Date/Time: Sun, 08 Sep 2024 00:12:23 +0000
Number of the chart in which the trade startet
View Count: 100
[2024-07-26 18:34:52] |
User931541 - Posts: 17 |
I've looked through everything (I think) there is in terms of logs, but I haven't found the number of the chart in which the trade was started anywhere. Have I really missed something or does it really not exist? |
[2024-07-26 19:13:29] |
If the order is from an automated trading system, then this would be noted in the Orders in the Trade Activity page on the Trade Activity Log. But, if this is a manual order, then the chart number is not specified. You could add the Chart Number to the "Text Tag" and then this will be available in the "OrderActionSource" on the Trade Activity page of the Trade Activity Log as well as the Note column on the Trade page of the Trade Activity Log. Refer to the following: Basic Trading and the Trade Window: Set >> Text Tag For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-29 18:36:31] |
It is an automatic trading per study. I have solved it via 'TextTag' and that is ok. Thanks!
