Date/Time: Thu, 31 Oct 2024 10:12:43 +0000
Is there a way to speed up the quantity change across charts that are linked?
View Count: 138
[2024-09-13 14:23:22] |
User740504 - Posts: 105 |
If I change the trade quantity (number of contracts) on my chart via the Trade Window attached to the chart, sometimes it will take a full second or two to change that same quantity on all other charts in that chartbook that are linked to that chart. Several times I have been burned when I click on a different quantity (either to exit a trade or add to a trade) and then immediately place an order on the DOM, only for the previous quantity to get executed because the system hasn't updated yet. I try to remember to give it a full second delay, but sometimes forget. I have multiple DOMs up to watch cross-asset flow, in a very particular order, with a very particular size to fit on my monitor, and so just putting the trade window on the DOM is not an option. Is there a way to increase this speed so that it's instant? Chart update interval is currently set to 10ms. Example: - Trade quantity set to 10 contracts. - I go long 10 contracts. - I feel I can tighten my stop and add more contracts. - I set quantity to 3 on the chart trade window. - I immediately place a limit buy order at my previous entry price on the DOM. - I then tighten my stop on the chart. If I don't wait a full second, 10 contracts will place on the DOM instead of the updated value of 3, since the system hasn't registered the change yet. This nearly screwed me today since I was outside of my risk parameters because I thought I was adding 3 and the system added more. Just curious if there's a way to speed up this process. Thank you as always. Date Time Of Last Edit: 2024-09-13 21:51:19
[2024-09-16 14:00:34] |
Sierra_Chart Engineering - Posts: 16766 |
No, there is going to be a small delay. That is just how it is. It depends upon the Chart Update Interval of the destination charts. We will look into seeing what we can do though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-16 14:02:00
[2024-09-16 14:03:58] |
This will be improved upon in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-16 14:04:04
[2024-09-16 15:15:02] |
Thank you!
