Date/Time: Fri, 25 Sep 2026 12:19:08 +0000
Teton order routing with AMP
View Count: 597
[2024-07-19 14:39:18]
User396631 - Posts: 2
I'm trying to set up Teton order routing with AMP. When I enter my Sierra Chart name in the AMP username for Sierra Chart field, it appears blank and doesn't verify the name. AMP mentioned I should contact Sierra to activate Teton order routing. Could this be the issue? Do I need to contact Sierra to activate Teton order routing? If so, where else can I get support to proceed with this? Thank you
[2024-07-19 14:52:33]
Sierra_Chart Engineering - Posts: 24971
AMP has contacted us about this. We are looking into this.
