Date/Time: Fri, 22 Nov 2024 15:32:13 +0000
OCO bracket issue
View Count: 284
[2024-09-26 20:28:45]
gr8fultrading - Posts: 8
I trade with 3-target bracket orders, which include three limit orders and one stop. When the first limit order is filled, the stops move according to the offset rules set up (see attachment), and are adjusted for the updated open contract quantity.
However, the original stop order does not go away. So I'm left with two stop orders... one with the adjusted contract quantity, and one with the quantity of contracts that were just closed via Target 1 limit order. If I then cancel the unneeded stop order, all pending orders cancel.
This does not happen in the Sierra Sim, only when trading the "live" account (which is a prop trader eval). Configuration details are in the second attachment. Any ideas?
Thanks,
Nate
imageSierra Chart bracket.jpg / V - Attached On 2024-09-26 20:28:06 UTC - Size: 172.17 KB - 44 views
Private File
[2024-09-26 21:17:15]
John - SC Support - Posts: 36213
Please get us an image of what you are seeing by following these instructions:
There is no reason for the original Stop order line to still be showing after the stop has moved to Break Even (with the appropriate offset).
[2024-09-27 18:59:05]
Here is the chart image link: https://www.sierrachart.com/image.php?Image=1727463277306.png
T1 limit order has filled, leaving the orders shown on screen: 2x limit orders, for 1 and 2 lots respectively; and 2x stop orders, one for 4 lots (unneeded) and one containing two separate orders for 1 and 2 lots (these correspond to the limit orders). This only appears to happen with the 10-lot bracket. Traded a 5-lot earlier today and did not experience the issue.
Please let me know what other information would be helpful.
[2024-09-27 19:27:10]
Thank you for that image. We need to see your Attached Orders configuration from your Trade Window. To get us this, attach the Trade Window to the chart (if not already there) by selecting "Trade >> Attach Trade Window to Chart" and make sure it is set to display the "Targets" tab. Then select "Edit >> Screen Images >> Upload Chart with Overlays" and get us the link that is given to you.
Make sure this is the configuration that is associated with the chart image you sent us.
Or, if you are using a Trading Study of some kind, then we need to know what you are using and how you have it configured for the attached orders.
Date Time Of Last Edit: 2024-09-27 19:27:55
[2024-09-27 19:33:55]
Here you go: https://www.sierrachart.com/image.php?Image=1727465597652.png
[2024-09-27 19:40:06]
Everything looks good. There is no reason that we can see for this to be occurring. In particular, it really does not make any sense that the Stop is for a quantity of 4, when a quantity of 7 was just closed out.
How are you entering your orders? Are you running any of kind of automated system that might be running on another chart that could be opening that Stop for a quantity of 4?
[2024-09-27 20:09:41]
Positions are entered using either a market or limit order. There is no automated system running that would enter that stop order of 4. Would the trade service logs or anything else be helpful to look at?
[2024-09-28 00:28:45]
Are you entering these orders manually through the Trade Window, or are you using some kind of study (like the Spreadsheet System for Trading, or something else)?
Please do get us your Trade Activity Log by following these instructions:
Trade Activity Log: Providing Trade Activity Log Data Lines to Support
[2024-09-28 17:16:00]
Trade Activity Log data:
ActivityType  DateTime  TransDateTime  Symbol  OrderActionSource  InternalOrderID  ServiceOrderID  OrderType  Quantity  BuySell  Price  Price2  OrderStatus  FillPrice  FilledQuantity  TradeAccount  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID  HighDuringPosition  LowDuringPosition  Note  AccountBalance  ExchangeOrderID  ClientOrderID  TimeInForce  Username  IsAutomated
Positions  2024-09-26 17:47:13.902356  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 18:04:40.421991  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 18:05:05.475941  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 19:28:52.495954  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 19:34:38.749750  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 20:18:59.725087  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 20:26:23.045107  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:01:21.089662  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:02:51.363464  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:20:33.294385  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:20:53.320169  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:25:18.774015  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:26:09.653171  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:27:02.108007  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:33:33.923293  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 22:34:18.975349  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:04:28.366722  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:05:41.788667  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:07:00.559883  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:08:14.888056  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:09:05.050402  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:10:18.565676  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:17:31.134670  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:18:48.748849  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:21:55.664118  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:22:40.694164  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:25:55.598775  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:26:58.589439  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:28:08.564587  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:28:58.661179  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:30:37.285258  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:31:27.416717  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-26 23:40:56.784788  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:09:34.964659  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:10:25.051646  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:15:49.363163  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:19:09.626433  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:20:14.930722  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:21:28.376134  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:22:18.532484  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:30:28.522653  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:32:00.693186  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:39:58.510657  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:40:43.589098  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:42:02.137291  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:44:49.632649  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 00:46:09.148208  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 01:21:17.539457  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 01:22:07.643967  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 01:23:21.308614  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 01:24:39.765638  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 01:25:52.653642  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 02:10:12.779242  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 02:10:57.894894  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 02:12:58.466294  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 02:16:02.683541  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 02:21:12.215652  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 02:31:43.814603  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 02:32:33.883162  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:01:32.141029  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:04:23.556345  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:05:57.294965  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:06:47.294597  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:08:01.110595  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:09:19.497796  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:11:01.861313  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:12:20.380293  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:13:05.414614  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:14:22.862864  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:15:08.048954  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:16:50.742590  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:17:40.822215  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:18:54.649776  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:20:04.917325  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:20:50.048665  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:26:26.407960  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:27:16.540904  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:28:29.908183  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:29:48.350232  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:31:11.426149  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:32:52.576092  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:33:37.745429  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:34:56.351484  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:36:14.839183  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:37:55.482811  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:38:40.495447  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 03:39:30.563673  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 04:27:29.617974  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 04:47:35.525860  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:30:57.599013  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:31:42.755259  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:33:01.251244  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:46:18.879433  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:47:31.550462  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:48:32.585471  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:54:03.427741  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:54:48.610833  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:56:34.738109  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 05:57:47.311049  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 06:48:27.314071  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 06:50:08.353694  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 06:50:58.541957  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 06:52:12.206119  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 06:53:30.714081  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 06:54:44.130573  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 07:14:30.920945  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 07:15:15.963611  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 07:20:39.207522  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 07:21:47.750051  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 07:22:35.565909  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Orders  2024-09-27 07:32:16.315224  2024-09-27 07:32:16.315186  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1217    Limit    Sell  5818.25    Pending Child-Client      TPT1771430  Close  1216            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.315283  2024-09-27 07:32:16.315277  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1218    Stop    Sell  5802.50    Pending Child-Client      TPT1771430  Close  1216            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.315308  2024-09-27 07:32:16.315304  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1  1216    Market  3  Buy      Order Sent      TPT1771430  Open              0.00      Day    N
Orders  2024-09-27 07:32:16.315754  2024-09-27 07:32:16.315746  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1220    Limit    Sell  5825.25    Pending Child-Client      TPT1771430  Close  1219            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.315767  2024-09-27 07:32:16.315762  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1221    Stop    Sell  5802.50    Pending Child-Client      TPT1771430  Close  1219            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.315780  2024-09-27 07:32:16.315775  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1  1219    Market  1  Buy      Order Sent      TPT1771430  Open              0.00      Day    N
Orders  2024-09-27 07:32:16.315805  2024-09-27 07:32:16.315801  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1223    Limit    Sell  5836.25    Pending Child-Client      TPT1771430  Close  1222            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.315813  2024-09-27 07:32:16.315809  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1224    Stop    Sell  5802.50    Pending Child-Client      TPT1771430  Close  1222            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.315822  2024-09-27 07:32:16.315818  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5811 | AO=1  1222    Market  1  Buy      Order Sent      TPT1771430  Open              0.00      Day    N
Orders  2024-09-27 07:32:16.400270  2024-09-27 07:32:16.400260  MESZ4.CME  Rithmic Direct - DTC (New)  1216  1980404594  Market  3  Buy      Pending Open      TPT1771430  Open              0.00    1216.17551  Day    N
Orders  2024-09-27 07:32:16.400304  2024-09-27 07:32:16.400302  MESZ4.CME  Rithmic Direct - DTC (New)  1219  1980404595  Market  1  Buy      Pending Open      TPT1771430  Open              0.00    1219.88942  Day    N
Orders  2024-09-27 07:32:16.400329  2024-09-27 07:32:16.400327  MESZ4.CME  Rithmic Direct - DTC (New)  1222  1980404596  Market  1  Buy      Pending Open      TPT1771430  Open              0.00    1222.55970  Day    N
Orders  2024-09-27 07:32:16.400339  2024-09-27 07:32:16.400338  MESZ4.CME  Rithmic Direct - DTC (New)  1216  1980404594  Market  3  Buy      Open      TPT1771430  Open              0.00  1980404594  1216.17551  Day    N
Orders  2024-09-27 07:32:16.400542  2024-09-27 07:32:16.400531  MESZ4.CME  Rithmic Direct - DTC (Filled)  1216  1980404594  Market  3  Buy      Filled  5811.00  3  TPT1771430  Open      1783438        0.00  1980404594  1216.17551  Day    N
Positions  2024-09-27 07:32:16.400743  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 3. Previous: 0. Fill of InternalOrderID: 1216        3        Unspecified      TPT1771430      3          0.00          N
Fills  2024-09-27 07:32:16.400766  2024-09-27 07:32:16.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1216  1980404594  Market  3  Buy      Filled  5811.00  3  TPT1771430  Open    3  1783438        0.00  1980404594  1216.17551  Day    N
Orders  2024-09-27 07:32:16.402160  2024-09-27 07:32:16.402157  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5818.00. Requested Price: 5818.00. Requested Quantity: 0  1217    Limit    Sell  5818.25    Pending Modify      TPT1771430  Close  1216  3          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402184  2024-09-27 07:32:16.402182  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5818.00. Requested Price: 5818.00. Requested Quantity: 0  1217    Limit    Sell  5818.00    Pending Child-Client      TPT1771430  Close  1216  3          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402209  2024-09-27 07:32:16.402207  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5802.25. Requested Price: 5802.25. Requested Quantity: 0  1218    Stop    Sell  5802.50    Pending Modify      TPT1771430  Close  1216  3          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402218  2024-09-27 07:32:16.402216  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5802.25. Requested Price: 5802.25. Requested Quantity: 0  1218    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1216  3          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402224  2024-09-27 07:32:16.402223  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 581100  1218    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1216            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402228  2024-09-27 07:32:16.402228  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 581350  1218    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1216            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402232  2024-09-27 07:32:16.402231  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 581100  1218    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1216            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402238  2024-09-27 07:32:16.402238  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 581100  1218    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1216            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402254  2024-09-27 07:32:16.402253  MESZ4.CME  Auto-sent child from parent fill  1217    Limit  3  Sell  5818.00    Order Sent      TPT1771430  Close  1216  3          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.402263  2024-09-27 07:32:16.402261  MESZ4.CME  Auto-sent child from parent fill  1218    Stop  3  Sell  5802.25    Order Sent      TPT1771430  Close  1216  3          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405365  2024-09-27 07:32:16.405358  MESZ4.CME  Rithmic Direct - DTC (New)  1219  1980404595  Market  1  Buy      Open      TPT1771430  Open    3          0.00  1980404595  1219.88942  Day    N
Orders  2024-09-27 07:32:16.405392  2024-09-27 07:32:16.405390  MESZ4.CME  Rithmic Direct - DTC (Filled)  1219  1980404595  Market  1  Buy      Filled  5811.00  1  TPT1771430  Open    3  1783440        0.00  1980404595  1219.88942  Day    N
Positions  2024-09-27 07:32:16.405403  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 4. Previous: 3. Fill of InternalOrderID: 1219        1        Unspecified      TPT1771430      4          0.00          N
Fills  2024-09-27 07:32:16.405415  2024-09-27 07:32:16.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1219  1980404595  Market  1  Buy      Filled  5811.00  1  TPT1771430  Open    4  1783440        0.00  1980404595  1219.88942  Day    N
Orders  2024-09-27 07:32:16.405466  2024-09-27 07:32:16.405464  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5825.00. Requested Price: 5825.00. Requested Quantity: 0  1220    Limit    Sell  5825.25    Pending Modify      TPT1771430  Close  1219  4          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405473  2024-09-27 07:32:16.405471  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5825.00. Requested Price: 5825.00. Requested Quantity: 0  1220    Limit    Sell  5825.00    Pending Child-Client      TPT1771430  Close  1219  4          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405485  2024-09-27 07:32:16.405483  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5802.25. Requested Price: 5802.25. Requested Quantity: 0  1221    Stop    Sell  5802.50    Pending Modify      TPT1771430  Close  1219  4          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405492  2024-09-27 07:32:16.405491  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5802.25. Requested Price: 5802.25. Requested Quantity: 0  1221    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1219  4          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405499  2024-09-27 07:32:16.405498  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 581100  1221    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1219            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405506  2024-09-27 07:32:16.405505  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 581350  1221    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1219            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405510  2024-09-27 07:32:16.405509  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 581100  1221    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1219            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405513  2024-09-27 07:32:16.405512  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 581100  1221    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1219            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405522  2024-09-27 07:32:16.405520  MESZ4.CME  Auto-sent child from parent fill  1220    Limit  1  Sell  5825.00    Order Sent      TPT1771430  Close  1219  4          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.405528  2024-09-27 07:32:16.405527  MESZ4.CME  Auto-sent child from parent fill  1221    Stop  1  Sell  5802.25    Order Sent      TPT1771430  Close  1219  4          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406020  2024-09-27 07:32:16.406014  MESZ4.CME  Rithmic Direct - DTC (New)  1222  1980404596  Market  1  Buy      Open      TPT1771430  Open    4          0.00  1980404596  1222.55970  Day    N
Orders  2024-09-27 07:32:16.406037  2024-09-27 07:32:16.406036  MESZ4.CME  Rithmic Direct - DTC (Filled)  1222  1980404596  Market  1  Buy      Filled  5811.00  1  TPT1771430  Open    4  1783442        0.00  1980404596  1222.55970  Day    N
Positions  2024-09-27 07:32:16.406045  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 5. Previous: 4. Fill of InternalOrderID: 1222        1        Unspecified      TPT1771430      5          0.00          N
Fills  2024-09-27 07:32:16.406051  2024-09-27 07:32:16.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1222  1980404596  Market  1  Buy      Filled  5811.00  1  TPT1771430  Open    5  1783442        0.00  1980404596  1222.55970  Day    N
Orders  2024-09-27 07:32:16.406093  2024-09-27 07:32:16.406091  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5836.00. Requested Price: 5836.00. Requested Quantity: 0  1223    Limit    Sell  5836.25    Pending Modify      TPT1771430  Close  1222  5          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406104  2024-09-27 07:32:16.406103  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5836.00. Requested Price: 5836.00. Requested Quantity: 0  1223    Limit    Sell  5836.00    Pending Child-Client      TPT1771430  Close  1222  5          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406117  2024-09-27 07:32:16.406115  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5802.25. Requested Price: 5802.25. Requested Quantity: 0  1224    Stop    Sell  5802.50    Pending Modify      TPT1771430  Close  1222  5          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406124  2024-09-27 07:32:16.406123  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5811.00. New price: 5802.25. Requested Price: 5802.25. Requested Quantity: 0  1224    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1222  5          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406131  2024-09-27 07:32:16.406130  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 581100  1224    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1222            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406136  2024-09-27 07:32:16.406135  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 581350  1224    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1222            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406157  2024-09-27 07:32:16.406156  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 581100  1224    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1222            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406160  2024-09-27 07:32:16.406159  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 581100  1224    Stop    Sell  5802.25    Pending Child-Client      TPT1771430  Close  1222            0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406166  2024-09-27 07:32:16.406165  MESZ4.CME  Auto-sent child from parent fill  1223    Limit  1  Sell  5836.00    Order Sent      TPT1771430  Close  1222  5          0.00      Good till Canceled    N
Orders  2024-09-27 07:32:16.406173  2024-09-27 07:32:16.406171  MESZ4.CME  Auto-sent child from parent fill  1224    Stop  1  Sell  5802.25    Order Sent      TPT1771430  Close  1222  5          0.00      Good till Canceled    N
Positions  2024-09-27 07:32:16.406642  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 3                Unspecified      TPT1771430      5          0.00          N
Positions  2024-09-27 07:32:16.406677  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 4                Unspecified      TPT1771430      5          0.00          N
Positions  2024-09-27 07:32:16.406686  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 5                Unspecified      TPT1771430      5          0.00          N
Orders  2024-09-27 07:32:16.434694  2024-09-27 07:32:16.434684  MESZ4.CME  Rithmic Direct - DTC (New)  1217  1980404600  Limit  3  Sell  5818.00    Pending Open      TPT1771430  Close  1216  5          0.00    1217.25636  Good till Canceled    N
Orders  2024-09-27 07:32:16.434748  2024-09-27 07:32:16.434744  MESZ4.CME  Rithmic Direct - DTC (New)  1218  1980404601  Stop  3  Sell  5802.25    Pending Open      TPT1771430  Close  1216  5          0.00    1218.73488  Good till Canceled    N
Orders  2024-09-27 07:32:16.435249  2024-09-27 07:32:16.435246  MESZ4.CME  Rithmic Direct - DTC (New)  1217  1980404600  Limit  3  Sell  5818.00    Open      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 07:32:16.435267  2024-09-27 07:32:16.435265  MESZ4.CME  Rithmic Direct - DTC (New)  1218  1980404601  Stop  3  Sell  5802.25    Open      TPT1771430  Close  1216  5          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 07:32:16.463901  2024-09-27 07:32:16.463893  MESZ4.CME  Rithmic Direct - DTC (New)  1220  1980404603  Limit  1  Sell  5825.00    Pending Open      TPT1771430  Close  1219  5          0.00    1220.48443  Good till Canceled    N
Orders  2024-09-27 07:32:16.463936  2024-09-27 07:32:16.463934  MESZ4.CME  Rithmic Direct - DTC (New)  1221  1980404604  Stop  1  Sell  5802.25    Pending Open      TPT1771430  Close  1219  5          0.00    1221.91220  Good till Canceled    N
Orders  2024-09-27 07:32:16.463948  2024-09-27 07:32:16.463946  MESZ4.CME  Rithmic Direct - DTC (New)  1220  1980404603  Limit  1  Sell  5825.00    Open      TPT1771430  Close  1219  5          0.00  1980404603  1220.48443  Good till Canceled    N
Orders  2024-09-27 07:32:16.463960  2024-09-27 07:32:16.463958  MESZ4.CME  Rithmic Direct - DTC (New)  1221  1980404604  Stop  1  Sell  5802.25    Open      TPT1771430  Close  1219  5          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 07:32:16.463970  2024-09-27 07:32:16.463968  MESZ4.CME  Rithmic Direct - DTC (New)  1223  1980404605  Limit  1  Sell  5836.00    Pending Open      TPT1771430  Close  1222  5          0.00    1223.38498  Good till Canceled    N
Orders  2024-09-27 07:32:16.463980  2024-09-27 07:32:16.463978  MESZ4.CME  Rithmic Direct - DTC (New)  1224  1980404606  Stop  1  Sell  5802.25    Pending Open      TPT1771430  Close  1222  5          0.00    1224.88490  Good till Canceled    N
Orders  2024-09-27 07:32:16.463989  2024-09-27 07:32:16.463987  MESZ4.CME  Rithmic Direct - DTC (New)  1223  1980404605  Limit  1  Sell  5836.00    Open      TPT1771430  Close  1222  5          0.00  1980404605  1223.38498  Good till Canceled    N
Orders  2024-09-27 07:32:16.464000  2024-09-27 07:32:16.463998  MESZ4.CME  Rithmic Direct - DTC (New)  1224  1980404606  Stop  1  Sell  5802.25    Open      TPT1771430  Close  1222  5          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 07:32:44.101850  2024-09-27 07:32:44.101841  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5823.00. Requested Quantity: 1  1220  1980404603  Limit  1  Sell  5825.00    Pending Modify      TPT1771430  Close  1219  5          0.00  1980404603  1220.48443  Good till Canceled    N
Orders  2024-09-27 07:32:44.179469  2024-09-27 07:32:44.179456  MESZ4.CME  Rithmic Direct - DTC (Order update)  1220  1980404603  Limit  1  Sell  5823.00    Pending Modify      TPT1771430  Close  1219  5          0.00  1980404603  1220.48443  Good till Canceled    N
Orders  2024-09-27 07:32:44.179636  2024-09-27 07:32:44.179633  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1220  1980404603  Limit  1  Sell  5823.00    Open      TPT1771430  Close  1219  5          0.00  1980404603  1220.48443  Good till Canceled    N
Orders  2024-09-27 07:52:37.586693  2024-09-27 07:52:37.586673  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5805.00. Requested Quantity: 3  1218  1980404601  Stop  3  Sell  5802.25    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 07:52:37.586826  2024-09-27 07:52:37.586823  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5805.00. Requested Quantity: 3. Requested Price: 5805.00. Requested Quantity: 1  1221  1980404604  Stop  1  Sell  5802.25    Pending Modify      TPT1771430  Close  1219  5          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 07:52:37.586847  2024-09-27 07:52:37.586845  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5805.00. Requested Quantity: 3. Requested Price: 5805.00. Requested Quantity: 1  1224  1980404606  Stop  1  Sell  5802.25    Pending Modify      TPT1771430  Close  1222  5          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 07:52:37.670227  2024-09-27 07:52:37.670218  MESZ4.CME  Rithmic Direct - DTC (Order update)  1218  1980404601  Stop  3  Sell  5805.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 07:52:37.670261  2024-09-27 07:52:37.670259  MESZ4.CME  Rithmic Direct - DTC (Order update)  1221  1980404604  Stop  1  Sell  5805.00    Pending Modify      TPT1771430  Close  1219  5          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 07:52:37.670276  2024-09-27 07:52:37.670274  MESZ4.CME  Rithmic Direct - DTC (Order update)  1224  1980404606  Stop  1  Sell  5805.00    Pending Modify      TPT1771430  Close  1222  5          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 07:52:37.670288  2024-09-27 07:52:37.670286  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1218  1980404601  Stop  3  Sell  5805.00    Open      TPT1771430  Close  1216  5          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 07:52:37.670321  2024-09-27 07:52:37.670319  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1221  1980404604  Stop  1  Sell  5805.00    Open      TPT1771430  Close  1219  5          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 07:52:37.670330  2024-09-27 07:52:37.670329  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1224  1980404606  Stop  1  Sell  5805.00    Open      TPT1771430  Close  1222  5          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 07:58:11.347175  2024-09-27 07:58:11.347164  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5803.00. Requested Quantity: 3  1218  1980404601  Stop  3  Sell  5805.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 07:58:11.347257  2024-09-27 07:58:11.347254  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5803.00. Requested Quantity: 3. Requested Price: 5803.00. Requested Quantity: 1  1221  1980404604  Stop  1  Sell  5805.00    Pending Modify      TPT1771430  Close  1219  5          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 07:58:11.347274  2024-09-27 07:58:11.347272  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5803.00. Requested Quantity: 3. Requested Price: 5803.00. Requested Quantity: 1  1224  1980404606  Stop  1  Sell  5805.00    Pending Modify      TPT1771430  Close  1222  5          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 07:58:11.425976  2024-09-27 07:58:11.425966  MESZ4.CME  Rithmic Direct - DTC (Order update)  1218  1980404601  Stop  3  Sell  5803.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 07:58:11.426014  2024-09-27 07:58:11.426012  MESZ4.CME  Rithmic Direct - DTC (Order update)  1221  1980404604  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1219  5          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 07:58:11.426023  2024-09-27 07:58:11.426021  MESZ4.CME  Rithmic Direct - DTC (Order update)  1224  1980404606  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1222  5          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 07:58:11.426040  2024-09-27 07:58:11.426038  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1218  1980404601  Stop  3  Sell  5803.00    Open      TPT1771430  Close  1216  5          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 07:58:11.426051  2024-09-27 07:58:11.426050  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1221  1980404604  Stop  1  Sell  5803.00    Open      TPT1771430  Close  1219  5          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 07:58:11.426060  2024-09-27 07:58:11.426058  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1224  1980404606  Stop  1  Sell  5803.00    Open      TPT1771430  Close  1222  5          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 07:58:31.588956  2024-09-27 07:58:31.588946  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5817.75. Requested Quantity: 3  1217  1980404600  Limit  3  Sell  5818.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 07:58:31.663345  2024-09-27 07:58:31.663335  MESZ4.CME  Rithmic Direct - DTC (Order update)  1217  1980404600  Limit  3  Sell  5817.75    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 07:58:31.663378  2024-09-27 07:58:31.663376  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1217  1980404600  Limit  3  Sell  5817.75    Open      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 07:58:38.274412  2024-09-27 07:58:38.274404  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5818.00. Requested Quantity: 3  1217  1980404600  Limit  3  Sell  5817.75    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 07:58:38.347462  2024-09-27 07:58:38.347449  MESZ4.CME  Rithmic Direct - DTC (Order update)  1217  1980404600  Limit  3  Sell  5818.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 07:58:38.347500  2024-09-27 07:58:38.347498  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1217  1980404600  Limit  3  Sell  5818.00    Open      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 08:10:31.292067  2024-09-27 08:10:31.292058  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5819.00. Requested Quantity: 3  1217  1980404600  Limit  3  Sell  5818.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 08:10:31.370790  2024-09-27 08:10:31.370779  MESZ4.CME  Rithmic Direct - DTC (Order update)  1217  1980404600  Limit  3  Sell  5819.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 08:10:31.370830  2024-09-27 08:10:31.370828  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1217  1980404600  Limit  3  Sell  5819.00    Open      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:02:09.073242  2024-09-27 09:02:09.073232  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5817.25. Requested Quantity: 3  1217  1980404600  Limit  3  Sell  5819.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:02:09.146511  2024-09-27 09:02:09.146492  MESZ4.CME  Rithmic Direct - DTC (Order update)  1217  1980404600  Limit  3  Sell  5817.25    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:02:09.146714  2024-09-27 09:02:09.146712  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1217  1980404600  Limit  3  Sell  5817.25    Open      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:15:05.448137  2024-09-27 09:15:05.448126  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5819.00. Requested Quantity: 3  1217  1980404600  Limit  3  Sell  5817.25    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:15:05.521664  2024-09-27 09:15:05.521655  MESZ4.CME  Rithmic Direct - DTC (Order update)  1217  1980404600  Limit  3  Sell  5819.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:15:05.521698  2024-09-27 09:15:05.521696  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1217  1980404600  Limit  3  Sell  5819.00    Open      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:25:33.245009  2024-09-27 09:25:33.244978  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5819.50. Requested Quantity: 3  1217  1980404600  Limit  3  Sell  5819.00    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:25:33.326965  2024-09-27 09:25:33.326955  MESZ4.CME  Rithmic Direct - DTC (Order update)  1217  1980404600  Limit  3  Sell  5819.50    Pending Modify      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:25:33.327005  2024-09-27 09:25:33.327003  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1217  1980404600  Limit  3  Sell  5819.50    Open      TPT1771430  Close  1216  5          0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:26:16.462833  2024-09-27 09:26:16.462821  MESZ4.CME  Rithmic Direct - DTC (Filled)  1217  1980404600  Limit  3  Sell  5819.50    Filled  5819.50  3  TPT1771430  Close  1216  5  1834913        0.00  1980404600  1217.25636  Good till Canceled    N
Positions  2024-09-27 09:26:16.462941  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 2. Previous: 5. Fill of InternalOrderID: 1217        3        Unspecified      TPT1771430      2          0.00          N
Fills  2024-09-27 09:26:16.462967  2024-09-27 09:26:16.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1217  1980404600  Limit  3  Sell  5819.50    Filled  5819.50  3  TPT1771430  Close  1216  2  1834913  5819.50  5804.25    0.00  1980404600  1217.25636  Good till Canceled    N
Orders  2024-09-27 09:26:16.463646  2024-09-27 09:26:16.463641  MESZ4.CME  Auto trail order modification. 1. Trigger order: 1217. Using LastModifyQuantity of 1. Using new provided price. Requested Price: 5808.00. Requested Quantity: 1  1224  1980404606  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:26:16.463706  2024-09-27 09:26:16.463703  MESZ4.CME  Auto trail order modification. 1. Trigger order: 1217. Using LastModifyQuantity of 1. Using new provided price. Requested Price: 5808.00. Requested Quantity: 1  1221  1980404604  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:26:16.464461  2024-09-27 09:26:16.464454  MESZ4.CME  Rithmic Direct - DTC (Order update)  1218  1980404601  Stop  3  Sell  5803.00    Pending Cancel      TPT1771430  Close  1216  2          0.00  1980404601  1218.73488  Good till Canceled    N
Orders  2024-09-27 09:26:16.465149  2024-09-27 09:26:16.465145  MESZ4.CME  Rithmic Direct - DTC (Canceled)  1218  1980404601  Stop  3  Sell  5803.00    Canceled      TPT1771430  Close  1216  2          0.00  1980404601  1218.73488  Good till Canceled    N
Positions  2024-09-27 09:26:16.465249  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 2                Unspecified      TPT1771430      2          0.00          N
Orders  2024-09-27 09:26:16.517047  2024-09-27 09:26:16.517020  MESZ4.CME  Rithmic Direct - DTC (Order update)  1224  1980404606  Stop  1  Sell  5808.00    Pending Modify      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:26:16.517138  2024-09-27 09:26:16.517131  MESZ4.CME  Rithmic Direct - DTC (Order update)  1221  1980404604  Stop  1  Sell  5808.00    Pending Modify      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:26:16.517182  2024-09-27 09:26:16.517176  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1224  1980404606  Stop  1  Sell  5808.00    Open      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:26:16.517230  2024-09-27 09:26:16.517223  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1221  1980404604  Stop  1  Sell  5808.00    Open      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:30:19.957368  2024-09-27 09:30:19.957342  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5803.00. Requested Quantity: 1  1221  1980404604  Stop  1  Sell  5808.00    Pending Modify      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:30:19.957514  2024-09-27 09:30:19.957511  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5803.00. Requested Quantity: 1. Requested Price: 5803.00. Requested Quantity: 1  1224  1980404606  Stop  1  Sell  5808.00    Pending Modify      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:30:20.037971  2024-09-27 09:30:20.037960  MESZ4.CME  Rithmic Direct - DTC (Order update)  1221  1980404604  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:30:20.038114  2024-09-27 09:30:20.038111  MESZ4.CME  Rithmic Direct - DTC (Order update)  1224  1980404606  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:30:20.038147  2024-09-27 09:30:20.038145  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1221  1980404604  Stop  1  Sell  5803.00    Open      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:30:20.038252  2024-09-27 09:30:20.038250  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1224  1980404606  Stop  1  Sell  5803.00    Open      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:36:43.107255  2024-09-27 09:36:43.107242  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5811.00. Requested Quantity: 1  1221  1980404604  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:36:43.107359  2024-09-27 09:36:43.107352  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5811.00. Requested Quantity: 1. Requested Price: 5811.00. Requested Quantity: 1  1224  1980404606  Stop  1  Sell  5803.00    Pending Modify      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:36:43.179941  2024-09-27 09:36:43.179927  MESZ4.CME  Rithmic Direct - DTC (Order update)  1221  1980404604  Stop  1  Sell  5811.00    Pending Modify      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:36:43.179975  2024-09-27 09:36:43.179973  MESZ4.CME  Rithmic Direct - DTC (Order update)  1224  1980404606  Stop  1  Sell  5811.00    Pending Modify      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 09:36:43.179988  2024-09-27 09:36:43.179987  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1221  1980404604  Stop  1  Sell  5811.00    Open      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 09:36:43.179999  2024-09-27 09:36:43.179997  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1224  1980404606  Stop  1  Sell  5811.00    Open      TPT1771430  Close  1222  2          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 10:10:38.585550  2024-09-27 10:10:38.585538  MESZ4.CME  Rithmic Direct - DTC (New)  1221  1980404604  Stop  1  Sell  5811.00  5811.00  Open      TPT1771430  Close  1219  2          0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 10:10:38.585596  2024-09-27 10:10:38.585595  MESZ4.CME  Updating last modify Price and Quantity to current values due to an external modification or other reason. LastModifyPrice1: 5811.00, CurrentPrice1: 5811.00, LastModifyQuantity: 1, CurrentQuantity: 1  1221  1980404604  Stop  1  Sell  5811.00  5811.00  Open      TPT1771430  Close  1219            0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 10:10:38.585627  2024-09-27 10:10:38.585625  MESZ4.CME  Rithmic Direct - DTC (Filled)  1221  1980404604  Stop  1  Sell  5811.00  5811.00  Filled  5811.00  1  TPT1771430  Close  1219  2  1864368        0.00  1980404604  1221.91220  Good till Canceled    N
Positions  2024-09-27 10:10:38.585638  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 1. Previous: 2. Fill of InternalOrderID: 1221        1        Unspecified      TPT1771430      1          0.00          N
Fills  2024-09-27 10:10:38.585648  2024-09-27 10:10:38.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1221  1980404604  Stop  1  Sell  5811.00  5811.00  Filled  5811.00  1  TPT1771430  Close  1219  1  1864368  5821.50  5811.00    0.00  1980404604  1221.91220  Good till Canceled    N
Orders  2024-09-27 10:10:38.594132  2024-09-27 10:10:38.594124  MESZ4.CME  Rithmic Direct - DTC (New)  1224  1980404606  Stop  1  Sell  5811.00  5811.00  Open      TPT1771430  Close  1222  1          0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 10:10:38.594158  2024-09-27 10:10:38.594157  MESZ4.CME  Updating last modify Price and Quantity to current values due to an external modification or other reason. LastModifyPrice1: 5811.00, CurrentPrice1: 5811.00, LastModifyQuantity: 1, CurrentQuantity: 1  1224  1980404606  Stop  1  Sell  5811.00  5811.00  Open      TPT1771430  Close  1222            0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 10:10:38.594251  2024-09-27 10:10:38.594249  MESZ4.CME  Rithmic Direct - DTC (Filled)  1224  1980404606  Stop  1  Sell  5811.00  5811.00  Filled  5811.00  1  TPT1771430  Close  1222  1  1864370        0.00  1980404606  1224.88490  Good till Canceled    N
Positions  2024-09-27 10:10:38.594265  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 0. Previous: 1. Fill of InternalOrderID: 1224        1        Unspecified      TPT1771430                0.00          N
Fills  2024-09-27 10:10:38.594279  2024-09-27 10:10:38.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1224  1980404606  Stop  1  Sell  5811.00  5811.00  Filled  5811.00  1  TPT1771430  Close  1222    1864370  5811.00  5811.00    0.00  1980404606  1224.88490  Good till Canceled    N
Orders  2024-09-27 10:10:38.595584  2024-09-27 10:10:38.595580  MESZ4.CME  Rithmic Direct - DTC (Order update)  1220  1980404603  Limit  1  Sell  5823.00    Pending Cancel      TPT1771430  Close  1219            0.00  1980404603  1220.48443  Good till Canceled    N
Orders  2024-09-27 10:10:38.595638  2024-09-27 10:10:38.595635  MESZ4.CME  Rithmic Direct - DTC (Canceled)  1220  1980404603  Limit  1  Sell  5823.00    Canceled      TPT1771430  Close  1219            0.00  1980404603  1220.48443  Good till Canceled    N
Orders  2024-09-27 10:10:38.595655  2024-09-27 10:10:38.595653  MESZ4.CME  Rithmic Direct - DTC (Order update)  1223  1980404605  Limit  1  Sell  5836.00    Pending Cancel      TPT1771430  Close  1222            0.00  1980404605  1223.38498  Good till Canceled    N
Orders  2024-09-27 10:10:38.595666  2024-09-27 10:10:38.595665  MESZ4.CME  Rithmic Direct - DTC (Canceled)  1223  1980404605  Limit  1  Sell  5836.00    Canceled      TPT1771430  Close  1222            0.00  1980404605  1223.38498  Good till Canceled    N
Positions  2024-09-27 10:10:38.612597  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 1                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 10:10:38.612632  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 10:10:44.592613  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 11:24:21.540504  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 11:41:24.290109  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 12:41:25.850961  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 12:43:15.993906  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 12:43:26.024352  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Orders  2024-09-27 13:43:54.216387  2024-09-27 13:43:54.216360  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1235    Limit    Sell  5798.25    Pending Child-Client      TPT1771430  Close  1234            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.216445  2024-09-27 13:43:54.216436  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1236    Stop    Sell  5782.50    Pending Child-Client      TPT1771430  Close  1234            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.216461  2024-09-27 13:43:54.216457  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1  1234    Market  7  Buy      Order Sent      TPT1771430  Open              0.00      Day    N
Orders  2024-09-27 13:43:54.216613  2024-09-27 13:43:54.216608  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1238    Limit    Sell  5805.25    Pending Child-Client      TPT1771430  Close  1237            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.216623  2024-09-27 13:43:54.216619  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1239    Stop    Sell  5782.50    Pending Child-Client      TPT1771430  Close  1237            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.216735  2024-09-27 13:43:54.216729  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1  1237    Market  2  Buy      Order Sent      TPT1771430  Open              0.00      Day    N
Orders  2024-09-27 13:43:54.216905  2024-09-27 13:43:54.216894  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1241    Limit    Sell  5816.25    Pending Child-Client      TPT1771430  Close  1240            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.216961  2024-09-27 13:43:54.216956  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1. Attached Order | Client side bracket order | Server side OCO order  1242    Stop    Sell  5782.50    Pending Child-Client      TPT1771430  Close  1240            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.216970  2024-09-27 13:43:54.216966  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order entry | Last: 5791.25 | AO=1  1240    Market  1  Buy      Order Sent      TPT1771430  Open              0.00      Day    N
Orders  2024-09-27 13:43:54.301457  2024-09-27 13:43:54.301449  MESZ4.CME  Rithmic Direct - DTC (New)  1234  1981210956  Market  7  Buy      Pending Open      TPT1771430  Open              0.00    1234.24180  Day    N
Orders  2024-09-27 13:43:54.301489  2024-09-27 13:43:54.301486  MESZ4.CME  Rithmic Direct - DTC (New)  1234  1981210956  Market  7  Buy      Open      TPT1771430  Open              0.00  1981210956  1234.24180  Day    N
Orders  2024-09-27 13:43:54.301503  2024-09-27 13:43:54.301501  MESZ4.CME  Rithmic Direct - DTC (Filled)  1234  1981210956  Market  7  Buy      Filled  5791.25  7  TPT1771430  Open      1932940        0.00  1981210956  1234.24180  Day    N
Positions  2024-09-27 13:43:54.301513  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 7. Previous: 0. Fill of InternalOrderID: 1234        7        Unspecified      TPT1771430      7          0.00          N
Fills  2024-09-27 13:43:54.301524  2024-09-27 13:43:54.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1234  1981210956  Market  7  Buy      Filled  5791.25  7  TPT1771430  Open    7  1932940        0.00  1981210956  1234.24180  Day    N
Orders  2024-09-27 13:43:54.301612  2024-09-27 13:43:54.301611  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 579125  1236    Stop    Sell  5782.50    Pending Child-Client      TPT1771430  Close  1234            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.301616  2024-09-27 13:43:54.301616  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 579375  1236    Stop    Sell  5782.50    Pending Child-Client      TPT1771430  Close  1234            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.301620  2024-09-27 13:43:54.301619  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 579125  1236    Stop    Sell  5782.50    Pending Child-Client      TPT1771430  Close  1234            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.301623  2024-09-27 13:43:54.301622  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 579125  1236    Stop    Sell  5782.50    Pending Child-Client      TPT1771430  Close  1234            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.301636  2024-09-27 13:43:54.301634  MESZ4.CME  Auto-sent child from parent fill  1235    Limit  7  Sell  5798.25    Order Sent      TPT1771430  Close  1234  7          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.301679  2024-09-27 13:43:54.301677  MESZ4.CME  Auto-sent child from parent fill  1236    Stop  7  Sell  5782.50    Order Sent      TPT1771430  Close  1234  7          0.00      Good till Canceled    N
Positions  2024-09-27 13:43:54.303270  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 7                Unspecified      TPT1771430      7          0.00          N
Orders  2024-09-27 13:43:54.303838  2024-09-27 13:43:54.303832  MESZ4.CME  Rithmic Direct - DTC (New)  1237  1981210958  Market  2  Buy      Pending Open      TPT1771430  Open    7          0.00    1237.41800  Day    N
Orders  2024-09-27 13:43:54.303859  2024-09-27 13:43:54.303857  MESZ4.CME  Rithmic Direct - DTC (New)  1240  1981210959  Market  1  Buy      Pending Open      TPT1771430  Open    7          0.00    1240.40461  Day    N
Orders  2024-09-27 13:43:54.303874  2024-09-27 13:43:54.303872  MESZ4.CME  Rithmic Direct - DTC (New)  1237  1981210958  Market  2  Buy      Open      TPT1771430  Open    7          0.00  1981210958  1237.41800  Day    N
Orders  2024-09-27 13:43:54.303939  2024-09-27 13:43:54.303937  MESZ4.CME  Rithmic Direct - DTC (Filled)  1237  1981210958  Market  2  Buy      Filled  5791.00  2  TPT1771430  Open    7  1932942        0.00  1981210958  1237.41800  Day    N
Positions  2024-09-27 13:43:54.303954  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 9. Previous: 7. Fill of InternalOrderID: 1237        2        Unspecified      TPT1771430      9          0.00          N
Fills  2024-09-27 13:43:54.303959  2024-09-27 13:43:54.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1237  1981210958  Market  2  Buy      Filled  5791.00  2  TPT1771430  Open    9  1932942        0.00  1981210958  1237.41800  Day    N
Orders  2024-09-27 13:43:54.304041  2024-09-27 13:43:54.304039  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5805.00. Requested Price: 5805.00. Requested Quantity: 0  1238    Limit    Sell  5805.25    Pending Modify      TPT1771430  Close  1237  9          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304053  2024-09-27 13:43:54.304051  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5805.00. Requested Price: 5805.00. Requested Quantity: 0  1238    Limit    Sell  5805.00    Pending Child-Client      TPT1771430  Close  1237  9          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304067  2024-09-27 13:43:54.304066  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5782.25. Requested Price: 5782.25. Requested Quantity: 0  1239    Stop    Sell  5782.50    Pending Modify      TPT1771430  Close  1237  9          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304083  2024-09-27 13:43:54.304081  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5782.25. Requested Price: 5782.25. Requested Quantity: 0  1239    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1237  9          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304096  2024-09-27 13:43:54.304095  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 579100  1239    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1237            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304099  2024-09-27 13:43:54.304099  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 579350  1239    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1237            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304102  2024-09-27 13:43:54.304101  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 579100  1239    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1237            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304105  2024-09-27 13:43:54.304104  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 579100  1239    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1237            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304115  2024-09-27 13:43:54.304113  MESZ4.CME  Auto-sent child from parent fill  1238    Limit  2  Sell  5805.00    Order Sent      TPT1771430  Close  1237  9          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304121  2024-09-27 13:43:54.304120  MESZ4.CME  Auto-sent child from parent fill  1239    Stop  2  Sell  5782.25    Order Sent      TPT1771430  Close  1237  9          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.304735  2024-09-27 13:43:54.304725  MESZ4.CME  Rithmic Direct - DTC (New)  1240  1981210959  Market  1  Buy      Open      TPT1771430  Open    9          0.00  1981210959  1240.40461  Day    N
Orders  2024-09-27 13:43:54.305412  2024-09-27 13:43:54.305404  MESZ4.CME  Rithmic Direct - DTC (Filled)  1240  1981210959  Market  1  Buy      Filled  5791.00  1  TPT1771430  Open    9  1932944        0.00  1981210959  1240.40461  Day    N
Positions  2024-09-27 13:43:54.305856  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 10. Previous: 9. Fill of InternalOrderID: 1240        1        Unspecified      TPT1771430      10          0.00          N
Fills  2024-09-27 13:43:54.305875  2024-09-27 13:43:54.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1240  1981210959  Market  1  Buy      Filled  5791.00  1  TPT1771430  Open    10  1932944        0.00  1981210959  1240.40461  Day    N
Orders  2024-09-27 13:43:54.305935  2024-09-27 13:43:54.305933  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5816.00. Requested Price: 5816.00. Requested Quantity: 0  1241    Limit    Sell  5816.25    Pending Modify      TPT1771430  Close  1240  10          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305949  2024-09-27 13:43:54.305947  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5816.00. Requested Price: 5816.00. Requested Quantity: 0  1241    Limit    Sell  5816.00    Pending Child-Client      TPT1771430  Close  1240  10          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305962  2024-09-27 13:43:54.305960  MESZ4.CME  Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5782.25. Requested Price: 5782.25. Requested Quantity: 0  1242    Stop    Sell  5782.50    Pending Modify      TPT1771430  Close  1240  10          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305968  2024-09-27 13:43:54.305967  MESZ4.CME  Order modified internally. Modifying Attached Order from parent fill. Parent base price: 5791.00. New price: 5782.25. Requested Price: 5782.25. Requested Quantity: 0  1242    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1240  10          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305974  2024-09-27 13:43:54.305973  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 579100  1242    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1240            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305978  2024-09-27 13:43:54.305977  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 579350  1242    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1240            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305980  2024-09-27 13:43:54.305979  MESZ4.CME  Updating move to breakeven stop reference price on parent modification/fill to 579100  1242    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1240            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305983  2024-09-27 13:43:54.305982  MESZ4.CME  Updating move to breakeven stop trigger price on parent modification/fill to 579100  1242    Stop    Sell  5782.25    Pending Child-Client      TPT1771430  Close  1240            0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305991  2024-09-27 13:43:54.305989  MESZ4.CME  Auto-sent child from parent fill  1241    Limit  1  Sell  5816.00    Order Sent      TPT1771430  Close  1240  10          0.00      Good till Canceled    N
Orders  2024-09-27 13:43:54.305998  2024-09-27 13:43:54.305997  MESZ4.CME  Auto-sent child from parent fill  1242    Stop  1  Sell  5782.25    Order Sent      TPT1771430  Close  1240  10          0.00      Good till Canceled    N
Positions  2024-09-27 13:43:54.306711  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 9                Unspecified      TPT1771430      10          0.00          N
Positions  2024-09-27 13:43:54.306748  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 10                Unspecified      TPT1771430      10          0.00          N
Orders  2024-09-27 13:43:54.348604  2024-09-27 13:43:54.348596  MESZ4.CME  Rithmic Direct - DTC (New)  1235  1981210962  Limit  7  Sell  5798.25    Pending Open      TPT1771430  Close  1234  10          0.00    1235.32031  Good till Canceled    N
Orders  2024-09-27 13:43:54.348641  2024-09-27 13:43:54.348639  MESZ4.CME  Rithmic Direct - DTC (New)  1236  1981210963  Stop  7  Sell  5782.50    Pending Open      TPT1771430  Close  1234  10          0.00    1236.40639  Good till Canceled    N
Orders  2024-09-27 13:43:54.351864  2024-09-27 13:43:54.351861  MESZ4.CME  Rithmic Direct - DTC (New)  1235  1981210962  Limit  7  Sell  5798.25    Open      TPT1771430  Close  1234  10          0.00  1981210962  1235.32031  Good till Canceled    N
Orders  2024-09-27 13:43:54.351884  2024-09-27 13:43:54.351882  MESZ4.CME  Rithmic Direct - DTC (New)  1236  1981210963  Stop  7  Sell  5782.50    Open      TPT1771430  Close  1234  10          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:43:54.386209  2024-09-27 13:43:54.386164  MESZ4.CME  Rithmic Direct - DTC (New)  1238  1981210964  Limit  2  Sell  5805.00    Pending Open      TPT1771430  Close  1237  10          0.00    1238.27029  Good till Canceled    N
Orders  2024-09-27 13:43:54.386890  2024-09-27 13:43:54.386886  MESZ4.CME  Rithmic Direct - DTC (New)  1239  1981210965  Stop  2  Sell  5782.25    Pending Open      TPT1771430  Close  1237  10          0.00    1239.44553  Good till Canceled    N
Orders  2024-09-27 13:43:54.386915  2024-09-27 13:43:54.386913  MESZ4.CME  Rithmic Direct - DTC (New)  1238  1981210964  Limit  2  Sell  5805.00    Open      TPT1771430  Close  1237  10          0.00  1981210964  1238.27029  Good till Canceled    N
Orders  2024-09-27 13:43:54.387984  2024-09-27 13:43:54.387981  MESZ4.CME  Rithmic Direct - DTC (New)  1239  1981210965  Stop  2  Sell  5782.25    Open      TPT1771430  Close  1237  10          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:43:54.388005  2024-09-27 13:43:54.388003  MESZ4.CME  Rithmic Direct - DTC (New)  1241  1981210966  Limit  1  Sell  5816.00    Pending Open      TPT1771430  Close  1240  10          0.00    1241.58896  Good till Canceled    N
Orders  2024-09-27 13:43:54.388017  2024-09-27 13:43:54.388015  MESZ4.CME  Rithmic Direct - DTC (New)  1242  1981210967  Stop  1  Sell  5782.25    Pending Open      TPT1771430  Close  1240  10          0.00    1242.23509  Good till Canceled    N
Orders  2024-09-27 13:43:54.388028  2024-09-27 13:43:54.388026  MESZ4.CME  Rithmic Direct - DTC (New)  1241  1981210966  Limit  1  Sell  5816.00    Open      TPT1771430  Close  1240  10          0.00  1981210966  1241.58896  Good till Canceled    N
Orders  2024-09-27 13:43:54.388038  2024-09-27 13:43:54.388036  MESZ4.CME  Rithmic Direct - DTC (New)  1242  1981210967  Stop  1  Sell  5782.25    Open      TPT1771430  Close  1240  10          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:44:30.432694  2024-09-27 13:44:30.432684  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5794.00. Requested Quantity: 7  1235  1981210962  Limit  7  Sell  5798.25    Pending Modify      TPT1771430  Close  1234  10          0.00  1981210962  1235.32031  Good till Canceled    N
Orders  2024-09-27 13:44:30.523016  2024-09-27 13:44:30.523006  MESZ4.CME  Rithmic Direct - DTC (Order update)  1235  1981210962  Limit  7  Sell  5794.00    Pending Modify      TPT1771430  Close  1234  10          0.00  1981210962  1235.32031  Good till Canceled    N
Orders  2024-09-27 13:44:30.523061  2024-09-27 13:44:30.523059  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1235  1981210962  Limit  7  Sell  5794.00    Open      TPT1771430  Close  1234  10          0.00  1981210962  1235.32031  Good till Canceled    N
Orders  2024-09-27 13:44:46.271777  2024-09-27 13:44:46.271764  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5781.00. Requested Quantity: 7  1236  1981210963  Stop  7  Sell  5782.50    Pending Modify      TPT1771430  Close  1234  10          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:44:46.271840  2024-09-27 13:44:46.271838  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5781.00. Requested Quantity: 7. Requested Price: 5781.00. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5782.25    Pending Modify      TPT1771430  Close  1237  10          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:44:46.271906  2024-09-27 13:44:46.271903  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5781.00. Requested Quantity: 7. Requested Price: 5781.00. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5782.25    Pending Modify      TPT1771430  Close  1240  10          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:44:46.373887  2024-09-27 13:44:46.373876  MESZ4.CME  Rithmic Direct - DTC (Order update)  1236  1981210963  Stop  7  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  10          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:44:46.373917  2024-09-27 13:44:46.373915  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1236  1981210963  Stop  7  Sell  5781.00    Open      TPT1771430  Close  1234  10          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:44:46.373929  2024-09-27 13:44:46.373927  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5781.00    Pending Modify      TPT1771430  Close  1237  10          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:44:46.373938  2024-09-27 13:44:46.373937  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5781.00    Pending Modify      TPT1771430  Close  1240  10          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:44:46.373947  2024-09-27 13:44:46.373946  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5781.00    Open      TPT1771430  Close  1237  10          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:44:46.373956  2024-09-27 13:44:46.373954  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5781.00    Open      TPT1771430  Close  1240  10          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:45:04.647290  2024-09-27 13:45:04.647274  MESZ4.CME  Rithmic Direct - DTC (Partial fill)  1235  1981210962  Limit  7  Sell  5794.00    Open  5794.00  1  TPT1771430  Close  1234  10  1933362        0.00  1981210962  1235.32031  Good till Canceled    N
Positions  2024-09-27 13:45:04.647327  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 9. Previous: 10. Fill of InternalOrderID: 1235        1        Unspecified      TPT1771430      9          0.00          N
Fills  2024-09-27 13:45:04.647338  2024-09-27 13:45:04.000000  MESZ4.CME  Rithmic Direct - DTC (Partial fill)  1235  1981210962  Limit  1  Sell  5794.00    Open  5794.00  1  TPT1771430  Close  1234  9  1933362  5794.00  5790.00    0.00  1981210962  1235.32031  Good till Canceled    N
Orders  2024-09-27 13:45:04.647493  2024-09-27 13:45:04.647490  MESZ4.CME  Auto trail order modification. 1. Trigger order: 1235. Using LastModifyQuantity of 1. Using new provided price. Requested Price: 5788.00. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5781.00    Pending Modify      TPT1771430  Close  1240  9          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:45:04.647528  2024-09-27 13:45:04.647526  MESZ4.CME  Auto trail order modification. 1. Trigger order: 1235. Using LastModifyQuantity of 2. Using new provided price. Requested Price: 5788.00. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5781.00    Pending Modify      TPT1771430  Close  1237  9          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:45:04.647544  2024-09-27 13:45:04.647542  MESZ4.CME  Auto trail order modification. 1. Trigger order: 1235. Using LastModifyQuantity of 7. Using new provided price. Requested Price: 5788.25. Requested Quantity: 7  1236  1981210963  Stop  7  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  9          0.00  1981210963  1236.40639  Good till Canceled    N
Positions  2024-09-27 13:45:04.648106  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 9                Unspecified      TPT1771430      9          0.00          N
Orders  2024-09-27 13:45:04.650528  2024-09-27 13:45:04.650521  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1236  1981210963  Stop  6  Sell  5781.00    Open      TPT1771430  Close  1234  9          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.650560  2024-09-27 13:45:04.650559  MESZ4.CME  Updating last modify Price and Quantity to current values due to an external modification or other reason. LastModifyPrice1: 5788.25, CurrentPrice1: 5781.00, LastModifyQuantity: 7, CurrentQuantity: 6  1236  1981210963  Stop  6  Sell  5781.00    Open      TPT1771430  Close  1234            0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.658068  2024-09-27 13:45:04.658059  MESZ4.CME  Rithmic Direct - DTC (Partial fill)  1235  1981210962  Limit  7  Sell  5794.00    Open  5794.00  2  TPT1771430  Close  1234  9  1933366        0.00  1981210962  1235.32031  Good till Canceled    N
Positions  2024-09-27 13:45:04.658097  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 8. Previous: 9. Fill of InternalOrderID: 1235        1        Unspecified      TPT1771430      8          0.00          N
Fills  2024-09-27 13:45:04.658105  2024-09-27 13:45:04.000000  MESZ4.CME  Rithmic Direct - DTC (Partial fill)  1235  1981210962  Limit  1  Sell  5794.00    Open  5794.00  2  TPT1771430  Close  1234  8  1933366  5794.00  5794.00    0.00  1981210962  1235.32031  Good till Canceled    N
Positions  2024-09-27 13:45:04.658212  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 8                Unspecified      TPT1771430      8          0.00          N
Orders  2024-09-27 13:45:04.661509  2024-09-27 13:45:04.661503  MESZ4.CME  Rithmic Direct - DTC (Order update)  1236  1981210963  Stop  6  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  8          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.661535  2024-09-27 13:45:04.661532  MESZ4.CME  Rithmic Direct - DTC (Partial fill)  1235  1981210962  Limit  7  Sell  5794.00    Open  5794.00  3  TPT1771430  Close  1234  8  1933367        0.00  1981210962  1235.32031  Good till Canceled    N
Positions  2024-09-27 13:45:04.661552  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 7. Previous: 8. Fill of InternalOrderID: 1235        1        Unspecified      TPT1771430      7          0.00          N
Fills  2024-09-27 13:45:04.661558  2024-09-27 13:45:04.000000  MESZ4.CME  Rithmic Direct - DTC (Partial fill)  1235  1981210962  Limit  1  Sell  5794.00    Open  5794.00  3  TPT1771430  Close  1234  7  1933367  5794.00  5794.00    0.00  1981210962  1235.32031  Good till Canceled    N
Orders  2024-09-27 13:45:04.661653  2024-09-27 13:45:04.661649  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1236  1981210963  Stop  5  Sell  5781.00    Open      TPT1771430  Close  1234  7          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.661672  2024-09-27 13:45:04.661671  MESZ4.CME  Updating last modify Price and Quantity to current values due to an external modification or other reason. LastModifyPrice1: 5781.00, CurrentPrice1: 5781.00, LastModifyQuantity: 6, CurrentQuantity: 5  1236  1981210963  Stop  5  Sell  5781.00    Open      TPT1771430  Close  1234            0.00  1981210963  1236.40639  Good till Canceled    N
Positions  2024-09-27 13:45:04.661681  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 7                Unspecified      TPT1771430      7          0.00          N
Orders  2024-09-27 13:45:04.661709  2024-09-27 13:45:04.661706  MESZ4.CME  Rithmic Direct - DTC (Order update)  1236  1981210963  Stop  5  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  7          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.661725  2024-09-27 13:45:04.661723  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  7          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.661731  2024-09-27 13:45:04.661730  MESZ4.CME  Updating last modify Price and Quantity to current values due to an external modification or other reason. LastModifyPrice1: 5781.00, CurrentPrice1: 5781.00, LastModifyQuantity: 5, CurrentQuantity: 4  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234            0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.680379  2024-09-27 13:45:04.680365  MESZ4.CME  Rithmic Direct - DTC (Filled)  1235  1981210962  Limit  7  Sell  5794.00    Filled  5794.00  7  TPT1771430  Close  1234  7  1933370        0.00  1981210962  1235.32031  Good till Canceled    N
Positions  2024-09-27 13:45:04.680413  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 3. Previous: 7. Fill of InternalOrderID: 1235        4        Unspecified      TPT1771430      3          0.00          N
Fills  2024-09-27 13:45:04.680423  2024-09-27 13:45:04.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1235  1981210962  Limit  4  Sell  5794.00    Filled  5794.00  7  TPT1771430  Close  1234  3  1933370  5794.00  5794.00    0.00  1981210962  1235.32031  Good till Canceled    N
Orders  2024-09-27 13:45:04.681014  2024-09-27 13:45:04.681008  MESZ4.CME  Rithmic Direct - DTC (Order update)  1236  1981210963  Stop  4  Sell  5781.00    Pending Cancel      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.681044  2024-09-27 13:45:04.681042  MESZ4.CME  Rithmic Direct - DTC (Canceled)  1236  1981210963  Stop  4  Sell  5781.00    Canceled      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Positions  2024-09-27 13:45:04.683280  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 3                Unspecified      TPT1771430      3          0.00          N
Orders  2024-09-27 13:45:04.694759  2024-09-27 13:45:04.694741  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5788.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:45:04.694804  2024-09-27 13:45:04.694802  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5788.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:45:04.694824  2024-09-27 13:45:04.694822  MESZ4.CME  Order modification failed | Rithmic Direct - DTC (Order cancel/replace reject)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:45:04.694858  2024-09-27 13:45:04.694856  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5788.00    Open      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:45:04.694872  2024-09-27 13:45:04.694869  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5788.00    Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:51:05.784163  2024-09-27 13:51:05.784153  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5783.25. Requested Quantity: 4  1236  1981210963  Stop  4  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:51:05.784399  2024-09-27 13:51:05.784396  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5783.25. Requested Quantity: 4. Requested Price: 5783.25. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5788.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:51:05.784459  2024-09-27 13:51:05.784457  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5783.25. Requested Quantity: 4. Requested Price: 5783.25. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5788.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:51:05.869997  2024-09-27 13:51:05.869989  MESZ4.CME  Order modification failed | Rithmic Direct - DTC (Order cancel/replace reject)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:51:05.870061  2024-09-27 13:51:05.870059  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5783.25    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:51:05.870075  2024-09-27 13:51:05.870073  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5783.25    Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:51:05.870103  2024-09-27 13:51:05.870102  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5783.25    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:51:05.870114  2024-09-27 13:51:05.870113  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5783.25    Open      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:51:10.909589  2024-09-27 13:51:10.909579  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5788.00. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5783.25    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:51:10.909648  2024-09-27 13:51:10.909646  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5788.00. Requested Quantity: 2. Requested Price: 5788.00. Requested Quantity: 4  1236  1981210963  Stop  4  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:51:10.909661  2024-09-27 13:51:10.909660  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5788.00. Requested Quantity: 2. Requested Price: 5788.00. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5783.25    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:51:10.992307  2024-09-27 13:51:10.992296  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5788.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:51:10.992344  2024-09-27 13:51:10.992342  MESZ4.CME  Order modification failed | Rithmic Direct - DTC (Order cancel/replace reject)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 13:51:10.992369  2024-09-27 13:51:10.992367  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5788.00    Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 13:51:10.992394  2024-09-27 13:51:10.992392  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5788.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 13:51:10.992404  2024-09-27 13:51:10.992403  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5788.00    Open      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:13:05.548881  2024-09-27 14:13:05.548853  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5790.00. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5788.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:13:05.549059  2024-09-27 14:13:05.549056  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5790.00. Requested Quantity: 2. Requested Price: 5790.00. Requested Quantity: 4  1236  1981210963  Stop  4  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:13:05.549171  2024-09-27 14:13:05.549166  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5790.00. Requested Quantity: 2. Requested Price: 5790.00. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5788.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:13:05.647434  2024-09-27 14:13:05.647420  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5790.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:13:05.647485  2024-09-27 14:13:05.647482  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5790.00    Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:13:05.647527  2024-09-27 14:13:05.647522  MESZ4.CME  Order modification failed | Rithmic Direct - DTC (Order cancel/replace reject)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:13:05.647577  2024-09-27 14:13:05.647575  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5790.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:13:05.647589  2024-09-27 14:13:05.647587  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5790.00    Open      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:42:30.497946  2024-09-27 14:42:30.497930  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5791.25. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5790.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:42:30.498072  2024-09-27 14:42:30.498070  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5791.25. Requested Quantity: 2. Requested Price: 5791.25. Requested Quantity: 4  1236  1981210963  Stop  4  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:42:30.498187  2024-09-27 14:42:30.498182  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5791.25. Requested Quantity: 2. Requested Price: 5791.25. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5790.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:42:30.593765  2024-09-27 14:42:30.593754  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5791.25    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:42:30.593830  2024-09-27 14:42:30.593828  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5791.25    Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:42:30.593850  2024-09-27 14:42:30.593849  MESZ4.CME  Order modification failed | Rithmic Direct - DTC (Order cancel/replace reject)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:42:30.593873  2024-09-27 14:42:30.593871  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5791.25    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:42:30.593883  2024-09-27 14:42:30.593881  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5791.25    Open      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:42:34.775445  2024-09-27 14:42:34.775436  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5790.00. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5791.25    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:42:34.775492  2024-09-27 14:42:34.775490  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5790.00. Requested Quantity: 2. Requested Price: 5790.00. Requested Quantity: 4  1236  1981210963  Stop  4  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:42:34.775506  2024-09-27 14:42:34.775505  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5790.00. Requested Quantity: 2. Requested Price: 5790.00. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5791.25    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:42:34.852748  2024-09-27 14:42:34.852737  MESZ4.CME  Order modification failed | Rithmic Direct - DTC (Order cancel/replace reject)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:42:34.852811  2024-09-27 14:42:34.852808  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5790.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:42:34.852827  2024-09-27 14:42:34.852825  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5790.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:42:34.852838  2024-09-27 14:42:34.852836  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5790.00    Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:42:34.852855  2024-09-27 14:42:34.852853  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5790.00    Open      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:46:20.388880  2024-09-27 14:46:20.388870  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5789.00. Requested Quantity: 2  1239  1981210965  Stop  2  Sell  5790.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:46:20.389150  2024-09-27 14:46:20.389146  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5789.00. Requested Quantity: 2. Requested Price: 5789.00. Requested Quantity: 4  1236  1981210963  Stop  4  Sell  5781.00    Pending Modify      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:46:20.389937  2024-09-27 14:46:20.389376  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order modification. Requested Price: 5789.00. Requested Quantity: 2. Requested Price: 5789.00. Requested Quantity: 1  1242  1981210967  Stop  1  Sell  5790.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:46:20.476016  2024-09-27 14:46:20.476005  MESZ4.CME  Rithmic Direct - DTC (Order update)  1239  1981210965  Stop  2  Sell  5789.00    Pending Modify      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:46:20.476065  2024-09-27 14:46:20.476063  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1239  1981210965  Stop  2  Sell  5789.00    Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 14:46:20.476091  2024-09-27 14:46:20.476089  MESZ4.CME  Order modification failed | Rithmic Direct - DTC (Order cancel/replace reject)  1236  1981210963  Stop  4  Sell  5781.00    Open      TPT1771430  Close  1234  3          0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 14:46:20.476144  2024-09-27 14:46:20.476140  MESZ4.CME  Rithmic Direct - DTC (Order update)  1242  1981210967  Stop  1  Sell  5789.00    Pending Modify      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 14:46:20.476177  2024-09-27 14:46:20.476175  MESZ4.CME  Rithmic Direct - DTC (Cancel/Replace complete)  1242  1981210967  Stop  1  Sell  5789.00    Open      TPT1771430  Close  1240  3          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 15:00:31.862544  2024-09-27 15:00:31.862531  MESZ4.CME  Rithmic Direct - DTC (New)  1239  1981210965  Stop  2  Sell  5789.00  5789.00  Open      TPT1771430  Close  1237  3          0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 15:00:31.862609  2024-09-27 15:00:31.862608  MESZ4.CME  Updating last modify Price and Quantity to current values due to an external modification or other reason. LastModifyPrice1: 5789.00, CurrentPrice1: 5789.00, LastModifyQuantity: 2, CurrentQuantity: 2  1239  1981210965  Stop  2  Sell  5789.00  5789.00  Open      TPT1771430  Close  1237            0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 15:00:31.862643  2024-09-27 15:00:31.862640  MESZ4.CME  Rithmic Direct - DTC (Filled)  1239  1981210965  Stop  2  Sell  5789.00  5789.00  Filled  5789.00  2  TPT1771430  Close  1237  3  1953822        0.00  1981210965  1239.44553  Good till Canceled    N
Positions  2024-09-27 15:00:31.862655  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 1. Previous: 3. Fill of InternalOrderID: 1239        2        Unspecified      TPT1771430      1          0.00          N
Fills  2024-09-27 15:00:31.862717  2024-09-27 15:00:32.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1239  1981210965  Stop  2  Sell  5789.00  5789.00  Filled  5789.00  2  TPT1771430  Close  1237  1  1953822  5802.25  5789.00    0.00  1981210965  1239.44553  Good till Canceled    N
Orders  2024-09-27 15:00:31.863933  2024-09-27 15:00:31.863921  MESZ4.CME  Rithmic Direct - DTC (New)  1242  1981210967  Stop  1  Sell  5789.00  5789.00  Open      TPT1771430  Close  1240  1          0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 15:00:31.863996  2024-09-27 15:00:31.863993  MESZ4.CME  Updating last modify Price and Quantity to current values due to an external modification or other reason. LastModifyPrice1: 5789.00, CurrentPrice1: 5789.00, LastModifyQuantity: 1, CurrentQuantity: 1  1242  1981210967  Stop  1  Sell  5789.00  5789.00  Open      TPT1771430  Close  1240            0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 15:00:31.865040  2024-09-27 15:00:31.865034  MESZ4.CME  Rithmic Direct - DTC (Filled)  1242  1981210967  Stop  1  Sell  5789.00  5789.00  Filled  5789.00  1  TPT1771430  Close  1240  1  1953824        0.00  1981210967  1242.23509  Good till Canceled    N
Positions  2024-09-27 15:00:31.865061  00:00:00.000000  MESZ4.CME  Updated Internal Position Quantity to 0. Previous: 1. Fill of InternalOrderID: 1242        1        Unspecified      TPT1771430                0.00          N
Fills  2024-09-27 15:00:31.865073  2024-09-27 15:00:32.000000  MESZ4.CME  Rithmic Direct - DTC (Filled)  1242  1981210967  Stop  1  Sell  5789.00  5789.00  Filled  5789.00  1  TPT1771430  Close  1240    1953824  5789.00  5789.00    0.00  1981210967  1242.23509  Good till Canceled    N
Orders  2024-09-27 15:00:31.866745  2024-09-27 15:00:31.866739  MESZ4.CME  Rithmic Direct - DTC (Order update)  1238  1981210964  Limit  2  Sell  5805.00    Pending Cancel      TPT1771430  Close  1237            0.00  1981210964  1238.27029  Good till Canceled    N
Orders  2024-09-27 15:00:31.866766  2024-09-27 15:00:31.866764  MESZ4.CME  Rithmic Direct - DTC (Order update)  1241  1981210966  Limit  1  Sell  5816.00    Pending Cancel      TPT1771430  Close  1240            0.00  1981210966  1241.58896  Good till Canceled    N
Orders  2024-09-27 15:00:31.866787  2024-09-27 15:00:31.866785  MESZ4.CME  Rithmic Direct - DTC (Canceled)  1238  1981210964  Limit  2  Sell  5805.00    Canceled      TPT1771430  Close  1237            0.00  1981210964  1238.27029  Good till Canceled    N
Orders  2024-09-27 15:00:31.866807  2024-09-27 15:00:31.866805  MESZ4.CME  Rithmic Direct - DTC (Canceled)  1241  1981210966  Limit  1  Sell  5816.00    Canceled      TPT1771430  Close  1240            0.00  1981210966  1241.58896  Good till Canceled    N
Positions  2024-09-27 15:00:31.868403  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 1                Unspecified      TPT1771430                0.00          N
Positions  2024-09-27 15:00:31.868441  00:00:00.000000  MESZ4.CME  Updated Service Position Quantity to 0                Unspecified      TPT1771430                0.00          N
Orders  2024-09-27 15:00:34.404148  2024-09-27 15:00:34.404136  MESZ4.CME  MESZ4.CME/MESZ4.CME [CBV][M] #2 | User order cancel  1236  1981210963  Stop  4  Sell  5781.00    Pending Cancel      TPT1771430  Close  1234            0.00  1981210963  1236.40639  Good till Canceled    N
Orders  2024-09-27 15:00:35.356643  2024-09-27 15:00:35.356631  MESZ4.CME  Rithmic Direct - DTC (Canceled)  1236  1981210963  Stop  4  Sell  5781.00    Canceled      TPT1771430  Close  1234            0.00  1981210963  1236.40639  Good till Canceled    N
Positions  2024-09-27 15:00:39.630836  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
Info  2024-09-28 12:10:41.044053  00:00:00.000000    Rithmic Direct - DTC | Received first Trade Positions report from DTC server.                Unspecified      TPT1771430                0.00          N
Positions  2024-09-28 12:10:50.908503  00:00:00.000000  MESZ4.CME  Removing Position with quantity of 0                Unspecified      TPT1771430                0.00          N
[2024-09-30 13:05:57]
Sierra_Chart Engineering - Posts: 17143
We have seen this issue with Rithmic before. This is strictly a Rithmic issue. It is Rithmic that is not setting the Status of the order to Canceled, or an Error status.
They are setting it to Open! Sierra Chart is simply displaying the status transmitted by Rithmic.
All of this is controlled by status. If Rithmic is not providing the proper status then, that is the issue.
Date Time Of Last Edit: 2024-09-30 13:06:27
[2024-09-30 14:44:49]
Rithmic has been contacted about this today, and we provided them details. We have asked them to resolve the issue.
[2024-09-30 16:51:00]
gr8fultrading - Posts: 8
Thank you. Will advise if issue persists.
[2024-09-30 20:37:02]
No issues with any trades today. Thank you again.
[2024-10-03 16:09:28]
We do not know whether Rithmic has done anything to resolve this or not. We would not expect it to be quick but we do not know.
