Date/Time: Sun, 08 Sep 2024 00:42:17 +0000
Denali Market Data Feed for Remote Buffer Delay Send Time In Milliseconds
View Count: 113
[2024-07-21 01:12:18] |
pyfoo - Posts: 1 |
Question Based on the setting linked below, a strategy will only be able to react to data with a delay of 1ms or greater, is this correct? In other words, if there is a strategy that requires less of a delay (say in the us/microsecond timespan), it would not be able to function on SC data feeds? -- Remote Buffer Delay Send Time In Milliseconds (Global Settings >> Sierra Chart Server Settings >> General >> General URL: Sierra Chart Server Settings: Remote Buffer Delay Send Time In Milliseconds (Global Settings >> Sierra Chart Server Settings >> General >> General) It states "This setting only affects Sierra Chart data feeds. It controls the transmission interval of data from the server, specified in milliseconds. Using a value of 0 uses the default." |
[2024-07-21 11:17:50] |
Sierra_Chart Engineering - Posts: 16292 |
First, there is absolutely no way you can ever expect data delivery, down to the millisecond or even within a few milliseconds. That is just not possible at all. It is inefficient and impossible to achieve. Anyone claiming that, is lying to you. You will need to have a direct multicast feed with the exchange, and have co-location, and the exchange data center. So we are not going to accept, that there is something wrong here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-21 11:18:53
