Date/Time: Sun, 08 Sep 2024 02:15:23 +0000
suggestion
View Count: 232
[2024-07-17 17:22:57] |
User124881 - Posts: 9 |
i would like to get the OFL subscription with sierra-chart but i don't know what package do i need and am already with rithmic for data what do you suggest.
[2024-07-17 17:27:27] |
What is OFL?
[2024-07-17 19:34:53] |
You would have to ask the company that makes Order Flow Labs if they have any requirement on a particular package.
[2024-07-17 19:46:03] |
thank you how do i connect rithmic to sierra-chart for data
[2024-07-17 19:50:42] |
which data feed do i need i only trade ES and NQ futures
[2024-07-18 13:55:51] |
In order to connect to Rithmic for trading and/or data, follow these instructions: Rithmic Trading Platform Service: Setup Instructions If you are getting the data from Rithmic, then there is nothing further you need to do. If you want to get the data from our Denali Exchange Data Feed, then you will need to follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Just be aware that in order to get the real-time data for the CME Group at the non-professional pricing, you need to have a live, funded, futures trading account, and you need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-18 14:10:50] |
i do not have a live account am doing the trading combine challenge with topset i was using rithmic with bookmap now i want to switch up to Sierra-chart what do i need am still confuse |
[2024-07-18 15:25:58] |
can i get my question answered please
[2024-07-18 16:36:51] |
Follow these instructions to connect to Rithmic: Rithmic Trading Platform Service: Setup Instructions As long as you are setup to get data from Rithmic, then you will get the data from Rithmic into your Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-18 17:01:13] |
i tried it and it's not working and can't figured out can you tell me what exactly i need to get so i can do the trading combine with topstep am going to cancel my rithmic account because it's not working it was made for bookmap and i don't know where to find the market data username and i can't set it up, i want to be able to trade ES/NQ and the mini what do i need |
[2024-07-18 17:46:21] |
To begin with, you should have a Rithmic Username and Password from TopStep. This will be different from what you use with Bookmap. You need to enter those credentials in all 3 of the sections on the "Data/Trade Service Settings" related to Rithmic (i.e. the Trading Username/Password, the Market Data Username/Password, and the Historical Data Username/Password). All of the information to connect to your Rithmic account is located at the following link: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-18 20:09:08] |
thanks i got it connected but am getting this message
[2024-07-18 20:18:34] |
Due to the lack of historical data with Rithmic, we do NOT recommend using a Continuous Futures Contract Chart with their data. Be sure to set the following option to "None": Chart Settings: Continuous Contract (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
