Date/Time: Fri, 22 Nov 2024 16:51:27 +0000
Using Rithmic with Sierra Chart in Apex funded account for non-professional
View Count: 167
[2024-09-26 00:44:14]
User321619 - Posts: 26
After looking at reviews it is clear that there might be problems in using Rithmic directly with Sierra Chart while having apex funded account.
Looking further it is possible to use Sierra Chart to place trades while having Apex funded account and using Denali data feed. Is that correct?
Am looking for Integrated Standard Sierra Chart (Service Package 10) currently. In addition to $36/month for this package. What will be fees for Denali data feed (non-professional). Will I have to use Teton routing to make this work? If yes, how much will that cost.
I also know that I will need to have a personal account with broker in which I will have to login once a month. For that Stage 5 is recommended. I have reached out to them and still waiting for response. However, if you could tell me if there is any monthly fee associated with their account. Or I just have to maintain a minimum balance? Does minimum balance depend on the contracts I will trade in my Apex funded trader account?
I know there are few questions. But quicker I get the answers I could start my Sierra chart use.
[2024-09-26 13:22:47]
John - SC Support - Posts: 36221
Yes, this is correct.
You will find the pricing for the exchanges at the following link:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
You do not need the Teton Order Routing Service to get the data. These are completely separate items.
You need to check with Stage 5 on their requirements. In general, you would just need to maintain a minimum balance.
There is no connection between your Stage 5 account and your APEX account. The minimum balance you would need with Stage 5 is up to Stage 5.
[2024-10-04 16:51:32]
Hello, I posted another support request. I usually get email confirmation of support request. However, for this request I did not get email confirmation. So not sure if you are able to see the support request. To make sure you are seeing the new support request, am posting it here again.
"Not getting any data"
Currently using Apex evaluation account.
Want to use Denali Data Feed. Activated the feed. Created external trade account. Connected and activated trade account. Switching back to "Rithmic Direct - DTC" in Data/Trade service settings in Sierra Chart.
After this am getting no data. It stopped, it was working before I did above steps.
Need help.
[2024-10-04 17:57:46]
This was answered here:
