Date/Time: Fri, 22 Nov 2024 17:15:19 +0000
Weekly chart not loading - despite all other charts loading fine.
View Count: 105
[2024-10-01 23:42:59] |
bennomori - Posts: 8 |
I am using SC Data (Denali), 1 instrument (ESZ24 atm). My weekly chart is taking hours to load when all other charts take a maximum of approx 1-2mins, even on full delete and download option. The chart eventually does load... hours/day later. I am not using tick data (1 second in most cases). Here is the snippet from logs: 2024-10-01 18:31:07.647 | ESZ24-CME [CBV] 30 Min #3 | Reloading chart. 2024-10-01 18:31:07.650 | ESZ24-CME [CBV] 30 Min #3 | Performing continuous chart historical Daily data download for symbol ESZ24-CME starting at last date in file. 2024-10-01 18:31:07.650 | Added historical Daily data request for ESZ24-CME to the queue. 2024-10-01 18:31:07.650 | Triggering next historical data download in queue. 2024-10-01 18:31:07.679 | ESZ24-CME [CBV] 30 Min #3 | Waiting for historical downloads to complete with the IDs: 36, 2024-10-01 18:31:07.690 | HD Request # 36 | Downloading Historical Daily chart data for ESZ24-CME. Starting date: 2024-09-27. Service: scdataallservices 2024-10-01 18:31:09.053 | HD Request # 36 | Requesting historical Daily data for ESZ24 starting at 2024-09-26. SC External HD service. 2024-10-01 18:31:10.208 | HD Request # 36 | Receiving historical Daily data for ESZ24-CME starting at 2024-09-27. 2024-10-01 18:31:10.209 | HD Request # 36 | Writing historical Daily data to the file ESZ24-CME.dly. 2024-10-01 18:31:10.212 | HD Request # 36 | Bytes received: 241 2024-10-01 18:31:10.212 | HD Request # 36 | Received 4 Daily data records from 2024-09-27 00:00:00 to 2024-10-01 00:00:00 (5.0 days) and wrote 3 records for ESZ24-CME 2024-10-01 18:31:10.212 | HD Request # 36 | Completion time: 3s. 2024-10-01 18:31:10.212 | HD Request # 36 | Daily data download complete for ESZ24-CME. Unique request ID: 36 2024-10-01 18:31:10.212 | Removing historical data download ID 36. Wondering if I have missed a setting or perhaps have it reloading from one of my many custom studies - but doubt it as I have not changed anything recently, and most of my studies are also used in the other higher level timeframe charts and no issues there. Keen to resolve as the weekly produces a few key levels I need... Any suggestions/questions much appreciated. |
[2024-10-02 13:46:15] |
John - SC Support - Posts: 36221 |
For that weekly chart, check the setting for "Chart >> Chart Settings >> Bar Period >> Chart Data Type". See if this is set to "Intraday Chart Only". If so, then the weekly chart is being created from Intraday data, which will take longer to load than the Daily Historical data. Change this to "Historical Chart" in order to use the Daily data and have it load faster - unless you have some specific reason for using the Intraday data. If the above is already set to "Historical Data" then the data should load relatively quickly. Is this setup to be a Continuous Futures Chart? If so, how many days of data are you loading? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-03 10:12:48] |
Sincere thanks John, Yes that makes sense re the intraday versus historical data retrieval time, explaining faster loading of those higher timeframe charts. I use VWAP standard deviations from the developing weekly (in realtime on my trading chart) so I assume I do need intraday data. It is a continuous futures contract volume based rollover back adjusted chart... 90 days bar period setting, which I occasionally beef up to 365 days to check out some past data. I setup a 2TB NVME drive yesterday and dedicated that to SC alone, just to eliminate disk speed as an issue. Running: CPU: AMD Ryzen 9 7950X 16 cores 32 threads, Memory is DDR5 64 GB running at 6000 mhz, Graphics is Nvidia 4080, Hard drives are all NVME PCI Gen 4 drives, screens are all DELL OLED 32inch 4K |
[2024-10-03 13:58:08] |
Sierra_Chart Engineering - Posts: 17143 |
Yes you will need an Intraday chart for accurate Volume Weighted Average Price studies. You can still use 1 Second data to decrease loading time: Changing Chart Bars Period: Improving Performance of Loading Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-10-03 13:58:13
[2024-10-06 23:24:59] |
Thanks again, made those changes and everything working much smoother. Appreciate the guidance.
