Date/Time: Tue, 04 Nov 2025 13:55:25 +0000
sc.BuyEntry = -1
View Count: 1270
[2014-09-01 18:00:48]
User33803 - Posts: 40
When I call the functions sc.BuyEntry or sc.SellEntry they return the value -1 which I assume that it is an error code and the order is not sent. I cannot find that error code in the documentation. Can you help me to find out what is going on?
The errors which come in the documentation(SCT_SKIPPED_DOWNLOADING_HISTORICAL_DATA, SCT_SKIPPED_FULL_RECALC, etc) are in the [-8999, -8995] range.
Could you, please, tell me what error corresponds to the value -1?
Date Time Of Last Edit: 2014-09-01 18:01:36
[2014-09-01 18:17:27]
The SCTRADING_ORDER_ERROR (-1) constant is documented here:
http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#TRADINGERROR
If you see a case where you get this error, and there is no corresponding message added to the Trade >> Trade Service Log, we need to know about that and be given an example to duplicate the problem.
[2014-09-01 18:20:00]
I will investigate.
Thank you.
