Date/Time: Fri, 18 Oct 2024 04:03:31 +0000
No CFE Real-time Data
View Count: 273
[2024-07-24 15:00:46] |
User359698 - Posts: 17 |
Hello, I haven't been receiving real-time data for CFE at all this week. I have tried everything I know to do but can't seem to get it going. From looking at the support board, I can't find anybody else who is having this issue. Please advise on what I can do to fix. Thank you. |
[2024-07-24 15:12:58] |
Sierra_Chart Engineering - Posts: 16656 |
What is the CFE futures symbol that you are using?
[2024-07-24 15:15:01] |
VX Futures
[2024-07-24 15:28:31] |
John - SC Support - Posts: 35333 |
What is the exact symbol as you have it entered for your chart (Chart >> Chart Settings >> Symbol >> Symbol)?
[2024-07-24 15:33:23] |
F.US.VXQ24
[2024-07-24 15:56:21] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-24 16:05:43] |
For the one symbol F.US.VXQ24 2024-07-23 20:07:00.961 | Trade activity files set size: 803 2024-07-23 20:07:01.360 | Reading Internal Order ID file. 2024-07-23 20:07:02.333 | Reading Trade Orders file. 2024-07-23 20:07:02.333 | Reading Trade Positions file. 2024-07-23 20:07:02.333 | Reading Trade Account Data files. 2024-07-23 20:07:02.392 | UDPListener (1664). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-07-23 20:07:02.392 | Software version: 2604 64-bit 2024-07-23 20:07:02.392 | Primary Thread ID: 23676 2024-07-23 20:07:02.392 | Usage end date: 2024-08-10 2024-07-23 20:07:02.392 | Enabled for: Advanced Features 2. 2024-07-23 20:07:02.392 | Enabled for: Sierra Chart Historical Data Service. 2024-07-23 20:07:02.392 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-07-23 20:07:02.392 | Enabled for: Delayed Denali Exchange Data Feed. 2024-07-23 20:07:02.392 | Enabled for exchange2: CME (Trading Account Required) 2024-07-23 20:07:02.392 | Enabled for exchange2: CBOT (Trading Account Required) 2024-07-23 20:07:02.392 | Enabled for exchange2: COMEX (Trading Account Required) 2024-07-23 20:07:02.392 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-07-23 20:07:02.392 | Enabled for exchange2: CFE 2024-07-23 20:07:02.392 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-07-23 20:07:02.392 | Current selected Data/Trading service: DTC - Sub Instance 2024-07-23 20:07:02.392 | Custom symbol settings values: enabled 2024-07-23 20:07:02.392 | Chart Update Interval: 2000 2024-07-23 20:07:02.392 | Intraday Data Storage Time Unit: 0 2024-07-23 20:07:02.392 | Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-07-23 20:07:02.392 | 2024-07-24 01:07:02 Local computer time in UTC 2024-07-23 20:07:02.392 | 2024-07-23 20:07:02 Local computer time in SC Time Zone 2024-07-23 20:07:02.392 | 2024-07-24 01:06:53 Server time in UTC 2024-07-23 20:07:02.392 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-07-23 20:07:02.392 | Program path: S:\Sierra Chart (CQG)\SierraChartInstance_13\ 2024-07-23 20:07:02.392 | Data Files path: S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\ 2024-07-23 20:07:02.392 | OS Version Number: 10.0 2024-07-23 20:07:02.392 | Locale Setting: C 2024-07-23 20:07:02.393 | DLLs: UserContributedStudies_64.dll 2024-07-23 20:07:02.393 | Allowed protected custom studies: 2024-07-23 20:07:02.393 | Crash reporter started: true 2024-07-23 20:07:02.393 | 2024-07-23 20:07:02.567 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-07-23 20:07:02.616 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-07-23 20:07:02.616 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-07-23 20:07:02.707 | Received 5 login tokens. 2024-07-23 20:07:04.888 | Requested user files to download. 2024-07-23 20:07:06.888 | 2024-07-23 20:07:06.910 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11101 2024-07-23 20:07:06.910 | DTC Client socket (1) | Creating socket. 2024-07-23 20:07:06.910 | DTC Client socket (1) | New receive buffer size: 0 2024-07-23 20:07:06.910 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-07-23 20:07:06.934 | DTC - Sub Instance | Network connection to server complete. 2024-07-23 20:07:06.934 | DTC - Sub Instance | Starting socket receive thread. 2024-07-23 20:07:06.934 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-07-23 20:07:06.935 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-07-23 20:07:06.935 | DTC - Sub Instance | Sending logon request message. 2024-07-23 20:07:06.936 | DTC - Sub Instance | Received logon response. 2024-07-23 20:07:06.936 | DTC - Sub Instance | Server Name: SC DTC Server. Build=49270. 2024-07-23 20:07:06.936 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-07-23 20:07:06.936 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg. 2024-07-23 20:07:06.936 | DTC - Sub Instance | Trading is supported. 2024-07-23 20:07:06.936 | DTC - Sub Instance | Order cancel and replace is supported. 2024-07-23 20:07:06.936 | DTC - Sub Instance | OCO Orders supported. 2024-07-23 20:07:06.936 | DTC - Sub Instance | Bracket Orders supported. 2024-07-23 20:07:06.936 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-07-23 20:07:06.936 | DTC - Sub Instance | Connected to server complete. 2024-07-23 20:07:06.936 | No download requests in the queue to start downloads for. 2024-07-23 20:07:06.936 | No download requests in the queue to start downloads for. 2024-07-23 20:07:06.936 | No download requests in the queue to start downloads for. 2024-07-23 20:07:06.936 | No download requests in the queue to start downloads for. 2024-07-23 20:07:06.936 | Subscribing to symbol for symbol alert. F.US.FGBXZ22 2024-07-23 20:07:06.936 | Using symbol data fast lookup vector 2024-07-23 20:07:06.937 | DTC - Sub Instance | Starting real-time market data updates for: F.US.FGBXZ22. ID: 1 Service code: cqg 2024-07-23 20:07:06.937 | DTC - Sub Instance | Requesting security definition data for: F.US.FGBXZ22. ID: 1 2024-07-23 20:07:06.937 | DTC - Sub Instance | Received security definition for symbol F.US.FGBXZ22 2024-07-23 20:07:10.155 | Files to Open on Startup | Opening file: VX_VP.Cht 2024-07-23 20:07:10.291 | F.US.VXQ24 [C] #3 | Reloading chart. 2024-07-23 20:07:10.410 | F.US.VXQ24 [C] #2 | Reloading chart. 2024-07-23 20:07:10.644 | F.US.VXQ24 [C] #1 | Reloading chart. 2024-07-23 20:07:10.693 | Files to Open on Startup | Opening file: VX-MW.Cht 2024-07-23 20:07:10.894 | F.US.VXQ24 [CB] Quarterly #3 | Reloading chart. 2024-07-23 20:07:14.601 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:14.601 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:14.601 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:14.606 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:14.607 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:14.607 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:16.142 | F.US.VXQ24 [CB] Monthly #1 | Reloading chart. 2024-07-23 20:07:17.615 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:17.615 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:17.615 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:17.624 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:17.625 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:17.625 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:19.277 | F.US.VXQ24 [CB] Weekly #2 | Reloading chart. 2024-07-23 20:07:20.832 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXV04.dly has a volume of 0 at 2004-10-14. 2024-07-23 20:07:20.846 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXN04.dly has a volume of 0 at 2004-07-15. 2024-07-23 20:07:20.859 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-04-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.859 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.860 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-05-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.860 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.862 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-06-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.862 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.862 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-07-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.862 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.863 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-08-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.863 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.864 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-09-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.864 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.865 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-10-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.865 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.866 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-11-18 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.866 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.867 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-12-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.867 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.868 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-01-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.868 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.868 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-02-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.868 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.869 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-03-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.869 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.870 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-04-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.870 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.888 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-11-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.889 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-12-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.889 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.898 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-03-10 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.899 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-04-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.899 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.905 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.906 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.906 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.911 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.912 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:20.912 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:22.521 | F.US.VXQ24 [C] Quarterly #4 | Reloading chart. 2024-07-23 20:07:24.092 | F.US.VXQ24 [C] Monthly #5 | Reloading chart. 2024-07-23 20:07:25.763 | F.US.VXQ24 [C] Weekly #6 | Reloading chart. 2024-07-23 20:07:27.357 | F.US.VXQ24 [CB] Yearly #7 | Reloading chart. 2024-07-23 20:07:28.741 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:28.742 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:28.742 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:28.746 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:28.747 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:28.747 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:30.446 | F.US.VXQ24 [C] Yearly #8 | Reloading chart. 2024-07-23 20:07:32.333 | Files to Open on Startup | Opening file: VX_DAILY.Cht 2024-07-23 20:07:32.568 | F.US.VXQ24 [CB] 1 Day #1 | Reloading chart. 2024-07-23 20:07:32.981 | F.US.VXQ24 [CB] 1 Day #2 | Reloading chart. 2024-07-23 20:07:33.600 | F.US.VXQ24 [C] 1 Day #3 | Reloading chart. 2024-07-23 20:07:33.873 | F.US.VXQ24 [C] 1 Day #4 | Reloading chart. 2024-07-23 20:07:34.575 | F.US.MVIM24 [CBV] #5 | Reloading chart. 2024-07-23 20:07:34.600 | F.US.MVIM24 [CBV] #5 | Performing continuous chart historical Daily data download for symbol F.US.MVIM24 starting at last date in file. 2024-07-23 20:07:34.600 | Starting DelayedDownloadMonitoringTimer 2024-07-23 20:07:34.601 | Starting HDTimeoutTimer 2024-07-23 20:07:34.601 | Added historical Daily data request for F.US.MVIM24 to the queue. 2024-07-23 20:07:34.657 | Triggering next historical data download in queue. 2024-07-23 20:07:34.658 | F.US.MVIM24 [CBV] #5 | Waiting for historical downloads to complete with the IDs: 1, 2024-07-23 20:07:35.036 | F.US.VXQ24 [CBV] #6 | Reloading chart. 2024-07-23 20:07:35.041 | F.US.VXQ24 [CBV] #6 | Performing continuous chart historical Daily data download for symbol F.US.VXQ24 starting at last date in file. 2024-07-23 20:07:35.041 | Added historical Daily data request for F.US.VXQ24 to the queue. 2024-07-23 20:07:35.050 | F.US.VXQ24 [CBV] #6 | Waiting for historical downloads to complete with the IDs: 2, 2024-07-23 20:07:35.260 | Files to Open on Startup | Opening file: VX_H4.Cht 2024-07-23 20:07:35.853 | F.US.VXQ24 [C] 240 Min #1 | Reloading chart. 2024-07-23 20:07:36.047 | F.US.VXQ24 [C] 240 Min #2 | Reloading chart. 2024-07-23 20:07:36.137 | Files to Open on Startup | Opening file: VX_H1.Cht 2024-07-23 20:07:36.611 | F.US.VXQ24 [C] 60 Min #2 | Reloading chart. 2024-07-23 20:07:36.816 | F.US.VXQ24 [C] 60 Min #1 | Reloading chart. 2024-07-23 20:07:36.918 | Files to Open on Startup | Opening file: VX_5.Cht 2024-07-23 20:07:37.355 | F.US.VXQ24 [C] 5 Min #1 | Reloading chart. 2024-07-23 20:07:37.631 | F.US.VXQ24 [C] #3 | Chart data loading complete. 2024-07-23 20:07:37.638 | F.US.VXQ24 [C] #1 | Chart data loading complete. 2024-07-23 20:07:37.733 | F.US.VXQ24 [C] #2 | Chart data loading complete. 2024-07-23 20:07:37.763 | F.US.VXQ24 [CB] Quarterly #3 | Chart data loading complete. 2024-07-23 20:07:37.777 | F.US.VXQ24 [CB] Monthly #1 | Chart data loading complete. 2024-07-23 20:07:37.806 | F.US.VXQ24 [CB] Weekly #2 | Chart data loading complete. 2024-07-23 20:07:37.820 | F.US.VXQ24 [C] Quarterly #4 | Chart data loading complete. 2024-07-23 20:07:37.847 | F.US.VXQ24 [C] Monthly #5 | Chart data loading complete. 2024-07-23 20:07:37.863 | F.US.VXQ24 [C] Weekly #6 | Chart data loading complete. 2024-07-23 20:07:37.879 | F.US.VXQ24 [CB] Yearly #7 | Chart data loading complete. 2024-07-23 20:07:37.882 | F.US.VXQ24 [C] Yearly #8 | Chart data loading complete. 2024-07-23 20:07:37.942 | HD Request # 1 | Downloading Historical Daily chart data for F.US.MVIM24. Starting date: 1974-08-06. Service: DTCSubInstance 2024-07-23 20:07:37.942 | HD Request # 1 | Using server: 127.0.0.1 port 11100 2024-07-23 20:07:37.942 | Socket (2) | Creating socket. 2024-07-23 20:07:37.942 | Socket (2) | New receive buffer size: 0 2024-07-23 20:07:37.942 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-23 20:07:38.038 | F.US.VXQ24 [CB] 1 Day #1 | Chart data loading complete. 2024-07-23 20:07:38.052 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-07-23 20:07:38.052 | HD Request # 1 | Sending historical data logon request message. 2024-07-23 20:07:38.053 | HD Request # 1 | Requesting historical Daily data starting at 1974-08-06. 2024-07-23 20:07:38.054 | HD Request # 1 | Data is being downloaded from a remote source. Download will start when this is done. 2024-07-23 20:07:38.055 | F.US.VXQ24 [CB] 1 Day #2 | Chart data loading complete. 2024-07-23 20:07:38.086 | F.US.VXQ24 [C] 1 Day #4 | Chart data loading complete. 2024-07-23 20:07:38.131 | F.US.VXQ24 [C] 240 Min #2 | Chart data loading complete. 2024-07-23 20:07:38.135 | F.US.VXQ24 [C] 240 Min #1 | Chart data loading complete. 2024-07-23 20:07:38.158 | F.US.VXQ24 [C] 60 Min #2 | Chart data loading complete. 2024-07-23 20:07:38.199 | F.US.VXQ24 [C] 1 Day #3 | Chart data loading complete. 2024-07-23 20:07:38.209 | F.US.VXQ24 [C] 60 Min #1 | Chart data loading complete. 2024-07-23 20:07:38.283 | F.US.VXQ24 [C] 5 Min #1 | Chart data loading complete. 2024-07-23 20:07:38.319 | DTC - Sub Instance | Starting real-time market data updates for: F.US.VXQ24. ID: 3 Service code: cqg 2024-07-23 20:07:38.319 | DTC - Sub Instance | Requesting security definition data for: F.US.VXQ24. ID: 3 2024-07-23 20:07:38.319 | Added historical Intraday data request for F.US.VXQ24 to the queue. 2024-07-23 20:07:38.319 | Intraday data recording state for symbol F.US.VXQ24 is set to download 'Pending'. 2024-07-23 20:07:38.319 | Triggering next historical data download in queue. 2024-07-23 20:07:38.320 | DTC - Sub Instance | Received security definition for symbol F.US.VXQ24 2024-07-23 20:07:39.041 | Socket (2) | CloseSocket call. 2024-07-23 20:07:39.041 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-23 20:07:39.041 | HD Request # 1 | Error downloading historical Daily data for F.US.MVIM24. Historical data file for F.US.MVIM24 not available. 2024-07-23 20:07:39.041 | Historical data download thread signaled to stop. 2024-07-23 20:07:39.041 | HD Request # 1 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MVIM24 2024-07-23 20:07:39.041 | HD Request # 1 | Completion time: 2s. 2024-07-23 20:07:39.041 | HD Request # 1 | Daily data download complete for F.US.MVIM24. Unique request ID: 1 2024-07-23 20:07:39.041 | Removing historical data download ID 1. 2024-07-23 20:07:39.041 | 2024-07-23 20:07:39.041 | Triggering next historical data download in queue. 2024-07-23 20:07:39.042 | Socket (2) | Socket gracefully closed by remote side. 2024-07-23 20:07:39.042 | Socket (2) | Closed. 2024-07-23 20:07:39.043 | HD Request # 2 | Downloading Historical Daily chart data for F.US.VXQ24. Starting date: 2024-07-19. Service: DTCSubInstance 2024-07-23 20:07:39.043 | HD Request # 2 | Using server: 127.0.0.1 port 11100 2024-07-23 20:07:39.043 | Socket (2) | Creating socket. 2024-07-23 20:07:39.043 | Socket (2) | New receive buffer size: 0 2024-07-23 20:07:39.043 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-23 20:07:39.075 | F.US.MVIM24 [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-23 20:07:39.076 | F.US.MVIM24 [CBV] #5 | Reloading chart. 2024-07-23 20:07:39.086 | F.US.MVIM24 [CBV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-07-23 20:07:39.087 | F.US.MVIM24 [CBV] #5 | Chart data loading complete. 2024-07-23 20:07:39.116 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-07-23 20:07:39.116 | HD Request # 2 | Sending historical data logon request message. 2024-07-23 20:07:39.116 | HD Request # 2 | Requesting historical Daily data starting at 2024-07-19. 2024-07-23 20:07:39.118 | HD Request # 2 | Data is being downloaded from a remote source. Download will start when this is done. 2024-07-23 20:07:39.156 | F.US.MVIM24 [CBV] #5 | Reloading chart. 2024-07-23 20:07:39.158 | F.US.MVIM24 [CBV] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-07-23 20:07:39.158 | F.US.MVIM24 [CBV] #5 | Chart data loading complete. 2024-07-23 20:07:39.232 | DTC - Sub Instance | Starting real-time market data updates for: F.US.MVIM24. ID: 2 Service code: cqg 2024-07-23 20:07:39.232 | DTC - Sub Instance | Requesting security definition data for: F.US.MVIM24. ID: 2 2024-07-23 20:07:39.232 | Added historical Intraday data request for F.US.MVIM24 to the queue. 2024-07-23 20:07:39.232 | Intraday data recording state for symbol F.US.MVIM24 is set to download 'Pending'. 2024-07-23 20:07:39.233 | Triggering next historical data download in queue. 2024-07-23 20:07:39.233 | DTC - Sub Instance | Received security definition for symbol F.US.MVIM24 2024-07-23 20:07:40.127 | HD Request # 2 | Decompressing data. 2024-07-23 20:07:40.129 | HD Request # 2 | Receiving historical Daily data for F.US.VXQ24 starting at 2024-07-19. 2024-07-23 20:07:40.129 | HD Request # 2 | Writing historical Daily data to the file F.US.VXQ24.dly. 2024-07-23 20:07:40.130 | Socket (2) | CloseSocket call. 2024-07-23 20:07:40.130 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-23 20:07:40.131 | Historical data download thread signaled to stop. 2024-07-23 20:07:40.131 | HD Request # 2 | Received 3 Daily data records from 2024-07-19 00:00:00 to 2024-07-23 00:00:00 (5.0 days) and wrote 3 records for F.US.VXQ24 2024-07-23 20:07:40.131 | HD Request # 2 | Completion time: 1s. 2024-07-23 20:07:40.131 | HD Request # 2 | Daily data download complete for F.US.VXQ24. Unique request ID: 2 2024-07-23 20:07:40.131 | Removing historical data download ID 2. 2024-07-23 20:07:40.131 | 2024-07-23 20:07:40.131 | Triggering next historical data download in queue. 2024-07-23 20:07:40.131 | Delaying start of download for F.US.VXQ24. 2024-07-23 20:07:40.132 | Socket (2) | Socket gracefully closed by remote side. 2024-07-23 20:07:40.132 | Socket (2) | Closed. 2024-07-23 20:07:40.144 | F.US.VXQ24 [CB] Monthly #1 | Reloading chart. 2024-07-23 20:07:41.527 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:41.529 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:41.529 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:41.536 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:41.537 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:41.537 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:43.199 | F.US.VXQ24 [CBV] #6 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-23 20:07:43.199 | F.US.VXQ24 [CBV] #6 | Reloading chart. 2024-07-23 20:07:43.208 | F.US.VXQ24 [CBV] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-07-23 20:07:43.208 | F.US.VXQ24 [CBV] #6 | Chart data loading complete. 2024-07-23 20:07:43.215 | F.US.VXQ24 [C] Yearly #8 | Reloading chart. 2024-07-23 20:07:44.658 | F.US.VXQ24 [CB] Monthly #1 | Chart data loading complete. 2024-07-23 20:07:44.666 | F.US.VXQ24 [C] Quarterly #4 | Reloading chart. 2024-07-23 20:07:46.094 | F.US.VXQ24 [C] Yearly #8 | Chart data loading complete. 2024-07-23 20:07:46.107 | HD Request # 3 | Downloading Intraday chart data for F.US.VXQ24 to the file F.US.VXQ24.scid. Service: cfe_exchange.data 2024-07-23 20:07:46.107 | HD Request # 3 | Download start date-time: 2024-07-23 15:59:57.000000. File last date-time: 2024-07-23 15:59:57.015004 2024-07-23 20:07:46.107 | HD Request # 3 | Using server: ds33.sierracharts.com port 10150 2024-07-23 20:07:46.124 | F.US.VXQ24 [CB] Quarterly #3 | Reloading chart. 2024-07-23 20:07:46.195 | Socket (2) | Creating socket. 2024-07-23 20:07:46.195 | Socket (2) | New receive buffer size: 0 2024-07-23 20:07:46.195 | Socket (2) | Connecting to IP: 69.39.70.245. 2024-07-23 20:07:46.327 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-07-23 20:07:46.327 | HD Request # 3 | Sending historical data logon request message. 2024-07-23 20:07:46.657 | HD Request # 3 | Requesting Intraday data. Start date-time: 2024-07-23 15:59:57. Record interval: 0. Symbol: VXQ24_FUT_CFE 2024-07-23 20:07:46.727 | HD Request # 3 | Decompressing data. 2024-07-23 20:07:46.793 | HD Request # 3 | Receiving Intraday data for F.US.VXQ24 starting at 2024-07-23 15:59:57.015000 2024-07-23 20:07:46.794 | Socket (2) | CloseSocket call. 2024-07-23 20:07:46.794 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-23 20:07:46.863 | Socket (2) | Socket gracefully closed by remote side. 2024-07-23 20:07:46.863 | Socket (2) | Closed. 2024-07-23 20:07:47.453 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:47.454 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:47.454 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:47.459 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:47.460 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:47.460 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:48.857 | F.US.VXQ24 [C] Quarterly #4 | Chart data loading complete. 2024-07-23 20:07:48.857 | Historical data download thread signaled to stop. 2024-07-23 20:07:48.857 | HD Request # 3 | Timestamp of first Intraday data file record written: 2024-07-23 17:00:00.000000. 2024-07-23 20:07:48.857 | HD Request # 3 | Received 423 Intraday data records from 2024-07-23 15:59:57.015000 to 2024-07-23 20:00:43.333002 (4.0 hours. Delay: 7.1 minutes) and wrote 418 records for F.US.VXQ24 2024-07-23 20:07:48.857 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2024-07-24 01:00:43.333002 2024-07-23 20:07:48.857 | HD Request # 3 | Completion time: 2s. 2024-07-23 20:07:48.857 | HD Request # 3 | Intraday data download complete for F.US.VXQ24. Unique request ID: 3 2024-07-23 20:07:48.857 | Removing historical data download ID 3. 2024-07-23 20:07:48.857 | Real-time Intraday chart data file updates started for F.US.VXQ24 2024-07-23 20:07:48.857 | Intraday chart data file opened for F.US.VXQ24 2024-07-23 20:07:48.857 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-07-23 20:07:48.857 | 2024-07-23 20:07:48.857 | Triggering next historical data download in queue. 2024-07-23 20:07:48.857 | HD Request # 4 | Downloading Intraday chart data for F.US.MVIM24 to the file F.US.MVIM24.scid. Service: cfe_exchange.data 2024-07-23 20:07:48.858 | HD Request # 4 | Download start date-time: 2024-06-18 07:56:58.000000. File last date-time: 2024-06-18 07:56:58.981000 2024-07-23 20:07:48.858 | HD Request # 4 | Using server: ds30.sierracharts.com port 10149 2024-07-23 20:07:48.858 | Socket (2) | Creating socket. 2024-07-23 20:07:48.858 | Socket (2) | New receive buffer size: 0 2024-07-23 20:07:48.858 | Socket (2) | Connecting to IP: 38.103.112.179. 2024-07-23 20:07:48.878 | F.US.VXQ24 [CB] Weekly #2 | Reloading chart. 2024-07-23 20:07:48.938 | HD Request # 4 | Setting DTC encoding to Binary VLS 2024-07-23 20:07:48.938 | HD Request # 4 | Sending historical data logon request message. 2024-07-23 20:07:49.249 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-06-18 07:56:58. Record interval: 0. Symbol: VXMM24_FUT_CFE 2024-07-23 20:07:49.287 | HD Request # 4 | Decompressing data. 2024-07-23 20:07:49.321 | HD Request # 4 | Receiving Intraday data for F.US.MVIM24 starting at 2024-06-18 07:56:58.981000 2024-07-23 20:07:49.321 | Socket (2) | CloseSocket call. 2024-07-23 20:07:49.321 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-23 20:07:49.354 | Socket (2) | Socket gracefully closed by remote side. 2024-07-23 20:07:49.354 | Socket (2) | Closed. 2024-07-23 20:07:50.329 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXV04.dly has a volume of 0 at 2004-10-14. 2024-07-23 20:07:50.342 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXN04.dly has a volume of 0 at 2004-07-15. 2024-07-23 20:07:50.355 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-04-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.355 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.356 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-05-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.356 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.357 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-06-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.357 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.358 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-07-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.358 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.359 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-08-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.359 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.360 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-09-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.360 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.360 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-10-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.360 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.361 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-11-18 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.361 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.362 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-12-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.362 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.363 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-01-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.363 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.364 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-02-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.364 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.365 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-03-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.365 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.366 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-04-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.366 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.383 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-11-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.385 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-12-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.385 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.393 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-03-10 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.394 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-04-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.394 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.400 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.401 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.401 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.406 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.407 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:50.407 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:51.802 | F.US.VXQ24 [CB] Quarterly #3 | Chart data loading complete. 2024-07-23 20:07:51.803 | Historical data download thread signaled to stop. 2024-07-23 20:07:51.803 | HD Request # 4 | Received 1 Intraday data record from 2024-06-18 07:56:58.981000 to 2024-06-18 07:56:58.981000 (0.0 seconds. Delay: 35.5 days) and wrote 0 records for F.US.MVIM24 2024-07-23 20:07:51.803 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2024-06-18 12:56:58.981000 2024-07-23 20:07:51.803 | HD Request # 4 | Completion time: 3s. 2024-07-23 20:07:51.803 | HD Request # 4 | Intraday data download complete for F.US.MVIM24. Unique request ID: 4 2024-07-23 20:07:51.803 | Removing historical data download ID 4. 2024-07-23 20:07:51.803 | Real-time Intraday chart data file updates started for F.US.MVIM24 2024-07-23 20:07:51.803 | Intraday chart data file opened for F.US.MVIM24 2024-07-23 20:07:51.803 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2024-07-23 20:07:51.803 | 2024-07-23 20:07:51.803 | No download requests in the queue to start downloads for. 2024-07-23 20:07:51.808 | F.US.VXQ24 [CB] Yearly #7 | Reloading chart. 2024-07-23 20:07:53.263 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:53.264 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:53.264 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:53.269 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:53.270 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:53.270 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-23 20:07:54.756 | F.US.VXQ24 [CB] Weekly #2 | Chart data loading complete. 2024-07-23 20:07:54.780 | F.US.VXQ24 [C] Weekly #6 | Reloading chart. 2024-07-23 20:07:56.264 | F.US.VXQ24 [CB] Yearly #7 | Chart data loading complete. 2024-07-23 20:07:56.267 | Requesting market depth updates for: F.US.MVIM24 if supported. NumLevels=1400 2024-07-23 20:07:56.267 | DTC - Sub Instance | Starting market orders updates for: F.US.MVIM24. MinimumMarketByOrderQuantity: 0. Service code: cqg 2024-07-23 20:07:56.267 | Requesting market depth updates for: F.US.VXQ24 if supported. NumLevels=1400 2024-07-23 20:07:56.267 | DTC - Sub Instance | Starting market orders updates for: F.US.VXQ24. MinimumMarketByOrderQuantity: 0. Service code: cqg 2024-07-23 20:07:56.268 | DTC - Sub Instance | Clearing market depth for F.US.MVIM24 2024-07-23 20:07:56.268 | DTC - Sub Instance | Clearing market depth for F.US.MVIM24 2024-07-23 20:07:56.268 | DTC - Sub Instance | Clearing market depth for F.US.VXQ24 2024-07-23 20:07:56.268 | DTC - Sub Instance | Clearing market depth for F.US.VXQ24 2024-07-23 20:07:56.270 | F.US.VXQ24 [C] Monthly #5 | Reloading chart. 2024-07-23 20:07:57.841 | F.US.VXQ24 [C] Weekly #6 | Chart data loading complete. 2024-07-23 20:07:57.850 | F.US.VXQ24 [CBV] #6 | Reloading chart. 2024-07-23 20:07:57.868 | F.US.VXQ24 [CBV] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-07-23 20:07:57.868 | F.US.VXQ24 [CBV] #6 | Chart data loading complete. 2024-07-23 20:07:58.187 | F.US.VXQ24 [C] Monthly #5 | Chart data loading complete. 2024-07-23 21:06:54.106 | Saved Chartbook: VX_VP.Cht. Time: 0.0016 seconds. 2024-07-23 21:06:54.120 | Saved Chartbook: VX-MW.Cht. Time: 0.0135 seconds. 2024-07-23 21:06:54.130 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0084 seconds. 2024-07-23 21:06:54.138 | Saved Chartbook: VX_H4.Cht. Time: 0.0068 seconds. 2024-07-23 21:06:54.146 | Saved Chartbook: VX_H1.Cht. Time: 0.0073 seconds. 2024-07-23 21:06:54.153 | Saved Chartbook: VX_5.Cht. Time: 0.0045 seconds. 2024-07-23 22:06:54.163 | Saved Chartbook: VX_VP.Cht. Time: 0.0019 seconds. 2024-07-23 22:06:54.176 | Saved Chartbook: VX-MW.Cht. Time: 0.0126 seconds. 2024-07-23 22:06:54.187 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0097 seconds. 2024-07-23 22:06:54.194 | Saved Chartbook: VX_H4.Cht. Time: 0.0062 seconds. 2024-07-23 22:06:54.202 | Saved Chartbook: VX_H1.Cht. Time: 0.0073 seconds. 2024-07-23 22:06:54.207 | Saved Chartbook: VX_5.Cht. Time: 0.0042 seconds. 2024-07-23 23:06:54.204 | Saved Chartbook: VX_VP.Cht. Time: 0.0020 seconds. 2024-07-23 23:06:54.220 | Saved Chartbook: VX-MW.Cht. Time: 0.0155 seconds. 2024-07-23 23:06:54.231 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0098 seconds. 2024-07-23 23:06:54.237 | Saved Chartbook: VX_H4.Cht. Time: 0.0051 seconds. 2024-07-23 23:06:54.244 | Saved Chartbook: VX_H1.Cht. Time: 0.0064 seconds. 2024-07-23 23:06:54.250 | Saved Chartbook: VX_5.Cht. Time: 0.0046 seconds. 2024-07-24 00:00:01.754 | Added historical Daily data request for F.US.VXQ24 to the queue. 2024-07-24 00:00:01.754 | Triggering next historical data download in queue. 2024-07-24 00:00:01.756 | HD Request # 5 | Downloading Historical Daily chart data for F.US.VXQ24. Starting date: 2024-07-19. Service: DTCSubInstance 2024-07-24 00:00:01.756 | HD Request # 5 | Using server: 127.0.0.1 port 11100 2024-07-24 00:00:01.756 | Socket (2) | Creating socket. 2024-07-24 00:00:01.757 | Socket (2) | New receive buffer size: 0 2024-07-24 00:00:01.757 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:00:01.877 | HD Request # 5 | Setting DTC encoding to Binary VLS 2024-07-24 00:00:01.877 | HD Request # 5 | Sending historical data logon request message. 2024-07-24 00:00:01.878 | HD Request # 5 | Requesting historical Daily data starting at 2024-07-19. 2024-07-24 00:00:01.878 | HD Request # 5 | Data is being downloaded from a remote source. Download will start when this is done. 2024-07-24 00:00:03.895 | HD Request # 5 | Decompressing data. 2024-07-24 00:00:03.895 | HD Request # 5 | Receiving historical Daily data for F.US.VXQ24 starting at 2024-07-19. 2024-07-24 00:00:03.895 | HD Request # 5 | Writing historical Daily data to the file F.US.VXQ24.dly. 2024-07-24 00:00:03.897 | Socket (2) | CloseSocket call. 2024-07-24 00:00:03.897 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:00:03.897 | Historical data download thread signaled to stop. 2024-07-24 00:00:03.897 | HD Request # 5 | Received 3 Daily data records from 2024-07-19 00:00:00 to 2024-07-23 00:00:00 (5.0 days) and wrote 3 records for F.US.VXQ24 2024-07-24 00:00:03.897 | HD Request # 5 | Completion time: 2s. 2024-07-24 00:00:03.897 | HD Request # 5 | Daily data download complete for F.US.VXQ24. Unique request ID: 5 2024-07-24 00:00:03.897 | Removing historical data download ID 5. 2024-07-24 00:00:03.897 | 2024-07-24 00:00:03.897 | No download requests in the queue to start downloads for. 2024-07-24 00:00:03.899 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:00:03.899 | Socket (2) | Closed. 2024-07-24 00:00:03.973 | F.US.VXQ24 [CB] Yearly #7 | Reloading chart. 2024-07-24 00:00:03.978 | F.US.VXQ24 [CB] Yearly #7 | Performing continuous chart historical Daily data download for symbol F.US.VXN05 starting at last date in file. 2024-07-24 00:00:03.978 | Added historical Daily data request for F.US.VXN05 to the queue. 2024-07-24 00:00:03.978 | Triggering next historical data download in queue. 2024-07-24 00:00:03.980 | F.US.VXQ24 [CB] Yearly #7 | Performing continuous chart historical Daily data download for symbol F.US.VXU05 starting at last date in file. 2024-07-24 00:00:03.981 | Added historical Daily data request for F.US.VXU05 to the queue. 2024-07-24 00:00:04.193 | F.US.VXQ24 [CB] Yearly #7 | Performing continuous chart historical Daily data download for symbol F.US.VXG24 starting at last date in file. 2024-07-24 00:00:04.193 | Added historical Daily data request for F.US.VXG24 to the queue. 2024-07-24 00:00:04.194 | F.US.VXQ24 [CB] Yearly #7 | Performing continuous chart historical Daily data download for symbol F.US.VXH24 starting at last date in file. 2024-07-24 00:00:04.194 | Added historical Daily data request for F.US.VXH24 to the queue. 2024-07-24 00:00:04.196 | F.US.VXQ24 [CB] Yearly #7 | Performing continuous chart historical Daily data download for symbol F.US.VXK24 starting at last date in file. 2024-07-24 00:00:04.196 | Added historical Daily data request for F.US.VXK24 to the queue. 2024-07-24 00:00:04.198 | F.US.VXQ24 [CB] Yearly #7 | Performing continuous chart historical Daily data download for symbol F.US.VXM24 starting at last date in file. 2024-07-24 00:00:04.198 | Added historical Daily data request for F.US.VXM24 to the queue. 2024-07-24 00:00:04.199 | F.US.VXQ24 [CB] Yearly #7 | Performing continuous chart historical Daily data download for symbol F.US.VXN24 starting at last date in file. 2024-07-24 00:00:04.199 | Added historical Daily data request for F.US.VXN24 to the queue. 2024-07-24 00:00:05.377 | F.US.VXQ24 [CB] Yearly #7 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, 2024-07-24 00:00:05.379 | HD Request # 6 | Downloading Historical Daily chart data for F.US.VXN05. Starting date: 1974-08-06. Service: DTCSubInstance 2024-07-24 00:00:05.379 | HD Request # 6 | Using server: 127.0.0.1 port 11100 2024-07-24 00:00:05.379 | Socket (2) | Creating socket. 2024-07-24 00:00:05.379 | Socket (2) | New receive buffer size: 0 2024-07-24 00:00:05.379 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:00:05.448 | HD Request # 6 | Setting DTC encoding to Binary VLS 2024-07-24 00:00:05.448 | HD Request # 6 | Sending historical data logon request message. 2024-07-24 00:00:05.448 | HD Request # 6 | Requesting historical Daily data starting at 1974-08-06. 2024-07-24 00:00:05.449 | HD Request # 6 | Data is being downloaded from a remote source. Download will start when this is done. 2024-07-24 00:00:05.757 | F.US.VXQ24 [CB] Quarterly #3 | Reloading chart. 2024-07-24 00:00:07.625 | F.US.VXQ24 [CB] Quarterly #3 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, 2024-07-24 00:00:07.627 | F.US.VXQ24 [CB] Monthly #1 | Reloading chart. 2024-07-24 00:00:10.215 | F.US.VXQ24 [CB] Monthly #1 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, 2024-07-24 00:00:10.248 | F.US.VXQ24 [C] Monthly #5 | Reloading chart. 2024-07-24 00:00:14.374 | F.US.VXQ24 [C] Monthly #5 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, 2024-07-24 00:00:14.378 | F.US.VXQ24 [C] Quarterly #4 | Reloading chart. 2024-07-24 00:00:14.450 | Socket (2) | CloseSocket call. 2024-07-24 00:00:14.450 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:00:14.450 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:00:14.450 | Socket (2) | Closed. 2024-07-24 00:00:19.224 | F.US.VXQ24 [C] Quarterly #4 | Waiting for historical downloads to complete with the IDs: 6, 7, 8, 9, 10, 11, 12, 2024-07-24 00:00:19.225 | HD Request # 6 | Error downloading historical Daily data for F.US.VXN05. Historical data file for F.US.VXN05 not available. 2024-07-24 00:00:19.225 | Historical data download thread signaled to stop. 2024-07-24 00:00:19.225 | HD Request # 6 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.VXN05 2024-07-24 00:00:19.225 | HD Request # 6 | Completion time: 14s. 2024-07-24 00:00:19.225 | HD Request # 6 | Daily data download complete for F.US.VXN05. Unique request ID: 6 2024-07-24 00:00:19.225 | Removing historical data download ID 6. 2024-07-24 00:00:19.225 | 2024-07-24 00:00:19.225 | Triggering next historical data download in queue. 2024-07-24 00:00:19.225 | HD Request # 7 | Downloading Historical Daily chart data for F.US.VXU05. Starting date: 1974-08-06. Service: DTCSubInstance 2024-07-24 00:00:19.225 | HD Request # 7 | Using server: 127.0.0.1 port 11100 2024-07-24 00:00:19.230 | F.US.VXQ24 [C] Weekly #6 | Reloading chart. 2024-07-24 00:00:19.241 | Socket (2) | Creating socket. 2024-07-24 00:00:19.241 | Socket (2) | New receive buffer size: 0 2024-07-24 00:00:19.241 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:00:25.312 | F.US.VXQ24 [C] Weekly #6 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, 10, 11, 12, 2024-07-24 00:00:25.338 | F.US.VXQ24 [CB] Weekly #2 | Reloading chart. 2024-07-24 00:00:25.411 | F.US.VXQ24 [CB] Weekly #2 | Performing continuous chart historical Daily data download for symbol F.US.VXZ04 starting at last date in file. 2024-07-24 00:00:25.411 | Added historical Daily data request for F.US.VXZ04 to the queue. 2024-07-24 00:00:25.411 | Triggering next historical data download in queue. 2024-07-24 00:00:25.417 | F.US.VXQ24 [CB] Weekly #2 | Performing continuous chart historical Daily data download for symbol F.US.VXJ05 starting at last date in file. 2024-07-24 00:00:25.417 | Added historical Daily data request for F.US.VXJ05 to the queue. 2024-07-24 00:00:29.280 | HD Request # 7 | Sending historical data logon request message. 2024-07-24 00:00:30.726 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXV04.dly has a volume of 0 at 2004-10-14. 2024-07-24 00:00:30.789 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXN04.dly has a volume of 0 at 2004-07-15. 2024-07-24 00:00:30.811 | F.US.VXQ24 [CB] Weekly #2 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, 10, 11, 12, 13, 14, 2024-07-24 00:00:30.814 | F.US.VXQ24 [C] Yearly #8 | Reloading chart. 2024-07-24 00:00:38.181 | F.US.VXQ24 [C] Yearly #8 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, 10, 11, 12, 2024-07-24 00:01:06.926 | HD Request # 7 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:06.926 | HD Request # 7 | Sending historical data logon request message. 2024-07-24 00:01:06.926 | Socket (2) | CloseSocket call. 2024-07-24 00:01:06.926 | Socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2024-07-24 00:01:06.926 | Socket (2) | Write has completed. Shutdown being performed. 2024-07-24 00:01:06.926 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:06.926 | HD Request # 7 | Error downloading historical Daily data for F.US.VXU05. Historical data logon error: Unsupported protocol version 2024-07-24 00:01:06.926 | Historical data download thread signaled to stop. 2024-07-24 00:01:06.926 | HD Request # 7 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.VXU05 2024-07-24 00:01:06.926 | HD Request # 7 | Completion time: 47s. 2024-07-24 00:01:06.926 | HD Request # 7 | Daily data download complete for F.US.VXU05. Unique request ID: 7 2024-07-24 00:01:06.926 | Removing historical data download ID 7. 2024-07-24 00:01:06.926 | 2024-07-24 00:01:06.927 | Triggering next historical data download in queue. 2024-07-24 00:01:06.928 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:06.928 | Socket (2) | Closed. 2024-07-24 00:01:06.930 | HD Request # 8 | Downloading Historical Daily chart data for F.US.VXG24. Starting date: 2024-02-06. Service: DTCSubInstance 2024-07-24 00:01:06.930 | HD Request # 8 | Using server: 127.0.0.1 port 11100 2024-07-24 00:01:06.930 | Socket (2) | Creating socket. 2024-07-24 00:01:06.930 | Socket (2) | New receive buffer size: 0 2024-07-24 00:01:06.930 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:01:07.251 | HD Request # 8 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:07.251 | HD Request # 8 | Sending historical data logon request message. 2024-07-24 00:01:07.251 | HD Request # 8 | Requesting historical Daily data starting at 2024-02-06. 2024-07-24 00:01:07.266 | HD Request # 8 | Decompressing data. 2024-07-24 00:01:07.268 | HD Request # 8 | Receiving historical Daily data for F.US.VXG24 starting at 2024-02-06. 2024-07-24 00:01:07.268 | HD Request # 8 | Writing historical Daily data to the file F.US.VXG24.dly. 2024-07-24 00:01:07.270 | Socket (2) | CloseSocket call. 2024-07-24 00:01:07.270 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:07.270 | Historical data download thread signaled to stop. 2024-07-24 00:01:07.270 | HD Request # 8 | Received 3 Daily data records from 2024-02-06 00:00:00 to 2024-02-08 00:00:00 (3.0 days) and wrote 3 records for F.US.VXG24 2024-07-24 00:01:07.270 | HD Request # 8 | Completion time: 1s. 2024-07-24 00:01:07.270 | HD Request # 8 | Daily data download complete for F.US.VXG24. Unique request ID: 8 2024-07-24 00:01:07.271 | Removing historical data download ID 8. 2024-07-24 00:01:07.271 | 2024-07-24 00:01:07.271 | Triggering next historical data download in queue. 2024-07-24 00:01:07.271 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:07.271 | Socket (2) | Closed. 2024-07-24 00:01:07.273 | HD Request # 9 | Downloading Historical Daily chart data for F.US.VXH24. Starting date: 2024-03-12. Service: DTCSubInstance 2024-07-24 00:01:07.273 | HD Request # 9 | Using server: 127.0.0.1 port 11100 2024-07-24 00:01:07.273 | Socket (2) | Creating socket. 2024-07-24 00:01:07.273 | Socket (2) | New receive buffer size: 0 2024-07-24 00:01:07.273 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:01:07.653 | HD Request # 9 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:07.653 | HD Request # 9 | Sending historical data logon request message. 2024-07-24 00:01:07.670 | HD Request # 9 | Requesting historical Daily data starting at 2024-03-12. 2024-07-24 00:01:07.687 | HD Request # 9 | Decompressing data. 2024-07-24 00:01:07.687 | HD Request # 9 | Receiving historical Daily data for F.US.VXH24 starting at 2024-03-12. 2024-07-24 00:01:07.687 | HD Request # 9 | Writing historical Daily data to the file F.US.VXH24.dly. 2024-07-24 00:01:07.689 | Socket (2) | CloseSocket call. 2024-07-24 00:01:07.689 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:07.689 | Historical data download thread signaled to stop. 2024-07-24 00:01:07.689 | HD Request # 9 | Received 3 Daily data records from 2024-03-12 00:00:00 to 2024-03-14 00:00:00 (3.0 days) and wrote 3 records for F.US.VXH24 2024-07-24 00:01:07.689 | HD Request # 9 | Completion time: 0s. 2024-07-24 00:01:07.689 | HD Request # 9 | Daily data download complete for F.US.VXH24. Unique request ID: 9 2024-07-24 00:01:07.689 | Removing historical data download ID 9. 2024-07-24 00:01:07.689 | 2024-07-24 00:01:07.690 | Triggering next historical data download in queue. 2024-07-24 00:01:07.690 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:07.690 | Socket (2) | Closed. 2024-07-24 00:01:07.692 | HD Request # 10 | Downloading Historical Daily chart data for F.US.VXK24. Starting date: 2024-05-14. Service: DTCSubInstance 2024-07-24 00:01:07.692 | HD Request # 10 | Using server: 127.0.0.1 port 11100 2024-07-24 00:01:07.692 | Socket (2) | Creating socket. 2024-07-24 00:01:07.692 | Socket (2) | New receive buffer size: 0 2024-07-24 00:01:07.692 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:01:09.235 | HD Request # 10 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:09.235 | HD Request # 10 | Sending historical data logon request message. 2024-07-24 00:01:09.235 | HD Request # 10 | Requesting historical Daily data starting at 2024-05-14. 2024-07-24 00:01:09.248 | HD Request # 10 | Decompressing data. 2024-07-24 00:01:09.250 | HD Request # 10 | Receiving historical Daily data for F.US.VXK24 starting at 2024-05-14. 2024-07-24 00:01:09.250 | HD Request # 10 | Writing historical Daily data to the file F.US.VXK24.dly. 2024-07-24 00:01:09.252 | Socket (2) | CloseSocket call. 2024-07-24 00:01:09.252 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:09.253 | Historical data download thread signaled to stop. 2024-07-24 00:01:09.253 | HD Request # 10 | Received 3 Daily data records from 2024-05-14 00:00:00 to 2024-05-16 00:00:00 (3.0 days) and wrote 3 records for F.US.VXK24 2024-07-24 00:01:09.253 | HD Request # 10 | Completion time: 2s. 2024-07-24 00:01:09.253 | HD Request # 10 | Daily data download complete for F.US.VXK24. Unique request ID: 10 2024-07-24 00:01:09.253 | Removing historical data download ID 10. 2024-07-24 00:01:09.253 | 2024-07-24 00:01:09.253 | Triggering next historical data download in queue. 2024-07-24 00:01:09.253 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:09.253 | Socket (2) | Closed. 2024-07-24 00:01:09.255 | HD Request # 11 | Downloading Historical Daily chart data for F.US.VXM24. Starting date: 2024-06-11. Service: DTCSubInstance 2024-07-24 00:01:09.255 | HD Request # 11 | Using server: 127.0.0.1 port 11100 2024-07-24 00:01:09.255 | Socket (2) | Creating socket. 2024-07-24 00:01:09.255 | Socket (2) | New receive buffer size: 0 2024-07-24 00:01:09.255 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:01:09.394 | HD Request # 11 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:09.394 | HD Request # 11 | Sending historical data logon request message. 2024-07-24 00:01:09.394 | HD Request # 11 | Requesting historical Daily data starting at 2024-06-11. 2024-07-24 00:01:09.407 | HD Request # 11 | Decompressing data. 2024-07-24 00:01:09.408 | HD Request # 11 | Receiving historical Daily data for F.US.VXM24 starting at 2024-06-11. 2024-07-24 00:01:09.409 | HD Request # 11 | Writing historical Daily data to the file F.US.VXM24.dly. 2024-07-24 00:01:09.411 | Socket (2) | CloseSocket call. 2024-07-24 00:01:09.411 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:09.411 | Historical data download thread signaled to stop. 2024-07-24 00:01:09.411 | HD Request # 11 | Received 3 Daily data records from 2024-06-11 00:00:00 to 2024-06-13 00:00:00 (3.0 days) and wrote 3 records for F.US.VXM24 2024-07-24 00:01:09.411 | HD Request # 11 | Completion time: 0s. 2024-07-24 00:01:09.411 | HD Request # 11 | Daily data download complete for F.US.VXM24. Unique request ID: 11 2024-07-24 00:01:09.411 | Removing historical data download ID 11. 2024-07-24 00:01:09.411 | 2024-07-24 00:01:09.411 | Triggering next historical data download in queue. 2024-07-24 00:01:09.412 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:09.412 | Socket (2) | Closed. 2024-07-24 00:01:09.413 | HD Request # 12 | Downloading Historical Daily chart data for F.US.VXN24. Starting date: 2024-07-09. Service: DTCSubInstance 2024-07-24 00:01:09.413 | HD Request # 12 | Using server: 127.0.0.1 port 11100 2024-07-24 00:01:09.413 | Socket (2) | Creating socket. 2024-07-24 00:01:09.413 | Socket (2) | New receive buffer size: 0 2024-07-24 00:01:09.413 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:01:09.544 | HD Request # 12 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:09.544 | HD Request # 12 | Sending historical data logon request message. 2024-07-24 00:01:09.544 | HD Request # 12 | Requesting historical Daily data starting at 2024-07-09. 2024-07-24 00:01:09.557 | HD Request # 12 | Decompressing data. 2024-07-24 00:01:09.559 | HD Request # 12 | Receiving historical Daily data for F.US.VXN24 starting at 2024-07-09. 2024-07-24 00:01:09.559 | HD Request # 12 | Writing historical Daily data to the file F.US.VXN24.dly. 2024-07-24 00:01:09.561 | Socket (2) | CloseSocket call. 2024-07-24 00:01:09.561 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:09.562 | Historical data download thread signaled to stop. 2024-07-24 00:01:09.562 | HD Request # 12 | Received 3 Daily data records from 2024-07-09 00:00:00 to 2024-07-11 00:00:00 (3.0 days) and wrote 3 records for F.US.VXN24 2024-07-24 00:01:09.562 | HD Request # 12 | Completion time: 0s. 2024-07-24 00:01:09.562 | HD Request # 12 | Daily data download complete for F.US.VXN24. Unique request ID: 12 2024-07-24 00:01:09.562 | Removing historical data download ID 12. 2024-07-24 00:01:09.562 | 2024-07-24 00:01:09.562 | Triggering next historical data download in queue. 2024-07-24 00:01:09.562 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:09.562 | Socket (2) | Closed. 2024-07-24 00:01:09.563 | HD Request # 13 | Downloading Historical Daily chart data for F.US.VXZ04. Starting date: 1974-08-06. Service: DTCSubInstance 2024-07-24 00:01:09.564 | HD Request # 13 | Using server: 127.0.0.1 port 11100 2024-07-24 00:01:09.564 | Socket (2) | Creating socket. 2024-07-24 00:01:09.564 | Socket (2) | New receive buffer size: 0 2024-07-24 00:01:09.565 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:01:09.659 | F.US.VXQ24 [CB] Monthly #1 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:09.706 | F.US.VXQ24 [CB] Monthly #1 | Reloading chart. 2024-07-24 00:01:09.717 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:09.718 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:09.718 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:09.724 | HD Request # 13 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:09.724 | HD Request # 13 | Sending historical data logon request message. 2024-07-24 00:01:09.725 | HD Request # 13 | Requesting historical Daily data starting at 1974-08-06. 2024-07-24 00:01:09.725 | HD Request # 13 | Data is being downloaded from a remote source. Download will start when this is done. 2024-07-24 00:01:09.726 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:09.727 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:09.727 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:10.719 | Socket (2) | CloseSocket call. 2024-07-24 00:01:10.719 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:10.720 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:10.720 | Socket (2) | Closed. 2024-07-24 00:01:12.552 | HD Request # 13 | Error downloading historical Daily data for F.US.VXZ04. Historical data file for F.US.VXZ04 not available. 2024-07-24 00:01:12.553 | Historical data download thread signaled to stop. 2024-07-24 00:01:12.553 | HD Request # 13 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.VXZ04 2024-07-24 00:01:12.553 | HD Request # 13 | Completion time: 3s. 2024-07-24 00:01:12.553 | HD Request # 13 | Daily data download complete for F.US.VXZ04. Unique request ID: 13 2024-07-24 00:01:12.553 | Removing historical data download ID 13. 2024-07-24 00:01:12.553 | 2024-07-24 00:01:12.553 | Triggering next historical data download in queue. 2024-07-24 00:01:12.554 | HD Request # 14 | Downloading Historical Daily chart data for F.US.VXJ05. Starting date: 1974-08-06. Service: DTCSubInstance 2024-07-24 00:01:12.554 | HD Request # 14 | Using server: 127.0.0.1 port 11100 2024-07-24 00:01:12.555 | F.US.VXQ24 [CB] Quarterly #3 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:12.556 | F.US.VXQ24 [CB] Quarterly #3 | Reloading chart. 2024-07-24 00:01:12.567 | Socket (2) | Creating socket. 2024-07-24 00:01:12.567 | Socket (2) | New receive buffer size: 0 2024-07-24 00:01:12.567 | Socket (2) | Connecting to IP: 127.0.0.1. 2024-07-24 00:01:12.568 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:12.569 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:12.569 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:12.610 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:12.614 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:12.614 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:15.181 | HD Request # 14 | Setting DTC encoding to Binary VLS 2024-07-24 00:01:15.181 | HD Request # 14 | Sending historical data logon request message. 2024-07-24 00:01:15.181 | HD Request # 14 | Requesting historical Daily data starting at 1974-08-06. 2024-07-24 00:01:15.181 | HD Request # 14 | Data is being downloaded from a remote source. Download will start when this is done. 2024-07-24 00:01:15.467 | F.US.VXQ24 [CB] Monthly #1 | Chart data loading complete. 2024-07-24 00:01:15.467 | F.US.VXQ24 [CB] Yearly #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:15.469 | F.US.VXQ24 [CB] Yearly #7 | Reloading chart. 2024-07-24 00:01:15.479 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:15.480 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:15.480 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:15.488 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:15.490 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:15.490 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:16.180 | Socket (2) | CloseSocket call. 2024-07-24 00:01:16.180 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 00:01:16.181 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 00:01:16.181 | Socket (2) | Closed. 2024-07-24 00:01:18.500 | F.US.VXQ24 [CB] Quarterly #3 | Chart data loading complete. 2024-07-24 00:01:18.500 | HD Request # 14 | Error downloading historical Daily data for F.US.VXJ05. Historical data file for F.US.VXJ05 not available. 2024-07-24 00:01:18.500 | Historical data download thread signaled to stop. 2024-07-24 00:01:18.501 | HD Request # 14 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.VXJ05 2024-07-24 00:01:18.501 | HD Request # 14 | Completion time: 6s. 2024-07-24 00:01:18.501 | HD Request # 14 | Daily data download complete for F.US.VXJ05. Unique request ID: 14 2024-07-24 00:01:18.501 | Removing historical data download ID 14. 2024-07-24 00:01:18.501 | 2024-07-24 00:01:18.501 | No download requests in the queue to start downloads for. 2024-07-24 00:01:18.502 | F.US.VXQ24 [C] Monthly #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:18.503 | F.US.VXQ24 [C] Monthly #5 | Reloading chart. 2024-07-24 00:01:18.575 | F.US.VXQ24 [C] Quarterly #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:18.577 | F.US.VXQ24 [C] Quarterly #4 | Reloading chart. 2024-07-24 00:01:18.687 | F.US.VXQ24 [C] Yearly #8 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:18.689 | F.US.VXQ24 [C] Yearly #8 | Reloading chart. 2024-07-24 00:01:18.764 | F.US.VXQ24 [C] Weekly #6 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:18.765 | F.US.VXQ24 [C] Weekly #6 | Reloading chart. 2024-07-24 00:01:18.831 | F.US.VXQ24 [CB] Weekly #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-07-24 00:01:18.832 | F.US.VXQ24 [CB] Weekly #2 | Reloading chart. 2024-07-24 00:01:18.835 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-04-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.835 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.837 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-05-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.837 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.838 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-06-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.838 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.840 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-07-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.840 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.841 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-08-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.841 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.843 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-09-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.843 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.845 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-10-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.845 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.846 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-11-18 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.846 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.848 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-12-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.848 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.901 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-01-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.901 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.902 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-02-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.902 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.904 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-03-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.904 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.906 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-04-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.906 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.964 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-11-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.966 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-12-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:18.966 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.007 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-03-10 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.009 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-04-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.009 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.019 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.020 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.020 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.063 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.065 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:19.065 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:21.743 | F.US.VXQ24 [C] Quarterly #4 | Chart data loading complete. 2024-07-24 00:01:21.746 | F.US.VXQ24 [C] Yearly #8 | Chart data loading complete. 2024-07-24 00:01:21.749 | F.US.VXQ24 [CB] Yearly #7 | Chart data loading complete. 2024-07-24 00:01:21.755 | F.US.VXQ24 [C] Monthly #5 | Chart data loading complete. 2024-07-24 00:01:21.760 | F.US.VXQ24 [C] Weekly #6 | Chart data loading complete. 2024-07-24 00:01:21.762 | F.US.VXQ24 [CB] Monthly #1 | Reloading chart. 2024-07-24 00:01:24.169 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:24.170 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:24.170 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:24.178 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:24.182 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:24.182 | F.US.VXQ24 [CB] Monthly #1 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:26.279 | F.US.VXQ24 [CB] Weekly #2 | Chart data loading complete. 2024-07-24 00:01:26.291 | F.US.VXQ24 [CB] Quarterly #3 | Reloading chart. 2024-07-24 00:01:28.686 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:28.687 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:28.687 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:28.694 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:28.696 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:28.696 | F.US.VXQ24 [CB] Quarterly #3 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:30.792 | F.US.VXQ24 [CB] Monthly #1 | Chart data loading complete. 2024-07-24 00:01:30.794 | F.US.VXQ24 [CB] Yearly #7 | Reloading chart. 2024-07-24 00:01:33.105 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:33.107 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:33.107 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:33.115 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:33.116 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:33.116 | F.US.VXQ24 [CB] Yearly #7 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:35.377 | F.US.VXQ24 [CB] Quarterly #3 | Chart data loading complete. 2024-07-24 00:01:35.380 | F.US.VXQ24 [C] Monthly #5 | Reloading chart. 2024-07-24 00:01:37.719 | F.US.VXQ24 [CB] Yearly #7 | Chart data loading complete. 2024-07-24 00:01:37.721 | F.US.VXQ24 [C] Quarterly #4 | Reloading chart. 2024-07-24 00:01:39.849 | F.US.VXQ24 [C] Monthly #5 | Chart data loading complete. 2024-07-24 00:01:39.851 | F.US.VXQ24 [C] Yearly #8 | Reloading chart. 2024-07-24 00:01:42.038 | F.US.VXQ24 [C] Quarterly #4 | Chart data loading complete. 2024-07-24 00:01:42.042 | F.US.VXQ24 [C] Weekly #6 | Reloading chart. 2024-07-24 00:01:44.314 | F.US.VXQ24 [C] Yearly #8 | Chart data loading complete. 2024-07-24 00:01:44.316 | F.US.VXQ24 [CB] Weekly #2 | Reloading chart. 2024-07-24 00:01:46.483 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXV04.dly has a volume of 0 at 2004-10-14. 2024-07-24 00:01:46.502 | F.US.VXQ24 [CB] Weekly #2 | File F.US.VXN04.dly has a volume of 0 at 2004-07-15. 2024-07-24 00:01:46.520 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-04-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.520 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.521 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-05-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.521 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.522 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-06-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXM03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.522 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.523 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-07-15 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.523 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.524 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-08-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.524 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.526 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-09-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.526 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.527 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-10-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.527 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.528 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-11-18 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXX03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.528 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.529 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2003-12-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ03.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.529 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.530 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-01-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.530 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.531 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-02-17 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXG04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.531 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.532 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-03-16 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXH04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.532 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.534 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-04-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.534 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.559 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-11-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.560 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2004-12-21 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXZ04.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.560 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXF05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.571 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-03-10 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.572 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-04-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.572 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXK05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.582 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-06-09 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.584 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-07-19 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXN05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.584 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXQ05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.591 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-08-11 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.593 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-09-20 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXU05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:46.593 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 0 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXV05.dly. Error: No Data for read. End of file. 2024-07-24 00:01:48.249 | F.US.VXQ24 [C] Weekly #6 | Chart data loading complete. 2024-07-24 00:01:48.629 | F.US.VXQ24 [CB] Weekly #2 | Chart data loading complete. 2024-07-24 00:06:54.246 | Saved Chartbook: VX_VP.Cht. Time: 0.0018 seconds. 2024-07-24 00:06:54.258 | Saved Chartbook: VX-MW.Cht. Time: 0.0103 seconds. 2024-07-24 00:06:54.268 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0090 seconds. 2024-07-24 00:06:54.275 | Saved Chartbook: VX_H4.Cht. Time: 0.0061 seconds. 2024-07-24 00:06:54.281 | Saved Chartbook: VX_H1.Cht. Time: 0.0056 seconds. 2024-07-24 00:06:54.286 | Saved Chartbook: VX_5.Cht. Time: 0.0041 seconds. 2024-07-24 01:06:54.298 | Saved Chartbook: VX_VP.Cht. Time: 0.0022 seconds. 2024-07-24 01:06:54.318 | Saved Chartbook: VX-MW.Cht. Time: 0.0143 seconds. 2024-07-24 01:06:54.349 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0083 seconds. 2024-07-24 01:06:54.360 | Saved Chartbook: VX_H4.Cht. Time: 0.0051 seconds. 2024-07-24 01:06:54.374 | Saved Chartbook: VX_H1.Cht. Time: 0.0061 seconds. 2024-07-24 01:06:54.385 | Saved Chartbook: VX_5.Cht. Time: 0.0029 seconds. 2024-07-24 02:06:54.402 | Saved Chartbook: VX_VP.Cht. Time: 0.0051 seconds. 2024-07-24 02:06:54.430 | Saved Chartbook: VX-MW.Cht. Time: 0.0262 seconds. 2024-07-24 02:06:54.443 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0122 seconds. 2024-07-24 02:06:54.449 | Saved Chartbook: VX_H4.Cht. Time: 0.0050 seconds. 2024-07-24 02:06:54.461 | Saved Chartbook: VX_H1.Cht. Time: 0.0110 seconds. 2024-07-24 02:06:54.466 | Saved Chartbook: VX_5.Cht. Time: 0.0039 seconds. 2024-07-24 03:06:54.475 | Saved Chartbook: VX_VP.Cht. Time: 0.0036 seconds. 2024-07-24 03:06:54.501 | Saved Chartbook: VX-MW.Cht. Time: 0.0243 seconds. 2024-07-24 03:06:54.511 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0090 seconds. 2024-07-24 03:06:54.517 | Saved Chartbook: VX_H4.Cht. Time: 0.0049 seconds. 2024-07-24 03:06:54.524 | Saved Chartbook: VX_H1.Cht. Time: 0.0055 seconds. 2024-07-24 03:06:54.529 | Saved Chartbook: VX_5.Cht. Time: 0.0043 seconds. 2024-07-24 04:06:54.537 | Saved Chartbook: VX_VP.Cht. Time: 0.0021 seconds. 2024-07-24 04:06:54.552 | Saved Chartbook: VX-MW.Cht. Time: 0.0143 seconds. 2024-07-24 04:06:54.563 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0106 seconds. 2024-07-24 04:06:54.570 | Saved Chartbook: VX_H4.Cht. Time: 0.0058 seconds. 2024-07-24 04:06:54.578 | Saved Chartbook: VX_H1.Cht. Time: 0.0064 seconds. 2024-07-24 04:06:54.584 | Saved Chartbook: VX_5.Cht. Time: 0.0057 seconds. 2024-07-24 05:06:54.585 | Saved Chartbook: VX_VP.Cht. Time: 0.0022 seconds. 2024-07-24 05:06:54.601 | Saved Chartbook: VX-MW.Cht. Time: 0.0149 seconds. 2024-07-24 05:06:54.612 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0098 seconds. 2024-07-24 05:06:54.618 | Saved Chartbook: VX_H4.Cht. Time: 0.0059 seconds. 2024-07-24 05:06:54.626 | Saved Chartbook: VX_H1.Cht. Time: 0.0062 seconds. 2024-07-24 05:06:54.631 | Saved Chartbook: VX_5.Cht. Time: 0.0043 seconds. 2024-07-24 06:06:54.631 | Saved Chartbook: VX_VP.Cht. Time: 0.0036 seconds. 2024-07-24 06:06:54.652 | Saved Chartbook: VX-MW.Cht. Time: 0.0186 seconds. 2024-07-24 06:06:54.667 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0139 seconds. 2024-07-24 06:06:54.677 | Saved Chartbook: VX_H4.Cht. Time: 0.0086 seconds. 2024-07-24 06:06:54.682 | Saved Chartbook: VX_H1.Cht. Time: 0.0044 seconds. 2024-07-24 06:06:54.687 | Saved Chartbook: VX_5.Cht. Time: 0.0045 seconds. 2024-07-24 07:06:54.690 | Saved Chartbook: VX_VP.Cht. Time: 0.0027 seconds. 2024-07-24 07:06:54.710 | Saved Chartbook: VX-MW.Cht. Time: 0.0187 seconds. 2024-07-24 07:06:54.721 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0101 seconds. 2024-07-24 07:06:54.728 | Saved Chartbook: VX_H4.Cht. Time: 0.0049 seconds. 2024-07-24 07:06:54.744 | Saved Chartbook: VX_H1.Cht. Time: 0.0155 seconds. 2024-07-24 07:06:54.757 | Saved Chartbook: VX_5.Cht. Time: 0.0118 seconds. 2024-07-24 08:06:54.779 | Saved Chartbook: VX_VP.Cht. Time: 0.0046 seconds. 2024-07-24 08:06:54.869 | Saved Chartbook: VX-MW.Cht. Time: 0.0874 seconds. 2024-07-24 08:06:54.891 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0203 seconds. 2024-07-24 08:06:54.912 | Saved Chartbook: VX_H4.Cht. Time: 0.0210 seconds. 2024-07-24 08:06:54.936 | Saved Chartbook: VX_H1.Cht. Time: 0.0222 seconds. 2024-07-24 08:06:54.948 | Saved Chartbook: VX_5.Cht. Time: 0.0099 seconds. 2024-07-24 09:06:54.954 | Saved Chartbook: VX_VP.Cht. Time: 0.0044 seconds. 2024-07-24 09:06:54.974 | Saved Chartbook: VX-MW.Cht. Time: 0.0192 seconds. 2024-07-24 09:06:54.989 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0142 seconds. 2024-07-24 09:06:55.003 | Saved Chartbook: VX_H4.Cht. Time: 0.0125 seconds. 2024-07-24 09:06:55.014 | Saved Chartbook: VX_H1.Cht. Time: 0.0098 seconds. 2024-07-24 09:06:55.021 | Saved Chartbook: VX_5.Cht. Time: 0.0068 seconds. 2024-07-24 09:44:19.549 | F.US.VXQ24 [C] 1 Day #3 | Reloading chart. 2024-07-24 09:44:22.300 | F.US.VXQ24 [C] 1 Day #3 | Chart data loading complete. 2024-07-24 09:45:53.547 | CQG account data changed. Requesting updated account information. 2024-07-24 09:45:54.219 | Successfully processed CQG account data. 2024-07-24 09:45:54.220 | Requested user files to download. 2024-07-24 10:06:55.026 | Saved Chartbook: VX_VP.Cht. Time: 0.0111 seconds. 2024-07-24 10:06:55.056 | Saved Chartbook: VX-MW.Cht. Time: 0.0289 seconds. 2024-07-24 10:06:55.071 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0140 seconds. 2024-07-24 10:06:55.086 | Saved Chartbook: VX_H4.Cht. Time: 0.0140 seconds. 2024-07-24 10:06:55.140 | Saved Chartbook: VX_H1.Cht. Time: 0.0534 seconds. 2024-07-24 10:06:55.160 | Saved Chartbook: VX_5.Cht. Time: 0.0196 seconds. 2024-07-24 10:17:58.158 | F.US.VXQ24 [C] 1 Day #3 | Reloading chart. 2024-07-24 10:18:00.824 | F.US.VXQ24 [C] 1 Day #3 | Chart data loading complete. 2024-07-24 11:01:30.421 | Saved Chartbook: VX_VP.Cht. Time: 0.0079 seconds. 2024-07-24 11:01:30.657 | Saved Chartbook: VX-MW.Cht. Time: 0.2299 seconds. 2024-07-24 11:01:30.706 | Saved Chartbook: VX_DAILY.Cht. Time: 0.0483 seconds. 2024-07-24 11:01:30.719 | Saved Chartbook: VX_H4.Cht. Time: 0.0122 seconds. 2024-07-24 11:01:30.791 | Saved Chartbook: VX_H1.Cht. Time: 0.0717 seconds. 2024-07-24 11:01:30.837 | Saved Chartbook: VX_5.Cht. Time: 0.0448 seconds. 2024-07-24 11:01:33.696 | Unsubscribed from market depth data for F.US.MVIM24 2024-07-24 11:01:33.696 | DTC - Sub Instance | Unsubscribing market orders updates for: F.US.MVIM24.. Service code: cqg 2024-07-24 11:01:33.696 | Unsubscribed from market depth data for F.US.VXQ24 2024-07-24 11:01:33.696 | DTC - Sub Instance | Unsubscribing market orders updates for: F.US.VXQ24.. Service code: cqg 2024-07-24 11:01:33.844 | DTC - Sub Instance | Clearing market depth for F.US.VXQ24 2024-07-24 11:01:33.844 | DTC - Sub Instance | Clearing market depth for F.US.MVIM24 2024-07-24 11:01:57.449 | F.US.VXQ24 1 Min #1 | Reloading chart. 2024-07-24 11:01:57.594 | F.US.VXQ24 1 Min #1 | Chart data loading complete. 2024-07-24 11:02:06.993 | File >> Disconnect selected. 2024-07-24 11:02:06.993 | DTC - Sub Instance | Waiting for socket receive thread to end 2024-07-24 11:02:06.994 | DTC Client socket (1) | CloseSocket call. 2024-07-24 11:02:06.994 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-07-24 11:02:06.994 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-07-24 11:02:06.994 | DTC Client socket (1) | Closed. 2024-07-24 11:02:06.994 | DTC - Sub Instance | Disconnected. 2024-07-24 11:02:13.568 | 2024-07-24 11:02:13.568 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11101 2024-07-24 11:02:13.568 | DTC Client socket (1) | Creating socket. 2024-07-24 11:02:13.568 | DTC Client socket (1) | New receive buffer size: 0 2024-07-24 11:02:13.568 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-07-24 11:02:13.569 | DTC - Sub Instance | Network connection to server complete. 2024-07-24 11:02:13.569 | DTC - Sub Instance | Starting socket receive thread. 2024-07-24 11:02:13.569 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-07-24 11:02:13.571 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-07-24 11:02:13.571 | DTC - Sub Instance | Sending logon request message. 2024-07-24 11:02:13.571 | DTC - Sub Instance | Received logon response. 2024-07-24 11:02:13.571 | DTC - Sub Instance | Server Name: SC DTC Server. Build=49270. 2024-07-24 11:02:13.571 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-07-24 11:02:13.571 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg. 2024-07-24 11:02:13.571 | DTC - Sub Instance | Trading is supported. 2024-07-24 11:02:13.571 | DTC - Sub Instance | Order cancel and replace is supported. 2024-07-24 11:02:13.571 | DTC - Sub Instance | OCO Orders supported. 2024-07-24 11:02:13.571 | DTC - Sub Instance | Bracket Orders supported. 2024-07-24 11:02:13.571 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-07-24 11:02:13.571 | DTC - Sub Instance | Connected to server complete. 2024-07-24 11:02:13.572 | No download requests in the queue to start downloads for. 2024-07-24 11:02:13.572 | No download requests in the queue to start downloads for. 2024-07-24 11:02:13.572 | No download requests in the queue to start downloads for. 2024-07-24 11:02:13.572 | No download requests in the queue to start downloads for. 2024-07-24 11:02:13.572 | Subscribing to symbol for symbol alert. F.US.FGBXZ22 2024-07-24 11:02:13.572 | Using symbol data fast lookup vector 2024-07-24 11:02:13.573 | DTC - Sub Instance | Starting real-time market data updates for: F.US.FGBXZ22. ID: 1 Service code: cqg 2024-07-24 11:02:13.573 | DTC - Sub Instance | Requesting security definition data for: F.US.FGBXZ22. ID: 1 2024-07-24 11:02:13.573 | DTC - Sub Instance | Received security definition for symbol F.US.FGBXZ22 2024-07-24 11:02:15.453 | DTC - Sub Instance | Starting real-time market data updates for: F.US.VXQ24. ID: 2 Service code: cqg 2024-07-24 11:02:15.453 | DTC - Sub Instance | Requesting security definition data for: F.US.VXQ24. ID: 2 2024-07-24 11:02:15.454 | Added historical Intraday data request for F.US.VXQ24 to the queue. 2024-07-24 11:02:15.454 | Intraday data recording state for symbol F.US.VXQ24 is set to download 'Pending'. 2024-07-24 11:02:15.454 | Triggering next historical data download in queue. 2024-07-24 11:02:15.458 | Delaying start of download for F.US.VXQ24. 2024-07-24 11:02:15.459 | DTC - Sub Instance | Received security definition for symbol F.US.VXQ24 2024-07-24 11:02:20.518 | HD Request # 15 | Downloading Intraday chart data for F.US.VXQ24 to the file F.US.VXQ24.scid. Service: cfe_exchange.data 2024-07-24 11:02:20.518 | HD Request # 15 | Download start date-time: 2024-07-23 20:00:43.000000. File last date-time: 2024-07-23 20:00:43.333002 2024-07-24 11:02:20.518 | HD Request # 15 | Using server: ds33.sierracharts.com port 10150 2024-07-24 11:02:20.597 | Socket (2) | Creating socket. 2024-07-24 11:02:20.597 | Socket (2) | New receive buffer size: 0 2024-07-24 11:02:20.597 | Socket (2) | Connecting to IP: 69.39.70.245. 2024-07-24 11:02:20.723 | HD Request # 15 | Setting DTC encoding to Binary VLS 2024-07-24 11:02:20.723 | HD Request # 15 | Sending historical data logon request message. 2024-07-24 11:02:21.039 | HD Request # 15 | Requesting Intraday data. Start date-time: 2024-07-23 20:00:43. Record interval: 0. Symbol: VXQ24_FUT_CFE 2024-07-24 11:02:21.100 | HD Request # 15 | Decompressing data. 2024-07-24 11:02:21.162 | HD Request # 15 | Receiving Intraday data for F.US.VXQ24 starting at 2024-07-23 20:00:43.333000 2024-07-24 11:02:21.336 | Socket (2) | CloseSocket call. 2024-07-24 11:02:21.336 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-24 11:02:21.337 | Historical data download thread signaled to stop. 2024-07-24 11:02:21.337 | HD Request # 15 | Timestamp of first Intraday data file record written: 2024-07-23 20:12:45.091000. 2024-07-24 11:02:21.338 | HD Request # 15 | Received 21091 Intraday data records from 2024-07-23 20:00:43.333000 to 2024-07-24 11:02:12.012000 (15.0 hours. Delay: 9.3 seconds) and wrote 21088 records for F.US.VXQ24 2024-07-24 11:02:21.338 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2024-07-24 16:02:12.012000 2024-07-24 11:02:21.338 | HD Request # 15 | Completion time: 1s. 2024-07-24 11:02:21.338 | HD Request # 15 | Intraday data download complete for F.US.VXQ24. Unique request ID: 15 2024-07-24 11:02:21.338 | Removing historical data download ID 15. 2024-07-24 11:02:21.338 | Real-time Intraday chart data file updates started for F.US.VXQ24 2024-07-24 11:02:21.338 | Intraday chart data file opened for F.US.VXQ24 2024-07-24 11:02:21.338 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2024-07-24 11:02:21.338 | 2024-07-24 11:02:21.338 | No download requests in the queue to start downloads for. 2024-07-24 11:02:21.398 | Socket (2) | Socket gracefully closed by remote side. 2024-07-24 11:02:21.398 | Socket (2) | Closed. |
[2024-07-28 16:57:10] |
Sierra_Chart Engineering - Posts: 16656 |
We apologize for the delay. This is a sub instance and it is hard for us to understand the issue from this instance. We need you to provide us the Message Log from the main instance of Sierra Chart. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-31 16:59:19] |
User359698 - Posts: 17 |
I have again stopped receiving real-time CFE data. I've followed the process from above with symbol F.US.VXQ24. Thank you. (Log removed ) Date Time Of Last Edit: 2024-07-31 17:35:11
[2024-07-31 17:34:53] |
This log is too big and we cannot go through it. Follow these instructions for the main instance of Sierra Chart: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Exit all sub instances of Sierra Chart. Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-31 17:41:46] |
Sorry. Please see below. 2024-07-31 12:40:08.602 | Software version: 2604 64-bit 2024-07-31 12:40:08.602 | Primary Thread ID: 18048 2024-07-31 12:40:08.602 | Usage end date: 2024-08-10 2024-07-31 12:40:08.602 | Enabled for: Advanced Features 2. 2024-07-31 12:40:08.602 | Enabled for: Sierra Chart Historical Data Service. 2024-07-31 12:40:08.602 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-07-31 12:40:08.602 | Enabled for: Delayed Denali Exchange Data Feed. 2024-07-31 12:40:08.602 | Enabled for exchange2: CME (Trading Account Required) 2024-07-31 12:40:08.602 | Enabled for exchange2: CBOT (Trading Account Required) 2024-07-31 12:40:08.602 | Enabled for exchange2: COMEX (Trading Account Required) 2024-07-31 12:40:08.602 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-07-31 12:40:08.602 | Enabled for exchange2: CFE 2024-07-31 12:40:08.602 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-07-31 12:40:08.602 | Current selected Data/Trading service: CQG WebAPI 2024-07-31 12:40:08.602 | Custom symbol settings values: enabled 2024-07-31 12:40:08.602 | Chart Update Interval: 1000 2024-07-31 12:40:08.602 | Intraday Data Storage Time Unit: 0 2024-07-31 12:40:08.602 | Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-07-31 12:40:08.602 | 2024-07-31 17:40:08 Local computer time in UTC 2024-07-31 12:40:08.602 | 2024-07-31 12:40:08 Local computer time in SC Time Zone 2024-07-31 12:40:08.602 | 2024-07-28 12:35:57 Server time in UTC 2024-07-31 12:40:08.602 | Local computer UTC time and Server UTC time difference: 1 seconds. 2024-07-31 12:40:08.602 | Program path: S:\Sierra Chart (CQG)\ 2024-07-31 12:40:08.602 | Data Files path: S:\Sierra Chart (CQG)\Data\ 2024-07-31 12:40:08.602 | OS Version Number: 10.0 2024-07-31 12:40:08.602 | Locale Setting: C 2024-07-31 12:40:08.604 | DLLs: UserContributedStudies_64.dll 2024-07-31 12:40:08.604 | Allowed protected custom studies: 2024-07-31 12:40:08.604 | Crash reporter started: true 2024-07-31 12:40:08.604 | 2024-07-31 12:40:28.121 | File >> Disconnect selected. 2024-07-31 12:40:28.121 | CQG WebAPI | Sending Web API Logoff message. 2024-07-31 12:40:28.121 | CQG WebSocket socket (1) | CloseSocket call. 2024-07-31 12:40:28.121 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2024-07-31 12:40:28.121 | CQG WebSocket socket (1) | Max send buffer size during socket life: 1826 2024-07-31 12:40:28.121 | CQG WebSocket | WebSocket closed. 2024-07-31 12:40:28.121 | CQG WebAPI | WebSocket closed. 2024-07-31 12:40:28.121 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-07-31 12:40:28.122 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2024-07-31 12:40:28.123 | DTC Client socket (9) | CloseSocket call. 2024-07-31 12:40:28.123 | DTC Client socket (9) | Max send buffers used during socket life: 3 2024-07-31 12:40:28.123 | DTC Client socket (9) | Max send buffer size during socket life: 2668 2024-07-31 12:40:28.123 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2024-07-31 12:40:28.126 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2024-07-31 12:40:28.128 | Denali Data Feed | Waiting for socket receive thread to end 2024-07-31 12:40:28.128 | DTC Client socket (2) | CloseSocket call. 2024-07-31 12:40:28.128 | DTC Client socket (2) | Max send buffers used during socket life: 3 2024-07-31 12:40:28.128 | DTC Client socket (2) | Max send buffer size during socket life: 5842 2024-07-31 12:40:28.128 | Denali Data Feed | Disconnected from the server. 2024-07-31 12:40:28.128 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-07-31 12:40:28.128 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2024-07-31 12:40:28.129 | DTC Client socket (8) | CloseSocket call. 2024-07-31 12:40:28.129 | DTC Client socket (8) | Shutdown started. Waiting for graceful close. 2024-07-31 12:40:28.129 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2024-07-31 12:40:28.130 | Denali Data Feed | Waiting for socket receive thread to end 2024-07-31 12:40:28.131 | DTC Client socket (4) | CloseSocket call. 2024-07-31 12:40:28.131 | Denali Data Feed | Disconnected from the server. 2024-07-31 12:40:28.131 | SC Data with Depth | Waiting for socket receive thread to end 2024-07-31 12:40:28.131 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2024-07-31 12:40:28.132 | DTC Client socket (3) | CloseSocket call. 2024-07-31 12:40:28.132 | DTC Client socket (3) | Max send buffers used during socket life: 3 2024-07-31 12:40:28.132 | DTC Client socket (3) | Max send buffer size during socket life: 1774 2024-07-31 12:40:28.132 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2024-07-31 12:40:28.132 | SC Data with Depth | Disconnected from the server. 2024-07-31 12:40:28.132 | CQG WebAPI | Disconnected. 2024-07-31 12:40:28.169 | DTC Client socket (8) | Socket gracefully closed by remote side. 2024-07-31 12:40:28.170 | DTC Client socket (8) | Closed. 2024-07-31 12:40:28.170 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-07-31 12:40:28.170 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-07-31 12:40:28.176 | DTC Client socket (4) | Socket gracefully closed by remote side. 2024-07-31 12:40:28.176 | DTC Client socket (4) | Closed. 2024-07-31 12:40:28.187 | DTC Client socket (9) | Socket gracefully closed by remote side. 2024-07-31 12:40:28.187 | DTC Client socket (9) | Closed. 2024-07-31 12:40:28.221 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-07-31 12:40:28.221 | CQG WebSocket socket (1) | Closed. 2024-07-31 12:40:28.241 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-07-31 12:40:28.241 | DTC Client socket (2) | Closed. 2024-07-31 12:40:28.244 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-07-31 12:40:28.244 | DTC Client socket (3) | Closed. 2024-07-31 12:40:31.913 | F.US.VXQ24 1 Min #1 | Reloading chart. 2024-07-31 12:40:32.056 | F.US.VXQ24 1 Min #1 | Chart data loading complete. 2024-07-31 12:40:35.517 | 2024-07-31 12:40:35.517 | CQG WebAPI | Connecting to server api.cqg.com 2024-07-31 12:40:35.517 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-07-31 12:40:35.657 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-07-31 12:40:35.657 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-07-31 12:40:35.657 | CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. 2024-07-31 12:40:35.705 | CQG WebSocket | Opening WebSocket. 2024-07-31 12:40:35.705 | CQG WebSocket | Sending WebSocket handshake. 2024-07-31 12:40:35.846 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-07-31 12:40:35.846 | CQG WebSocket | Server header | Connection: Upgrade 2024-07-31 12:40:35.846 | CQG WebSocket | Server header | Sec-WebSocket-Accept: cXNPX+s95eSKHCGPuEMsDns4R7g= 2024-07-31 12:40:35.846 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-07-31 12:40:35.846 | CQG WebSocket | Server header | Upgrade: websocket 2024-07-31 12:40:35.846 | CQG WebSocket | Server header | 2024-07-31 12:40:35.846 | CQG WebSocket | Web socket state is now open. 2024-07-31 12:40:35.846 | CQG WebAPI | WebSocket connected. 2024-07-31 12:40:35.847 | CQG WebAPI | Sending market data logon message. 2024-07-31 12:40:35.937 | CQG WebAPI | Base Time: 2024-07-28T00:26:10. 2024-07-28 00:26:10 2024-07-31 12:40:35.937 | CQG WebAPI | Logon successful. Session Token = SgYTeAdfu6bUF4X0RK5Agz5k9bcEQ/3GqBufAeuoBiY9n3ZfdyKSUewX275Iuca7kahjG/q7/WU 2024-07-31 12:40:35.937 | CQG WebAPI | Connected to server complete. 2024-07-31 12:40:35.939 | No download requests in the queue to start downloads for. 2024-07-31 12:40:35.939 | No download requests in the queue to start downloads for. 2024-07-31 12:40:35.939 | No download requests in the queue to start downloads for. 2024-07-31 12:40:35.939 | No download requests in the queue to start downloads for. 2024-07-31 12:40:35.939 | Updated verified funded futures trading account ending date to: 2024-08-30 17:40:35 2024-07-31 12:40:35.940 | CQG WebAPI | Sending Trade Accounts request message. 2024-07-31 12:40:36.040 | CQG WebAPI | Brokerage name: AMP. Account Name: 112608 2024-07-31 12:40:36.040 | Updated verified funded futures trading account ending date to: 2024-08-30 17:40:36 2024-07-31 12:40:36.040 | CQG WebAPI | Sending collateral subscribe request. 2024-07-31 12:40:36.181 | CQG WebAPI | Sending positions subscribe request. RequestID: 2545 2024-07-31 12:40:36.181 | CQG WebAPI | Sending orders subscribe request. RequestID: 2546 2024-07-31 12:40:36.181 | Mapping F.US.EU6Z22 to 6EZ22. Service code: cme 2024-07-31 12:40:36.181 | Using symbol data fast lookup vector 2024-07-31 12:40:36.181 | Denali Data Feed | Starting real-time market data updates for: F.US.EU6Z22 (6EZ22). ID: 1 Service code: cme 2024-07-31 12:40:36.181 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 2024-07-31 12:40:36.181 | CQG WebAPI | Sending symbol resolution request for F.US.EU6Z22. ID: 2547 2024-07-31 12:40:36.181 | Denali Data Feed | Requesting security definition data for: F.US.EU6Z22 (6EZ22). ID: 1 2024-07-31 12:40:36.181 | Mapping F.US.EU6H23 to 6EH23. Service code: cme 2024-07-31 12:40:36.181 | Denali Data Feed | Starting real-time market data updates for: F.US.EU6H23 (6EH23). ID: 2 Service code: cme 2024-07-31 12:40:36.181 | CQG WebAPI | Sending symbol resolution request for F.US.EU6H23. ID: 2548 2024-07-31 12:40:36.181 | Denali Data Feed | Requesting security definition data for: F.US.EU6H23 (6EH23). ID: 2 2024-07-31 12:40:36.181 | Mapping F.US.EU6M23 to 6EM23. Service code: cme 2024-07-31 12:40:36.182 | DTC Client socket (2) | Creating socket. 2024-07-31 12:40:36.182 | DTC Client socket (2) | New receive buffer size: 0 2024-07-31 12:40:36.182 | DTC Client socket (2) | Connecting to IP: 67.214.125.6. 2024-07-31 12:40:36.182 | Denali Data Feed | Starting real-time market data updates for: F.US.EU6M23 (6EM23). ID: 3 Service code: cme 2024-07-31 12:40:36.182 | CQG WebAPI | Sending symbol resolution request for F.US.EU6M23. ID: 2549 2024-07-31 12:40:36.182 | Denali Data Feed | Requesting security definition data for: F.US.EU6M23 (6EM23). ID: 3 2024-07-31 12:40:36.182 | Mapping F.US.M6EM24 to M6EM24. Service code: cme 2024-07-31 12:40:36.182 | Denali Data Feed | Starting real-time market data updates for: F.US.M6EM24 (M6EM24). ID: 4 Service code: cme 2024-07-31 12:40:36.182 | CQG WebAPI | Sending symbol resolution request for F.US.M6EM24. ID: 2550 2024-07-31 12:40:36.182 | Denali Data Feed | Requesting security definition data for: F.US.M6EM24 (M6EM24). ID: 4 2024-07-31 12:40:36.182 | Mapping F.US.EU6U24 to 6EU24. Service code: cme 2024-07-31 12:40:36.182 | Denali Data Feed | Starting real-time market data updates for: F.US.EU6U24 (6EU24). ID: 5 Service code: cme 2024-07-31 12:40:36.182 | CQG WebAPI | Sending symbol resolution request for F.US.EU6U24. ID: 2551 2024-07-31 12:40:36.182 | Denali Data Feed | Requesting security definition data for: F.US.EU6U24 (6EU24). ID: 5 2024-07-31 12:40:36.182 | Mapping F.US.CA6U24 to 6CU24. Service code: cme 2024-07-31 12:40:36.182 | Denali Data Feed | Starting real-time market data updates for: F.US.CA6U24 (6CU24). ID: 6 Service code: cme 2024-07-31 12:40:36.182 | CQG WebAPI | Sending symbol resolution request for F.US.CA6U24. ID: 2552 2024-07-31 12:40:36.182 | Denali Data Feed | Requesting security definition data for: F.US.CA6U24 (6CU24). ID: 6 2024-07-31 12:40:36.182 | Mapping F.US.MESU24 to MESU24. Service code: cme 2024-07-31 12:40:36.182 | Denali Data Feed | Starting real-time market data updates for: F.US.MESU24 (MESU24). ID: 7 Service code: cme 2024-07-31 12:40:36.182 | CQG WebAPI | Sending symbol resolution request for F.US.MESU24. ID: 2553 2024-07-31 12:40:36.182 | Denali Data Feed | Requesting security definition data for: F.US.MESU24 (MESU24). ID: 7 2024-07-31 12:40:36.182 | Mapping F.US.MNQU24 to MNQU24. Service code: cme 2024-07-31 12:40:36.182 | Denali Data Feed | Starting real-time market data updates for: F.US.MNQU24 (MNQU24). ID: 8 Service code: cme 2024-07-31 12:40:36.182 | CQG WebAPI | Sending symbol resolution request for F.US.MNQU24. ID: 2554 2024-07-31 12:40:36.182 | Denali Data Feed | Requesting security definition data for: F.US.MNQU24 (MNQU24). ID: 8 2024-07-31 12:40:36.182 | Requesting market depth updates for: F.US.M6EM24 if supported. NumLevels=100 2024-07-31 12:40:36.182 | Requesting market depth updates for: F.US.EU6U24 if supported. NumLevels=100 2024-07-31 12:40:36.182 | Requesting market depth updates for: F.US.CA6U24 if supported. NumLevels=100 2024-07-31 12:40:36.182 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXZ22. ID: 9 2024-07-31 12:40:36.182 | Symbol Error | F.US.DSXZ22 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXZ22. ID: 9 2024-07-31 12:40:36.183 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH23. ID: 10 2024-07-31 12:40:36.183 | Symbol Error | F.US.DSXH23 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH23. ID: 10 2024-07-31 12:40:36.183 | Mapping F.US.TUAU24 to ZTU24. Service code: cbot 2024-07-31 12:40:36.183 | Denali Data Feed | Starting real-time market data updates for: F.US.TUAU24 (ZTU24). ID: 11 Service code: cbot 2024-07-31 12:40:36.183 | CQG WebAPI | Sending symbol resolution request for F.US.TUAU24. ID: 2555 2024-07-31 12:40:36.183 | Denali Data Feed | Requesting security definition data for: F.US.TUAU24 (ZTU24). ID: 11 2024-07-31 12:40:36.183 | Requesting market depth updates for: F.US.TUAU24 if supported. NumLevels=100 2024-07-31 12:40:36.183 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DLZ22. ID: 12 2024-07-31 12:40:36.183 | Symbol Error | F.US.DLZ22 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DLZ22. ID: 12 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DECL-NQ. ID: 13 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DECL-NQ. ID: 13 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: TVOL-NQ. ID: 14 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: TVOL-NQ. ID: 14 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DVOL-YM. ID: 15 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DVOL-YM. ID: 15 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DVOL-TF. ID: 16 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DVOL-TF. ID: 16 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: TVOL-TF. ID: 17 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: TVOL-TF. ID: 17 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DECL-YM. ID: 18 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DECL-YM. ID: 18 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DECL-NYSE. ID: 19 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DECL-NYSE. ID: 19 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: ADV-NQ. ID: 20 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: ADV-NQ. ID: 20 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: UVOL-NQ. ID: 21 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: UVOL-NQ. ID: 21 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DVOL-NYSE. ID: 22 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DVOL-NYSE. ID: 22 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: TVOL-YM. ID: 23 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: TVOL-YM. ID: 23 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: UVOL-TF. ID: 24 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: UVOL-TF. ID: 24 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: ADV-YM. ID: 25 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: ADV-YM. ID: 25 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: TVOL-NYSE. ID: 26 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: TVOL-NYSE. ID: 26 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: UVOL-YM. ID: 27 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: UVOL-YM. ID: 27 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: ADV-TF. ID: 28 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: ADV-TF. ID: 28 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DVOL-NQ. ID: 29 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DVOL-NQ. ID: 29 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: DECL-TF. ID: 30 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: DECL-TF. ID: 30 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: UVOL-NYSE. ID: 31 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: UVOL-NYSE. ID: 31 2024-07-31 12:40:36.183 | DTC Client socket (3) | Creating socket. 2024-07-31 12:40:36.183 | SC Data with Depth | Starting real-time market data updates for: ADV-NYSE. ID: 32 Service code: statscalc 2024-07-31 12:40:36.183 | SC Data with Depth | Requesting security definition data for: ADV-NYSE. ID: 32 2024-07-31 12:40:36.183 | DTC Client socket (3) | New receive buffer size: 0 2024-07-31 12:40:36.183 | DTC Client socket (3) | Connecting to IP: 67.214.125.7. 2024-07-31 12:40:36.183 | Mapping F.US.CLEJ23 to CLJ23. Service code: nymex 2024-07-31 12:40:36.183 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEJ23 (CLJ23). ID: 33 Service code: nymex 2024-07-31 12:40:36.183 | CQG WebAPI | Sending symbol resolution request for F.US.CLEJ23. ID: 2556 2024-07-31 12:40:36.184 | Denali Data Feed | Requesting security definition data for: F.US.CLEJ23 (CLJ23). ID: 33 2024-07-31 12:40:36.184 | Mapping F.US.CLEU24 to CLU24. Service code: nymex 2024-07-31 12:40:36.184 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEU24 (CLU24). ID: 34 Service code: nymex 2024-07-31 12:40:36.184 | CQG WebAPI | Sending symbol resolution request for F.US.CLEU24. ID: 2557 2024-07-31 12:40:36.184 | Denali Data Feed | Requesting security definition data for: F.US.CLEU24 (CLU24). ID: 34 2024-07-31 12:40:36.184 | Mapping F.US.MCLEH24 to MCLH24. Service code: nymex 2024-07-31 12:40:36.184 | Denali Data Feed | Starting real-time market data updates for: F.US.MCLEH24 (MCLH24). ID: 35 Service code: nymex 2024-07-31 12:40:36.184 | CQG WebAPI | Sending symbol resolution request for F.US.MCLEH24. ID: 2558 2024-07-31 12:40:36.184 | Denali Data Feed | Requesting security definition data for: F.US.MCLEH24 (MCLH24). ID: 35 2024-07-31 12:40:36.184 | Requesting market depth updates for: F.US.CLEU24 if supported. NumLevels=100 2024-07-31 12:40:36.184 | Requesting market depth updates for: F.US.MCLEH24 if supported. NumLevels=100 2024-07-31 12:40:36.184 | Mapping F.US.M2KM24 to M2KM24. Service code: cme 2024-07-31 12:40:36.184 | Denali Data Feed | Starting real-time market data updates for: F.US.M2KM24 (M2KM24). ID: 36 Service code: cme 2024-07-31 12:40:36.184 | CQG WebAPI | Sending symbol resolution request for F.US.M2KM24. ID: 2559 2024-07-31 12:40:36.184 | Denali Data Feed | Requesting security definition data for: F.US.M2KM24 (M2KM24). ID: 36 2024-07-31 12:40:36.184 | Mapping F.US.RTYU24 to RTYU24. Service code: cme 2024-07-31 12:40:36.184 | Denali Data Feed | Starting real-time market data updates for: F.US.RTYU24 (RTYU24). ID: 37 Service code: cme 2024-07-31 12:40:36.184 | CQG WebAPI | Sending symbol resolution request for F.US.RTYU24. ID: 2560 2024-07-31 12:40:36.184 | Denali Data Feed | Requesting security definition data for: F.US.RTYU24 (RTYU24). ID: 37 2024-07-31 12:40:36.184 | Requesting market depth updates for: F.US.M2KM24 if supported. NumLevels=100 2024-07-31 12:40:36.184 | Requesting market depth updates for: F.US.RTYU24 if supported. NumLevels=100 2024-07-31 12:40:36.184 | Mapping F.US.BP6H22 to 6BH22. Service code: cme 2024-07-31 12:40:36.184 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6H22 (6BH22). ID: 38 Service code: cme 2024-07-31 12:40:36.184 | CQG WebAPI | Sending symbol resolution request for F.US.BP6H22. ID: 2561 2024-07-31 12:40:36.184 | Denali Data Feed | Requesting security definition data for: F.US.BP6H22 (6BH22). ID: 38 2024-07-31 12:40:36.184 | Mapping F.US.BP6Z22 to 6BZ22. Service code: cme 2024-07-31 12:40:36.185 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6Z22 (6BZ22). ID: 39 Service code: cme 2024-07-31 12:40:36.185 | CQG WebAPI | Sending symbol resolution request for F.US.BP6Z22. ID: 2562 2024-07-31 12:40:36.185 | Denali Data Feed | Requesting security definition data for: F.US.BP6Z22 (6BZ22). ID: 39 2024-07-31 12:40:36.185 | Mapping F.US.BP6M23 to 6BM23. Service code: cme 2024-07-31 12:40:36.185 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6M23 (6BM23). ID: 40 Service code: cme 2024-07-31 12:40:36.185 | CQG WebAPI | Sending symbol resolution request for F.US.BP6M23. ID: 2563 2024-07-31 12:40:36.185 | Denali Data Feed | Requesting security definition data for: F.US.BP6M23 (6BM23). ID: 40 2024-07-31 12:40:36.185 | Mapping F.US.M6BM24 to M6BM24. Service code: cme 2024-07-31 12:40:36.185 | Denali Data Feed | Starting real-time market data updates for: F.US.M6BM24 (M6BM24). ID: 41 Service code: cme 2024-07-31 12:40:36.185 | CQG WebAPI | Sending symbol resolution request for F.US.M6BM24. ID: 2564 2024-07-31 12:40:36.185 | Denali Data Feed | Requesting security definition data for: F.US.M6BM24 (M6BM24). ID: 41 2024-07-31 12:40:36.185 | Mapping F.US.BP6U24 to 6BU24. Service code: cme 2024-07-31 12:40:36.185 | Denali Data Feed | Starting real-time market data updates for: F.US.BP6U24 (6BU24). ID: 42 Service code: cme 2024-07-31 12:40:36.185 | CQG WebAPI | Sending symbol resolution request for F.US.BP6U24. ID: 2565 2024-07-31 12:40:36.185 | Denali Data Feed | Requesting security definition data for: F.US.BP6U24 (6BU24). ID: 42 2024-07-31 12:40:36.185 | Requesting market depth updates for: F.US.M6BM24 if supported. NumLevels=100 2024-07-31 12:40:36.185 | Requesting market depth updates for: F.US.BP6U24 if supported. NumLevels=100 2024-07-31 12:40:36.185 | Mapping F.US.EPH23 to ESH23. Service code: cme 2024-07-31 12:40:36.185 | Denali Data Feed | Starting real-time market data updates for: F.US.EPH23 (ESH23). ID: 43 Service code: cme 2024-07-31 12:40:36.185 | CQG WebAPI | Sending symbol resolution request for F.US.EPH23. ID: 2566 2024-07-31 12:40:36.185 | Denali Data Feed | Requesting security definition data for: F.US.EPH23 (ESH23). ID: 43 2024-07-31 12:40:36.185 | Mapping F.US.MNQH23 to MNQH23. Service code: cme 2024-07-31 12:40:36.185 | Denali Data Feed | Starting real-time market data updates for: F.US.MNQH23 (MNQH23). ID: 44 Service code: cme 2024-07-31 12:40:36.185 | CQG WebAPI | Sending symbol resolution request for F.US.MNQH23. ID: 2567 2024-07-31 12:40:36.185 | Denali Data Feed | Requesting security definition data for: F.US.MNQH23 (MNQH23). ID: 44 2024-07-31 12:40:36.185 | Mapping F.US.EPU24 to ESU24. Service code: cme 2024-07-31 12:40:36.185 | Denali Data Feed | Starting real-time market data updates for: F.US.EPU24 (ESU24). ID: 45 Service code: cme 2024-07-31 12:40:36.185 | CQG WebAPI | Sending symbol resolution request for F.US.EPU24. ID: 2568 2024-07-31 12:40:36.185 | Denali Data Feed | Requesting security definition data for: F.US.EPU24 (ESU24). ID: 45 2024-07-31 12:40:36.185 | Requesting market depth updates for: F.US.MESU24 if supported. NumLevels=100 2024-07-31 12:40:36.185 | Requesting market depth updates for: F.US.EPU24 if supported. NumLevels=100 2024-07-31 12:40:36.186 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DDZ22. ID: 46 2024-07-31 12:40:36.186 | Symbol Error | F.US.DDZ22 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DDZ22. ID: 46 2024-07-31 12:40:36.186 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DDH23. ID: 47 2024-07-31 12:40:36.186 | Symbol Error | F.US.DDH23 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DDH23. ID: 47 2024-07-31 12:40:36.186 | Mapping F.US.FVAU24 to ZFU24. Service code: cbot 2024-07-31 12:40:36.186 | Denali Data Feed | Starting real-time market data updates for: F.US.FVAU24 (ZFU24). ID: 48 Service code: cbot 2024-07-31 12:40:36.186 | CQG WebAPI | Sending symbol resolution request for F.US.FVAU24. ID: 2569 2024-07-31 12:40:36.186 | Denali Data Feed | Requesting security definition data for: F.US.FVAU24 (ZFU24). ID: 48 2024-07-31 12:40:36.186 | Requesting market depth updates for: F.US.FVAU24 if supported. NumLevels=100 2024-07-31 12:40:36.186 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FBTPZ22. ID: 49 2024-07-31 12:40:36.186 | Symbol Error | F.US.FBTPZ22 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FBTPZ22. ID: 49 2024-07-31 12:40:36.187 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FBTPH23. ID: 50 2024-07-31 12:40:36.187 | Symbol Error | F.US.FBTPH23 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FBTPH23. ID: 50 2024-07-31 12:40:36.187 | Mapping F.US.YMU24 to YMU24. Service code: cbot 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.YMU24 (YMU24). ID: 51 Service code: cbot 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.YMU24. ID: 2570 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.YMU24 (YMU24). ID: 51 2024-07-31 12:40:36.187 | Mapping F.US.MYMU24 to MYMU24. Service code: cbot 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.MYMU24 (MYMU24). ID: 52 Service code: cbot 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.MYMU24. ID: 2571 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.MYMU24 (MYMU24). ID: 52 2024-07-31 12:40:36.187 | Requesting market depth updates for: F.US.YMU24 if supported. NumLevels=100 2024-07-31 12:40:36.187 | Requesting market depth updates for: F.US.MYMU24 if supported. NumLevels=100 2024-07-31 12:40:36.187 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 53 Service code: fxstatscalc 2024-07-31 12:40:36.187 | SC Data with Depth | Requesting security definition data for: USDX. ID: 53 2024-07-31 12:40:36.187 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBU24. ID: 54 2024-07-31 12:40:36.187 | Symbol Error | F.US.DBU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBU24. ID: 54 2024-07-31 12:40:36.187 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FOATU24. ID: 55 2024-07-31 12:40:36.187 | Symbol Error | F.US.FOATU24 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FOATU24. ID: 55 2024-07-31 12:40:36.187 | Mapping F.US.USAU24 to ZBU24. Service code: cbot 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.USAU24 (ZBU24). ID: 56 Service code: cbot 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.USAU24. ID: 2572 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.USAU24 (ZBU24). ID: 56 2024-07-31 12:40:36.187 | Mapping F.US.NGEQ24 to NGQ24. Service code: nymex 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.NGEQ24 (NGQ24). ID: 57 Service code: nymex 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.NGEQ24. ID: 2573 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.NGEQ24 (NGQ24). ID: 57 2024-07-31 12:40:36.187 | Mapping F.US.GCEQ24 to GCQ24. Service code: comex 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.GCEQ24 (GCQ24). ID: 58 Service code: comex 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.GCEQ24. ID: 2574 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.GCEQ24 (GCQ24). ID: 58 2024-07-31 12:40:36.187 | Mapping F.US.DA6U24 to 6AU24. Service code: cme 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.DA6U24 (6AU24). ID: 59 Service code: cme 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.DA6U24. ID: 2575 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.DA6U24 (6AU24). ID: 59 2024-07-31 12:40:36.187 | Mapping F.US.JY6U24 to 6JU24. Service code: cme 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.JY6U24 (6JU24). ID: 60 Service code: cme 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.JY6U24. ID: 2576 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.JY6U24 (6JU24). ID: 60 2024-07-31 12:40:36.187 | Mapping F.US.CPEU24 to HGU24. Service code: comex 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.CPEU24 (HGU24). ID: 61 Service code: comex 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.CPEU24. ID: 2577 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.CPEU24 (HGU24). ID: 61 2024-07-31 12:40:36.187 | Mapping F.US.SIEU24 to SIU24. Service code: comex 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.SIEU24 (SIU24). ID: 62 Service code: comex 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.SIEU24. ID: 2578 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.SIEU24 (SIU24). ID: 62 2024-07-31 12:40:36.187 | Mapping F.US.TYAU24 to ZNU24. Service code: cbot 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.TYAU24 (ZNU24). ID: 63 Service code: cbot 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.TYAU24. ID: 2579 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.TYAU24 (ZNU24). ID: 63 2024-07-31 12:40:36.187 | Mapping F.US.ENQU24 to NQU24. Service code: cme 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.ENQU24 (NQU24). ID: 64 Service code: cme 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.ENQU24. ID: 2580 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.ENQU24 (NQU24). ID: 64 2024-07-31 12:40:36.187 | Mapping F.US.SF6U24 to 6SU24. Service code: cme 2024-07-31 12:40:36.187 | Denali Data Feed | Starting real-time market data updates for: F.US.SF6U24 (6SU24). ID: 65 Service code: cme 2024-07-31 12:40:36.187 | CQG WebAPI | Sending symbol resolution request for F.US.SF6U24. ID: 2581 2024-07-31 12:40:36.187 | Denali Data Feed | Requesting security definition data for: F.US.SF6U24 (6SU24). ID: 65 2024-07-31 12:40:36.188 | Mapping F.US.FVAZ22 to ZFZ22. Service code: cbot 2024-07-31 12:40:36.188 | Denali Data Feed | Starting real-time market data updates for: F.US.FVAZ22 (ZFZ22). ID: 66 Service code: cbot 2024-07-31 12:40:36.188 | CQG WebAPI | Sending symbol resolution request for F.US.FVAZ22. ID: 2582 2024-07-31 12:40:36.188 | Denali Data Feed | Requesting security definition data for: F.US.FVAZ22 (ZFZ22). ID: 66 2024-07-31 12:40:36.188 | Requesting market depth updates for: F.US.TYAU24 if supported. NumLevels=100 2024-07-31 12:40:36.188 | Mapping F.US.CPEH22 to HGH22. Service code: comex 2024-07-31 12:40:36.188 | Denali Data Feed | Starting real-time market data updates for: F.US.CPEH22 (HGH22). ID: 67 Service code: comex 2024-07-31 12:40:36.188 | CQG WebAPI | Sending symbol resolution request for F.US.CPEH22. ID: 2583 2024-07-31 12:40:36.188 | Denali Data Feed | Requesting security definition data for: F.US.CPEH22 (HGH22). ID: 67 2024-07-31 12:40:36.188 | Mapping F.US.CPEZ22 to HGZ22. Service code: comex 2024-07-31 12:40:36.188 | Denali Data Feed | Starting real-time market data updates for: F.US.CPEZ22 (HGZ22). ID: 68 Service code: comex 2024-07-31 12:40:36.188 | CQG WebAPI | Sending symbol resolution request for F.US.CPEZ22. ID: 2584 2024-07-31 12:40:36.188 | Denali Data Feed | Requesting security definition data for: F.US.CPEZ22 (HGZ22). ID: 68 2024-07-31 12:40:36.188 | Mapping F.US.CPEK23 to HGK23. Service code: comex 2024-07-31 12:40:36.189 | Denali Data Feed | Starting real-time market data updates for: F.US.CPEK23 (HGK23). ID: 69 Service code: comex 2024-07-31 12:40:36.189 | CQG WebAPI | Sending symbol resolution request for F.US.CPEK23. ID: 2585 2024-07-31 12:40:36.189 | Denali Data Feed | Requesting security definition data for: F.US.CPEK23 (HGK23). ID: 69 2024-07-31 12:40:36.189 | Mapping F.US.PLEV24 to PLV24. Service code: nymex 2024-07-31 12:40:36.189 | Denali Data Feed | Starting real-time market data updates for: F.US.PLEV24 (PLV24). ID: 70 Service code: nymex 2024-07-31 12:40:36.189 | CQG WebAPI | Sending symbol resolution request for F.US.PLEV24. ID: 2586 2024-07-31 12:40:36.189 | Denali Data Feed | Requesting security definition data for: F.US.PLEV24 (PLV24). ID: 70 2024-07-31 12:40:36.189 | Requesting market depth updates for: F.US.PLEV24 if supported. NumLevels=100 2024-07-31 12:40:36.189 | Mapping F.US.USAH23 to ZBH23. Service code: cbot 2024-07-31 12:40:36.189 | Denali Data Feed | Starting real-time market data updates for: F.US.USAH23 (ZBH23). ID: 71 Service code: cbot 2024-07-31 12:40:36.189 | CQG WebAPI | Sending symbol resolution request for F.US.USAH23. ID: 2587 2024-07-31 12:40:36.189 | Denali Data Feed | Requesting security definition data for: F.US.USAH23 (ZBH23). ID: 71 2024-07-31 12:40:36.189 | Mapping F.US.NGEQ23 to NGQ23. Service code: nymex 2024-07-31 12:40:36.189 | Denali Data Feed | Starting real-time market data updates for: F.US.NGEQ23 (NGQ23). ID: 72 Service code: nymex 2024-07-31 12:40:36.189 | CQG WebAPI | Sending symbol resolution request for F.US.NGEQ23. ID: 2588 2024-07-31 12:40:36.189 | Denali Data Feed | Requesting security definition data for: F.US.NGEQ23 (NGQ23). ID: 72 2024-07-31 12:40:36.189 | Mapping F.US.MHGU24 to MHGU24. Service code: comex 2024-07-31 12:40:36.189 | Denali Data Feed | Starting real-time market data updates for: F.US.MHGU24 (MHGU24). ID: 73 Service code: comex 2024-07-31 12:40:36.189 | CQG WebAPI | Sending symbol resolution request for F.US.MHGU24. ID: 2589 2024-07-31 12:40:36.189 | Denali Data Feed | Requesting security definition data for: F.US.MHGU24 (MHGU24). ID: 73 2024-07-31 12:40:36.189 | Requesting market depth updates for: F.US.CPEU24 if supported. NumLevels=100 2024-07-31 12:40:36.189 | Requesting market depth updates for: F.US.MHGU24 if supported. NumLevels=100 2024-07-31 12:40:36.189 | Mapping F.US.SIEH22 to SIH22. Service code: comex 2024-07-31 12:40:36.190 | Denali Data Feed | Starting real-time market data updates for: F.US.SIEH22 (SIH22). ID: 74 Service code: comex 2024-07-31 12:40:36.190 | CQG WebAPI | Sending symbol resolution request for F.US.SIEH22. ID: 2590 2024-07-31 12:40:36.190 | Denali Data Feed | Requesting security definition data for: F.US.SIEH22 (SIH22). ID: 74 2024-07-31 12:40:36.190 | Mapping F.US.USAZ23 to ZBZ23. Service code: cbot 2024-07-31 12:40:36.190 | Denali Data Feed | Starting real-time market data updates for: F.US.USAZ23 (ZBZ23). ID: 75 Service code: cbot 2024-07-31 12:40:36.190 | CQG WebAPI | Sending symbol resolution request for F.US.USAZ23. ID: 2591 2024-07-31 12:40:36.190 | Denali Data Feed | Requesting security definition data for: F.US.USAZ23 (ZBZ23). ID: 75 2024-07-31 12:40:36.190 | Requesting market depth updates for: F.US.USAU24 if supported. NumLevels=100 2024-07-31 12:40:36.190 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FGBXZ22. ID: 76 2024-07-31 12:40:36.190 | Symbol Error | F.US.FGBXZ22 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FGBXZ22. ID: 76 2024-07-31 12:40:36.190 | Mapping F.US.VXQ24 to VXQ24_FUT_CFE. Service code: cfe_exchange.data 2024-07-31 12:40:36.190 | Denali Data Feed | Starting real-time market data updates for: F.US.VXQ24 (VXQ24_FUT_CFE). ID: 77 Service code: cfe_exchange.data 2024-07-31 12:40:36.190 | Denali Data Feed | Connecting to the server ds33.sierracharts.com. Port 443 2024-07-31 12:40:36.190 | CQG WebAPI | Sending symbol resolution request for F.US.VXQ24. ID: 2592 2024-07-31 12:40:36.190 | Denali Data Feed | Requesting security definition data for: F.US.VXQ24 (VXQ24_FUT_CFE). ID: 77 2024-07-31 12:40:36.190 | Mapping F.US.MVIM24 to VXMM24_FUT_CFE. Service code: cfe_exchange.data 2024-07-31 12:40:36.190 | Denali Data Feed | Starting real-time market data updates for: F.US.MVIM24 (VXMM24_FUT_CFE). ID: 78 Service code: cfe_exchange.data 2024-07-31 12:40:36.190 | CQG WebAPI | Sending symbol resolution request for F.US.MVIM24. ID: 2593 2024-07-31 12:40:36.190 | Denali Data Feed | Requesting security definition data for: F.US.MVIM24 (VXMM24_FUT_CFE). ID: 78 2024-07-31 12:40:36.190 | Mapping F.US.MVIQ24 to VXMQ24_FUT_CFE. Service code: cfe_exchange.data 2024-07-31 12:40:36.190 | Denali Data Feed | Starting real-time market data updates for: F.US.MVIQ24 (VXMQ24_FUT_CFE). ID: 79 Service code: cfe_exchange.data 2024-07-31 12:40:36.190 | CQG WebAPI | Sending symbol resolution request for F.US.MVIQ24. ID: 2594 2024-07-31 12:40:36.190 | Denali Data Feed | Requesting security definition data for: F.US.MVIQ24 (VXMQ24_FUT_CFE). ID: 79 2024-07-31 12:40:36.190 | Requesting market depth updates for: F.US.VXQ24 if supported. NumLevels=100 2024-07-31 12:40:36.190 | Requesting market depth updates for: F.US.MVIQ24 if supported. NumLevels=100 2024-07-31 12:40:36.191 | DTC Client socket (4) | Creating socket. 2024-07-31 12:40:36.191 | DTC Client socket (4) | New receive buffer size: 0 2024-07-31 12:40:36.191 | DTC Client socket (4) | Connecting to IP: 69.39.70.245. 2024-07-31 12:40:36.191 | Mapping F.US.MNGQ24 to MNGQ24. Service code: nymex 2024-07-31 12:40:36.191 | Denali Data Feed | Starting real-time market data updates for: F.US.MNGQ24 (MNGQ24). ID: 80 Service code: nymex 2024-07-31 12:40:36.191 | CQG WebAPI | Sending symbol resolution request for F.US.MNGQ24. ID: 2595 2024-07-31 12:40:36.191 | Denali Data Feed | Requesting security definition data for: F.US.MNGQ24 (MNGQ24). ID: 80 2024-07-31 12:40:36.191 | Mapping F.US.NGEU24 to NGU24. Service code: nymex 2024-07-31 12:40:36.191 | Denali Data Feed | Starting real-time market data updates for: F.US.NGEU24 (NGU24). ID: 81 Service code: nymex 2024-07-31 12:40:36.191 | CQG WebAPI | Sending symbol resolution request for F.US.NGEU24. ID: 2596 2024-07-31 12:40:36.191 | Denali Data Feed | Requesting security definition data for: F.US.NGEU24 (NGU24). ID: 81 2024-07-31 12:40:36.191 | Mapping F.US.MNGU24 to MNGU24. Service code: nymex 2024-07-31 12:40:36.191 | Denali Data Feed | Starting real-time market data updates for: F.US.MNGU24 (MNGU24). ID: 82 Service code: nymex 2024-07-31 12:40:36.191 | CQG WebAPI | Sending symbol resolution request for F.US.MNGU24. ID: 2597 2024-07-31 12:40:36.191 | Denali Data Feed | Requesting security definition data for: F.US.MNGU24 (MNGU24). ID: 82 2024-07-31 12:40:36.191 | Requesting market depth updates for: F.US.NGEU24 if supported. NumLevels=100 2024-07-31 12:40:36.191 | Requesting market depth updates for: F.US.MNGU24 if supported. NumLevels=100 2024-07-31 12:40:36.191 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBZ22. ID: 83 2024-07-31 12:40:36.191 | Symbol Error | F.US.DBZ22 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBZ22. ID: 83 2024-07-31 12:40:36.191 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBH23. ID: 84 2024-07-31 12:40:36.191 | Symbol Error | F.US.DBH23 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBH23. ID: 84 2024-07-31 12:40:36.191 | Mapping F.US.EJYM24 to J7M24. Service code: cme 2024-07-31 12:40:36.192 | Denali Data Feed | Starting real-time market data updates for: F.US.EJYM24 (J7M24). ID: 85 Service code: cme 2024-07-31 12:40:36.192 | CQG WebAPI | Sending symbol resolution request for F.US.EJYM24. ID: 2598 2024-07-31 12:40:36.192 | Denali Data Feed | Requesting security definition data for: F.US.EJYM24 (J7M24). ID: 85 2024-07-31 12:40:36.192 | Requesting market depth updates for: F.US.EJYM24 if supported. NumLevels=100 2024-07-31 12:40:36.192 | Requesting market depth updates for: F.US.JY6U24 if supported. NumLevels=100 2024-07-31 12:40:36.192 | Mapping F.US.GCEQ22 to GCQ22. Service code: comex 2024-07-31 12:40:36.192 | Denali Data Feed | Starting real-time market data updates for: F.US.GCEQ22 (GCQ22). ID: 86 Service code: comex 2024-07-31 12:40:36.192 | CQG WebAPI | Sending symbol resolution request for F.US.GCEQ22. ID: 2599 2024-07-31 12:40:36.192 | Denali Data Feed | Requesting security definition data for: F.US.GCEQ22 (GCQ22). ID: 86 2024-07-31 12:40:36.192 | Mapping F.US.GCEG23 to GCG23. Service code: comex 2024-07-31 12:40:36.192 | Denali Data Feed | Starting real-time market data updates for: F.US.GCEG23 (GCG23). ID: 87 Service code: comex 2024-07-31 12:40:36.192 | CQG WebAPI | Sending symbol resolution request for F.US.GCEG23. ID: 2600 2024-07-31 12:40:36.192 | Denali Data Feed | Requesting security definition data for: F.US.GCEG23 (GCG23). ID: 87 2024-07-31 12:40:36.192 | Mapping F.US.GCEQ23 to GCQ23. Service code: comex 2024-07-31 12:40:36.192 | Denali Data Feed | Starting real-time market data updates for: F.US.GCEQ23 (GCQ23). ID: 88 Service code: comex 2024-07-31 12:40:36.192 | CQG WebAPI | Sending symbol resolution request for F.US.GCEQ23. ID: 2601 2024-07-31 12:40:36.192 | Denali Data Feed | Requesting security definition data for: F.US.GCEQ23 (GCQ23). ID: 88 2024-07-31 12:40:36.192 | Mapping F.US.GCEZ24 to GCZ24. Service code: comex 2024-07-31 12:40:36.192 | Denali Data Feed | Starting real-time market data updates for: F.US.GCEZ24 (GCZ24). ID: 89 Service code: comex 2024-07-31 12:40:36.192 | CQG WebAPI | Sending symbol resolution request for F.US.GCEZ24. ID: 2602 2024-07-31 12:40:36.192 | Denali Data Feed | Requesting security definition data for: F.US.GCEZ24 (GCZ24). ID: 89 2024-07-31 12:40:36.192 | Mapping F.US.MGCQ24 to MGCQ24. Service code: comex 2024-07-31 12:40:36.192 | Denali Data Feed | Starting real-time market data updates for: F.US.MGCQ24 (MGCQ24). ID: 90 Service code: comex 2024-07-31 12:40:36.193 | CQG WebAPI | Sending symbol resolution request for F.US.MGCQ24. ID: 2603 2024-07-31 12:40:36.193 | Denali Data Feed | Requesting security definition data for: F.US.MGCQ24 (MGCQ24). ID: 90 2024-07-31 12:40:36.193 | Mapping F.US.MGCZ24 to MGCZ24. Service code: comex 2024-07-31 12:40:36.193 | Denali Data Feed | Starting real-time market data updates for: F.US.MGCZ24 (MGCZ24). ID: 91 Service code: comex 2024-07-31 12:40:36.193 | CQG WebAPI | Sending symbol resolution request for F.US.MGCZ24. ID: 2604 2024-07-31 12:40:36.193 | Denali Data Feed | Requesting security definition data for: F.US.MGCZ24 (MGCZ24). ID: 91 2024-07-31 12:40:36.193 | Requesting market depth updates for: F.US.GCEZ24 if supported. NumLevels=100 2024-07-31 12:40:36.193 | Requesting market depth updates for: F.US.MGCZ24 if supported. NumLevels=100 2024-07-31 12:40:36.193 | Mapping F.US.CLEQ22 to CLQ22. Service code: nymex 2024-07-31 12:40:36.193 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEQ22 (CLQ22). ID: 92 Service code: nymex 2024-07-31 12:40:36.193 | CQG WebAPI | Sending symbol resolution request for F.US.CLEQ22. ID: 2605 2024-07-31 12:40:36.193 | Denali Data Feed | Requesting security definition data for: F.US.CLEQ22 (CLQ22). ID: 92 2024-07-31 12:40:36.193 | Mapping F.US.CLEX22 to CLX22. Service code: nymex 2024-07-31 12:40:36.193 | Denali Data Feed | Starting real-time market data updates for: F.US.CLEX22 (CLX22). ID: 93 Service code: nymex 2024-07-31 12:40:36.193 | CQG WebAPI | Sending symbol resolution request for F.US.CLEX22. ID: 2606 2024-07-31 12:40:36.193 | Denali Data Feed | Requesting security definition data for: F.US.CLEX22 (CLX22). ID: 93 2024-07-31 12:40:36.193 | Mapping F.US.SILN24 to SILN24. Service code: comex 2024-07-31 12:40:36.193 | Denali Data Feed | Starting real-time market data updates for: F.US.SILN24 (SILN24). ID: 94 Service code: comex 2024-07-31 12:40:36.193 | CQG WebAPI | Sending symbol resolution request for F.US.SILN24. ID: 2607 2024-07-31 12:40:36.193 | Denali Data Feed | Requesting security definition data for: F.US.SILN24 (SILN24). ID: 94 2024-07-31 12:40:36.193 | Requesting market depth updates for: F.US.SIEU24 if supported. NumLevels=100 2024-07-31 12:40:36.193 | Requesting market depth updates for: F.US.SILN24 if supported. NumLevels=100 2024-07-31 12:40:36.193 | Mapping F.US.JY6H22 to 6JH22. Service code: cme 2024-07-31 12:40:36.194 | Denali Data Feed | Starting real-time market data updates for: F.US.JY6H22 (6JH22). ID: 95 Service code: cme 2024-07-31 12:40:36.194 | CQG WebAPI | Sending symbol resolution request for F.US.JY6H22. ID: 2608 2024-07-31 12:40:36.194 | Denali Data Feed | Requesting security definition data for: F.US.JY6H22 (6JH22). ID: 95 2024-07-31 12:40:36.194 | Mapping F.US.JY6Z22 to 6JZ22. Service code: cme 2024-07-31 12:40:36.194 | Denali Data Feed | Starting real-time market data updates for: F.US.JY6Z22 (6JZ22). ID: 96 Service code: cme 2024-07-31 12:40:36.194 | CQG WebAPI | Sending symbol resolution request for F.US.JY6Z22. ID: 2609 2024-07-31 12:40:36.194 | Denali Data Feed | Requesting security definition data for: F.US.JY6Z22 (6JZ22). ID: 96 2024-07-31 12:40:36.194 | Mapping F.US.JY6H23 to 6JH23. Service code: cme 2024-07-31 12:40:36.194 | Denali Data Feed | Starting real-time market data updates for: F.US.JY6H23 (6JH23). ID: 97 Service code: cme 2024-07-31 12:40:36.194 | CQG WebAPI | Sending symbol resolution request for F.US.JY6H23. ID: 2610 2024-07-31 12:40:36.194 | Denali Data Feed | Requesting security definition data for: F.US.JY6H23 (6JH23). ID: 97 2024-07-31 12:40:36.194 | Mapping F.US.SF6M23 to 6SM23. Service code: cme 2024-07-31 12:40:36.194 | Denali Data Feed | Starting real-time market data updates for: F.US.SF6M23 (6SM23). ID: 98 Service code: cme 2024-07-31 12:40:36.194 | CQG WebAPI | Sending symbol resolution request for F.US.SF6M23. ID: 2611 2024-07-31 12:40:36.194 | Denali Data Feed | Requesting security definition data for: F.US.SF6M23 (6SM23). ID: 98 2024-07-31 12:40:36.194 | Mapping F.US.MSFM24 to MSFM24. Service code: cme 2024-07-31 12:40:36.194 | Denali Data Feed | Starting real-time market data updates for: F.US.MSFM24 (MSFM24). ID: 99 Service code: cme 2024-07-31 12:40:36.194 | CQG WebAPI | Sending symbol resolution request for F.US.MSFM24. ID: 2612 2024-07-31 12:40:36.194 | Denali Data Feed | Requesting security definition data for: F.US.MSFM24 (MSFM24). ID: 99 2024-07-31 12:40:36.194 | Mapping F.US.M6AU24 to M6AU24. Service code: cme 2024-07-31 12:40:36.194 | Denali Data Feed | Starting real-time market data updates for: F.US.M6AU24 (M6AU24). ID: 100 Service code: cme 2024-07-31 12:40:36.194 | CQG WebAPI | Sending symbol resolution request for F.US.M6AU24. ID: 2613 2024-07-31 12:40:36.194 | Denali Data Feed | Requesting security definition data for: F.US.M6AU24 (M6AU24). ID: 100 2024-07-31 12:40:36.194 | Requesting market depth updates for: F.US.SF6U24 if supported. NumLevels=100 2024-07-31 12:40:36.194 | Requesting market depth updates for: F.US.MSFM24 if supported. NumLevels=100 2024-07-31 12:40:36.194 | Requesting market depth updates for: F.US.DA6U24 if supported. NumLevels=100 2024-07-31 12:40:36.194 | Requesting market depth updates for: F.US.M6AU24 if supported. NumLevels=100 2024-07-31 12:40:36.195 | Requesting market depth updates for: F.US.ENQU24 if supported. NumLevels=100 2024-07-31 12:40:36.195 | Requesting market depth updates for: F.US.MNQU24 if supported. NumLevels=100 2024-07-31 12:40:36.237 | CQG WebAPI | Received symbol resolution report for symbol F.US.EU6Z22. Search Symbol: F.US.EU6Z22. Request ID: 2547. Contract ID: 3. 2024-07-31 12:40:36.238 | Denali Data Feed | Network connection to server complete. 2024-07-31 12:40:36.238 | Denali Data Feed | Starting socket receive thread. 2024-07-31 12:40:36.238 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-07-31 12:40:36.243 | Denali Data Feed | Network connection to server complete. 2024-07-31 12:40:36.243 | Denali Data Feed | Starting socket receive thread. 2024-07-31 12:40:36.243 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2024-07-31 12:40:36.243 | SC Data with Depth | Network connection to server complete. 2024-07-31 12:40:36.243 | SC Data with Depth | Starting socket receive thread. 2024-07-31 12:40:36.243 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2024-07-31 12:40:36.287 | CQG WebAPI | Received symbol resolution report for symbol F.US.EU6H23. Search Symbol: F.US.EU6H23. Request ID: 2548. Contract ID: 4. 2024-07-31 12:40:36.287 | CQG WebAPI | Received symbol resolution report for symbol F.US.EU6M23. Search Symbol: F.US.EU6M23. Request ID: 2549. Contract ID: 5. 2024-07-31 12:40:36.287 | CQG WebAPI | Received symbol resolution report for symbol F.US.M6EM24. Search Symbol: F.US.M6EM24. Request ID: 2550. Contract ID: 6. 2024-07-31 12:40:36.287 | CQG WebAPI | Received symbol resolution report for symbol F.US.EU6U24. Search Symbol: F.US.EU6U24. Request ID: 2551. Contract ID: 7. 2024-07-31 12:40:36.287 | CQG WebAPI | Received symbol resolution report for symbol F.US.CA6U24. Search Symbol: F.US.CA6U24. Request ID: 2552. Contract ID: 8. 2024-07-31 12:40:36.287 | CQG WebAPI | Received symbol resolution report for symbol F.US.MESU24. Search Symbol: F.US.MESU24. Request ID: 2553. Contract ID: 1. 2024-07-31 12:40:36.287 | CQG WebAPI | Received symbol resolution report for symbol F.US.MNQU24. Search Symbol: F.US.MNQU24. Request ID: 2554. Contract ID: 2. 2024-07-31 12:40:36.288 | CQG WebAPI | Received symbol resolution report for symbol F.US.TUAU24. Search Symbol: F.US.TUAU24. Request ID: 2555. Contract ID: 9. 2024-07-31 12:40:36.295 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEJ23. Search Symbol: F.US.CLEJ23. Request ID: 2556. Contract ID: 10. 2024-07-31 12:40:36.295 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU24. Search Symbol: F.US.CLEU24. Request ID: 2557. Contract ID: 11. 2024-07-31 12:40:36.298 | CQG WebAPI | Received symbol resolution report for symbol F.US.MCLEH24. Search Symbol: F.US.MCLEH24. Request ID: 2558. Contract ID: 12. 2024-07-31 12:40:36.298 | CQG WebAPI | Received symbol resolution report for symbol F.US.M2KM24. Search Symbol: F.US.M2KM24. Request ID: 2559. Contract ID: 13. 2024-07-31 12:40:36.298 | CQG WebAPI | Received symbol resolution report for symbol F.US.RTYU24. Search Symbol: F.US.RTYU24. Request ID: 2560. Contract ID: 14. 2024-07-31 12:40:36.298 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6H22. Search Symbol: F.US.BP6H22. Request ID: 2561. Contract ID: 15. 2024-07-31 12:40:36.310 | SC Data with Depth | Setting DTC encoding to Binary VLS 2024-07-31 12:40:36.310 | SC Data with Depth | Sending logon request message. 2024-07-31 12:40:36.312 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-07-31 12:40:36.312 | Denali Data Feed | Sending logon request message. 2024-07-31 12:40:36.325 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-07-31 12:40:36.325 | Denali Data Feed | Sending logon request message. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6Z22. Search Symbol: F.US.BP6Z22. Request ID: 2562. Contract ID: 16. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6M23. Search Symbol: F.US.BP6M23. Request ID: 2563. Contract ID: 17. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.M6BM24. Search Symbol: F.US.M6BM24. Request ID: 2564. Contract ID: 18. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U24. Search Symbol: F.US.BP6U24. Request ID: 2565. Contract ID: 19. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPH23. Search Symbol: F.US.EPH23. Request ID: 2566. Contract ID: 20. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.MNQH23. Search Symbol: F.US.MNQH23. Request ID: 2567. Contract ID: 21. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.EPU24. Search Symbol: F.US.EPU24. Request ID: 2568. Contract ID: 22. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.FVAU24. Search Symbol: F.US.FVAU24. Request ID: 2569. Contract ID: 23. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.YMU24. Search Symbol: F.US.YMU24. Request ID: 2570. Contract ID: 24. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.MYMU24. Search Symbol: F.US.MYMU24. Request ID: 2571. Contract ID: 25. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.USAU24. Search Symbol: F.US.USAU24. Request ID: 2572. Contract ID: 26. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.NGEQ24. Search Symbol: F.US.NGEQ24. Request ID: 2573. Contract ID: 27. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.GCEQ24. Search Symbol: F.US.GCEQ24. Request ID: 2574. Contract ID: 28. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.DA6U24. Search Symbol: F.US.DA6U24. Request ID: 2575. Contract ID: 29. 2024-07-31 12:40:36.338 | CQG WebAPI | Received symbol resolution report for symbol F.US.JY6U24. Search Symbol: F.US.JY6U24. Request ID: 2576. Contract ID: 30. 2024-07-31 12:40:36.339 | CQG WebAPI | Received symbol resolution report for symbol F.US.CPEU24. Search Symbol: F.US.CPEU24. Request ID: 2577. Contract ID: 31. 2024-07-31 12:40:36.339 | CQG WebAPI | Received symbol resolution report for symbol F.US.SIEU24. Search Symbol: F.US.SIEU24. Request ID: 2578. Contract ID: 32. 2024-07-31 12:40:36.375 | CQG WebAPI | Received symbol resolution report for symbol F.US.TYAU24. Search Symbol: F.US.TYAU24. Request ID: 2579. Contract ID: 33. 2024-07-31 12:40:36.375 | CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU24. Search Symbol: F.US.ENQU24. Request ID: 2580. Contract ID: 34. 2024-07-31 12:40:36.375 | CQG WebAPI | Received symbol resolution report for symbol F.US.SF6U24. Search Symbol: F.US.SF6U24. Request ID: 2581. Contract ID: 35. 2024-07-31 12:40:36.375 | CQG WebAPI | Received symbol resolution report for symbol F.US.FVAZ22. Search Symbol: F.US.FVAZ22. Request ID: 2582. Contract ID: 36. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.CPEH22. Search Symbol: F.US.CPEH22. Request ID: 2583. Contract ID: 37. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.CPEZ22. Search Symbol: F.US.CPEZ22. Request ID: 2584. Contract ID: 38. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.CPEK23. Search Symbol: F.US.CPEK23. Request ID: 2585. Contract ID: 39. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.PLEV24. Search Symbol: F.US.PLEV24. Request ID: 2586. Contract ID: 40. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.USAH23. Search Symbol: F.US.USAH23. Request ID: 2587. Contract ID: 41. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.NGEQ23. Search Symbol: F.US.NGEQ23. Request ID: 2588. Contract ID: 42. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MHGU24. Search Symbol: F.US.MHGU24. Request ID: 2589. Contract ID: 43. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.SIEH22. Search Symbol: F.US.SIEH22. Request ID: 2590. Contract ID: 44. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.USAZ23. Search Symbol: F.US.USAZ23. Request ID: 2591. Contract ID: 45. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.VXQ24. Search Symbol: F.US.VXQ24. Request ID: 2592. Contract ID: 46. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MVIM24. Search Symbol: F.US.MVIM24. Request ID: 2593. Contract ID: 47. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MVIQ24. Search Symbol: F.US.MVIQ24. Request ID: 2594. Contract ID: 48. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MNGQ24. Search Symbol: F.US.MNGQ24. Request ID: 2595. Contract ID: 49. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.NGEU24. Search Symbol: F.US.NGEU24. Request ID: 2596. Contract ID: 50. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MNGU24. Search Symbol: F.US.MNGU24. Request ID: 2597. Contract ID: 51. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.EJYM24. Search Symbol: F.US.EJYM24. Request ID: 2598. Contract ID: 52. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.GCEQ22. Search Symbol: F.US.GCEQ22. Request ID: 2599. Contract ID: 53. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.GCEG23. Search Symbol: F.US.GCEG23. Request ID: 2600. Contract ID: 54. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.GCEQ23. Search Symbol: F.US.GCEQ23. Request ID: 2601. Contract ID: 55. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.GCEZ24. Search Symbol: F.US.GCEZ24. Request ID: 2602. Contract ID: 56. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MGCQ24. Search Symbol: F.US.MGCQ24. Request ID: 2603. Contract ID: 57. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MGCZ24. Search Symbol: F.US.MGCZ24. Request ID: 2604. Contract ID: 58. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ22. Search Symbol: F.US.CLEQ22. Request ID: 2605. Contract ID: 59. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.CLEX22. Search Symbol: F.US.CLEX22. Request ID: 2606. Contract ID: 60. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.SILN24. Search Symbol: F.US.SILN24. Request ID: 2607. Contract ID: 61. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.JY6H22. Search Symbol: F.US.JY6H22. Request ID: 2608. Contract ID: 62. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.JY6Z22. Search Symbol: F.US.JY6Z22. Request ID: 2609. Contract ID: 63. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.JY6H23. Search Symbol: F.US.JY6H23. Request ID: 2610. Contract ID: 64. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.SF6M23. Search Symbol: F.US.SF6M23. Request ID: 2611. Contract ID: 65. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.MSFM24. Search Symbol: F.US.MSFM24. Request ID: 2612. Contract ID: 66. 2024-07-31 12:40:36.376 | CQG WebAPI | Received symbol resolution report for symbol F.US.M6AU24. Search Symbol: F.US.M6AU24. Request ID: 2613. Contract ID: 67. 2024-07-31 12:40:36.486 | HD Server Manager | Incoming connection from IP: 127.0.0.1 2024-07-31 12:40:36.487 | HD Server Manager | Started new historical data server. Count=1 2024-07-31 12:40:36.573 | HD Server | Thread:24528 (5) | Creating socket. 2024-07-31 12:40:36.573 | HD Server | Thread:24528 (5) | New receive buffer size: 262144 2024-07-31 12:40:36.574 | HD Server | Thread:24528 (5) | Allocated send buffers: 32 of 4096 bytes. 2024-07-31 12:40:36.574 | HD Server | Setting DTC encoding to Binary VLS | Thread:24528 2024-07-31 12:40:36.576 | HD Server | Received login. Requesting authorization. | Username: Zachary Harris. | Thread:24528 2024-07-31 12:40:36.576 | HD Server | Login has been authorized. | Username: Zachary Harris. | Thread:24528 2024-07-31 12:40:36.578 | HD Server | HD Request #291 | Socket: 5 | Symbol: F.US.DBU24 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-01-27 17:40:36 | ClientReqID: 291 | Username: Zachary Harris. | Thread:24528 2024-07-31 12:40:36.579 | CQG WebAPI | Using primary service for historical data for F.US.DBU24 2024-07-31 12:40:36.580 | No historical data client is currently set to download historical Intraday data for F.US.DBU24. 2024-07-31 12:40:36.580 | Real-time Intraday chart data file updates started for F.US.DBU24 2024-07-31 12:40:36.580 | Intraday chart data file opened for F.US.DBU24 2024-07-31 12:40:36.685 | SC Data with Depth | Received logon response. 2024-07-31 12:40:36.685 | SC Data with Depth | Server Name: SC Realtime Server. 2024-07-31 12:40:36.685 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2024-07-31 12:40:36.685 | SC Data with Depth | Successfully connected. 2024-07-31 12:40:36.685 | SC Data with Depth | Trading is not supported. 2024-07-31 12:40:36.685 | SC Data with Depth | MarketDepthIsSupported: 1 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: ADV-NQ 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: ADV-NYSE 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: ADV-TF 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: ADV-YM 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DECL-NQ 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DECL-NYSE 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DECL-TF 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DECL-YM 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DVOL-NQ 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DVOL-NYSE 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DVOL-TF 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: DVOL-YM 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: TVOL-NQ 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: TVOL-NYSE 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: TVOL-TF 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: TVOL-YM 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: USDX 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: UVOL-NQ 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: UVOL-NYSE 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: UVOL-TF 2024-07-31 12:40:36.685 | SC Data with Depth | Restarting real-time data updates for symbol: UVOL-YM 2024-07-31 12:40:36.825 | Denali Data Feed | Received logon response. 2024-07-31 12:40:36.825 | Denali Data Feed | Server Name: SC Realtime Server. 2024-07-31 12:40:36.825 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-07-31 12:40:36.825 | Denali Data Feed | Successfully connected. 2024-07-31 12:40:36.825 | Denali Data Feed | Trading is not supported. 2024-07-31 12:40:36.825 | Denali Data Feed | MarketDepthIsSupported: 1 2024-07-31 12:40:36.825 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MVIM24 -> VXMM24_FUT_CFE 2024-07-31 12:40:36.861 | Denali Data Feed (Market Orders Data) | Connecting to the server ds33.sierracharts.com. Port 10060 2024-07-31 12:40:36.862 | DTC Client socket (8) | Creating socket. 2024-07-31 12:40:36.862 | DTC Client socket (8) | New receive buffer size: 0 2024-07-31 12:40:36.862 | DTC Client socket (8) | Connecting to IP: 69.39.70.245. 2024-07-31 12:40:36.886 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MVIQ24 -> VXMQ24_FUT_CFE. Market Depth data restarted. 2024-07-31 12:40:36.887 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.VXQ24 -> VXQ24_FUT_CFE. Market Depth data restarted. 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol ADV-NQ 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol ADV-NYSE 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol ADV-TF 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol ADV-YM 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DECL-NQ 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DECL-NYSE 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DECL-TF 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DECL-YM 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DVOL-NQ 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DVOL-NYSE 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DVOL-TF 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol DVOL-YM 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol TVOL-NQ 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol TVOL-NYSE 2024-07-31 12:40:36.887 | SC Data with Depth | Received security definition for symbol TVOL-TF 2024-07-31 12:40:36.888 | SC Data with Depth | Received security definition for symbol TVOL-YM 2024-07-31 12:40:36.888 | SC Data with Depth | Received security definition for symbol USDX 2024-07-31 12:40:36.888 | SC Data with Depth | Received security definition for symbol UVOL-NQ 2024-07-31 12:40:36.888 | SC Data with Depth | Received security definition for symbol UVOL-NYSE 2024-07-31 12:40:36.888 | SC Data with Depth | Received security definition for symbol UVOL-TF 2024-07-31 12:40:36.888 | SC Data with Depth | Received security definition for symbol UVOL-YM 2024-07-31 12:40:36.907 | Added historical Intraday data request for F.US.VXQ24 to the queue. 2024-07-31 12:40:36.907 | Intraday data recording state for symbol F.US.VXQ24 is set to download 'Pending'. 2024-07-31 12:40:36.907 | Triggering next historical data download in queue. 2024-07-31 12:40:36.921 | Delaying start of download for F.US.VXQ24. 2024-07-31 12:40:36.922 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2024-07-31 12:40:36.922 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2024-07-31 12:40:36.922 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2024-07-31 12:40:36.980 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2024-07-31 12:40:36.980 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2024-07-31 12:40:36.983 | Denali Data Feed | Clearing market depth for F.US.MVIQ24 2024-07-31 12:40:36.983 | Denali Data Feed | Clearing market depth for F.US.MVIQ24 2024-07-31 12:40:36.983 | Denali Data Feed | Real-time data for symbol F.US.MVIM24 is currently unavailable. 2024-07-31 12:40:36.983 | Denali Data Feed | Received security definition for symbol F.US.MVIM24 2024-07-31 12:40:36.983 | Denali Data Feed | Received security definition for symbol F.US.MVIQ24 2024-07-31 12:40:36.983 | Denali Data Feed | Clearing market depth for F.US.VXQ24 2024-07-31 12:40:36.983 | Denali Data Feed | Received security definition for symbol F.US.VXQ24 2024-07-31 12:40:37.062 | Denali Data Feed | Received logon response. 2024-07-31 12:40:37.062 | Denali Data Feed | Server Name: SC Realtime Server. 2024-07-31 12:40:37.062 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-07-31 12:40:37.062 | Denali Data Feed | Successfully connected. 2024-07-31 12:40:37.062 | Denali Data Feed | Trading is not supported. 2024-07-31 12:40:37.062 | Denali Data Feed | MarketDepthIsSupported: 1 2024-07-31 12:40:37.062 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6H22 -> 6BH22 2024-07-31 12:40:37.062 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6M23 -> 6BM23 2024-07-31 12:40:37.090 | Denali Data Feed (Market Orders Data) | Connecting to the server ds28-2.sierracharts.com. Port 10060 2024-07-31 12:40:37.091 | DTC Client socket (9) | Creating socket. 2024-07-31 12:40:37.091 | DTC Client socket (9) | New receive buffer size: 0 2024-07-31 12:40:37.091 | DTC Client socket (9) | Connecting to IP: 67.214.125.6. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6U24 -> 6BU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.BP6Z22 -> 6BZ22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CA6U24 -> 6CU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEJ23 -> CLJ23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEQ22 -> CLQ22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEU24 -> CLU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CLEX22 -> CLX22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CPEH22 -> HGH22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CPEK23 -> HGK23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CPEU24 -> HGU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.CPEZ22 -> HGZ22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DA6U24 -> 6AU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EJYM24 -> J7M24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.ENQU24 -> NQU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPH23 -> ESH23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EPU24 -> ESU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EU6H23 -> 6EH23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EU6M23 -> 6EM23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EU6U24 -> 6EU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.EU6Z22 -> 6EZ22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FVAU24 -> ZFU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FVAZ22 -> ZFZ22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.GCEG23 -> GCG23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.GCEQ22 -> GCQ22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.GCEQ23 -> GCQ23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.GCEQ24 -> GCQ24 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.GCEZ24 -> GCZ24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.JY6H22 -> 6JH22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.JY6H23 -> 6JH23 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.JY6U24 -> 6JU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.JY6Z22 -> 6JZ22 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.M2KM24 -> M2KM24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.M6AU24 -> M6AU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.M6BM24 -> M6BM24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.M6EM24 -> M6EM24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MCLEH24 -> MCLH24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MESU24 -> MESU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MGCQ24 -> MGCQ24 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MGCZ24 -> MGCZ24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MHGU24 -> MHGU24. Market Depth data restarted. 2024-07-31 12:40:37.119 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MNGQ24 -> MNGQ24 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MNGU24 -> MNGU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MNQH23 -> MNQH23 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MNQU24 -> MNQU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MSFM24 -> MSFM24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.MYMU24 -> MYMU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.NGEQ23 -> NGQ23 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.NGEQ24 -> NGQ24 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.NGEU24 -> NGU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.PLEV24 -> PLV24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.RTYU24 -> RTYU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.SF6M23 -> 6SM23 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.SF6U24 -> 6SU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.SIEH22 -> SIH22 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.SIEU24 -> SIU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.SILN24 -> SILN24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.TUAU24 -> ZTU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.TYAU24 -> ZNU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.USAH23 -> ZBH23 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.USAU24 -> ZBU24. Market Depth data restarted. 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.USAZ23 -> ZBZ23 2024-07-31 12:40:37.120 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.YMU24 -> YMU24. Market Depth data restarted. 2024-07-31 12:40:37.152 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2024-07-31 12:40:37.152 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2024-07-31 12:40:37.152 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard 2024-07-31 12:40:37.218 | Denali Data Feed | Clearing market depth for F.US.BP6U24 2024-07-31 12:40:37.218 | Denali Data Feed | Real-time data for symbol F.US.BP6H22 is currently unavailable. 2024-07-31 12:40:37.218 | Denali Data Feed | Received security definition for symbol F.US.BP6H22 2024-07-31 12:40:37.218 | Denali Data Feed | Real-time data for symbol F.US.BP6M23 is currently unavailable. 2024-07-31 12:40:37.218 | Denali Data Feed | Received security definition for symbol F.US.BP6M23 2024-07-31 12:40:37.218 | Denali Data Feed | Received security definition for symbol F.US.BP6U24 2024-07-31 12:40:37.219 | Denali Data Feed | Real-time data for symbol F.US.BP6Z22 is currently unavailable. 2024-07-31 12:40:37.219 | Denali Data Feed | Received security definition for symbol F.US.BP6Z22 2024-07-31 12:40:37.232 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2024-07-31 12:40:37.232 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Received logon response. 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Successfully connected. 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: VXMQ24_FUT_CFE. MinimumMarketByOrderQuantity: 0. Service code: cfe_exchange.data 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MVIQ24 -> VXMQ24_FUT_CFE 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: VXQ24_FUT_CFE. MinimumMarketByOrderQuantity: 0. Service code: cfe_exchange.data 2024-07-31 12:40:37.387 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.VXQ24 -> VXQ24_FUT_CFE 2024-07-31 12:40:37.488 | Denali Data Feed | Clearing market depth for F.US.CA6U24 2024-07-31 12:40:37.488 | Denali Data Feed | Clearing market depth for F.US.CLEU24 2024-07-31 12:40:37.488 | Denali Data Feed | Received security definition for symbol F.US.CA6U24 2024-07-31 12:40:37.488 | Denali Data Feed | Real-time data for symbol F.US.CLEJ23 is currently unavailable. 2024-07-31 12:40:37.488 | Denali Data Feed | Received security definition for symbol F.US.CLEJ23 2024-07-31 12:40:37.488 | Denali Data Feed | Real-time data for symbol F.US.CLEQ22 is currently unavailable. 2024-07-31 12:40:37.488 | Denali Data Feed | Received security definition for symbol F.US.CLEQ22 2024-07-31 12:40:37.488 | Denali Data Feed | Received security definition for symbol F.US.CLEU24 2024-07-31 12:40:37.488 | Denali Data Feed | Clearing market depth for F.US.CPEU24 2024-07-31 12:40:37.489 | Denali Data Feed | Clearing market depth for F.US.DA6U24 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.CLEX22 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.CLEX22 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.CPEH22 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.CPEH22 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.CPEK23 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.CPEK23 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.CPEU24 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.CPEZ22 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.CPEZ22 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.DA6U24 2024-07-31 12:40:37.489 | Denali Data Feed | Clearing market depth for F.US.EJYM24 2024-07-31 12:40:37.489 | Denali Data Feed | Clearing market depth for F.US.ENQU24 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.EJYM24 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.EJYM24 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.ENQU24 2024-07-31 12:40:37.489 | Denali Data Feed | Clearing market depth for F.US.EPU24 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.EPH23 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.EPH23 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.EPU24 2024-07-31 12:40:37.489 | Denali Data Feed | Clearing market depth for F.US.EU6U24 2024-07-31 12:40:37.489 | Denali Data Feed | Clearing market depth for F.US.FVAU24 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.EU6H23 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.EU6H23 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.EU6M23 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.EU6M23 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.EU6U24 2024-07-31 12:40:37.489 | Denali Data Feed | Real-time data for symbol F.US.EU6Z22 is currently unavailable. 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.EU6Z22 2024-07-31 12:40:37.489 | Denali Data Feed | Received security definition for symbol F.US.FVAU24 2024-07-31 12:40:37.490 | Denali Data Feed | Clearing market depth for F.US.GCEZ24 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.FVAZ22 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.FVAZ22 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.GCEG23 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.GCEG23 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.GCEQ22 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.GCEQ22 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.GCEQ23 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.GCEQ23 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.GCEQ24 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.GCEZ24 2024-07-31 12:40:37.490 | Denali Data Feed | Clearing market depth for F.US.JY6U24 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.JY6H22 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.JY6H22 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.JY6H23 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.JY6H23 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.JY6U24 2024-07-31 12:40:37.490 | Denali Data Feed | Clearing market depth for F.US.M2KM24 2024-07-31 12:40:37.490 | Denali Data Feed | Clearing market depth for F.US.M6AU24 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.JY6Z22 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.JY6Z22 2024-07-31 12:40:37.490 | Denali Data Feed | Real-time data for symbol F.US.M2KM24 is currently unavailable. 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.M2KM24 2024-07-31 12:40:37.490 | Denali Data Feed | Received security definition for symbol F.US.M6AU24 2024-07-31 12:40:37.490 | Denali Data Feed | Clearing market depth for F.US.M6BM24 2024-07-31 12:40:37.491 | Denali Data Feed | Clearing market depth for F.US.M6EM24 2024-07-31 12:40:37.491 | Denali Data Feed | Real-time data for symbol F.US.M6BM24 is currently unavailable. 2024-07-31 12:40:37.491 | Denali Data Feed | Received security definition for symbol F.US.M6BM24 2024-07-31 12:40:37.491 | Denali Data Feed | Real-time data for symbol F.US.M6EM24 is currently unavailable. 2024-07-31 12:40:37.491 | Denali Data Feed | Received security definition for symbol F.US.M6EM24 2024-07-31 12:40:37.491 | Denali Data Feed | Clearing market depth for F.US.MCLEH24 2024-07-31 12:40:37.491 | Denali Data Feed | Real-time data for symbol F.US.MCLEH24 is currently unavailable. 2024-07-31 12:40:37.491 | Denali Data Feed | Received security definition for symbol F.US.MCLEH24 2024-07-31 12:40:37.491 | Denali Data Feed | Clearing market depth for F.US.MESU24 2024-07-31 12:40:37.491 | Denali Data Feed | Received security definition for symbol F.US.MESU24 2024-07-31 12:40:37.491 | Denali Data Feed | Clearing market depth for F.US.MGCZ24 2024-07-31 12:40:37.491 | Denali Data Feed | Received security definition for symbol F.US.MGCQ24 2024-07-31 12:40:37.491 | Denali Data Feed | Received security definition for symbol F.US.MGCZ24 2024-07-31 12:40:37.491 | Denali Data Feed | Clearing market depth for F.US.MHGU24 2024-07-31 12:40:37.491 | Denali Data Feed | Clearing market depth for F.US.MNGU24 2024-07-31 12:40:37.492 | Denali Data Feed | Clearing market depth for F.US.MNQU24 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.MHGU24 2024-07-31 12:40:37.492 | Denali Data Feed | Real-time data for symbol F.US.MNGQ24 is currently unavailable. 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.MNGQ24 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.MNGU24 2024-07-31 12:40:37.492 | Denali Data Feed | Real-time data for symbol F.US.MNQH23 is currently unavailable. 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.MNQH23 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.MNQU24 2024-07-31 12:40:37.492 | Denali Data Feed | Clearing market depth for F.US.MSFM24 2024-07-31 12:40:37.492 | Denali Data Feed | Clearing market depth for F.US.MYMU24 2024-07-31 12:40:37.492 | Denali Data Feed | Clearing market depth for F.US.NGEU24 2024-07-31 12:40:37.492 | Denali Data Feed | Clearing market depth for F.US.PLEV24 2024-07-31 12:40:37.492 | Denali Data Feed | Real-time data for symbol F.US.MSFM24 is currently unavailable. 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.MSFM24 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.MYMU24 2024-07-31 12:40:37.492 | Denali Data Feed | Real-time data for symbol F.US.NGEQ23 is currently unavailable. 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.NGEQ23 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.NGEQ24 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.NGEU24 2024-07-31 12:40:37.492 | Denali Data Feed | Received security definition for symbol F.US.PLEV24 2024-07-31 12:40:37.492 | Denali Data Feed | Clearing market depth for F.US.RTYU24 2024-07-31 12:40:37.492 | Denali Data Feed | Clearing market depth for F.US.SF6U24 2024-07-31 12:40:37.493 | Denali Data Feed | Clearing market depth for F.US.SIEU24 2024-07-31 12:40:37.493 | Denali Data Feed | Clearing market depth for F.US.SILN24 2024-07-31 12:40:37.493 | Denali Data Feed | Received security definition for symbol F.US.RTYU24 2024-07-31 12:40:37.493 | Denali Data Feed | Real-time data for symbol F.US.SF6M23 is currently unavailable. 2024-07-31 12:40:37.493 | Denali Data Feed | Received security definition for symbol F.US.SF6M23 2024-07-31 12:40:37.493 | Denali Data Feed | Received security definition for symbol F.US.SF6U24 2024-07-31 12:40:37.493 | Denali Data Feed | Real-time data for symbol F.US.SIEH22 is currently unavailable. 2024-07-31 12:40:37.493 | Denali Data Feed | Received security definition for symbol F.US.SIEH22 2024-07-31 12:40:37.493 | Denali Data Feed | Received security definition for symbol F.US.SIEU24 2024-07-31 12:40:37.493 | Denali Data Feed | Received security definition for symbol F.US.SILN24 2024-07-31 12:40:37.493 | Denali Data Feed | Clearing market depth for F.US.TUAU24 2024-07-31 12:40:37.493 | Denali Data Feed | Clearing market depth for F.US.TYAU24 2024-07-31 12:40:37.493 | Denali Data Feed | Clearing market depth for F.US.USAU24 2024-07-31 12:40:37.493 | Denali Data Feed | Clearing market depth for F.US.YMU24 2024-07-31 12:40:37.495 | Denali Data Feed | Received security definition for symbol F.US.TUAU24 2024-07-31 12:40:37.495 | Denali Data Feed | Received security definition for symbol F.US.TYAU24 2024-07-31 12:40:37.495 | Denali Data Feed | Real-time data for symbol F.US.USAH23 is currently unavailable. 2024-07-31 12:40:37.495 | Denali Data Feed | Received security definition for symbol F.US.USAH23 2024-07-31 12:40:37.495 | Denali Data Feed | Received security definition for symbol F.US.USAU24 2024-07-31 12:40:37.495 | Denali Data Feed | Real-time data for symbol F.US.USAZ23 is currently unavailable. 2024-07-31 12:40:37.495 | Denali Data Feed | Received security definition for symbol F.US.USAZ23 2024-07-31 12:40:37.495 | Denali Data Feed | Received security definition for symbol F.US.YMU24 2024-07-31 12:40:37.543 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MVIQ24. Market orders request not authorized. 2024-07-31 12:40:37.543 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.VXQ24. Market orders request not authorized. 2024-07-31 12:40:37.568 | HD Server | HD Request | Socket: 5 | Symbol: F.US.DBU24 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 0 | Error: Historical data file for F.US.DBU24 not available. S:\Sierra Chart (CQG)\Data\F.US.DBU24.scid | ClientReqID: 291 | Username: Zachary Harris. | Thread:24528 2024-07-31 12:40:37.568 | HD Server | Thread:24528 (5) | Socket gracefully closed by remote side. 2024-07-31 12:40:37.568 | HD Server | Thread:24528 (5) | CloseSocket call. 2024-07-31 12:40:37.570 | HD Server | Thread:24528 (0) | CloseSocket call. 2024-07-31 12:40:37.570 | HD Server | Thread:24528 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-07-31 12:40:37.570 | HD Server | Thread:24528 (5) | Closed. 2024-07-31 12:40:37.570 | HD Server | Thread:24528 (0) | CloseSocket call. 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Received logon response. 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Successfully connected. 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: 6BU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.BP6U24 -> 6BU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: 6CU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.CA6U24 -> 6CU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: CLU24. MinimumMarketByOrderQuantity: 0. Service code: nymex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.CLEU24 -> CLU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: HGU24. MinimumMarketByOrderQuantity: 0. Service code: comex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.CPEU24 -> HGU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: 6AU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.DA6U24 -> 6AU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: J7M24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.EJYM24 -> J7M24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.ENQU24 -> NQU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESU24. MinimumMarketByOrderQuantity: 203. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.EPU24 -> ESU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: 6EU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.EU6U24 -> 6EU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ZFU24. MinimumMarketByOrderQuantity: 0. Service code: cbot 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.FVAU24 -> ZFU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: GCZ24. MinimumMarketByOrderQuantity: 0. Service code: comex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.GCEZ24 -> GCZ24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: 6JU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.JY6U24 -> 6JU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: M2KM24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.M2KM24 -> M2KM24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: M6AU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.M6AU24 -> M6AU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: M6BM24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.M6BM24 -> M6BM24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: M6EM24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.M6EM24 -> M6EM24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MCLH24. MinimumMarketByOrderQuantity: 0. Service code: nymex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MCLEH24 -> MCLH24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MESU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MESU24 -> MESU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MGCZ24. MinimumMarketByOrderQuantity: 0. Service code: comex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MGCZ24 -> MGCZ24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MHGU24. MinimumMarketByOrderQuantity: 0. Service code: comex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MHGU24 -> MHGU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MNGU24. MinimumMarketByOrderQuantity: 0. Service code: nymex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MNGU24 -> MNGU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MNQU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MNQU24 -> MNQU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MSFM24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MSFM24 -> MSFM24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: MYMU24. MinimumMarketByOrderQuantity: 0. Service code: cbot 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.MYMU24 -> MYMU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NGU24. MinimumMarketByOrderQuantity: 0. Service code: nymex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.NGEU24 -> NGU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: PLV24. MinimumMarketByOrderQuantity: 0. Service code: nymex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.PLEV24 -> PLV24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: RTYU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.RTYU24 -> RTYU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: 6SU24. MinimumMarketByOrderQuantity: 0. Service code: cme 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.SF6U24 -> 6SU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: SIU24. MinimumMarketByOrderQuantity: 0. Service code: comex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.SIEU24 -> SIU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: SILN24. MinimumMarketByOrderQuantity: 0. Service code: comex 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.SILN24 -> SILN24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ZTU24. MinimumMarketByOrderQuantity: 0. Service code: cbot 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.TUAU24 -> ZTU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ZNU24. MinimumMarketByOrderQuantity: 0. Service code: cbot 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.TYAU24 -> ZNU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ZBU24. MinimumMarketByOrderQuantity: 0. Service code: cbot 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.USAU24 -> ZBU24 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: YMU24. MinimumMarketByOrderQuantity: 0. Service code: cbot 2024-07-31 12:40:37.639 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: F.US.YMU24 -> YMU24 2024-07-31 12:40:37.645 | HD Server | Server thread ending. Closing socket. | Username: Zachary Harris. | Thread:24528 2024-07-31 12:40:37.645 | HD Server Manager | Current server count=0 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.BP6U24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.CA6U24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.CLEU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.CPEU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.DA6U24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.EJYM24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Real-time data for symbol F.US.EJYM24 is currently unavailable. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.ENQU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.EPU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.EU6U24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.FVAU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.GCEZ24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.JY6U24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Real-time data for symbol F.US.M2KM24 is currently unavailable. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.M2KM24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.M6AU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.M6BM24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Real-time data for symbol F.US.M6BM24 is currently unavailable. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.M6EM24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Real-time data for symbol F.US.M6EM24 is currently unavailable. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MCLEH24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Real-time data for symbol F.US.MCLEH24 is currently unavailable. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MESU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MGCZ24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MHGU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MNGU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MNQU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Real-time data for symbol F.US.MSFM24 is currently unavailable. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MSFM24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.MYMU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.NGEU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.PLEV24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.RTYU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.SF6U24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.SIEU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.SILN24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.TUAU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.TYAU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.USAU24. Market orders request not authorized. 2024-07-31 12:40:37.796 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: F.US.YMU24. Market orders request not authorized. 2024-07-31 12:40:37.882 | HD Server Manager | Incoming connection from IP: 127.0.0.1 2024-07-31 12:40:37.882 | HD Server Manager | Started new historical data server. Count=1 2024-07-31 12:40:37.954 | HD Server | Thread:21420 (5) | Creating socket. 2024-07-31 12:40:37.954 | HD Server | Thread:21420 (5) | New receive buffer size: 262144 2024-07-31 12:40:37.954 | HD Server | Thread:21420 (5) | Allocated send buffers: 32 of 4096 bytes. 2024-07-31 12:40:37.955 | HD Server | Setting DTC encoding to Binary VLS | Thread:21420 2024-07-31 12:40:37.956 | HD Server | Received login. Requesting authorization. | Username: Zachary Harris. | Thread:21420 2024-07-31 12:40:37.956 | HD Server | Login has been authorized. | Username: Zachary Harris. | Thread:21420 2024-07-31 12:40:37.958 | HD Server | HD Request #293 | Socket: 5 | Symbol: F.US.FOATU24 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2024-01-27 17:40:37 | ClientReqID: 293 | Username: Zachary Harris. | Thread:21420 2024-07-31 12:40:37.960 | CQG WebAPI | Using primary service for historical data for F.US.FOATU24 2024-07-31 12:40:37.960 | No historical data client is currently set to download historical Intraday data for F.US.FOATU24. 2024-07-31 12:40:37.960 | Real-time Intraday chart data file updates started for F.US.FOATU24 2024-07-31 12:40:37.960 | Intraday chart data file opened for F.US.FOATU24 2024-07-31 12:40:38.966 | HD Server | HD Request | Socket: 5 | Symbol: F.US.FOATU24 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 0 | Error: Historical data file for F.US.FOATU24 not available. S:\Sierra Chart (CQG)\Data\F.US.FOATU24.scid | ClientReqID: 293 | Username: Zachary Harris. | Thread:21420 2024-07-31 12:40:38.967 | HD Server | Thread:21420 (5) | Socket gracefully closed by remote side. 2024-07-31 12:40:38.967 | HD Server | Thread:21420 (5) | CloseSocket call. 2024-07-31 12:40:38.969 | HD Server | Thread:21420 (0) | CloseSocket call. 2024-07-31 12:40:38.969 | HD Server | Thread:21420 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-07-31 12:40:38.969 | HD Server | Thread:21420 (5) | Closed. 2024-07-31 12:40:38.969 | HD Server | Thread:21420 (0) | CloseSocket call. 2024-07-31 12:40:39.146 | HD Server | Server thread ending. Closing socket. | Username: Zachary Harris. | Thread:21420 2024-07-31 12:40:39.147 | HD Server Manager | Current server count=0 2024-07-31 12:40:41.448 | HD Request # 183 | Downloading Intraday chart data for F.US.VXQ24 to the file F.US.VXQ24.scid. Service: cfe_exchange.data 2024-07-31 12:40:41.448 | HD Request # 183 | Download start date-time: 2024-07-31 11:55:45.000000. File last date-time: 2024-07-31 11:55:45.008000 2024-07-31 12:40:41.449 | HD Request # 183 | Using server: ds30.sierracharts.com port 10150 2024-07-31 12:40:41.449 | Socket (5) | Creating socket. 2024-07-31 12:40:41.449 | Socket (5) | New receive buffer size: 0 2024-07-31 12:40:41.449 | Socket (5) | Connecting to IP: 38.103.112.179. 2024-07-31 12:40:41.526 | HD Request # 183 | Setting DTC encoding to Binary VLS 2024-07-31 12:40:41.526 | HD Request # 183 | Sending historical data logon request message. 2024-07-31 12:40:41.559 | HD Request # 183 | Requesting Intraday data. Start date-time: 2024-07-31 11:55:45. Record interval: 0. Symbol: VXQ24_FUT_CFE 2024-07-31 12:40:41.594 | HD Request # 183 | Decompressing data. 2024-07-31 12:40:41.634 | HD Request # 183 | Receiving Intraday data for F.US.VXQ24 starting at 2024-07-31 11:55:45.008000 2024-07-31 12:40:41.636 | Socket (5) | CloseSocket call. 2024-07-31 12:40:41.636 | Socket (5) | Shutdown started. Waiting for graceful close. 2024-07-31 12:40:41.636 | Historical data download thread signaled to stop. 2024-07-31 12:40:41.636 | HD Request # 183 | Timestamp of first Intraday data file record written: 2024-07-31 11:55:51.039000. 2024-07-31 12:40:41.636 | HD Request # 183 | Received 1773 Intraday data records from 2024-07-31 11:55:45.008000 to 2024-07-31 12:40:30.017000 (44.8 minutes. Delay: 11.6 seconds) and wrote 1772 records for F.US.VXQ24 2024-07-31 12:40:41.637 | HD Request # 183 | Add time&sales data | Remembered last file record date-time: 2024-07-31 17:40:30.017000 2024-07-31 12:40:41.637 | HD Request # 183 | Completion time: 0s. 2024-07-31 12:40:41.637 | HD Request # 183 | Intraday data download complete for F.US.VXQ24. Unique request ID: 183 2024-07-31 12:40:41.637 | Removing historical data download ID 183. 2024-07-31 12:40:41.637 | Real-time Intraday chart data file updates started for F.US.VXQ24 2024-07-31 12:40:41.637 | Intraday chart data file opened for F.US.VXQ24 2024-07-31 12:40:41.637 | HD Request # 183 | Enabling Intraday chart updating for symbol. 2024-07-31 12:40:41.637 | 2024-07-31 12:40:41.637 | No download requests in the queue to start downloads for. 2024-07-31 12:40:41.675 | Socket (5) | Socket gracefully closed by remote side. 2024-07-31 12:40:41.675 | Socket (5) | Closed. 2024-07-31 12:40:48.339 | Opened cached Intraday file: S:\Sierra Chart (CQG)\Data\F.US.VXQ24.scid. Thread ID: 17432 |
[2024-07-31 19:37:02] |
Sierra_Chart Engineering - Posts: 16656 |
This log does not indicate any problem for F.US.VXQ24 that we can see. Do you see updating in the Current Quote window for the symbol: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.4 - Not Receiving Real-Time Data From Data Feed Also this log is full of a lot of other symbols. It is hard to go through. This is why we specified only opening one chart for the symbol. Also from another log, to solve this problem: 2024-07-24 00:01:19.007 | F.US.VXQ24 [CB] Weekly #2 | Error while getting daily settlement price with date 2005-03-10 from file. S:\Sierra Chart (CQG)\SierraChartInstance_13\Data\F.US.VXJ05.dly. Error: No Data for read. End of file. Refer to: Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-31 19:37:20
