Date/Time: Mon, 28 Sep 2026 10:04:49 +0000
the teton data is not updated
View Count: 512
[2024-09-02 20:43:02]
User498355 - Posts: 1
Dear Sierra Chart!
Today i download a new sierra chart 2627 version.
(before that I used 2626, it worked fine)
I did not update the old version, I start 2627 as a new one.
I set up the data connection: TETON CME Order Routing, AMP futures,(as I used before) but the data is not updated.
what can be done to make it work?
I also sent the message log.
AMP account: 164952
I also spoke with amp support, everything is fine there.
I already deleted the scid files, and delete all data and download, but it didn't solve the problem.
thank you
Peter
[2024-09-03 02:00:24]
Sierra_Chart Engineering - Posts: 24994
The current Sierra Chart version is 2671. Here are the update instructions:
The market may have been closed, at the time you did not see any updating.
Date Time Of Last Edit: 2024-09-03 02:00:29
