Date/Time: Wed, 15 Jan 2025 08:38:18 +0000
Setting lower region to
View Count: 135
[2024-08-13 16:03:15] |
sean3000 - Posts: 61 |
I have a study in a lower region with values that can become very large, so I prefer to set this study's value format to Large Integer with Suffix. However, doing this causes the main region's price column to become much wider than the price text. Is there any way to address this? |
Screenshot 2024-08-13 at 9.36.01 AM.png / V - Attached On 2024-08-13 15:57:10 UTC - Size: 167.91 KB - 43 views |
[2024-08-13 16:34:25] |
John - SC Support - Posts: 37226 |
The first answer is that you can not change the width of the price ladder. So how it is showing is what it is. But, we are a bit confused on why you are having it be so wide. We did a couple of setups similar to what you have and we are not able to reproduce the width you are seeing. Attached is basically the same layout as you have, but we do not see the large width you are seeing. Rather, you can see that the width is being driven by the size of the numbers in the study in region 2. Please get us a copy of that chart for us to take a look. Follow these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
PLTR-NQTV[M] 1 Min #5 2024-08-13 11_32_41.133.png / V - Attached On 2024-08-13 16:32:59 UTC - Size: 88.58 KB - 51 views |
[2024-08-14 19:47:45] |
Thanks. Attaching a screenshot and chartbook with isolated chart.
Screenshot 2024-08-14 at 1.43.02 PM.png / V - Attached On 2024-08-14 19:45:05 UTC - Size: 134.58 KB - 35 views Price Column Width Issue 08-14-2024.Cht - Attached On 2024-08-14 19:47:01 UTC - Size: 9.48 KB - 185 views |
[2024-08-14 19:58:41] |
For the study with ID of 6 (Volume Delta Weighted Average), which is the first study in Region 2. Go to the Scale Settings for that study and disable the option for "Include in Scale Width Calculation". Refer to the following: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Chart Scale and Scale Adjusting: Include in Scale Width Calculation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
