Date/Time: Tue, 04 Nov 2025 15:43:12 +0000
How do I add the [M] and the DD: 00:00:00 on my chart?
View Count: 314
| [2024-07-26 03:48:58] |
| User354557 - Posts: 2 |
I know it's a strange request but I don't know how to word it. I just know that having the [M] and the DD: should be 00:00:00 for a zero delay in data. Is there a way to have this or something of reference to see that data isn't delayed. Thanks! |
| [2024-07-26 17:08:03] |
| John - SC Support - Posts: 42754 |
The "[M]" indicator is automatically placed after the symbol in the Chart Header, if you are using the data from us (Sierra Chart). The only thing you have to in order to view this is to have the symbol displayed in the Chart Header. The "Data Delay" is a chart header option that you can either choose to display or not. Refer to the following for how to modify the Chart Header: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
