Date/Time: Sun, 08 Sep 2024 00:29:37 +0000
Point of Control
View Count: 116
[2024-07-19 13:53:03] |
User213504 - Posts: 62 |
Is it possible to display the daily POC from a daily chart on to a smaller time frame chart? Study Price Overlay overlays the entire study.
[2024-07-19 15:06:09] |
We are not quite understanding the issue. Yes, the Study/Price Overlay will overlay the entire study, but you will get the POC from each day to mapped to the bars that match that day. Are you having some issue with the way this is functioning? Or are you really only wanting a single day of information?
[2024-07-19 15:38:06] |
A single day on the current day's chart. Having the entire study puts too much information on the chart.
[2024-07-19 18:25:06] |
The easiest way to do this would be to have a chart with only a single day in it, and put the POC study on that and then use the Study/Price Overlay to overlay that one day's worth of information to the other chart. Otherwise, you would have to use the Spreadsheet Study to pull out just the one day's worth of information you want and then overlay that to the lower timeframe chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-19 19:00:27] |
I tried something and it works. I hid all lines on the daily chart except the POC. S/P Overlay just placed the POC on the chart.
