Date/Time: Thu, 26 Nov 2026 13:20:44 +0000
diagonal drawings misaligned
View Count: 503
| [2024-07-24 15:57:26] |
| SafSaf - Posts: 160 |
alright lads, please see the attachment. you will see 3 charts i've bunched together for the purposes of a screen shot. the first one is a 5 min, then a 1 min and finally a 30 min. please pay particular attention to the blue diagonal lines marked '1hr' and '2hr'. you will notice, compared to the price, these lines are in different positions on each chart. how do i get them to be in exactly the same positions, bearing in mind the orange horizontal lines are? for reference, all the lines were drawn in another chart in the same chartbook and i allowed them to be copied into all the other charts in the chart book. on the 5 min, the 1hr line is at 5608.50, the same line is at 5609.50 on the 1 min and at 5603 on the 30 min on the 5 min, the 2hr line is at 5576.00, 5577 on the 1 min and 5570.50 on the 30 min i need them to be in exactly the same position on all charts pls |
| [2024-07-24 16:02:42] |
This is due to how drawings are mapped between charts. Refer to the following: Lines/Rays or Other Chart Drawings Move After Drawing Them: How Chart Drawings Are Mapped Between Bars with Different Starting Date-Times Keep in mind that if you are looking at where the drawings extend to after the last bar, then this will definitely not match up between charts, as that space can be different, and the times that actually make up that space are different, so you will have different values in that area. But you should be good within the bars themselves. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
