | HD Request # 14 | Received 23674 Intraday data records from 2024-10-08 15:23:10.272000 to 2024-10-08 16:01:21.090000 (38.2 minutes. Delay: 4.2 seconds) and wrote 23648 records for GCZ24_FUT_CME 2024-10-08 16:01:25.255 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2024-10-08 15:01:21.090000 2024-10-08 16:01:25.255 | Added 34 Time and Sales records to Intraday data file for GCZ24_FUT_CME after download. 2024-10-08 16:01:25.255 | HD Request # 14 | Completion time: 2s. 2024-10-08 16:01:25.255 | HD Request # 14 | Intraday data download complete for GCZ24_FUT_CME. Unique request ID: 56 2024-10-08 16:01:25.255 | Removing historical data download ID 56. 2024-10-08 16:01:25.255 | Real-time Intraday chart data file updates started for GCZ24_FUT_CME 2024-10-08 16:01:25.255 | Intraday chart data file opened for GCZ24_FUT_CME 2024-10-08 16:01:25.255 | HD Request # 14 | Enabling Intraday chart updating for symbol. 2024-10-08 16:01:25.255 | 2024-10-08 16:01:25.255 | Triggering next historical data download in queue. 2024-10-08 16:01:25.256 | HD Request # 15 | Downloading Intraday chart data for GCG13_FUT_CME to the file GCG13_FUT_CME.scid. Service: comex 2024-10-08 16:01:25.256 | HD Request # 15 | Download start date-time: 2012-11-14 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 16:01:25.256 | HD Request # 15 | Using server: ds26.sierracharts.com port 10150 2024-10-08 16:01:25.293 | Socket (3) | Creating socket. 2024-10-08 16:01:25.294 | Socket (3) | New receive buffer size: 0 2024-10-08 16:01:25.294 | Socket (3) | Connecting to IP: 69.39.70.243. 2024-10-08 16:01:25.324 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 16:01:25.324 | Socket (2) | Closed. 2024-10-08 16:01:25.482 | HD Request # 15 | Setting DTC encoding to Binary VLS 2024-10-08 16:01:25.482 | HD Request # 15 | Sending historical data logon request message. 2024-10-08 16:01:25.530 | GCZ24_FUT_CME [CBV] 60 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 16:01:25.531 | GCZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 16:01:25.532 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:01:25.532 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:25.532 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:01:25.532 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:01:25.554 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:01:25.554 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:01:25.555 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:01:25.555 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:01:25.557 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:01:25.557 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:01:25.934 | GCZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 16:01:25.949 | GCZ24_FUT_CME [CBV] 60 Min #2 | Waiting for historical downloads to complete with the IDs: 113, 114, 115, 116, 2024-10-08 16:01:26.063 | HD Request # 15 | Requesting Intraday data. Start date-time: 2012-11-14 00:00:00. Record interval: 0. Symbol: GCG13 2024-10-08 16:01:26.155 | HD Request # 15 | Decompressing data. 2024-10-08 16:01:26.350 | HD Request # 15 | Receiving Intraday data for GCG13_FUT_CME starting at 2012-11-14 00:18:08.000000 2024-10-08 16:01:26.539 | HD Request # 15 | Timestamp of first Intraday data file record written: 2012-11-14 00:18:08.000000. 2024-10-08 16:01:28.031 | Opened cached Intraday file: C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.scid. Thread ID: 5928 2024-10-08 16:01:28.486 | GCZ24_FUT_CME [CBV] 60 Min #2 | Chart data loading complete. 2024-10-08 16:01:53.042 | Socket (3) | CloseSocket call. 2024-10-08 16:01:53.043 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-10-08 16:01:53.043 | Historical data download thread signaled to stop. 2024-10-08 16:01:53.043 | HD Request # 15 | Received 3727949 Intraday data records from 2012-11-14 00:18:08.000000 to 2013-02-26 16:10:21.000000 (104.7 days. Delay: 11.6 years) and wrote 3727949 records for GCG13_FUT_CME 2024-10-08 16:01:53.061 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2013-02-26 16:10:21.000000 2024-10-08 16:01:53.061 | HD Request # 15 | Completion time: 28s. 2024-10-08 16:01:53.061 | HD Request # 15 | Intraday data download complete for GCG13_FUT_CME. Unique request ID: 57 2024-10-08 16:01:53.061 | Removing historical data download ID 57. 2024-10-08 16:01:53.061 | Real-time Intraday chart data file updates started for GCG13_FUT_CME 2024-10-08 16:01:53.061 | Intraday chart data file opened for GCG13_FUT_CME 2024-10-08 16:01:53.061 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2024-10-08 16:01:53.061 | 2024-10-08 16:01:53.061 | Triggering next historical data download in queue. 2024-10-08 16:01:53.061 | HD Request # 16 | Downloading Intraday chart data for GCJ13_FUT_CME to the file GCJ13_FUT_CME.scid. Service: comex 2024-10-08 16:01:53.062 | HD Request # 16 | Download start date-time: 2013-01-15 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 16:01:53.062 | HD Request # 16 | Using server: ds28.sierracharts.com port 10149 2024-10-08 16:01:53.063 | Socket (2) | Creating socket. 2024-10-08 16:01:53.063 | Socket (2) | New receive buffer size: 0 2024-10-08 16:01:53.063 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-10-08 16:01:53.129 | Socket (3) | Socket gracefully closed by remote side. 2024-10-08 16:01:53.129 | Socket (3) | Closed. 2024-10-08 16:01:53.245 | HD Request # 16 | Setting DTC encoding to Binary VLS 2024-10-08 16:01:53.245 | HD Request # 16 | Sending historical data logon request message. 2024-10-08 16:01:53.823 | HD Request # 16 | Requesting Intraday data. Start date-time: 2013-01-15 00:00:00. Record interval: 0. Symbol: GCJ13 2024-10-08 16:01:53.915 | HD Request # 16 | Decompressing data. 2024-10-08 16:01:54.120 | HD Request # 16 | Receiving Intraday data for GCJ13_FUT_CME starting at 2013-01-15 00:28:14.000000 2024-10-08 16:01:54.332 | HD Request # 16 | Timestamp of first Intraday data file record written: 2013-01-15 00:28:14.000000. 2024-10-08 16:02:16.860 | Socket (2) | CloseSocket call. 2024-10-08 16:02:16.860 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 16:02:16.860 | Historical data download thread signaled to stop. 2024-10-08 16:02:16.860 | HD Request # 16 | Received 4203313 Intraday data records from 2013-01-15 00:28:14.000000 to 2013-04-26 17:56:08.001000 (101.7 days. Delay: 11.5 years) and wrote 4203313 records for GCJ13_FUT_CME 2024-10-08 16:02:16.871 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2013-04-26 16:56:08.001000 2024-10-08 16:02:16.871 | HD Request # 16 | Completion time: 23s. 2024-10-08 16:02:16.871 | HD Request # 16 | Intraday data download complete for GCJ13_FUT_CME. Unique request ID: 58 2024-10-08 16:02:16.871 | Removing historical data download ID 58. 2024-10-08 16:02:16.871 | Real-time Intraday chart data file updates started for GCJ13_FUT_CME 2024-10-08 16:02:16.871 | Intraday chart data file opened for GCJ13_FUT_CME 2024-10-08 16:02:16.871 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2024-10-08 16:02:16.871 | 2024-10-08 16:02:16.871 | Triggering next historical data download in queue. 2024-10-08 16:02:16.871 | HD Request # 17 | Downloading Intraday chart data for GCM13_FUT_CME to the file GCM13_FUT_CME.scid. Service: comex 2024-10-08 16:02:16.871 | HD Request # 17 | Download start date-time: 2013-03-13 00:00:00.000000. File last date-time: 00:00:00.000000 2024-10-08 16:02:16.871 | HD Request # 17 | Using server: ds32.sierracharts.com port 10150 2024-10-08 16:02:16.872 | Socket (3) | Creating socket. 2024-10-08 16:02:16.872 | Socket (3) | New receive buffer size: 0 2024-10-08 16:02:16.872 | Socket (3) | Connecting to IP: 67.214.125.3. 2024-10-08 16:02:16.954 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 16:02:16.954 | Socket (2) | Closed. 2024-10-08 16:02:17.054 | HD Request # 17 | Setting DTC encoding to Binary VLS 2024-10-08 16:02:17.054 | HD Request # 17 | Sending historical data logon request message. 2024-10-08 16:02:18.375 | HD Request # 17 | Requesting Intraday data. Start date-time: 2013-03-13 00:00:00. Record interval: 0. Symbol: GCM13 2024-10-08 16:02:18.469 | HD Request # 17 | Decompressing data. 2024-10-08 16:02:18.678 | HD Request # 17 | Receiving Intraday data for GCM13_FUT_CME starting at 2013-03-13 00:08:40.000000 2024-10-08 16:02:18.887 | HD Request # 17 | Timestamp of first Intraday data file record written: 2013-03-13 00:08:40.000000. 2024-10-08 16:03:14.498 | DTC - Sub Instance | Waiting for socket receive thread to end 2024-10-08 16:03:14.499 | DTC Client socket (1) | CloseSocket call. 2024-10-08 16:03:14.499 | DTC - Sub Instance | Disconnected. 2024-10-08 16:03:14.499 | Canceling queued historical data download request for GCQ13_FUT_CME Intraday data. 2024-10-08 16:03:14.499 | Removing historical data download ID 60. 2024-10-08 16:03:14.499 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-10-08 16:03:14.500 | Canceling queued historical data download request for GCZ13_FUT_CME Intraday data. 2024-10-08 16:03:14.500 | Removing historical data download ID 61. 2024-10-08 16:03:14.500 | Canceling queued historical data download request for GCG14_FUT_CME Intraday data. 2024-10-08 16:03:14.500 | Removing historical data download ID 62. 2024-10-08 16:03:14.500 | Canceling queued historical data download request for GCJ14_FUT_CME Intraday data. 2024-10-08 16:03:14.500 | Removing historical data download ID 63. 2024-10-08 16:03:14.500 | Canceling queued historical data download request for GCM14_FUT_CME Intraday data. 2024-10-08 16:03:14.500 | Removing historical data download ID 64. 2024-10-08 16:03:14.501 | Canceling queued historical data download request for GCQ14_FUT_CME Intraday data. 2024-10-08 16:03:14.501 | Removing historical data download ID 65. 2024-10-08 16:03:14.501 | Canceling queued historical data download request for GCZ14_FUT_CME Intraday data. 2024-10-08 16:03:14.501 | Removing historical data download ID 66. 2024-10-08 16:03:14.501 | Canceling queued historical data download request for GCG15_FUT_CME Intraday data. 2024-10-08 16:03:14.501 | Removing historical data download ID 67. 2024-10-08 16:03:14.502 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-10-08 16:03:14.502 | DTC Client socket (1) | Closed. 2024-10-08 16:03:14.502 | Canceling queued historical data download request for GCJ15_FUT_CME Intraday data. 2024-10-08 16:03:14.502 | Removing historical data download ID 68. 2024-10-08 16:03:14.503 | Canceling queued historical data download request for GCM15_FUT_CME Intraday data. 2024-10-08 16:03:14.503 | Removing historical data download ID 69. 2024-10-08 16:03:14.504 | Canceling queued historical data download request for GCQ15_FUT_CME Intraday data. 2024-10-08 16:03:14.504 | Removing historical data download ID 70. 2024-10-08 16:03:14.504 | Canceling queued historical data download request for GCZ15_FUT_CME Intraday data. 2024-10-08 16:03:14.504 | Removing historical data download ID 71. 2024-10-08 16:03:14.504 | Canceling queued historical data download request for GCG16_FUT_CME Intraday data. 2024-10-08 16:03:14.504 | Removing historical data download ID 72. 2024-10-08 16:03:14.505 | Canceling queued historical data download request for GCJ16_FUT_CME Intraday data. 2024-10-08 16:03:14.505 | Removing historical data download ID 73. 2024-10-08 16:03:14.505 | Canceling queued historical data download request for GCM16_FUT_CME Intraday data. 2024-10-08 16:03:14.505 | Removing historical data download ID 74. 2024-10-08 16:03:14.505 | Canceling queued historical data download request for GCQ16_FUT_CME Intraday data. 2024-10-08 16:03:14.505 | Removing historical data download ID 75. 2024-10-08 16:03:14.505 | Canceling queued historical data download request for GCZ16_FUT_CME Intraday data. 2024-10-08 16:03:14.505 | Removing historical data download ID 76. 2024-10-08 16:03:14.506 | Canceling queued historical data download request for GCG17_FUT_CME Intraday data. 2024-10-08 16:03:14.506 | Removing historical data download ID 77. 2024-10-08 16:03:14.506 | Canceling queued historical data download request for GCJ17_FUT_CME Intraday data. 2024-10-08 16:03:14.506 | Removing historical data download ID 78. 2024-10-08 16:03:14.506 | Canceling queued historical data download request for GCM17_FUT_CME Intraday data. 2024-10-08 16:03:14.506 | Removing historical data download ID 79. 2024-10-08 16:03:14.506 | Canceling queued historical data download request for GCQ17_FUT_CME Intraday data. 2024-10-08 16:03:14.506 | Removing historical data download ID 80. 2024-10-08 16:03:14.507 | Canceling queued historical data download request for GCZ17_FUT_CME Intraday data. 2024-10-08 16:03:14.507 | Removing historical data download ID 81. 2024-10-08 16:03:14.507 | Canceling queued historical data download request for GCG18_FUT_CME Intraday data. 2024-10-08 16:03:14.507 | Removing historical data download ID 82. 2024-10-08 16:03:14.507 | Canceling queued historical data download request for GCJ18_FUT_CME Intraday data. 2024-10-08 16:03:14.507 | Removing historical data download ID 83. 2024-10-08 16:03:14.507 | Canceling queued historical data download request for GCM18_FUT_CME Intraday data. 2024-10-08 16:03:14.507 | Removing historical data download ID 84. 2024-10-08 16:03:14.508 | Canceling queued historical data download request for GCQ18_FUT_CME Intraday data. 2024-10-08 16:03:14.508 | Removing historical data download ID 85. 2024-10-08 16:03:14.508 | Canceling queued historical data download request for GCZ18_FUT_CME Intraday data. 2024-10-08 16:03:14.508 | Removing historical data download ID 86. 2024-10-08 16:03:14.508 | Canceling queued historical data download request for GCG19_FUT_CME Intraday data. 2024-10-08 16:03:14.508 | Removing historical data download ID 87. 2024-10-08 16:03:14.508 | Canceling queued historical data download request for GCJ19_FUT_CME Intraday data. 2024-10-08 16:03:14.508 | Removing historical data download ID 88. 2024-10-08 16:03:14.509 | Canceling queued historical data download request for GCM19_FUT_CME Intraday data. 2024-10-08 16:03:14.509 | Removing historical data download ID 89. 2024-10-08 16:03:14.509 | Canceling queued historical data download request for GCQ19_FUT_CME Intraday data. 2024-10-08 16:03:14.509 | Removing historical data download ID 90. 2024-10-08 16:03:14.509 | Canceling queued historical data download request for GCZ19_FUT_CME Intraday data. 2024-10-08 16:03:14.509 | Removing historical data download ID 91. 2024-10-08 16:03:14.509 | Canceling queued historical data download request for GCG20_FUT_CME Intraday data. 2024-10-08 16:03:14.509 | Removing historical data download ID 92. 2024-10-08 16:03:14.509 | Canceling queued historical data download request for GCJ20_FUT_CME Intraday data. 2024-10-08 16:03:14.509 | Removing historical data download ID 93. 2024-10-08 16:03:14.510 | Canceling queued historical data download request for GCM20_FUT_CME Intraday data. 2024-10-08 16:03:14.510 | Removing historical data download ID 94. 2024-10-08 16:03:14.510 | Canceling queued historical data download request for GCQ20_FUT_CME Intraday data. 2024-10-08 16:03:14.510 | Removing historical data download ID 95. 2024-10-08 16:03:14.510 | Canceling queued historical data download request for GCZ20_FUT_CME Intraday data. 2024-10-08 16:03:14.510 | Removing historical data download ID 96. 2024-10-08 16:03:14.511 | Canceling queued historical data download request for GCG21_FUT_CME Intraday data. 2024-10-08 16:03:14.511 | Removing historical data download ID 97. 2024-10-08 16:03:14.511 | Canceling queued historical data download request for GCJ21_FUT_CME Intraday data. 2024-10-08 16:03:14.511 | Removing historical data download ID 98. 2024-10-08 16:03:14.511 | Canceling queued historical data download request for GCM21_FUT_CME Intraday data. 2024-10-08 16:03:14.511 | Removing historical data download ID 99. 2024-10-08 16:03:14.511 | Canceling queued historical data download request for GCQ21_FUT_CME Intraday data. 2024-10-08 16:03:14.511 | Removing historical data download ID 100. 2024-10-08 16:03:14.512 | Canceling queued historical data download request for GCZ21_FUT_CME Intraday data. 2024-10-08 16:03:14.512 | Removing historical data download ID 101. 2024-10-08 16:03:14.512 | Canceling queued historical data download request for GCG22_FUT_CME Intraday data. 2024-10-08 16:03:14.512 | Removing historical data download ID 102. 2024-10-08 16:03:14.512 | Canceling queued historical data download request for GCJ22_FUT_CME Intraday data. 2024-10-08 16:03:14.512 | Removing historical data download ID 103. 2024-10-08 16:03:14.513 | Canceling queued historical data download request for GCM22_FUT_CME Intraday data. 2024-10-08 16:03:14.513 | Removing historical data download ID 104. 2024-10-08 16:03:14.513 | Canceling queued historical data download request for GCQ22_FUT_CME Intraday data. 2024-10-08 16:03:14.513 | Removing historical data download ID 105. 2024-10-08 16:03:14.513 | Canceling queued historical data download request for GCZ22_FUT_CME Intraday data. 2024-10-08 16:03:14.513 | Removing historical data download ID 106. 2024-10-08 16:03:14.513 | Canceling queued historical data download request for GCG23_FUT_CME Intraday data. 2024-10-08 16:03:14.513 | Removing historical data download ID 107. 2024-10-08 16:03:14.513 | Canceling queued historical data download request for GCJ23_FUT_CME Intraday data. 2024-10-08 16:03:14.513 | Removing historical data download ID 108. 2024-10-08 16:03:14.514 | Canceling queued historical data download request for GCM23_FUT_CME Intraday data. 2024-10-08 16:03:14.514 | Removing historical data download ID 109. 2024-10-08 16:03:14.514 | Canceling queued historical data download request for GCQ23_FUT_CME Intraday data. 2024-10-08 16:03:14.514 | Removing historical data download ID 110. 2024-10-08 16:03:14.514 | Canceling queued historical data download request for GCZ23_FUT_CME Intraday data. 2024-10-08 16:03:14.514 | Removing historical data download ID 111. 2024-10-08 16:03:14.514 | Canceling queued historical data download request for GCG24_FUT_CME Intraday data. 2024-10-08 16:03:14.514 | Removing historical data download ID 112. 2024-10-08 16:03:14.514 | Canceling queued historical data download request for GCJ24_FUT_CME Intraday data. 2024-10-08 16:03:14.514 | Removing historical data download ID 113. 2024-10-08 16:03:14.514 | Canceling queued historical data download request for GCM24_FUT_CME Intraday data. 2024-10-08 16:03:14.514 | Removing historical data download ID 114. 2024-10-08 16:03:14.515 | Canceling queued historical data download request for GCQ24_FUT_CME Intraday data. 2024-10-08 16:03:14.515 | Removing historical data download ID 115. 2024-10-08 16:03:14.515 | Canceling queued historical data download request for GCZ24_FUT_CME Daily data. 2024-10-08 16:03:14.515 | Removing historical data download ID 116. 2024-10-08 16:03:14.515 | HD Request # 17 | Active download canceled. 2024-10-08 16:03:14.515 | Historical data download thread signaled to stop. 2024-10-08 16:03:14.515 | Socket (3) | CloseSocket call. 2024-10-08 16:03:14.515 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-10-08 16:03:14.516 | HD Request # 17 | Received 3691534 Intraday data records from 2013-03-13 00:08:40.000000 to 2013-05-02 19:09:12.000000 (50.8 days. Delay: 11.4 years) and wrote 3691534 records for GCM13_FUT_CME 2024-10-08 16:03:14.516 | HD Request # 17 | Completion time: 58s. 2024-10-08 16:03:14.517 | HD Request # 17 | Intraday data download complete for GCM13_FUT_CME. Unique request ID: 59 2024-10-08 16:03:14.517 | Removing historical data download ID 59. 2024-10-08 16:03:14.517 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2024-10-08 16:03:14.517 | 2024-10-08 16:03:14.517 | No download requests in the queue to start downloads for. 2024-10-08 16:03:14.517 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-10-08 16:03:14.723 | GCZ24_FUT_CME [CV] Daily #8 | Reloading chart. 2024-10-08 16:03:15.331 | Unable to determine transition date based on volume from files: GCM16_FUT_CME.dly, GCQ16_FUT_CME.dly 2024-10-08 16:03:15.331 | The GCQ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.331 | Unable to determine transition date based on volume from files: GCQ16_FUT_CME.dly, GCZ16_FUT_CME.dly 2024-10-08 16:03:15.331 | The GCZ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.331 | Unable to determine transition date based on volume from files: GCZ16_FUT_CME.dly, GCG17_FUT_CME.dly 2024-10-08 16:03:15.331 | The GCG17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.331 | Unable to determine transition date based on volume from files: GCG17_FUT_CME.dly, GCJ17_FUT_CME.dly 2024-10-08 16:03:15.331 | The GCJ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.331 | Unable to determine transition date based on volume from files: GCJ17_FUT_CME.dly, GCM17_FUT_CME.dly 2024-10-08 16:03:15.331 | The GCM17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.331 | Unable to determine transition date based on volume from files: GCM17_FUT_CME.dly, GCQ17_FUT_CME.dly 2024-10-08 16:03:15.331 | The GCQ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.332 | Unable to determine transition date based on volume from files: GCQ17_FUT_CME.dly, GCZ17_FUT_CME.dly 2024-10-08 16:03:15.332 | The GCZ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.332 | Unable to determine transition date based on volume from files: GCZ17_FUT_CME.dly, GCG18_FUT_CME.dly 2024-10-08 16:03:15.332 | The GCG18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.332 | Unable to determine transition date based on volume from files: GCG18_FUT_CME.dly, GCJ18_FUT_CME.dly 2024-10-08 16:03:15.332 | The GCJ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.332 | Unable to determine transition date based on volume from files: GCJ18_FUT_CME.dly, GCM18_FUT_CME.dly 2024-10-08 16:03:15.332 | The GCM18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.332 | Unable to determine transition date based on volume from files: GCM18_FUT_CME.dly, GCQ18_FUT_CME.dly 2024-10-08 16:03:15.332 | The GCQ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.332 | Unable to determine transition date based on volume from files: GCQ18_FUT_CME.dly, GCZ18_FUT_CME.dly 2024-10-08 16:03:15.332 | The GCZ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.333 | Unable to determine transition date based on volume from files: GCZ18_FUT_CME.dly, GCG19_FUT_CME.dly 2024-10-08 16:03:15.333 | The GCG19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.333 | Unable to determine transition date based on volume from files: GCG19_FUT_CME.dly, GCJ19_FUT_CME.dly 2024-10-08 16:03:15.333 | The GCJ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.333 | Unable to determine transition date based on volume from files: GCJ19_FUT_CME.dly, GCM19_FUT_CME.dly 2024-10-08 16:03:15.333 | The GCM19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.333 | Unable to determine transition date based on volume from files: GCM19_FUT_CME.dly, GCQ19_FUT_CME.dly 2024-10-08 16:03:15.333 | The GCQ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.333 | Unable to determine transition date based on volume from files: GCQ19_FUT_CME.dly, GCZ19_FUT_CME.dly 2024-10-08 16:03:15.333 | The GCZ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.333 | Unable to determine transition date based on volume from files: GCZ19_FUT_CME.dly, GCG20_FUT_CME.dly 2024-10-08 16:03:15.333 | The GCG20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.334 | Unable to determine transition date based on volume from files: GCG20_FUT_CME.dly, GCJ20_FUT_CME.dly 2024-10-08 16:03:15.334 | The GCJ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.334 | Unable to determine transition date based on volume from files: GCJ20_FUT_CME.dly, GCM20_FUT_CME.dly 2024-10-08 16:03:15.334 | The GCM20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.334 | Unable to determine transition date based on volume from files: GCM20_FUT_CME.dly, GCQ20_FUT_CME.dly 2024-10-08 16:03:15.334 | The GCQ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.334 | Unable to determine transition date based on volume from files: GCQ20_FUT_CME.dly, GCZ20_FUT_CME.dly 2024-10-08 16:03:15.334 | The GCZ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.334 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:03:15.334 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.335 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:03:15.335 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.335 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:03:15.335 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.335 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:03:15.335 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.335 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:03:15.335 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.335 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:03:15.335 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.335 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:03:15.335 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.336 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:03:15.336 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.336 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:03:15.336 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.336 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:03:15.336 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.336 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:03:15.336 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.336 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:03:15.336 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.336 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:03:15.336 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.337 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:03:15.337 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.337 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:03:15.337 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.337 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:15.337 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.337 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:15.337 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.337 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:15.337 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.337 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:15.337 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:15.366 | GCZ24_FUT_CME [CV] Daily #3 | Reloading chart. 2024-10-08 16:03:16.009 | Unable to determine transition date based on volume from files: GCM16_FUT_CME.dly, GCQ16_FUT_CME.dly 2024-10-08 16:03:16.009 | The GCQ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.009 | Unable to determine transition date based on volume from files: GCQ16_FUT_CME.dly, GCZ16_FUT_CME.dly 2024-10-08 16:03:16.009 | The GCZ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.010 | Unable to determine transition date based on volume from files: GCZ16_FUT_CME.dly, GCG17_FUT_CME.dly 2024-10-08 16:03:16.010 | The GCG17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.010 | Unable to determine transition date based on volume from files: GCG17_FUT_CME.dly, GCJ17_FUT_CME.dly 2024-10-08 16:03:16.010 | The GCJ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.010 | Unable to determine transition date based on volume from files: GCJ17_FUT_CME.dly, GCM17_FUT_CME.dly 2024-10-08 16:03:16.010 | The GCM17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.011 | Unable to determine transition date based on volume from files: GCM17_FUT_CME.dly, GCQ17_FUT_CME.dly 2024-10-08 16:03:16.011 | The GCQ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.011 | Unable to determine transition date based on volume from files: GCQ17_FUT_CME.dly, GCZ17_FUT_CME.dly 2024-10-08 16:03:16.011 | The GCZ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.011 | Unable to determine transition date based on volume from files: GCZ17_FUT_CME.dly, GCG18_FUT_CME.dly 2024-10-08 16:03:16.011 | The GCG18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.011 | Unable to determine transition date based on volume from files: GCG18_FUT_CME.dly, GCJ18_FUT_CME.dly 2024-10-08 16:03:16.012 | The GCJ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.012 | Unable to determine transition date based on volume from files: GCJ18_FUT_CME.dly, GCM18_FUT_CME.dly 2024-10-08 16:03:16.012 | The GCM18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.012 | Unable to determine transition date based on volume from files: GCM18_FUT_CME.dly, GCQ18_FUT_CME.dly 2024-10-08 16:03:16.012 | The GCQ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.012 | Unable to determine transition date based on volume from files: GCQ18_FUT_CME.dly, GCZ18_FUT_CME.dly 2024-10-08 16:03:16.012 | The GCZ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.013 | Unable to determine transition date based on volume from files: GCZ18_FUT_CME.dly, GCG19_FUT_CME.dly 2024-10-08 16:03:16.013 | The GCG19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.013 | Unable to determine transition date based on volume from files: GCG19_FUT_CME.dly, GCJ19_FUT_CME.dly 2024-10-08 16:03:16.013 | The GCJ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.013 | Unable to determine transition date based on volume from files: GCJ19_FUT_CME.dly, GCM19_FUT_CME.dly 2024-10-08 16:03:16.013 | The GCM19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.013 | Unable to determine transition date based on volume from files: GCM19_FUT_CME.dly, GCQ19_FUT_CME.dly 2024-10-08 16:03:16.013 | The GCQ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.014 | Unable to determine transition date based on volume from files: GCQ19_FUT_CME.dly, GCZ19_FUT_CME.dly 2024-10-08 16:03:16.014 | The GCZ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.014 | Unable to determine transition date based on volume from files: GCZ19_FUT_CME.dly, GCG20_FUT_CME.dly 2024-10-08 16:03:16.014 | The GCG20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.014 | Unable to determine transition date based on volume from files: GCG20_FUT_CME.dly, GCJ20_FUT_CME.dly 2024-10-08 16:03:16.014 | The GCJ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.015 | Unable to determine transition date based on volume from files: GCJ20_FUT_CME.dly, GCM20_FUT_CME.dly 2024-10-08 16:03:16.015 | The GCM20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.015 | Unable to determine transition date based on volume from files: GCM20_FUT_CME.dly, GCQ20_FUT_CME.dly 2024-10-08 16:03:16.015 | The GCQ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.015 | Unable to determine transition date based on volume from files: GCQ20_FUT_CME.dly, GCZ20_FUT_CME.dly 2024-10-08 16:03:16.015 | The GCZ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.015 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:03:16.015 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.016 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:03:16.016 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.016 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:03:16.016 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.016 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:03:16.016 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.016 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:03:16.016 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.017 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:03:16.017 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.018 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:03:16.018 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.018 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:03:16.018 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.018 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:16.018 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.018 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:16.018 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.018 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:16.018 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.018 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:16.018 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.053 | GCZ24_FUT_CME [CV] Daily #8 | Chart data loading complete. 2024-10-08 16:03:16.078 | GCZ24_FUT_CME [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 16:03:16.078 | GCZ24_FUT_CME [CBV] #5 | Reloading chart. 2024-10-08 16:03:16.078 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:03:16.078 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.079 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:03:16.079 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.080 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:16.080 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.081 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:16.081 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.081 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:16.081 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.093 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2020-12-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.093 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.094 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.094 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.095 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.095 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.097 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-06-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.097 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.098 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-08-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.098 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.099 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.099 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.100 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.100 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.101 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.101 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.102 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.102 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.104 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.104 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.105 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.105 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.106 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.106 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.107 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.107 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.108 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.108 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.109 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.109 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.110 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.110 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.111 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.111 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.113 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.113 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.114 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.114 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.115 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.115 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.121 | GCZ24_FUT_CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 16:03:16.122 | GCZ24_FUT_CME [CV] #4 | Reloading chart. 2024-10-08 16:03:16.122 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:16.122 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.123 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:16.123 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.123 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:16.123 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.123 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:16.123 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.156 | GCZ24_FUT_CME [CBV] #6 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 16:03:16.158 | GCZ24_FUT_CME [CBV] #6 | Reloading chart. 2024-10-08 16:03:16.158 | Unable to determine transition date based on volume from files: GCQ10_FUT_CME.dly, GCZ10_FUT_CME.dly 2024-10-08 16:03:16.158 | The GCZ10_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.158 | Unable to determine transition date based on volume from files: GCZ10_FUT_CME.dly, GCG11_FUT_CME.dly 2024-10-08 16:03:16.158 | The GCG11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.158 | Unable to determine transition date based on volume from files: GCG11_FUT_CME.dly, GCJ11_FUT_CME.dly 2024-10-08 16:03:16.158 | The GCJ11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.158 | Unable to determine transition date based on volume from files: GCJ11_FUT_CME.dly, GCM11_FUT_CME.dly 2024-10-08 16:03:16.158 | The GCM11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.159 | Unable to determine transition date based on volume from files: GCM11_FUT_CME.dly, GCQ11_FUT_CME.dly 2024-10-08 16:03:16.159 | The GCQ11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.159 | Unable to determine transition date based on volume from files: GCQ11_FUT_CME.dly, GCZ11_FUT_CME.dly 2024-10-08 16:03:16.159 | The GCZ11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.159 | Unable to determine transition date based on volume from files: GCZ11_FUT_CME.dly, GCG12_FUT_CME.dly 2024-10-08 16:03:16.159 | The GCG12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.159 | Unable to determine transition date based on volume from files: GCG12_FUT_CME.dly, GCJ12_FUT_CME.dly 2024-10-08 16:03:16.159 | The GCJ12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.159 | Unable to determine transition date based on volume from files: GCJ12_FUT_CME.dly, GCM12_FUT_CME.dly 2024-10-08 16:03:16.159 | The GCM12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.159 | Unable to determine transition date based on volume from files: GCM12_FUT_CME.dly, GCQ12_FUT_CME.dly 2024-10-08 16:03:16.159 | The GCQ12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.406 | Unable to determine transition date based on volume from files: GCM16_FUT_CME.dly, GCQ16_FUT_CME.dly 2024-10-08 16:03:16.406 | The GCQ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.406 | Unable to determine transition date based on volume from files: GCQ16_FUT_CME.dly, GCZ16_FUT_CME.dly 2024-10-08 16:03:16.406 | The GCZ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.406 | Unable to determine transition date based on volume from files: GCZ16_FUT_CME.dly, GCG17_FUT_CME.dly 2024-10-08 16:03:16.406 | The GCG17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.407 | Unable to determine transition date based on volume from files: GCG17_FUT_CME.dly, GCJ17_FUT_CME.dly 2024-10-08 16:03:16.407 | The GCJ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.407 | Unable to determine transition date based on volume from files: GCJ17_FUT_CME.dly, GCM17_FUT_CME.dly 2024-10-08 16:03:16.407 | The GCM17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.407 | Unable to determine transition date based on volume from files: GCM17_FUT_CME.dly, GCQ17_FUT_CME.dly 2024-10-08 16:03:16.407 | The GCQ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.407 | Unable to determine transition date based on volume from files: GCQ17_FUT_CME.dly, GCZ17_FUT_CME.dly 2024-10-08 16:03:16.407 | The GCZ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.407 | Unable to determine transition date based on volume from files: GCZ17_FUT_CME.dly, GCG18_FUT_CME.dly 2024-10-08 16:03:16.407 | The GCG18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.407 | Unable to determine transition date based on volume from files: GCG18_FUT_CME.dly, GCJ18_FUT_CME.dly 2024-10-08 16:03:16.407 | The GCJ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.408 | Unable to determine transition date based on volume from files: GCJ18_FUT_CME.dly, GCM18_FUT_CME.dly 2024-10-08 16:03:16.408 | The GCM18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.408 | Unable to determine transition date based on volume from files: GCM18_FUT_CME.dly, GCQ18_FUT_CME.dly 2024-10-08 16:03:16.408 | The GCQ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.408 | Unable to determine transition date based on volume from files: GCQ18_FUT_CME.dly, GCZ18_FUT_CME.dly 2024-10-08 16:03:16.408 | The GCZ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.408 | Unable to determine transition date based on volume from files: GCZ18_FUT_CME.dly, GCG19_FUT_CME.dly 2024-10-08 16:03:16.408 | The GCG19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.408 | Unable to determine transition date based on volume from files: GCG19_FUT_CME.dly, GCJ19_FUT_CME.dly 2024-10-08 16:03:16.408 | The GCJ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.408 | Unable to determine transition date based on volume from files: GCJ19_FUT_CME.dly, GCM19_FUT_CME.dly 2024-10-08 16:03:16.408 | The GCM19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.408 | Unable to determine transition date based on volume from files: GCM19_FUT_CME.dly, GCQ19_FUT_CME.dly 2024-10-08 16:03:16.408 | The GCQ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.409 | Unable to determine transition date based on volume from files: GCQ19_FUT_CME.dly, GCZ19_FUT_CME.dly 2024-10-08 16:03:16.409 | The GCZ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.409 | Unable to determine transition date based on volume from files: GCZ19_FUT_CME.dly, GCG20_FUT_CME.dly 2024-10-08 16:03:16.409 | The GCG20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.409 | Unable to determine transition date based on volume from files: GCG20_FUT_CME.dly, GCJ20_FUT_CME.dly 2024-10-08 16:03:16.409 | The GCJ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.409 | Unable to determine transition date based on volume from files: GCJ20_FUT_CME.dly, GCM20_FUT_CME.dly 2024-10-08 16:03:16.409 | The GCM20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.409 | Unable to determine transition date based on volume from files: GCM20_FUT_CME.dly, GCQ20_FUT_CME.dly 2024-10-08 16:03:16.409 | The GCQ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.409 | Unable to determine transition date based on volume from files: GCQ20_FUT_CME.dly, GCZ20_FUT_CME.dly 2024-10-08 16:03:16.409 | The GCZ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.409 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:03:16.409 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.410 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:03:16.410 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.410 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:03:16.410 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.410 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:03:16.410 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.410 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:03:16.410 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.410 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:03:16.410 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.410 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:03:16.410 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.410 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:03:16.410 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:03:16.411 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:03:16.411 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:03:16.411 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:03:16.411 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:03:16.411 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:03:16.411 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:03:16.411 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.411 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:16.412 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.412 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:16.412 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.412 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:16.412 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.412 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:16.412 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:16.424 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2010-08-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ10_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.424 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ10_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.425 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2010-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ10_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.425 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.426 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.426 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.427 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.427 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.428 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.428 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.430 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.430 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.431 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.431 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.432 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.432 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.433 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-04-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.433 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.435 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.435 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.436 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.436 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.993 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-04-26 from file. C:\Sierra\SierraChartInstance_2\Data\GCM16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.994 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.994 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.995 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.995 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.996 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.996 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.997 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.997 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.998 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.998 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.999 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:16.999 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.001 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.001 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.002 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.002 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.004 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.004 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.005 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-04-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.005 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.007 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.007 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.008 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.008 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.010 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.010 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.011 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.011 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.013 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.013 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.014 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.014 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.015 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.015 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.017 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.017 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.019 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.019 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.020 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.020 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.022 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-06-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCM20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.022 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.023 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.023 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.024 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-12-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.024 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.026 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.026 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.027 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.027 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.029 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-06-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.029 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.030 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-08-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.030 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.031 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.031 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.033 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.033 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.034 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.034 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.036 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.036 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.037 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.037 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.039 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.039 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.040 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.040 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.042 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.042 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.043 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.043 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.045 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.045 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.046 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.046 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.048 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.048 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.049 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.049 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.051 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.051 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.053 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.053 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.098 | GCZ24_FUT_CME [CV] Daily #3 | Chart data loading complete. 2024-10-08 16:03:17.122 | GCZ24_FUT_CME [CBV] 60 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-10-08 16:03:17.123 | GCZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 16:03:17.123 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:17.123 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.124 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:17.124 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.135 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.135 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.136 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.136 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.137 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.137 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.143 | GCZ24_FUT_CME [CBV] #5 | Reloading chart. 2024-10-08 16:03:17.184 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:03:17.184 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.185 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:03:17.185 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.185 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:03:17.185 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.185 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:03:17.185 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.185 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:03:17.185 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.185 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:03:17.185 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.185 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:03:17.185 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.186 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:03:17.186 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.186 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:03:17.186 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.186 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:03:17.186 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.186 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:03:17.186 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.186 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:03:17.186 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.186 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:03:17.186 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.186 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:03:17.186 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.187 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:03:17.187 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.187 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:17.187 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.187 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:17.187 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.187 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:17.187 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.187 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:17.187 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.199 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2020-12-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.199 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.201 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.201 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.202 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.202 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.203 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-06-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.203 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.204 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-08-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.204 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.205 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2021-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.205 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.207 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.207 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.208 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.208 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.209 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.209 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.210 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.210 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.211 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2022-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.211 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.212 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.212 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.213 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.213 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.214 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.214 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.216 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.216 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.217 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2023-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.217 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.219 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.219 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.220 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.220 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.221 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.221 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.222 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 2024-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.222 | GCZ24_FUT_CME [CBV] #5 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:17.222 | 2024-10-08 16:03:17.222 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-10-08 16:03:17.222 | DTC Client socket (1) | Creating socket. 2024-10-08 16:03:17.222 | DTC Client socket (1) | New receive buffer size: 0 2024-10-08 16:03:17.222 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-10-08 16:03:17.224 | GCZ24_FUT_CME [CV] #4 | Reloading chart. 2024-10-08 16:03:17.241 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:17.241 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.241 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:17.241 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.241 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:17.241 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.241 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:17.241 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.253 | DTC - Sub Instance | Network connection to server complete. 2024-10-08 16:03:17.253 | DTC - Sub Instance | Starting socket receive thread. 2024-10-08 16:03:17.253 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-10-08 16:03:17.254 | GCZ24_FUT_CME [CBV] #6 | Reloading chart. 2024-10-08 16:03:17.734 | Unable to determine transition date based on volume from files: GCQ10_FUT_CME.dly, GCZ10_FUT_CME.dly 2024-10-08 16:03:17.734 | The GCZ10_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.734 | Unable to determine transition date based on volume from files: GCZ10_FUT_CME.dly, GCG11_FUT_CME.dly 2024-10-08 16:03:17.734 | The GCG11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.735 | Unable to determine transition date based on volume from files: GCG11_FUT_CME.dly, GCJ11_FUT_CME.dly 2024-10-08 16:03:17.735 | The GCJ11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.735 | Unable to determine transition date based on volume from files: GCJ11_FUT_CME.dly, GCM11_FUT_CME.dly 2024-10-08 16:03:17.735 | The GCM11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.735 | Unable to determine transition date based on volume from files: GCM11_FUT_CME.dly, GCQ11_FUT_CME.dly 2024-10-08 16:03:17.735 | The GCQ11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.735 | Unable to determine transition date based on volume from files: GCQ11_FUT_CME.dly, GCZ11_FUT_CME.dly 2024-10-08 16:03:17.735 | The GCZ11_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.735 | Unable to determine transition date based on volume from files: GCZ11_FUT_CME.dly, GCG12_FUT_CME.dly 2024-10-08 16:03:17.735 | The GCG12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.735 | Unable to determine transition date based on volume from files: GCG12_FUT_CME.dly, GCJ12_FUT_CME.dly 2024-10-08 16:03:17.735 | The GCJ12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.736 | Unable to determine transition date based on volume from files: GCJ12_FUT_CME.dly, GCM12_FUT_CME.dly 2024-10-08 16:03:17.736 | The GCM12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.736 | Unable to determine transition date based on volume from files: GCM12_FUT_CME.dly, GCQ12_FUT_CME.dly 2024-10-08 16:03:17.736 | The GCQ12_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.989 | Unable to determine transition date based on volume from files: GCM16_FUT_CME.dly, GCQ16_FUT_CME.dly 2024-10-08 16:03:17.989 | The GCQ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.989 | Unable to determine transition date based on volume from files: GCQ16_FUT_CME.dly, GCZ16_FUT_CME.dly 2024-10-08 16:03:17.989 | The GCZ16_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.989 | Unable to determine transition date based on volume from files: GCZ16_FUT_CME.dly, GCG17_FUT_CME.dly 2024-10-08 16:03:17.989 | The GCG17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.989 | Unable to determine transition date based on volume from files: GCG17_FUT_CME.dly, GCJ17_FUT_CME.dly 2024-10-08 16:03:17.989 | The GCJ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.989 | Unable to determine transition date based on volume from files: GCJ17_FUT_CME.dly, GCM17_FUT_CME.dly 2024-10-08 16:03:17.989 | The GCM17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.989 | Unable to determine transition date based on volume from files: GCM17_FUT_CME.dly, GCQ17_FUT_CME.dly 2024-10-08 16:03:17.989 | The GCQ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.990 | Unable to determine transition date based on volume from files: GCQ17_FUT_CME.dly, GCZ17_FUT_CME.dly 2024-10-08 16:03:17.990 | The GCZ17_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.990 | Unable to determine transition date based on volume from files: GCZ17_FUT_CME.dly, GCG18_FUT_CME.dly 2024-10-08 16:03:17.990 | The GCG18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.990 | Unable to determine transition date based on volume from files: GCG18_FUT_CME.dly, GCJ18_FUT_CME.dly 2024-10-08 16:03:17.990 | The GCJ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.990 | Unable to determine transition date based on volume from files: GCJ18_FUT_CME.dly, GCM18_FUT_CME.dly 2024-10-08 16:03:17.990 | The GCM18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.990 | Unable to determine transition date based on volume from files: GCM18_FUT_CME.dly, GCQ18_FUT_CME.dly 2024-10-08 16:03:17.990 | The GCQ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.990 | Unable to determine transition date based on volume from files: GCQ18_FUT_CME.dly, GCZ18_FUT_CME.dly 2024-10-08 16:03:17.990 | The GCZ18_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCZ18_FUT_CME.dly, GCG19_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCG19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCG19_FUT_CME.dly, GCJ19_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCJ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCJ19_FUT_CME.dly, GCM19_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCM19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCM19_FUT_CME.dly, GCQ19_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCQ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCQ19_FUT_CME.dly, GCZ19_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCZ19_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCZ19_FUT_CME.dly, GCG20_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCG20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCG20_FUT_CME.dly, GCJ20_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCJ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.991 | Unable to determine transition date based on volume from files: GCJ20_FUT_CME.dly, GCM20_FUT_CME.dly 2024-10-08 16:03:17.991 | The GCM20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCM20_FUT_CME.dly, GCQ20_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCQ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCQ20_FUT_CME.dly, GCZ20_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCZ20_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCZ20_FUT_CME.dly, GCG21_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCG21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCG21_FUT_CME.dly, GCJ21_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCJ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCJ21_FUT_CME.dly, GCM21_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCM21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCM21_FUT_CME.dly, GCQ21_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCQ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCQ21_FUT_CME.dly, GCZ21_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCZ21_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.992 | Unable to determine transition date based on volume from files: GCZ21_FUT_CME.dly, GCG22_FUT_CME.dly 2024-10-08 16:03:17.992 | The GCG22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.993 | Unable to determine transition date based on volume from files: GCG22_FUT_CME.dly, GCJ22_FUT_CME.dly 2024-10-08 16:03:17.993 | The GCJ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.993 | Unable to determine transition date based on volume from files: GCJ22_FUT_CME.dly, GCM22_FUT_CME.dly 2024-10-08 16:03:17.993 | The GCM22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.993 | Unable to determine transition date based on volume from files: GCM22_FUT_CME.dly, GCQ22_FUT_CME.dly 2024-10-08 16:03:17.993 | The GCQ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.993 | Unable to determine transition date based on volume from files: GCQ22_FUT_CME.dly, GCZ22_FUT_CME.dly 2024-10-08 16:03:17.993 | The GCZ22_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.993 | Unable to determine transition date based on volume from files: GCZ22_FUT_CME.dly, GCG23_FUT_CME.dly 2024-10-08 16:03:17.993 | The GCG23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.993 | Unable to determine transition date based on volume from files: GCG23_FUT_CME.dly, GCJ23_FUT_CME.dly 2024-10-08 16:03:17.993 | The GCJ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.993 | Unable to determine transition date based on volume from files: GCJ23_FUT_CME.dly, GCM23_FUT_CME.dly 2024-10-08 16:03:17.993 | The GCM23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.994 | Unable to determine transition date based on volume from files: GCM23_FUT_CME.dly, GCQ23_FUT_CME.dly 2024-10-08 16:03:17.994 | The GCQ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.994 | Unable to determine transition date based on volume from files: GCQ23_FUT_CME.dly, GCZ23_FUT_CME.dly 2024-10-08 16:03:17.994 | The GCZ23_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.994 | Unable to determine transition date based on volume from files: GCZ23_FUT_CME.dly, GCG24_FUT_CME.dly 2024-10-08 16:03:17.994 | The GCG24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.994 | Unable to determine transition date based on volume from files: GCG24_FUT_CME.dly, GCJ24_FUT_CME.dly 2024-10-08 16:03:17.994 | The GCJ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.994 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:17.994 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:17.994 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:17.994 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:18.008 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2010-08-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ10_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.008 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ10_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.010 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2010-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ10_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.010 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.011 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.011 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.013 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.013 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.014 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.014 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.015 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.015 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.017 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2011-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ11_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.017 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.018 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.018 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.020 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-04-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.020 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.022 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.022 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.023 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.023 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.642 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-04-26 from file. C:\Sierra\SierraChartInstance_2\Data\GCM16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.644 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.644 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.645 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.645 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.647 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2016-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ16_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.647 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.648 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.648 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.650 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.650 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.651 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.651 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.653 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.653 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.654 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2017-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ17_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.654 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.656 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.656 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.657 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-04-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.657 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.659 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.659 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.660 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.660 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.661 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2018-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ18_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.661 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.663 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.663 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.664 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.664 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.666 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.666 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.667 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.667 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.669 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2019-12-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ19_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.669 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.670 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.670 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.672 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.672 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.673 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-06-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCM20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.673 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.675 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.675 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.676 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2020-12-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ20_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.676 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.678 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.678 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.679 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.679 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.681 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-06-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCM21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.681 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.682 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-08-02 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.682 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.684 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2021-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ21_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.684 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.685 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-02-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCG22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.685 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.687 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.687 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.688 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.688 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.690 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.690 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.691 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2022-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ22_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.691 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.693 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.693 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.694 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-04-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.694 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.696 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.696 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.697 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-08-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.697 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.698 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2023-12-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ23_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.698 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.700 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-02-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCG24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.700 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.701 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.701 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.703 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.703 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.704 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2024-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.704 | GCZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.705 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-10-08 16:03:18.705 | DTC - Sub Instance | Sending logon request message. 2024-10-08 16:03:18.713 | DTC - Sub Instance | Received logon response. 2024-10-08 16:03:18.713 | DTC - Sub Instance | Server Name: SC DTC Server. Build=49642. 2024-10-08 16:03:18.713 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-10-08 16:03:18.713 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading. 2024-10-08 16:03:18.713 | DTC - Sub Instance | Trading is supported. 2024-10-08 16:03:18.713 | DTC - Sub Instance | Order cancel and replace is supported. 2024-10-08 16:03:18.713 | DTC - Sub Instance | OCO Orders supported. 2024-10-08 16:03:18.713 | DTC - Sub Instance | Bracket Orders supported. 2024-10-08 16:03:18.713 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-10-08 16:03:18.713 | DTC - Sub Instance | Connected to server complete. 2024-10-08 16:03:18.717 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-10-08 16:03:18.722 | Using symbol data fast lookup vector 2024-10-08 16:03:18.722 | DTC - Sub Instance | Starting real-time market data updates for: GCZ24_FUT_CME. ID: 1 2024-10-08 16:03:18.722 | DTC - Sub Instance | Requesting security definition data for: GCZ24_FUT_CME. ID: 1 2024-10-08 16:03:18.724 | DTC - Sub Instance | Received security definition for symbol GCZ24_FUT_CME 2024-10-08 16:03:18.758 | GCZ24_FUT_CME [CBV] 60 Min #2 | Reloading chart. 2024-10-08 16:03:18.779 | Unable to determine transition date based on volume from files: GCJ24_FUT_CME.dly, GCM24_FUT_CME.dly 2024-10-08 16:03:18.779 | The GCM24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:18.780 | Unable to determine transition date based on volume from files: GCM24_FUT_CME.dly, GCQ24_FUT_CME.dly 2024-10-08 16:03:18.780 | The GCQ24_FUT_CME.dly symbol may not be the active contract month. 2024-10-08 16:03:18.796 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-04-01 from file. C:\Sierra\SierraChartInstance_2\Data\GCJ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.796 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.797 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-06-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCM24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.797 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.798 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 2024-08-03 from file. C:\Sierra\SierraChartInstance_2\Data\GCQ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.798 | GCZ24_FUT_CME [CBV] 60 Min #2 | Error while getting daily settlement price with date 0 from file. C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.dly. Error: No Data for read. End of file. 2024-10-08 16:03:18.799 | Added historical Intraday data request for GCZ24_FUT_CME to the queue. 2024-10-08 16:03:18.799 | Intraday data recording state for symbol GCZ24_FUT_CME is set to download 'Pending'. 2024-10-08 16:03:18.799 | Triggering next historical data download in queue. 2024-10-08 16:03:18.799 | Delaying start of download for GCZ24_FUT_CME. 2024-10-08 16:03:18.947 | Socket (3) | Socket gracefully closed by remote side. 2024-10-08 16:03:18.948 | Socket (3) | Closed. 2024-10-08 16:03:19.400 | GCZ24_FUT_CME [CV] #4 | Chart data loading complete. 2024-10-08 16:03:19.459 | GCZ24_FUT_CME [CBV] #5 | Chart data loading complete. 2024-10-08 16:03:20.686 | GCZ24_FUT_CME [CBV] 60 Min #2 | Chart data loading complete. 2024-10-08 16:03:23.023 | HD Request # 18 | Downloading Intraday chart data for GCZ24_FUT_CME to the file GCZ24_FUT_CME.scid. Service: comex 2024-10-08 16:03:23.023 | HD Request # 18 | Download start date-time: 2024-10-08 16:03:12.000000. File last date-time: 2024-10-08 16:03:12.048000 2024-10-08 16:03:23.023 | HD Request # 18 | Using server: ds26.sierracharts.com port 10149 2024-10-08 16:03:23.023 | Socket (2) | Creating socket. 2024-10-08 16:03:23.023 | Socket (2) | New receive buffer size: 0 2024-10-08 16:03:23.023 | Socket (2) | Connecting to IP: 69.39.70.243. 2024-10-08 16:03:24.814 | GCZ24_FUT_CME [CBV] #6 | Chart data loading complete. 2024-10-08 16:03:26.222 | HD Request # 18 | Setting DTC encoding to Binary VLS 2024-10-08 16:03:26.222 | HD Request # 18 | Sending historical data logon request message. 2024-10-08 16:03:26.799 | HD Request # 18 | Requesting Intraday data. Start date-time: 2024-10-08 16:03:12. Record interval: 0. Symbol: GCZ24 2024-10-08 16:03:26.885 | HD Request # 18 | Decompressing data. 2024-10-08 16:03:26.975 | HD Request # 18 | Receiving Intraday data for GCZ24_FUT_CME starting at 2024-10-08 16:03:12.048000 2024-10-08 16:03:26.976 | Socket (2) | CloseSocket call. 2024-10-08 16:03:26.976 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-10-08 16:03:27.067 | Socket (2) | Socket gracefully closed by remote side. 2024-10-08 16:03:27.068 | Socket (2) | Closed. 2024-10-08 16:03:27.441 | Historical data download thread signaled to stop. 2024-10-08 16:03:27.441 | HD Request # 18 | Timestamp of first Intraday data file record written: 2024-10-08 16:03:12.480000. 2024-10-08 16:03:27.441 | HD Request # 18 | Received 31 Intraday data records from 2024-10-08 16:03:12.048000 to 2024-10-08 16:03:20.993000 (8.9 seconds. Delay: 6.4 seconds) and wrote 30 records for GCZ24_FUT_CME 2024-10-08 16:03:27.454 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2024-10-08 15:03:20.993000 2024-10-08 16:03:27.454 | Added 9 Time and Sales records to Intraday data file for GCZ24_FUT_CME after download. 2024-10-08 16:03:27.454 | HD Request # 18 | Completion time: 4s. 2024-10-08 16:03:27.454 | HD Request # 18 | Intraday data download complete for GCZ24_FUT_CME. Unique request ID: 117 2024-10-08 16:03:27.454 | Removing historical data download ID 117. 2024-10-08 16:03:27.454 | Real-time Intraday chart data file updates started for GCZ24_FUT_CME 2024-10-08 16:03:27.454 | Intraday chart data file opened for GCZ24_FUT_CME 2024-10-08 16:03:27.454 | HD Request # 18 | Enabling Intraday chart updating for symbol. 2024-10-08 16:03:27.454 | 2024-10-08 16:03:27.454 | No download requests in the queue to start downloads for. 2024-10-08 16:03:28.867 | Opened cached Intraday file: C:\Sierra\SierraChartInstance_2\Data\GCZ24_FUT_CME.scid. Thread ID: 5928 |
[2024-10-08 16:08:42] |
John - SC Support - Posts: 36203 |
It all depends on what service you are connected to. The log you attached is from a sub-instance which is connected to a main instance that is setup to connect to the Teton Order Routing Service. Therefore, the symbols as they are in the log are correct for that service. With regards to the errors in your log, refer to the following: Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-08 17:52:25] |
User518718 - Posts: 5 |
Hi John I have tried this, nothing appears on the screen unless I hit the translate symbols. What else do you suggest? Many thanks |
[2024-10-08 20:28:22] |
This is not making any sense. If the symbols are already translated then doing it again will not really do anything, certainly not make it so you will get data. The one thing that will happen is that since the data is reconnecting, it will download the historical data to the current time. Start with your main instance. Make sure you are able to get data flowing in the main instance. If you are not getting data in the main instance, then we need to see your Message Log from the main instance by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. If you are getting the real-time data in the main instance, then go to a sub-instance and see if you are getting the real-time data for that symbol in that sub-instance. If not, then follow the same instructions as above to get us the Message Log from your Sub-Instance. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
