Date/Time: Sun, 08 Sep 2024 00:34:40 +0000
Tool Text Labels on top of DOM Graph/Profile
View Count: 78
[2024-07-23 17:57:46] |
aruehlicke - Posts: 2 |
I can't find an answer on how to display tool text labels on top of my DOM graph/profiles on the right side of the chart. If this isn't an option, is there a way to indent my chart so that my text labels aren't obstructed or display in their own column? Thanks |
[2024-07-23 18:56:31] |
Drawings are either drawn above or below the other items on the screen. Refer to the following setting and the one below it: Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) The only other thing is to look at the options for the particular drawing to see if you can move the location of the text elsewhere. This will depend on the particular drawing as to what is available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-23 20:03:53] |
Figured it out, thanks to the response above. Chart settings -> Chart Drawings -> Draw Drawings Underneath Main Graph and Studies "No"
